--- ray/src/util/rmatrix.c 2015/05/04 23:27:04 2.14 +++ ray/src/util/rmatrix.c 2019/12/28 18:05:14 2.39 @@ -1,15 +1,16 @@ #ifndef lint -static const char RCSid[] = "$Id: rmatrix.c,v 2.14 2015/05/04 23:27:04 greg Exp $"; +static const char RCSid[] = "$Id: rmatrix.c,v 2.39 2019/12/28 18:05:14 greg Exp $"; #endif /* * General matrix operations. */ -#include #include -#include -#include +#include +#include "rtio.h" +#include "platform.h" #include "resolu.h" +#include "paths.h" #include "rmatrix.h" static char rmx_mismatch_warn[] = "WARNING: data type mismatch\n"; @@ -24,10 +25,11 @@ rmx_alloc(int nr, int nc, int n) return(NULL); dnew = (RMATRIX *)malloc(sizeof(RMATRIX)-sizeof(dnew->mtx) + sizeof(dnew->mtx[0])*(n*nr*nc)); - if (dnew == NULL) + if (!dnew) return(NULL); dnew->nrows = nr; dnew->ncols = nc; dnew->ncomp = n; dnew->dtype = DTdouble; + dnew->swapin = 0; dnew->info = NULL; return(dnew); } @@ -59,7 +61,7 @@ rmx_newtype(int dtyp1, int dtyp2) int rmx_addinfo(RMATRIX *rm, const char *info) { - if (!info || !*info) + if (!rm || !info || !*info) return(0); if (!rm->info) { rm->info = (char *)malloc(strlen(info)+1); @@ -77,7 +79,7 @@ static int get_dminfo(char *s, void *p) { RMATRIX *ip = (RMATRIX *)p; - char fmt[64]; + char fmt[MAXFMTLEN]; int i; if (headidval(fmt, s)) @@ -94,6 +96,10 @@ get_dminfo(char *s, void *p) ip->ncols = atoi(s+6); return(0); } + if ((i = isbigendian(s)) >= 0) { + ip->swapin = (nativebigendian() != i); + return(0); + } if (!formatval(fmt, s)) { rmx_addinfo(ip, s); return(0); @@ -110,9 +116,7 @@ static int rmx_load_ascii(RMATRIX *rm, FILE *fp) { int i, j, k; -#ifdef _WIN32 - _setmode(fileno(fp), _O_TEXT); -#endif + for (i = 0; i < rm->nrows; i++) for (j = 0; j < rm->ncols; j++) for (k = 0; k < rm->ncomp; k++) @@ -133,8 +137,10 @@ rmx_load_float(RMATRIX *rm, FILE *fp) } for (i = 0; i < rm->nrows; i++) for (j = 0; j < rm->ncols; j++) { - if (fread(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp) + if (getbinary(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp) return(0); + if (rm->swapin) + swap32((char *)val, rm->ncomp); for (k = rm->ncomp; k--; ) rmx_lval(rm,i,j,k) = val[k]; } @@ -144,19 +150,14 @@ rmx_load_float(RMATRIX *rm, FILE *fp) static int rmx_load_double(RMATRIX *rm, FILE *fp) { - int i, j, k; - double val[100]; + int i, j; - if (rm->ncomp > 100) { - fputs("Unsupported # components in rmx_load_double()\n", stderr); - exit(1); - } for (i = 0; i < rm->nrows; i++) for (j = 0; j < rm->ncols; j++) { - if (fread(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp) + if (getbinary(&rmx_lval(rm,i,j,0), sizeof(double), rm->ncomp, fp) != rm->ncomp) return(0); - for (k = rm->ncomp; k--; ) - rmx_lval(rm,i,j,k) = val[k]; + if (rm->swapin) + swap64((char *)&rmx_lval(rm,i,j,0), rm->ncomp); } return(1); } @@ -167,7 +168,7 @@ rmx_load_rgbe(RMATRIX *rm, FILE *fp) COLOR *scan = (COLOR *)malloc(sizeof(COLOR)*rm->ncols); int i, j; - if (scan == NULL) + if (!scan) return(0); for (i = 0; i < rm->nrows; i++) { if (freadscan(scan, rm->ncols, fp) < 0) { @@ -192,17 +193,13 @@ rmx_load(const char *inspec) RMATRIX dinfo; RMATRIX *dnew; - if (inspec == NULL) { /* reading from stdin? */ + if (!inspec) { /* reading from stdin? */ inspec = ""; -#ifdef _WIN32 - _setmode(fileno(stdin), _O_BINARY); -#endif + SET_FILE_BINARY(stdin); } else if (inspec[0] == '!') { - if ((fp = popen(inspec+1, "r")) == NULL) + if (!(fp = popen(inspec+1, "r"))) return(NULL); -#ifdef _WIN32 - _setmode(fileno(fp), _O_BINARY); -#endif + SET_FILE_BINARY(fp); } else { const char *sp = inspec; /* check suffix */ while (*sp) @@ -211,14 +208,15 @@ rmx_load(const char *inspec) --sp; if (!strcasecmp(sp, "XML")) { /* assume it's a BSDF */ CMATRIX *cm = cm_loadBTDF((char *)inspec); - if (cm == NULL) + if (!cm) return(NULL); dnew = rmx_from_cmatrix(cm); cm_free(cm); + dnew->dtype = DTascii; return(dnew); } /* else open it ourselves */ - if ((fp = fopen(inspec, "rb")) == NULL) + if (!(fp = fopen(inspec, "rb"))) return(NULL); } #ifdef getc_unlocked @@ -226,6 +224,7 @@ rmx_load(const char *inspec) #endif dinfo.nrows = dinfo.ncols = dinfo.ncomp = 0; dinfo.dtype = DTascii; /* assumed w/o FORMAT */ + dinfo.swapin = 0; dinfo.info = NULL; if (getheader(fp, get_dminfo, &dinfo) < 0) { fclose(fp); @@ -245,23 +244,26 @@ rmx_load(const char *inspec) } } dnew = rmx_alloc(dinfo.nrows, dinfo.ncols, dinfo.ncomp); - if (dnew == NULL) { + if (!dnew) { fclose(fp); return(NULL); } dnew->info = dinfo.info; switch (dinfo.dtype) { case DTascii: + SET_FILE_TEXT(fp); if (!rmx_load_ascii(dnew, fp)) goto loaderr; dnew->dtype = DTascii; /* should leave double? */ break; case DTfloat: + dnew->swapin = dinfo.swapin; if (!rmx_load_float(dnew, fp)) goto loaderr; dnew->dtype = DTfloat; break; case DTdouble: + dnew->swapin = dinfo.swapin; if (!rmx_load_double(dnew, fp)) goto loaderr; dnew->dtype = DTdouble; @@ -298,14 +300,15 @@ loaderr: /* should report error? */ static int rmx_write_ascii(const RMATRIX *rm, FILE *fp) { + const char *fmt = (rm->dtype == DTfloat) ? " %.7e" : + (rm->dtype == DTrgbe) | (rm->dtype == DTxyze) ? " %.3e" : + " %.15e" ; int i, j, k; -#ifdef _WIN32 - _setmode(fileno(fp), _O_TEXT); -#endif + for (i = 0; i < rm->nrows; i++) { for (j = 0; j < rm->ncols; j++) { for (k = 0; k < rm->ncomp; k++) - fprintf(fp, " %.15e", rmx_lval(rm,i,j,k)); + fprintf(fp, fmt, rmx_lval(rm,i,j,k)); fputc('\t', fp); } fputc('\n', fp); @@ -327,7 +330,7 @@ rmx_write_float(const RMATRIX *rm, FILE *fp) for (j = 0; j < rm->ncols; j++) { for (k = rm->ncomp; k--; ) val[k] = (float)rmx_lval(rm,i,j,k); - if (fwrite(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp) + if (putbinary(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp) return(0); } return(1); @@ -336,37 +339,29 @@ rmx_write_float(const RMATRIX *rm, FILE *fp) static int rmx_write_double(const RMATRIX *rm, FILE *fp) { - int i, j, k; - double val[100]; + int i, j; - if (rm->ncomp > 100) { - fputs("Unsupported # components in rmx_write_double()\n", stderr); - exit(1); - } for (i = 0; i < rm->nrows; i++) - for (j = 0; j < rm->ncols; j++) { - for (k = rm->ncomp; k--; ) - val[k] = rmx_lval(rm,i,j,k); - if (fwrite(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp) + for (j = 0; j < rm->ncols; j++) + if (putbinary(&rmx_lval(rm,i,j,0), sizeof(double), rm->ncomp, fp) != rm->ncomp) return(0); - } return(1); } static int rmx_write_rgbe(const RMATRIX *rm, FILE *fp) { - COLOR *scan = (COLOR *)malloc(sizeof(COLOR)*rm->ncols); + COLR *scan = (COLR *)malloc(sizeof(COLR)*rm->ncols); int i, j; - if (scan == NULL) + if (!scan) return(0); for (i = 0; i < rm->nrows; i++) { for (j = rm->ncols; j--; ) - setcolor(scan[j], rmx_lval(rm,i,j,0), + setcolr(scan[j], rmx_lval(rm,i,j,0), rmx_lval(rm,i,j,1), rmx_lval(rm,i,j,2) ); - if (fwritescan(scan, rm->ncols, fp) < 0) { + if (fwritecolrs(scan, rm->ncols, fp) < 0) { free(scan); return(0); } @@ -382,8 +377,11 @@ rmx_write(const RMATRIX *rm, int dtype, FILE *fp) RMATRIX *mydm = NULL; int ok = 1; - if ((rm == NULL) | (fp == NULL)) + if (!rm | !fp) return(0); +#ifdef getc_unlocked + flockfile(fp); +#endif /* complete header */ if (rm->info) fputs(rm->info, fp); @@ -403,10 +401,12 @@ rmx_write(const RMATRIX *rm, int dtype, FILE *fp) return(0); cmtx[0] = cmtx[1] = cmtx[2] = 1; mydm = rmx_transform(rm, 3, cmtx); - if (mydm == NULL) + if (!mydm) return(0); rm = mydm; } + if ((dtype == DTfloat) | (dtype == DTdouble)) + fputendian(fp); /* important to record */ fputformat((char *)cm_fmt_id[dtype], fp); fputc('\n', fp); switch (dtype) { /* write data */ @@ -428,7 +428,11 @@ rmx_write(const RMATRIX *rm, int dtype, FILE *fp) return(0); } ok &= (fflush(fp) == 0); - rmx_free(mydm); +#ifdef getc_unlocked + funlockfile(fp); +#endif + if (mydm) + rmx_free(mydm); return(ok); } @@ -439,7 +443,7 @@ rmx_identity(const int dim, const int n) RMATRIX *rid = rmx_alloc(dim, dim, n); int i, k; - if (rid == NULL) + if (!rid) return(NULL); memset(rid->mtx, 0, sizeof(rid->mtx[0])*n*dim*dim); for (i = dim; i--; ) @@ -454,10 +458,10 @@ rmx_copy(const RMATRIX *rm) { RMATRIX *dnew; - if (rm == NULL) + if (!rm) return(NULL); dnew = rmx_alloc(rm->nrows, rm->ncols, rm->ncomp); - if (dnew == NULL) + if (!dnew) return(NULL); rmx_addinfo(dnew, rm->info); dnew->dtype = rm->dtype; @@ -473,10 +477,18 @@ rmx_transpose(const RMATRIX *rm) RMATRIX *dnew; int i, j, k; - if (rm == NULL) + if (!rm) return(0); + if ((rm->nrows == 1) | (rm->ncols == 1)) { + dnew = rmx_copy(rm); + if (!dnew) + return(NULL); + dnew->nrows = rm->ncols; + dnew->ncols = rm->nrows; + return(dnew); + } dnew = rmx_alloc(rm->ncols, rm->nrows, rm->ncomp); - if (dnew == NULL) + if (!dnew) return(NULL); if (rm->info) { rmx_addinfo(dnew, rm->info); @@ -497,11 +509,10 @@ rmx_multiply(const RMATRIX *m1, const RMATRIX *m2) RMATRIX *mres; int i, j, k, h; - if ((m1 == NULL) | (m2 == NULL) || - (m1->ncomp != m2->ncomp) | (m1->ncols != m2->nrows)) + if (!m1 | !m2 || (m1->ncomp != m2->ncomp) | (m1->ncols != m2->nrows)) return(NULL); mres = rmx_alloc(m1->nrows, m2->ncols, m1->ncomp); - if (mres == NULL) + if (!mres) return(NULL); i = rmx_newtype(m1->dtype, m2->dtype); if (i) @@ -513,13 +524,68 @@ rmx_multiply(const RMATRIX *m1, const RMATRIX *m2) for (k = mres->ncomp; k--; ) { long double d = 0; for (h = m1->ncols; h--; ) - d += (long double)rmx_lval(m1,i,h,k) * - (long double)rmx_lval(m2,h,j,k); + d += rmx_lval(m1,i,h,k) * rmx_lval(m2,h,j,k); rmx_lval(mres,i,j,k) = (double)d; } return(mres); } +/* Element-wise multiplication (or division) of m2 into m1 */ +int +rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide) +{ + int zeroDivides = 0; + int i, j, k; + + if (!m1 | !m2 || (m1->ncols != m2->ncols) | (m1->nrows != m2->nrows)) + return(0); + if ((m2->ncomp > 1) & (m2->ncomp != m1->ncomp)) + return(0); + i = rmx_newtype(m1->dtype, m2->dtype); + if (i) + m1->dtype = i; + else + rmx_addinfo(m1, rmx_mismatch_warn); + for (i = m1->nrows; i--; ) + for (j = m1->ncols; j--; ) + if (divide) { + double d; + if (m2->ncomp == 1) { + d = rmx_lval(m2,i,j,0); + if (d == 0) { + ++zeroDivides; + for (k = m1->ncomp; k--; ) + rmx_lval(m1,i,j,k) = 0; + } else { + d = 1./d; + for (k = m1->ncomp; k--; ) + rmx_lval(m1,i,j,k) *= d; + } + } else + for (k = m1->ncomp; k--; ) { + d = rmx_lval(m2,i,j,k); + if (d == 0) { + ++zeroDivides; + rmx_lval(m1,i,j,k) = 0; + } else + rmx_lval(m1,i,j,k) /= d; + } + } else { + if (m2->ncomp == 1) { + const double d = rmx_lval(m2,i,j,0); + for (k = m1->ncomp; k--; ) + rmx_lval(m1,i,j,k) *= d; + } else + for (k = m1->ncomp; k--; ) + rmx_lval(m1,i,j,k) *= rmx_lval(m2,i,j,k); + } + if (zeroDivides) { + rmx_addinfo(m1, "WARNING: zero divide(s) corrupted results\n"); + errno = ERANGE; + } + return(1); +} + /* Sum second matrix into first, applying scale factor beforehand */ int rmx_sum(RMATRIX *msum, const RMATRIX *madd, const double sf[]) @@ -527,14 +593,14 @@ rmx_sum(RMATRIX *msum, const RMATRIX *madd, const doub double *mysf = NULL; int i, j, k; - if ((msum == NULL) | (madd == NULL) || + if (!msum | !madd || (msum->nrows != madd->nrows) | (msum->ncols != madd->ncols) | (msum->ncomp != madd->ncomp)) return(0); - if (sf == NULL) { + if (!sf) { mysf = (double *)malloc(sizeof(double)*msum->ncomp); - if (mysf == NULL) + if (!mysf) return(0); for (k = msum->ncomp; k--; ) mysf[k] = 1; @@ -549,8 +615,8 @@ rmx_sum(RMATRIX *msum, const RMATRIX *madd, const doub for (j = msum->ncols; j--; ) for (k = msum->ncomp; k--; ) rmx_lval(msum,i,j,k) += sf[k] * rmx_lval(madd,i,j,k); - - free(mysf); + if (mysf) + free(mysf); return(1); } @@ -560,13 +626,15 @@ rmx_scale(RMATRIX *rm, const double sf[]) { int i, j, k; - if ((rm == NULL) | (sf == NULL)) + if (!rm | !sf) return(0); for (i = rm->nrows; i--; ) for (j = rm->ncols; j--; ) for (k = rm->ncomp; k--; ) rmx_lval(rm,i,j,k) *= sf[k]; + if (rm->info) + rmx_addinfo(rm, "Applied scalar\n"); return(1); } @@ -577,11 +645,18 @@ rmx_transform(const RMATRIX *msrc, int n, const double int i, j, ks, kd; RMATRIX *dnew; - if ((msrc == NULL) | (n <= 0) | (cmat == NULL)) + if (!msrc | (n <= 0) | !cmat) return(NULL); dnew = rmx_alloc(msrc->nrows, msrc->ncols, n); - if (dnew == NULL) + if (!dnew) return(NULL); + if (msrc->info) { + char buf[128]; + sprintf(buf, "Applied %dx%d component transform\n", + dnew->ncomp, msrc->ncomp); + rmx_addinfo(dnew, msrc->info); + rmx_addinfo(dnew, buf); + } dnew->dtype = msrc->dtype; for (i = dnew->nrows; i--; ) for (j = dnew->ncols; j--; ) @@ -601,10 +676,10 @@ rmx_from_cmatrix(const CMATRIX *cm) int i, j; RMATRIX *dnew; - if (cm == NULL) + if (!cm) return(NULL); dnew = rmx_alloc(cm->nrows, cm->ncols, 3); - if (dnew == NULL) + if (!dnew) return(NULL); dnew->dtype = DTfloat; for (i = dnew->nrows; i--; ) @@ -624,10 +699,10 @@ cm_from_rmatrix(const RMATRIX *rm) int i, j; CMATRIX *cnew; - if (rm == NULL || rm->ncomp != 3) + if (!rm || rm->ncomp != 3) return(NULL); cnew = cm_alloc(rm->nrows, rm->ncols); - if (cnew == NULL) + if (!cnew) return(NULL); for (i = cnew->nrows; i--; ) for (j = cnew->ncols; j--; ) {
