--- ray/src/util/rmatrix.c 2019/08/12 04:12:57 2.31 +++ ray/src/util/rmatrix.c 2023/12/21 23:58:05 2.77 @@ -1,48 +1,102 @@ #ifndef lint -static const char RCSid[] = "$Id: rmatrix.c,v 2.31 2019/08/12 04:12:57 greg Exp $"; +static const char RCSid[] = "$Id: rmatrix.c,v 2.77 2023/12/21 23:58:05 greg Exp $"; #endif /* * General matrix operations. */ -#include #include -#include -#include #include #include "rtio.h" #include "platform.h" #include "resolu.h" #include "paths.h" #include "rmatrix.h" +#if !defined(_WIN32) && !defined(_WIN64) +#include +#endif -static char rmx_mismatch_warn[] = "WARNING: data type mismatch\n"; +static const char rmx_mismatch_warn[] = "WARNING: data type mismatch\n"; -/* Allocate a nr x nc matrix with n components */ +#define array_size(rm) (sizeof(double)*(rm)->nrows*(rm)->ncols*(rm)->ncomp) +#define mapped_size(rm) ((char *)(rm)->mtx + array_size(rm) - (char *)(rm)->mapped) + +/* Initialize a RMATRIX struct but don't allocate array space */ RMATRIX * -rmx_alloc(int nr, int nc, int n) +rmx_new(int nr, int nc, int n) { RMATRIX *dnew; - if ((nr <= 0) | (nc <= 0) | (n <= 0)) + if (n <= 0) return(NULL); - dnew = (RMATRIX *)malloc(sizeof(RMATRIX)-sizeof(dnew->mtx) + - sizeof(dnew->mtx[0])*(n*nr*nc)); - if (dnew == NULL) + + dnew = (RMATRIX *)calloc(1, sizeof(RMATRIX)); + if (!dnew) return(NULL); - dnew->nrows = nr; dnew->ncols = nc; dnew->ncomp = n; + dnew->dtype = DTdouble; - dnew->info = NULL; + dnew->nrows = nr; + dnew->ncols = nc; + dnew->ncomp = n; + setcolor(dnew->cexp, 1.f, 1.f, 1.f); + memcpy(dnew->wlpart, WLPART, sizeof(dnew->wlpart)); + return(dnew); } -/* Free a RMATRIX array */ +/* Prepare a RMATRIX for writing (allocate array if needed) */ +int +rmx_prepare(RMATRIX *rm) +{ + if (!rm) return(0); + if (rm->mtx) + return(1); + if ((rm->nrows <= 0) | (rm->ncols <= 0) | (rm->ncomp <= 0)) + return(0); + rm->mtx = (double *)malloc(array_size(rm)); + return(rm->mtx != NULL); +} + +/* Call rmx_new() and rmx_prepare() */ +RMATRIX * +rmx_alloc(int nr, int nc, int n) +{ + RMATRIX *dnew = rmx_new(nr, nc, n); + + if (dnew && !rmx_prepare(dnew)) { + rmx_free(dnew); + dnew = NULL; + } + return(dnew); +} + +/* Clear state by freeing info and matrix data */ void -rmx_free(RMATRIX *rm) +rmx_reset(RMATRIX *rm) { if (!rm) return; - if (rm->info) + if (rm->info) { free(rm->info); + rm->info = NULL; + } + if (rm->mtx) { +#ifdef MAP_FILE + if (rm->mapped) { + munmap(rm->mapped, mapped_size(rm)); + rm->mapped = NULL; + } else +#endif + free(rm->mtx); + rm->mtx = NULL; + } +} + +/* Free an RMATRIX struct and data */ +void +rmx_free(RMATRIX *rm) +{ + if (!rm) return; + rmx_reset(rm); free(rm); } @@ -50,8 +104,8 @@ rmx_free(RMATRIX *rm) int rmx_newtype(int dtyp1, int dtyp2) { - if ((dtyp1==DTxyze) | (dtyp1==DTrgbe) | - (dtyp2==DTxyze) | (dtyp2==DTrgbe) + if ((dtyp1==DTxyze) | (dtyp1==DTrgbe) | (dtyp1==DTspec) | + (dtyp2==DTxyze) | (dtyp2==DTrgbe) | (dtyp2==DTspec) && dtyp1 != dtyp2) return(0); if (dtyp1 < dtyp2) @@ -63,17 +117,21 @@ rmx_newtype(int dtyp1, int dtyp2) int rmx_addinfo(RMATRIX *rm, const char *info) { - if (!info || !*info) + int oldlen = 0; + + if (!rm || !info || !*info) return(0); if (!rm->info) { rm->info = (char *)malloc(strlen(info)+1); if (rm->info) rm->info[0] = '\0'; - } else + } else { + oldlen = strlen(rm->info); rm->info = (char *)realloc(rm->info, - strlen(rm->info)+strlen(info)+1); + oldlen+strlen(info)+1); + } if (!rm->info) return(0); - strcat(rm->info, info); + strcpy(rm->info+oldlen, info); return(1); } @@ -84,10 +142,10 @@ get_dminfo(char *s, void *p) char fmt[MAXFMTLEN]; int i; - if (headidval(fmt, s)) + if (headidval(NULL, s)) return(0); - if (!strncmp(s, "NCOMP=", 6)) { - ip->ncomp = atoi(s+6); + if (isncomp(s)) { + ip->ncomp = ncompval(s); return(0); } if (!strncmp(s, "NROWS=", 6)) { @@ -98,10 +156,29 @@ get_dminfo(char *s, void *p) ip->ncols = atoi(s+6); return(0); } + if ((i = isbigendian(s)) >= 0) { + ip->swapin = (nativebigendian() != i); + return(0); + } + if (isexpos(s)) { + float f = exposval(s); + scalecolor(ip->cexp, f); + return(0); + } + if (iscolcor(s)) { + COLOR ctmp; + colcorval(ctmp, s); + multcolor(ip->cexp, ctmp); + return(0); + } + if (iswlsplit(s)) { + wlsplitval(ip->wlpart, s); + return(0); + } if (!formatval(fmt, s)) { rmx_addinfo(ip, s); return(0); - } + } /* else check format */ for (i = 1; i < DTend; i++) if (!strcmp(fmt, cm_fmt_id[i])) { ip->dtype = i; @@ -111,163 +188,229 @@ get_dminfo(char *s, void *p) } static int -rmx_load_ascii(RMATRIX *rm, FILE *fp) +rmx_load_ascii(double *drp, const RMATRIX *rm, FILE *fp) { - int i, j, k; + int j, k; - for (i = 0; i < rm->nrows; i++) - for (j = 0; j < rm->ncols; j++) - for (k = 0; k < rm->ncomp; k++) - if (fscanf(fp, "%lf", &rmx_lval(rm,i,j,k)) != 1) - return(0); + for (j = 0; j < rm->ncols; j++) + for (k = rm->ncomp; k-- > 0; ) + if (fscanf(fp, "%lf", drp++) != 1) + return(0); return(1); } static int -rmx_load_float(RMATRIX *rm, FILE *fp) +rmx_load_float(double *drp, const RMATRIX *rm, FILE *fp) { - int i, j, k; + int j, k; float val[100]; if (rm->ncomp > 100) { fputs("Unsupported # components in rmx_load_float()\n", stderr); exit(1); } - for (i = 0; i < rm->nrows; i++) - for (j = 0; j < rm->ncols; j++) { + for (j = 0; j < rm->ncols; j++) { if (getbinary(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp) - return(0); - for (k = rm->ncomp; k--; ) - rmx_lval(rm,i,j,k) = val[k]; - } + return(0); + if (rm->swapin) + swap32((char *)val, rm->ncomp); + for (k = 0; k < rm->ncomp; k++) + *drp++ = val[k]; + } return(1); } static int -rmx_load_double(RMATRIX *rm, FILE *fp) +rmx_load_double(double *drp, const RMATRIX *rm, FILE *fp) { - int i, j; + if (getbinary(drp, sizeof(*drp)*rm->ncomp, rm->ncols, fp) != rm->ncols) + return(0); + if (rm->swapin) + swap64((char *)drp, rm->ncols*rm->ncomp); + return(1); +} - for (i = 0; i < rm->nrows; i++) - for (j = 0; j < rm->ncols; j++) - if (getbinary(&rmx_lval(rm,i,j,0), sizeof(double), rm->ncomp, fp) != rm->ncomp) - return(0); +static int +rmx_load_rgbe(double *drp, const RMATRIX *rm, FILE *fp) +{ + COLR *scan; + COLOR col; + int j; + + if (rm->ncomp != 3) + return(0); + scan = (COLR *)tempbuffer(sizeof(COLR)*rm->ncols); + if (!scan) + return(0); + if (freadcolrs(scan, rm->ncols, fp) < 0) + return(0); + for (j = 0; j < rm->ncols; j++) { + colr_color(col, scan[j]); + *drp++ = colval(col,RED); + *drp++ = colval(col,GRN); + *drp++ = colval(col,BLU); + } return(1); } static int -rmx_load_rgbe(RMATRIX *rm, FILE *fp) +rmx_load_spec(double *drp, const RMATRIX *rm, FILE *fp) { - COLOR *scan = (COLOR *)malloc(sizeof(COLOR)*rm->ncols); - int i, j; + uby8 *scan; + SCOLOR scol; + int j, k; - if (scan == NULL) + if ((rm->ncomp < 3) | (rm->ncomp > MAXCSAMP)) return(0); - for (i = 0; i < rm->nrows; i++) { - if (freadscan(scan, rm->ncols, fp) < 0) { - free(scan); + scan = (uby8 *)tempbuffer((rm->ncomp+1)*rm->ncols); + if (!scan) return(0); - } - for (j = rm->ncols; j--; ) { - rmx_lval(rm,i,j,0) = colval(scan[j],RED); - rmx_lval(rm,i,j,1) = colval(scan[j],GRN); - rmx_lval(rm,i,j,2) = colval(scan[j],BLU); - } + if (freadscolrs(scan, rm->ncomp, rm->ncols, fp) < 0) + return(0); + for (j = 0; j < rm->ncols; j++) { + scolr2scolor(scol, scan+j*(rm->ncomp+1), rm->ncomp); + for (k = 0; k < rm->ncomp; k++) + *drp++ = scol[k]; } - free(scan); return(1); } +/* Read matrix header from input stream (cannot be XML) */ +int +rmx_load_header(RMATRIX *rm, FILE *fp) +{ + if (!rm | !fp) + return(0); + rmx_reset(rm); /* clear state */ + if (rm->nrows | rm->ncols | !rm->dtype) { + rm->nrows = rm->ncols = 0; + rm->ncomp = 3; + setcolor(rm->cexp, 1.f, 1.f, 1.f); + memcpy(rm->wlpart, WLPART, sizeof(rm->wlpart)); + rm->swapin = 0; + } + rm->dtype = DTascii; /* assumed w/o FORMAT */ + if (getheader(fp, get_dminfo, rm) < 0) { + fputs("Unrecognized matrix format\n", stderr); + return(0); + } + if ((rm->dtype == DTrgbe) | (rm->dtype == DTxyze) && + rm->ncomp != 3) + return(0); + if (rm->ncols <= 0 && /* resolution string? */ + !fscnresolu(&rm->ncols, &rm->nrows, fp)) + return(0); + if (rm->dtype == DTascii) /* set file type (WINDOWS) */ + SET_FILE_TEXT(fp); + else + SET_FILE_BINARY(fp); + return(1); +} + +/* Load next row as double (cannot be XML) */ +int +rmx_load_row(double *drp, const RMATRIX *rm, FILE *fp) +{ + switch (rm->dtype) { + case DTascii: + return(rmx_load_ascii(drp, rm, fp)); + case DTfloat: + return(rmx_load_float(drp, rm, fp)); + case DTdouble: + return(rmx_load_double(drp, rm, fp)); + case DTrgbe: + case DTxyze: + return(rmx_load_rgbe(drp, rm, fp)); + case DTspec: + return(rmx_load_spec(drp, rm, fp)); + default: + fputs("Unsupported data type in rmx_load_row()\n", stderr); + } + return(0); +} + +/* Allocate & load post-header data from stream given type set in rm->dtype */ +int +rmx_load_data(RMATRIX *rm, FILE *fp) +{ + int i; +#ifdef MAP_FILE + long pos; /* map memory for file > 1MB if possible */ + if ((rm->dtype == DTdouble) & !rm->swapin && array_size(rm) >= 1L<<20 && + (pos = ftell(fp)) >= 0 && !(pos % sizeof(double))) { + rm->mapped = mmap(NULL, array_size(rm)+pos, PROT_READ|PROT_WRITE, + MAP_PRIVATE, fileno(fp), 0); + if (rm->mapped != MAP_FAILED) { + rm->mtx = (double *)rm->mapped + pos/sizeof(double); + return(1); + } /* else fall back on reading into memory */ + rm->mapped = NULL; + } +#endif + if (!rmx_prepare(rm)) { /* need in-core matrix array */ + fprintf(stderr, "Cannot allocate %g MByte matrix array\n", + (1./(1L<<20))*(double)array_size(rm)); + return(0); + } + for (i = 0; i < rm->nrows; i++) + if (!rmx_load_row(rmx_lval(rm,i,0), rm, fp)) + return(0); + return(1); +} + /* Load matrix from supported file type */ RMATRIX * -rmx_load(const char *inspec) +rmx_load(const char *inspec, RMPref rmp) { - FILE *fp = stdin; - RMATRIX dinfo; + FILE *fp; RMATRIX *dnew; + int ok; - if (inspec == NULL) { /* reading from stdin? */ - inspec = ""; - SET_FILE_BINARY(stdin); - } else if (inspec[0] == '!') { - if ((fp = popen(inspec+1, "r")) == NULL) - return(NULL); - SET_FILE_BINARY(stdin); - } else { + if (!inspec) + inspec = stdin_name; + else if (!*inspec) + return(NULL); + if (inspec == stdin_name) /* reading from stdin? */ + fp = stdin; + else if (inspec[0] == '!') + fp = popen(inspec+1, "r"); + else { const char *sp = inspec; /* check suffix */ while (*sp) ++sp; while (sp > inspec && sp[-1] != '.') --sp; if (!strcasecmp(sp, "XML")) { /* assume it's a BSDF */ - CMATRIX *cm = cm_loadBTDF((char *)inspec); - if (cm == NULL) + CMATRIX *cm = rmp==RMPnone ? (CMATRIX *)NULL : + rmp==RMPtrans ? cm_loadBTDF(inspec) : + cm_loadBRDF(inspec, rmp==RMPreflB) ; + if (!cm) return(NULL); dnew = rmx_from_cmatrix(cm); cm_free(cm); dnew->dtype = DTascii; - return(dnew); - } - /* else open it ourselves */ - if ((fp = fopen(inspec, "rb")) == NULL) - return(NULL); + return(dnew); /* return here */ + } /* else open it ourselves */ + fp = fopen(inspec, "r"); } + if (!fp) { + fprintf(stderr, "Cannot open for reading: %s\n", inspec); + return(NULL); + } #ifdef getc_unlocked flockfile(fp); #endif - dinfo.nrows = dinfo.ncols = dinfo.ncomp = 0; - dinfo.dtype = DTascii; /* assumed w/o FORMAT */ - dinfo.info = NULL; - if (getheader(fp, get_dminfo, &dinfo) < 0) { - fclose(fp); + SET_FILE_BINARY(fp); /* load header info */ + if (!rmx_load_header(dnew = rmx_new(0,0,3), fp)) { + fprintf(stderr, "Bad header in: %s\n", inspec); + if (inspec[0] == '!') pclose(fp); + else fclose(fp); + rmx_free(dnew); return(NULL); } - if ((dinfo.nrows <= 0) | (dinfo.ncols <= 0)) { - if (!fscnresolu(&dinfo.ncols, &dinfo.nrows, fp)) { - fclose(fp); - return(NULL); - } - if (dinfo.ncomp <= 0) - dinfo.ncomp = 3; - else if ((dinfo.dtype == DTrgbe) | (dinfo.dtype == DTxyze) && - dinfo.ncomp != 3) { - fclose(fp); - return(NULL); - } - } - dnew = rmx_alloc(dinfo.nrows, dinfo.ncols, dinfo.ncomp); - if (dnew == NULL) { - fclose(fp); - return(NULL); - } - dnew->info = dinfo.info; - switch (dinfo.dtype) { - case DTascii: - SET_FILE_TEXT(stdin); - if (!rmx_load_ascii(dnew, fp)) - goto loaderr; - dnew->dtype = DTascii; /* should leave double? */ - break; - case DTfloat: - if (!rmx_load_float(dnew, fp)) - goto loaderr; - dnew->dtype = DTfloat; - break; - case DTdouble: - if (!rmx_load_double(dnew, fp)) - goto loaderr; - dnew->dtype = DTdouble; - break; - case DTrgbe: - case DTxyze: - if (!rmx_load_rgbe(dnew, fp)) - goto loaderr; - dnew->dtype = dinfo.dtype; - break; - default: - goto loaderr; - } - if (fp != stdin) { + ok = rmx_load_data(dnew, fp); /* allocate & load data */ + + if (fp != stdin) { /* close input stream */ if (inspec[0] == '!') pclose(fp); else @@ -277,149 +420,212 @@ rmx_load(const char *inspec) else funlockfile(fp); #endif + if (!ok) { /* load failure? */ + fprintf(stderr, "Error loading data from: %s\n", inspec); + rmx_free(dnew); + return(NULL); + } + /* undo exposure? */ + if ((dnew->cexp[0] != 1.f) | + (dnew->cexp[1] != 1.f) | (dnew->cexp[2] != 1.f)) { + double cmlt[MAXCSAMP]; + int i; + cmlt[0] = 1./dnew->cexp[0]; + cmlt[1] = 1./dnew->cexp[1]; + cmlt[2] = 1./dnew->cexp[2]; + if (dnew->ncomp > MAXCSAMP) { + fprintf(stderr, "Excess spectral components in: %s\n", + inspec); + rmx_free(dnew); + return(NULL); + } + for (i = dnew->ncomp; i-- > 3; ) + cmlt[i] = cmlt[1]; + rmx_scale(dnew, cmlt); + setcolor(dnew->cexp, 1.f, 1.f, 1.f); + } return(dnew); -loaderr: /* should report error? */ - if (inspec[0] == '!') - pclose(fp); - else - fclose(fp); - rmx_free(dnew); - return(NULL); } static int -rmx_write_ascii(const RMATRIX *rm, FILE *fp) +rmx_write_ascii(const double *dp, int nc, int len, FILE *fp) { - const char *fmt = (rm->dtype == DTfloat) ? " %.7e" : - (rm->dtype == DTrgbe) | (rm->dtype == DTxyze) ? " %.3e" : - " %.15e" ; - int i, j, k; - - for (i = 0; i < rm->nrows; i++) { - for (j = 0; j < rm->ncols; j++) { - for (k = 0; k < rm->ncomp; k++) - fprintf(fp, fmt, rmx_lval(rm,i,j,k)); + while (len-- > 0) { + int k = nc; + while (k-- > 0) + fprintf(fp, " %.7e", *dp++); fputc('\t', fp); - } - fputc('\n', fp); } - return(1); + return(fputc('\n', fp) != EOF); } static int -rmx_write_float(const RMATRIX *rm, FILE *fp) +rmx_write_float(const double *dp, int len, FILE *fp) { - int i, j, k; - float val[100]; + float val; - if (rm->ncomp > 100) { - fputs("Unsupported # components in rmx_write_float()\n", stderr); - exit(1); - } - for (i = 0; i < rm->nrows; i++) - for (j = 0; j < rm->ncols; j++) { - for (k = rm->ncomp; k--; ) - val[k] = (float)rmx_lval(rm,i,j,k); - if (putbinary(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp) + while (len--) { + val = *dp++; + if (putbinary(&val, sizeof(float), 1, fp) != 1) return(0); - } + } return(1); } static int -rmx_write_double(const RMATRIX *rm, FILE *fp) +rmx_write_rgbe(const double *dp, int nc, int len, FILE *fp) { - int i, j; + COLR *scan; + int j; - for (i = 0; i < rm->nrows; i++) - for (j = 0; j < rm->ncols; j++) - if (putbinary(&rmx_lval(rm,i,j,0), sizeof(double), rm->ncomp, fp) != rm->ncomp) - return(0); - return(1); + if ((nc != 1) & (nc != 3)) return(0); + scan = (COLR *)tempbuffer(sizeof(COLR)*len); + if (!scan) return(0); + + for (j = 0; j < len; j++, dp += nc) + if (nc == 1) + setcolr(scan[j], dp[0], dp[0], dp[0]); + else + setcolr(scan[j], dp[0], dp[1], dp[2]); + + return(fwritecolrs(scan, len, fp) >= 0); } static int -rmx_write_rgbe(const RMATRIX *rm, FILE *fp) +rmx_write_spec(const double *dp, int nc, int len, FILE *fp) { - COLR *scan = (COLR *)malloc(sizeof(COLR)*rm->ncols); - int i, j; + uby8 *scan; + SCOLOR scol; + int j, k; - if (scan == NULL) + if (nc < 3) return(0); + scan = (uby8 *)tempbuffer((nc+1)*len); + if (!scan) return(0); + for (j = len; j--; dp += nc) { + for (k = nc; k--; ) + scol[k] = dp[k]; + scolor2scolr(scan+j*(nc+1), scol, nc); + } + return(fwritescolrs(scan, nc, len, fp) >= 0); +} + +/* Check if CIE XYZ primaries were specified */ +static int +findCIEprims(const char *info) +{ + RGBPRIMS prims; + + if (!info) return(0); - for (i = 0; i < rm->nrows; i++) { - for (j = rm->ncols; j--; ) - setcolr(scan[j], rmx_lval(rm,i,j,0), - rmx_lval(rm,i,j,1), - rmx_lval(rm,i,j,2) ); - if (fwritecolrs(scan, rm->ncols, fp) < 0) { - free(scan); + info = strstr(info, PRIMARYSTR); + if (!info || !primsval(prims, info)) return(0); - } - } - free(scan); - return(1); + + return((prims[RED][CIEX] > .99) & (prims[RED][CIEY] < .01) && + (prims[GRN][CIEX] < .01) & (prims[GRN][CIEY] > .99) && + (prims[BLU][CIEX] < .01) & (prims[BLU][CIEY] < .01)); } -/* Write matrix to file type indicated by dtype */ +/* Finish writing header data with resolution and format, returning type used */ int -rmx_write(const RMATRIX *rm, int dtype, FILE *fp) +rmx_write_header(const RMATRIX *rm, int dtype, FILE *fp) { - RMATRIX *mydm = NULL; - int ok = 1; - - if ((rm == NULL) | (fp == NULL)) + if (!rm | !fp || rm->ncols <= 0) return(0); -#ifdef getc_unlocked - flockfile(fp); -#endif - /* complete header */ if (rm->info) fputs(rm->info, fp); if (dtype == DTfromHeader) dtype = rm->dtype; - else if ((dtype == DTrgbe) & (rm->dtype == DTxyze)) + else if (dtype == DTrgbe && (rm->dtype == DTxyze || + findCIEprims(rm->info))) dtype = DTxyze; else if ((dtype == DTxyze) & (rm->dtype == DTrgbe)) dtype = DTrgbe; - if ((dtype != DTrgbe) & (dtype != DTxyze)) { - fprintf(fp, "NROWS=%d\n", rm->nrows); + if ((dtype < DTspec) & (rm->ncomp > 3)) + dtype = DTspec; + else if ((dtype == DTspec) & (rm->ncomp <= 3)) + return(0); + + if (dtype == DTascii) /* set file type (WINDOWS) */ + SET_FILE_TEXT(fp); + else + SET_FILE_BINARY(fp); + /* write exposure? */ + if (rm->ncomp == 3 && (rm->cexp[RED] != rm->cexp[GRN]) | + (rm->cexp[GRN] != rm->cexp[BLU])) + fputcolcor(rm->cexp, fp); + else if (rm->cexp[GRN] != 1.f) + fputexpos(rm->cexp[GRN], fp); + /* matrix size? */ + if ((dtype > DTspec) | (rm->nrows <= 0)) { + if (rm->nrows > 0) + fprintf(fp, "NROWS=%d\n", rm->nrows); fprintf(fp, "NCOLS=%d\n", rm->ncols); - fprintf(fp, "NCOMP=%d\n", rm->ncomp); - } else if (rm->ncomp != 3) { /* wrong # components? */ - double cmtx[3]; - if (rm->ncomp != 1) /* only convert grayscale */ - return(0); - cmtx[0] = cmtx[1] = cmtx[2] = 1; - mydm = rmx_transform(rm, 3, cmtx); - if (mydm == NULL) - return(0); - rm = mydm; } - fputformat((char *)cm_fmt_id[dtype], fp); - fputc('\n', fp); - switch (dtype) { /* write data */ + if (dtype >= DTspec) { /* # components & split? */ + fputncomp(rm->ncomp, fp); + if (rm->ncomp > 3 && + memcmp(rm->wlpart, WLPART, sizeof(WLPART))) + fputwlsplit(rm->wlpart, fp); + } else if ((rm->ncomp != 3) & (rm->ncomp != 1)) + return(0); /* wrong # components */ + if ((dtype == DTfloat) | (dtype == DTdouble)) + fputendian(fp); /* important to record */ + fputformat(cm_fmt_id[dtype], fp); + fputc('\n', fp); /* end of header */ + if ((dtype <= DTspec) & (rm->nrows > 0)) + fprtresolu(rm->ncols, rm->nrows, fp); + return(dtype); +} + +/* Write out matrix data (usually by row) */ +int +rmx_write_data(const double *dp, int nc, int len, int dtype, FILE *fp) +{ + switch (dtype) { case DTascii: - ok = rmx_write_ascii(rm, fp); - break; + return(rmx_write_ascii(dp, nc, len, fp)); case DTfloat: - ok = rmx_write_float(rm, fp); - break; + return(rmx_write_float(dp, nc*len, fp)); case DTdouble: - ok = rmx_write_double(rm, fp); - break; + return(putbinary(dp, sizeof(*dp)*nc, len, fp) == len); case DTrgbe: case DTxyze: - fprtresolu(rm->ncols, rm->nrows, fp); - ok = rmx_write_rgbe(rm, fp); - break; - default: - return(0); + return(rmx_write_rgbe(dp, nc, len, fp)); + case DTspec: + return(rmx_write_spec(dp, nc, len, fp)); } - ok &= (fflush(fp) == 0); + return(0); +} + +/* Write matrix using file format indicated by dtype */ +int +rmx_write(const RMATRIX *rm, int dtype, FILE *fp) +{ + int ok = 0; + int i; + /* complete header */ + dtype = rmx_write_header(rm, dtype, fp); + if (dtype <= 0) + return(0); #ifdef getc_unlocked + flockfile(fp); +#endif + if (dtype == DTdouble) /* write all at once? */ + ok = rmx_write_data(rm->mtx, rm->ncomp, + rm->nrows*rm->ncols, dtype, fp); + else /* else row by row */ + for (i = 0; i < rm->nrows; i++) { + ok = rmx_write_data(rmx_val(rm,i,0), rm->ncomp, + rm->ncols, dtype, fp); + if (!ok) break; + } + + if (ok) ok = (fflush(fp) == 0); +#ifdef getc_unlocked funlockfile(fp); #endif - rmx_free(mydm); + if (!ok) fputs("Error writing matrix\n", stderr); return(ok); } @@ -430,60 +636,101 @@ rmx_identity(const int dim, const int n) RMATRIX *rid = rmx_alloc(dim, dim, n); int i, k; - if (rid == NULL) + if (!rid) return(NULL); - memset(rid->mtx, 0, sizeof(rid->mtx[0])*n*dim*dim); - for (i = dim; i--; ) + memset(rid->mtx, 0, array_size(rid)); + for (i = dim; i--; ) { + double *dp = rmx_lval(rid,i,i); for (k = n; k--; ) - rmx_lval(rid,i,i,k) = 1; + dp[k] = 1.; + } return(rid); } -/* Duplicate the given matrix */ +/* Duplicate the given matrix (may be unallocated) */ RMATRIX * rmx_copy(const RMATRIX *rm) { RMATRIX *dnew; - if (rm == NULL) + if (!rm) return(NULL); - dnew = rmx_alloc(rm->nrows, rm->ncols, rm->ncomp); - if (dnew == NULL) + dnew = rmx_new(rm->nrows, rm->ncols, rm->ncomp); + if (!dnew) return(NULL); + if (rm->mtx) { + if (!rmx_prepare(dnew)) { + rmx_free(dnew); + return(NULL); + } + memcpy(dnew->mtx, rm->mtx, array_size(dnew)); + } rmx_addinfo(dnew, rm->info); dnew->dtype = rm->dtype; - memcpy(dnew->mtx, rm->mtx, - sizeof(rm->mtx[0])*rm->ncomp*rm->nrows*rm->ncols); + copycolor(dnew->cexp, rm->cexp); + memcpy(dnew->wlpart, rm->wlpart, sizeof(dnew->wlpart)); return(dnew); } +/* Replace data in first matrix with data from second */ +int +rmx_transfer_data(RMATRIX *rdst, RMATRIX *rsrc, int dometa) +{ + if (!rdst | !rsrc || (rdst->nrows != rsrc->nrows) | + (rdst->ncols != rsrc->ncols) | + (rdst->ncomp != rsrc->ncomp)) + return(0); + + if (dometa) { /* transfer everything? */ + rmx_reset(rdst); + *rdst = *rsrc; + rsrc->info = NULL; rsrc->mapped = NULL; rsrc->mtx = NULL; + return(1); + } +#ifdef MAP_FILE /* just matrix data -- leave metadata */ + if (rdst->mapped) + munmap(rdst->mapped, mapped_size(rdst)); + else +#endif + if (rdst->mtx) + free(rdst->mtx); + rdst->mapped = rsrc->mapped; + rdst->mtx = rsrc->mtx; + rsrc->mapped = NULL; rsrc->mtx = NULL; + return(1); +} + /* Allocate and assign transposed matrix */ RMATRIX * rmx_transpose(const RMATRIX *rm) { RMATRIX *dnew; - int i, j, k; + int i, j; - if (rm == NULL) + if (!rm || !rm->mtx) return(0); if ((rm->nrows == 1) | (rm->ncols == 1)) { dnew = rmx_copy(rm); + if (!dnew) + return(NULL); dnew->nrows = rm->ncols; dnew->ncols = rm->nrows; return(dnew); } dnew = rmx_alloc(rm->ncols, rm->nrows, rm->ncomp); - if (dnew == NULL) + if (!dnew) return(NULL); if (rm->info) { rmx_addinfo(dnew, rm->info); rmx_addinfo(dnew, "Transposed rows and columns\n"); } dnew->dtype = rm->dtype; - for (i = dnew->nrows; i--; ) - for (j = dnew->ncols; j--; ) - for (k = dnew->ncomp; k--; ) - rmx_lval(dnew,i,j,k) = rmx_lval(rm,j,i,k); + copycolor(dnew->cexp, rm->cexp); + memcpy(dnew->wlpart, rm->wlpart, sizeof(dnew->wlpart)); + for (j = dnew->ncols; j--; ) + for (i = dnew->nrows; i--; ) + memcpy(rmx_lval(dnew,i,j), rmx_val(rm,j,i), + sizeof(double)*dnew->ncomp); return(dnew); } @@ -494,11 +741,11 @@ rmx_multiply(const RMATRIX *m1, const RMATRIX *m2) RMATRIX *mres; int i, j, k, h; - if ((m1 == NULL) | (m2 == NULL) || + if (!m1 | !m2 || !m1->mtx | !m2->mtx | (m1->ncomp != m2->ncomp) | (m1->ncols != m2->nrows)) return(NULL); mres = rmx_alloc(m1->nrows, m2->ncols, m1->ncomp); - if (mres == NULL) + if (!mres) return(NULL); i = rmx_newtype(m1->dtype, m2->dtype); if (i) @@ -508,10 +755,10 @@ rmx_multiply(const RMATRIX *m1, const RMATRIX *m2) for (i = mres->nrows; i--; ) for (j = mres->ncols; j--; ) for (k = mres->ncomp; k--; ) { - long double d = 0; + double d = 0; for (h = m1->ncols; h--; ) - d += rmx_lval(m1,i,h,k) * rmx_lval(m2,h,j,k); - rmx_lval(mres,i,j,k) = (double)d; + d += rmx_val(m1,i,h)[k] * rmx_val(m2,h,j)[k]; + rmx_lval(mres,i,j)[k] = d; } return(mres); } @@ -523,8 +770,8 @@ rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide int zeroDivides = 0; int i, j, k; - if ((m1 == NULL) | (m2 == NULL) || - (m1->ncols != m2->ncols) | (m1->nrows != m2->nrows)) + if (!m1 | !m2 || !m1->mtx | !m2->mtx | + (m1->ncols != m2->ncols) | (m1->nrows != m2->nrows)) return(0); if ((m2->ncomp > 1) & (m2->ncomp != m1->ncomp)) return(0); @@ -538,36 +785,36 @@ rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide if (divide) { double d; if (m2->ncomp == 1) { - d = rmx_lval(m2,i,j,0); + d = rmx_val(m2,i,j)[0]; if (d == 0) { ++zeroDivides; for (k = m1->ncomp; k--; ) - rmx_lval(m1,i,j,k) = 0; + rmx_lval(m1,i,j)[k] = 0; } else { d = 1./d; for (k = m1->ncomp; k--; ) - rmx_lval(m1,i,j,k) *= d; + rmx_lval(m1,i,j)[k] *= d; } } else for (k = m1->ncomp; k--; ) { - d = rmx_lval(m2,i,j,k); + d = rmx_val(m2,i,j)[k]; if (d == 0) { ++zeroDivides; - rmx_lval(m1,i,j,k) = 0; + rmx_lval(m1,i,j)[k] = 0; } else - rmx_lval(m1,i,j,k) /= d; + rmx_lval(m1,i,j)[k] /= d; } } else { if (m2->ncomp == 1) { - const double d = rmx_lval(m2,i,j,0); + const double d = rmx_val(m2,i,j)[0]; for (k = m1->ncomp; k--; ) - rmx_lval(m1,i,j,k) *= d; + rmx_lval(m1,i,j)[k] *= d; } else for (k = m1->ncomp; k--; ) - rmx_lval(m1,i,j,k) *= rmx_lval(m2,i,j,k); + rmx_lval(m1,i,j)[k] *= rmx_val(m2,i,j)[k]; } if (zeroDivides) { - fputs("Divide by zero in rmx_elemult()\n", stderr); + rmx_addinfo(m1, "WARNING: zero divide(s) corrupted results\n"); errno = ERANGE; } return(1); @@ -580,14 +827,14 @@ rmx_sum(RMATRIX *msum, const RMATRIX *madd, const doub double *mysf = NULL; int i, j, k; - if ((msum == NULL) | (madd == NULL) || + if (!msum | !madd || !msum->mtx | !madd->mtx | (msum->nrows != madd->nrows) | (msum->ncols != madd->ncols) | (msum->ncomp != madd->ncomp)) return(0); - if (sf == NULL) { + if (!sf) { mysf = (double *)malloc(sizeof(double)*msum->ncomp); - if (mysf == NULL) + if (!mysf) return(0); for (k = msum->ncomp; k--; ) mysf[k] = 1; @@ -599,11 +846,14 @@ rmx_sum(RMATRIX *msum, const RMATRIX *madd, const doub else rmx_addinfo(msum, rmx_mismatch_warn); for (i = msum->nrows; i--; ) - for (j = msum->ncols; j--; ) + for (j = msum->ncols; j--; ) { + const double *da = rmx_val(madd,i,j); + double *ds = rmx_lval(msum,i,j); for (k = msum->ncomp; k--; ) - rmx_lval(msum,i,j,k) += sf[k] * rmx_lval(madd,i,j,k); - - free(mysf); + ds[k] += sf[k] * da[k]; + } + if (mysf) + free(mysf); return(1); } @@ -613,15 +863,17 @@ rmx_scale(RMATRIX *rm, const double sf[]) { int i, j, k; - if ((rm == NULL) | (sf == NULL)) + if (!rm | !sf || !rm->mtx) return(0); for (i = rm->nrows; i--; ) - for (j = rm->ncols; j--; ) + for (j = rm->ncols; j--; ) { + double *dp = rmx_lval(rm,i,j); for (k = rm->ncomp; k--; ) - rmx_lval(rm,i,j,k) *= sf[k]; - + dp[k] *= sf[k]; + } if (rm->info) rmx_addinfo(rm, "Applied scalar\n"); + /* XXX: should record as exposure for COLR and SCOLR types? */ return(1); } @@ -632,27 +884,29 @@ rmx_transform(const RMATRIX *msrc, int n, const double int i, j, ks, kd; RMATRIX *dnew; - if ((msrc == NULL) | (n <= 0) | (cmat == NULL)) + if (!msrc | (n <= 0) | !cmat || !msrc->mtx) return(NULL); dnew = rmx_alloc(msrc->nrows, msrc->ncols, n); - if (dnew == NULL) + if (!dnew) return(NULL); if (msrc->info) { char buf[128]; - sprintf(buf, "Applied %dx%d matrix transform\n", + sprintf(buf, "Applied %dx%d component transform\n", dnew->ncomp, msrc->ncomp); rmx_addinfo(dnew, msrc->info); rmx_addinfo(dnew, buf); } dnew->dtype = msrc->dtype; for (i = dnew->nrows; i--; ) - for (j = dnew->ncols; j--; ) + for (j = dnew->ncols; j--; ) { + const double *ds = rmx_val(msrc,i,j); for (kd = dnew->ncomp; kd--; ) { double d = 0; for (ks = msrc->ncomp; ks--; ) - d += cmat[kd*msrc->ncomp + ks] * rmx_lval(msrc,i,j,ks); - rmx_lval(dnew,i,j,kd) = d; + d += cmat[kd*msrc->ncomp + ks] * ds[ks]; + rmx_lval(dnew,i,j)[kd] = d; } + } return(dnew); } @@ -663,18 +917,19 @@ rmx_from_cmatrix(const CMATRIX *cm) int i, j; RMATRIX *dnew; - if (cm == NULL) + if (!cm) return(NULL); dnew = rmx_alloc(cm->nrows, cm->ncols, 3); - if (dnew == NULL) + if (!dnew) return(NULL); dnew->dtype = DTfloat; for (i = dnew->nrows; i--; ) for (j = dnew->ncols; j--; ) { const COLORV *cv = cm_lval(cm,i,j); - rmx_lval(dnew,i,j,0) = cv[0]; - rmx_lval(dnew,i,j,1) = cv[1]; - rmx_lval(dnew,i,j,2) = cv[2]; + double *dp = rmx_lval(dnew,i,j); + dp[0] = cv[0]; + dp[1] = cv[1]; + dp[2] = cv[2]; } return(dnew); } @@ -686,17 +941,30 @@ cm_from_rmatrix(const RMATRIX *rm) int i, j; CMATRIX *cnew; - if (rm == NULL || rm->ncomp != 3) + if (!rm || !rm->mtx | (rm->ncomp == 2)) return(NULL); cnew = cm_alloc(rm->nrows, rm->ncols); - if (cnew == NULL) + if (!cnew) return(NULL); for (i = cnew->nrows; i--; ) for (j = cnew->ncols; j--; ) { - COLORV *cv = cm_lval(cnew,i,j); - cv[0] = (COLORV)rmx_lval(rm,i,j,0); - cv[1] = (COLORV)rmx_lval(rm,i,j,1); - cv[2] = (COLORV)rmx_lval(rm,i,j,2); + const double *dp = rmx_val(rm,i,j); + COLORV *cv = cm_lval(cnew,i,j); + switch (rm->ncomp) { + case 3: + setcolor(cv, dp[0], dp[1], dp[2]); + break; + case 1: + setcolor(cv, dp[0], dp[0], dp[0]); + break; + default: { + SCOLOR scol; + int k; + for (k = rm->ncomp; k--; ) + scol[k] = dp[k]; + scolor2color(cv, scol, rm->ncomp, rm->wlpart); + } break; + } } return(cnew); }
