root/radiance/ray/src/util/rmatrix.c
Thu Aug 27 04:07:05 2015 UTC (8 years, 8 months ago) by greg
Diff to previous 2.17 , to selected 2.13
Make sure result from loading XML file is ASCII
Wed Jul 22 04:47:51 2015 UTC (8 years, 9 months ago) by greg
Changes since 2.16: +12 -7 lines
Diff to previous 2.16 , to selected 2.13
Moved some file settings around to improve logic
Wed Jul 22 04:29:56 2015 UTC (8 years, 9 months ago) by greg
Changes since 2.15: +2 -3 lines
Diff to previous 2.15 , to selected 2.13
Reduced precision of multiplies in favor of time when little differ found
Fri May 8 18:25:03 2015 UTC (8 years, 11 months ago) by greg
Added rtprocess.h needed for popen() under Windows
Mon May 4 23:27:04 2015 UTC (8 years, 11 months ago) by greg
Diff to previous 2.13
Minor type-checking fix
Revision 2.13 - (view) (download) (annotate) - [selected]
Mon May 4 20:53:21 2015 UTC (8 years, 11 months ago) by greg
Changes since 2.12: +28 -11 lines
Diff to previous 2.12
Fri Jan 23 01:14:20 2015 UTC (9 years, 3 months ago) by greg
Changes since 2.11: +5 -7 lines
Fixed rmx_identity(), which was incorrect as first written but never used
Tue Dec 16 20:21:46 2014 UTC (9 years, 4 months ago) by greg
Fixed output format for ASCII from ASCII inputs
Thu Sep 18 23:20:12 2014 UTC (9 years, 7 months ago) by greg
CVS Tags: rad4R2P2
Changes since 2.9: +3 -3 lines
Took out unreliable call to ftell()
Thu Aug 28 05:59:42 2014 UTC (9 years, 8 months ago) by greg
CVS Tags: rad4R2P1
Bug fix pointed out by Andy McNeil
Wed Aug 27 13:33:47 2014 UTC (9 years, 8 months ago) by greg
Changes since 2.7: +6 -5 lines
Bug fixes in matrix concatenation
Tue Aug 5 21:45:05 2014 UTC (9 years, 8 months ago) by greg
Changes since 2.6: +4 -1 lines
Added missing _O_BINARY setting for Windows
Sat Aug 2 17:10:43 2014 UTC (9 years, 8 months ago) by greg
Changes since 2.5: +56 -27 lines
Fri Aug 1 23:37:24 2014 UTC (9 years, 8 months ago) by greg
Changes since 2.4: +47 -3 lines
Maintain header information in matrix structure
Thu Jul 24 16:28:17 2014 UTC (9 years, 9 months ago) by greg
CVS Tags: rad4R2
Changes since 2.3: +9 -3 lines
Made NROWS/NCOLS more consistent with resolution string
Tue Jul 8 16:39:41 2014 UTC (9 years, 9 months ago) by greg
Removed unnecessary address operators from function ids.
Sat May 31 19:21:21 2014 UTC (9 years, 10 months ago) by greg
Changes since 2.1: +13 -19 lines
Bug fixes
Sat May 31 05:02:37 2014 UTC (9 years, 10 months ago) by greg
Diff to selected 2.13
