root/radiance/ray/src/util/rmatrix.c
Revision: 2.46
Committed: Tue Jan 19 23:32:00 2021 UTC (3 years, 4 months ago) by greg
Changes since 2.45: +11 -9 lines
2 static const char RCSid[] = "$Id: rmatrix.c,v 2.45 2021/01/15 02:46:28 greg Exp $";
5 * General matrix operations.
6 */
7
8 #include <stdlib.h>
9 #include <errno.h>
10 #include "rtio.h"
11 #include "platform.h"
12 #include "resolu.h"
13 #include "paths.h"
14 #include "rmatrix.h"
15
16 static char rmx_mismatch_warn[] = "WARNING: data type mismatch\n";
17
18 /* Allocate a nr x nc matrix with n components */
19 RMATRIX *
20 rmx_alloc(int nr, int nc, int n)
21 {
22 RMATRIX *dnew;
23
24 if ((nr <= 0) | (nc <= 0) | (n <= 0))
25 return(NULL);
26 dnew = (RMATRIX *)malloc(sizeof(RMATRIX)-sizeof(dnew->mtx) +
27 sizeof(dnew->mtx[0])*n*nr*nc);
28 if (!dnew)
29 return(NULL);
30 dnew->nrows = nr; dnew->ncols = nc; dnew->ncomp = n;
31 dnew->dtype = DTdouble;
32 dnew->swapin = 0;
33 dnew->info = NULL;
34 return(dnew);
35 }
36
37 /* Free a RMATRIX array */
38 void
39 rmx_free(RMATRIX *rm)
40 {
41 if (!rm) return;
42 if (rm->info)
43 free(rm->info);
44 free(rm);
45 }
46
47 /* Resolve data type based on two input types (returns 0 for mismatch) */
48 int
49 rmx_newtype(int dtyp1, int dtyp2)
50 {
51 if ((dtyp1==DTxyze) | (dtyp1==DTrgbe) |
52 (dtyp2==DTxyze) | (dtyp2==DTrgbe)
53 && dtyp1 != dtyp2)
54 return(0);
55 if (dtyp1 < dtyp2)
56 return(dtyp1);
57 return(dtyp2);
58 }
59
60 /* Append header information associated with matrix data */
61 int
62 rmx_addinfo(RMATRIX *rm, const char *info)
63 {
64 if (!rm || !info || !*info)
65 return(0);
66 if (!rm->info) {
67 rm->info = (char *)malloc(strlen(info)+1);
68 if (rm->info) rm->info[0] = '\0';
69 } else
70 rm->info = (char *)realloc(rm->info,
71 strlen(rm->info)+strlen(info)+1);
72 if (!rm->info)
73 return(0);
74 strcat(rm->info, info);
75 return(1);
76 }
77
78 static int
79 get_dminfo(char *s, void *p)
80 {
81 RMATRIX *ip = (RMATRIX *)p;
82 char fmt[MAXFMTLEN];
83 int i;
84
85 if (headidval(fmt, s))
86 return(0);
87 if (!strncmp(s, "NCOMP=", 6)) {
88 ip->ncomp = atoi(s+6);
89 return(0);
90 }
91 if (!strncmp(s, "NROWS=", 6)) {
92 ip->nrows = atoi(s+6);
93 return(0);
94 }
95 if (!strncmp(s, "NCOLS=", 6)) {
96 ip->ncols = atoi(s+6);
97 return(0);
98 }
99 if ((i = isbigendian(s)) >= 0) {
100 ip->swapin = (nativebigendian() != i);
101 return(0);
102 }
103 if (isexpos(s)) {
104 double d = exposval(s);
105 scalecolor(ip->mtx, d);
106 return(0);
107 }
108 if (iscolcor(s)) {
109 COLOR ctmp;
110 colcorval(ctmp, s);
111 multcolor(ip->mtx, ctmp);
112 return(0);
113 }
114 if (!formatval(fmt, s)) {
115 rmx_addinfo(ip, s);
116 return(0);
117 }
118 for (i = 1; i < DTend; i++)
119 if (!strcmp(fmt, cm_fmt_id[i])) {
120 ip->dtype = i;
121 return(0);
122 }
123 return(-1);
124 }
125
126 static int
127 rmx_load_ascii(RMATRIX *rm, FILE *fp)
128 {
129 int i, j, k;
130
131 for (i = 0; i < rm->nrows; i++)
132 for (j = 0; j < rm->ncols; j++)
133 for (k = 0; k < rm->ncomp; k++)
134 if (fscanf(fp, "%lf", &rmx_lval(rm,i,j,k)) != 1)
135 return(0);
136 return(1);
137 }
138
139 static int
140 rmx_load_float(RMATRIX *rm, FILE *fp)
141 {
142 int i, j, k;
143 float val[100];
144
145 if (rm->ncomp > 100) {
146 fputs("Unsupported # components in rmx_load_float()\n", stderr);
147 exit(1);
148 }
149 for (i = 0; i < rm->nrows; i++)
150 for (j = 0; j < rm->ncols; j++) {
151 if (getbinary(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp)
152 return(0);
153 if (rm->swapin)
154 swap32((char *)val, rm->ncomp);
155 for (k = rm->ncomp; k--; )
156 rmx_lval(rm,i,j,k) = val[k];
157 }
158 return(1);
159 }
160
161 static int
162 rmx_load_double(RMATRIX *rm, FILE *fp)
163 {
164 int i;
165
166 if ((char *)&rmx_lval(rm,1,0,0) - (char *)&rmx_lval(rm,0,0,0) !=
167 sizeof(double)*rm->ncols*rm->ncomp) {
168 fputs("Code error in rmx_load_double()\n", stderr);
169 exit(1);
170 }
171 for (i = 0; i < rm->nrows; i++) {
172 if (getbinary(&rmx_lval(rm,i,0,0), sizeof(double)*rm->ncomp,
173 rm->ncols, fp) != rm->ncols)
174 return(0);
175 if (rm->swapin)
176 swap64((char *)&rmx_lval(rm,i,0,0), rm->ncols*rm->ncomp);
177 }
178 return(1);
179 }
180
181 static int
182 rmx_load_rgbe(RMATRIX *rm, FILE *fp)
183 {
184 COLOR *scan = (COLOR *)malloc(sizeof(COLOR)*rm->ncols);
185 int i, j;
186
187 if (!scan)
188 return(0);
189 for (i = 0; i < rm->nrows; i++) {
190 if (freadscan(scan, rm->ncols, fp) < 0) {
191 free(scan);
192 return(0);
193 }
194 for (j = rm->ncols; j--; ) {
195 rmx_lval(rm,i,j,0) = colval(scan[j],RED);
196 rmx_lval(rm,i,j,1) = colval(scan[j],GRN);
197 rmx_lval(rm,i,j,2) = colval(scan[j],BLU);
198 }
199 }
200 free(scan);
201 return(1);
202 }
203
204 /* Load matrix from supported file type */
205 RMATRIX *
206 rmx_load(const char *inspec, RMPref rmp)
207 {
208 FILE *fp;
209 RMATRIX dinfo;
210 RMATRIX *dnew;
211
212 if (!inspec || !*inspec)
213 return(NULL);
214 if (inspec == stdin_name) { /* reading from stdin? */
215 fp = stdin;
216 } else if (inspec[0] == '!') {
217 if (!(fp = popen(inspec+1, "r")))
218 return(NULL);
219 } else {
220 const char *sp = inspec; /* check suffix */
221 while (*sp)
222 ++sp;
223 while (sp > inspec && sp[-1] != '.')
224 --sp;
225 if (!strcasecmp(sp, "XML")) { /* assume it's a BSDF */
226 CMATRIX *cm = rmp==RMPtrans ? cm_loadBTDF(inspec) :
227 cm_loadBRDF(inspec, rmp==RMPreflB) ;
228 if (!cm)
229 return(NULL);
230 dnew = rmx_from_cmatrix(cm);
231 cm_free(cm);
232 dnew->dtype = DTascii;
233 return(dnew);
234 }
235 /* else open it ourselves */
236 if (!(fp = fopen(inspec, "r")))
237 return(NULL);
238 }
239 SET_FILE_BINARY(fp);
240 #ifdef getc_unlocked
241 flockfile(fp);
242 #endif
243 dinfo.nrows = dinfo.ncols = dinfo.ncomp = 0;
244 dinfo.dtype = DTascii; /* assumed w/o FORMAT */
245 dinfo.swapin = 0;
246 dinfo.info = NULL;
247 dinfo.mtx[0] = dinfo.mtx[1] = dinfo.mtx[2] = 1.;
248 if (getheader(fp, get_dminfo, &dinfo) < 0) {
249 fclose(fp);
250 return(NULL);
251 }
252 if ((dinfo.nrows <= 0) | (dinfo.ncols <= 0)) {
253 if (!fscnresolu(&dinfo.ncols, &dinfo.nrows, fp)) {
254 fclose(fp);
255 return(NULL);
256 }
257 if (dinfo.ncomp <= 0)
258 dinfo.ncomp = 3;
259 else if ((dinfo.dtype == DTrgbe) | (dinfo.dtype == DTxyze) &&
260 dinfo.ncomp != 3) {
261 fclose(fp);
262 return(NULL);
263 }
264 }
265 dnew = rmx_alloc(dinfo.nrows, dinfo.ncols, dinfo.ncomp);
266 if (!dnew) {
267 fclose(fp);
268 return(NULL);
269 }
270 dnew->info = dinfo.info;
271 switch (dinfo.dtype) {
272 case DTascii:
273 SET_FILE_TEXT(fp);
274 if (!rmx_load_ascii(dnew, fp))
275 goto loaderr;
276 dnew->dtype = DTascii; /* should leave double? */
277 break;
278 case DTfloat:
279 dnew->swapin = dinfo.swapin;
280 if (!rmx_load_float(dnew, fp))
281 goto loaderr;
282 dnew->dtype = DTfloat;
283 break;
284 case DTdouble:
285 dnew->swapin = dinfo.swapin;
286 if (!rmx_load_double(dnew, fp))
287 goto loaderr;
288 dnew->dtype = DTdouble;
289 break;
290 case DTrgbe:
291 case DTxyze:
292 if (!rmx_load_rgbe(dnew, fp))
293 goto loaderr;
294 dnew->dtype = dinfo.dtype; /* undo exposure? */
295 if ((dinfo.mtx[0] != 1.) | (dinfo.mtx[1] != 1.) |
296 (dinfo.mtx[2] != 1.)) {
297 dinfo.mtx[0] = 1./dinfo.mtx[0];
298 dinfo.mtx[1] = 1./dinfo.mtx[1];
299 dinfo.mtx[2] = 1./dinfo.mtx[2];
300 rmx_scale(dnew, dinfo.mtx);
301 }
302 break;
303 default:
304 goto loaderr;
305 }
306 if (fp != stdin) {
307 if (inspec[0] == '!')
308 pclose(fp);
309 else
310 fclose(fp);
311 }
312 #ifdef getc_unlocked
313 else
314 funlockfile(fp);
315 #endif
316 return(dnew);
317 loaderr: /* should report error? */
318 if (inspec[0] == '!')
319 pclose(fp);
320 else
321 fclose(fp);
322 rmx_free(dnew);
323 return(NULL);
324 }
325
326 static int
327 rmx_write_ascii(const RMATRIX *rm, FILE *fp)
328 {
329 const char *fmt = (rm->dtype == DTfloat) ? " %.7e" :
330 (rm->dtype == DTrgbe) | (rm->dtype == DTxyze) ? " %.3e" :
331 " %.15e" ;
332 int i, j, k;
333
334 for (i = 0; i < rm->nrows; i++) {
335 for (j = 0; j < rm->ncols; j++) {
336 for (k = 0; k < rm->ncomp; k++)
337 fprintf(fp, fmt, rmx_lval(rm,i,j,k));
338 fputc('\t', fp);
339 }
340 fputc('\n', fp);
341 }
342 return(1);
343 }
344
345 static int
346 rmx_write_float(const RMATRIX *rm, FILE *fp)
347 {
348 int i, j, k;
349 float val[100];
350
351 if (rm->ncomp > 100) {
352 fputs("Unsupported # components in rmx_write_float()\n", stderr);
353 exit(1);
354 }
355 for (i = 0; i < rm->nrows; i++)
356 for (j = 0; j < rm->ncols; j++) {
357 for (k = rm->ncomp; k--; )
358 val[k] = (float)rmx_lval(rm,i,j,k);
359 if (putbinary(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp)
360 return(0);
361 }
362 return(1);
363 }
364
365 static int
366 rmx_write_double(const RMATRIX *rm, FILE *fp)
367 {
368 int i, j;
369
370 for (i = 0; i < rm->nrows; i++)
371 for (j = 0; j < rm->ncols; j++)
372 if (putbinary(&rmx_lval(rm,i,j,0), sizeof(double), rm->ncomp, fp) != rm->ncomp)
373 return(0);
374 return(1);
375 }
376
377 static int
378 rmx_write_rgbe(const RMATRIX *rm, FILE *fp)
379 {
380 COLR *scan = (COLR *)malloc(sizeof(COLR)*rm->ncols);
381 int i, j;
382
383 if (!scan)
384 return(0);
385 for (i = 0; i < rm->nrows; i++) {
386 for (j = rm->ncols; j--; )
387 setcolr(scan[j], rmx_lval(rm,i,j,0),
388 rmx_lval(rm,i,j,1),
389 rmx_lval(rm,i,j,2) );
390 if (fwritecolrs(scan, rm->ncols, fp) < 0) {
391 free(scan);
392 return(0);
393 }
394 }
395 free(scan);
396 return(1);
397 }
398
399 /* Write matrix to file type indicated by dtype */
400 int
401 rmx_write(const RMATRIX *rm, int dtype, FILE *fp)
402 {
403 RMATRIX *mydm = NULL;
404 int ok = 1;
405
406 if (!rm | !fp)
407 return(0);
408 #ifdef getc_unlocked
409 flockfile(fp);
410 #endif
411 /* complete header */
412 if (rm->info)
413 fputs(rm->info, fp);
414 if (dtype == DTfromHeader)
415 dtype = rm->dtype;
416 else if ((dtype == DTrgbe) & (rm->dtype == DTxyze))
417 dtype = DTxyze;
418 else if ((dtype == DTxyze) & (rm->dtype == DTrgbe))
419 dtype = DTrgbe;
420 if ((dtype != DTrgbe) & (dtype != DTxyze)) {
421 fprintf(fp, "NROWS=%d\n", rm->nrows);
422 fprintf(fp, "NCOLS=%d\n", rm->ncols);
423 fprintf(fp, "NCOMP=%d\n", rm->ncomp);
424 } else if (rm->ncomp != 3) { /* wrong # components? */
425 double cmtx[3];
426 if (rm->ncomp != 1) /* only convert grayscale */
427 return(0);
428 cmtx[0] = cmtx[1] = cmtx[2] = 1;
429 mydm = rmx_transform(rm, 3, cmtx);
430 if (!mydm)
431 return(0);
432 rm = mydm;
433 }
434 if ((dtype == DTfloat) | (dtype == DTdouble))
435 fputendian(fp); /* important to record */
436 fputformat((char *)cm_fmt_id[dtype], fp);
437 fputc('\n', fp);
438 switch (dtype) { /* write data */
439 case DTascii:
440 ok = rmx_write_ascii(rm, fp);
441 break;
442 case DTfloat:
443 ok = rmx_write_float(rm, fp);
444 break;
445 case DTdouble:
446 ok = rmx_write_double(rm, fp);
447 break;
448 case DTrgbe:
449 case DTxyze:
450 fprtresolu(rm->ncols, rm->nrows, fp);
451 ok = rmx_write_rgbe(rm, fp);
452 break;
453 default:
454 return(0);
455 }
456 ok &= (fflush(fp) == 0);
457 #ifdef getc_unlocked
458 funlockfile(fp);
459 #endif
460 if (mydm)
461 rmx_free(mydm);
462 return(ok);
463 }
464
465 /* Allocate and assign square identity matrix with n components */
466 RMATRIX *
467 rmx_identity(const int dim, const int n)
468 {
469 RMATRIX *rid = rmx_alloc(dim, dim, n);
470 int i, k;
471
472 if (!rid)
473 return(NULL);
474 memset(rid->mtx, 0, sizeof(rid->mtx[0])*n*dim*dim);
475 for (i = dim; i--; )
476 for (k = n; k--; )
477 rmx_lval(rid,i,i,k) = 1;
478 return(rid);
479 }
480
481 /* Duplicate the given matrix */
482 RMATRIX *
483 rmx_copy(const RMATRIX *rm)
484 {
485 RMATRIX *dnew;
486
487 if (!rm)
488 return(NULL);
489 dnew = rmx_alloc(rm->nrows, rm->ncols, rm->ncomp);
490 if (!dnew)
491 return(NULL);
492 rmx_addinfo(dnew, rm->info);
493 dnew->dtype = rm->dtype;
494 memcpy(dnew->mtx, rm->mtx,
495 sizeof(rm->mtx[0])*rm->ncomp*rm->nrows*rm->ncols);
496 return(dnew);
497 }
498
499 /* Allocate and assign transposed matrix */
500 RMATRIX *
501 rmx_transpose(const RMATRIX *rm)
502 {
503 RMATRIX *dnew;
504 int i, j, k;
505
506 if (!rm)
507 return(0);
508 if ((rm->nrows == 1) | (rm->ncols == 1)) {
509 dnew = rmx_copy(rm);
510 if (!dnew)
511 return(NULL);
512 dnew->nrows = rm->ncols;
513 dnew->ncols = rm->nrows;
514 return(dnew);
515 }
516 dnew = rmx_alloc(rm->ncols, rm->nrows, rm->ncomp);
517 if (!dnew)
518 return(NULL);
519 if (rm->info) {
520 rmx_addinfo(dnew, rm->info);
521 rmx_addinfo(dnew, "Transposed rows and columns\n");
522 }
523 dnew->dtype = rm->dtype;
524 for (i = dnew->nrows; i--; )
525 for (j = dnew->ncols; j--; )
526 for (k = dnew->ncomp; k--; )
527 rmx_lval(dnew,i,j,k) = rmx_lval(rm,j,i,k);
528 return(dnew);
529 }
530
531 /* Multiply (concatenate) two matrices and allocate the result */
532 RMATRIX *
533 rmx_multiply(const RMATRIX *m1, const RMATRIX *m2)
534 {
535 RMATRIX *mres;
536 int i, j, k, h;
537
538 if (!m1 | !m2 || (m1->ncomp != m2->ncomp) | (m1->ncols != m2->nrows))
539 return(NULL);
540 mres = rmx_alloc(m1->nrows, m2->ncols, m1->ncomp);
541 if (!mres)
542 return(NULL);
543 i = rmx_newtype(m1->dtype, m2->dtype);
544 if (i)
545 mres->dtype = i;
546 else
547 rmx_addinfo(mres, rmx_mismatch_warn);
548 for (i = mres->nrows; i--; )
549 for (j = mres->ncols; j--; )
550 for (k = mres->ncomp; k--; ) {
551 long double d = 0;
552 for (h = m1->ncols; h--; )
553 d += rmx_lval(m1,i,h,k) * rmx_lval(m2,h,j,k);
554 rmx_lval(mres,i,j,k) = (double)d;
555 }
556 return(mres);
557 }
558
559 /* Element-wise multiplication (or division) of m2 into m1 */
560 int
561 rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide)
562 {
563 int zeroDivides = 0;
564 int i, j, k;
565
566 if (!m1 | !m2 || (m1->ncols != m2->ncols) | (m1->nrows != m2->nrows))
567 return(0);
568 if ((m2->ncomp > 1) & (m2->ncomp != m1->ncomp))
569 return(0);
570 i = rmx_newtype(m1->dtype, m2->dtype);
571 if (i)
572 m1->dtype = i;
573 else
574 rmx_addinfo(m1, rmx_mismatch_warn);
575 for (i = m1->nrows; i--; )
576 for (j = m1->ncols; j--; )
577 if (divide) {
578 double d;
579 if (m2->ncomp == 1) {
580 d = rmx_lval(m2,i,j,0);
581 if (d == 0) {
582 ++zeroDivides;
583 for (k = m1->ncomp; k--; )
584 rmx_lval(m1,i,j,k) = 0;
585 } else {
586 d = 1./d;
587 for (k = m1->ncomp; k--; )
588 rmx_lval(m1,i,j,k) *= d;
589 }
590 } else
591 for (k = m1->ncomp; k--; ) {
592 d = rmx_lval(m2,i,j,k);
593 if (d == 0) {
594 ++zeroDivides;
595 rmx_lval(m1,i,j,k) = 0;
596 } else
597 rmx_lval(m1,i,j,k) /= d;
598 }
599 } else {
600 if (m2->ncomp == 1) {
601 const double d = rmx_lval(m2,i,j,0);
602 for (k = m1->ncomp; k--; )
603 rmx_lval(m1,i,j,k) *= d;
604 } else
605 for (k = m1->ncomp; k--; )
606 rmx_lval(m1,i,j,k) *= rmx_lval(m2,i,j,k);
607 }
608 if (zeroDivides) {
609 rmx_addinfo(m1, "WARNING: zero divide(s) corrupted results\n");
610 errno = ERANGE;
611 }
612 return(1);
613 }
614
615 /* Sum second matrix into first, applying scale factor beforehand */
616 int
617 rmx_sum(RMATRIX *msum, const RMATRIX *madd, const double sf[])
618 {
619 double *mysf = NULL;
620 int i, j, k;
621
622 if (!msum | !madd ||
623 (msum->nrows != madd->nrows) |
624 (msum->ncols != madd->ncols) |
625 (msum->ncomp != madd->ncomp))
626 return(0);
627 if (!sf) {
628 mysf = (double *)malloc(sizeof(double)*msum->ncomp);
629 if (!mysf)
630 return(0);
631 for (k = msum->ncomp; k--; )
632 mysf[k] = 1;
633 sf = mysf;
634 }
635 i = rmx_newtype(msum->dtype, madd->dtype);
636 if (i)
637 msum->dtype = i;
638 else
639 rmx_addinfo(msum, rmx_mismatch_warn);
640 for (i = msum->nrows; i--; )
641 for (j = msum->ncols; j--; )
642 for (k = msum->ncomp; k--; )
643 rmx_lval(msum,i,j,k) += sf[k] * rmx_lval(madd,i,j,k);
644 if (mysf)
645 free(mysf);
646 return(1);
647 }
648
649 /* Scale the given matrix by the indicated scalar component vector */
650 int
651 rmx_scale(RMATRIX *rm, const double sf[])
652 {
653 int i, j, k;
654
655 if (!rm | !sf)
656 return(0);
657 for (i = rm->nrows; i--; )
658 for (j = rm->ncols; j--; )
659 for (k = rm->ncomp; k--; )
660 rmx_lval(rm,i,j,k) *= sf[k];
661
662 if (rm->info)
663 rmx_addinfo(rm, "Applied scalar\n");
664 return(1);
665 }
666
667 /* Allocate new matrix and apply component transformation */
668 RMATRIX *
669 rmx_transform(const RMATRIX *msrc, int n, const double cmat[])
670 {
671 int i, j, ks, kd;
672 RMATRIX *dnew;
673
674 if (!msrc | (n <= 0) | !cmat)
675 return(NULL);
676 dnew = rmx_alloc(msrc->nrows, msrc->ncols, n);
677 if (!dnew)
678 return(NULL);
679 if (msrc->info) {
680 char buf[128];
681 sprintf(buf, "Applied %dx%d component transform\n",
682 dnew->ncomp, msrc->ncomp);
683 rmx_addinfo(dnew, msrc->info);
684 rmx_addinfo(dnew, buf);
685 }
686 dnew->dtype = msrc->dtype;
687 for (i = dnew->nrows; i--; )
688 for (j = dnew->ncols; j--; )
689 for (kd = dnew->ncomp; kd--; ) {
690 double d = 0;
691 for (ks = msrc->ncomp; ks--; )
692 d += cmat[kd*msrc->ncomp + ks] * rmx_lval(msrc,i,j,ks);
693 rmx_lval(dnew,i,j,kd) = d;
694 }
695 return(dnew);
696 }
697
698 /* Convert a color matrix to newly allocated RMATRIX buffer */
699 RMATRIX *
700 rmx_from_cmatrix(const CMATRIX *cm)
701 {
702 int i, j;
703 RMATRIX *dnew;
704
705 if (!cm)
706 return(NULL);
707 dnew = rmx_alloc(cm->nrows, cm->ncols, 3);
708 if (!dnew)
709 return(NULL);
710 dnew->dtype = DTfloat;
711 for (i = dnew->nrows; i--; )
712 for (j = dnew->ncols; j--; ) {
713 const COLORV *cv = cm_lval(cm,i,j);
714 rmx_lval(dnew,i,j,0) = cv[0];
715 rmx_lval(dnew,i,j,1) = cv[1];
716 rmx_lval(dnew,i,j,2) = cv[2];
717 }
718 return(dnew);
719 }
720
721 /* Convert general matrix to newly allocated CMATRIX buffer */
722 CMATRIX *
723 cm_from_rmatrix(const RMATRIX *rm)
724 {
725 int i, j;
726 CMATRIX *cnew;
727
728 if (!rm || rm->ncomp != 3)
729 return(NULL);
730 cnew = cm_alloc(rm->nrows, rm->ncols);
731 if (!cnew)
732 return(NULL);
733 for (i = cnew->nrows; i--; )
734 for (j = cnew->ncols; j--; ) {
735 COLORV *cv = cm_lval(cnew,i,j);
736 cv[0] = (COLORV)rmx_lval(rm,i,j,0);
737 cv[1] = (COLORV)rmx_lval(rm,i,j,1);
738 cv[2] = (COLORV)rmx_lval(rm,i,j,2);
739 }
740 return(cnew);
741 }
