root/radiance/ray/src/util/rmatrix.c
Revision: 2.39
Committed: Sat Dec 28 18:05:14 2019 UTC (5 years, 7 months ago) by greg
Changes since 2.38: +1 -4 lines
2 static const char RCSid[] = "$Id: rmatrix.c,v 2.38 2019/09/10 17:22:55 greg Exp $";
5 * General matrix operations.
6 */
7
8 #include <stdlib.h>
9 #include <errno.h>
10 #include "rtio.h"
11 #include "platform.h"
12 #include "resolu.h"
13 #include "paths.h"
14 #include "rmatrix.h"
15
16 static char rmx_mismatch_warn[] = "WARNING: data type mismatch\n";
17
18 /* Allocate a nr x nc matrix with n components */
19 RMATRIX *
20 rmx_alloc(int nr, int nc, int n)
21 {
22 RMATRIX *dnew;
23
24 if ((nr <= 0) | (nc <= 0) | (n <= 0))
25 return(NULL);
26 dnew = (RMATRIX *)malloc(sizeof(RMATRIX)-sizeof(dnew->mtx) +
27 sizeof(dnew->mtx[0])*(n*nr*nc));
28 if (!dnew)
29 return(NULL);
30 dnew->nrows = nr; dnew->ncols = nc; dnew->ncomp = n;
31 dnew->dtype = DTdouble;
32 dnew->swapin = 0;
33 dnew->info = NULL;
34 return(dnew);
35 }
36
37 /* Free a RMATRIX array */
38 void
39 rmx_free(RMATRIX *rm)
40 {
41 if (!rm) return;
42 if (rm->info)
43 free(rm->info);
44 free(rm);
45 }
46
47 /* Resolve data type based on two input types (returns 0 for mismatch) */
48 int
49 rmx_newtype(int dtyp1, int dtyp2)
50 {
51 if ((dtyp1==DTxyze) | (dtyp1==DTrgbe) |
52 (dtyp2==DTxyze) | (dtyp2==DTrgbe)
53 && dtyp1 != dtyp2)
54 return(0);
55 if (dtyp1 < dtyp2)
56 return(dtyp1);
57 return(dtyp2);
58 }
59
60 /* Append header information associated with matrix data */
61 int
62 rmx_addinfo(RMATRIX *rm, const char *info)
63 {
64 if (!rm || !info || !*info)
65 return(0);
66 if (!rm->info) {
67 rm->info = (char *)malloc(strlen(info)+1);
68 if (rm->info) rm->info[0] = '\0';
69 } else
70 rm->info = (char *)realloc(rm->info,
71 strlen(rm->info)+strlen(info)+1);
72 if (!rm->info)
73 return(0);
74 strcat(rm->info, info);
75 return(1);
76 }
77
78 static int
79 get_dminfo(char *s, void *p)
80 {
81 RMATRIX *ip = (RMATRIX *)p;
82 char fmt[MAXFMTLEN];
83 int i;
84
85 if (headidval(fmt, s))
86 return(0);
87 if (!strncmp(s, "NCOMP=", 6)) {
88 ip->ncomp = atoi(s+6);
89 return(0);
90 }
91 if (!strncmp(s, "NROWS=", 6)) {
92 ip->nrows = atoi(s+6);
93 return(0);
94 }
95 if (!strncmp(s, "NCOLS=", 6)) {
96 ip->ncols = atoi(s+6);
97 return(0);
98 }
99 if ((i = isbigendian(s)) >= 0) {
100 ip->swapin = (nativebigendian() != i);
101 return(0);
102 }
103 if (!formatval(fmt, s)) {
104 rmx_addinfo(ip, s);
105 return(0);
106 }
107 for (i = 1; i < DTend; i++)
108 if (!strcmp(fmt, cm_fmt_id[i])) {
109 ip->dtype = i;
110 return(0);
111 }
112 return(-1);
113 }
114
115 static int
116 rmx_load_ascii(RMATRIX *rm, FILE *fp)
117 {
118 int i, j, k;
119
120 for (i = 0; i < rm->nrows; i++)
121 for (j = 0; j < rm->ncols; j++)
122 for (k = 0; k < rm->ncomp; k++)
123 if (fscanf(fp, "%lf", &rmx_lval(rm,i,j,k)) != 1)
124 return(0);
125 return(1);
126 }
127
128 static int
129 rmx_load_float(RMATRIX *rm, FILE *fp)
130 {
131 int i, j, k;
132 float val[100];
133
134 if (rm->ncomp > 100) {
135 fputs("Unsupported # components in rmx_load_float()\n", stderr);
136 exit(1);
137 }
138 for (i = 0; i < rm->nrows; i++)
139 for (j = 0; j < rm->ncols; j++) {
140 if (getbinary(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp)
141 return(0);
142 if (rm->swapin)
143 swap32((char *)val, rm->ncomp);
144 for (k = rm->ncomp; k--; )
145 rmx_lval(rm,i,j,k) = val[k];
146 }
147 return(1);
148 }
149
150 static int
151 rmx_load_double(RMATRIX *rm, FILE *fp)
152 {
153 int i, j;
154
155 for (i = 0; i < rm->nrows; i++)
156 for (j = 0; j < rm->ncols; j++) {
157 if (getbinary(&rmx_lval(rm,i,j,0), sizeof(double), rm->ncomp, fp) != rm->ncomp)
158 return(0);
159 if (rm->swapin)
160 swap64((char *)&rmx_lval(rm,i,j,0), rm->ncomp);
161 }
162 return(1);
163 }
164
165 static int
166 rmx_load_rgbe(RMATRIX *rm, FILE *fp)
167 {
168 COLOR *scan = (COLOR *)malloc(sizeof(COLOR)*rm->ncols);
169 int i, j;
170
171 if (!scan)
172 return(0);
173 for (i = 0; i < rm->nrows; i++) {
174 if (freadscan(scan, rm->ncols, fp) < 0) {
175 free(scan);
176 return(0);
177 }
178 for (j = rm->ncols; j--; ) {
179 rmx_lval(rm,i,j,0) = colval(scan[j],RED);
180 rmx_lval(rm,i,j,1) = colval(scan[j],GRN);
181 rmx_lval(rm,i,j,2) = colval(scan[j],BLU);
182 }
183 }
184 free(scan);
185 return(1);
186 }
187
188 /* Load matrix from supported file type */
189 RMATRIX *
190 rmx_load(const char *inspec)
191 {
192 FILE *fp = stdin;
193 RMATRIX dinfo;
194 RMATRIX *dnew;
195
196 if (!inspec) { /* reading from stdin? */
197 inspec = "<stdin>";
198 SET_FILE_BINARY(stdin);
199 } else if (inspec[0] == '!') {
200 if (!(fp = popen(inspec+1, "r")))
201 return(NULL);
202 SET_FILE_BINARY(fp);
203 } else {
204 const char *sp = inspec; /* check suffix */
205 while (*sp)
206 ++sp;
207 while (sp > inspec && sp[-1] != '.')
208 --sp;
209 if (!strcasecmp(sp, "XML")) { /* assume it's a BSDF */
210 CMATRIX *cm = cm_loadBTDF((char *)inspec);
211 if (!cm)
212 return(NULL);
213 dnew = rmx_from_cmatrix(cm);
214 cm_free(cm);
215 dnew->dtype = DTascii;
216 return(dnew);
217 }
218 /* else open it ourselves */
219 if (!(fp = fopen(inspec, "rb")))
220 return(NULL);
221 }
222 #ifdef getc_unlocked
223 flockfile(fp);
224 #endif
225 dinfo.nrows = dinfo.ncols = dinfo.ncomp = 0;
226 dinfo.dtype = DTascii; /* assumed w/o FORMAT */
227 dinfo.swapin = 0;
228 dinfo.info = NULL;
229 if (getheader(fp, get_dminfo, &dinfo) < 0) {
230 fclose(fp);
231 return(NULL);
232 }
233 if ((dinfo.nrows <= 0) | (dinfo.ncols <= 0)) {
234 if (!fscnresolu(&dinfo.ncols, &dinfo.nrows, fp)) {
235 fclose(fp);
236 return(NULL);
237 }
238 if (dinfo.ncomp <= 0)
239 dinfo.ncomp = 3;
240 else if ((dinfo.dtype == DTrgbe) | (dinfo.dtype == DTxyze) &&
241 dinfo.ncomp != 3) {
242 fclose(fp);
243 return(NULL);
244 }
245 }
246 dnew = rmx_alloc(dinfo.nrows, dinfo.ncols, dinfo.ncomp);
247 if (!dnew) {
248 fclose(fp);
249 return(NULL);
250 }
251 dnew->info = dinfo.info;
252 switch (dinfo.dtype) {
253 case DTascii:
254 SET_FILE_TEXT(fp);
255 if (!rmx_load_ascii(dnew, fp))
256 goto loaderr;
257 dnew->dtype = DTascii; /* should leave double? */
258 break;
259 case DTfloat:
260 dnew->swapin = dinfo.swapin;
261 if (!rmx_load_float(dnew, fp))
262 goto loaderr;
263 dnew->dtype = DTfloat;
264 break;
265 case DTdouble:
266 dnew->swapin = dinfo.swapin;
267 if (!rmx_load_double(dnew, fp))
268 goto loaderr;
269 dnew->dtype = DTdouble;
270 break;
271 case DTrgbe:
272 case DTxyze:
273 if (!rmx_load_rgbe(dnew, fp))
274 goto loaderr;
275 dnew->dtype = dinfo.dtype;
276 break;
277 default:
278 goto loaderr;
279 }
280 if (fp != stdin) {
281 if (inspec[0] == '!')
282 pclose(fp);
283 else
284 fclose(fp);
285 }
286 #ifdef getc_unlocked
287 else
288 funlockfile(fp);
289 #endif
290 return(dnew);
291 loaderr: /* should report error? */
292 if (inspec[0] == '!')
293 pclose(fp);
294 else
295 fclose(fp);
296 rmx_free(dnew);
297 return(NULL);
298 }
299
300 static int
301 rmx_write_ascii(const RMATRIX *rm, FILE *fp)
302 {
303 const char *fmt = (rm->dtype == DTfloat) ? " %.7e" :
304 (rm->dtype == DTrgbe) | (rm->dtype == DTxyze) ? " %.3e" :
305 " %.15e" ;
306 int i, j, k;
307
308 for (i = 0; i < rm->nrows; i++) {
309 for (j = 0; j < rm->ncols; j++) {
310 for (k = 0; k < rm->ncomp; k++)
311 fprintf(fp, fmt, rmx_lval(rm,i,j,k));
312 fputc('\t', fp);
313 }
314 fputc('\n', fp);
315 }
316 return(1);
317 }
318
319 static int
320 rmx_write_float(const RMATRIX *rm, FILE *fp)
321 {
322 int i, j, k;
323 float val[100];
324
325 if (rm->ncomp > 100) {
326 fputs("Unsupported # components in rmx_write_float()\n", stderr);
327 exit(1);
328 }
329 for (i = 0; i < rm->nrows; i++)
330 for (j = 0; j < rm->ncols; j++) {
331 for (k = rm->ncomp; k--; )
332 val[k] = (float)rmx_lval(rm,i,j,k);
333 if (putbinary(val, sizeof(val[0]), rm->ncomp, fp) != rm->ncomp)
334 return(0);
335 }
336 return(1);
337 }
338
339 static int
340 rmx_write_double(const RMATRIX *rm, FILE *fp)
341 {
342 int i, j;
343
344 for (i = 0; i < rm->nrows; i++)
345 for (j = 0; j < rm->ncols; j++)
346 if (putbinary(&rmx_lval(rm,i,j,0), sizeof(double), rm->ncomp, fp) != rm->ncomp)
347 return(0);
348 return(1);
349 }
350
351 static int
352 rmx_write_rgbe(const RMATRIX *rm, FILE *fp)
353 {
354 COLR *scan = (COLR *)malloc(sizeof(COLR)*rm->ncols);
355 int i, j;
356
357 if (!scan)
358 return(0);
359 for (i = 0; i < rm->nrows; i++) {
360 for (j = rm->ncols; j--; )
361 setcolr(scan[j], rmx_lval(rm,i,j,0),
362 rmx_lval(rm,i,j,1),
363 rmx_lval(rm,i,j,2) );
364 if (fwritecolrs(scan, rm->ncols, fp) < 0) {
365 free(scan);
366 return(0);
367 }
368 }
369 free(scan);
370 return(1);
371 }
372
373 /* Write matrix to file type indicated by dtype */
374 int
375 rmx_write(const RMATRIX *rm, int dtype, FILE *fp)
376 {
377 RMATRIX *mydm = NULL;
378 int ok = 1;
379
380 if (!rm | !fp)
381 return(0);
382 #ifdef getc_unlocked
383 flockfile(fp);
384 #endif
385 /* complete header */
386 if (rm->info)
387 fputs(rm->info, fp);
388 if (dtype == DTfromHeader)
389 dtype = rm->dtype;
390 else if ((dtype == DTrgbe) & (rm->dtype == DTxyze))
391 dtype = DTxyze;
392 else if ((dtype == DTxyze) & (rm->dtype == DTrgbe))
393 dtype = DTrgbe;
394 if ((dtype != DTrgbe) & (dtype != DTxyze)) {
395 fprintf(fp, "NROWS=%d\n", rm->nrows);
396 fprintf(fp, "NCOLS=%d\n", rm->ncols);
397 fprintf(fp, "NCOMP=%d\n", rm->ncomp);
398 } else if (rm->ncomp != 3) { /* wrong # components? */
399 double cmtx[3];
400 if (rm->ncomp != 1) /* only convert grayscale */
401 return(0);
402 cmtx[0] = cmtx[1] = cmtx[2] = 1;
403 mydm = rmx_transform(rm, 3, cmtx);
404 if (!mydm)
405 return(0);
406 rm = mydm;
407 }
408 if ((dtype == DTfloat) | (dtype == DTdouble))
409 fputendian(fp); /* important to record */
410 fputformat((char *)cm_fmt_id[dtype], fp);
411 fputc('\n', fp);
412 switch (dtype) { /* write data */
413 case DTascii:
414 ok = rmx_write_ascii(rm, fp);
415 break;
416 case DTfloat:
417 ok = rmx_write_float(rm, fp);
418 break;
419 case DTdouble:
420 ok = rmx_write_double(rm, fp);
421 break;
422 case DTrgbe:
423 case DTxyze:
424 fprtresolu(rm->ncols, rm->nrows, fp);
425 ok = rmx_write_rgbe(rm, fp);
426 break;
427 default:
428 return(0);
429 }
430 ok &= (fflush(fp) == 0);
431 #ifdef getc_unlocked
432 funlockfile(fp);
433 #endif
434 if (mydm)
435 rmx_free(mydm);
436 return(ok);
437 }
438
439 /* Allocate and assign square identity matrix with n components */
440 RMATRIX *
441 rmx_identity(const int dim, const int n)
442 {
443 RMATRIX *rid = rmx_alloc(dim, dim, n);
444 int i, k;
445
446 if (!rid)
447 return(NULL);
448 memset(rid->mtx, 0, sizeof(rid->mtx[0])*n*dim*dim);
449 for (i = dim; i--; )
450 for (k = n; k--; )
451 rmx_lval(rid,i,i,k) = 1;
452 return(rid);
453 }
454
455 /* Duplicate the given matrix */
456 RMATRIX *
457 rmx_copy(const RMATRIX *rm)
458 {
459 RMATRIX *dnew;
460
461 if (!rm)
462 return(NULL);
463 dnew = rmx_alloc(rm->nrows, rm->ncols, rm->ncomp);
464 if (!dnew)
465 return(NULL);
466 rmx_addinfo(dnew, rm->info);
467 dnew->dtype = rm->dtype;
468 memcpy(dnew->mtx, rm->mtx,
469 sizeof(rm->mtx[0])*rm->ncomp*rm->nrows*rm->ncols);
470 return(dnew);
471 }
472
473 /* Allocate and assign transposed matrix */
474 RMATRIX *
475 rmx_transpose(const RMATRIX *rm)
476 {
477 RMATRIX *dnew;
478 int i, j, k;
479
480 if (!rm)
481 return(0);
482 if ((rm->nrows == 1) | (rm->ncols == 1)) {
483 dnew = rmx_copy(rm);
484 if (!dnew)
485 return(NULL);
486 dnew->nrows = rm->ncols;
487 dnew->ncols = rm->nrows;
488 return(dnew);
489 }
490 dnew = rmx_alloc(rm->ncols, rm->nrows, rm->ncomp);
491 if (!dnew)
492 return(NULL);
493 if (rm->info) {
494 rmx_addinfo(dnew, rm->info);
495 rmx_addinfo(dnew, "Transposed rows and columns\n");
496 }
497 dnew->dtype = rm->dtype;
498 for (i = dnew->nrows; i--; )
499 for (j = dnew->ncols; j--; )
500 for (k = dnew->ncomp; k--; )
501 rmx_lval(dnew,i,j,k) = rmx_lval(rm,j,i,k);
502 return(dnew);
503 }
504
505 /* Multiply (concatenate) two matrices and allocate the result */
506 RMATRIX *
507 rmx_multiply(const RMATRIX *m1, const RMATRIX *m2)
508 {
509 RMATRIX *mres;
510 int i, j, k, h;
511
512 if (!m1 | !m2 || (m1->ncomp != m2->ncomp) | (m1->ncols != m2->nrows))
513 return(NULL);
514 mres = rmx_alloc(m1->nrows, m2->ncols, m1->ncomp);
515 if (!mres)
516 return(NULL);
517 i = rmx_newtype(m1->dtype, m2->dtype);
518 if (i)
519 mres->dtype = i;
520 else
521 rmx_addinfo(mres, rmx_mismatch_warn);
522 for (i = mres->nrows; i--; )
523 for (j = mres->ncols; j--; )
524 for (k = mres->ncomp; k--; ) {
525 long double d = 0;
526 for (h = m1->ncols; h--; )
527 d += rmx_lval(m1,i,h,k) * rmx_lval(m2,h,j,k);
528 rmx_lval(mres,i,j,k) = (double)d;
529 }
530 return(mres);
531 }
532
533 /* Element-wise multiplication (or division) of m2 into m1 */
534 int
535 rmx_elemult(RMATRIX *m1, const RMATRIX *m2, int divide)
536 {
537 int zeroDivides = 0;
538 int i, j, k;
539
540 if (!m1 | !m2 || (m1->ncols != m2->ncols) | (m1->nrows != m2->nrows))
541 return(0);
542 if ((m2->ncomp > 1) & (m2->ncomp != m1->ncomp))
543 return(0);
544 i = rmx_newtype(m1->dtype, m2->dtype);
545 if (i)
546 m1->dtype = i;
547 else
548 rmx_addinfo(m1, rmx_mismatch_warn);
549 for (i = m1->nrows; i--; )
550 for (j = m1->ncols; j--; )
551 if (divide) {
552 double d;
553 if (m2->ncomp == 1) {
554 d = rmx_lval(m2,i,j,0);
555 if (d == 0) {
556 ++zeroDivides;
557 for (k = m1->ncomp; k--; )
558 rmx_lval(m1,i,j,k) = 0;
559 } else {
560 d = 1./d;
561 for (k = m1->ncomp; k--; )
562 rmx_lval(m1,i,j,k) *= d;
563 }
564 } else
565 for (k = m1->ncomp; k--; ) {
566 d = rmx_lval(m2,i,j,k);
567 if (d == 0) {
568 ++zeroDivides;
569 rmx_lval(m1,i,j,k) = 0;
570 } else
571 rmx_lval(m1,i,j,k) /= d;
572 }
573 } else {
574 if (m2->ncomp == 1) {
575 const double d = rmx_lval(m2,i,j,0);
576 for (k = m1->ncomp; k--; )
577 rmx_lval(m1,i,j,k) *= d;
578 } else
579 for (k = m1->ncomp; k--; )
580 rmx_lval(m1,i,j,k) *= rmx_lval(m2,i,j,k);
581 }
582 if (zeroDivides) {
583 rmx_addinfo(m1, "WARNING: zero divide(s) corrupted results\n");
584 errno = ERANGE;
585 }
586 return(1);
587 }
588
589 /* Sum second matrix into first, applying scale factor beforehand */
590 int
591 rmx_sum(RMATRIX *msum, const RMATRIX *madd, const double sf[])
592 {
593 double *mysf = NULL;
594 int i, j, k;
595
596 if (!msum | !madd ||
597 (msum->nrows != madd->nrows) |
598 (msum->ncols != madd->ncols) |
599 (msum->ncomp != madd->ncomp))
600 return(0);
601 if (!sf) {
602 mysf = (double *)malloc(sizeof(double)*msum->ncomp);
603 if (!mysf)
604 return(0);
605 for (k = msum->ncomp; k--; )
606 mysf[k] = 1;
607 sf = mysf;
608 }
609 i = rmx_newtype(msum->dtype, madd->dtype);
610 if (i)
611 msum->dtype = i;
612 else
613 rmx_addinfo(msum, rmx_mismatch_warn);
614 for (i = msum->nrows; i--; )
615 for (j = msum->ncols; j--; )
616 for (k = msum->ncomp; k--; )
617 rmx_lval(msum,i,j,k) += sf[k] * rmx_lval(madd,i,j,k);
618 if (mysf)
619 free(mysf);
620 return(1);
621 }
622
623 /* Scale the given matrix by the indicated scalar component vector */
624 int
625 rmx_scale(RMATRIX *rm, const double sf[])
626 {
627 int i, j, k;
628
629 if (!rm | !sf)
630 return(0);
631 for (i = rm->nrows; i--; )
632 for (j = rm->ncols; j--; )
633 for (k = rm->ncomp; k--; )
634 rmx_lval(rm,i,j,k) *= sf[k];
635
636 if (rm->info)
637 rmx_addinfo(rm, "Applied scalar\n");
638 return(1);
639 }
640
641 /* Allocate new matrix and apply component transformation */
642 RMATRIX *
643 rmx_transform(const RMATRIX *msrc, int n, const double cmat[])
644 {
645 int i, j, ks, kd;
646 RMATRIX *dnew;
647
648 if (!msrc | (n <= 0) | !cmat)
649 return(NULL);
650 dnew = rmx_alloc(msrc->nrows, msrc->ncols, n);
651 if (!dnew)
652 return(NULL);
653 if (msrc->info) {
654 char buf[128];
655 sprintf(buf, "Applied %dx%d component transform\n",
656 dnew->ncomp, msrc->ncomp);
657 rmx_addinfo(dnew, msrc->info);
658 rmx_addinfo(dnew, buf);
659 }
660 dnew->dtype = msrc->dtype;
661 for (i = dnew->nrows; i--; )
662 for (j = dnew->ncols; j--; )
663 for (kd = dnew->ncomp; kd--; ) {
664 double d = 0;
665 for (ks = msrc->ncomp; ks--; )
666 d += cmat[kd*msrc->ncomp + ks] * rmx_lval(msrc,i,j,ks);
667 rmx_lval(dnew,i,j,kd) = d;
668 }
669 return(dnew);
670 }
671
672 /* Convert a color matrix to newly allocated RMATRIX buffer */
673 RMATRIX *
674 rmx_from_cmatrix(const CMATRIX *cm)
675 {
676 int i, j;
677 RMATRIX *dnew;
678
679 if (!cm)
680 return(NULL);
681 dnew = rmx_alloc(cm->nrows, cm->ncols, 3);
682 if (!dnew)
683 return(NULL);
684 dnew->dtype = DTfloat;
685 for (i = dnew->nrows; i--; )
686 for (j = dnew->ncols; j--; ) {
687 const COLORV *cv = cm_lval(cm,i,j);
688 rmx_lval(dnew,i,j,0) = cv[0];
689 rmx_lval(dnew,i,j,1) = cv[1];
690 rmx_lval(dnew,i,j,2) = cv[2];
691 }
692 return(dnew);
693 }
694
695 /* Convert general matrix to newly allocated CMATRIX buffer */
696 CMATRIX *
697 cm_from_rmatrix(const RMATRIX *rm)
698 {
699 int i, j;
700 CMATRIX *cnew;
701
702 if (!rm || rm->ncomp != 3)
703 return(NULL);
704 cnew = cm_alloc(rm->nrows, rm->ncols);
705 if (!cnew)
706 return(NULL);
707 for (i = cnew->nrows; i--; )
708 for (j = cnew->ncols; j--; ) {
709 COLORV *cv = cm_lval(cnew,i,j);
710 cv[0] = (COLORV)rmx_lval(rm,i,j,0);
711 cv[1] = (COLORV)rmx_lval(rm,i,j,1);
712 cv[2] = (COLORV)rmx_lval(rm,i,j,2);
713 }
714 return(cnew);
715 }
