--- ray/src/util/rmatrix.c 2023/12/02 16:28:35 2.68 +++ ray/src/util/rmatrix.c 2023/12/08 00:12:31 2.74 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rmatrix.c,v 2.68 2023/12/02 16:28:35 greg Exp $"; +static const char RCSid[] = "$Id: rmatrix.c,v 2.74 2023/12/08 00:12:31 greg Exp $"; #endif /* * General matrix operations. @@ -31,14 +31,16 @@ rmx_new(int nr, int nc, int n) return(NULL); dnew = (RMATRIX *)calloc(1, sizeof(RMATRIX)); - if (dnew) { - dnew->dtype = DTdouble; - dnew->nrows = nr; - dnew->ncols = nc; - dnew->ncomp = n; - setcolor(dnew->cexp, 1.f, 1.f, 1.f); - memcpy(dnew->wlpart, WLPART, sizeof(dnew->wlpart)); - } + if (!dnew) + return(NULL); + + dnew->dtype = DTdouble; + dnew->nrows = nr; + dnew->ncols = nc; + dnew->ncomp = n; + setcolor(dnew->cexp, 1.f, 1.f, 1.f); + memcpy(dnew->wlpart, WLPART, sizeof(dnew->wlpart)); + return(dnew); } @@ -372,14 +374,15 @@ rmx_load(const char *inspec, RMPref rmp) fp = stdin; else if (inspec[0] == '!') fp = popen(inspec+1, "r"); - else if (rmp != RMPnone) { + else { const char *sp = inspec; /* check suffix */ while (*sp) ++sp; while (sp > inspec && sp[-1] != '.') --sp; if (!strcasecmp(sp, "XML")) { /* assume it's a BSDF */ - CMATRIX *cm = rmp==RMPtrans ? cm_loadBTDF(inspec) : + CMATRIX *cm = rmp==RMPnone ? (CMATRIX *)NULL : + rmp==RMPtrans ? cm_loadBTDF(inspec) : cm_loadBRDF(inspec, rmp==RMPreflB) ; if (!cm) return(NULL); @@ -447,7 +450,7 @@ rmx_write_ascii(const double *dp, int nc, int len, FIL { while (len-- > 0) { int k = nc; - while (nc-- > 0) + while (k-- > 0) fprintf(fp, " %.7e", *dp++); fputc('\t', fp); } @@ -525,7 +528,7 @@ findCIEprims(const char *info) int rmx_write_header(const RMATRIX *rm, int dtype, FILE *fp) { - if (!rm | !fp || !rm->mtx | (rm->ncols <= 0)) + if (!rm | !fp || rm->ncols <= 0) return(0); if (rm->info) fputs(rm->info, fp); @@ -536,7 +539,7 @@ rmx_write_header(const RMATRIX *rm, int dtype, FILE *f dtype = DTxyze; else if ((dtype == DTxyze) & (rm->dtype == DTrgbe)) dtype = DTrgbe; - if ((dtype == DTspec) & (rm->ncomp < 3)) + if ((dtype == DTspec) & (rm->ncomp <= 3)) return(0); if (dtype == DTascii) /* set file type (WINDOWS) */ @@ -557,8 +560,8 @@ rmx_write_header(const RMATRIX *rm, int dtype, FILE *f } if (dtype >= DTspec) { /* # components & split? */ fputncomp(rm->ncomp, fp); - if (dtype == DTspec || (rm->ncomp > 3 && - memcmp(rm->wlpart, WLPART, sizeof(WLPART)))) + if (rm->ncomp > 3 && + memcmp(rm->wlpart, WLPART, sizeof(WLPART))) fputwlsplit(rm->wlpart, fp); } else if ((rm->ncomp != 3) & (rm->ncomp != 1)) return(0); /* wrong # components */ @@ -640,23 +643,53 @@ rmx_identity(const int dim, const int n) return(rid); } -/* Duplicate the given matrix */ +/* Duplicate the given matrix (may be unallocated) */ RMATRIX * rmx_copy(const RMATRIX *rm) { RMATRIX *dnew; - if (!rm || !rm->mtx) + if (!rm) return(NULL); - dnew = rmx_alloc(rm->nrows, rm->ncols, rm->ncomp); + dnew = rmx_new(rm->nrows, rm->ncols, rm->ncomp); if (!dnew) return(NULL); + if (rm->mtx) { + if (!rmx_prepare(dnew)) { + rmx_free(dnew); + return(NULL); + } + memcpy(dnew->mtx, rm->mtx, array_size(dnew)); + } rmx_addinfo(dnew, rm->info); dnew->dtype = rm->dtype; copycolor(dnew->cexp, rm->cexp); memcpy(dnew->wlpart, rm->wlpart, sizeof(dnew->wlpart)); - memcpy(dnew->mtx, rm->mtx, array_size(dnew)); return(dnew); +} + +/* Replace data in first matrix with data from second */ +int +rmx_transfer_data(RMATRIX *rdst, RMATRIX *rsrc, int dometa) +{ + if (!rdst | !rsrc || (rdst->nrows != rsrc->nrows) | + (rdst->ncols != rsrc->ncols) | + (rdst->ncomp != rsrc->ncomp)) + return(0); + + if (dometa) { /* transfer everything? */ + rmx_reset(rdst); + *rdst = *rsrc; + rsrc->info = NULL; rsrc->mapped = NULL; rsrc->mtx = NULL; + return(1); + } + if (rdst->mapped) + return(0); /* XXX can't handle this case */ + /* just matrix data -- leave metadata */ + if (rdst->mtx) free(rdst->mtx); + rdst->mtx = rsrc->mtx; + rsrc->mtx = NULL; + return(1); } /* Allocate and assign transposed matrix */
