| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rmatrix.c,v 2.36 2019/09/03 23:43:07 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* General matrix operations.
| 6 |
| 7 |
| 8 |
#include <stdio.h>
| 9 |
#include <stdlib.h>
| 10 |
#include <string.h>
| 11 |
#include <fcntl.h>
| 12 |
#include <errno.h>
| 13 |
#include "rtio.h"
| 14 |
#include "platform.h"
| 15 |
#include "resolu.h"
| 16 |
#include "paths.h"
| 17 |
#include "rmatrix.h"
| 18 |
| 19 |
static char rmx_mismatch_warn[] = "WARNING: data type mismatch\n";
| 20 |
| 21 |
/* Allocate a nr x nc matrix with n components */
| 22 |
RMATRIX *
| 23 |
rmx_alloc(int nr, int nc, int n)
| 24 |
| 25 |
RMATRIX *dnew;
| 26 |
| 27 |
if ((nr <= 0) | (nc <= 0) | (n <= 0))
| 28 |
return(NULL);
| 29 |
dnew = (RMATRIX *)malloc(sizeof(RMATRIX)-sizeof(dnew->mtx) +
| 30 |
sizeof(dnew->mtx[0])*(n*nr*nc));
| 31 |
if (!dnew)
| 32 |
return(NULL);
| 33 |
dnew->nrows = nr; dnew->ncols = nc; dnew->ncomp = n;
| 34 |
dnew->dtype = DTdouble;
| 35 |
dnew->swapin = 0;
| 36 |
dnew->info = NULL;
| 37 |
return(dnew);
| 38 |
| 39 |
| 40 |
/* Free a RMATRIX array */
| 41 |
void
| 42 |
rmx_free(RMATRIX *rm)
| 43 |
| 44 |
if (!rm) return;
| 45 |
if (rm->info)
| 46 |
free(rm->info);
| 47 |
free(rm);
| 48 |
| 49 |
| 50 |
/* Resolve data type based on two input types (returns 0 for mismatch) */
| 51 |
int
| 52 |
rmx_newtype(int dtyp1, int dtyp2)
| 53 |
| 54 |
if ((dtyp1==DTxyze) | (dtyp1==DTrgbe) |
| 55 |
(dtyp2==DTxyze) | (dtyp2==DTrgbe)
| 56 |
&& dtyp1 != dtyp2)
| 57 |
return(0);
| 58 |
if (dtyp1 < dtyp2)
| 59 |
return(dtyp1);
| 60 |
return(dtyp2);
| 61 |
| 62 |
| 63 |
/* Append header information associated with matrix data */
| 64 |
int
| 65 |
rmx_addinfo(RMATRIX *rm, const char *info)
| 66 |
| 67 |
if (!rm || !info || !*info)
| 68 |
return(0);
| 69 |
if (!rm->info) {
| 70 |
rm->info = (char *)malloc(strlen(info)+1);
| 71 |
if (rm->info) rm->info[0] = '\0';
| 72 |
} else
| 73 |
rm->info = (char *)realloc(rm->info,
| 74 |
strlen(rm->info)+strlen(info)+1);
| 75 |
if (!rm->info)
| 76 |
return(0);
| 77 |
strcat(rm->info, info);
| 78 |
return(1);
| 79 |
| 80 |
| 81 |
static int
| 82 |
get_dminfo(char *s, void *p)
| 83 |
| 84 |
RMATRIX *ip = (RMATRIX *)p;
| 85 |
char fmt[MAXFMTLEN];
| 86 |
int i;
| 87 |
| 88 |
if (headidval(fmt, s))
| 89 |
return(0);
| 90 |
if (!strncmp(s, "NCOMP=", 6)) {
| 91 |
ip->ncomp = atoi(s+6);
| 92 |
return(0);
| 93 |
| 94 |
if (!strncmp(s, "NROWS=", 6)) {
| 95 |
ip->nrows = atoi(s+6);
| 96 |
return(0);
| 97 |
| 98 |
if (!strncmp(s, "NCOLS=", 6)) {
| 99 |
ip->ncols = atoi(s+6);
| 100 |
return(0);
| 101 |
| 102 |
if ((i = isbigendian(s)) >= 0) {
| 103 |
ip->swapin = (nativebigendian() != i);
| 104 |
return(0);
| 105 |
| 106 |
if (!formatval(fmt, s)) {
| 107 |
rmx_addinfo(ip, s);
| 108 |
return(0);
| 109 |
| 110 |
for (i = 1; i < DTend; i++)
| 111 |
if (!strcmp(fmt, cm_fmt_id[i])) {
| 112 |
ip->dtype = i;
| 113 |
return(0);
| 114 |
| 115 |
return(-1);
| 116 |
| 117 |
| 118 |
static int
| 119 |
rmx_load_ascii(RMATRIX *rm, FILE *fp)
| 120 |
| 121 |
int i, j, k;
| 122 |
| 123 |
for (i = 0; i < rm->nrows; i++)
| 124 |
for (j = 0; j < rm->ncols; j++)
| 125 |
for (k = 0; k < rm->ncomp; k++)
| 126 |
if (fscanf(fp, "%lf", &rmx_lval(rm,i,j,k)) != 1)
| 127 |
return(0);
| 128 |
return(1);
| 129 |
| 130 |
| 131 |
static int
| 132 |
rmx_load_float(RMATRIX *rm, FILE *fp)
| 133 |
| 134 |
int i, j, k;
| 135 |
float val[100];
| 136 |
| 137 |
if (rm->ncomp > 100) {
| 138 |
fputs("Unsupported # components in rmx_load_float()\n", stderr);
| 139 |
exit(1);
| 140 |
| 141 |
| 142 |
for (j = 0; j < rm->ncols; j++) {
| 143 |
if (getbinary(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp)
| 144 |
return(0);
| 145 |
if (rm->swapin)
| 146 |
swap32((char *)val, rm->ncomp);
| 147 |
for (k = rm->ncomp; k--; )
| 148 |
rmx_lval(rm,i,j,k) = val[k];
| 149 |
| 150 |
return(1);
| 151 |
| 152 |
| 153 |
static int
| 154 |
rmx_load_double(RMATRIX *rm, FILE *fp)
| 155 |
| 156 |
int i, j;
| 157 |
| 158 |
| 159 |
| 160 |
if (getbinary(&rmx_lval(rm,i,j,0), sizeof(double), rm->ncomp, fp) != rm->ncomp)
| 161 |
return(0);
| 162 |
if (rm->swapin)
| 163 |
swap64((char *)&rmx_lval(rm,i,j,0), rm->ncomp);
| 164 |
| 165 |
return(1);
| 166 |
| 167 |
| 168 |
static int
| 169 |
rmx_load_rgbe(RMATRIX *rm, FILE *fp)
| 170 |
| 171 |
COLOR *scan = (COLOR *)malloc(sizeof(COLOR)*rm->ncols);
| 172 |
int i, j;
| 173 |
| 174 |
if (!scan)
| 175 |
return(0);
| 176 |
for (i = 0; i < rm->nrows; i++) {
| 177 |
if (freadscan(scan, rm->ncols, fp) < 0) {
| 178 |
free(scan);
| 179 |
return(0);
| 180 |
| 181 |
for (j = rm->ncols; j--; ) {
| 182 |
rmx_lval(rm,i,j,0) = colval(scan[j],RED);
| 183 |
rmx_lval(rm,i,j,1) = colval(scan[j],GRN);
| 184 |
rmx_lval(rm,i,j,2) = colval(scan[j],BLU);
| 185 |
| 186 |
| 187 |
free(scan);
| 188 |
return(1);
| 189 |
| 190 |
| 191 |
/* Load matrix from supported file type */
| 192 |
RMATRIX *
| 193 |
rmx_load(const char *inspec)
| 194 |
| 195 |
FILE *fp = stdin;
| 196 |
RMATRIX dinfo;
| 197 |
RMATRIX *dnew;
| 198 |
| 199 |
if (!inspec) { /* reading from stdin? */
| 200 |
inspec = "<stdin>";
| 201 |
SET_FILE_BINARY(stdin);
| 202 |
} else if (inspec[0] == '!') {
| 203 |
if (!(fp = popen(inspec+1, "r")))
| 204 |
return(NULL);
| 205 |
SET_FILE_BINARY(fp);
| 206 |
} else {
| 207 |
const char *sp = inspec; /* check suffix */
| 208 |
while (*sp)
| 209 |
++sp;
| 210 |
while (sp > inspec && sp[-1] != '.')
| 211 |
--sp;
| 212 |
if (!strcasecmp(sp, "XML")) { /* assume it's a BSDF */
| 213 |
CMATRIX *cm = cm_loadBTDF((char *)inspec);
| 214 |
if (!cm)
| 215 |
return(NULL);
| 216 |
dnew = rmx_from_cmatrix(cm);
| 217 |
cm_free(cm);
| 218 |
dnew->dtype = DTascii;
| 219 |
return(dnew);
| 220 |
| 221 |
/* else open it ourselves */
| 222 |
if (!(fp = fopen(inspec, "rb")))
| 223 |
return(NULL);
| 224 |
| 225 |
#ifdef getc_unlocked
| 226 |
flockfile(fp);
| 227 |
#endif
| 228 |
dinfo.nrows = dinfo.ncols = dinfo.ncomp = 0;
| 229 |
dinfo.dtype = DTascii; /* assumed w/o FORMAT */
| 230 |
dinfo.swapin = 0;
| 231 |
dinfo.info = NULL;
| 232 |
if (getheader(fp, get_dminfo, &dinfo) < 0) {
| 233 |
fclose(fp);
| 234 |
return(NULL);
| 235 |
| 236 |
if ((dinfo.nrows <= 0) | (dinfo.ncols <= 0)) {
| 237 |
if (!fscnresolu(&dinfo.ncols, &dinfo.nrows, fp)) {
| 238 |
fclose(fp);
| 239 |
return(NULL);
| 240 |
| 241 |
if (dinfo.ncomp <= 0)
| 242 |
dinfo.ncomp = 3;
| 243 |
else if ((dinfo.dtype == DTrgbe) | (dinfo.dtype == DTxyze) &&
| 244 |
dinfo.ncomp != 3) {
| 245 |
fclose(fp);
| 246 |
return(NULL);
| 247 |
| 248 |
| 249 |
dnew = rmx_alloc(dinfo.nrows, dinfo.ncols, dinfo.ncomp);
| 250 |
if (!dnew) {
| 251 |
fclose(fp);
| 252 |
return(NULL);
| 253 |
| 254 |
dnew->info = dinfo.info;
| 255 |
switch (dinfo.dtype) {
| 256 |
case DTascii:
| 257 |
SET_FILE_TEXT(fp);
| 258 |
if (!rmx_load_ascii(dnew, fp))
| 259 |
goto loaderr;
| 260 |
dnew->dtype = DTascii; /* should leave double? */
| 261 |
break;
| 262 |
case DTfloat:
| 263 |
dnew->swapin = dinfo.swapin;
| 264 |
if (!rmx_load_float(dnew, fp))
| 265 |
goto loaderr;
| 266 |
dnew->dtype = DTfloat;
| 267 |
break;
| 268 |
case DTdouble:
| 269 |
| 270 |
if (!rmx_load_double(dnew, fp))
| 271 |
goto loaderr;
| 272 |
| 273 |
break;
| 274 |
case DTrgbe:
| 275 |
case DTxyze:
| 276 |
if (!rmx_load_rgbe(dnew, fp))
| 277 |
goto loaderr;
| 278 |
dnew->dtype = dinfo.dtype;
| 279 |
break;
| 280 |
default:
| 281 |
goto loaderr;
| 282 |
| 283 |
if (fp != stdin) {
| 284 |
| 285 |
pclose(fp);
| 286 |
else
| 287 |
fclose(fp);
| 288 |
| 289 |
| 290 |
else
| 291 |
funlockfile(fp);
| 292 |
#endif
| 293 |
return(dnew);
| 294 |
loaderr: /* should report error? */
| 295 |
| 296 |
pclose(fp);
| 297 |
else
| 298 |
fclose(fp);
| 299 |
rmx_free(dnew);
| 300 |
return(NULL);
| 301 |
| 302 |
| 303 |
static int
| 304 |
rmx_write_ascii(const RMATRIX *rm, FILE *fp)
| 305 |
| 306 |
const char *fmt = (rm->dtype == DTfloat) ? " %.7e" :
| 307 |
(rm->dtype == DTrgbe) | (rm->dtype == DTxyze) ? " %.3e" :
| 308 |
" %.15e" ;
| 309 |
int i, j, k;
| 310 |
| 311 |
| 312 |
| 313 |
| 314 |
fprintf(fp, fmt, rmx_lval(rm,i,j,k));
| 315 |
fputc('\t', fp);
| 316 |
| 317 |
fputc('\n', fp);
| 318 |
| 319 |
return(1);
| 320 |
| 321 |
| 322 |
static int
| 323 |
rmx_write_float(const RMATRIX *rm, FILE *fp)
| 324 |
| 325 |
int i, j, k;
| 326 |
float val[100];
| 327 |
| 328 |
| 329 |
fputs("Unsupported # components in rmx_write_float()\n", stderr);
| 330 |
exit(1);
| 331 |
| 332 |
| 333 |
| 334 |
| 335 |
val[k] = (float)rmx_lval(rm,i,j,k);
| 336 |
if (putbinary(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp)
| 337 |
return(0);
| 338 |
| 339 |
return(1);
| 340 |
| 341 |
| 342 |
static int
| 343 |
rmx_write_double(const RMATRIX *rm, FILE *fp)
| 344 |
| 345 |
int i, j;
| 346 |
| 347 |
| 348 |
| 349 |
if (putbinary(&rmx_lval(rm,i,j,0), sizeof(double), rm->ncomp, fp) != rm->ncomp)
| 350 |
return(0);
| 351 |
return(1);
| 352 |
| 353 |
| 354 |
static int
| 355 |
rmx_write_rgbe(const RMATRIX *rm, FILE *fp)
| 356 |
| 357 |
COLR *scan = (COLR *)malloc(sizeof(COLR)*rm->ncols);
| 358 |
int i, j;
| 359 |
| 360 |
if (!scan)
| 361 |
return(0);
| 362 |
| 363 |
| 364 |
setcolr(scan[j], rmx_lval(rm,i,j,0),
| 365 |
rmx_lval(rm,i,j,1),
| 366 |
rmx_lval(rm,i,j,2) );
| 367 |
if (fwritecolrs(scan, rm->ncols, fp) < 0) {
| 368 |
free(scan);
| 369 |
return(0);
| 370 |
| 371 |
| 372 |
free(scan);
| 373 |
return(1);
| 374 |
| 375 |
| 376 |
/* Write matrix to file type indicated by dtype */
| 377 |
int
| 378 |
rmx_write(const RMATRIX *rm, int dtype, FILE *fp)
| 379 |
| 380 |
RMATRIX *mydm = NULL;
| 381 |
int ok = 1;
| 382 |
| 383 |
if (!rm | !fp)
| 384 |
return(0);
| 385 |
| 386 |
flockfile(fp);
| 387 |
#endif
| 388 |
/* complete header */
| 389 |
if (rm->info)
| 390 |
fputs(rm->info, fp);
| 391 |
if (dtype == DTfromHeader)
| 392 |
dtype = rm->dtype;
| 393 |
else if ((dtype == DTrgbe) & (rm->dtype == DTxyze))
| 394 |
dtype = DTxyze;
| 395 |
else if ((dtype == DTxyze) & (rm->dtype == DTrgbe))
| 396 |
dtype = DTrgbe;
| 397 |
if ((dtype != DTrgbe) & (dtype != DTxyze)) {
| 398 |
fprintf(fp, "NROWS=%d\n", rm->nrows);
| 399 |
fprintf(fp, "NCOLS=%d\n", rm->ncols);
| 400 |
fprintf(fp, "NCOMP=%d\n", rm->ncomp);
| 401 |
} else if (rm->ncomp != 3) { /* wrong # components? */
| 402 |
double cmtx[3];
| 403 |
if (rm->ncomp != 1) /* only convert grayscale */
| 404 |
return(0);
| 405 |
cmtx[0] = cmtx[1] = cmtx[2] = 1;
| 406 |
mydm = rmx_transform(rm, 3, cmtx);
| 407 |
if (!mydm)
| 408 |
return(0);
| 409 |
rm = mydm;
| 410 |
| 411 |
if ((dtype == DTfloat) | (dtype == DTdouble))
| 412 |
fputendian(fp); /* important to record */
| 413 |
fputformat((char *)cm_fmt_id[dtype], fp);
| 414 |
fputc('\n', fp);
| 415 |
switch (dtype) { /* write data */
| 416 |
case DTascii:
| 417 |
ok = rmx_write_ascii(rm, fp);
| 418 |
break;
| 419 |
case DTfloat:
| 420 |
ok = rmx_write_float(rm, fp);
| 421 |
break;
| 422 |
case DTdouble:
| 423 |
ok = rmx_write_double(rm, fp);
| 424 |
break;
| 425 |
case DTrgbe:
| 426 |
case DTxyze:
| 427 |
fprtresolu(rm->ncols, rm->nrows, fp);
| 428 |
ok = rmx_write_rgbe(rm, fp);
| 429 |
break;
| 430 |
default:
| 431 |
return(0);
| 432 |
| 433 |
ok &= (fflush(fp) == 0);
| 434 |
| 435 |
funlockfile(fp);
| 436 |
#endif
| 437 |
if (mydm)
| 438 |
rmx_free(mydm);
| 439 |
return(ok);
| 440 |
| 441 |
| 442 |
/* Allocate and assign square identity matrix with n components */
| 443 |
RMATRIX *
| 444 |
rmx_identity(const int dim, const int n)
| 445 |
| 446 |
RMATRIX *rid = rmx_alloc(dim, dim, n);
| 447 |
int i, k;
| 448 |
| 449 |
if (!rid)
| 450 |
return(NULL);
| 451 |
memset(rid->mtx, 0, sizeof(rid->mtx[0])*n*dim*dim);
| 452 |
for (i = dim; i--; )
| 453 |
for (k = n; k--; )
| 454 |
rmx_lval(rid,i,i,k) = 1;
| 455 |
return(rid);
| 456 |
| 457 |
| 458 |
/* Duplicate the given matrix */
| 459 |
RMATRIX *
| 460 |
rmx_copy(const RMATRIX *rm)
| 461 |
| 462 |
RMATRIX *dnew;
| 463 |
| 464 |
if (!rm)
| 465 |
return(NULL);
| 466 |
dnew = rmx_alloc(rm->nrows, rm->ncols, rm->ncomp);
| 467 |
if (!dnew)
| 468 |
return(NULL);
| 469 |
rmx_addinfo(dnew, rm->info);
| 470 |
dnew->dtype = rm->dtype;
| 471 |
memcpy(dnew->mtx, rm->mtx,
| 472 |
sizeof(rm->mtx[0])*rm->ncomp*rm->nrows*rm->ncols);
| 473 |
return(dnew);
| 474 |
| 475 |
| 476 |
/* Allocate and assign transposed matrix */
| 477 |
RMATRIX *
| 478 |
rmx_transpose(const RMATRIX *rm)
| 479 |
| 480 |
RMATRIX *dnew;
| 481 |
int i, j, k;
| 482 |
| 483 |
if (!rm)
| 484 |
return(0);
| 485 |
if ((rm->nrows == 1) | (rm->ncols == 1)) {
| 486 |
dnew = rmx_copy(rm);
| 487 |
if (!dnew)
| 488 |
return(NULL);
| 489 |
dnew->nrows = rm->ncols;
| 490 |
dnew->ncols = rm->nrows;
| 491 |
return(dnew);
| 492 |
| 493 |
dnew = rmx_alloc(rm->ncols, rm->nrows, rm->ncomp);
| 494 |
if (!dnew)
| 495 |
return(NULL);
| 496 |
if (rm->info) {
| 497 |
| 498 |
rmx_addinfo(dnew, "Transposed rows and columns\n");
| 499 |
| 500 |
| 501 |
for (i = dnew->nrows; i--; )
| 502 |
for (j = dnew->ncols; j--; )
| 503 |
for (k = dnew->ncomp; k--; )
| 504 |
rmx_lval(dnew,i,j,k) = rmx_lval(rm,j,i,k);
| 505 |
return(dnew);
| 506 |
| 507 |
| 508 |
/* Multiply (concatenate) two matrices and allocate the result */
| 509 |
RMATRIX *
| 510 |
rmx_multiply(const RMATRIX *m1, const RMATRIX *m2)
| 511 |
| 512 |
RMATRIX *mres;
| 513 |
int i, j, k, h;
| 514 |
| 515 |
if (!m1 | !m2 || (m1->ncomp != m2->ncomp) | (m1->ncols != m2->nrows))
| 516 |
return(NULL);
| 517 |
mres = rmx_alloc(m1->nrows, m2->ncols, m1->ncomp);
| 518 |
if (!mres)
| 519 |
return(NULL);
| 520 |
i = rmx_newtype(m1->dtype, m2->dtype);
| 521 |
if (i)
| 522 |
mres->dtype = i;
| 523 |
else
| 524 |
rmx_addinfo(mres, rmx_mismatch_warn);
| 525 |
for (i = mres->nrows; i--; )
| 526 |
for (j = mres->ncols; j--; )
| 527 |
for (k = mres->ncomp; k--; ) {
| 528 |
long double d = 0;
| 529 |
for (h = m1->ncols; h--; )
| 530 |
d += rmx_lval(m1,i,h,k) * rmx_lval(m2,h,j,k);
| 531 |
rmx_lval(mres,i,j,k) = (double)d;
| 532 |
| 533 |
return(mres);
| 534 |
| 535 |
| 536 |
/* Element-wise multiplication (or division) of m2 into m1 */
| 537 |
int
| 538 |
rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide)
| 539 |
| 540 |
int zeroDivides = 0;
| 541 |
int i, j, k;
| 542 |
| 543 |
if (!m1 | !m2 || (m1->ncols != m2->ncols) | (m1->nrows != m2->nrows))
| 544 |
return(0);
| 545 |
if ((m2->ncomp > 1) & (m2->ncomp != m1->ncomp))
| 546 |
return(0);
| 547 |
| 548 |
if (i)
| 549 |
m1->dtype = i;
| 550 |
else
| 551 |
rmx_addinfo(m1, rmx_mismatch_warn);
| 552 |
for (i = m1->nrows; i--; )
| 553 |
for (j = m1->ncols; j--; )
| 554 |
if (divide) {
| 555 |
double d;
| 556 |
if (m2->ncomp == 1) {
| 557 |
d = rmx_lval(m2,i,j,0);
| 558 |
if (d == 0) {
| 559 |
++zeroDivides;
| 560 |
for (k = m1->ncomp; k--; )
| 561 |
rmx_lval(m1,i,j,k) = 0;
| 562 |
} else {
| 563 |
d = 1./d;
| 564 |
| 565 |
rmx_lval(m1,i,j,k) *= d;
| 566 |
| 567 |
} else
| 568 |
for (k = m1->ncomp; k--; ) {
| 569 |
d = rmx_lval(m2,i,j,k);
| 570 |
if (d == 0) {
| 571 |
++zeroDivides;
| 572 |
| 573 |
} else
| 574 |
rmx_lval(m1,i,j,k) /= d;
| 575 |
| 576 |
} else {
| 577 |
| 578 |
const double d = rmx_lval(m2,i,j,0);
| 579 |
| 580 |
| 581 |
} else
| 582 |
| 583 |
rmx_lval(m1,i,j,k) *= rmx_lval(m2,i,j,k);
| 584 |
| 585 |
if (zeroDivides) {
| 586 |
rmx_addinfo(m1, "WARNING: zero divide(s) corrupted results\n");
| 587 |
errno = ERANGE;
| 588 |
| 589 |
return(1);
| 590 |
| 591 |
| 592 |
/* Sum second matrix into first, applying scale factor beforehand */
| 593 |
int
| 594 |
rmx_sum(RMATRIX *msum, const RMATRIX *madd, const double sf[])
| 595 |
| 596 |
double *mysf = NULL;
| 597 |
int i, j, k;
| 598 |
| 599 |
if (!msum | !madd ||
| 600 |
(msum->nrows != madd->nrows) |
| 601 |
(msum->ncols != madd->ncols) |
| 602 |
(msum->ncomp != madd->ncomp))
| 603 |
return(0);
| 604 |
if (!sf) {
| 605 |
mysf = (double *)malloc(sizeof(double)*msum->ncomp);
| 606 |
if (!mysf)
| 607 |
return(0);
| 608 |
for (k = msum->ncomp; k--; )
| 609 |
mysf[k] = 1;
| 610 |
sf = mysf;
| 611 |
| 612 |
i = rmx_newtype(msum->dtype, madd->dtype);
| 613 |
if (i)
| 614 |
msum->dtype = i;
| 615 |
else
| 616 |
rmx_addinfo(msum, rmx_mismatch_warn);
| 617 |
for (i = msum->nrows; i--; )
| 618 |
for (j = msum->ncols; j--; )
| 619 |
| 620 |
rmx_lval(msum,i,j,k) += sf[k] * rmx_lval(madd,i,j,k);
| 621 |
if (mysf)
| 622 |
free(mysf);
| 623 |
return(1);
| 624 |
| 625 |
| 626 |
/* Scale the given matrix by the indicated scalar component vector */
| 627 |
int
| 628 |
rmx_scale(RMATRIX *rm, const double sf[])
| 629 |
| 630 |
int i, j, k;
| 631 |
| 632 |
if (!rm | !sf)
| 633 |
return(0);
| 634 |
for (i = rm->nrows; i--; )
| 635 |
| 636 |
| 637 |
rmx_lval(rm,i,j,k) *= sf[k];
| 638 |
| 639 |
if (rm->info)
| 640 |
rmx_addinfo(rm, "Applied scalar\n");
| 641 |
return(1);
| 642 |
| 643 |
| 644 |
/* Allocate new matrix and apply component transformation */
| 645 |
RMATRIX *
| 646 |
rmx_transform(const RMATRIX *msrc, int n, const double cmat[])
| 647 |
| 648 |
int i, j, ks, kd;
| 649 |
RMATRIX *dnew;
| 650 |
| 651 |
if (!msrc | (n <= 0) | !cmat)
| 652 |
return(NULL);
| 653 |
dnew = rmx_alloc(msrc->nrows, msrc->ncols, n);
| 654 |
if (!dnew)
| 655 |
return(NULL);
| 656 |
if (msrc->info) {
| 657 |
char buf[128];
| 658 |
sprintf(buf, "Applied %dx%d matrix transform\n",
| 659 |
dnew->ncomp, msrc->ncomp);
| 660 |
rmx_addinfo(dnew, msrc->info);
| 661 |
rmx_addinfo(dnew, buf);
| 662 |
| 663 |
dnew->dtype = msrc->dtype;
| 664 |
| 665 |
| 666 |
for (kd = dnew->ncomp; kd--; ) {
| 667 |
double d = 0;
| 668 |
for (ks = msrc->ncomp; ks--; )
| 669 |
d += cmat[kd*msrc->ncomp + ks] * rmx_lval(msrc,i,j,ks);
| 670 |
rmx_lval(dnew,i,j,kd) = d;
| 671 |
| 672 |
return(dnew);
| 673 |
| 674 |
| 675 |
/* Convert a color matrix to newly allocated RMATRIX buffer */
| 676 |
RMATRIX *
| 677 |
rmx_from_cmatrix(const CMATRIX *cm)
| 678 |
| 679 |
int i, j;
| 680 |
RMATRIX *dnew;
| 681 |
| 682 |
if (!cm)
| 683 |
return(NULL);
| 684 |
dnew = rmx_alloc(cm->nrows, cm->ncols, 3);
| 685 |
if (!dnew)
| 686 |
return(NULL);
| 687 |
| 688 |
| 689 |
for (j = dnew->ncols; j--; ) {
| 690 |
const COLORV *cv = cm_lval(cm,i,j);
| 691 |
rmx_lval(dnew,i,j,0) = cv[0];
| 692 |
rmx_lval(dnew,i,j,1) = cv[1];
| 693 |
rmx_lval(dnew,i,j,2) = cv[2];
| 694 |
| 695 |
return(dnew);
| 696 |
| 697 |
| 698 |
/* Convert general matrix to newly allocated CMATRIX buffer */
| 699 |
CMATRIX *
| 700 |
cm_from_rmatrix(const RMATRIX *rm)
| 701 |
| 702 |
int i, j;
| 703 |
CMATRIX *cnew;
| 704 |
| 705 |
if (!rm || rm->ncomp != 3)
| 706 |
return(NULL);
| 707 |
cnew = cm_alloc(rm->nrows, rm->ncols);
| 708 |
if (!cnew)
| 709 |
return(NULL);
| 710 |
for (i = cnew->nrows; i--; )
| 711 |
for (j = cnew->ncols; j--; ) {
| 712 |
COLORV *cv = cm_lval(cnew,i,j);
| 713 |
cv[0] = (COLORV)rmx_lval(rm,i,j,0);
| 714 |
cv[1] = (COLORV)rmx_lval(rm,i,j,1);
| 715 |
cv[2] = (COLORV)rmx_lval(rm,i,j,2);
| 716 |
| 717 |
return(cnew);
| 718 |
