--- ray/src/util/rmatrix.c 2016/08/18 00:52:48 2.21 +++ ray/src/util/rmatrix.c 2022/03/04 17:17:28 2.52 @@ -1,37 +1,62 @@ #ifndef lint -static const char RCSid[] = "$Id: rmatrix.c,v 2.21 2016/08/18 00:52:48 greg Exp $"; +static const char RCSid[] = "$Id: rmatrix.c,v 2.52 2022/03/04 17:17:28 greg Exp $"; #endif /* * General matrix operations. */ -#include #include -#include -#include +#include #include "rtio.h" #include "platform.h" #include "resolu.h" #include "paths.h" #include "rmatrix.h" +#if !defined(_WIN32) && !defined(_WIN64) +#include +#endif static char rmx_mismatch_warn[] = "WARNING: data type mismatch\n"; -/* Allocate a nr x nc matrix with n components */ +#define array_size(rm) (sizeof(double)*(rm)->nrows*(rm)->ncols*(rm)->ncomp) +#define mapped_size(rm) ((char *)(rm)->mtx + array_size(rm) - (char *)(rm)->mapped) + +/* Initialize a RMATRIX struct but don't allocate array space */ RMATRIX * +rmx_new(int nr, int nc, int n) +{ + RMATRIX *dnew = (RMATRIX *)calloc(1, sizeof(RMATRIX)); + + if (dnew) { + dnew->dtype = DTdouble; + dnew->nrows = nr; + dnew->ncols = nc; + dnew->ncomp = n; + } + return(dnew); +} + +/* Prepare a RMATRIX for writing (allocate array if needed) */ +int +rmx_prepare(RMATRIX *rm) +{ + if (!rm) return(0); + if (rm->mtx) + return(1); + rm->mtx = (double *)malloc(array_size(rm)); + return(rm->mtx != NULL); +} + +/* Call rmx_new() and rmx_prepare() */ +RMATRIX * rmx_alloc(int nr, int nc, int n) { - RMATRIX *dnew; + RMATRIX *dnew = rmx_new(nr, nc, n); - if ((nr <= 0) | (nc <= 0) | (n <= 0)) - return(NULL); - dnew = (RMATRIX *)malloc(sizeof(RMATRIX)-sizeof(dnew->mtx) + - sizeof(dnew->mtx[0])*(n*nr*nc)); - if (dnew == NULL) - return(NULL); - dnew->nrows = nr; dnew->ncols = nc; dnew->ncomp = n; - dnew->dtype = DTdouble; - dnew->info = NULL; + if (dnew && !rmx_prepare(dnew)) { + rmx_free(dnew); + dnew = NULL; + } return(dnew); } @@ -42,6 +67,12 @@ rmx_free(RMATRIX *rm) if (!rm) return; if (rm->info) free(rm->info); +#ifdef MAP_FILE + if (rm->mapped) + munmap(rm->mapped, mapped_size(rm)); + else +#endif + free(rm->mtx); free(rm); } @@ -62,17 +93,21 @@ rmx_newtype(int dtyp1, int dtyp2) int rmx_addinfo(RMATRIX *rm, const char *info) { - if (!info || !*info) + int oldlen = 0; + + if (!rm || !info || !*info) return(0); if (!rm->info) { rm->info = (char *)malloc(strlen(info)+1); if (rm->info) rm->info[0] = '\0'; - } else + } else { + oldlen = strlen(rm->info); rm->info = (char *)realloc(rm->info, - strlen(rm->info)+strlen(info)+1); + oldlen+strlen(info)+1); + } if (!rm->info) return(0); - strcat(rm->info, info); + strcpy(rm->info+oldlen, info); return(1); } @@ -80,7 +115,7 @@ static int get_dminfo(char *s, void *p) { RMATRIX *ip = (RMATRIX *)p; - char fmt[64]; + char fmt[MAXFMTLEN]; int i; if (headidval(fmt, s)) @@ -97,10 +132,25 @@ get_dminfo(char *s, void *p) ip->ncols = atoi(s+6); return(0); } + if ((i = isbigendian(s)) >= 0) { + ip->swapin = (nativebigendian() != i); + return(0); + } + if (isexpos(s)) { + float f = exposval(s); + scalecolor(ip->cexp, f); + return(0); + } + if (iscolcor(s)) { + COLOR ctmp; + colcorval(ctmp, s); + multcolor(ip->cexp, ctmp); + return(0); + } if (!formatval(fmt, s)) { rmx_addinfo(ip, s); return(0); - } + } /* else check format */ for (i = 1; i < DTend; i++) if (!strcmp(fmt, cm_fmt_id[i])) { ip->dtype = i; @@ -114,6 +164,8 @@ rmx_load_ascii(RMATRIX *rm, FILE *fp) { int i, j, k; + if (!rmx_prepare(rm)) + return(0); for (i = 0; i < rm->nrows; i++) for (j = 0; j < rm->ncols; j++) for (k = 0; k < rm->ncomp; k++) @@ -132,10 +184,14 @@ rmx_load_float(RMATRIX *rm, FILE *fp) fputs("Unsupported # components in rmx_load_float()\n", stderr); exit(1); } + if (!rmx_prepare(rm)) + return(0); for (i = 0; i < rm->nrows; i++) for (j = 0; j < rm->ncols; j++) { if (getbinary(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp) return(0); + if (rm->swapin) + swap32((char *)val, rm->ncomp); for (k = rm->ncomp; k--; ) rmx_lval(rm,i,j,k) = val[k]; } @@ -145,20 +201,29 @@ rmx_load_float(RMATRIX *rm, FILE *fp) static int rmx_load_double(RMATRIX *rm, FILE *fp) { - int i, j, k; - double val[100]; - - if (rm->ncomp > 100) { - fputs("Unsupported # components in rmx_load_double()\n", stderr); - exit(1); + int i; +#ifdef MAP_FILE + long pos; /* map memory to file if possible */ + if (!rm->swapin && array_size(rm) >= 1L<<20 && + (pos = ftell(fp)) >= 0 && !(pos % sizeof(double))) { + rm->mapped = mmap(NULL, array_size(rm)+pos, PROT_READ|PROT_WRITE, + MAP_PRIVATE, fileno(fp), 0); + if (rm->mapped != MAP_FAILED) { + rm->mtx = (double *)rm->mapped + pos/sizeof(double); + return(1); + } + rm->mapped = NULL; } - for (i = 0; i < rm->nrows; i++) - for (j = 0; j < rm->ncols; j++) { - if (getbinary(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp) - return(0); - for (k = rm->ncomp; k--; ) - rmx_lval(rm,i,j,k) = val[k]; - } +#endif + if (!rmx_prepare(rm)) + return(0); + for (i = 0; i < rm->nrows; i++) { + if (getbinary(&rmx_lval(rm,i,0,0), sizeof(double)*rm->ncomp, + rm->ncols, fp) != rm->ncols) + return(0); + if (rm->swapin) + swap64((char *)&rmx_lval(rm,i,0,0), rm->ncols*rm->ncomp); + } return(1); } @@ -168,8 +233,10 @@ rmx_load_rgbe(RMATRIX *rm, FILE *fp) COLOR *scan = (COLOR *)malloc(sizeof(COLOR)*rm->ncols); int i, j; - if (scan == NULL) + if (!scan) return(0); + if (!rmx_prepare(rm)) + return(0); for (i = 0; i < rm->nrows; i++) { if (freadscan(scan, rm->ncols, fp) < 0) { free(scan); @@ -187,23 +254,20 @@ rmx_load_rgbe(RMATRIX *rm, FILE *fp) /* Load matrix from supported file type */ RMATRIX * -rmx_load(const char *inspec) +rmx_load(const char *inspec, RMPref rmp) { - FILE *fp = stdin; - RMATRIX dinfo; + FILE *fp; RMATRIX *dnew; - if (inspec == NULL) { /* reading from stdin? */ - inspec = ""; -#if defined(_WIN32) || defined(_WIN64) - _setmode(fileno(stdin), _O_BINARY); -#endif + if (!inspec) + inspec = stdin_name; + else if (!*inspec) + return(NULL); + if (inspec == stdin_name) { /* reading from stdin? */ + fp = stdin; } else if (inspec[0] == '!') { - if ((fp = popen(inspec+1, "r")) == NULL) + if (!(fp = popen(inspec+1, "r"))) return(NULL); -#if defined(_WIN32) || defined(_WIN64) - _setmode(fileno(fp), _O_BINARY); -#endif } else { const char *sp = inspec; /* check suffix */ while (*sp) @@ -211,8 +275,9 @@ rmx_load(const char *inspec) while (sp > inspec && sp[-1] != '.') --sp; if (!strcasecmp(sp, "XML")) { /* assume it's a BSDF */ - CMATRIX *cm = cm_loadBTDF((char *)inspec); - if (cm == NULL) + CMATRIX *cm = rmp==RMPtrans ? cm_loadBTDF(inspec) : + cm_loadBRDF(inspec, rmp==RMPreflB) ; + if (!cm) return(NULL); dnew = rmx_from_cmatrix(cm); cm_free(cm); @@ -220,43 +285,37 @@ rmx_load(const char *inspec) return(dnew); } /* else open it ourselves */ - if ((fp = fopen(inspec, "rb")) == NULL) + if (!(fp = fopen(inspec, "r"))) return(NULL); } + SET_FILE_BINARY(fp); #ifdef getc_unlocked flockfile(fp); #endif - dinfo.nrows = dinfo.ncols = dinfo.ncomp = 0; - dinfo.dtype = DTascii; /* assumed w/o FORMAT */ - dinfo.info = NULL; - if (getheader(fp, get_dminfo, &dinfo) < 0) { + if (!(dnew = rmx_new(0,0,3))) { fclose(fp); return(NULL); } - if ((dinfo.nrows <= 0) | (dinfo.ncols <= 0)) { - if (!fscnresolu(&dinfo.ncols, &dinfo.nrows, fp)) { + dnew->dtype = DTascii; /* assumed w/o FORMAT */ + dnew->cexp[0] = dnew->cexp[1] = dnew->cexp[2] = 1.f; + if (getheader(fp, get_dminfo, dnew) < 0) { + fclose(fp); + return(NULL); + } + if ((dnew->nrows <= 0) | (dnew->ncols <= 0)) { + if (!fscnresolu(&dnew->ncols, &dnew->nrows, fp)) { fclose(fp); return(NULL); } - if (dinfo.ncomp <= 0) - dinfo.ncomp = 3; - else if ((dinfo.dtype == DTrgbe) | (dinfo.dtype == DTxyze) && - dinfo.ncomp != 3) { + if ((dnew->dtype == DTrgbe) | (dnew->dtype == DTxyze) && + dnew->ncomp != 3) { fclose(fp); return(NULL); } } - dnew = rmx_alloc(dinfo.nrows, dinfo.ncols, dinfo.ncomp); - if (dnew == NULL) { - fclose(fp); - return(NULL); - } - dnew->info = dinfo.info; - switch (dinfo.dtype) { + switch (dnew->dtype) { case DTascii: -#if defined(_WIN32) || defined(_WIN64) - _setmode(fileno(fp), _O_TEXT); -#endif + SET_FILE_TEXT(fp); if (!rmx_load_ascii(dnew, fp)) goto loaderr; dnew->dtype = DTascii; /* should leave double? */ @@ -275,7 +334,16 @@ rmx_load(const char *inspec) case DTxyze: if (!rmx_load_rgbe(dnew, fp)) goto loaderr; - dnew->dtype = dinfo.dtype; + /* undo exposure? */ + if ((dnew->cexp[0] != 1.f) | (dnew->cexp[1] != 1.f) | + (dnew->cexp[2] != 1.f)) { + double cmlt[3]; + cmlt[0] = 1./dnew->cexp[0]; + cmlt[1] = 1./dnew->cexp[1]; + cmlt[2] = 1./dnew->cexp[2]; + rmx_scale(dnew, cmlt); + } + dnew->swapin = 0; break; default: goto loaderr; @@ -303,12 +371,15 @@ loaderr: /* should report error? */ static int rmx_write_ascii(const RMATRIX *rm, FILE *fp) { + const char *fmt = (rm->dtype == DTfloat) ? " %.7e" : + (rm->dtype == DTrgbe) | (rm->dtype == DTxyze) ? " %.3e" : + " %.15e" ; int i, j, k; for (i = 0; i < rm->nrows; i++) { for (j = 0; j < rm->ncols; j++) { for (k = 0; k < rm->ncomp; k++) - fprintf(fp, " %.15e", rmx_lval(rm,i,j,k)); + fprintf(fp, fmt, rmx_lval(rm,i,j,k)); fputc('\t', fp); } fputc('\n', fp); @@ -339,37 +410,29 @@ rmx_write_float(const RMATRIX *rm, FILE *fp) static int rmx_write_double(const RMATRIX *rm, FILE *fp) { - int i, j, k; - double val[100]; + int i; - if (rm->ncomp > 100) { - fputs("Unsupported # components in rmx_write_double()\n", stderr); - exit(1); - } for (i = 0; i < rm->nrows; i++) - for (j = 0; j < rm->ncols; j++) { - for (k = rm->ncomp; k--; ) - val[k] = rmx_lval(rm,i,j,k); - if (putbinary(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp) + if (putbinary(&rmx_lval(rm,i,0,0), sizeof(double)*rm->ncomp, + rm->ncols, fp) != rm->ncols) return(0); - } return(1); } static int rmx_write_rgbe(const RMATRIX *rm, FILE *fp) { - COLOR *scan = (COLOR *)malloc(sizeof(COLOR)*rm->ncols); + COLR *scan = (COLR *)malloc(sizeof(COLR)*rm->ncols); int i, j; - if (scan == NULL) + if (!scan) return(0); for (i = 0; i < rm->nrows; i++) { for (j = rm->ncols; j--; ) - setcolor(scan[j], rmx_lval(rm,i,j,0), + setcolr(scan[j], rmx_lval(rm,i,j,0), rmx_lval(rm,i,j,1), rmx_lval(rm,i,j,2) ); - if (fwritescan(scan, rm->ncols, fp) < 0) { + if (fwritecolrs(scan, rm->ncols, fp) < 0) { free(scan); return(0); } @@ -378,14 +441,30 @@ rmx_write_rgbe(const RMATRIX *rm, FILE *fp) return(1); } +/* Check if CIE XYZ primaries were specified */ +static int +findCIEprims(const char *info) +{ + RGBPRIMS prims; + + if (!info) + return(0); + info = strstr(info, PRIMARYSTR); + if (!info || !primsval(prims, info)) + return(0); + + return((prims[RED][CIEX] > .99) & (prims[RED][CIEY] < .01) && + (prims[GRN][CIEX] < .01) & (prims[GRN][CIEY] > .99) && + (prims[BLU][CIEX] < .01) & (prims[BLU][CIEY] < .01)); +} + /* Write matrix to file type indicated by dtype */ int rmx_write(const RMATRIX *rm, int dtype, FILE *fp) { - RMATRIX *mydm = NULL; int ok = 1; - if ((rm == NULL) | (fp == NULL)) + if (!rm | !fp || !rm->mtx) return(0); #ifdef getc_unlocked flockfile(fp); @@ -395,7 +474,8 @@ rmx_write(const RMATRIX *rm, int dtype, FILE *fp) fputs(rm->info, fp); if (dtype == DTfromHeader) dtype = rm->dtype; - else if ((dtype == DTrgbe) & (rm->dtype == DTxyze)) + else if (dtype == DTrgbe && (rm->dtype == DTxyze || + findCIEprims(rm->info))) dtype = DTxyze; else if ((dtype == DTxyze) & (rm->dtype == DTrgbe)) dtype = DTrgbe; @@ -404,16 +484,20 @@ rmx_write(const RMATRIX *rm, int dtype, FILE *fp) fprintf(fp, "NCOLS=%d\n", rm->ncols); fprintf(fp, "NCOMP=%d\n", rm->ncomp); } else if (rm->ncomp != 3) { /* wrong # components? */ - double cmtx[3]; + CMATRIX *cm; /* convert & write */ if (rm->ncomp != 1) /* only convert grayscale */ return(0); - cmtx[0] = cmtx[1] = cmtx[2] = 1; - mydm = rmx_transform(rm, 3, cmtx); - if (mydm == NULL) + if (!(cm = cm_from_rmatrix(rm))) return(0); - rm = mydm; + fputformat(cm_fmt_id[dtype], fp); + fputc('\n', fp); + ok = cm_write(cm, dtype, fp); + cm_free(cm); + return(ok); } - fputformat((char *)cm_fmt_id[dtype], fp); + if ((dtype == DTfloat) | (dtype == DTdouble)) + fputendian(fp); /* important to record */ + fputformat(cm_fmt_id[dtype], fp); fputc('\n', fp); switch (dtype) { /* write data */ case DTascii: @@ -437,7 +521,6 @@ rmx_write(const RMATRIX *rm, int dtype, FILE *fp) #ifdef getc_unlocked funlockfile(fp); #endif - rmx_free(mydm); return(ok); } @@ -448,9 +531,9 @@ rmx_identity(const int dim, const int n) RMATRIX *rid = rmx_alloc(dim, dim, n); int i, k; - if (rid == NULL) + if (!rid) return(NULL); - memset(rid->mtx, 0, sizeof(rid->mtx[0])*n*dim*dim); + memset(rid->mtx, 0, array_size(rid)); for (i = dim; i--; ) for (k = n; k--; ) rmx_lval(rid,i,i,k) = 1; @@ -463,15 +546,14 @@ rmx_copy(const RMATRIX *rm) { RMATRIX *dnew; - if (rm == NULL) + if (!rm) return(NULL); dnew = rmx_alloc(rm->nrows, rm->ncols, rm->ncomp); - if (dnew == NULL) + if (!dnew) return(NULL); rmx_addinfo(dnew, rm->info); dnew->dtype = rm->dtype; - memcpy(dnew->mtx, rm->mtx, - sizeof(rm->mtx[0])*rm->ncomp*rm->nrows*rm->ncols); + memcpy(dnew->mtx, rm->mtx, array_size(dnew)); return(dnew); } @@ -482,10 +564,18 @@ rmx_transpose(const RMATRIX *rm) RMATRIX *dnew; int i, j, k; - if (rm == NULL) + if (!rm) return(0); + if ((rm->nrows == 1) | (rm->ncols == 1)) { + dnew = rmx_copy(rm); + if (!dnew) + return(NULL); + dnew->nrows = rm->ncols; + dnew->ncols = rm->nrows; + return(dnew); + } dnew = rmx_alloc(rm->ncols, rm->nrows, rm->ncomp); - if (dnew == NULL) + if (!dnew) return(NULL); if (rm->info) { rmx_addinfo(dnew, rm->info); @@ -506,11 +596,10 @@ rmx_multiply(const RMATRIX *m1, const RMATRIX *m2) RMATRIX *mres; int i, j, k, h; - if ((m1 == NULL) | (m2 == NULL) || - (m1->ncomp != m2->ncomp) | (m1->ncols != m2->nrows)) + if (!m1 | !m2 || (m1->ncomp != m2->ncomp) | (m1->ncols != m2->nrows)) return(NULL); mres = rmx_alloc(m1->nrows, m2->ncols, m1->ncomp); - if (mres == NULL) + if (!mres) return(NULL); i = rmx_newtype(m1->dtype, m2->dtype); if (i) @@ -528,6 +617,62 @@ rmx_multiply(const RMATRIX *m1, const RMATRIX *m2) return(mres); } +/* Element-wise multiplication (or division) of m2 into m1 */ +int +rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide) +{ + int zeroDivides = 0; + int i, j, k; + + if (!m1 | !m2 || (m1->ncols != m2->ncols) | (m1->nrows != m2->nrows)) + return(0); + if ((m2->ncomp > 1) & (m2->ncomp != m1->ncomp)) + return(0); + i = rmx_newtype(m1->dtype, m2->dtype); + if (i) + m1->dtype = i; + else + rmx_addinfo(m1, rmx_mismatch_warn); + for (i = m1->nrows; i--; ) + for (j = m1->ncols; j--; ) + if (divide) { + double d; + if (m2->ncomp == 1) { + d = rmx_lval(m2,i,j,0); + if (d == 0) { + ++zeroDivides; + for (k = m1->ncomp; k--; ) + rmx_lval(m1,i,j,k) = 0; + } else { + d = 1./d; + for (k = m1->ncomp; k--; ) + rmx_lval(m1,i,j,k) *= d; + } + } else + for (k = m1->ncomp; k--; ) { + d = rmx_lval(m2,i,j,k); + if (d == 0) { + ++zeroDivides; + rmx_lval(m1,i,j,k) = 0; + } else + rmx_lval(m1,i,j,k) /= d; + } + } else { + if (m2->ncomp == 1) { + const double d = rmx_lval(m2,i,j,0); + for (k = m1->ncomp; k--; ) + rmx_lval(m1,i,j,k) *= d; + } else + for (k = m1->ncomp; k--; ) + rmx_lval(m1,i,j,k) *= rmx_lval(m2,i,j,k); + } + if (zeroDivides) { + rmx_addinfo(m1, "WARNING: zero divide(s) corrupted results\n"); + errno = ERANGE; + } + return(1); +} + /* Sum second matrix into first, applying scale factor beforehand */ int rmx_sum(RMATRIX *msum, const RMATRIX *madd, const double sf[]) @@ -535,14 +680,14 @@ rmx_sum(RMATRIX *msum, const RMATRIX *madd, const doub double *mysf = NULL; int i, j, k; - if ((msum == NULL) | (madd == NULL) || + if (!msum | !madd || (msum->nrows != madd->nrows) | (msum->ncols != madd->ncols) | (msum->ncomp != madd->ncomp)) return(0); - if (sf == NULL) { + if (!sf) { mysf = (double *)malloc(sizeof(double)*msum->ncomp); - if (mysf == NULL) + if (!mysf) return(0); for (k = msum->ncomp; k--; ) mysf[k] = 1; @@ -557,8 +702,8 @@ rmx_sum(RMATRIX *msum, const RMATRIX *madd, const doub for (j = msum->ncols; j--; ) for (k = msum->ncomp; k--; ) rmx_lval(msum,i,j,k) += sf[k] * rmx_lval(madd,i,j,k); - - free(mysf); + if (mysf) + free(mysf); return(1); } @@ -568,13 +713,15 @@ rmx_scale(RMATRIX *rm, const double sf[]) { int i, j, k; - if ((rm == NULL) | (sf == NULL)) + if (!rm | !sf) return(0); for (i = rm->nrows; i--; ) for (j = rm->ncols; j--; ) for (k = rm->ncomp; k--; ) rmx_lval(rm,i,j,k) *= sf[k]; + if (rm->info) + rmx_addinfo(rm, "Applied scalar\n"); return(1); } @@ -585,11 +732,18 @@ rmx_transform(const RMATRIX *msrc, int n, const double int i, j, ks, kd; RMATRIX *dnew; - if ((msrc == NULL) | (n <= 0) | (cmat == NULL)) + if (!msrc | (n <= 0) | !cmat) return(NULL); dnew = rmx_alloc(msrc->nrows, msrc->ncols, n); - if (dnew == NULL) + if (!dnew) return(NULL); + if (msrc->info) { + char buf[128]; + sprintf(buf, "Applied %dx%d component transform\n", + dnew->ncomp, msrc->ncomp); + rmx_addinfo(dnew, msrc->info); + rmx_addinfo(dnew, buf); + } dnew->dtype = msrc->dtype; for (i = dnew->nrows; i--; ) for (j = dnew->ncols; j--; ) @@ -609,10 +763,10 @@ rmx_from_cmatrix(const CMATRIX *cm) int i, j; RMATRIX *dnew; - if (cm == NULL) + if (!cm) return(NULL); dnew = rmx_alloc(cm->nrows, cm->ncols, 3); - if (dnew == NULL) + if (!dnew) return(NULL); dnew->dtype = DTfloat; for (i = dnew->nrows; i--; ) @@ -632,17 +786,21 @@ cm_from_rmatrix(const RMATRIX *rm) int i, j; CMATRIX *cnew; - if (rm == NULL || rm->ncomp != 3) + if (!rm || !rm->mtx | ((rm->ncomp != 3) & (rm->ncomp != 1))) return(NULL); cnew = cm_alloc(rm->nrows, rm->ncols); - if (cnew == NULL) + if (!cnew) return(NULL); for (i = cnew->nrows; i--; ) for (j = cnew->ncols; j--; ) { COLORV *cv = cm_lval(cnew,i,j); - cv[0] = (COLORV)rmx_lval(rm,i,j,0); - cv[1] = (COLORV)rmx_lval(rm,i,j,1); - cv[2] = (COLORV)rmx_lval(rm,i,j,2); + if (rm->ncomp == 1) + cv[0] = cv[1] = cv[2] = (COLORV)rmx_lval(rm,i,j,0); + else { + cv[0] = (COLORV)rmx_lval(rm,i,j,0); + cv[1] = (COLORV)rmx_lval(rm,i,j,1); + cv[2] = (COLORV)rmx_lval(rm,i,j,2); + } } return(cnew); }
