--- ray/src/util/rmatrix.c 2023/05/18 23:55:10 2.58 +++ ray/src/util/rmatrix.c 2023/12/01 02:05:00 2.67 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rmatrix.c,v 2.58 2023/05/18 23:55:10 greg Exp $"; +static const char RCSid[] = "$Id: rmatrix.c,v 2.67 2023/12/01 02:05:00 greg Exp $"; #endif /* * General matrix operations. @@ -16,7 +16,7 @@ static const char RCSid[] = "$Id: rmatrix.c,v 2.58 202 #include #endif -static char rmx_mismatch_warn[] = "WARNING: data type mismatch\n"; +static const char rmx_mismatch_warn[] = "WARNING: data type mismatch\n"; #define array_size(rm) (sizeof(double)*(rm)->nrows*(rm)->ncols*(rm)->ncomp) #define mapped_size(rm) ((char *)(rm)->mtx + array_size(rm) - (char *)(rm)->mapped) @@ -25,14 +25,19 @@ static char rmx_mismatch_warn[] = "WARNING: data type RMATRIX * rmx_new(int nr, int nc, int n) { - RMATRIX *dnew = (RMATRIX *)calloc(1, sizeof(RMATRIX)); + RMATRIX *dnew; + if (n <= 0) + return(NULL); + + dnew = (RMATRIX *)calloc(1, sizeof(RMATRIX)); if (dnew) { dnew->dtype = DTdouble; dnew->nrows = nr; dnew->ncols = nc; dnew->ncomp = n; setcolor(dnew->cexp, 1.f, 1.f, 1.f); + memcpy(dnew->wlpart, WLPART, sizeof(dnew->wlpart)); } return(dnew); } @@ -44,6 +49,8 @@ rmx_prepare(RMATRIX *rm) if (!rm) return(0); if (rm->mtx) return(1); + if ((rm->nrows <= 0) | (rm->ncols <= 0) | (rm->ncomp <= 0)) + return(0); rm->mtx = (double *)malloc(array_size(rm)); return(rm->mtx != NULL); } @@ -61,19 +68,33 @@ rmx_alloc(int nr, int nc, int n) return(dnew); } -/* Free a RMATRIX array */ +/* Clear state by freeing info and matrix data */ void -rmx_free(RMATRIX *rm) +rmx_reset(RMATRIX *rm) { if (!rm) return; - if (rm->info) + if (rm->info) { free(rm->info); + rm->info = NULL; + } + if (rm->mtx) { #ifdef MAP_FILE - if (rm->mapped) - munmap(rm->mapped, mapped_size(rm)); - else + if (rm->mapped) { + munmap(rm->mapped, mapped_size(rm)); + rm->mapped = NULL; + } else #endif - free(rm->mtx); + free(rm->mtx); + rm->mtx = NULL; + } +} + +/* Free an RMATRIX struct and data */ +void +rmx_free(RMATRIX *rm) +{ + if (!rm) return; + rmx_reset(rm); free(rm); } @@ -81,8 +102,8 @@ rmx_free(RMATRIX *rm) int rmx_newtype(int dtyp1, int dtyp2) { - if ((dtyp1==DTxyze) | (dtyp1==DTrgbe) | - (dtyp2==DTxyze) | (dtyp2==DTrgbe) + if ((dtyp1==DTxyze) | (dtyp1==DTrgbe) | (dtyp1==DTspec) | + (dtyp2==DTxyze) | (dtyp2==DTrgbe) | (dtyp2==DTspec) && dtyp1 != dtyp2) return(0); if (dtyp1 < dtyp2) @@ -119,10 +140,10 @@ get_dminfo(char *s, void *p) char fmt[MAXFMTLEN]; int i; - if (headidval(fmt, s)) + if (headidval(NULL, s)) return(0); - if (!strncmp(s, "NCOMP=", 6)) { - ip->ncomp = atoi(s+6); + if (isncomp(s)) { + ip->ncomp = ncompval(s); return(0); } if (!strncmp(s, "NROWS=", 6)) { @@ -148,6 +169,10 @@ get_dminfo(char *s, void *p) multcolor(ip->cexp, ctmp); return(0); } + if (iswlsplit(s)) { + wlsplitval(ip->wlpart, s); + return(0); + } if (!formatval(fmt, s)) { rmx_addinfo(ip, s); return(0); @@ -161,54 +186,157 @@ get_dminfo(char *s, void *p) } static int -rmx_load_ascii(RMATRIX *rm, FILE *fp) +rmx_load_ascii(double *drp, const RMATRIX *rm, FILE *fp) { - int i, j, k; + int j, k; - if (!rmx_prepare(rm)) - return(0); - for (i = 0; i < rm->nrows; i++) - for (j = 0; j < rm->ncols; j++) { - double *dp = rmx_lval(rm,i,j); - for (k = 0; k < rm->ncomp; k++) - if (fscanf(fp, "%lf", &dp[k]) != 1) - return(0); - } + for (j = 0; j < rm->ncols; j++) + for (k = rm->ncomp; k-- > 0; ) + if (fscanf(fp, "%lf", drp++) != 1) + return(0); return(1); } static int -rmx_load_float(RMATRIX *rm, FILE *fp) +rmx_load_float(double *drp, const RMATRIX *rm, FILE *fp) { - int i, j, k; + int j, k; float val[100]; if (rm->ncomp > 100) { fputs("Unsupported # components in rmx_load_float()\n", stderr); exit(1); } - if (!rmx_prepare(rm)) - return(0); - for (i = 0; i < rm->nrows; i++) - for (j = 0; j < rm->ncols; j++) { - double *dp = rmx_lval(rm,i,j); + for (j = 0; j < rm->ncols; j++) { if (getbinary(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp) - return(0); + return(0); if (rm->swapin) - swap32((char *)val, rm->ncomp); - for (k = rm->ncomp; k--; ) - dp[k] = val[k]; - } + swap32((char *)val, rm->ncomp); + for (k = 0; k < rm->ncomp; k++) + *drp++ = val[k]; + } return(1); } static int -rmx_load_double(RMATRIX *rm, FILE *fp) +rmx_load_double(double *drp, const RMATRIX *rm, FILE *fp) { + if (getbinary(drp, sizeof(*drp)*rm->ncomp, rm->ncols, fp) != rm->ncols) + return(0); + if (rm->swapin) + swap64((char *)drp, rm->ncols*rm->ncomp); + return(1); +} + +static int +rmx_load_rgbe(double *drp, const RMATRIX *rm, FILE *fp) +{ + COLR *scan; + COLOR col; + int j; + + if (rm->ncomp != 3) + return(0); + scan = (COLR *)tempbuffer(sizeof(COLR)*rm->ncols); + if (!scan) + return(0); + if (freadcolrs(scan, rm->ncols, fp) < 0) + return(0); + for (j = 0; j < rm->ncols; j++) { + colr_color(col, scan[j]); + *drp++ = colval(col,RED); + *drp++ = colval(col,GRN); + *drp++ = colval(col,BLU); + } + return(1); +} + +static int +rmx_load_spec(double *drp, const RMATRIX *rm, FILE *fp) +{ + uby8 *scan; + SCOLOR scol; + int j, k; + + if ((rm->ncomp < 3) | (rm->ncomp > MAXCSAMP)) + return(0); + scan = (uby8 *)tempbuffer((rm->ncomp+1)*rm->ncols); + if (!scan) + return(0); + if (freadscolrs(scan, rm->ncomp, rm->ncols, fp) < 0) + return(0); + for (j = 0; j < rm->ncols; j++) { + scolr2scolor(scol, scan+j*(rm->ncomp+1), rm->ncomp); + for (k = 0; k < rm->ncomp; k++) + *drp++ = scol[k]; + } + return(1); +} + +/* Read matrix header from input stream (cannot be XML) */ +int +rmx_load_header(RMATRIX *rm, FILE *fp) +{ + if (!rm | !fp) + return(0); + rmx_reset(rm); /* clear state */ + if (rm->nrows | rm->ncols | !rm->dtype) { + rm->nrows = rm->ncols = 0; + rm->ncomp = 3; + setcolor(rm->cexp, 1.f, 1.f, 1.f); + memcpy(rm->wlpart, WLPART, sizeof(rm->wlpart)); + rm->swapin = 0; + } + rm->dtype = DTascii; /* assumed w/o FORMAT */ + if (getheader(fp, get_dminfo, rm) < 0) { + fputs("Unrecognized matrix format\n", stderr); + return(0); + } + /* resolution string? */ + if ((rm->nrows <= 0) | (rm->ncols <= 0)) { + if (!fscnresolu(&rm->ncols, &rm->nrows, fp)) + return(0); + if ((rm->dtype == DTrgbe) | (rm->dtype == DTxyze) && + rm->ncomp != 3) + return(0); + } + if (rm->dtype == DTascii) /* set input type (WINDOWS) */ + SET_FILE_TEXT(fp); + else + SET_FILE_BINARY(fp); + return(1); +} + +/* Load next row as double (cannot be XML) */ +int +rmx_load_row(double *drp, const RMATRIX *rm, FILE *fp) +{ + switch (rm->dtype) { + case DTascii: + return(rmx_load_ascii(drp, rm, fp)); + case DTfloat: + return(rmx_load_float(drp, rm, fp)); + case DTdouble: + return(rmx_load_double(drp, rm, fp)); + case DTrgbe: + case DTxyze: + return(rmx_load_rgbe(drp, rm, fp)); + case DTspec: + return(rmx_load_spec(drp, rm, fp)); + default: + fputs("Unsupported data type in rmx_load_row()\n", stderr); + } + return(0); +} + +/* Allocate & load post-header data from stream given type set in rm->dtype */ +int +rmx_load_data(RMATRIX *rm, FILE *fp) +{ int i; #ifdef MAP_FILE long pos; /* map memory for file > 1MB if possible */ - if (!rm->swapin && array_size(rm) >= 1L<<20 && + if ((rm->dtype == DTdouble) & !rm->swapin && array_size(rm) >= 1L<<20 && (pos = ftell(fp)) >= 0 && !(pos % sizeof(double))) { rm->mapped = mmap(NULL, array_size(rm)+pos, PROT_READ|PROT_WRITE, MAP_PRIVATE, fileno(fp), 0); @@ -219,61 +347,34 @@ rmx_load_double(RMATRIX *rm, FILE *fp) rm->mapped = NULL; } #endif - if (!rmx_prepare(rm)) + if (!rmx_prepare(rm)) { /* need in-core matrix array */ + fprintf(stderr, "Cannot allocate %g MByte matrix array\n", + (1./(1L<<20))*(double)array_size(rm)); return(0); - for (i = 0; i < rm->nrows; i++) { - if (getbinary(rmx_lval(rm,i,0), sizeof(double)*rm->ncomp, - rm->ncols, fp) != rm->ncols) - return(0); - if (rm->swapin) - swap64((char *)rmx_lval(rm,i,0), rm->ncols*rm->ncomp); } + for (i = 0; i < rm->nrows; i++) + if (!rmx_load_row(rmx_lval(rm,i,0), rm, fp)) + return(0); return(1); } -static int -rmx_load_rgbe(RMATRIX *rm, FILE *fp) -{ - COLOR *scan = (COLOR *)malloc(sizeof(COLOR)*rm->ncols); - int i, j; - - if (!scan) - return(0); - if (!rmx_prepare(rm)) - return(0); - for (i = 0; i < rm->nrows; i++) { - double *dp = rmx_lval(rm,i,0); - if (freadscan(scan, rm->ncols, fp) < 0) { - free(scan); - return(0); - } - for (j = 0; j < rm->ncols; j++, dp += 3) { - dp[0] = colval(scan[j],RED); - dp[1] = colval(scan[j],GRN); - dp[2] = colval(scan[j],BLU); - } - } - free(scan); - return(1); -} - /* Load matrix from supported file type */ RMATRIX * rmx_load(const char *inspec, RMPref rmp) { FILE *fp; RMATRIX *dnew; + int ok; if (!inspec) inspec = stdin_name; else if (!*inspec) return(NULL); - if (inspec == stdin_name) { /* reading from stdin? */ + if (inspec == stdin_name) /* reading from stdin? */ fp = stdin; - } else if (inspec[0] == '!') { - if (!(fp = popen(inspec+1, "r"))) - return(NULL); - } else { + else if (inspec[0] == '!') + fp = popen(inspec+1, "r"); + else if (rmp != RMPnone) { const char *sp = inspec; /* check suffix */ while (*sp) ++sp; @@ -287,62 +388,26 @@ rmx_load(const char *inspec, RMPref rmp) dnew = rmx_from_cmatrix(cm); cm_free(cm); dnew->dtype = DTascii; - return(dnew); - } - /* else open it ourselves */ - if (!(fp = fopen(inspec, "r"))) - return(NULL); + return(dnew); /* return here */ + } /* else open it ourselves */ + fp = fopen(inspec, "r"); } - SET_FILE_BINARY(fp); + if (!fp) + return(NULL); #ifdef getc_unlocked flockfile(fp); #endif - if (!(dnew = rmx_new(0,0,3))) { - fclose(fp); + SET_FILE_BINARY(fp); /* load header info */ + if (!rmx_load_header(dnew = rmx_new(0,0,3), fp)) { + fprintf(stderr, "Bad header in: %s\n", inspec); + if (inspec[0] == '!') pclose(fp); + else fclose(fp); + rmx_free(dnew); return(NULL); } - dnew->dtype = DTascii; /* assumed w/o FORMAT */ - if (getheader(fp, get_dminfo, dnew) < 0) { - fclose(fp); - return(NULL); - } - if ((dnew->nrows <= 0) | (dnew->ncols <= 0)) { - if (!fscnresolu(&dnew->ncols, &dnew->nrows, fp)) { - fclose(fp); - return(NULL); - } - if ((dnew->dtype == DTrgbe) | (dnew->dtype == DTxyze) && - dnew->ncomp != 3) { - fclose(fp); - return(NULL); - } - } - switch (dnew->dtype) { - case DTascii: - SET_FILE_TEXT(fp); - if (!rmx_load_ascii(dnew, fp)) - goto loaderr; - dnew->dtype = DTascii; /* should leave double? */ - break; - case DTfloat: - if (!rmx_load_float(dnew, fp)) - goto loaderr; - dnew->dtype = DTfloat; - break; - case DTdouble: - if (!rmx_load_double(dnew, fp)) - goto loaderr; - dnew->dtype = DTdouble; - break; - case DTrgbe: - case DTxyze: - if (!rmx_load_rgbe(dnew, fp)) - goto loaderr; - break; - default: - goto loaderr; - } - if (fp != stdin) { + ok = rmx_load_data(dnew, fp); /* allocate & load data */ + + if (fp != stdin) { /* close input stream */ if (inspec[0] == '!') pclose(fp); else @@ -352,102 +417,93 @@ rmx_load(const char *inspec, RMPref rmp) else funlockfile(fp); #endif + if (!ok) { /* load failure? */ + fprintf(stderr, "Error loading data from: %s\n", inspec); + rmx_free(dnew); + return(NULL); + } /* undo exposure? */ - if (dnew->ncomp == 3 && (dnew->cexp[0] != 1.f) | + if ((dnew->cexp[0] != 1.f) | (dnew->cexp[1] != 1.f) | (dnew->cexp[2] != 1.f)) { - double cmlt[3]; + double cmlt[MAXCSAMP]; + int i; cmlt[0] = 1./dnew->cexp[0]; cmlt[1] = 1./dnew->cexp[1]; cmlt[2] = 1./dnew->cexp[2]; + if (dnew->ncomp > MAXCSAMP) { + fprintf(stderr, "Excess spectral components in: %s\n", + inspec); + rmx_free(dnew); + return(NULL); + } + for (i = dnew->ncomp; i-- > 3; ) + cmlt[i] = cmlt[1]; rmx_scale(dnew, cmlt); setcolor(dnew->cexp, 1.f, 1.f, 1.f); } return(dnew); -loaderr: /* should report error? */ - if (inspec[0] == '!') - pclose(fp); - else - fclose(fp); - rmx_free(dnew); - return(NULL); } static int -rmx_write_ascii(const RMATRIX *rm, FILE *fp) +rmx_write_ascii(const double *dp, int nc, int len, FILE *fp) { - const char *fmt = (rm->dtype == DTfloat) ? " %.7e" : - (rm->dtype == DTrgbe) | (rm->dtype == DTxyze) ? " %.3e" : - " %.15e" ; - int i, j, k; - - for (i = 0; i < rm->nrows; i++) { - for (j = 0; j < rm->ncols; j++) { - const double *dp = rmx_lval(rm,i,j); - for (k = 0; k < rm->ncomp; k++) - fprintf(fp, fmt, dp[k]); + while (len-- > 0) { + int k = nc; + while (nc-- > 0) + fprintf(fp, " %.7e", *dp++); fputc('\t', fp); - } - fputc('\n', fp); } - return(1); + return(fputc('\n', fp) != EOF); } static int -rmx_write_float(const RMATRIX *rm, FILE *fp) +rmx_write_float(const double *dp, int len, FILE *fp) { - int i, j, k; - float val[100]; + float val; - if (rm->ncomp > 100) { - fputs("Unsupported # components in rmx_write_float()\n", stderr); - exit(1); - } - for (i = 0; i < rm->nrows; i++) - for (j = 0; j < rm->ncols; j++) { - const double *dp = rmx_lval(rm,i,j); - for (k = rm->ncomp; k--; ) - val[k] = (float)dp[k]; - if (putbinary(val, sizeof(float), rm->ncomp, fp) != rm->ncomp) + while (len--) { + val = *dp++; + if (putbinary(&val, sizeof(float), 1, fp) != 1) return(0); - } + } return(1); } static int -rmx_write_double(const RMATRIX *rm, FILE *fp) +rmx_write_rgbe(const double *dp, int nc, int len, FILE *fp) { - int i; + COLR *scan; + int j; - for (i = 0; i < rm->nrows; i++) - if (putbinary(rmx_lval(rm,i,0), sizeof(double)*rm->ncomp, - rm->ncols, fp) != rm->ncols) - return(0); - return(1); + if ((nc != 1) & (nc != 3)) return(0); + scan = (COLR *)tempbuffer(sizeof(COLR)*len); + if (!scan) return(0); + + for (j = 0; j < len; j++, dp += nc) + if (nc == 1) + setcolr(scan[j], dp[0], dp[0], dp[0]); + else + setcolr(scan[j], dp[0], dp[1], dp[2]); + + return(fwritecolrs(scan, len, fp) >= 0); } static int -rmx_write_rgbe(const RMATRIX *rm, FILE *fp) +rmx_write_spec(const double *dp, int nc, int len, FILE *fp) { - COLR *scan = (COLR *)malloc(sizeof(COLR)*rm->ncols); - int i, j; + uby8 *scan; + SCOLOR scol; + int j, k; - if (!scan) - return(0); - for (i = 0; i < rm->nrows; i++) { - for (j = rm->ncols; j--; ) { - const double *dp = rmx_lval(rm,i,j); - if (rm->ncomp == 1) - setcolr(scan[j], dp[0], dp[0], dp[0]); - else - setcolr(scan[j], dp[0], dp[1], dp[2]); - } - if (fwritecolrs(scan, rm->ncols, fp) < 0) { - free(scan); - return(0); - } + if (nc < 3) return(0); + scan = (uby8 *)tempbuffer((nc+1)*len); + if (!scan) return(0); + for (j = len; j--; dp += nc) { + for (k = nc; k--; ) + scol[k] = dp[k]; + scolor2scolr(scan+j*(nc+1), scol, nc); } - free(scan); - return(1); + return(fwritescolrs(scan, nc, len, fp) >= 0); } /* Check if CIE XYZ primaries were specified */ @@ -467,18 +523,12 @@ findCIEprims(const char *info) (prims[BLU][CIEX] < .01) & (prims[BLU][CIEY] < .01)); } -/* Write matrix to file type indicated by dtype */ +/* Finish writing header data with resolution and format, returning type used */ int -rmx_write(const RMATRIX *rm, int dtype, FILE *fp) +rmx_write_header(const RMATRIX *rm, int dtype, FILE *fp) { - int ok = 1; - if (!rm | !fp || !rm->mtx) return(0); -#ifdef getc_unlocked - flockfile(fp); -#endif - /* complete header */ if (rm->info) fputs(rm->info, fp); if (dtype == DTfromHeader) @@ -488,45 +538,86 @@ rmx_write(const RMATRIX *rm, int dtype, FILE *fp) dtype = DTxyze; else if ((dtype == DTxyze) & (rm->dtype == DTrgbe)) dtype = DTrgbe; - if (rm->ncomp == 3) { /* write exposure? */ - if ((rm->cexp[RED] != rm->cexp[GRN]) | - (rm->cexp[GRN] != rm->cexp[BLU])) - fputcolcor(rm->cexp, fp); - else if (rm->cexp[GRN] != 1.f) - fputexpos(rm->cexp[GRN], fp); - } + + if (dtype == DTascii) /* set output type (WINDOWS) */ + SET_FILE_TEXT(fp); + else + SET_FILE_BINARY(fp); + /* write exposure? */ + if (rm->ncomp == 3 && (rm->cexp[RED] != rm->cexp[GRN]) | + (rm->cexp[GRN] != rm->cexp[BLU])) + fputcolcor(rm->cexp, fp); + else if (rm->cexp[GRN] != 1.f) + fputexpos(rm->cexp[GRN], fp); if ((dtype != DTrgbe) & (dtype != DTxyze)) { - fprintf(fp, "NROWS=%d\n", rm->nrows); - fprintf(fp, "NCOLS=%d\n", rm->ncols); - fprintf(fp, "NCOMP=%d\n", rm->ncomp); + if (dtype != DTspec) { + fprintf(fp, "NROWS=%d\n", rm->nrows); + fprintf(fp, "NCOLS=%d\n", rm->ncols); + } else if (rm->ncomp < 3) + return(0); /* bad # components */ + fputncomp(rm->ncomp, fp); + if (dtype == DTspec || (rm->ncomp > 3 && + memcmp(rm->wlpart, WLPART, sizeof(WLPART)))) + fputwlsplit(rm->wlpart, fp); } else if ((rm->ncomp != 3) & (rm->ncomp != 1)) return(0); /* wrong # components */ if ((dtype == DTfloat) | (dtype == DTdouble)) fputendian(fp); /* important to record */ fputformat(cm_fmt_id[dtype], fp); - fputc('\n', fp); - switch (dtype) { /* write data */ + fputc('\n', fp); /* end of header */ + if (dtype <= DTspec) + fprtresolu(rm->ncols, rm->nrows, fp); + return(dtype); +} + +/* Write out matrix data (usually by row) */ +int +rmx_write_data(const double *dp, int nc, int len, int dtype, FILE *fp) +{ + switch (dtype) { case DTascii: - ok = rmx_write_ascii(rm, fp); - break; + return(rmx_write_ascii(dp, nc, len, fp)); case DTfloat: - ok = rmx_write_float(rm, fp); - break; + return(rmx_write_float(dp, nc*len, fp)); case DTdouble: - ok = rmx_write_double(rm, fp); - break; + return(putbinary(dp, sizeof(*dp)*nc, len, fp) == len); case DTrgbe: case DTxyze: - fprtresolu(rm->ncols, rm->nrows, fp); - ok = rmx_write_rgbe(rm, fp); - break; - default: - return(0); + return(rmx_write_rgbe(dp, nc, len, fp)); + case DTspec: + return(rmx_write_spec(dp, nc, len, fp)); } - ok &= (fflush(fp) == 0); + return(0); +} + +/* Write matrix using file format indicated by dtype */ +int +rmx_write(const RMATRIX *rm, int dtype, FILE *fp) +{ + int ok = 0; + int i; + /* complete header */ + dtype = rmx_write_header(rm, dtype, fp); + if (dtype <= 0) + return(0); #ifdef getc_unlocked + flockfile(fp); +#endif + if (dtype == DTdouble) /* write all at once? */ + ok = rmx_write_data(rm->mtx, rm->ncomp, + rm->nrows*rm->ncols, dtype, fp); + else /* else row by row */ + for (i = 0; i < rm->nrows; i++) { + ok = rmx_write_data(rmx_val(rm,i,0), rm->ncomp, + rm->ncols, dtype, fp); + if (!ok) break; + } + + if (ok) ok = (fflush(fp) == 0); +#ifdef getc_unlocked funlockfile(fp); #endif + if (!ok) fputs("Error writing matrix\n", stderr); return(ok); } @@ -554,13 +645,15 @@ rmx_copy(const RMATRIX *rm) { RMATRIX *dnew; - if (!rm) + if (!rm || !rm->mtx) return(NULL); dnew = rmx_alloc(rm->nrows, rm->ncols, rm->ncomp); if (!dnew) return(NULL); rmx_addinfo(dnew, rm->info); dnew->dtype = rm->dtype; + copycolor(dnew->cexp, rm->cexp); + memcpy(dnew->wlpart, rm->wlpart, sizeof(dnew->wlpart)); memcpy(dnew->mtx, rm->mtx, array_size(dnew)); return(dnew); } @@ -572,7 +665,7 @@ rmx_transpose(const RMATRIX *rm) RMATRIX *dnew; int i, j; - if (!rm) + if (!rm || !rm->mtx) return(0); if ((rm->nrows == 1) | (rm->ncols == 1)) { dnew = rmx_copy(rm); @@ -590,9 +683,11 @@ rmx_transpose(const RMATRIX *rm) rmx_addinfo(dnew, "Transposed rows and columns\n"); } dnew->dtype = rm->dtype; + copycolor(dnew->cexp, rm->cexp); + memcpy(dnew->wlpart, rm->wlpart, sizeof(dnew->wlpart)); for (j = dnew->ncols; j--; ) for (i = dnew->nrows; i--; ) - memcpy(rmx_lval(dnew,i,j), rmx_lval(rm,j,i), + memcpy(rmx_lval(dnew,i,j), rmx_val(rm,j,i), sizeof(double)*dnew->ncomp); return(dnew); } @@ -604,7 +699,8 @@ rmx_multiply(const RMATRIX *m1, const RMATRIX *m2) RMATRIX *mres; int i, j, k, h; - if (!m1 | !m2 || (m1->ncomp != m2->ncomp) | (m1->ncols != m2->nrows)) + if (!m1 | !m2 || !m1->mtx | !m2->mtx | + (m1->ncomp != m2->ncomp) | (m1->ncols != m2->nrows)) return(NULL); mres = rmx_alloc(m1->nrows, m2->ncols, m1->ncomp); if (!mres) @@ -619,7 +715,7 @@ rmx_multiply(const RMATRIX *m1, const RMATRIX *m2) for (k = mres->ncomp; k--; ) { double d = 0; for (h = m1->ncols; h--; ) - d += rmx_lval(m1,i,h)[k] * rmx_lval(m2,h,j)[k]; + d += rmx_val(m1,i,h)[k] * rmx_val(m2,h,j)[k]; rmx_lval(mres,i,j)[k] = d; } return(mres); @@ -632,7 +728,8 @@ rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide int zeroDivides = 0; int i, j, k; - if (!m1 | !m2 || (m1->ncols != m2->ncols) | (m1->nrows != m2->nrows)) + if (!m1 | !m2 || !m1->mtx | !m2->mtx | + (m1->ncols != m2->ncols) | (m1->nrows != m2->nrows)) return(0); if ((m2->ncomp > 1) & (m2->ncomp != m1->ncomp)) return(0); @@ -646,7 +743,7 @@ rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide if (divide) { double d; if (m2->ncomp == 1) { - d = rmx_lval(m2,i,j)[0]; + d = rmx_val(m2,i,j)[0]; if (d == 0) { ++zeroDivides; for (k = m1->ncomp; k--; ) @@ -658,7 +755,7 @@ rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide } } else for (k = m1->ncomp; k--; ) { - d = rmx_lval(m2,i,j)[k]; + d = rmx_val(m2,i,j)[k]; if (d == 0) { ++zeroDivides; rmx_lval(m1,i,j)[k] = 0; @@ -667,12 +764,12 @@ rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide } } else { if (m2->ncomp == 1) { - const double d = rmx_lval(m2,i,j)[0]; + const double d = rmx_val(m2,i,j)[0]; for (k = m1->ncomp; k--; ) rmx_lval(m1,i,j)[k] *= d; } else for (k = m1->ncomp; k--; ) - rmx_lval(m1,i,j)[k] *= rmx_lval(m2,i,j)[k]; + rmx_lval(m1,i,j)[k] *= rmx_val(m2,i,j)[k]; } if (zeroDivides) { rmx_addinfo(m1, "WARNING: zero divide(s) corrupted results\n"); @@ -688,7 +785,7 @@ rmx_sum(RMATRIX *msum, const RMATRIX *madd, const doub double *mysf = NULL; int i, j, k; - if (!msum | !madd || + if (!msum | !madd || !msum->mtx | !madd->mtx | (msum->nrows != madd->nrows) | (msum->ncols != madd->ncols) | (msum->ncomp != madd->ncomp)) @@ -708,7 +805,7 @@ rmx_sum(RMATRIX *msum, const RMATRIX *madd, const doub rmx_addinfo(msum, rmx_mismatch_warn); for (i = msum->nrows; i--; ) for (j = msum->ncols; j--; ) { - const double *da = rmx_lval(madd,i,j); + const double *da = rmx_val(madd,i,j); double *ds = rmx_lval(msum,i,j); for (k = msum->ncomp; k--; ) ds[k] += sf[k] * da[k]; @@ -724,7 +821,7 @@ rmx_scale(RMATRIX *rm, const double sf[]) { int i, j, k; - if (!rm | !sf) + if (!rm | !sf || !rm->mtx) return(0); for (i = rm->nrows; i--; ) for (j = rm->ncols; j--; ) { @@ -734,6 +831,7 @@ rmx_scale(RMATRIX *rm, const double sf[]) } if (rm->info) rmx_addinfo(rm, "Applied scalar\n"); + /* XXX: should record as exposure for COLR and SCOLR types? */ return(1); } @@ -744,7 +842,7 @@ rmx_transform(const RMATRIX *msrc, int n, const double int i, j, ks, kd; RMATRIX *dnew; - if (!msrc | (n <= 0) | !cmat) + if (!msrc | (n <= 0) | !cmat || !msrc->mtx) return(NULL); dnew = rmx_alloc(msrc->nrows, msrc->ncols, n); if (!dnew) @@ -759,7 +857,7 @@ rmx_transform(const RMATRIX *msrc, int n, const double dnew->dtype = msrc->dtype; for (i = dnew->nrows; i--; ) for (j = dnew->ncols; j--; ) { - const double *ds = rmx_lval(msrc,i,j); + const double *ds = rmx_val(msrc,i,j); for (kd = dnew->ncomp; kd--; ) { double d = 0; for (ks = msrc->ncomp; ks--; ) @@ -801,19 +899,30 @@ cm_from_rmatrix(const RMATRIX *rm) int i, j; CMATRIX *cnew; - if (!rm || !rm->mtx | ((rm->ncomp != 3) & (rm->ncomp != 1))) + if (!rm || !rm->mtx | (rm->ncomp == 2)) return(NULL); cnew = cm_alloc(rm->nrows, rm->ncols); if (!cnew) return(NULL); for (i = cnew->nrows; i--; ) for (j = cnew->ncols; j--; ) { - const double *dp = rmx_lval(rm,i,j); + const double *dp = rmx_val(rm,i,j); COLORV *cv = cm_lval(cnew,i,j); - if (rm->ncomp == 1) - setcolor(cv, dp[0], dp[0], dp[0]); - else + switch (rm->ncomp) { + case 3: setcolor(cv, dp[0], dp[1], dp[2]); + break; + case 1: + setcolor(cv, dp[0], dp[0], dp[0]); + break; + default: { + SCOLOR scol; + int k; + for (k = rm->ncomp; k--; ) + scol[k] = dp[k]; + scolor2color(cv, scol, rm->ncomp, rm->wlpart); + } break; + } } return(cnew); }
