--- ray/src/util/rmatrix.c 2023/11/27 22:04:45 2.61 +++ ray/src/util/rmatrix.c 2023/11/28 00:39:56 2.62 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rmatrix.c,v 2.61 2023/11/27 22:04:45 greg Exp $"; +static const char RCSid[] = "$Id: rmatrix.c,v 2.62 2023/11/28 00:39:56 greg Exp $"; #endif /* * General matrix operations. @@ -302,23 +302,89 @@ rmx_load_spec(RMATRIX *rm, FILE *fp) return(1); } +/* Read matrix header from input stream (cannot be XML) */ +int +rmx_load_header(RMATRIX *rm, FILE *fp) +{ + if (!rm | !fp) + return(-1); + if (rm->info) { /* clear state */ + free(rm->info); + rm->info = NULL; + } + if (rm->mtx) { /* ...and data */ +#ifdef MAP_FILE + if (rm->mapped) { + munmap(rm->mapped, mapped_size(rm)); + rm->mapped = NULL; + } else +#endif + free(rm->mtx); + rm->mtx = NULL; + } + if (rm->nrows | rm->ncols | !rm->dtype) { + rm->nrows = rm->ncols = 0; + rm->ncomp = 3; + setcolor(rm->cexp, 1.f, 1.f, 1.f); + memcpy(rm->wlpart, WLPART, sizeof(rm->wlpart)); + } + SET_FILE_BINARY(fp); + rm->dtype = DTascii; /* assumed w/o FORMAT */ + if (getheader(fp, get_dminfo, rm) < 0) { + fputs("Unrecognized matrix format\n", stderr); + return(-1); + } + /* resolution string? */ + if ((rm->nrows <= 0) | (rm->ncols <= 0)) { + if (!fscnresolu(&rm->ncols, &rm->nrows, fp)) + return(-1); + if ((rm->dtype == DTrgbe) | (rm->dtype == DTxyze) && + rm->ncomp != 3) + return(-1); + } + return(rm->dtype); +} + +/* Allocate & load post-header data from stream given type set in rm->dtype */ +int +rmx_load_data(RMATRIX *rm, FILE *fp) +{ + switch (rm->dtype) { + case DTascii: + SET_FILE_TEXT(fp); + return(rmx_load_ascii(rm, fp)); + case DTfloat: + return(rmx_load_float(rm, fp)); + case DTdouble: + return(rmx_load_double(rm, fp)); + case DTrgbe: + case DTxyze: + return(rmx_load_rgbe(rm, fp)); + case DTspec: + return(rmx_load_spec(rm, fp)); + default: + fputs("Unsupported data type in rmx_loaddata()\n", stderr); + } + return(0); +} + /* Load matrix from supported file type */ RMATRIX * rmx_load(const char *inspec, RMPref rmp) { FILE *fp; RMATRIX *dnew; + int ok; if (!inspec) inspec = stdin_name; else if (!*inspec) return(NULL); - if (inspec == stdin_name) { /* reading from stdin? */ + if (inspec == stdin_name) /* reading from stdin? */ fp = stdin; - } else if (inspec[0] == '!') { - if (!(fp = popen(inspec+1, "r"))) - return(NULL); - } else { + else if (inspec[0] == '!') + fp = popen(inspec+1, "r"); + else { const char *sp = inspec; /* check suffix */ while (*sp) ++sp; @@ -332,66 +398,26 @@ rmx_load(const char *inspec, RMPref rmp) dnew = rmx_from_cmatrix(cm); cm_free(cm); dnew->dtype = DTascii; - return(dnew); - } - /* else open it ourselves */ - if (!(fp = fopen(inspec, "r"))) - return(NULL); + return(dnew); /* return here */ + } /* else open it ourselves */ + fp = fopen(inspec, "r"); } - SET_FILE_BINARY(fp); + if (!fp) + return(NULL); #ifdef getc_unlocked flockfile(fp); #endif - if (!(dnew = rmx_new(0,0,3))) { - fclose(fp); + /* load header info */ + if (rmx_load_header(dnew = rmx_new(0,0,3), fp) < 0) { + fprintf(stderr, "Bad header in: %s\n", inspec); + if (inspec[0] == '!') pclose(fp); + else fclose(fp); + rmx_free(dnew); return(NULL); } - dnew->dtype = DTascii; /* assumed w/o FORMAT */ - if (getheader(fp, get_dminfo, dnew) < 0) { - fclose(fp); - return(NULL); - } - if ((dnew->nrows <= 0) | (dnew->ncols <= 0)) { - if (!fscnresolu(&dnew->ncols, &dnew->nrows, fp)) { - fclose(fp); - return(NULL); - } - if ((dnew->dtype == DTrgbe) | (dnew->dtype == DTxyze) && - dnew->ncomp != 3) { - fclose(fp); - return(NULL); - } - } - switch (dnew->dtype) { - case DTascii: - SET_FILE_TEXT(fp); - if (!rmx_load_ascii(dnew, fp)) - goto loaderr; - dnew->dtype = DTascii; /* should leave double? */ - break; - case DTfloat: - if (!rmx_load_float(dnew, fp)) - goto loaderr; - dnew->dtype = DTfloat; - break; - case DTdouble: - if (!rmx_load_double(dnew, fp)) - goto loaderr; - dnew->dtype = DTdouble; - break; - case DTrgbe: - case DTxyze: - if (!rmx_load_rgbe(dnew, fp)) - goto loaderr; - break; - case DTspec: - if (!rmx_load_spec(dnew, fp)) - goto loaderr; - break; - default: - goto loaderr; - } - if (fp != stdin) { + ok = rmx_load_data(dnew, fp); /* allocate & load data */ + + if (fp != stdin) { /* close input stream */ if (inspec[0] == '!') pclose(fp); else @@ -401,6 +427,11 @@ rmx_load(const char *inspec, RMPref rmp) else funlockfile(fp); #endif + if (!ok) { /* load failure? */ + fprintf(stderr, "Error loading data from: %s\n", inspec); + rmx_free(dnew); + return(NULL); + } /* undo exposure? */ if ((dnew->cexp[0] != 1.f) | (dnew->cexp[1] != 1.f) | (dnew->cexp[2] != 1.f)) { @@ -409,21 +440,18 @@ rmx_load(const char *inspec, RMPref rmp) cmlt[0] = 1./dnew->cexp[0]; cmlt[1] = 1./dnew->cexp[1]; cmlt[2] = 1./dnew->cexp[2]; - if (dnew->ncomp > MAXCSAMP) - goto loaderr; + if (dnew->ncomp > MAXCSAMP) { + fprintf(stderr, "Excess spectral components in: %s\n", + inspec); + rmx_free(dnew); + return(NULL); + } for (i = dnew->ncomp; i-- > 3; ) cmlt[i] = cmlt[1]; rmx_scale(dnew, cmlt); setcolor(dnew->cexp, 1.f, 1.f, 1.f); } return(dnew); -loaderr: /* should report error? */ - if (inspec[0] == '!') - pclose(fp); - else - fclose(fp); - rmx_free(dnew); - return(NULL); } static int @@ -436,7 +464,7 @@ rmx_write_ascii(const RMATRIX *rm, FILE *fp) for (i = 0; i < rm->nrows; i++) { for (j = 0; j < rm->ncols; j++) { - const double *dp = rmx_lval(rm,i,j); + const double *dp = rmx_val(rm,i,j); for (k = 0; k < rm->ncomp; k++) fprintf(fp, fmt, dp[k]); fputc('\t', fp); @@ -458,7 +486,7 @@ rmx_write_float(const RMATRIX *rm, FILE *fp) } for (i = 0; i < rm->nrows; i++) for (j = 0; j < rm->ncols; j++) { - const double *dp = rmx_lval(rm,i,j); + const double *dp = rmx_val(rm,i,j); for (k = rm->ncomp; k--; ) val[k] = (float)dp[k]; if (putbinary(val, sizeof(float), rm->ncomp, fp) != rm->ncomp) @@ -473,7 +501,7 @@ rmx_write_double(const RMATRIX *rm, FILE *fp) int i; for (i = 0; i < rm->nrows; i++) - if (putbinary(rmx_lval(rm,i,0), sizeof(double)*rm->ncomp, + if (putbinary(rmx_val(rm,i,0), sizeof(double)*rm->ncomp, rm->ncols, fp) != rm->ncols) return(0); return(1); @@ -489,7 +517,7 @@ rmx_write_rgbe(const RMATRIX *rm, FILE *fp) return(0); for (i = 0; i < rm->nrows; i++) { for (j = rm->ncols; j--; ) { - const double *dp = rmx_lval(rm,i,j); + const double *dp = rmx_val(rm,i,j); if (rm->ncomp == 1) setcolr(scan[j], dp[0], dp[0], dp[0]); else @@ -516,7 +544,7 @@ rmx_write_spec(const RMATRIX *rm, FILE *fp) return(0); for (i = 0; i < rm->nrows; i++) { for (j = rm->ncols; j--; ) { - const double *dp = rmx_lval(rm,i,j); + const double *dp = rmx_val(rm,i,j); for (k = rm->ncomp; k--; ) scol[k] = dp[k]; scolor2scolr(scan+j*(rm->ncomp+1), scol, rm->ncomp); @@ -616,6 +644,7 @@ rmx_write(const RMATRIX *rm, int dtype, FILE *fp) #ifdef getc_unlocked funlockfile(fp); #endif + if (!ok) fputs("Error writing matrix\n", stderr); return(ok); } @@ -685,7 +714,7 @@ rmx_transpose(const RMATRIX *rm) memcpy(dnew->wlpart, rm->wlpart, sizeof(dnew->wlpart)); for (j = dnew->ncols; j--; ) for (i = dnew->nrows; i--; ) - memcpy(rmx_lval(dnew,i,j), rmx_lval(rm,j,i), + memcpy(rmx_lval(dnew,i,j), rmx_val(rm,j,i), sizeof(double)*dnew->ncomp); return(dnew); } @@ -712,7 +741,7 @@ rmx_multiply(const RMATRIX *m1, const RMATRIX *m2) for (k = mres->ncomp; k--; ) { double d = 0; for (h = m1->ncols; h--; ) - d += rmx_lval(m1,i,h)[k] * rmx_lval(m2,h,j)[k]; + d += rmx_val(m1,i,h)[k] * rmx_val(m2,h,j)[k]; rmx_lval(mres,i,j)[k] = d; } return(mres); @@ -739,7 +768,7 @@ rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide if (divide) { double d; if (m2->ncomp == 1) { - d = rmx_lval(m2,i,j)[0]; + d = rmx_val(m2,i,j)[0]; if (d == 0) { ++zeroDivides; for (k = m1->ncomp; k--; ) @@ -751,7 +780,7 @@ rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide } } else for (k = m1->ncomp; k--; ) { - d = rmx_lval(m2,i,j)[k]; + d = rmx_val(m2,i,j)[k]; if (d == 0) { ++zeroDivides; rmx_lval(m1,i,j)[k] = 0; @@ -760,12 +789,12 @@ rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide } } else { if (m2->ncomp == 1) { - const double d = rmx_lval(m2,i,j)[0]; + const double d = rmx_val(m2,i,j)[0]; for (k = m1->ncomp; k--; ) rmx_lval(m1,i,j)[k] *= d; } else for (k = m1->ncomp; k--; ) - rmx_lval(m1,i,j)[k] *= rmx_lval(m2,i,j)[k]; + rmx_lval(m1,i,j)[k] *= rmx_val(m2,i,j)[k]; } if (zeroDivides) { rmx_addinfo(m1, "WARNING: zero divide(s) corrupted results\n"); @@ -801,7 +830,7 @@ rmx_sum(RMATRIX *msum, const RMATRIX *madd, const doub rmx_addinfo(msum, rmx_mismatch_warn); for (i = msum->nrows; i--; ) for (j = msum->ncols; j--; ) { - const double *da = rmx_lval(madd,i,j); + const double *da = rmx_val(madd,i,j); double *ds = rmx_lval(msum,i,j); for (k = msum->ncomp; k--; ) ds[k] += sf[k] * da[k]; @@ -853,7 +882,7 @@ rmx_transform(const RMATRIX *msrc, int n, const double dnew->dtype = msrc->dtype; for (i = dnew->nrows; i--; ) for (j = dnew->ncols; j--; ) { - const double *ds = rmx_lval(msrc,i,j); + const double *ds = rmx_val(msrc,i,j); for (kd = dnew->ncomp; kd--; ) { double d = 0; for (ks = msrc->ncomp; ks--; ) @@ -902,7 +931,7 @@ cm_from_rmatrix(const RMATRIX *rm) return(NULL); for (i = cnew->nrows; i--; ) for (j = cnew->ncols; j--; ) { - const double *dp = rmx_lval(rm,i,j); + const double *dp = rmx_val(rm,i,j); COLORV *cv = cm_lval(cnew,i,j); switch (rm->ncomp) { case 3:
