root/radiance/ray/src/util/rmatrix.c
Revision: 2.10
Committed: Thu Sep 18 23:20:12 2014 UTC (10 years, 8 months ago) by greg
CVS Tags: rad4R2P2
Changes since 2.9: +3 -3 lines
Took out unreliable call to ftell()
2 static const char RCSid[] = "$Id: rmatrix.c,v 2.9 2014/08/28 05:59:42 greg Exp $";
5 * General matrix operations.
6 */
7
8 #include <stdio.h>
9 #include <stdlib.h>
10 #include <string.h>
11 #include <fcntl.h>
12 #include "resolu.h"
13 #include "rmatrix.h"
14
15 static char rmx_mismatch_warn[] = "WARNING: data type mismatch\n";
16
17 /* Allocate a nr x nc matrix with n components */
18 RMATRIX *
19 rmx_alloc(int nr, int nc, int n)
20 {
21 RMATRIX *dnew;
22
23 if ((nr <= 0) | (nc <= 0) | (n <= 0))
24 return(NULL);
25 dnew = (RMATRIX *)malloc(sizeof(RMATRIX)-sizeof(dnew->mtx) +
26 sizeof(dnew->mtx[0])*(n*nr*nc));
27 if (dnew == NULL)
28 return(NULL);
29 dnew->nrows = nr; dnew->ncols = nc; dnew->ncomp = n;
30 dnew->dtype = DTdouble;
31 dnew->info = NULL;
32 return(dnew);
33 }
34
35 /* Free a RMATRIX array */
36 void
37 rmx_free(RMATRIX *rm)
38 {
39 if (!rm) return;
40 if (rm->info)
41 free(rm->info);
42 free(rm);
43 }
44
45 /* Resolve data type based on two input types (returns 0 for mismatch) */
46 int
47 rmx_newtype(int dtyp1, int dtyp2)
48 {
49 if ((dtyp1==DTxyze) | (dtyp1==DTrgbe) && dtyp1 != dtyp2)
50 return(0);
51 if (dtyp1 < dtyp2)
52 return(dtyp1);
53 return(dtyp2);
54 }
55
56 /* Append header information associated with matrix data */
57 int
58 rmx_addinfo(RMATRIX *rm, const char *info)
59 {
60 if (!info || !*info)
61 return(0);
62 if (!rm->info) {
63 rm->info = (char *)malloc(strlen(info)+1);
64 if (rm->info) rm->info[0] = '\0';
65 } else
66 rm->info = (char *)realloc(rm->info,
67 strlen(rm->info)+strlen(info)+1);
68 if (!rm->info)
69 return(0);
70 strcat(rm->info, info);
71 return(1);
72 }
73
74 static int
75 get_dminfo(char *s, void *p)
76 {
77 RMATRIX *ip = (RMATRIX *)p;
78 char fmt[64];
79 int i;
80
81 if (headidval(fmt, s))
82 return(0);
83 if (!strncmp(s, "NCOMP=", 6)) {
84 ip->ncomp = atoi(s+6);
85 return(0);
86 }
87 if (!strncmp(s, "NROWS=", 6)) {
88 ip->nrows = atoi(s+6);
89 return(0);
90 }
91 if (!strncmp(s, "NCOLS=", 6)) {
92 ip->ncols = atoi(s+6);
93 return(0);
94 }
95 if (!formatval(fmt, s)) {
96 rmx_addinfo(ip, s);
97 return(0);
98 }
99 for (i = 1; i < DTend; i++)
100 if (!strcmp(fmt, cm_fmt_id[i])) {
101 ip->dtype = i;
102 return(0);
103 }
104 return(-1);
105 }
106
107 static int
108 rmx_load_ascii(RMATRIX *rm, FILE *fp)
109 {
110 int i, j, k;
111 #ifdef _WIN32
112 _setmode(fileno(fp), _O_TEXT);
113 #endif
114 for (i = 0; i < rm->nrows; i++)
115 for (j = 0; j < rm->ncols; j++)
116 for (k = 0; k < rm->ncomp; k++)
117 if (fscanf(fp, "%lf", &rmx_lval(rm,i,j,k)) != 1)
118 return(0);
119 return(1);
120 }
121
122 static int
123 rmx_load_float(RMATRIX *rm, FILE *fp)
124 {
125 int i, j, k;
126 float val[100];
127
128 if (rm->ncomp > 100) {
129 fputs("Unsupported # components in rmx_load_float()\n", stderr);
130 exit(1);
131 }
132 for (i = 0; i < rm->nrows; i++)
133 for (j = 0; j < rm->ncols; j++) {
134 if (fread(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp)
135 return(0);
136 for (k = rm->ncomp; k--; )
137 rmx_lval(rm,i,j,k) = val[k];
138 }
139 return(1);
140 }
141
142 static int
143 rmx_load_double(RMATRIX *rm, FILE *fp)
144 {
145 int i, j, k;
146 double val[100];
147
148 if (rm->ncomp > 100) {
149 fputs("Unsupported # components in rmx_load_double()\n", stderr);
150 exit(1);
151 }
152 for (i = 0; i < rm->nrows; i++)
153 for (j = 0; j < rm->ncols; j++) {
154 if (fread(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp)
155 return(0);
156 for (k = rm->ncomp; k--; )
157 rmx_lval(rm,i,j,k) = val[k];
158 }
159 return(1);
160 }
161
162 static int
163 rmx_load_rgbe(RMATRIX *rm, FILE *fp)
164 {
165 COLOR *scan = (COLOR *)malloc(sizeof(COLOR)*rm->ncols);
166 int i, j;
167
168 if (scan == NULL)
169 return(0);
170 for (i = 0; i < rm->nrows; i++) {
171 if (freadscan(scan, rm->ncols, fp) < 0) {
172 free(scan);
173 return(0);
174 }
175 for (j = rm->ncols; j--; ) {
176 rmx_lval(rm,i,j,0) = colval(scan[j],RED);
177 rmx_lval(rm,i,j,1) = colval(scan[j],GRN);
178 rmx_lval(rm,i,j,2) = colval(scan[j],BLU);
179 }
180 }
181 free(scan);
182 return(1);
183 }
184
185 /* Load matrix from supported file type */
186 RMATRIX *
187 rmx_load(const char *fname)
188 {
189 FILE *fp = stdin;
190 RMATRIX dinfo;
191 RMATRIX *dnew;
192
193 if (fname == NULL) { /* reading from stdin? */
194 fname = "<stdin>";
195 #ifdef _WIN32
196 _setmode(fileno(stdin), _O_BINARY);
197 #endif
198 } else {
199 const char *sp = fname; /* check suffix */
200 while (*sp)
201 ++sp;
202 while (sp > fname && sp[-1] != '.')
203 --sp;
204 if (!strcasecmp(sp, "XML")) { /* assume it's a BSDF */
205 CMATRIX *cm = cm_loadBTDF((char *)fname);
206 if (cm == NULL)
207 return(NULL);
208 dnew = rmx_from_cmatrix(cm);
209 cm_free(cm);
210 return(dnew);
211 }
212 /* else open it ourselves */
213 if ((fp = fopen(fname, "rb")) == NULL)
214 return(NULL);
215 }
216 #ifdef getc_unlocked
217 flockfile(fp);
218 #endif
219 dinfo.nrows = dinfo.ncols = dinfo.ncomp = 0;
220 dinfo.dtype = DTascii; /* assumed w/o FORMAT */
221 dinfo.info = NULL;
222 if (getheader(fp, get_dminfo, &dinfo) < 0) {
223 fclose(fp);
224 return(NULL);
225 }
226 if ((dinfo.nrows <= 0) | (dinfo.ncols <= 0)) {
227 if (!fscnresolu(&dinfo.ncols, &dinfo.nrows, fp)) {
228 fclose(fp);
229 return(NULL);
230 }
231 if (dinfo.ncomp <= 0)
232 dinfo.ncomp = 3;
233 else if ((dinfo.dtype == DTrgbe) | (dinfo.dtype == DTxyze) &&
234 dinfo.ncomp != 3) {
235 fclose(fp);
236 return(NULL);
237 }
238 }
239 dnew = rmx_alloc(dinfo.nrows, dinfo.ncols, dinfo.ncomp);
240 if (dnew == NULL) {
241 fclose(fp);
242 return(NULL);
243 }
244 dnew->info = dinfo.info;
245 switch (dinfo.dtype) {
246 case DTascii:
247 if (!rmx_load_ascii(dnew, fp))
248 goto loaderr;
249 break;
250 case DTfloat:
251 if (!rmx_load_float(dnew, fp))
252 goto loaderr;
253 dnew->dtype = DTfloat;
254 break;
255 case DTdouble:
256 if (!rmx_load_double(dnew, fp))
257 goto loaderr;
258 dnew->dtype = DTdouble;
259 break;
260 case DTrgbe:
261 case DTxyze:
262 if (!rmx_load_rgbe(dnew, fp))
263 goto loaderr;
264 dnew->dtype = dinfo.dtype;
265 break;
266 default:
267 goto loaderr;
268 }
269 if (fp != stdin)
270 fclose(fp);
271 return(dnew);
272 loaderr: /* should report error? */
273 fclose(fp);
274 rmx_free(dnew);
275 return(NULL);
276 }
277
278 static int
279 rmx_write_ascii(const RMATRIX *rm, FILE *fp)
280 {
281 int i, j, k;
282 #ifdef _WIN32
283 _setmode(fileno(fp), _O_TEXT);
284 #endif
285 for (i = 0; i < rm->nrows; i++) {
286 for (j = 0; j < rm->ncols; j++) {
287 for (k = 0; k < rm->ncomp; k++)
288 fprintf(fp, " %.15e", rmx_lval(rm,i,j,k));
289 fputc('\t', fp);
290 }
291 fputc('\n', fp);
292 }
293 return(1);
294 }
295
296 static int
297 rmx_write_float(const RMATRIX *rm, FILE *fp)
298 {
299 int i, j, k;
300 float val[100];
301
302 if (rm->ncomp > 100) {
303 fputs("Unsupported # components in rmx_write_float()\n", stderr);
304 exit(1);
305 }
306 for (i = 0; i < rm->nrows; i++)
307 for (j = 0; j < rm->ncols; j++) {
308 for (k = rm->ncomp; k--; )
309 val[k] = (float)rmx_lval(rm,i,j,k);
310 if (fwrite(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp)
311 return(0);
312 }
313 return(1);
314 }
315
316 static int
317 rmx_write_double(const RMATRIX *rm, FILE *fp)
318 {
319 int i, j, k;
320 double val[100];
321
322 if (rm->ncomp > 100) {
323 fputs("Unsupported # components in rmx_write_double()\n", stderr);
324 exit(1);
325 }
326 for (i = 0; i < rm->nrows; i++)
327 for (j = 0; j < rm->ncols; j++) {
328 for (k = rm->ncomp; k--; )
329 val[k] = rmx_lval(rm,i,j,k);
330 if (fwrite(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp)
331 return(0);
332 }
333 return(1);
334 }
335
336 static int
337 rmx_write_rgbe(const RMATRIX *rm, FILE *fp)
338 {
339 COLOR *scan = (COLOR *)malloc(sizeof(COLOR)*rm->ncols);
340 int i, j;
341
342 if (scan == NULL)
343 return(0);
344 for (i = 0; i < rm->nrows; i++) {
345 for (j = rm->ncols; j--; )
346 setcolor(scan[j], rmx_lval(rm,i,j,0),
347 rmx_lval(rm,i,j,1),
348 rmx_lval(rm,i,j,2) );
349 if (fwritescan(scan, rm->ncols, fp) < 0) {
350 free(scan);
351 return(0);
352 }
353 }
354 free(scan);
355 return(1);
356 }
357
358 /* Write matrix to file type indicated by dtype */
359 int
360 rmx_write(const RMATRIX *rm, int dtype, FILE *fp)
361 {
362 RMATRIX *mydm = NULL;
363 int ok = 1;
364
365 if ((rm == NULL) | (fp == NULL))
366 return(0);
367 /* complete header */
368 if (rm->info)
369 fputs(rm->info, fp);
370 if (dtype == DTfromHeader)
371 dtype = rm->dtype;
372 else if ((dtype == DTrgbe) & (rm->dtype == DTxyze))
373 dtype = DTxyze;
374 else if ((dtype == DTxyze) & (rm->dtype == DTrgbe))
375 dtype = DTrgbe;
376 if ((dtype != DTrgbe) & (dtype != DTxyze)) {
377 fprintf(fp, "NROWS=%d\n", rm->nrows);
378 fprintf(fp, "NCOLS=%d\n", rm->ncols);
379 fprintf(fp, "NCOMP=%d\n", rm->ncomp);
380 } else if (rm->ncomp != 3) { /* wrong # components? */
381 double cmtx[3];
382 if (rm->ncomp != 1) /* only convert grayscale */
383 return(0);
384 cmtx[0] = cmtx[1] = cmtx[2] = 1;
385 mydm = rmx_transform(rm, 3, cmtx);
386 if (mydm == NULL)
387 return(0);
388 rm = mydm;
389 }
390 fputformat((char *)cm_fmt_id[dtype], fp);
391 fputc('\n', fp);
392 switch (dtype) { /* write data */
393 case DTascii:
394 ok = rmx_write_ascii(rm, fp);
395 break;
396 case DTfloat:
397 ok = rmx_write_float(rm, fp);
398 break;
399 case DTdouble:
400 ok = rmx_write_double(rm, fp);
401 break;
402 case DTrgbe:
403 case DTxyze:
404 fprtresolu(rm->ncols, rm->nrows, fp);
405 ok = rmx_write_rgbe(rm, fp);
406 break;
407 default:
408 return(0);
409 }
410 ok &= (fflush(fp) == 0);
411 rmx_free(mydm);
412 return(ok);
413 }
414
415 /* Allocate and assign square identity matrix with n components */
416 RMATRIX *
417 rmx_identity(const int dim, const int n)
418 {
419 RMATRIX *rid = rmx_alloc(dim, dim, n);
420 int i;
421
422 if (rid == NULL)
423 return(NULL);
424 memset(rid->mtx, 0, sizeof(rid->mtx[0])*dim*dim);
425 for (i = dim; i--; )
426 rmx_lval(rid,i,i,0) = 1;
427 for (i = n; --i; )
428 memcpy(rid->mtx+i*(dim*dim), rid->mtx,
429 sizeof(rid->mtx[0])*dim*dim);
430 return(rid);
431 }
432
433 /* Duplicate the given matrix */
434 RMATRIX *
435 rmx_copy(const RMATRIX *rm)
436 {
437 RMATRIX *dnew;
438
439 if (rm == NULL)
440 return(NULL);
441 dnew = rmx_alloc(rm->nrows, rm->ncols, rm->ncomp);
442 if (dnew == NULL)
443 return(NULL);
444 rmx_addinfo(dnew, rm->info);
445 dnew->dtype = rm->dtype;
446 memcpy(dnew->mtx, rm->mtx,
447 sizeof(rm->mtx[0])*rm->ncomp*rm->nrows*rm->ncols);
448 return(dnew);
449 }
450
451 /* Allocate and assign transposed matrix */
452 RMATRIX *
453 rmx_transpose(const RMATRIX *rm)
454 {
455 RMATRIX *dnew;
456 int i, j, k;
457
458 if (rm == NULL)
459 return(0);
460 dnew = rmx_alloc(rm->ncols, rm->nrows, rm->ncomp);
461 if (dnew == NULL)
462 return(NULL);
463 if (rm->info) {
464 rmx_addinfo(dnew, rm->info);
465 rmx_addinfo(dnew, "Transposed rows and columns\n");
466 }
467 dnew->dtype = rm->dtype;
468 for (i = dnew->nrows; i--; )
469 for (j = dnew->ncols; j--; )
470 for (k = dnew->ncomp; k--; )
471 rmx_lval(dnew,i,j,k) = rmx_lval(rm,j,i,k);
472 return(dnew);
473 }
474
475 /* Multiply (concatenate) two matrices and allocate the result */
476 RMATRIX *
477 rmx_multiply(const RMATRIX *m1, const RMATRIX *m2)
478 {
479 RMATRIX *mres;
480 int i, j, k, h;
481
482 if ((m1 == NULL) | (m2 == NULL) ||
483 (m1->ncomp != m2->ncomp) | (m1->ncols != m2->nrows))
484 return(NULL);
485 mres = rmx_alloc(m1->nrows, m2->ncols, m1->ncomp);
486 if (mres == NULL)
487 return(NULL);
488 i = rmx_newtype(m1->dtype, m2->dtype);
489 if (i)
490 mres->dtype = i;
491 else
492 rmx_addinfo(mres, rmx_mismatch_warn);
493 for (i = mres->nrows; i--; )
494 for (j = mres->ncols; j--; )
495 for (k = mres->ncomp; k--; ) {
496 long double d = 0;
497 for (h = m1->ncols; h--; )
498 d += (long double)rmx_lval(m1,i,h,k) *
499 (long double)rmx_lval(m2,h,j,k);
500 rmx_lval(mres,i,j,k) = (double)d;
501 }
502 return(mres);
503 }
504
505 /* Sum second matrix into first, applying scale factor beforehand */
506 int
507 rmx_sum(RMATRIX *msum, const RMATRIX *madd, const double sf[])
508 {
509 double *mysf = NULL;
510 int i, j, k;
511
512 if ((msum == NULL) | (madd == NULL) ||
513 (msum->nrows != madd->nrows) |
514 (msum->ncols != madd->ncols) |
515 (msum->ncomp != madd->ncomp))
516 return(0);
517 if (sf == NULL) {
518 mysf = (double *)malloc(sizeof(double)*msum->ncomp);
519 if (mysf == NULL)
520 return(0);
521 for (k = msum->ncomp; k--; )
522 mysf[k] = 1;
523 sf = mysf;
524 }
525 i = rmx_newtype(msum->dtype, madd->dtype);
526 if (i)
527 msum->dtype = i;
528 else
529 rmx_addinfo(msum, rmx_mismatch_warn);
530 for (i = msum->nrows; i--; )
531 for (j = msum->ncols; j--; )
532 for (k = msum->ncomp; k--; )
533 rmx_lval(msum,i,j,k) += sf[k] * rmx_lval(madd,i,j,k);
534
535 free(mysf);
536 return(1);
537 }
538
539 /* Scale the given matrix by the indicated scalar component vector */
540 int
541 rmx_scale(RMATRIX *rm, const double sf[])
542 {
543 int i, j, k;
544
545 if ((rm == NULL) | (sf == NULL))
546 return(0);
547 for (i = rm->nrows; i--; )
548 for (j = rm->ncols; j--; )
549 for (k = rm->ncomp; k--; )
550 rmx_lval(rm,i,j,k) *= sf[k];
551
552 return(1);
553 }
554
555 /* Allocate new matrix and apply component transformation */
556 RMATRIX *
557 rmx_transform(const RMATRIX *msrc, int n, const double cmat[])
558 {
559 int i, j, ks, kd;
560 RMATRIX *dnew;
561
562 if ((msrc == NULL) | (n <= 0) | (cmat == NULL))
563 return(NULL);
564 dnew = rmx_alloc(msrc->nrows, msrc->ncols, n);
565 if (dnew == NULL)
566 return(NULL);
567 dnew->dtype = msrc->dtype;
568 for (i = dnew->nrows; i--; )
569 for (j = dnew->ncols; j--; )
570 for (kd = dnew->ncomp; kd--; ) {
571 double d = 0;
572 for (ks = msrc->ncomp; ks--; )
573 d += cmat[kd*msrc->ncomp + ks] * rmx_lval(msrc,i,j,ks);
574 rmx_lval(dnew,i,j,kd) = d;
575 }
576 return(dnew);
577 }
578
579 /* Convert a color matrix to newly allocated RMATRIX buffer */
580 RMATRIX *
581 rmx_from_cmatrix(const CMATRIX *cm)
582 {
583 int i, j;
584 RMATRIX *dnew;
585
586 if (cm == NULL)
587 return(NULL);
588 dnew = rmx_alloc(cm->nrows, cm->ncols, 3);
589 if (dnew == NULL)
590 return(NULL);
591 dnew->dtype = DTfloat;
592 for (i = dnew->nrows; i--; )
593 for (j = dnew->ncols; j--; ) {
594 const COLORV *cv = cm_lval(cm,i,j);
595 rmx_lval(dnew,i,j,0) = cv[0];
596 rmx_lval(dnew,i,j,1) = cv[1];
597 rmx_lval(dnew,i,j,2) = cv[2];
598 }
599 return(dnew);
600 }
601
602 /* Convert general matrix to newly allocated CMATRIX buffer */
603 CMATRIX *
604 cm_from_rmatrix(const RMATRIX *rm)
605 {
606 int i, j;
607 CMATRIX *cnew;
608
609 if (rm == NULL || rm->ncomp != 3)
610 return(NULL);
611 cnew = cm_alloc(rm->nrows, rm->ncols);
612 if (cnew == NULL)
613 return(NULL);
614 for (i = cnew->nrows; i--; )
615 for (j = cnew->ncols; j--; ) {
616 COLORV *cv = cm_lval(cnew,i,j);
617 cv[0] = (COLORV)rmx_lval(rm,i,j,0);
618 cv[1] = (COLORV)rmx_lval(rm,i,j,1);
619 cv[2] = (COLORV)rmx_lval(rm,i,j,2);
620 }
621 return(cnew);
622 }
