root/radiance/ray/src/util/rmatrix.c
Revision: 2.41
Committed: Thu Mar 26 18:01:26 2020 UTC (4 years, 2 months ago) by greg
Changes since 2.40: +13 -8 lines
Minor efficiency improvements
2 static const char RCSid[] = "$Id: rmatrix.c,v 2.40 2020/03/25 01:51:09 greg Exp $";
5 * General matrix operations.
6 */
7
8 #include <stdlib.h>
9 #include <errno.h>
10 #include "rtio.h"
11 #include "platform.h"
12 #include "resolu.h"
13 #include "paths.h"
14 #include "rmatrix.h"
15
16 static char rmx_mismatch_warn[] = "WARNING: data type mismatch\n";
17
18 /* Allocate a nr x nc matrix with n components */
19 RMATRIX *
20 rmx_alloc(int nr, int nc, int n)
21 {
22 RMATRIX *dnew;
23
24 if ((nr <= 0) | (nc <= 0) | (n <= 0))
25 return(NULL);
26 dnew = (RMATRIX *)malloc(sizeof(RMATRIX)-sizeof(dnew->mtx) +
27 sizeof(dnew->mtx[0])*(n*nr*nc));
28 if (!dnew)
29 return(NULL);
30 dnew->nrows = nr; dnew->ncols = nc; dnew->ncomp = n;
31 dnew->dtype = DTdouble;
32 dnew->swapin = 0;
33 dnew->info = NULL;
34 return(dnew);
35 }
36
37 /* Free a RMATRIX array */
38 void
39 rmx_free(RMATRIX *rm)
40 {
41 if (!rm) return;
42 if (rm->info)
43 free(rm->info);
44 free(rm);
45 }
46
47 /* Resolve data type based on two input types (returns 0 for mismatch) */
48 int
49 rmx_newtype(int dtyp1, int dtyp2)
50 {
51 if ((dtyp1==DTxyze) | (dtyp1==DTrgbe) |
52 (dtyp2==DTxyze) | (dtyp2==DTrgbe)
53 && dtyp1 != dtyp2)
54 return(0);
55 if (dtyp1 < dtyp2)
56 return(dtyp1);
57 return(dtyp2);
58 }
59
60 /* Append header information associated with matrix data */
61 int
62 rmx_addinfo(RMATRIX *rm, const char *info)
63 {
64 if (!rm || !info || !*info)
65 return(0);
66 if (!rm->info) {
67 rm->info = (char *)malloc(strlen(info)+1);
68 if (rm->info) rm->info[0] = '\0';
69 } else
70 rm->info = (char *)realloc(rm->info,
71 strlen(rm->info)+strlen(info)+1);
72 if (!rm->info)
73 return(0);
74 strcat(rm->info, info);
75 return(1);
76 }
77
78 static int
79 get_dminfo(char *s, void *p)
80 {
81 RMATRIX *ip = (RMATRIX *)p;
82 char fmt[MAXFMTLEN];
83 int i;
84
85 if (headidval(fmt, s))
86 return(0);
87 if (!strncmp(s, "NCOMP=", 6)) {
88 ip->ncomp = atoi(s+6);
89 return(0);
90 }
91 if (!strncmp(s, "NROWS=", 6)) {
92 ip->nrows = atoi(s+6);
93 return(0);
94 }
95 if (!strncmp(s, "NCOLS=", 6)) {
96 ip->ncols = atoi(s+6);
97 return(0);
98 }
99 if ((i = isbigendian(s)) >= 0) {
100 ip->swapin = (nativebigendian() != i);
101 return(0);
102 }
103 if (isexpos(s)) {
104 double d = exposval(s);
105 scalecolor(ip->mtx, d);
106 return(0);
107 }
108 if (iscolcor(s)) {
109 COLOR ctmp;
110 colcorval(ctmp, s);
111 multcolor(ip->mtx, ctmp);
112 return(0);
113 }
114 if (!formatval(fmt, s)) {
115 rmx_addinfo(ip, s);
116 return(0);
117 }
118 for (i = 1; i < DTend; i++)
119 if (!strcmp(fmt, cm_fmt_id[i])) {
120 ip->dtype = i;
121 return(0);
122 }
123 return(-1);
124 }
125
126 static int
127 rmx_load_ascii(RMATRIX *rm, FILE *fp)
128 {
129 int i, j, k;
130
131 for (i = 0; i < rm->nrows; i++)
132 for (j = 0; j < rm->ncols; j++)
133 for (k = 0; k < rm->ncomp; k++)
134 if (fscanf(fp, "%lf", &rmx_lval(rm,i,j,k)) != 1)
135 return(0);
136 return(1);
137 }
138
139 static int
140 rmx_load_float(RMATRIX *rm, FILE *fp)
141 {
142 int i, j, k;
143 float val[100];
144
145 if (rm->ncomp > 100) {
146 fputs("Unsupported # components in rmx_load_float()\n", stderr);
147 exit(1);
148 }
149 for (i = 0; i < rm->nrows; i++)
150 for (j = 0; j < rm->ncols; j++) {
151 if (getbinary(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp)
152 return(0);
153 if (rm->swapin)
154 swap32((char *)val, rm->ncomp);
155 for (k = rm->ncomp; k--; )
156 rmx_lval(rm,i,j,k) = val[k];
157 }
158 return(1);
159 }
160
161 static int
162 rmx_load_double(RMATRIX *rm, FILE *fp)
163 {
164 int i;
165
166 if (&rmx_lval(rm,0,0,0) - &rmx_lval(rm,1,0,0) !=
167 sizeof(double)*rm->ncols*rm->ncomp) {
168 fputs("Code error in rmx_load_double()\n", stderr);
169 exit(1);
170 }
171 for (i = 0; i < rm->nrows; i++) {
172 if (getbinary(&rmx_lval(rm,i,0,0), sizeof(double)*rm->ncomp,
173 rm->ncols, fp) != rm->ncols)
174 return(0);
175 if (rm->swapin)
176 swap64((char *)&rmx_lval(rm,i,0,0), rm->ncols*rm->ncomp);
177 }
178 return(1);
179 }
180
181 static int
182 rmx_load_rgbe(RMATRIX *rm, FILE *fp)
183 {
184 COLOR *scan = (COLOR *)malloc(sizeof(COLOR)*rm->ncols);
185 int i, j;
186
187 if (!scan)
188 return(0);
189 for (i = 0; i < rm->nrows; i++) {
190 if (freadscan(scan, rm->ncols, fp) < 0) {
191 free(scan);
192 return(0);
193 }
194 for (j = rm->ncols; j--; ) {
195 rmx_lval(rm,i,j,0) = colval(scan[j],RED);
196 rmx_lval(rm,i,j,1) = colval(scan[j],GRN);
197 rmx_lval(rm,i,j,2) = colval(scan[j],BLU);
198 }
199 }
200 free(scan);
201 return(1);
202 }
203
204 /* Load matrix from supported file type */
205 RMATRIX *
206 rmx_load(const char *inspec)
207 {
208 FILE *fp = stdin;
209 RMATRIX dinfo;
210 RMATRIX *dnew;
211
212 if (!inspec) { /* reading from stdin? */
213 inspec = "<stdin>";
214 SET_FILE_BINARY(stdin);
215 } else if (inspec[0] == '!') {
216 if (!(fp = popen(inspec+1, "r")))
217 return(NULL);
218 SET_FILE_BINARY(fp);
219 } else {
220 const char *sp = inspec; /* check suffix */
221 while (*sp)
222 ++sp;
223 while (sp > inspec && sp[-1] != '.')
224 --sp;
225 if (!strcasecmp(sp, "XML")) { /* assume it's a BSDF */
226 CMATRIX *cm = cm_loadBTDF((char *)inspec);
227 if (!cm)
228 return(NULL);
229 dnew = rmx_from_cmatrix(cm);
230 cm_free(cm);
231 dnew->dtype = DTascii;
232 return(dnew);
233 }
234 /* else open it ourselves */
235 if (!(fp = fopen(inspec, "rb")))
236 return(NULL);
237 }
238 #ifdef getc_unlocked
239 flockfile(fp);
240 #endif
241 dinfo.nrows = dinfo.ncols = dinfo.ncomp = 0;
242 dinfo.dtype = DTascii; /* assumed w/o FORMAT */
243 dinfo.swapin = 0;
244 dinfo.info = NULL;
245 dinfo.mtx[0] = dinfo.mtx[1] = dinfo.mtx[2] = 1.;
246 if (getheader(fp, get_dminfo, &dinfo) < 0) {
247 fclose(fp);
248 return(NULL);
249 }
250 if ((dinfo.nrows <= 0) | (dinfo.ncols <= 0)) {
251 if (!fscnresolu(&dinfo.ncols, &dinfo.nrows, fp)) {
252 fclose(fp);
253 return(NULL);
254 }
255 if (dinfo.ncomp <= 0)
256 dinfo.ncomp = 3;
257 else if ((dinfo.dtype == DTrgbe) | (dinfo.dtype == DTxyze) &&
258 dinfo.ncomp != 3) {
259 fclose(fp);
260 return(NULL);
261 }
262 }
263 dnew = rmx_alloc(dinfo.nrows, dinfo.ncols, dinfo.ncomp);
264 if (!dnew) {
265 fclose(fp);
266 return(NULL);
267 }
268 dnew->info = dinfo.info;
269 switch (dinfo.dtype) {
270 case DTascii:
271 SET_FILE_TEXT(fp);
272 if (!rmx_load_ascii(dnew, fp))
273 goto loaderr;
274 dnew->dtype = DTascii; /* should leave double? */
275 break;
276 case DTfloat:
277 dnew->swapin = dinfo.swapin;
278 if (!rmx_load_float(dnew, fp))
279 goto loaderr;
280 dnew->dtype = DTfloat;
281 break;
282 case DTdouble:
283 dnew->swapin = dinfo.swapin;
284 if (!rmx_load_double(dnew, fp))
285 goto loaderr;
286 dnew->dtype = DTdouble;
287 break;
288 case DTrgbe:
289 case DTxyze:
290 if (!rmx_load_rgbe(dnew, fp))
291 goto loaderr;
292 dnew->dtype = dinfo.dtype; /* undo exposure? */
293 if ((dinfo.mtx[0] != 1.) | (dinfo.mtx[1] != 1.) |
294 (dinfo.mtx[2] != 1.)) {
295 dinfo.mtx[0] = 1./dinfo.mtx[0];
296 dinfo.mtx[1] = 1./dinfo.mtx[1];
297 dinfo.mtx[2] = 1./dinfo.mtx[2];
298 rmx_scale(dnew, dinfo.mtx);
299 }
300 break;
301 default:
302 goto loaderr;
303 }
304 if (fp != stdin) {
305 if (inspec[0] == '!')
306 pclose(fp);
307 else
308 fclose(fp);
309 }
310 #ifdef getc_unlocked
311 else
312 funlockfile(fp);
313 #endif
314 return(dnew);
315 loaderr: /* should report error? */
316 if (inspec[0] == '!')
317 pclose(fp);
318 else
319 fclose(fp);
320 rmx_free(dnew);
321 return(NULL);
322 }
323
324 static int
325 rmx_write_ascii(const RMATRIX *rm, FILE *fp)
326 {
327 const char *fmt = (rm->dtype == DTfloat) ? " %.7e" :
328 (rm->dtype == DTrgbe) | (rm->dtype == DTxyze) ? " %.3e" :
329 " %.15e" ;
330 int i, j, k;
331
332 for (i = 0; i < rm->nrows; i++) {
333 for (j = 0; j < rm->ncols; j++) {
334 for (k = 0; k < rm->ncomp; k++)
335 fprintf(fp, fmt, rmx_lval(rm,i,j,k));
336 fputc('\t', fp);
337 }
338 fputc('\n', fp);
339 }
340 return(1);
341 }
342
343 static int
344 rmx_write_float(const RMATRIX *rm, FILE *fp)
345 {
346 int i, j, k;
347 float val[100];
348
349 if (rm->ncomp > 100) {
350 fputs("Unsupported # components in rmx_write_float()\n", stderr);
351 exit(1);
352 }
353 for (i = 0; i < rm->nrows; i++)
354 for (j = 0; j < rm->ncols; j++) {
355 for (k = rm->ncomp; k--; )
356 val[k] = (float)rmx_lval(rm,i,j,k);
357 if (putbinary(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp)
358 return(0);
359 }
360 return(1);
361 }
362
363 static int
364 rmx_write_double(const RMATRIX *rm, FILE *fp)
365 {
366 int i, j;
367
368 for (i = 0; i < rm->nrows; i++)
369 for (j = 0; j < rm->ncols; j++)
370 if (putbinary(&rmx_lval(rm,i,j,0), sizeof(double), rm->ncomp, fp) != rm->ncomp)
371 return(0);
372 return(1);
373 }
374
375 static int
376 rmx_write_rgbe(const RMATRIX *rm, FILE *fp)
377 {
378 COLR *scan = (COLR *)malloc(sizeof(COLR)*rm->ncols);
379 int i, j;
380
381 if (!scan)
382 return(0);
383 for (i = 0; i < rm->nrows; i++) {
384 for (j = rm->ncols; j--; )
385 setcolr(scan[j], rmx_lval(rm,i,j,0),
386 rmx_lval(rm,i,j,1),
387 rmx_lval(rm,i,j,2) );
388 if (fwritecolrs(scan, rm->ncols, fp) < 0) {
389 free(scan);
390 return(0);
391 }
392 }
393 free(scan);
394 return(1);
395 }
396
397 /* Write matrix to file type indicated by dtype */
398 int
399 rmx_write(const RMATRIX *rm, int dtype, FILE *fp)
400 {
401 RMATRIX *mydm = NULL;
402 int ok = 1;
403
404 if (!rm | !fp)
405 return(0);
406 #ifdef getc_unlocked
407 flockfile(fp);
408 #endif
409 /* complete header */
410 if (rm->info)
411 fputs(rm->info, fp);
412 if (dtype == DTfromHeader)
413 dtype = rm->dtype;
414 else if ((dtype == DTrgbe) & (rm->dtype == DTxyze))
415 dtype = DTxyze;
416 else if ((dtype == DTxyze) & (rm->dtype == DTrgbe))
417 dtype = DTrgbe;
418 if ((dtype != DTrgbe) & (dtype != DTxyze)) {
419 fprintf(fp, "NROWS=%d\n", rm->nrows);
420 fprintf(fp, "NCOLS=%d\n", rm->ncols);
421 fprintf(fp, "NCOMP=%d\n", rm->ncomp);
422 } else if (rm->ncomp != 3) { /* wrong # components? */
423 double cmtx[3];
424 if (rm->ncomp != 1) /* only convert grayscale */
425 return(0);
426 cmtx[0] = cmtx[1] = cmtx[2] = 1;
427 mydm = rmx_transform(rm, 3, cmtx);
428 if (!mydm)
429 return(0);
430 rm = mydm;
431 }
432 if ((dtype == DTfloat) | (dtype == DTdouble))
433 fputendian(fp); /* important to record */
434 fputformat((char *)cm_fmt_id[dtype], fp);
435 fputc('\n', fp);
436 switch (dtype) { /* write data */
437 case DTascii:
438 ok = rmx_write_ascii(rm, fp);
439 break;
440 case DTfloat:
441 ok = rmx_write_float(rm, fp);
442 break;
443 case DTdouble:
444 ok = rmx_write_double(rm, fp);
445 break;
446 case DTrgbe:
447 case DTxyze:
448 fprtresolu(rm->ncols, rm->nrows, fp);
449 ok = rmx_write_rgbe(rm, fp);
450 break;
451 default:
452 return(0);
453 }
454 ok &= (fflush(fp) == 0);
455 #ifdef getc_unlocked
456 funlockfile(fp);
457 #endif
458 if (mydm)
459 rmx_free(mydm);
460 return(ok);
461 }
462
463 /* Allocate and assign square identity matrix with n components */
464 RMATRIX *
465 rmx_identity(const int dim, const int n)
466 {
467 RMATRIX *rid = rmx_alloc(dim, dim, n);
468 int i, k;
469
470 if (!rid)
471 return(NULL);
472 memset(rid->mtx, 0, sizeof(rid->mtx[0])*n*dim*dim);
473 for (i = dim; i--; )
474 for (k = n; k--; )
475 rmx_lval(rid,i,i,k) = 1;
476 return(rid);
477 }
478
479 /* Duplicate the given matrix */
480 RMATRIX *
481 rmx_copy(const RMATRIX *rm)
482 {
483 RMATRIX *dnew;
484
485 if (!rm)
486 return(NULL);
487 dnew = rmx_alloc(rm->nrows, rm->ncols, rm->ncomp);
488 if (!dnew)
489 return(NULL);
490 rmx_addinfo(dnew, rm->info);
491 dnew->dtype = rm->dtype;
492 memcpy(dnew->mtx, rm->mtx,
493 sizeof(rm->mtx[0])*rm->ncomp*rm->nrows*rm->ncols);
494 return(dnew);
495 }
496
497 /* Allocate and assign transposed matrix */
498 RMATRIX *
499 rmx_transpose(const RMATRIX *rm)
500 {
501 RMATRIX *dnew;
502 int i, j, k;
503
504 if (!rm)
505 return(0);
506 if ((rm->nrows == 1) | (rm->ncols == 1)) {
507 dnew = rmx_copy(rm);
508 if (!dnew)
509 return(NULL);
510 dnew->nrows = rm->ncols;
511 dnew->ncols = rm->nrows;
512 return(dnew);
513 }
514 dnew = rmx_alloc(rm->ncols, rm->nrows, rm->ncomp);
515 if (!dnew)
516 return(NULL);
517 if (rm->info) {
518 rmx_addinfo(dnew, rm->info);
519 rmx_addinfo(dnew, "Transposed rows and columns\n");
520 }
521 dnew->dtype = rm->dtype;
522 for (i = dnew->nrows; i--; )
523 for (j = dnew->ncols; j--; )
524 for (k = dnew->ncomp; k--; )
525 rmx_lval(dnew,i,j,k) = rmx_lval(rm,j,i,k);
526 return(dnew);
527 }
528
529 /* Multiply (concatenate) two matrices and allocate the result */
530 RMATRIX *
531 rmx_multiply(const RMATRIX *m1, const RMATRIX *m2)
532 {
533 RMATRIX *mres;
534 int i, j, k, h;
535
536 if (!m1 | !m2 || (m1->ncomp != m2->ncomp) | (m1->ncols != m2->nrows))
537 return(NULL);
538 mres = rmx_alloc(m1->nrows, m2->ncols, m1->ncomp);
539 if (!mres)
540 return(NULL);
541 i = rmx_newtype(m1->dtype, m2->dtype);
542 if (i)
543 mres->dtype = i;
544 else
545 rmx_addinfo(mres, rmx_mismatch_warn);
546 for (i = mres->nrows; i--; )
547 for (j = mres->ncols; j--; )
548 for (k = mres->ncomp; k--; ) {
549 long double d = 0;
550 for (h = m1->ncols; h--; )
551 d += rmx_lval(m1,i,h,k) * rmx_lval(m2,h,j,k);
552 rmx_lval(mres,i,j,k) = (double)d;
553 }
554 return(mres);
555 }
556
557 /* Element-wise multiplication (or division) of m2 into m1 */
558 int
559 rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide)
560 {
561 int zeroDivides = 0;
562 int i, j, k;
563
564 if (!m1 | !m2 || (m1->ncols != m2->ncols) | (m1->nrows != m2->nrows))
565 return(0);
566 if ((m2->ncomp > 1) & (m2->ncomp != m1->ncomp))
567 return(0);
568 i = rmx_newtype(m1->dtype, m2->dtype);
569 if (i)
570 m1->dtype = i;
571 else
572 rmx_addinfo(m1, rmx_mismatch_warn);
573 for (i = m1->nrows; i--; )
574 for (j = m1->ncols; j--; )
575 if (divide) {
576 double d;
577 if (m2->ncomp == 1) {
578 d = rmx_lval(m2,i,j,0);
579 if (d == 0) {
580 ++zeroDivides;
581 for (k = m1->ncomp; k--; )
582 rmx_lval(m1,i,j,k) = 0;
583 } else {
584 d = 1./d;
585 for (k = m1->ncomp; k--; )
586 rmx_lval(m1,i,j,k) *= d;
587 }
588 } else
589 for (k = m1->ncomp; k--; ) {
590 d = rmx_lval(m2,i,j,k);
591 if (d == 0) {
592 ++zeroDivides;
593 rmx_lval(m1,i,j,k) = 0;
594 } else
595 rmx_lval(m1,i,j,k) /= d;
596 }
597 } else {
598 if (m2->ncomp == 1) {
599 const double d = rmx_lval(m2,i,j,0);
600 for (k = m1->ncomp; k--; )
601 rmx_lval(m1,i,j,k) *= d;
602 } else
603 for (k = m1->ncomp; k--; )
604 rmx_lval(m1,i,j,k) *= rmx_lval(m2,i,j,k);
605 }
606 if (zeroDivides) {
607 rmx_addinfo(m1, "WARNING: zero divide(s) corrupted results\n");
608 errno = ERANGE;
609 }
610 return(1);
611 }
612
613 /* Sum second matrix into first, applying scale factor beforehand */
614 int
615 rmx_sum(RMATRIX *msum, const RMATRIX *madd, const double sf[])
616 {
617 double *mysf = NULL;
618 int i, j, k;
619
620 if (!msum | !madd ||
621 (msum->nrows != madd->nrows) |
622 (msum->ncols != madd->ncols) |
623 (msum->ncomp != madd->ncomp))
624 return(0);
625 if (!sf) {
626 mysf = (double *)malloc(sizeof(double)*msum->ncomp);
627 if (!mysf)
628 return(0);
629 for (k = msum->ncomp; k--; )
630 mysf[k] = 1;
631 sf = mysf;
632 }
633 i = rmx_newtype(msum->dtype, madd->dtype);
634 if (i)
635 msum->dtype = i;
636 else
637 rmx_addinfo(msum, rmx_mismatch_warn);
638 for (i = msum->nrows; i--; )
639 for (j = msum->ncols; j--; )
640 for (k = msum->ncomp; k--; )
641 rmx_lval(msum,i,j,k) += sf[k] * rmx_lval(madd,i,j,k);
642 if (mysf)
643 free(mysf);
644 return(1);
645 }
646
647 /* Scale the given matrix by the indicated scalar component vector */
648 int
649 rmx_scale(RMATRIX *rm, const double sf[])
650 {
651 int i, j, k;
652
653 if (!rm | !sf)
654 return(0);
655 for (i = rm->nrows; i--; )
656 for (j = rm->ncols; j--; )
657 for (k = rm->ncomp; k--; )
658 rmx_lval(rm,i,j,k) *= sf[k];
659
660 if (rm->info)
661 rmx_addinfo(rm, "Applied scalar\n");
662 return(1);
663 }
664
665 /* Allocate new matrix and apply component transformation */
666 RMATRIX *
667 rmx_transform(const RMATRIX *msrc, int n, const double cmat[])
668 {
669 int i, j, ks, kd;
670 RMATRIX *dnew;
671
672 if (!msrc | (n <= 0) | !cmat)
673 return(NULL);
674 dnew = rmx_alloc(msrc->nrows, msrc->ncols, n);
675 if (!dnew)
676 return(NULL);
677 if (msrc->info) {
678 char buf[128];
679 sprintf(buf, "Applied %dx%d component transform\n",
680 dnew->ncomp, msrc->ncomp);
681 rmx_addinfo(dnew, msrc->info);
682 rmx_addinfo(dnew, buf);
683 }
684 dnew->dtype = msrc->dtype;
685 for (i = dnew->nrows; i--; )
686 for (j = dnew->ncols; j--; )
687 for (kd = dnew->ncomp; kd--; ) {
688 double d = 0;
689 for (ks = msrc->ncomp; ks--; )
690 d += cmat[kd*msrc->ncomp + ks] * rmx_lval(msrc,i,j,ks);
691 rmx_lval(dnew,i,j,kd) = d;
692 }
693 return(dnew);
694 }
695
696 /* Convert a color matrix to newly allocated RMATRIX buffer */
697 RMATRIX *
698 rmx_from_cmatrix(const CMATRIX *cm)
699 {
700 int i, j;
701 RMATRIX *dnew;
702
703 if (!cm)
704 return(NULL);
705 dnew = rmx_alloc(cm->nrows, cm->ncols, 3);
706 if (!dnew)
707 return(NULL);
708 dnew->dtype = DTfloat;
709 for (i = dnew->nrows; i--; )
710 for (j = dnew->ncols; j--; ) {
711 const COLORV *cv = cm_lval(cm,i,j);
712 rmx_lval(dnew,i,j,0) = cv[0];
713 rmx_lval(dnew,i,j,1) = cv[1];
714 rmx_lval(dnew,i,j,2) = cv[2];
715 }
716 return(dnew);
717 }
718
719 /* Convert general matrix to newly allocated CMATRIX buffer */
720 CMATRIX *
721 cm_from_rmatrix(const RMATRIX *rm)
722 {
723 int i, j;
724 CMATRIX *cnew;
725
726 if (!rm || rm->ncomp != 3)
727 return(NULL);
728 cnew = cm_alloc(rm->nrows, rm->ncols);
729 if (!cnew)
730 return(NULL);
731 for (i = cnew->nrows; i--; )
732 for (j = cnew->ncols; j--; ) {
733 COLORV *cv = cm_lval(cnew,i,j);
734 cv[0] = (COLORV)rmx_lval(rm,i,j,0);
735 cv[1] = (COLORV)rmx_lval(rm,i,j,1);
736 cv[2] = (COLORV)rmx_lval(rm,i,j,2);
737 }
738 return(cnew);
739 }
