--- ray/src/util/rmatrix.c 2014/07/24 16:28:17 2.4 +++ ray/src/util/rmatrix.c 2014/08/02 17:10:43 2.6 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rmatrix.c,v 2.4 2014/07/24 16:28:17 greg Exp $"; +static const char RCSid[] = "$Id: rmatrix.c,v 2.6 2014/08/02 17:10:43 greg Exp $"; #endif /* * General matrix operations. @@ -12,10 +12,7 @@ static const char RCSid[] = "$Id: rmatrix.c,v 2.4 2014 #include "resolu.h" #include "rmatrix.h" -typedef struct { - int nrows, ncols, ncomp; - int dtype; -} DMINFO; +static char rmx_mismatch_warn[] = "WARNING: data type mismatch\n"; /* Allocate a nr x nc matrix with n components */ RMATRIX * @@ -30,16 +27,58 @@ rmx_alloc(int nr, int nc, int n) if (dnew == NULL) return(NULL); dnew->nrows = nr; dnew->ncols = nc; dnew->ncomp = n; + dnew->dtype = DTdouble; + dnew->info = NULL; return(dnew); } +/* Free a RMATRIX array */ +void +rmx_free(RMATRIX *rm) +{ + if (!rm) return; + if (rm->info) + free(rm->info); + free(rm); +} + +/* Resolve data type based on two input types (returns 0 for mismatch) */ +int +rmx_newtype(int dtyp1, int dtyp2) +{ + if ((dtyp1==DTxyze) | (dtyp1==DTrgbe) && dtyp1 != dtyp2) + return(0); + if (dtyp1 < dtyp2) + return(dtyp1); + return(dtyp2); +} + +/* Append header information associated with matrix data */ +int +rmx_addinfo(RMATRIX *rm, const char *info) +{ + if (!info || !*info) + return(0); + if (!rm->info) + rm->info = (char *)malloc(strlen(info)+1); + else + rm->info = (char *)realloc(rm->info, + strlen(rm->info)+strlen(info)+1); + if (!rm->info) + return(0); + strcat(rm->info, info); + return(1); +} + static int get_dminfo(char *s, void *p) { - DMINFO *ip = (DMINFO *)p; - char fmt[32]; + RMATRIX *ip = (RMATRIX *)p; + char fmt[64]; int i; + if (headidval(fmt, s)) + return(0); if (!strncmp(s, "NCOMP=", 6)) { ip->ncomp = atoi(s+6); return(0); @@ -52,8 +91,10 @@ get_dminfo(char *s, void *p) ip->ncols = atoi(s+6); return(0); } - if (!formatval(fmt, s)) + if (!formatval(fmt, s)) { + rmx_addinfo(ip, s); return(0); + } for (i = 1; i < DTend; i++) if (!strcmp(fmt, cm_fmt_id[i])) { ip->dtype = i; @@ -145,7 +186,7 @@ RMATRIX * rmx_load(const char *fname) { FILE *fp = stdin; - DMINFO dinfo; + RMATRIX dinfo; RMATRIX *dnew; if (fname == NULL) { /* reading from stdin? */ @@ -172,7 +213,8 @@ rmx_load(const char *fname) flockfile(fp); #endif dinfo.nrows = dinfo.ncols = dinfo.ncomp = 0; - dinfo.dtype = DTascii; + dinfo.dtype = DTascii; /* assumed w/o FORMAT */ + dinfo.info = NULL; if (getheader(fp, get_dminfo, &dinfo) < 0) { fclose(fp); return(NULL); @@ -195,6 +237,7 @@ rmx_load(const char *fname) fclose(fp); return(NULL); } + dnew->info = dinfo.info; switch (dinfo.dtype) { case DTascii: if (!rmx_load_ascii(dnew, fp)) @@ -203,15 +246,18 @@ rmx_load(const char *fname) case DTfloat: if (!rmx_load_float(dnew, fp)) goto loaderr; + dnew->dtype = DTfloat; break; case DTdouble: if (!rmx_load_double(dnew, fp)) goto loaderr; + dnew->dtype = DTdouble; break; case DTrgbe: case DTxyze: if (!rmx_load_rgbe(dnew, fp)) goto loaderr; + dnew->dtype = dinfo.dtype; break; default: goto loaderr; @@ -305,7 +351,7 @@ rmx_write_rgbe(const RMATRIX *rm, FILE *fp) return(1); } -/* Write matrix to file type indicated by dt */ +/* Write matrix to file type indicated by dtype */ long rmx_write(const RMATRIX *rm, int dtype, FILE *fp) { @@ -315,6 +361,14 @@ rmx_write(const RMATRIX *rm, int dtype, FILE *fp) if ((rm == NULL) | (fp == NULL)) return(0); /* complete header */ + if (rm->info) + fputs(rm->info, fp); + if (dtype == DTfromHeader) + dtype = rm->dtype; + else if ((dtype == DTrgbe) & (rm->dtype == DTxyze)) + dtype = DTxyze; + else if ((dtype = DTxyze) & (rm->dtype == DTrgbe)) + dtype = DTrgbe; if ((dtype != DTrgbe) & (dtype != DTxyze)) { fprintf(fp, "NROWS=%d\n", rm->nrows); fprintf(fp, "NCOLS=%d\n", rm->ncols); @@ -383,6 +437,8 @@ rmx_copy(const RMATRIX *rm) dnew = rmx_alloc(rm->nrows, rm->ncols, rm->ncomp); if (dnew == NULL) return(NULL); + rmx_addinfo(dnew, rm->info); + dnew->dtype = rm->dtype; memcpy(dnew->mtx, rm->mtx, sizeof(rm->mtx[0])*rm->ncomp*rm->nrows*rm->ncols); return(dnew); @@ -400,6 +456,11 @@ rmx_transpose(const RMATRIX *rm) dnew = rmx_alloc(rm->ncols, rm->nrows, rm->ncomp); if (dnew == NULL) return(NULL); + if (rm->info) { + rmx_addinfo(dnew, rm->info); + rmx_addinfo(dnew, "Transposed rows and columns\n"); + } + dnew->dtype = rm->dtype; for (i = dnew->nrows; i--; ) for (j = dnew->ncols; j--; ) for (k = dnew->ncomp; k--; ) @@ -420,6 +481,11 @@ rmx_multiply(const RMATRIX *m1, const RMATRIX *m2) mres = rmx_alloc(m1->nrows, m2->ncols, m1->ncomp); if (mres == NULL) return(NULL); + i = rmx_newtype(m1->dtype, m2->dtype); + if (i) + mres->dtype = i; + else + rmx_addinfo(mres, rmx_mismatch_warn); for (i = mres->nrows; i--; ) for (j = mres->ncols; j--; ) for (h = m1->ncols; h--; ) { @@ -452,6 +518,11 @@ rmx_sum(RMATRIX *msum, const RMATRIX *madd, const doub mysf[k] = 1; sf = mysf; } + i = rmx_newtype(msum->dtype, madd->dtype); + if (i) + msum->dtype = i; + else + rmx_addinfo(msum, rmx_mismatch_warn); for (i = msum->nrows; i--; ) for (j = msum->ncols; j--; ) for (k = msum->ncomp; k--; ) @@ -489,6 +560,7 @@ rmx_transform(const RMATRIX *msrc, int n, const double dnew = rmx_alloc(msrc->nrows, msrc->ncols, n); if (dnew == NULL) return(NULL); + dnew->dtype = msrc->dtype; for (i = dnew->nrows; i--; ) for (j = dnew->ncols; j--; ) for (kd = dnew->ncomp; kd--; ) { @@ -512,6 +584,7 @@ rmx_from_cmatrix(const CMATRIX *cm) dnew = rmx_alloc(cm->nrows, cm->ncols, 3); if (dnew == NULL) return(NULL); + dnew->dtype = DTfloat; for (i = dnew->nrows; i--; ) for (j = dnew->ncols; j--; ) { const COLORV *cv = cm_lval(cm,i,j);
