fix(rmtxop): potential overrun of #? header ID
perf: made EXPOSURE and COLORCORR handling more consistent across types
fix(rmtxop): Fixed recently introduced bug in RGBE/XYZE load function
perf(rmtxop): Minor tweak for transpose to improve mmap efficiency
fix(rmtxop): Fixed bug introduced in previous change for transpose operation
perf(rmtxop): realized simpler solution to output of RGBE or XYZE from 1 chan
refactor(rmtxop): Changed matrix array access macros
perf(rmtxop): Reduced memory use when writing HDR output from single channel
perf(rmtxop): Turned off memory-mapped input for files < 1 MByte
perf(rmtxop): Added memory-mapping for double matrices
feat: Added float and double alignment to i/o routines for future mmap() use
fix: added check for primaries to write XYZE file
fix: reinstated interpretation of NULL file name as stdin, so dctimestep works
fix: fixed malloc() call overflow for large matrices
Fixed silly/fatal error in previous modifications
Better fix to bug in last change
Fixed bug in last change
Minor efficiency improvements
Info clarification
Fixed binary mode setting
Minor changes should not affect behavior
Added warning about divide-by-zero to matrix information header
Made checks more compact and consistent
Forgot to check for no memory
Special case for vector transpose
Made ASCII output sensitive to matrix precision
Improved commenting on matrix operations for rmtxop
Saved a little time and memory when writing out RGBE data
Made double i/o more efficient by avoiding unnecessary element copies
Re-removed long double promotion, which I'd already done and undone previously!
Force promotion to long double
Make sure result from loading XML file is ASCII
Moved some file settings around to improve logic
Reduced precision of multiplies in favor of time when little differ found
Added rtprocess.h needed for popen() under Windows
Minor type-checking fix
Fixed rmx_identity(), which was incorrect as first written but never used
Fixed output format for ASCII from ASCII inputs
Took out unreliable call to ftell()
Bug fix pointed out by Andy McNeil
Bug fixes in matrix concatenation
Added missing _O_BINARY setting for Windows
Maintain header information in matrix structure
Made NROWS/NCOLS more consistent with resolution string
Removed unnecessary address operators from function ids.
Bug fixes
