Re-removed long double promotion, which I'd already done and undone previously!
Force promotion to long double
Make sure result from loading XML file is ASCII
Moved some file settings around to improve logic
Reduced precision of multiplies in favor of time when little differ found
Added rtprocess.h needed for popen() under Windows
Minor type-checking fix
Fixed rmx_identity(), which was incorrect as first written but never used
Fixed output format for ASCII from ASCII inputs
Took out unreliable call to ftell()
Bug fix pointed out by Andy McNeil
Bug fixes in matrix concatenation
Added missing _O_BINARY setting for Windows
Maintain header information in matrix structure
Made NROWS/NCOLS more consistent with resolution string
Removed unnecessary address operators from function ids.
Bug fixes
