root/radiance/ray/src/util/rmatrix.c
Sat Jul 1 15:25:26 2023 UTC (10 months, 1 week ago) by greg
Diff to previous 2.58 , to selected 2.39
fix(rmtxop): potential overrun of #? header ID
Thu May 18 23:55:10 2023 UTC (11 months, 3 weeks ago) by greg
Changes since 2.57: +19 -12 lines
Diff to previous 2.57 , to selected 2.39
perf: made EXPOSURE and COLORCORR handling more consistent across types
Mon Mar 14 23:28:14 2022 UTC (2 years, 1 month ago) by greg
Diff to previous 2.56 , to selected 2.39
fix(rmtxop): Fixed recently introduced bug in RGBE/XYZE load function
Fri Mar 11 01:11:13 2022 UTC (2 years, 1 month ago) by greg
Changes since 2.55: +5 -5 lines
Diff to previous 2.55 , to selected 2.39
perf(rmtxop): Minor tweak for transpose to improve mmap efficiency
Sun Mar 6 17:21:49 2022 UTC (2 years, 2 months ago) by greg
Changes since 2.54: +3 -3 lines
Diff to previous 2.54 , to selected 2.39
fix(rmtxop): Fixed bug introduced in previous change for transpose operation
Sat Mar 5 15:33:09 2022 UTC (2 years, 2 months ago) by greg
Changes since 2.53: +7 -14 lines
Diff to previous 2.53 , to selected 2.39
perf(rmtxop): realized simpler solution to output of RGBE or XYZE from 1 chan
Sat Mar 5 01:45:21 2022 UTC (2 years, 2 months ago) by greg
Changes since 2.52: +65 -52 lines
Diff to previous 2.52 , to selected 2.39
refactor(rmtxop): Changed matrix array access macros
Fri Mar 4 17:17:28 2022 UTC (2 years, 2 months ago) by greg
Changes since 2.51: +24 -22 lines
Diff to previous 2.51 , to selected 2.39
perf(rmtxop): Reduced memory use when writing HDR output from single channel
Fri Mar 4 02:07:34 2022 UTC (2 years, 2 months ago) by greg
Changes since 2.50: +3 -2 lines
Diff to previous 2.50 , to selected 2.39
perf(rmtxop): Turned off memory-mapped input for files < 1 MByte
Fri Mar 4 01:27:12 2022 UTC (2 years, 2 months ago) by greg
Changes since 2.49: +95 -53 lines
Diff to previous 2.49 , to selected 2.39
perf(rmtxop): Added memory-mapping for double matrices
Thu Mar 3 03:55:13 2022 UTC (2 years, 2 months ago) by greg
Changes since 2.48: +2 -2 lines
Diff to previous 2.48 , to selected 2.39
feat: Added float and double alignment to i/o routines for future mmap() use
Thu Mar 18 00:34:31 2021 UTC (3 years, 1 month ago) by greg
Changes since 2.47: +20 -2 lines
Diff to previous 2.47 , to selected 2.39
fix: added check for primaries to write XYZE file
Fri Jan 22 16:19:15 2021 UTC (3 years, 3 months ago) by greg
Changes since 2.46: +4 -2 lines
Diff to previous 2.46 , to selected 2.39
fix: reinstated interpretation of NULL file name as stdin, so dctimestep works
Tue Jan 19 23:32:00 2021 UTC (3 years, 3 months ago) by greg
Changes since 2.45: +11 -9 lines
Diff to previous 2.45 , to selected 2.39
Fri Jan 15 02:46:28 2021 UTC (3 years, 3 months ago) by greg
Diff to previous 2.44 , to selected 2.39
fix: fixed malloc() call overflow for large matrices
Thu May 7 18:45:16 2020 UTC (4 years ago) by greg
Diff to previous 2.43 , to selected 2.39
Fixed silly/fatal error in previous modifications
Thu Mar 26 18:05:44 2020 UTC (4 years, 1 month ago) by greg
Changes since 2.42: +3 -2 lines
Diff to previous 2.42 , to selected 2.39
Better fix to bug in last change
Thu Mar 26 18:04:24 2020 UTC (4 years, 1 month ago) by greg
Changes since 2.41: +2 -3 lines
Diff to previous 2.41 , to selected 2.39
Fixed bug in last change
Thu Mar 26 18:01:26 2020 UTC (4 years, 1 month ago) by greg
Changes since 2.40: +13 -8 lines
Diff to previous 2.40 , to selected 2.39
Minor efficiency improvements
Wed Mar 25 01:51:09 2020 UTC (4 years, 1 month ago) by greg
Changes since 2.39: +21 -2 lines
Diff to previous 2.39
Revision 2.39 - (view) (download) (annotate) - [selected]
Sat Dec 28 18:05:14 2019 UTC (4 years, 4 months ago) by greg
Changes since 2.38: +1 -4 lines
Diff to previous 2.38
Tue Sep 10 17:22:55 2019 UTC (4 years, 7 months ago) by greg
Diff to previous 2.37 , to selected 2.39
Info clarification
Wed Sep 4 00:03:05 2019 UTC (4 years, 8 months ago) by greg
Changes since 2.36: +3 -3 lines
Diff to previous 2.36 , to selected 2.39
Fixed binary mode setting
Tue Sep 3 23:43:07 2019 UTC (4 years, 8 months ago) by greg
Changes since 2.35: +2 -1 lines
Diff to previous 2.35 , to selected 2.39
Minor changes should not affect behavior
Wed Aug 14 18:20:02 2019 UTC (4 years, 8 months ago) by greg
Changes since 2.34: +16 -2 lines
Diff to previous 2.34 , to selected 2.39
Mon Aug 12 20:38:19 2019 UTC (4 years, 8 months ago) by greg
Changes since 2.33: +2 -2 lines
Diff to previous 2.33 , to selected 2.39
Added warning about divide-by-zero to matrix information header
Mon Aug 12 18:15:44 2019 UTC (4 years, 8 months ago) by greg
Changes since 2.32: +35 -36 lines
Diff to previous 2.32 , to selected 2.39
Made checks more compact and consistent
Mon Aug 12 04:46:34 2019 UTC (4 years, 8 months ago) by greg
Changes since 2.31: +3 -1 lines
Diff to previous 2.31 , to selected 2.39
Forgot to check for no memory
Mon Aug 12 04:12:57 2019 UTC (4 years, 8 months ago) by greg
Changes since 2.30: +7 -1 lines
Diff to previous 2.30 , to selected 2.39
Special case for vector transpose
Fri Oct 19 00:21:31 2018 UTC (5 years, 6 months ago) by greg
Changes since 2.29: +5 -2 lines
Diff to previous 2.29 , to selected 2.39
Made ASCII output sensitive to matrix precision
Thu Aug 2 18:33:50 2018 UTC (5 years, 9 months ago) by greg
Diff to previous 2.28 , to selected 2.39
Wed Jun 13 18:36:38 2018 UTC (5 years, 10 months ago) by greg
Changes since 2.27: +10 -1 lines
Diff to previous 2.27 , to selected 2.39
Improved commenting on matrix operations for rmtxop
Mon Apr 9 21:36:45 2018 UTC (6 years, 1 month ago) by greg
Changes since 2.26: +4 -4 lines
Diff to previous 2.26 , to selected 2.39
Saved a little time and memory when writing out RGBE data
Mon Apr 9 21:30:07 2018 UTC (6 years, 1 month ago) by greg
Changes since 2.25: +7 -23 lines
Diff to previous 2.25 , to selected 2.39
Made double i/o more efficient by avoiding unnecessary element copies
Mon Aug 28 15:59:46 2017 UTC (6 years, 8 months ago) by greg
Changes since 2.24: +59 -1 lines
Diff to previous 2.24 , to selected 2.39
Tue Aug 30 15:11:22 2016 UTC (7 years, 8 months ago) by greg
Changes since 2.23: +2 -3 lines
Diff to previous 2.23 , to selected 2.39
Re-removed long double promotion, which I'd already done and undone previously!
Tue Aug 30 14:54:08 2016 UTC (7 years, 8 months ago) by greg
Changes since 2.22: +3 -2 lines
Diff to previous 2.22 , to selected 2.39
Force promotion to long double
Thu Aug 18 17:57:57 2016 UTC (7 years, 8 months ago) by greg
Changes since 2.21: +4 -10 lines
Diff to previous 2.21 , to selected 2.39
Thu Aug 18 00:52:48 2016 UTC (7 years, 8 months ago) by greg
Changes since 2.20: +6 -5 lines
Diff to previous 2.20 , to selected 2.39
Changes since 2.19: +5 -4 lines
Diff to previous 2.19 , to selected 2.39
Tue Feb 2 18:02:32 2016 UTC (8 years, 3 months ago) by greg
Diff to previous 2.18 , to selected 2.39
Thu Aug 27 04:07:05 2015 UTC (8 years, 8 months ago) by greg
Diff to previous 2.17 , to selected 2.39
Make sure result from loading XML file is ASCII
Wed Jul 22 04:47:51 2015 UTC (8 years, 9 months ago) by greg
Changes since 2.16: +12 -7 lines
Diff to previous 2.16 , to selected 2.39
Moved some file settings around to improve logic
Wed Jul 22 04:29:56 2015 UTC (8 years, 9 months ago) by greg
Changes since 2.15: +2 -3 lines
Diff to previous 2.15 , to selected 2.39
Reduced precision of multiplies in favor of time when little differ found
Fri May 8 18:25:03 2015 UTC (9 years ago) by greg
Diff to previous 2.14 , to selected 2.39
Added rtprocess.h needed for popen() under Windows
Mon May 4 23:27:04 2015 UTC (9 years ago) by greg
Diff to previous 2.13 , to selected 2.39
Minor type-checking fix
Mon May 4 20:53:21 2015 UTC (9 years ago) by greg
Changes since 2.12: +28 -11 lines
Diff to previous 2.12 , to selected 2.39
Fri Jan 23 01:14:20 2015 UTC (9 years, 3 months ago) by greg
Changes since 2.11: +5 -7 lines
Diff to previous 2.11 , to selected 2.39
Fixed rmx_identity(), which was incorrect as first written but never used
Tue Dec 16 20:21:46 2014 UTC (9 years, 4 months ago) by greg
Diff to previous 2.10 , to selected 2.39
Fixed output format for ASCII from ASCII inputs
Thu Sep 18 23:20:12 2014 UTC (9 years, 7 months ago) by greg
CVS Tags: rad4R2P2
Changes since 2.9: +3 -3 lines
Diff to previous 2.9 , to selected 2.39
Took out unreliable call to ftell()
Thu Aug 28 05:59:42 2014 UTC (9 years, 8 months ago) by greg
CVS Tags: rad4R2P1
Diff to previous 2.8 , to selected 2.39
Bug fix pointed out by Andy McNeil
Wed Aug 27 13:33:47 2014 UTC (9 years, 8 months ago) by greg
Changes since 2.7: +6 -5 lines
Diff to previous 2.7 , to selected 2.39
Bug fixes in matrix concatenation
Tue Aug 5 21:45:05 2014 UTC (9 years, 9 months ago) by greg
Changes since 2.6: +4 -1 lines
Diff to previous 2.6 , to selected 2.39
Added missing _O_BINARY setting for Windows
Sat Aug 2 17:10:43 2014 UTC (9 years, 9 months ago) by greg
Changes since 2.5: +56 -27 lines
Diff to previous 2.5 , to selected 2.39
Fri Aug 1 23:37:24 2014 UTC (9 years, 9 months ago) by greg
Changes since 2.4: +47 -3 lines
Diff to previous 2.4 , to selected 2.39
Maintain header information in matrix structure
Thu Jul 24 16:28:17 2014 UTC (9 years, 9 months ago) by greg
CVS Tags: rad4R2
Changes since 2.3: +9 -3 lines
Diff to previous 2.3 , to selected 2.39
Made NROWS/NCOLS more consistent with resolution string
Tue Jul 8 16:39:41 2014 UTC (9 years, 10 months ago) by greg
Diff to previous 2.2 , to selected 2.39
Removed unnecessary address operators from function ids.
Sat May 31 19:21:21 2014 UTC (9 years, 11 months ago) by greg
Changes since 2.1: +13 -19 lines
Diff to previous 2.1 , to selected 2.39
Bug fixes
Sat May 31 05:02:37 2014 UTC (9 years, 11 months ago) by greg
Diff to selected 2.39
