root/radiance/ray/src/util/rmatrix.c
Revision: 2.72
Committed: Tue Dec 5 21:45:39 2023 UTC (18 months, 3 weeks ago) by greg
fix(rmtxop,rmtxcomb): Fixed bug in ASCII matrix output
2 static const char RCSid[] = "$Id: rmatrix.c,v 2.71 2023/12/05 21:13:38 greg Exp $";
5 * General matrix operations.
6 */
7
8 #include <stdlib.h>
9 #include <errno.h>
10 #include "rtio.h"
11 #include "platform.h"
12 #include "resolu.h"
13 #include "paths.h"
14 #include "rmatrix.h"
15 #if !defined(_WIN32) && !defined(_WIN64)
16 #include <sys/mman.h>
17 #endif
18
19 static const char rmx_mismatch_warn[] = "WARNING: data type mismatch\n";
20
21 #define array_size(rm) (sizeof(double)*(rm)->nrows*(rm)->ncols*(rm)->ncomp)
22 #define mapped_size(rm) ((char *)(rm)->mtx + array_size(rm) - (char *)(rm)->mapped)
23
24 /* Initialize a RMATRIX struct but don't allocate array space */
25 RMATRIX *
26 rmx_new(int nr, int nc, int n)
27 {
28 RMATRIX *dnew;
29
30 if (n <= 0)
31 return(NULL);
32
33 dnew = (RMATRIX *)calloc(1, sizeof(RMATRIX));
34 if (!dnew)
35 return(NULL);
36
37 dnew->dtype = DTdouble;
38 dnew->nrows = nr;
39 dnew->ncols = nc;
40 dnew->ncomp = n;
41 setcolor(dnew->cexp, 1.f, 1.f, 1.f);
42 memcpy(dnew->wlpart, WLPART, sizeof(dnew->wlpart));
43
44 return(dnew);
45 }
46
47 /* Prepare a RMATRIX for writing (allocate array if needed) */
48 int
49 rmx_prepare(RMATRIX *rm)
50 {
51 if (!rm) return(0);
52 if (rm->mtx)
53 return(1);
54 if ((rm->nrows <= 0) | (rm->ncols <= 0) | (rm->ncomp <= 0))
55 return(0);
56 rm->mtx = (double *)malloc(array_size(rm));
57 return(rm->mtx != NULL);
58 }
59
60 /* Call rmx_new() and rmx_prepare() */
61 RMATRIX *
62 rmx_alloc(int nr, int nc, int n)
63 {
64 RMATRIX *dnew = rmx_new(nr, nc, n);
65
66 if (dnew && !rmx_prepare(dnew)) {
67 rmx_free(dnew);
68 dnew = NULL;
69 }
70 return(dnew);
71 }
72
73 /* Clear state by freeing info and matrix data */
74 void
75 rmx_reset(RMATRIX *rm)
76 {
77 if (!rm) return;
78 if (rm->info) {
79 free(rm->info);
80 rm->info = NULL;
81 }
82 if (rm->mtx) {
83 #ifdef MAP_FILE
84 if (rm->mapped) {
85 munmap(rm->mapped, mapped_size(rm));
86 rm->mapped = NULL;
87 } else
88 #endif
89 free(rm->mtx);
90 rm->mtx = NULL;
91 }
92 }
93
94 /* Free an RMATRIX struct and data */
95 void
96 rmx_free(RMATRIX *rm)
97 {
98 if (!rm) return;
99 rmx_reset(rm);
100 free(rm);
101 }
102
103 /* Resolve data type based on two input types (returns 0 for mismatch) */
104 int
105 rmx_newtype(int dtyp1, int dtyp2)
106 {
107 if ((dtyp1==DTxyze) | (dtyp1==DTrgbe) | (dtyp1==DTspec) |
108 (dtyp2==DTxyze) | (dtyp2==DTrgbe) | (dtyp2==DTspec)
109 && dtyp1 != dtyp2)
110 return(0);
111 if (dtyp1 < dtyp2)
112 return(dtyp1);
113 return(dtyp2);
114 }
115
116 /* Append header information associated with matrix data */
117 int
118 rmx_addinfo(RMATRIX *rm, const char *info)
119 {
120 int oldlen = 0;
121
122 if (!rm || !info || !*info)
123 return(0);
124 if (!rm->info) {
125 rm->info = (char *)malloc(strlen(info)+1);
126 if (rm->info) rm->info[0] = '\0';
127 } else {
128 oldlen = strlen(rm->info);
129 rm->info = (char *)realloc(rm->info,
130 oldlen+strlen(info)+1);
131 }
132 if (!rm->info)
133 return(0);
134 strcpy(rm->info+oldlen, info);
135 return(1);
136 }
137
138 static int
139 get_dminfo(char *s, void *p)
140 {
141 RMATRIX *ip = (RMATRIX *)p;
142 char fmt[MAXFMTLEN];
143 int i;
144
145 if (headidval(NULL, s))
146 return(0);
147 if (isncomp(s)) {
148 ip->ncomp = ncompval(s);
149 return(0);
150 }
151 if (!strncmp(s, "NROWS=", 6)) {
152 ip->nrows = atoi(s+6);
153 return(0);
154 }
155 if (!strncmp(s, "NCOLS=", 6)) {
156 ip->ncols = atoi(s+6);
157 return(0);
158 }
159 if ((i = isbigendian(s)) >= 0) {
160 ip->swapin = (nativebigendian() != i);
161 return(0);
162 }
163 if (isexpos(s)) {
164 float f = exposval(s);
165 scalecolor(ip->cexp, f);
166 return(0);
167 }
168 if (iscolcor(s)) {
169 COLOR ctmp;
170 colcorval(ctmp, s);
171 multcolor(ip->cexp, ctmp);
172 return(0);
173 }
174 if (iswlsplit(s)) {
175 wlsplitval(ip->wlpart, s);
176 return(0);
177 }
178 if (!formatval(fmt, s)) {
179 rmx_addinfo(ip, s);
180 return(0);
181 } /* else check format */
182 for (i = 1; i < DTend; i++)
183 if (!strcmp(fmt, cm_fmt_id[i])) {
184 ip->dtype = i;
185 return(0);
186 }
187 return(-1);
188 }
189
190 static int
191 rmx_load_ascii(double *drp, const RMATRIX *rm, FILE *fp)
192 {
193 int j, k;
194
195 for (j = 0; j < rm->ncols; j++)
196 for (k = rm->ncomp; k-- > 0; )
197 if (fscanf(fp, "%lf", drp++) != 1)
198 return(0);
199 return(1);
200 }
201
202 static int
203 rmx_load_float(double *drp, const RMATRIX *rm, FILE *fp)
204 {
205 int j, k;
206 float val[100];
207
208 if (rm->ncomp > 100) {
209 fputs("Unsupported # components in rmx_load_float()\n", stderr);
210 exit(1);
211 }
212 for (j = 0; j < rm->ncols; j++) {
213 if (getbinary(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp)
214 return(0);
215 if (rm->swapin)
216 swap32((char *)val, rm->ncomp);
217 for (k = 0; k < rm->ncomp; k++)
218 *drp++ = val[k];
219 }
220 return(1);
221 }
222
223 static int
224 rmx_load_double(double *drp, const RMATRIX *rm, FILE *fp)
225 {
226 if (getbinary(drp, sizeof(*drp)*rm->ncomp, rm->ncols, fp) != rm->ncols)
227 return(0);
228 if (rm->swapin)
229 swap64((char *)drp, rm->ncols*rm->ncomp);
230 return(1);
231 }
232
233 static int
234 rmx_load_rgbe(double *drp, const RMATRIX *rm, FILE *fp)
235 {
236 COLR *scan;
237 COLOR col;
238 int j;
239
240 if (rm->ncomp != 3)
241 return(0);
242 scan = (COLR *)tempbuffer(sizeof(COLR)*rm->ncols);
243 if (!scan)
244 return(0);
245 if (freadcolrs(scan, rm->ncols, fp) < 0)
246 return(0);
247 for (j = 0; j < rm->ncols; j++) {
248 colr_color(col, scan[j]);
249 *drp++ = colval(col,RED);
250 *drp++ = colval(col,GRN);
251 *drp++ = colval(col,BLU);
252 }
253 return(1);
254 }
255
256 static int
257 rmx_load_spec(double *drp, const RMATRIX *rm, FILE *fp)
258 {
259 uby8 *scan;
260 SCOLOR scol;
261 int j, k;
262
263 if ((rm->ncomp < 3) | (rm->ncomp > MAXCSAMP))
264 return(0);
265 scan = (uby8 *)tempbuffer((rm->ncomp+1)*rm->ncols);
266 if (!scan)
267 return(0);
268 if (freadscolrs(scan, rm->ncomp, rm->ncols, fp) < 0)
269 return(0);
270 for (j = 0; j < rm->ncols; j++) {
271 scolr2scolor(scol, scan+j*(rm->ncomp+1), rm->ncomp);
272 for (k = 0; k < rm->ncomp; k++)
273 *drp++ = scol[k];
274 }
275 return(1);
276 }
277
278 /* Read matrix header from input stream (cannot be XML) */
279 int
280 rmx_load_header(RMATRIX *rm, FILE *fp)
281 {
282 if (!rm | !fp)
283 return(0);
284 rmx_reset(rm); /* clear state */
285 if (rm->nrows | rm->ncols | !rm->dtype) {
286 rm->nrows = rm->ncols = 0;
287 rm->ncomp = 3;
288 setcolor(rm->cexp, 1.f, 1.f, 1.f);
289 memcpy(rm->wlpart, WLPART, sizeof(rm->wlpart));
290 rm->swapin = 0;
291 }
292 rm->dtype = DTascii; /* assumed w/o FORMAT */
293 if (getheader(fp, get_dminfo, rm) < 0) {
294 fputs("Unrecognized matrix format\n", stderr);
295 return(0);
296 }
297 if ((rm->dtype == DTrgbe) | (rm->dtype == DTxyze) &&
298 rm->ncomp != 3)
299 return(0);
300 if (rm->ncols <= 0 && /* resolution string? */
301 !fscnresolu(&rm->ncols, &rm->nrows, fp))
302 return(0);
303 if (rm->dtype == DTascii) /* set file type (WINDOWS) */
304 SET_FILE_TEXT(fp);
305 else
306 SET_FILE_BINARY(fp);
307 return(1);
308 }
309
310 /* Load next row as double (cannot be XML) */
311 int
312 rmx_load_row(double *drp, const RMATRIX *rm, FILE *fp)
313 {
314 switch (rm->dtype) {
315 case DTascii:
316 return(rmx_load_ascii(drp, rm, fp));
317 case DTfloat:
318 return(rmx_load_float(drp, rm, fp));
319 case DTdouble:
320 return(rmx_load_double(drp, rm, fp));
321 case DTrgbe:
322 case DTxyze:
323 return(rmx_load_rgbe(drp, rm, fp));
324 case DTspec:
325 return(rmx_load_spec(drp, rm, fp));
326 default:
327 fputs("Unsupported data type in rmx_load_row()\n", stderr);
328 }
329 return(0);
330 }
331
332 /* Allocate & load post-header data from stream given type set in rm->dtype */
333 int
334 rmx_load_data(RMATRIX *rm, FILE *fp)
335 {
336 int i;
337 #ifdef MAP_FILE
338 long pos; /* map memory for file > 1MB if possible */
339 if ((rm->dtype == DTdouble) & !rm->swapin && array_size(rm) >= 1L<<20 &&
340 (pos = ftell(fp)) >= 0 && !(pos % sizeof(double))) {
341 rm->mapped = mmap(NULL, array_size(rm)+pos, PROT_READ|PROT_WRITE,
342 MAP_PRIVATE, fileno(fp), 0);
343 if (rm->mapped != MAP_FAILED) {
344 rm->mtx = (double *)rm->mapped + pos/sizeof(double);
345 return(1);
346 } /* else fall back on reading into memory */
347 rm->mapped = NULL;
348 }
349 #endif
350 if (!rmx_prepare(rm)) { /* need in-core matrix array */
351 fprintf(stderr, "Cannot allocate %g MByte matrix array\n",
352 (1./(1L<<20))*(double)array_size(rm));
353 return(0);
354 }
355 for (i = 0; i < rm->nrows; i++)
356 if (!rmx_load_row(rmx_lval(rm,i,0), rm, fp))
357 return(0);
358 return(1);
359 }
360
361 /* Load matrix from supported file type */
362 RMATRIX *
363 rmx_load(const char *inspec, RMPref rmp)
364 {
365 FILE *fp;
366 RMATRIX *dnew;
367 int ok;
368
369 if (!inspec)
370 inspec = stdin_name;
371 else if (!*inspec)
372 return(NULL);
373 if (inspec == stdin_name) /* reading from stdin? */
374 fp = stdin;
375 else if (inspec[0] == '!')
376 fp = popen(inspec+1, "r");
377 else {
378 const char *sp = inspec; /* check suffix */
379 while (*sp)
380 ++sp;
381 while (sp > inspec && sp[-1] != '.')
382 --sp;
383 if (!strcasecmp(sp, "XML")) { /* assume it's a BSDF */
384 CMATRIX *cm = rmp==RMPnone ? (CMATRIX *)NULL :
385 rmp==RMPtrans ? cm_loadBTDF(inspec) :
386 cm_loadBRDF(inspec, rmp==RMPreflB) ;
387 if (!cm)
388 return(NULL);
389 dnew = rmx_from_cmatrix(cm);
390 cm_free(cm);
391 dnew->dtype = DTascii;
392 return(dnew); /* return here */
393 } /* else open it ourselves */
394 fp = fopen(inspec, "r");
395 }
396 if (!fp)
397 return(NULL);
398 #ifdef getc_unlocked
399 flockfile(fp);
400 #endif
401 SET_FILE_BINARY(fp); /* load header info */
402 if (!rmx_load_header(dnew = rmx_new(0,0,3), fp)) {
403 fprintf(stderr, "Bad header in: %s\n", inspec);
404 if (inspec[0] == '!') pclose(fp);
405 else fclose(fp);
406 rmx_free(dnew);
407 return(NULL);
408 }
409 ok = rmx_load_data(dnew, fp); /* allocate & load data */
410
411 if (fp != stdin) { /* close input stream */
412 if (inspec[0] == '!')
413 pclose(fp);
414 else
415 fclose(fp);
416 }
417 #ifdef getc_unlocked
418 else
419 funlockfile(fp);
420 #endif
421 if (!ok) { /* load failure? */
422 fprintf(stderr, "Error loading data from: %s\n", inspec);
423 rmx_free(dnew);
424 return(NULL);
425 }
426 /* undo exposure? */
427 if ((dnew->cexp[0] != 1.f) |
428 (dnew->cexp[1] != 1.f) | (dnew->cexp[2] != 1.f)) {
429 double cmlt[MAXCSAMP];
430 int i;
431 cmlt[0] = 1./dnew->cexp[0];
432 cmlt[1] = 1./dnew->cexp[1];
433 cmlt[2] = 1./dnew->cexp[2];
434 if (dnew->ncomp > MAXCSAMP) {
435 fprintf(stderr, "Excess spectral components in: %s\n",
436 inspec);
437 rmx_free(dnew);
438 return(NULL);
439 }
440 for (i = dnew->ncomp; i-- > 3; )
441 cmlt[i] = cmlt[1];
442 rmx_scale(dnew, cmlt);
443 setcolor(dnew->cexp, 1.f, 1.f, 1.f);
444 }
445 return(dnew);
446 }
447
448 static int
449 rmx_write_ascii(const double *dp, int nc, int len, FILE *fp)
450 {
451 while (len-- > 0) {
452 int k = nc;
453 while (k-- > 0)
454 fprintf(fp, " %.7e", *dp++);
455 fputc('\t', fp);
456 }
457 return(fputc('\n', fp) != EOF);
458 }
459
460 static int
461 rmx_write_float(const double *dp, int len, FILE *fp)
462 {
463 float val;
464
465 while (len--) {
466 val = *dp++;
467 if (putbinary(&val, sizeof(float), 1, fp) != 1)
468 return(0);
469 }
470 return(1);
471 }
472
473 static int
474 rmx_write_rgbe(const double *dp, int nc, int len, FILE *fp)
475 {
476 COLR *scan;
477 int j;
478
479 if ((nc != 1) & (nc != 3)) return(0);
480 scan = (COLR *)tempbuffer(sizeof(COLR)*len);
481 if (!scan) return(0);
482
483 for (j = 0; j < len; j++, dp += nc)
484 if (nc == 1)
485 setcolr(scan[j], dp[0], dp[0], dp[0]);
486 else
487 setcolr(scan[j], dp[0], dp[1], dp[2]);
488
489 return(fwritecolrs(scan, len, fp) >= 0);
490 }
491
492 static int
493 rmx_write_spec(const double *dp, int nc, int len, FILE *fp)
494 {
495 uby8 *scan;
496 SCOLOR scol;
497 int j, k;
498
499 if (nc < 3) return(0);
500 scan = (uby8 *)tempbuffer((nc+1)*len);
501 if (!scan) return(0);
502 for (j = len; j--; dp += nc) {
503 for (k = nc; k--; )
504 scol[k] = dp[k];
505 scolor2scolr(scan+j*(nc+1), scol, nc);
506 }
507 return(fwritescolrs(scan, nc, len, fp) >= 0);
508 }
509
510 /* Check if CIE XYZ primaries were specified */
511 static int
512 findCIEprims(const char *info)
513 {
514 RGBPRIMS prims;
515
516 if (!info)
517 return(0);
518 info = strstr(info, PRIMARYSTR);
519 if (!info || !primsval(prims, info))
520 return(0);
521
522 return((prims[RED][CIEX] > .99) & (prims[RED][CIEY] < .01) &&
523 (prims[GRN][CIEX] < .01) & (prims[GRN][CIEY] > .99) &&
524 (prims[BLU][CIEX] < .01) & (prims[BLU][CIEY] < .01));
525 }
526
527 /* Finish writing header data with resolution and format, returning type used */
528 int
529 rmx_write_header(const RMATRIX *rm, int dtype, FILE *fp)
530 {
531 if (!rm | !fp || rm->ncols <= 0)
532 return(0);
533 if (rm->info)
534 fputs(rm->info, fp);
535 if (dtype == DTfromHeader)
536 dtype = rm->dtype;
537 else if (dtype == DTrgbe && (rm->dtype == DTxyze ||
538 findCIEprims(rm->info)))
539 dtype = DTxyze;
540 else if ((dtype == DTxyze) & (rm->dtype == DTrgbe))
541 dtype = DTrgbe;
542 if ((dtype == DTspec) & (rm->ncomp < 3))
543 return(0);
544
545 if (dtype == DTascii) /* set file type (WINDOWS) */
546 SET_FILE_TEXT(fp);
547 else
548 SET_FILE_BINARY(fp);
549 /* write exposure? */
550 if (rm->ncomp == 3 && (rm->cexp[RED] != rm->cexp[GRN]) |
551 (rm->cexp[GRN] != rm->cexp[BLU]))
552 fputcolcor(rm->cexp, fp);
553 else if (rm->cexp[GRN] != 1.f)
554 fputexpos(rm->cexp[GRN], fp);
555 /* matrix size? */
556 if ((dtype > DTspec) | (rm->nrows <= 0)) {
557 if (rm->nrows > 0)
558 fprintf(fp, "NROWS=%d\n", rm->nrows);
559 fprintf(fp, "NCOLS=%d\n", rm->ncols);
560 }
561 if (dtype >= DTspec) { /* # components & split? */
562 fputncomp(rm->ncomp, fp);
563 if (dtype == DTspec || (rm->ncomp > 3 &&
564 memcmp(rm->wlpart, WLPART, sizeof(WLPART))))
565 fputwlsplit(rm->wlpart, fp);
566 } else if ((rm->ncomp != 3) & (rm->ncomp != 1))
567 return(0); /* wrong # components */
568 if ((dtype == DTfloat) | (dtype == DTdouble))
569 fputendian(fp); /* important to record */
570 fputformat(cm_fmt_id[dtype], fp);
571 fputc('\n', fp); /* end of header */
572 if ((dtype <= DTspec) & (rm->nrows > 0))
573 fprtresolu(rm->ncols, rm->nrows, fp);
574 return(dtype);
575 }
576
577 /* Write out matrix data (usually by row) */
578 int
579 rmx_write_data(const double *dp, int nc, int len, int dtype, FILE *fp)
580 {
581 switch (dtype) {
582 case DTascii:
583 return(rmx_write_ascii(dp, nc, len, fp));
584 case DTfloat:
585 return(rmx_write_float(dp, nc*len, fp));
586 case DTdouble:
587 return(putbinary(dp, sizeof(*dp)*nc, len, fp) == len);
588 case DTrgbe:
589 case DTxyze:
590 return(rmx_write_rgbe(dp, nc, len, fp));
591 case DTspec:
592 return(rmx_write_spec(dp, nc, len, fp));
593 }
594 return(0);
595 }
596
597 /* Write matrix using file format indicated by dtype */
598 int
599 rmx_write(const RMATRIX *rm, int dtype, FILE *fp)
600 {
601 int ok = 0;
602 int i;
603 /* complete header */
604 dtype = rmx_write_header(rm, dtype, fp);
605 if (dtype <= 0)
606 return(0);
607 #ifdef getc_unlocked
608 flockfile(fp);
609 #endif
610 if (dtype == DTdouble) /* write all at once? */
611 ok = rmx_write_data(rm->mtx, rm->ncomp,
612 rm->nrows*rm->ncols, dtype, fp);
613 else /* else row by row */
614 for (i = 0; i < rm->nrows; i++) {
615 ok = rmx_write_data(rmx_val(rm,i,0), rm->ncomp,
616 rm->ncols, dtype, fp);
617 if (!ok) break;
618 }
619
620 if (ok) ok = (fflush(fp) == 0);
621 #ifdef getc_unlocked
622 funlockfile(fp);
623 #endif
624 if (!ok) fputs("Error writing matrix\n", stderr);
625 return(ok);
626 }
627
628 /* Allocate and assign square identity matrix with n components */
629 RMATRIX *
630 rmx_identity(const int dim, const int n)
631 {
632 RMATRIX *rid = rmx_alloc(dim, dim, n);
633 int i, k;
634
635 if (!rid)
636 return(NULL);
637 memset(rid->mtx, 0, array_size(rid));
638 for (i = dim; i--; ) {
639 double *dp = rmx_lval(rid,i,i);
640 for (k = n; k--; )
641 dp[k] = 1.;
642 }
643 return(rid);
644 }
645
646 /* Duplicate the given matrix (may be unallocated) */
647 RMATRIX *
648 rmx_copy(const RMATRIX *rm)
649 {
650 RMATRIX *dnew;
651
652 if (!rm)
653 return(NULL);
654 dnew = rmx_new(rm->nrows, rm->ncols, rm->ncomp);
655 if (!dnew)
656 return(NULL);
657 if (rm->mtx) {
658 if (!rmx_prepare(dnew)) {
659 rmx_free(dnew);
660 return(NULL);
661 }
662 memcpy(dnew->mtx, rm->mtx, array_size(dnew));
663 }
664 rmx_addinfo(dnew, rm->info);
665 dnew->dtype = rm->dtype;
666 copycolor(dnew->cexp, rm->cexp);
667 memcpy(dnew->wlpart, rm->wlpart, sizeof(dnew->wlpart));
668 return(dnew);
669 }
670
671 /* Allocate and assign transposed matrix */
672 RMATRIX *
673 rmx_transpose(const RMATRIX *rm)
674 {
675 RMATRIX *dnew;
676 int i, j;
677
678 if (!rm || !rm->mtx)
679 return(0);
680 if ((rm->nrows == 1) | (rm->ncols == 1)) {
681 dnew = rmx_copy(rm);
682 if (!dnew)
683 return(NULL);
684 dnew->nrows = rm->ncols;
685 dnew->ncols = rm->nrows;
686 return(dnew);
687 }
688 dnew = rmx_alloc(rm->ncols, rm->nrows, rm->ncomp);
689 if (!dnew)
690 return(NULL);
691 if (rm->info) {
692 rmx_addinfo(dnew, rm->info);
693 rmx_addinfo(dnew, "Transposed rows and columns\n");
694 }
695 dnew->dtype = rm->dtype;
696 copycolor(dnew->cexp, rm->cexp);
697 memcpy(dnew->wlpart, rm->wlpart, sizeof(dnew->wlpart));
698 for (j = dnew->ncols; j--; )
699 for (i = dnew->nrows; i--; )
700 memcpy(rmx_lval(dnew,i,j), rmx_val(rm,j,i),
701 sizeof(double)*dnew->ncomp);
702 return(dnew);
703 }
704
705 /* Multiply (concatenate) two matrices and allocate the result */
706 RMATRIX *
707 rmx_multiply(const RMATRIX *m1, const RMATRIX *m2)
708 {
709 RMATRIX *mres;
710 int i, j, k, h;
711
712 if (!m1 | !m2 || !m1->mtx | !m2->mtx |
713 (m1->ncomp != m2->ncomp) | (m1->ncols != m2->nrows))
714 return(NULL);
715 mres = rmx_alloc(m1->nrows, m2->ncols, m1->ncomp);
716 if (!mres)
717 return(NULL);
718 i = rmx_newtype(m1->dtype, m2->dtype);
719 if (i)
720 mres->dtype = i;
721 else
722 rmx_addinfo(mres, rmx_mismatch_warn);
723 for (i = mres->nrows; i--; )
724 for (j = mres->ncols; j--; )
725 for (k = mres->ncomp; k--; ) {
726 double d = 0;
727 for (h = m1->ncols; h--; )
728 d += rmx_val(m1,i,h)[k] * rmx_val(m2,h,j)[k];
729 rmx_lval(mres,i,j)[k] = d;
730 }
731 return(mres);
732 }
733
734 /* Element-wise multiplication (or division) of m2 into m1 */
735 int
736 rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide)
737 {
738 int zeroDivides = 0;
739 int i, j, k;
740
741 if (!m1 | !m2 || !m1->mtx | !m2->mtx |
742 (m1->ncols != m2->ncols) | (m1->nrows != m2->nrows))
743 return(0);
744 if ((m2->ncomp > 1) & (m2->ncomp != m1->ncomp))
745 return(0);
746 i = rmx_newtype(m1->dtype, m2->dtype);
747 if (i)
748 m1->dtype = i;
749 else
750 rmx_addinfo(m1, rmx_mismatch_warn);
751 for (i = m1->nrows; i--; )
752 for (j = m1->ncols; j--; )
753 if (divide) {
754 double d;
755 if (m2->ncomp == 1) {
756 d = rmx_val(m2,i,j)[0];
757 if (d == 0) {
758 ++zeroDivides;
759 for (k = m1->ncomp; k--; )
760 rmx_lval(m1,i,j)[k] = 0;
761 } else {
762 d = 1./d;
763 for (k = m1->ncomp; k--; )
764 rmx_lval(m1,i,j)[k] *= d;
765 }
766 } else
767 for (k = m1->ncomp; k--; ) {
768 d = rmx_val(m2,i,j)[k];
769 if (d == 0) {
770 ++zeroDivides;
771 rmx_lval(m1,i,j)[k] = 0;
772 } else
773 rmx_lval(m1,i,j)[k] /= d;
774 }
775 } else {
776 if (m2->ncomp == 1) {
777 const double d = rmx_val(m2,i,j)[0];
778 for (k = m1->ncomp; k--; )
779 rmx_lval(m1,i,j)[k] *= d;
780 } else
781 for (k = m1->ncomp; k--; )
782 rmx_lval(m1,i,j)[k] *= rmx_val(m2,i,j)[k];
783 }
784 if (zeroDivides) {
785 rmx_addinfo(m1, "WARNING: zero divide(s) corrupted results\n");
786 errno = ERANGE;
787 }
788 return(1);
789 }
790
791 /* Sum second matrix into first, applying scale factor beforehand */
792 int
793 rmx_sum(RMATRIX *msum, const RMATRIX *madd, const double sf[])
794 {
795 double *mysf = NULL;
796 int i, j, k;
797
798 if (!msum | !madd || !msum->mtx | !madd->mtx |
799 (msum->nrows != madd->nrows) |
800 (msum->ncols != madd->ncols) |
801 (msum->ncomp != madd->ncomp))
802 return(0);
803 if (!sf) {
804 mysf = (double *)malloc(sizeof(double)*msum->ncomp);
805 if (!mysf)
806 return(0);
807 for (k = msum->ncomp; k--; )
808 mysf[k] = 1;
809 sf = mysf;
810 }
811 i = rmx_newtype(msum->dtype, madd->dtype);
812 if (i)
813 msum->dtype = i;
814 else
815 rmx_addinfo(msum, rmx_mismatch_warn);
816 for (i = msum->nrows; i--; )
817 for (j = msum->ncols; j--; ) {
818 const double *da = rmx_val(madd,i,j);
819 double *ds = rmx_lval(msum,i,j);
820 for (k = msum->ncomp; k--; )
821 ds[k] += sf[k] * da[k];
822 }
823 if (mysf)
824 free(mysf);
825 return(1);
826 }
827
828 /* Scale the given matrix by the indicated scalar component vector */
829 int
830 rmx_scale(RMATRIX *rm, const double sf[])
831 {
832 int i, j, k;
833
834 if (!rm | !sf || !rm->mtx)
835 return(0);
836 for (i = rm->nrows; i--; )
837 for (j = rm->ncols; j--; ) {
838 double *dp = rmx_lval(rm,i,j);
839 for (k = rm->ncomp; k--; )
840 dp[k] *= sf[k];
841 }
842 if (rm->info)
843 rmx_addinfo(rm, "Applied scalar\n");
844 /* XXX: should record as exposure for COLR and SCOLR types? */
845 return(1);
846 }
847
848 /* Allocate new matrix and apply component transformation */
849 RMATRIX *
850 rmx_transform(const RMATRIX *msrc, int n, const double cmat[])
851 {
852 int i, j, ks, kd;
853 RMATRIX *dnew;
854
855 if (!msrc | (n <= 0) | !cmat || !msrc->mtx)
856 return(NULL);
857 dnew = rmx_alloc(msrc->nrows, msrc->ncols, n);
858 if (!dnew)
859 return(NULL);
860 if (msrc->info) {
861 char buf[128];
862 sprintf(buf, "Applied %dx%d component transform\n",
863 dnew->ncomp, msrc->ncomp);
864 rmx_addinfo(dnew, msrc->info);
865 rmx_addinfo(dnew, buf);
866 }
867 dnew->dtype = msrc->dtype;
868 for (i = dnew->nrows; i--; )
869 for (j = dnew->ncols; j--; ) {
870 const double *ds = rmx_val(msrc,i,j);
871 for (kd = dnew->ncomp; kd--; ) {
872 double d = 0;
873 for (ks = msrc->ncomp; ks--; )
874 d += cmat[kd*msrc->ncomp + ks] * ds[ks];
875 rmx_lval(dnew,i,j)[kd] = d;
876 }
877 }
878 return(dnew);
879 }
880
881 /* Convert a color matrix to newly allocated RMATRIX buffer */
882 RMATRIX *
883 rmx_from_cmatrix(const CMATRIX *cm)
884 {
885 int i, j;
886 RMATRIX *dnew;
887
888 if (!cm)
889 return(NULL);
890 dnew = rmx_alloc(cm->nrows, cm->ncols, 3);
891 if (!dnew)
892 return(NULL);
893 dnew->dtype = DTfloat;
894 for (i = dnew->nrows; i--; )
895 for (j = dnew->ncols; j--; ) {
896 const COLORV *cv = cm_lval(cm,i,j);
897 double *dp = rmx_lval(dnew,i,j);
898 dp[0] = cv[0];
899 dp[1] = cv[1];
900 dp[2] = cv[2];
901 }
902 return(dnew);
903 }
904
905 /* Convert general matrix to newly allocated CMATRIX buffer */
906 CMATRIX *
907 cm_from_rmatrix(const RMATRIX *rm)
908 {
909 int i, j;
910 CMATRIX *cnew;
911
912 if (!rm || !rm->mtx | (rm->ncomp == 2))
913 return(NULL);
914 cnew = cm_alloc(rm->nrows, rm->ncols);
915 if (!cnew)
916 return(NULL);
917 for (i = cnew->nrows; i--; )
918 for (j = cnew->ncols; j--; ) {
919 const double *dp = rmx_val(rm,i,j);
920 COLORV *cv = cm_lval(cnew,i,j);
921 switch (rm->ncomp) {
922 case 3:
923 setcolor(cv, dp[0], dp[1], dp[2]);
924 break;
925 case 1:
926 setcolor(cv, dp[0], dp[0], dp[0]);
927 break;
928 default: {
929 SCOLOR scol;
930 int k;
931 for (k = rm->ncomp; k--; )
932 scol[k] = dp[k];
933 scolor2color(cv, scol, rm->ncomp, rm->wlpart);
934 } break;
935 }
936 }
937 return(cnew);
938 }
