--- ray/src/util/rmatrix.c 2023/11/28 00:46:23 2.63 +++ ray/src/util/rmatrix.c 2023/12/05 01:06:10 2.70 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rmatrix.c,v 2.63 2023/11/28 00:46:23 greg Exp $"; +static const char RCSid[] = "$Id: rmatrix.c,v 2.70 2023/12/05 01:06:10 greg Exp $"; #endif /* * General matrix operations. @@ -31,14 +31,16 @@ rmx_new(int nr, int nc, int n) return(NULL); dnew = (RMATRIX *)calloc(1, sizeof(RMATRIX)); - if (dnew) { - dnew->dtype = DTdouble; - dnew->nrows = nr; - dnew->ncols = nc; - dnew->ncomp = n; - setcolor(dnew->cexp, 1.f, 1.f, 1.f); - memcpy(dnew->wlpart, WLPART, sizeof(dnew->wlpart)); - } + if (!dnew) + return(NULL); + + dnew->dtype = DTdouble; + dnew->nrows = nr; + dnew->ncols = nc; + dnew->ncomp = n; + setcolor(dnew->cexp, 1.f, 1.f, 1.f); + memcpy(dnew->wlpart, WLPART, sizeof(dnew->wlpart)); + return(dnew); } @@ -68,19 +70,33 @@ rmx_alloc(int nr, int nc, int n) return(dnew); } -/* Free a RMATRIX array */ +/* Clear state by freeing info and matrix data */ void -rmx_free(RMATRIX *rm) +rmx_reset(RMATRIX *rm) { if (!rm) return; - if (rm->info) + if (rm->info) { free(rm->info); + rm->info = NULL; + } + if (rm->mtx) { #ifdef MAP_FILE - if (rm->mapped) - munmap(rm->mapped, mapped_size(rm)); - else + if (rm->mapped) { + munmap(rm->mapped, mapped_size(rm)); + rm->mapped = NULL; + } else #endif - free(rm->mtx); + free(rm->mtx); + rm->mtx = NULL; + } +} + +/* Free an RMATRIX struct and data */ +void +rmx_free(RMATRIX *rm) +{ + if (!rm) return; + rmx_reset(rm); free(rm); } @@ -172,133 +188,90 @@ get_dminfo(char *s, void *p) } static int -rmx_load_ascii(RMATRIX *rm, FILE *fp) +rmx_load_ascii(double *drp, const RMATRIX *rm, FILE *fp) { - int i, j, k; + int j, k; - if (!rmx_prepare(rm)) - return(0); - for (i = 0; i < rm->nrows; i++) - for (j = 0; j < rm->ncols; j++) { - double *dp = rmx_lval(rm,i,j); - for (k = 0; k < rm->ncomp; k++) - if (fscanf(fp, "%lf", &dp[k]) != 1) - return(0); - } + for (j = 0; j < rm->ncols; j++) + for (k = rm->ncomp; k-- > 0; ) + if (fscanf(fp, "%lf", drp++) != 1) + return(0); return(1); } static int -rmx_load_float(RMATRIX *rm, FILE *fp) +rmx_load_float(double *drp, const RMATRIX *rm, FILE *fp) { - int i, j, k; + int j, k; float val[100]; if (rm->ncomp > 100) { fputs("Unsupported # components in rmx_load_float()\n", stderr); exit(1); } - if (!rmx_prepare(rm)) - return(0); - for (i = 0; i < rm->nrows; i++) - for (j = 0; j < rm->ncols; j++) { - double *dp = rmx_lval(rm,i,j); + for (j = 0; j < rm->ncols; j++) { if (getbinary(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp) - return(0); + return(0); if (rm->swapin) - swap32((char *)val, rm->ncomp); - for (k = rm->ncomp; k--; ) - dp[k] = val[k]; - } + swap32((char *)val, rm->ncomp); + for (k = 0; k < rm->ncomp; k++) + *drp++ = val[k]; + } return(1); } static int -rmx_load_double(RMATRIX *rm, FILE *fp) +rmx_load_double(double *drp, const RMATRIX *rm, FILE *fp) { - int i; -#ifdef MAP_FILE - long pos; /* map memory for file > 1MB if possible */ - if (!rm->swapin && array_size(rm) >= 1L<<20 && - (pos = ftell(fp)) >= 0 && !(pos % sizeof(double))) { - rm->mapped = mmap(NULL, array_size(rm)+pos, PROT_READ|PROT_WRITE, - MAP_PRIVATE, fileno(fp), 0); - if (rm->mapped != MAP_FAILED) { - rm->mtx = (double *)rm->mapped + pos/sizeof(double); - return(1); - } /* else fall back on reading into memory */ - rm->mapped = NULL; - } -#endif - if (!rmx_prepare(rm)) + if (getbinary(drp, sizeof(*drp)*rm->ncomp, rm->ncols, fp) != rm->ncols) return(0); - for (i = 0; i < rm->nrows; i++) { - if (getbinary(rmx_lval(rm,i,0), sizeof(double)*rm->ncomp, - rm->ncols, fp) != rm->ncols) - return(0); - if (rm->swapin) - swap64((char *)rmx_lval(rm,i,0), rm->ncols*rm->ncomp); - } + if (rm->swapin) + swap64((char *)drp, rm->ncols*rm->ncomp); return(1); } static int -rmx_load_rgbe(RMATRIX *rm, FILE *fp) +rmx_load_rgbe(double *drp, const RMATRIX *rm, FILE *fp) { - COLOR *scan = (COLOR *)malloc(sizeof(COLOR)*rm->ncols); - int i, j; + COLR *scan; + COLOR col; + int j; + if (rm->ncomp != 3) + return(0); + scan = (COLR *)tempbuffer(sizeof(COLR)*rm->ncols); if (!scan) return(0); - if (!rmx_prepare(rm)) { - free(scan); + if (freadcolrs(scan, rm->ncols, fp) < 0) return(0); + for (j = 0; j < rm->ncols; j++) { + colr_color(col, scan[j]); + *drp++ = colval(col,RED); + *drp++ = colval(col,GRN); + *drp++ = colval(col,BLU); } - for (i = 0; i < rm->nrows; i++) { - double *dp = rmx_lval(rm,i,0); - if (freadscan(scan, rm->ncols, fp) < 0) { - free(scan); - return(0); - } - for (j = 0; j < rm->ncols; j++, dp += 3) { - dp[0] = colval(scan[j],RED); - dp[1] = colval(scan[j],GRN); - dp[2] = colval(scan[j],BLU); - } - } - free(scan); return(1); } static int -rmx_load_spec(RMATRIX *rm, FILE *fp) +rmx_load_spec(double *drp, const RMATRIX *rm, FILE *fp) { uby8 *scan; SCOLOR scol; - int i, j, k; + int j, k; - if (rm->ncomp < 3) + if ((rm->ncomp < 3) | (rm->ncomp > MAXCSAMP)) return(0); - scan = (uby8 *)malloc((rm->ncomp+1)*rm->ncols); + scan = (uby8 *)tempbuffer((rm->ncomp+1)*rm->ncols); if (!scan) return(0); - if (!rmx_prepare(rm)) { - free(scan); + if (freadscolrs(scan, rm->ncomp, rm->ncols, fp) < 0) return(0); + for (j = 0; j < rm->ncols; j++) { + scolr2scolor(scol, scan+j*(rm->ncomp+1), rm->ncomp); + for (k = 0; k < rm->ncomp; k++) + *drp++ = scol[k]; } - for (i = 0; i < rm->nrows; i++) { - double *dp = rmx_lval(rm,i,0); - if (freadscolrs(scan, rm->ncomp, rm->ncols, fp) < 0) { - free(scan); - return(0); - } - for (j = 0; j < rm->ncols; j++) { - scolr2scolor(scol, scan+j*(rm->ncomp+1), rm->ncomp); - for (k = 0; k < rm->ncomp; k++) - *dp++ = scol[k]; - } - } - free(scan); return(1); } @@ -308,20 +281,7 @@ rmx_load_header(RMATRIX *rm, FILE *fp) { if (!rm | !fp) return(0); - if (rm->info) { /* clear state */ - free(rm->info); - rm->info = NULL; - } - if (rm->mtx) { /* ...and data */ -#ifdef MAP_FILE - if (rm->mapped) { - munmap(rm->mapped, mapped_size(rm)); - rm->mapped = NULL; - } else -#endif - free(rm->mtx); - rm->mtx = NULL; - } + rmx_reset(rm); /* clear state */ if (rm->nrows | rm->ncols | !rm->dtype) { rm->nrows = rm->ncols = 0; rm->ncomp = 3; @@ -329,46 +289,75 @@ rmx_load_header(RMATRIX *rm, FILE *fp) memcpy(rm->wlpart, WLPART, sizeof(rm->wlpart)); rm->swapin = 0; } - SET_FILE_BINARY(fp); rm->dtype = DTascii; /* assumed w/o FORMAT */ if (getheader(fp, get_dminfo, rm) < 0) { fputs("Unrecognized matrix format\n", stderr); return(0); } - /* resolution string? */ - if ((rm->nrows <= 0) | (rm->ncols <= 0)) { - if (!fscnresolu(&rm->ncols, &rm->nrows, fp)) - return(0); - if ((rm->dtype == DTrgbe) | (rm->dtype == DTxyze) && - rm->ncomp != 3) - return(0); - } + if ((rm->dtype == DTrgbe) | (rm->dtype == DTxyze) && + rm->ncomp != 3) + return(0); + if (rm->ncols <= 0 && /* resolution string? */ + !fscnresolu(&rm->ncols, &rm->nrows, fp)) + return(0); + if (rm->dtype == DTascii) /* set file type (WINDOWS) */ + SET_FILE_TEXT(fp); + else + SET_FILE_BINARY(fp); return(1); } -/* Allocate & load post-header data from stream given type set in rm->dtype */ +/* Load next row as double (cannot be XML) */ int -rmx_load_data(RMATRIX *rm, FILE *fp) +rmx_load_row(double *drp, const RMATRIX *rm, FILE *fp) { switch (rm->dtype) { case DTascii: - SET_FILE_TEXT(fp); - return(rmx_load_ascii(rm, fp)); + return(rmx_load_ascii(drp, rm, fp)); case DTfloat: - return(rmx_load_float(rm, fp)); + return(rmx_load_float(drp, rm, fp)); case DTdouble: - return(rmx_load_double(rm, fp)); + return(rmx_load_double(drp, rm, fp)); case DTrgbe: case DTxyze: - return(rmx_load_rgbe(rm, fp)); + return(rmx_load_rgbe(drp, rm, fp)); case DTspec: - return(rmx_load_spec(rm, fp)); + return(rmx_load_spec(drp, rm, fp)); default: - fputs("Unsupported data type in rmx_loaddata()\n", stderr); + fputs("Unsupported data type in rmx_load_row()\n", stderr); } return(0); } +/* Allocate & load post-header data from stream given type set in rm->dtype */ +int +rmx_load_data(RMATRIX *rm, FILE *fp) +{ + int i; +#ifdef MAP_FILE + long pos; /* map memory for file > 1MB if possible */ + if ((rm->dtype == DTdouble) & !rm->swapin && array_size(rm) >= 1L<<20 && + (pos = ftell(fp)) >= 0 && !(pos % sizeof(double))) { + rm->mapped = mmap(NULL, array_size(rm)+pos, PROT_READ|PROT_WRITE, + MAP_PRIVATE, fileno(fp), 0); + if (rm->mapped != MAP_FAILED) { + rm->mtx = (double *)rm->mapped + pos/sizeof(double); + return(1); + } /* else fall back on reading into memory */ + rm->mapped = NULL; + } +#endif + if (!rmx_prepare(rm)) { /* need in-core matrix array */ + fprintf(stderr, "Cannot allocate %g MByte matrix array\n", + (1./(1L<<20))*(double)array_size(rm)); + return(0); + } + for (i = 0; i < rm->nrows; i++) + if (!rmx_load_row(rmx_lval(rm,i,0), rm, fp)) + return(0); + return(1); +} + /* Load matrix from supported file type */ RMATRIX * rmx_load(const char *inspec, RMPref rmp) @@ -385,7 +374,7 @@ rmx_load(const char *inspec, RMPref rmp) fp = stdin; else if (inspec[0] == '!') fp = popen(inspec+1, "r"); - else { + else if (rmp != RMPnone) { const char *sp = inspec; /* check suffix */ while (*sp) ++sp; @@ -408,7 +397,7 @@ rmx_load(const char *inspec, RMPref rmp) #ifdef getc_unlocked flockfile(fp); #endif - /* load header info */ + SET_FILE_BINARY(fp); /* load header info */ if (!rmx_load_header(dnew = rmx_new(0,0,3), fp)) { fprintf(stderr, "Bad header in: %s\n", inspec); if (inspec[0] == '!') pclose(fp); @@ -456,107 +445,65 @@ rmx_load(const char *inspec, RMPref rmp) } static int -rmx_write_ascii(const RMATRIX *rm, FILE *fp) +rmx_write_ascii(const double *dp, int nc, int len, FILE *fp) { - const char *fmt = (rm->dtype == DTfloat) ? " %.7e" : - (rm->dtype == DTrgbe) | (rm->dtype == DTxyze) | - (rm->dtype == DTspec) ? " %.3e" : " %.15e" ; - int i, j, k; - - for (i = 0; i < rm->nrows; i++) { - for (j = 0; j < rm->ncols; j++) { - const double *dp = rmx_val(rm,i,j); - for (k = 0; k < rm->ncomp; k++) - fprintf(fp, fmt, dp[k]); + while (len-- > 0) { + int k = nc; + while (nc-- > 0) + fprintf(fp, " %.7e", *dp++); fputc('\t', fp); - } - fputc('\n', fp); } - return(1); + return(fputc('\n', fp) != EOF); } static int -rmx_write_float(const RMATRIX *rm, FILE *fp) +rmx_write_float(const double *dp, int len, FILE *fp) { - int i, j, k; - float val[100]; + float val; - if (rm->ncomp > 100) { - fputs("Unsupported # components in rmx_write_float()\n", stderr); - exit(1); - } - for (i = 0; i < rm->nrows; i++) - for (j = 0; j < rm->ncols; j++) { - const double *dp = rmx_val(rm,i,j); - for (k = rm->ncomp; k--; ) - val[k] = (float)dp[k]; - if (putbinary(val, sizeof(float), rm->ncomp, fp) != rm->ncomp) + while (len--) { + val = *dp++; + if (putbinary(&val, sizeof(float), 1, fp) != 1) return(0); - } + } return(1); } static int -rmx_write_double(const RMATRIX *rm, FILE *fp) +rmx_write_rgbe(const double *dp, int nc, int len, FILE *fp) { - int i; + COLR *scan; + int j; - for (i = 0; i < rm->nrows; i++) - if (putbinary(rmx_val(rm,i,0), sizeof(double)*rm->ncomp, - rm->ncols, fp) != rm->ncols) - return(0); - return(1); -} + if ((nc != 1) & (nc != 3)) return(0); + scan = (COLR *)tempbuffer(sizeof(COLR)*len); + if (!scan) return(0); -static int -rmx_write_rgbe(const RMATRIX *rm, FILE *fp) -{ - COLR *scan = (COLR *)malloc(sizeof(COLR)*rm->ncols); - int i, j; - - if (!scan) - return(0); - for (i = 0; i < rm->nrows; i++) { - for (j = rm->ncols; j--; ) { - const double *dp = rmx_val(rm,i,j); - if (rm->ncomp == 1) + for (j = 0; j < len; j++, dp += nc) + if (nc == 1) setcolr(scan[j], dp[0], dp[0], dp[0]); else setcolr(scan[j], dp[0], dp[1], dp[2]); - } - if (fwritecolrs(scan, rm->ncols, fp) < 0) { - free(scan); - return(0); - } - } - free(scan); - return(1); + + return(fwritecolrs(scan, len, fp) >= 0); } static int -rmx_write_spec(const RMATRIX *rm, FILE *fp) +rmx_write_spec(const double *dp, int nc, int len, FILE *fp) { - uby8 *scan = (uby8 *)malloc((rm->ncomp+1)*rm->ncols); - int ok = 1; + uby8 *scan; SCOLOR scol; - int i, j, k; + int j, k; - if (!scan) - return(0); - for (i = 0; i < rm->nrows; i++) { - for (j = rm->ncols; j--; ) { - const double *dp = rmx_val(rm,i,j); - for (k = rm->ncomp; k--; ) + if (nc < 3) return(0); + scan = (uby8 *)tempbuffer((nc+1)*len); + if (!scan) return(0); + for (j = len; j--; dp += nc) { + for (k = nc; k--; ) scol[k] = dp[k]; - scolor2scolr(scan+j*(rm->ncomp+1), scol, rm->ncomp); - } - if (fwritescolrs(scan, rm->ncomp, rm->ncols, fp) < 0) { - ok = 0; - break; - } + scolor2scolr(scan+j*(nc+1), scol, nc); } - free(scan); - return(ok); + return(fwritescolrs(scan, nc, len, fp) >= 0); } /* Check if CIE XYZ primaries were specified */ @@ -576,18 +523,12 @@ findCIEprims(const char *info) (prims[BLU][CIEX] < .01) & (prims[BLU][CIEY] < .01)); } -/* Write matrix to file type indicated by dtype */ +/* Finish writing header data with resolution and format, returning type used */ int -rmx_write(const RMATRIX *rm, int dtype, FILE *fp) +rmx_write_header(const RMATRIX *rm, int dtype, FILE *fp) { - int ok = 1; - - if (!rm | !fp || !rm->mtx) + if (!rm | !fp || rm->ncols <= 0) return(0); -#ifdef getc_unlocked - flockfile(fp); -#endif - /* complete header */ if (rm->info) fputs(rm->info, fp); if (dtype == DTfromHeader) @@ -597,52 +538,86 @@ rmx_write(const RMATRIX *rm, int dtype, FILE *fp) dtype = DTxyze; else if ((dtype == DTxyze) & (rm->dtype == DTrgbe)) dtype = DTrgbe; + if ((dtype == DTspec) & (rm->ncomp < 3)) + return(0); + + if (dtype == DTascii) /* set file type (WINDOWS) */ + SET_FILE_TEXT(fp); + else + SET_FILE_BINARY(fp); /* write exposure? */ if (rm->ncomp == 3 && (rm->cexp[RED] != rm->cexp[GRN]) | (rm->cexp[GRN] != rm->cexp[BLU])) fputcolcor(rm->cexp, fp); else if (rm->cexp[GRN] != 1.f) fputexpos(rm->cexp[GRN], fp); - if ((dtype != DTrgbe) & (dtype != DTxyze)) { - if (dtype == DTspec) { - if (rm->ncomp < 3) - return(0); /* bad # components */ - fputwlsplit(rm->wlpart, fp); - } else { + /* matrix size? */ + if ((dtype > DTspec) | (rm->nrows <= 0)) { + if (rm->nrows > 0) fprintf(fp, "NROWS=%d\n", rm->nrows); - fprintf(fp, "NCOLS=%d\n", rm->ncols); - } + fprintf(fp, "NCOLS=%d\n", rm->ncols); + } + if (dtype >= DTspec) { /* # components & split? */ fputncomp(rm->ncomp, fp); + if (dtype == DTspec || (rm->ncomp > 3 && + memcmp(rm->wlpart, WLPART, sizeof(WLPART)))) + fputwlsplit(rm->wlpart, fp); } else if ((rm->ncomp != 3) & (rm->ncomp != 1)) return(0); /* wrong # components */ if ((dtype == DTfloat) | (dtype == DTdouble)) fputendian(fp); /* important to record */ fputformat(cm_fmt_id[dtype], fp); - fputc('\n', fp); - switch (dtype) { /* write data */ + fputc('\n', fp); /* end of header */ + if ((dtype <= DTspec) & (rm->nrows > 0)) + fprtresolu(rm->ncols, rm->nrows, fp); + return(dtype); +} + +/* Write out matrix data (usually by row) */ +int +rmx_write_data(const double *dp, int nc, int len, int dtype, FILE *fp) +{ + switch (dtype) { case DTascii: - ok = rmx_write_ascii(rm, fp); - break; + return(rmx_write_ascii(dp, nc, len, fp)); case DTfloat: - ok = rmx_write_float(rm, fp); - break; + return(rmx_write_float(dp, nc*len, fp)); case DTdouble: - ok = rmx_write_double(rm, fp); - break; + return(putbinary(dp, sizeof(*dp)*nc, len, fp) == len); case DTrgbe: case DTxyze: - fprtresolu(rm->ncols, rm->nrows, fp); - ok = rmx_write_rgbe(rm, fp); - break; + return(rmx_write_rgbe(dp, nc, len, fp)); case DTspec: - fprtresolu(rm->ncols, rm->nrows, fp); - ok = rmx_write_spec(rm, fp); - break; - default: - return(0); + return(rmx_write_spec(dp, nc, len, fp)); } - ok &= (fflush(fp) == 0); + return(0); +} + +/* Write matrix using file format indicated by dtype */ +int +rmx_write(const RMATRIX *rm, int dtype, FILE *fp) +{ + int ok = 0; + int i; + /* complete header */ + dtype = rmx_write_header(rm, dtype, fp); + if (dtype <= 0) + return(0); #ifdef getc_unlocked + flockfile(fp); +#endif + if (dtype == DTdouble) /* write all at once? */ + ok = rmx_write_data(rm->mtx, rm->ncomp, + rm->nrows*rm->ncols, dtype, fp); + else /* else row by row */ + for (i = 0; i < rm->nrows; i++) { + ok = rmx_write_data(rmx_val(rm,i,0), rm->ncomp, + rm->ncols, dtype, fp); + if (!ok) break; + } + + if (ok) ok = (fflush(fp) == 0); +#ifdef getc_unlocked funlockfile(fp); #endif if (!ok) fputs("Error writing matrix\n", stderr); @@ -667,7 +642,7 @@ rmx_identity(const int dim, const int n) return(rid); } -/* Duplicate the given matrix */ +/* Duplicate the given matrix (may be unallocated) */ RMATRIX * rmx_copy(const RMATRIX *rm) { @@ -675,14 +650,20 @@ rmx_copy(const RMATRIX *rm) if (!rm) return(NULL); - dnew = rmx_alloc(rm->nrows, rm->ncols, rm->ncomp); + dnew = rmx_new(rm->nrows, rm->ncols, rm->ncomp); if (!dnew) return(NULL); + if (rm->mtx) { + if (!rmx_prepare(dnew)) { + rmx_free(dnew); + return(NULL); + } + memcpy(dnew->mtx, rm->mtx, array_size(dnew)); + } rmx_addinfo(dnew, rm->info); dnew->dtype = rm->dtype; copycolor(dnew->cexp, rm->cexp); memcpy(dnew->wlpart, rm->wlpart, sizeof(dnew->wlpart)); - memcpy(dnew->mtx, rm->mtx, array_size(dnew)); return(dnew); } @@ -693,7 +674,7 @@ rmx_transpose(const RMATRIX *rm) RMATRIX *dnew; int i, j; - if (!rm) + if (!rm || !rm->mtx) return(0); if ((rm->nrows == 1) | (rm->ncols == 1)) { dnew = rmx_copy(rm); @@ -727,7 +708,8 @@ rmx_multiply(const RMATRIX *m1, const RMATRIX *m2) RMATRIX *mres; int i, j, k, h; - if (!m1 | !m2 || (m1->ncomp != m2->ncomp) | (m1->ncols != m2->nrows)) + if (!m1 | !m2 || !m1->mtx | !m2->mtx | + (m1->ncomp != m2->ncomp) | (m1->ncols != m2->nrows)) return(NULL); mres = rmx_alloc(m1->nrows, m2->ncols, m1->ncomp); if (!mres) @@ -755,7 +737,8 @@ rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide int zeroDivides = 0; int i, j, k; - if (!m1 | !m2 || (m1->ncols != m2->ncols) | (m1->nrows != m2->nrows)) + if (!m1 | !m2 || !m1->mtx | !m2->mtx | + (m1->ncols != m2->ncols) | (m1->nrows != m2->nrows)) return(0); if ((m2->ncomp > 1) & (m2->ncomp != m1->ncomp)) return(0); @@ -811,7 +794,7 @@ rmx_sum(RMATRIX *msum, const RMATRIX *madd, const doub double *mysf = NULL; int i, j, k; - if (!msum | !madd || + if (!msum | !madd || !msum->mtx | !madd->mtx | (msum->nrows != madd->nrows) | (msum->ncols != madd->ncols) | (msum->ncomp != madd->ncomp)) @@ -847,7 +830,7 @@ rmx_scale(RMATRIX *rm, const double sf[]) { int i, j, k; - if (!rm | !sf) + if (!rm | !sf || !rm->mtx) return(0); for (i = rm->nrows; i--; ) for (j = rm->ncols; j--; ) { @@ -868,7 +851,7 @@ rmx_transform(const RMATRIX *msrc, int n, const double int i, j, ks, kd; RMATRIX *dnew; - if (!msrc | (n <= 0) | !cmat) + if (!msrc | (n <= 0) | !cmat || !msrc->mtx) return(NULL); dnew = rmx_alloc(msrc->nrows, msrc->ncols, n); if (!dnew)
