root/Development/ray/src/util/rfluxmtx.c
Revision: 2.66
Committed: Thu Oct 23 23:34:00 2025 UTC (6 days, 21 hours ago) by greg
Changes since 2.65: +4 -2 lines
feat(rfluxmtx): Permit passing of -e and -f options to rcontrib
2 static const char RCSid[] = "$Id: rfluxmtx.c,v 2.65 2025/10/22 20:00:17 greg Exp $";
5 * Calculate flux transfer matrix or matrices using rcontrib
6 */
7
8 #include "copyright.h"
9
10 #include <ctype.h>
11 #include <stdlib.h>
12 #include "rtio.h"
13 #include "rtmath.h"
14 #include "rtprocess.h"
15 #include "bsdf.h"
16 #include "bsdf_m.h"
17 #include "random.h"
18 #include "triangulate.h"
19 #include "platform.h"
20
21 #ifndef MAXRCARG
22 #define MAXRCARG 10000
23 #endif
24
25 #define NOWARN 1
26 #define VERBO 2
27
28 int verbose = 0; /* verbose/warning mode */
29
30 char *rcarg[MAXRCARG+1] = {"rcontrib", "-fo+"};
31 int nrcargs = 2;
32
33 const char overflowerr[] = "%s: too many arguments!\n";
34
35 #define CHECKARGC(n) if (nrcargs >= MAXRCARG-(n)) \
36 { fprintf(stderr, overflowerr, progname); exit(1); }
37
38 int sampcnt = 0; /* sample count (0==unset) */
39
40 char *reinhfn = "reinhartb.cal";
41 char *shirchiufn = "disk2square.cal";
42 char *kfullfn = "klems_full.cal";
43 char *khalffn = "klems_half.cal";
44 char *kquarterfn = "klems_quarter.cal";
45 char *ciefn = "cieskyscan.cal";
46
47 /* string indicating parameters */
48 #define PARAMSTART "@rfluxmtx"
49
50 /* surface type IDs */
51 #define ST_NONE 0
52 #define ST_POLY 1
53 #define ST_RING 2
54 #define ST_SOURCE 3
55
56 typedef struct surf_s {
57 struct surf_s *next; /* next surface in list */
58 void *priv; /* private data (malloc'ed) */
59 char sname[32]; /* surface name */
60 FVECT snrm; /* surface normal */
61 double area; /* surface area / proj. solid angle */
62 short styp; /* surface type */
63 short nfargs; /* number of real arguments */
64 double farg[1]; /* real values (extends struct) */
65 } SURF; /* surface structure */
66
67 typedef struct {
68 FVECT uva[2]; /* tangent axes */
69 int ntris; /* number of triangles */
70 struct ptri {
71 double afrac; /* fraction of total area */
72 short vndx[3]; /* vertex indices */
73 } tri[1]; /* triangle array (extends struct) */
74 } POLYTRIS; /* triangulated polygon */
75
76 typedef struct param_s {
77 char sign; /* '-' for axis reversal */
78 char hemis[31]; /* hemispherical sampling spec. */
79 int hsiz; /* hemisphere basis size */
80 int nsurfs; /* number of surfaces */
81 SURF *slist; /* list of surfaces */
82 FVECT vup; /* up vector (zero if unset) */
83 FVECT nrm; /* average normal direction */
84 FVECT udir, vdir; /* tangent axes */
85 char *outfn; /* output file name (receiver) */
86 int (*sample_basis)(struct param_s *p, int, FILE *);
87 } PARAMS; /* sender/receiver parameters */
88
89 PARAMS curparams;
90 char curmod[128];
91 char newparams[1024];
92
93 typedef int SURFSAMP(FVECT, SURF *, double);
94
95 static SURFSAMP ssamp_bad, ssamp_poly, ssamp_ring;
96
97 SURFSAMP *orig_in_surf[4] = {
98 ssamp_bad, ssamp_poly, ssamp_ring, ssamp_bad
99 };
100
101 /* Clear parameter set */
102 static void
103 clear_params(PARAMS *p, int reset_only)
104 {
105 while (p->slist != NULL) {
106 SURF *sdel = p->slist;
107 p->slist = sdel->next;
108 if (sdel->priv != NULL)
109 free(sdel->priv);
110 free(sdel);
111 }
112 if (reset_only) {
113 p->slist = NULL;
114 p->nsurfs = 0;
115 memset(p->nrm, 0, sizeof(FVECT));
116 memset(p->vup, 0, sizeof(FVECT));
117 p->outfn = NULL;
118 return;
119 }
120 memset(p, 0, sizeof(PARAMS));
121 }
122
123 /* Get surface type from name */
124 static int
125 surf_type(const char *otype)
126 {
127 if (!strcmp(otype, "polygon"))
128 return(ST_POLY);
129 if (!strcmp(otype, "ring"))
130 return(ST_RING);
131 if (!strcmp(otype, "source"))
132 return(ST_SOURCE);
133 return(ST_NONE);
134 }
135
136 /* Add arguments to oconv command */
137 static char *
138 oconv_command(int ac, char *av[])
139 {
140 static char oconvbuf[2048] = "!oconv -f ";
141 char *cp = oconvbuf + 10;
142 char *recv = *av++;
143
144 if (ac-- <= 0)
145 return(NULL);
146 if (verbose & NOWARN) { /* warnings off? */
147 strcpy(cp, "-w ");
148 cp += 3;
149 }
150 while (ac-- > 0) { /* copy each argument */
151 int len = strlen(*av);
152 if (cp+len+4 >= oconvbuf+sizeof(oconvbuf))
153 goto overrun;
154 if (matchany(*av, SPECIALS)) {
155 *cp++ = QUOTCHAR;
156 strcpy(cp, *av++);
157 cp += len;
158 *cp++ = QUOTCHAR;
159 } else {
160 strcpy(cp, *av++);
161 cp += len;
162 }
163 *cp++ = ' ';
164 }
165 /* receiver goes last */
166 if (matchany(recv, SPECIALS)) {
167 *cp++ = QUOTCHAR;
168 while (*recv) {
169 if (cp >= oconvbuf+(sizeof(oconvbuf)-3))
170 goto overrun;
171 *cp++ = *recv++;
172 }
173 *cp++ = QUOTCHAR;
174 *cp = '\0';
175 } else
176 strcpy(cp, recv);
177 return(oconvbuf);
178 overrun:
179 fputs(progname, stderr);
180 fputs(": too many file arguments!\n", stderr);
181 exit(1);
182 }
183
184 #if defined(_WIN32) || defined(_WIN64)
185
186 /* Open a pipe to/from a command given as an argument list */
187 static FILE *
188 popen_arglist(char *av[], char *mode)
189 {
190 char cmd[10240];
191
192 if (!convert_commandline(cmd, sizeof(cmd), av)) {
193 fputs(progname, stderr);
194 fputs(": command line too long in popen_arglist()\n", stderr);
195 return(NULL);
196 }
197 if (verbose & VERBO)
198 fprintf(stderr, "%s: opening pipe %s: %s\n",
199 progname, (*mode=='w') ? "to" : "from", cmd);
200 return(popen(cmd, mode));
201 }
202
203 #define pclose_al pclose
204
205 /* Execute system command (Windows version) */
206 static int
207 my_exec(char *av[])
208 {
209 char cmd[10240];
210
211 if (!convert_commandline(cmd, sizeof(cmd), av)) {
212 fputs(progname, stderr);
213 fputs(": command line too long in my_exec()\n", stderr);
214 return(1);
215 }
216 if (verbose & VERBO)
217 fprintf(stderr, "%s: running: %s\n", progname, cmd);
218 return(system(cmd));
219 }
220
221 #else /* UNIX */
222
223 static SUBPROC rt_proc = SP_INACTIVE; /* we only support one of these */
224
225 /* Open a pipe to a command using an argument list */
226 static FILE *
227 popen_arglist(char *av[], char *mode)
228 {
229 int fd;
230
231 if (rt_proc.pid > 0) {
232 fprintf(stderr, "%s: only one i/o pipe at a time!\n", progname);
233 return(NULL);
234 }
235 if (verbose & VERBO) {
236 char cmd[4096];
237 if (!convert_commandline(cmd, sizeof(cmd), av))
238 strcpy(cmd, "COMMAND TOO LONG TO SHOW");
239 fprintf(stderr, "%s: opening pipe %s: %s\n",
240 progname, (*mode=='w') ? "to" : "from", cmd);
241 }
242 if (*mode == 'w') {
243 fd = rt_proc.w = dup(fileno(stdout));
244 rt_proc.flags |= PF_FILT_OUT;
245 } else if (*mode == 'r') {
246 fd = rt_proc.r = dup(fileno(stdin));
247 rt_proc.flags |= PF_FILT_INP;
248 }
249 if (fd < 0 || open_process(&rt_proc, av) <= 0) {
250 perror(av[0]);
251 return(NULL);
252 }
253 return(fdopen(fd, mode));
254 }
255
256 /* Close command pipe (returns -1 on error to match pclose) */
257 static int
258 pclose_al(FILE *fp)
259 {
260 int prob = (fclose(fp) == EOF);
261
262 if (rt_proc.pid <= 0)
263 return(-1);
264
265 prob |= (close_process(&rt_proc) != 0);
266
267 return(-prob);
268 }
269
270 /* Execute system command in our stead (Unix version) */
271 static int
272 my_exec(char *av[])
273 {
274 char *compath;
275
276 if ((compath = getpath((char *)av[0], getenv("PATH"), X_OK)) == NULL) {
277 fprintf(stderr, "%s: cannot locate %s\n", progname, av[0]);
278 return(1);
279 }
280 if (verbose & VERBO) {
281 char cmd[4096];
282 if (!convert_commandline(cmd, sizeof(cmd), av))
283 strcpy(cmd, "COMMAND TOO LONG TO SHOW");
284 fprintf(stderr, "%s: running: %s\n", progname, cmd);
285 }
286 execv(compath, av); /* successful call never returns */
287 perror(compath);
288 return(1);
289 }
290
291 #endif
292
293 /* Get normalized direction vector from string specification */
294 static int
295 get_direction(FVECT dv, const char *s)
296 {
297 int sign = 1;
298 int axis = 0;
299
300 memset(dv, 0, sizeof(FVECT));
301 nextchar:
302 switch (*s) {
303 case '+':
304 ++s;
305 goto nextchar;
306 case '-':
307 sign = -sign;
308 ++s;
309 goto nextchar;
310 case 'z':
311 case 'Z':
312 ++axis;
313 case 'y':
314 case 'Y':
315 ++axis;
316 case 'x':
317 case 'X':
318 dv[axis] = sign;
319 return(!s[1] | isspace(s[1]));
320 default:
321 break;
322 }
323 #ifdef SMLFLT
324 if (sscanf(s, "%f,%f,%f", &dv[0], &dv[1], &dv[2]) != 3)
325 #else
326 if (sscanf(s, "%lf,%lf,%lf", &dv[0], &dv[1], &dv[2]) != 3)
327 #endif
328 return(0);
329 dv[0] *= (RREAL)sign;
330 return(normalize(dv) > 0);
331 }
332
333 /* Parse program parameters (directives) */
334 static int
335 parse_params(PARAMS *p, char *pargs)
336 {
337 char *cp = pargs;
338 int nparams = 0;
339 int quot;
340 int i;
341
342 for ( ; ; ) {
343 switch (*cp++) {
344 case 'h':
345 if (*cp++ != '=')
346 break;
347 if ((*cp == '+') | (*cp == '-'))
348 p->sign = *cp++;
349 else
350 p->sign = '+';
351 p->hsiz = 0;
352 i = 0;
353 while (*cp && !isspace(*cp)) {
354 if (isdigit(*cp))
355 p->hsiz = 10*p->hsiz + *cp - '0';
356 p->hemis[i++] = *cp++;
357 }
358 if (!i)
359 break;
360 p->hemis[i] = '\0';
361 p->hsiz += !p->hsiz;
362 ++nparams;
363 continue;
364 case 'u':
365 if (*cp++ != '=')
366 break;
367 if (!get_direction(p->vup, cp))
368 break;
369 while (*cp && !isspace(*cp++))
370 ;
371 ++nparams;
372 continue;
373 case 'o':
374 if (*cp++ != '=')
375 break;
376 quot = 0;
377 if ((*cp == '"') | (*cp == '\''))
378 quot = *cp++;
379 i = 0;
380 while (*cp && (quot ? (*cp != quot) : !isspace(*cp))) {
381 i++; cp++;
382 }
383 if (!i)
384 break;
385 if (!*cp) {
386 if (quot)
387 break;
388 cp[1] = '\0';
389 }
390 *cp = '\0';
391 p->outfn = savqstr(cp-i);
392 *cp++ = quot ? quot : ' ';
393 ++nparams;
394 continue;
395 case ' ':
396 case '\t':
397 case '\r':
398 case '\n':
399 continue;
400 case '\0':
401 return(nparams);
402 default:
403 break;
404 }
405 break;
406 }
407 fprintf(stderr, "%s: bad parameter string: %s", progname, pargs);
408 exit(1);
409 return(-1); /* pro forma return */
410 }
411
412 /* Add receiver arguments (directives) corresponding to the current modifier */
413 static void
414 finish_receiver(void)
415 {
416 char sbuf[256];
417 int uniform = 0;
418 char *calfn = NULL;
419 char *params = NULL;
420 char *binv = NULL;
421 char *binf = NULL;
422 char *nbins = NULL;
423
424 if (!curmod[0]) {
425 fputs(progname, stderr);
426 fputs(": missing receiver surface!\n", stderr);
427 exit(1);
428 }
429 if (curparams.outfn != NULL) { /* add output file spec. */
430 CHECKARGC(2);
431 rcarg[nrcargs++] = "-o";
432 rcarg[nrcargs++] = curparams.outfn;
433 }
434 /* check arguments */
435 if (!curparams.hemis[0]) {
436 fputs(progname, stderr);
437 fputs(": missing hemisphere sampling type!\n", stderr);
438 exit(1);
439 }
440 if (normalize(curparams.nrm) == 0) {
441 fputs(progname, stderr);
442 fputs(": undefined normal for hemisphere sampling\n", stderr);
443 exit(1);
444 }
445 if (normalize(curparams.vup) == 0) {
446 if (fabs(curparams.nrm[2]) < .7)
447 curparams.vup[2] = 1;
448 else
449 curparams.vup[1] = 1;
450 }
451 /* determine sample type/bin */
452 if ((tolower(curparams.hemis[0]) == 'u') | (curparams.hemis[0] == '1')) {
453 if (curparams.slist->styp != ST_SOURCE) {
454 sprintf(sbuf, "if(-Dx*%g-Dy*%g-Dz*%g,0,-1)",
455 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2]);
456 binv = savqstr(sbuf);
457 } else
458 binv = "0";
459 nbins = "1"; /* uniform sampling -- one bin */
460 uniform = 1;
461 } else if (tolower(curparams.hemis[0]) == 's' &&
462 tolower(curparams.hemis[1]) == 'c') {
463 /* assign parameters */
464 if (curparams.hsiz <= 1) {
465 fputs(progname, stderr);
466 fputs(": missing size for Shirley-Chiu sampling!\n", stderr);
467 exit(1);
468 }
469 calfn = shirchiufn; shirchiufn = NULL;
470 sprintf(sbuf, "SCdim=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1",
471 curparams.hsiz,
472 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
473 curparams.vup[0], curparams.vup[1], curparams.vup[2],
474 curparams.sign);
475 params = savqstr(sbuf);
476 binv = "scbin";
477 nbins = "SCdim*SCdim";
478 } else if ((tolower(curparams.hemis[0]) == 'r') |
479 (tolower(curparams.hemis[0]) == 't')) {
480 calfn = reinhfn; reinhfn = NULL;
481 sprintf(sbuf, "MF=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1",
482 curparams.hsiz,
483 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
484 curparams.vup[0], curparams.vup[1], curparams.vup[2],
485 curparams.sign);
486 params = savqstr(sbuf);
487 binv = "rbin";
488 nbins = "Nrbins";
489 } else if (tolower(curparams.hemis[0]) == 'k' &&
490 !curparams.hemis[1] |
491 (tolower(curparams.hemis[1]) == 'f') |
492 (curparams.hemis[1] == '1')) {
493 calfn = kfullfn; kfullfn = NULL;
494 binf = "kbin";
495 nbins = "Nkbins";
496 } else if (tolower(curparams.hemis[0]) == 'k' &&
497 (tolower(curparams.hemis[1]) == 'h') |
498 (curparams.hemis[1] == '2')) {
499 calfn = khalffn; khalffn = NULL;
500 binf = "khbin";
501 nbins = "Nkhbins";
502 } else if (tolower(curparams.hemis[0]) == 'k' &&
503 (tolower(curparams.hemis[1]) == 'q') |
504 (curparams.hemis[1] == '4')) {
505 calfn = kquarterfn; kquarterfn = NULL;
506 binf = "kqbin";
507 nbins = "Nkqbins";
508 } else if (!strcasecmp(curparams.hemis, "cie")) {
509 calfn = ciefn; ciefn = NULL;
510 sprintf(sbuf, "rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1",
511 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
512 curparams.vup[0], curparams.vup[1], curparams.vup[2],
513 curparams.sign);
514 params = savqstr(sbuf);
515 binv = "cbin";
516 nbins = "Ncbins";
517 } else {
518 fprintf(stderr, "%s: unrecognized hemisphere sampling: h=%s\n",
519 progname, curparams.hemis);
520 exit(1);
521 }
522 if (tolower(curparams.hemis[0]) == 'k') {
523 sprintf(sbuf, "RHS=%c1", curparams.sign);
524 params = savqstr(sbuf);
525 }
526 if (!uniform) {
527 SURF *sp;
528 for (sp = curparams.slist; sp != NULL; sp = sp->next)
529 if (sp->styp == ST_SOURCE && fabs(sp->area - PI) > 1e-3) {
530 fprintf(stderr, "%s: source '%s' must be 180-degrees\n",
531 progname, sp->sname);
532 exit(1);
533 }
534 }
535 if (calfn != NULL) { /* add cal file if needed */
536 CHECKARGC(2);
537 rcarg[nrcargs++] = "-f";
538 rcarg[nrcargs++] = calfn;
539 }
540 if (params != NULL) { /* parameters _after_ cal file */
541 CHECKARGC(2);
542 rcarg[nrcargs++] = "-p";
543 rcarg[nrcargs++] = params;
544 }
545 if (nbins != NULL) { /* add #bins if set */
546 CHECKARGC(2);
547 rcarg[nrcargs++] = "-bn";
548 rcarg[nrcargs++] = nbins;
549 }
550 if (binv != NULL) {
551 CHECKARGC(2); /* assign bin variable */
552 rcarg[nrcargs++] = "-b";
553 rcarg[nrcargs++] = binv;
554 } else if (binf != NULL) {
555 CHECKARGC(2); /* assign bin function */
556 rcarg[nrcargs++] = "-b";
557 sprintf(sbuf, "%s(%g,%g,%g,%g,%g,%g)", binf,
558 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
559 curparams.vup[0], curparams.vup[1], curparams.vup[2]);
560 rcarg[nrcargs++] = savqstr(sbuf);
561 }
562 CHECKARGC(2); /* modifier argument goes last */
563 rcarg[nrcargs++] = "-m";
564 rcarg[nrcargs++] = savqstr(curmod);
565 }
566
567 /* Make randomly oriented tangent plane axes for given normal direction */
568 static void
569 make_axes(FVECT uva[2], const FVECT nrm)
570 {
571 int i;
572
573 if (!getperpendicular(uva[0], nrm, 1)) {
574 fputs(progname, stderr);
575 fputs(": bad surface normal in make_axes!\n", stderr);
576 exit(1);
577 }
578 fcross(uva[1], nrm, uva[0]);
579 }
580
581 /* Illegal sender surfaces end up here */
582 static int
583 ssamp_bad(FVECT orig, SURF *sp, double x)
584 {
585 fprintf(stderr, "%s: illegal sender surface '%s'\n",
586 progname, sp->sname);
587 return(0);
588 }
589
590 /* Generate origin on ring surface from uniform random variable */
591 static int
592 ssamp_ring(FVECT orig, SURF *sp, double x)
593 {
594 FVECT *uva = (FVECT *)sp->priv;
595 double samp2[2];
596 double uv[2];
597 int i;
598
599 if (uva == NULL) { /* need tangent axes */
600 uva = (FVECT *)malloc(sizeof(FVECT)*2);
601 if (uva == NULL) {
602 fputs(progname, stderr);
603 fputs(": out of memory in ssamp_ring!\n", stderr);
604 return(0);
605 }
606 make_axes(uva, sp->snrm);
607 sp->priv = (void *)uva;
608 }
609 SDmultiSamp(samp2, 2, x);
610 samp2[0] = sqrt(samp2[0]*sp->area*(1./PI) + sp->farg[6]*sp->farg[6]);
611 samp2[1] *= 2.*PI;
612 uv[0] = samp2[0]*tcos(samp2[1]);
613 uv[1] = samp2[0]*tsin(samp2[1]);
614 for (i = 3; i--; )
615 orig[i] = sp->farg[i] + uv[0]*uva[0][i] + uv[1]*uva[1][i];
616 return(1);
617 }
618
619 /* Add triangle to polygon's list (call-back function) */
620 static int
621 add_triangle(const Vert2_list *tp, int a, int b, int c)
622 {
623 POLYTRIS *ptp = (POLYTRIS *)tp->p;
624 struct ptri *trip = ptp->tri + ptp->ntris++;
625
626 trip->vndx[0] = a;
627 trip->vndx[1] = b;
628 trip->vndx[2] = c;
629 return(1);
630 }
631
632 /* Generate origin on polygon surface from uniform random variable */
633 static int
634 ssamp_poly(FVECT orig, SURF *sp, double x)
635 {
636 POLYTRIS *ptp = (POLYTRIS *)sp->priv;
637 double samp2[2];
638 double *v0, *v1, *v2;
639 int i;
640
641 if (ptp == NULL) { /* need to triangulate */
642 ptp = (POLYTRIS *)malloc(sizeof(POLYTRIS) +
643 sizeof(struct ptri)*(sp->nfargs/3 - 3));
644 if (ptp == NULL)
645 goto memerr;
646 if (sp->nfargs == 3) { /* simple case */
647 ptp->ntris = 1;
648 ptp->tri[0].vndx[0] = 0;
649 ptp->tri[0].vndx[1] = 1;
650 ptp->tri[0].vndx[2] = 2;
651 ptp->tri[0].afrac = 1;
652 } else {
653 Vert2_list *v2l = polyAlloc(sp->nfargs/3);
654 if (v2l == NULL)
655 goto memerr;
656 make_axes(ptp->uva, sp->snrm);
657 for (i = v2l->nv; i--; ) {
658 v2l->v[i].mX = DOT(sp->farg+3*i, ptp->uva[0]);
659 v2l->v[i].mY = DOT(sp->farg+3*i, ptp->uva[1]);
660 }
661 ptp->ntris = 0;
662 v2l->p = (void *)ptp;
663 if (!polyTriangulate(v2l, add_triangle)) {
664 fprintf(stderr,
665 "%s: cannot triangulate polygon '%s'\n",
666 progname, sp->sname);
667 return(0);
668 }
669 for (i = ptp->ntris; i--; ) {
670 int a = ptp->tri[i].vndx[0];
671 int b = ptp->tri[i].vndx[1];
672 int c = ptp->tri[i].vndx[2];
673 ptp->tri[i].afrac =
674 (v2l->v[a].mX*v2l->v[b].mY -
675 v2l->v[b].mX*v2l->v[a].mY +
676 v2l->v[b].mX*v2l->v[c].mY -
677 v2l->v[c].mX*v2l->v[b].mY +
678 v2l->v[c].mX*v2l->v[a].mY -
679 v2l->v[a].mX*v2l->v[c].mY) /
680 (2.*sp->area);
681 }
682 polyFree(v2l);
683 }
684 sp->priv = (void *)ptp;
685 }
686 /* pick triangle by partial area */
687 for (i = 0; i < ptp->ntris-1 && x > ptp->tri[i].afrac; i++)
688 x -= ptp->tri[i].afrac;
689 SDmultiSamp(samp2, 2, x/ptp->tri[i].afrac);
690 samp2[0] *= samp2[1] = sqrt(samp2[1]);
691 samp2[1] = 1. - samp2[1];
692 v0 = sp->farg + 3*ptp->tri[i].vndx[0];
693 v1 = sp->farg + 3*ptp->tri[i].vndx[1];
694 v2 = sp->farg + 3*ptp->tri[i].vndx[2];
695 for (i = 3; i--; )
696 orig[i] = v0[i] + samp2[0]*(v1[i] - v0[i])
697 + samp2[1]*(v2[i] - v0[i]) ;
698 return(1);
699 memerr:
700 fputs(progname, stderr);
701 fputs(": out of memory in ssamp_poly!\n", stderr);
702 return(0);
703 }
704
705 /* Compute sample origin based on projected areas of sender subsurfaces */
706 static int
707 sample_origin(PARAMS *p, FVECT orig, const FVECT rdir, double x)
708 {
709 static double *projsa;
710 static int nall;
711 double tarea = 0;
712 int i;
713 SURF *sp;
714 /* special case for lone surface */
715 if (p->nsurfs == 1) {
716 sp = p->slist;
717 if (DOT(sp->snrm, rdir) >= FTINY) {
718 fprintf(stderr,
719 "%s: internal - sample behind sender '%s'\n",
720 progname, sp->sname);
721 return(0);
722 }
723 return((*orig_in_surf[sp->styp])(orig, sp, x));
724 }
725 if (p->nsurfs > nall) { /* (re)allocate surface area cache */
726 if (projsa) free(projsa);
727 projsa = (double *)malloc(sizeof(double)*p->nsurfs);
728 if (projsa == NULL) {
729 fputs(progname, stderr);
730 fputs(": out of memory in sample_origin!\n", stderr);
731 exit(1);
732 }
733 nall = p->nsurfs;
734 }
735 /* compute projected areas */
736 for (i = 0, sp = p->slist; sp != NULL; i++, sp = sp->next) {
737 projsa[i] = -DOT(sp->snrm, rdir) * sp->area;
738 tarea += projsa[i] *= (double)(projsa[i] > 0);
739 }
740 if (tarea < FTINY*FTINY) { /* wrong side of sender? */
741 fputs(progname, stderr);
742 fputs(": internal - sample behind all sender elements!\n",
743 stderr);
744 return(0);
745 }
746 tarea *= x; /* get surface from list */
747 for (i = 0, sp = p->slist; tarea > projsa[i]; sp = sp->next)
748 tarea -= projsa[i++];
749 return((*orig_in_surf[sp->styp])(orig, sp, tarea/projsa[i]));
750 }
751
752 /* Uniform sample generator */
753 static int
754 sample_uniform(PARAMS *p, int b, FILE *fp)
755 {
756 int n = sampcnt;
757 double samp3[3];
758 FVECT duvw, orig_dir[2];
759 int i;
760
761 if (fp == NULL) /* just requesting number of bins? */
762 return(1);
763
764 while (n--) { /* stratified hemisphere sampling */
765 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
766 square2disk(duvw, samp3[1], samp3[2]);
767 duvw[2] = -sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
768 for (i = 3; i--; )
769 orig_dir[1][i] = duvw[0]*p->udir[i] +
770 duvw[1]*p->vdir[i] +
771 duvw[2]*p->nrm[i] ;
772 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
773 return(0);
774 if (putbinary(orig_dir, sizeof(FVECT), 2, fp) != 2)
775 return(0);
776 }
777 return(1);
778 }
779
780 /* Shirly-Chiu sample generator */
781 static int
782 sample_shirchiu(PARAMS *p, int b, FILE *fp)
783 {
784 int n = sampcnt;
785 double samp3[3];
786 FVECT duvw, orig_dir[2];
787 int i;
788
789 if (fp == NULL) /* just requesting number of bins? */
790 return(p->hsiz*p->hsiz);
791
792 while (n--) { /* stratified sampling */
793 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
794 square2disk(duvw, (b/p->hsiz + samp3[1])/curparams.hsiz,
795 (b%p->hsiz + samp3[2])/curparams.hsiz);
796 duvw[2] = sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
797 for (i = 3; i--; )
798 orig_dir[1][i] = -duvw[0]*p->udir[i] -
799 duvw[1]*p->vdir[i] -
800 duvw[2]*p->nrm[i] ;
801 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
802 return(0);
803 if (putbinary(orig_dir, sizeof(FVECT), 2, fp) != 2)
804 return(0);
805 }
806 return(1);
807 }
808
809 /* Reinhart/Tregenza sample generator */
810 static int
811 sample_reinhart(PARAMS *p, int b, FILE *fp)
812 {
813 #define T_NALT 7
814 static const int tnaz[T_NALT] = {30, 30, 24, 24, 18, 12, 6};
815 const int RowMax = T_NALT*p->hsiz + 1;
816 const double RAH = (.5*PI)/(RowMax-.5);
817 #define rnaz(r) (r >= RowMax-1 ? 1 : p->hsiz*tnaz[r/p->hsiz])
818 int n = sampcnt;
819 int row, col;
820 double samp3[3];
821 double alt, azi;
822 double duvw[3];
823 FVECT orig_dir[2];
824 int i;
825
826 if (fp == NULL) { /* just requesting number of bins? */
827 n = 0;
828 for (row = RowMax; row--; ) n += rnaz(row);
829 return(n);
830 }
831 row = 0; /* identify row & column */
832 col = b;
833 while (col >= rnaz(row)) {
834 col -= rnaz(row);
835 ++row;
836 }
837 while (n--) { /* stratified sampling */
838 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
839 if (row >= RowMax-1) /* avoid crowding at zenith */
840 samp3[1] *= samp3[1];
841 alt = (row+samp3[1])*RAH;
842 azi = (2.*PI)*(col+samp3[2]-.5)/rnaz(row);
843 duvw[2] = cos(alt); /* measured from horizon */
844 duvw[0] = tsin(azi)*duvw[2];
845 duvw[1] = -tcos(azi)*duvw[2];
846 duvw[2] = sqrt(1. - duvw[2]*duvw[2]);
847 for (i = 3; i--; )
848 orig_dir[1][i] = -duvw[0]*p->udir[i] -
849 duvw[1]*p->vdir[i] -
850 duvw[2]*p->nrm[i] ;
851 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
852 return(0);
853 if (putbinary(orig_dir, sizeof(FVECT), 2, fp) != 2)
854 return(0);
855 }
856 return(1);
857 #undef rnaz
858 #undef T_NALT
859 }
860
861 /* Klems sample generator */
862 static int
863 sample_klems(PARAMS *p, int b, FILE *fp)
864 {
865 static const char bname[4][20] = {
866 "LBNL/Klems Full",
867 "LBNL/Klems Half",
868 "INTERNAL ERROR",
869 "LBNL/Klems Quarter"
870 };
871 static ANGLE_BASIS *kbasis[4];
872 const int bi = p->hemis[1] - '1';
873 int n = sampcnt;
874 double samp2[2];
875 double duvw[3];
876 FVECT orig_dir[2];
877 int i;
878
879 if (!kbasis[bi]) { /* need to get basis, first */
880 for (i = 4; i--; )
881 if (!strcasecmp(abase_list[i].name, bname[bi])) {
882 kbasis[bi] = &abase_list[i];
883 break;
884 }
885 if (i < 0) {
886 fprintf(stderr, "%s: unknown hemisphere basis '%s'\n",
887 progname, bname[bi]);
888 return(0);
889 }
890 }
891 if (fp == NULL) /* just requesting number of bins? */
892 return(kbasis[bi]->nangles);
893
894 while (n--) { /* stratified sampling */
895 SDmultiSamp(samp2, 2, (n+frandom())/sampcnt);
896 if (!fo_getvec(duvw, b+samp2[1], kbasis[bi]))
897 return(0);
898 for (i = 3; i--; )
899 orig_dir[1][i] = -duvw[0]*p->udir[i] -
900 duvw[1]*p->vdir[i] -
901 duvw[2]*p->nrm[i] ;
902 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp2[0]))
903 return(0);
904 if (putbinary(orig_dir, sizeof(FVECT), 2, fp) != 2)
905 return(0);
906 }
907 return(1);
908 }
909
910 /* Prepare hemisphere basis sampler that will send rays to rcontrib */
911 static int
912 prepare_sampler(PARAMS *p)
913 {
914 if (p->slist == NULL) { /* missing sample surface! */
915 fputs(progname, stderr);
916 fputs(": no sender surface!\n", stderr);
917 return(-1);
918 }
919 /* misplaced output file spec. */
920 if ((p->outfn != NULL) & !(verbose & NOWARN))
921 fprintf(stderr, "%s: warning - ignoring output file in sender ('%s')\n",
922 progname, p->outfn);
923 /* check/set basis hemisphere */
924 if (!p->hemis[0]) {
925 fputs(progname, stderr);
926 fputs(": missing sender sampling type!\n", stderr);
927 return(-1);
928 }
929 if (normalize(p->nrm) == 0) {
930 fputs(progname, stderr);
931 fputs(": undefined normal for sender sampling\n", stderr);
932 return(-1);
933 }
934 if (normalize(p->vup) == 0) {
935 if (fabs(p->nrm[2]) < .7)
936 p->vup[2] = 1;
937 else
938 p->vup[1] = 1;
939 }
940 fcross(p->udir, p->vup, p->nrm);
941 if (normalize(p->udir) == 0) {
942 fputs(progname, stderr);
943 fputs(": up vector coincides with sender normal\n", stderr);
944 return(-1);
945 }
946 fcross(p->vdir, p->nrm, p->udir);
947 if (p->sign == '-') { /* left-handed coordinate system? */
948 p->udir[0] *= -1.;
949 p->udir[1] *= -1.;
950 p->udir[2] *= -1.;
951 }
952 if ((tolower(p->hemis[0]) == 'u') | (p->hemis[0] == '1'))
953 p->sample_basis = sample_uniform;
954 else if (tolower(p->hemis[0]) == 's' &&
955 tolower(p->hemis[1]) == 'c')
956 p->sample_basis = sample_shirchiu;
957 else if ((tolower(p->hemis[0]) == 'r') |
958 (tolower(p->hemis[0]) == 't'))
959 p->sample_basis = sample_reinhart;
960 else if (tolower(p->hemis[0]) == 'k') {
961 switch (p->hemis[1]) {
962 case '1':
963 case '2':
964 case '4':
965 break;
966 case 'f':
967 case 'F':
968 case '\0':
969 p->hemis[1] = '1';
970 break;
971 case 'h':
972 case 'H':
973 p->hemis[1] = '2';
974 break;
975 case 'q':
976 case 'Q':
977 p->hemis[1] = '4';
978 break;
979 default:
980 goto unrecognized;
981 }
982 p->hemis[2] = '\0';
983 p->sample_basis = sample_klems;
984 } else
985 goto unrecognized;
986 /* return number of bins */
987 return((*p->sample_basis)(p,0,NULL));
988 unrecognized:
989 fprintf(stderr, "%s: unrecognized sender sampling: h=%s\n",
990 progname, p->hemis);
991 return(-1);
992 }
993
994 /* Compute normal and area for polygon */
995 static int
996 finish_polygon(SURF *p)
997 {
998 const int nv = p->nfargs / 3;
999 FVECT e1, e2, vc;
1000 int i;
1001
1002 memset(p->snrm, 0, sizeof(FVECT));
1003 VSUB(e1, p->farg+3, p->farg);
1004 for (i = 2; i < nv; i++) {
1005 VSUB(e2, p->farg+3*i, p->farg);
1006 VCROSS(vc, e1, e2);
1007 p->snrm[0] += vc[0];
1008 p->snrm[1] += vc[1];
1009 p->snrm[2] += vc[2];
1010 VCOPY(e1, e2);
1011 }
1012 p->area = normalize(p->snrm)*0.5;
1013 return(p->area > FTINY*FTINY);
1014 }
1015
1016 /* Add a surface to our current parameters */
1017 static void
1018 add_surface(int st, const char *oname, FILE *fp)
1019 {
1020 SURF *snew;
1021 int n;
1022 /* get floating-point arguments */
1023 if (!fscanf(fp, "%d", &n)) return;
1024 while (n-- > 0) fscanf(fp, "%*s");
1025 if (!fscanf(fp, "%d", &n)) return;
1026 while (n-- > 0) fscanf(fp, "%*d");
1027 if (!fscanf(fp, "%d", &n) || n <= 0) return;
1028 snew = (SURF *)malloc(sizeof(SURF) + sizeof(double)*(n-1));
1029 if (snew == NULL) {
1030 fputs(progname, stderr);
1031 fputs(": out of memory in add_surface!\n", stderr);
1032 exit(1);
1033 }
1034 strncpy(snew->sname, oname, sizeof(snew->sname)-1);
1035 snew->sname[sizeof(snew->sname)-1] = '\0';
1036 snew->styp = st;
1037 snew->priv = NULL;
1038 snew->nfargs = n;
1039 for (n = 0; n < snew->nfargs; n++)
1040 if (fscanf(fp, "%lf", &snew->farg[n]) != 1) {
1041 fprintf(stderr, "%s: error reading arguments for '%s'\n",
1042 progname, oname);
1043 exit(1);
1044 }
1045 switch (st) {
1046 case ST_RING:
1047 if (snew->nfargs != 8)
1048 goto badcount;
1049 VCOPY(snew->snrm, snew->farg+3);
1050 if (normalize(snew->snrm) == 0)
1051 goto badnorm;
1052 if (snew->farg[7] < snew->farg[6]) {
1053 double t = snew->farg[7];
1054 snew->farg[7] = snew->farg[6];
1055 snew->farg[6] = t;
1056 }
1057 snew->area = PI*(snew->farg[7]*snew->farg[7] -
1058 snew->farg[6]*snew->farg[6]);
1059 break;
1060 case ST_POLY:
1061 if (snew->nfargs < 9 || snew->nfargs % 3)
1062 goto badcount;
1063 finish_polygon(snew);
1064 break;
1065 case ST_SOURCE:
1066 if (snew->nfargs != 4)
1067 goto badcount;
1068 for (n = 3; n--; ) /* need to reverse "normal" */
1069 snew->snrm[n] = -snew->farg[n];
1070 if (normalize(snew->snrm) == 0)
1071 goto badnorm;
1072 snew->area = sin((PI/180./2.)*snew->farg[3]);
1073 snew->area *= PI*snew->area;
1074 break;
1075 }
1076 if ((snew->area <= FTINY*FTINY) & !(verbose & NOWARN)) {
1077 fprintf(stderr, "%s: warning - zero area for surface '%s'\n",
1078 progname, oname);
1079 free(snew);
1080 return;
1081 }
1082 VSUM(curparams.nrm, curparams.nrm, snew->snrm, snew->area);
1083 snew->next = curparams.slist;
1084 curparams.slist = snew;
1085 curparams.nsurfs++;
1086 return;
1087 badcount:
1088 fprintf(stderr, "%s: bad argument count for surface element '%s'\n",
1089 progname, oname);
1090 exit(1);
1091 badnorm:
1092 fprintf(stderr, "%s: bad orientation for surface element '%s'\n",
1093 progname, oname);
1094 exit(1);
1095 }
1096
1097 /* Parse a receiver object (look for modifiers to add to rcontrib command) */
1098 static int
1099 add_recv_object(FILE *fp)
1100 {
1101 int st;
1102 char thismod[128], otype[32], oname[128];
1103 int n;
1104
1105 if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3)
1106 return(0); /* must have hit EOF! */
1107 if (!strcmp(otype, "alias")) {
1108 fscanf(fp, "%*s"); /* skip alias */
1109 return(0);
1110 }
1111 /* is it a new receiver? */
1112 if ((st = surf_type(otype)) != ST_NONE) {
1113 if (strcmp(thismod, curmod)) {
1114 if (curmod[0]) { /* output last receiver? */
1115 finish_receiver();
1116 clear_params(&curparams, 1);
1117 }
1118 parse_params(&curparams, newparams);
1119 newparams[0] = '\0';
1120 strcpy(curmod, thismod);
1121 }
1122 add_surface(st, oname, fp); /* read & store surface */
1123 return(1);
1124 }
1125 /* else skip arguments */
1126 if (!fscanf(fp, "%d", &n)) return(0);
1127 while (n-- > 0) fscanf(fp, "%*s");
1128 if (!fscanf(fp, "%d", &n)) return(0);
1129 while (n-- > 0) fscanf(fp, "%*d");
1130 if (!fscanf(fp, "%d", &n)) return(0);
1131 while (n-- > 0) fscanf(fp, "%*f");
1132 return(0);
1133 }
1134
1135 /* Parse a sender object */
1136 static int
1137 add_send_object(FILE *fp)
1138 {
1139 int st;
1140 char thismod[128], otype[32], oname[128];
1141 int n;
1142
1143 if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3)
1144 return(0); /* must have hit EOF! */
1145 if (!strcmp(otype, "alias")) {
1146 fscanf(fp, "%*s"); /* skip alias */
1147 return(0);
1148 }
1149 /* is it a new surface? */
1150 if ((st = surf_type(otype)) != ST_NONE) {
1151 if (st == ST_SOURCE) {
1152 fputs(progname, stderr);
1153 fputs(": cannot use source as a sender!\n", stderr);
1154 return(-1);
1155 }
1156 if (strcmp(thismod, curmod)) {
1157 if (curmod[0]) {
1158 fputs(progname, stderr);
1159 fputs(": warning - multiple modifiers in sender\n",
1160 stderr);
1161 }
1162 strcpy(curmod, thismod);
1163 }
1164 parse_params(&curparams, newparams);
1165 newparams[0] = '\0';
1166 add_surface(st, oname, fp); /* read & store surface */
1167 return(0);
1168 }
1169 /* else skip arguments */
1170 if (!fscanf(fp, "%d", &n)) return(0);
1171 while (n-- > 0) fscanf(fp, "%*s");
1172 if (!fscanf(fp, "%d", &n)) return(0);
1173 while (n-- > 0) fscanf(fp, "%*d");
1174 if (!fscanf(fp, "%d", &n)) return(0);
1175 while (n-- > 0) fscanf(fp, "%*f");
1176 return(0);
1177 }
1178
1179 /* Load a Radiance scene using the given callback function for objects */
1180 static int
1181 load_scene(const char *inspec, int (*ocb)(FILE *))
1182 {
1183 int rv = 0;
1184 char inpbuf[1024];
1185 FILE *fp;
1186 int c;
1187
1188 if (*inspec == '!')
1189 fp = popen(inspec+1, "r");
1190 else
1191 fp = fopen(inspec, "r");
1192 if (fp == NULL) {
1193 fprintf(stderr, "%s: cannot load '%s'\n", progname, inspec);
1194 return(-1);
1195 }
1196 while ((c = getc(fp)) != EOF) { /* load receiver data */
1197 if (isspace(c)) /* skip leading white space */
1198 continue;
1199 if (c == '!') { /* read from a new command */
1200 inpbuf[0] = c;
1201 if (fgetline(inpbuf+1, sizeof(inpbuf)-1, fp) != NULL) {
1202 if ((c = load_scene(inpbuf, ocb)) < 0)
1203 return(c);
1204 rv += c;
1205 }
1206 continue;
1207 }
1208 if (c == '#') { /* parameters/comment */
1209 if ((c = getc(fp)) == EOF || ungetc(c,fp) == EOF)
1210 break;
1211 if (!isspace(c) && fscanf(fp, "%s", inpbuf) == 1 &&
1212 !strcmp(inpbuf, PARAMSTART)) {
1213 if (fgets(inpbuf, sizeof(inpbuf), fp) != NULL)
1214 strcat(newparams, inpbuf);
1215 continue;
1216 }
1217 while ((c = getc(fp)) != EOF && c != '\n')
1218 ; /* else skipping comment */
1219 continue;
1220 }
1221 ungetc(c, fp); /* else check object for receiver */
1222 c = (*ocb)(fp);
1223 if (c < 0)
1224 return(c);
1225 rv += c;
1226 }
1227 /* close our input stream */
1228 c = (*inspec == '!') ? pclose(fp) : fclose(fp);
1229 if (c != 0) {
1230 fprintf(stderr, "%s: error loading '%s'\n", progname, inspec);
1231 return(-1);
1232 }
1233 return(rv);
1234 }
1235
1236 /* Get command arguments and run program */
1237 int
1238 main(int argc, char *argv[])
1239 {
1240 char fmtopt[6] = "-faa"; /* default output is ASCII */
1241 char *xrs=NULL, *yrs=NULL, *ldopt=NULL;
1242 char *iropt = NULL;
1243 char *sendfn;
1244 char sampcntbuf[32], nsbinbuf[32];
1245 FILE *rcfp;
1246 int nsbins;
1247 int a, i;
1248 /* set global progname */
1249 fixargv0(argv[0]);
1250 /* screen rcontrib options */
1251 for (a = 1; a < argc-2; a++) {
1252 int na;
1253 /* check for argument expansion */
1254 while ((na = expandarg(&argc, &argv, a)) > 0)
1255 ;
1256 if (na < 0) {
1257 fprintf(stderr, "%s: cannot expand '%s'\n",
1258 progname, argv[a]);
1259 return(1);
1260 }
1261 if (argv[a][0] != '-' || !argv[a][1])
1262 break;
1263 na = 1;
1264 switch (argv[a][1]) { /* !! Keep consistent !! */
1265 case 'v': /* verbose mode */
1266 verbose ^= VERBO;
1267 na = 0;
1268 continue;
1269 case 'f': /* special case for -fo, -ff, etc. */
1270 switch (argv[a][2]) {
1271 case '\0': /* cal file */
1272 na = 2;
1273 break;
1274 case 'o': /* force output */
1275 goto userr;
1276 case 'a': /* output format */
1277 case 'f':
1278 case 'd':
1279 case 'c':
1280 if (!(fmtopt[3] = argv[a][3]))
1281 fmtopt[3] = argv[a][2];
1282 fmtopt[2] = argv[a][2];
1283 na = 0;
1284 continue; /* will pass later */
1285 default:
1286 goto userr;
1287 }
1288 break;
1289 case 'x': /* x-resolution */
1290 xrs = argv[++a];
1291 na = 0;
1292 continue;
1293 case 'y': /* y-resolution */
1294 yrs = argv[++a];
1295 na = 0;
1296 continue;
1297 case 'c': /* spectral sampling or count */
1298 switch (argv[a][2]) {
1299 case 's':
1300 na = 2;
1301 break;
1302 case 'w':
1303 na = 3;
1304 break;
1305 case '\0':
1306 sampcnt = atoi(argv[++a]);
1307 if (sampcnt <= 0)
1308 goto userr;
1309 na = 0; /* we re-add this later */
1310 continue;
1311 }
1312 break;
1313 case 'I': /* only for pass-through mode */
1314 case 'i':
1315 iropt = argv[a];
1316 na = 0;
1317 continue;
1318 case 'w': /* options without arguments */
1319 if (!argv[a][2])
1320 verbose ^= NOWARN;
1321 else if (strchr("+1tTyY", argv[a][2]) != NULL)
1322 verbose &= ~NOWARN;
1323 else
1324 verbose |= NOWARN;
1325 break;
1326 case 'V':
1327 case 'u':
1328 case 'h':
1329 case 'r':
1330 break;
1331 case 'n': /* options with 1 argument */
1332 case 's':
1333 case 'o':
1334 case 't':
1335 case 'e':
1336 na = 2;
1337 break;
1338 case 'b': /* special case */
1339 if (argv[a][2] != 'v') goto userr;
1340 break;
1341 case 'l': /* special case */
1342 if (argv[a][2] == 'd') {
1343 ldopt = argv[a];
1344 na = 0;
1345 continue;
1346 }
1347 na = 2;
1348 break;
1349 case 'd': /* special case */
1350 if (argv[a][2] != 'v') na = 2;
1351 break;
1352 case 'a': /* special case */
1353 if (argv[a][2] == 'p') {
1354 na = 2; /* photon map [+ bandwidth(s)] */
1355 if (a < argc-3 && atoi(argv[a+1]) > 0)
1356 na += 1 + (a < argc-4 && atoi(argv[a+2]) > 0);
1357 } else
1358 na = (argv[a][2] == 'v') ? 4 : 2;
1359 break;
1360 case 'm': /* special case */
1361 if (!argv[a][2]) goto userr;
1362 na = (argv[a][2] == 'e') | (argv[a][2] == 'a') ? 4 : 2;
1363 break;
1364 default: /* anything else is verbotten */
1365 goto userr;
1366 }
1367 if (na <= 0) continue;
1368 CHECKARGC(na); /* pass on option */
1369 rcarg[nrcargs++] = argv[a];
1370 while (--na) /* + arguments if any */
1371 rcarg[nrcargs++] = argv[++a];
1372 }
1373 if (a > argc-2)
1374 goto userr; /* check at end of options */
1375 sendfn = argv[a++]; /* assign sender & receiver inputs */
1376 if (sendfn[0] == '-') { /* user wants pass-through mode? */
1377 if (sendfn[1]) goto userr;
1378 sendfn = NULL;
1379 if (iropt) {
1380 CHECKARGC(1);
1381 rcarg[nrcargs++] = iropt;
1382 }
1383 if (xrs) {
1384 CHECKARGC(2);
1385 rcarg[nrcargs++] = "-x";
1386 rcarg[nrcargs++] = xrs;
1387 }
1388 if (yrs) {
1389 CHECKARGC(2);
1390 rcarg[nrcargs++] = "-y";
1391 rcarg[nrcargs++] = yrs;
1392 }
1393 if (ldopt) {
1394 CHECKARGC(1);
1395 rcarg[nrcargs++] = ldopt;
1396 }
1397 if (sampcnt <= 0) sampcnt = 1;
1398 } else { /* else in sampling mode */
1399 if (iropt) {
1400 fputs(progname, stderr);
1401 fputs(": -i, -I supported for pass-through only\n", stderr);
1402 return(1);
1403 }
1404 #ifdef SMLFLT
1405 fmtopt[2] = 'f';
1406 #else
1407 fmtopt[2] = 'd';
1408 #endif
1409 if (sampcnt <= 0) sampcnt = 10000;
1410 }
1411 sprintf(sampcntbuf, "%d", sampcnt);
1412 CHECKARGC(3); /* add our format & sample count */
1413 rcarg[nrcargs++] = fmtopt;
1414 rcarg[nrcargs++] = "-c";
1415 rcarg[nrcargs++] = sampcntbuf;
1416 /* add receiver arguments to rcontrib */
1417 if (load_scene(argv[a], add_recv_object) < 0)
1418 return(1);
1419 finish_receiver();
1420 if (sendfn == NULL) { /* pass-through mode? */
1421 CHECKARGC(1); /* add octree */
1422 rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1423 rcarg[nrcargs] = NULL;
1424 return(my_exec(rcarg)); /* rcontrib does everything */
1425 }
1426 clear_params(&curparams, 0); /* else load sender surface & params */
1427 curmod[0] = '\0';
1428 if (load_scene(sendfn, add_send_object) < 0)
1429 return(1);
1430 if ((nsbins = prepare_sampler(&curparams)) <= 0)
1431 return(1);
1432 CHECKARGC(3); /* add row count and octree */
1433 rcarg[nrcargs++] = "-y";
1434 sprintf(nsbinbuf, "%d", nsbins);
1435 rcarg[nrcargs++] = nsbinbuf;
1436 rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1437 rcarg[nrcargs] = NULL;
1438 /* open pipe to rcontrib process */
1439 if ((rcfp = popen_arglist(rcarg, "w")) == NULL)
1440 return(1);
1441 SET_FILE_BINARY(rcfp);
1442 #ifdef getc_unlocked
1443 flockfile(rcfp);
1444 #endif
1445 if (verbose & VERBO) {
1446 fprintf(stderr, "%s: sampling %d directions", progname, nsbins);
1447 if (curparams.nsurfs > 1)
1448 fprintf(stderr, " (%d elements)\n", curparams.nsurfs);
1449 else
1450 fputc('\n', stderr);
1451 }
1452 for (i = 0; i < nsbins; i++) /* send rcontrib ray samples */
1453 if (!(*curparams.sample_basis)(&curparams, i, rcfp))
1454 return(1);
1455 return(pclose_al(rcfp) < 0); /* all finished! */
1456 userr:
1457 if (a < argc-2)
1458 fprintf(stderr, "%s: unsupported option '%s'\n", progname, argv[a]);
1459 fprintf(stderr, "Usage: %s [-v][rcontrib options] sender.rad receiver.rad [-i system.oct] [system.rad ..]\n",
1460 progname);
1461 return(1);
1462 }
