root/radiance/ray/src/util/rfluxmtx.c
Revision: 2.4
Committed: Tue Jul 22 21:55:31 2014 UTC (9 years, 9 months ago) by greg
Changes since 2.3: +47 -6 lines
2 static const char RCSid[] = "$Id: rfluxmtx.c,v 2.3 2014/07/22 02:12:48 greg Exp $";
5 * Calculate flux transfer matrix or matrices using rcontrib
6 */
7
8 #include "copyright.h"
9
10 #include <ctype.h>
11 #include <stdlib.h>
12 #include "rtio.h"
13 #include "rtmath.h"
14 #include "bsdf.h"
15 #include "bsdf_m.h"
16 #include "random.h"
17 #include "triangulate.h"
18 #include "platform.h"
19
20 #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
21 #undef getc
22 #define getc getc_unlocked
23 #endif
24
25 #ifdef _WIN32
26 #define SPECIALS " \t\"$*?"
27 #define QUOTCHAR '"'
28 #else
29 #define SPECIALS " \t\n'\"()${}*?[];|&"
30 #define QUOTCHAR '\''
31 #define ALTQUOT '"'
32 #endif
33
34 #define MAXRCARG 512
35
36 char *progname; /* global argv[0] */
37
38 int verbose = 0; /* verbose mode? */
39
40 char *rcarg[MAXRCARG+1] = {"rcontrib", "-fo+"};
41 int nrcargs = 2;
42
43 const char overflowerr[] = "%s: too many arguments!\n";
44
45 #define CHECKARGC(n) if (nrcargs >= MAXRCARG-(n)) \
46 { fprintf(stderr, overflowerr, progname); exit(1); }
47
48 int sampcnt = 0; /* sample count (0==unset) */
49
50 char *reinhfn = "reinhartb.cal";
51 char *shirchiufn = "disk2square.cal";
52 char *kfullfn = "klems_full.cal";
53 char *khalffn = "klems_half.cal";
54 char *kquarterfn = "klems_quarter.cal";
55
56 #define PARAMSTART "@rfluxmtx" /* string indicating parameters */
57
58 /* surface type IDs */
59 #define ST_NONE 0
60 #define ST_POLY 1
61 #define ST_RING 2
62 #define ST_SOURCE 3
63
64 typedef struct surf_s {
65 struct surf_s *next; /* next surface in list */
66 void *priv; /* private data (malloc'ed) */
67 char sname[32]; /* surface name */
68 FVECT snrm; /* surface normal */
69 double area; /* surface area / proj. solid angle */
70 short styp; /* surface type */
71 short nfargs; /* number of real arguments */
72 double farg[1]; /* real values (extends struct) */
73 } SURF; /* surface structure */
74
75 typedef struct {
76 FVECT uva[2]; /* tangent axes */
77 int ntris; /* number of triangles */
78 struct ptri {
79 float afrac; /* fraction of total area */
80 short vndx[3]; /* vertex indices */
81 } tri[1]; /* triangle array (extends struct) */
82 } POLYTRIS; /* triangulated polygon */
83
84 typedef struct param_s {
85 char hemis[32]; /* hemispherical sampling spec. */
86 int hsiz; /* hemisphere basis size */
87 int nsurfs; /* number of surfaces */
88 SURF *slist; /* list of surfaces */
89 FVECT vup; /* up vector (zero if unset) */
90 FVECT nrm; /* average normal direction */
91 FVECT udir, vdir; /* v-up tangent axes */
92 char *outfn; /* output file name (receiver) */
93 int (*sample_basis)(struct param_s *p, int, FILE *);
94 } PARAMS; /* sender/receiver parameters */
95
96 PARAMS curparams;
97 char curmod[128];
98
99 typedef int SURFSAMP(FVECT, SURF *, double);
100
101 static SURFSAMP ssamp_bad, ssamp_poly, ssamp_ring;
102
103 SURFSAMP *orig_in_surf[4] = {
104 ssamp_bad, ssamp_poly, ssamp_ring, ssamp_bad
105 };
106
107 /* Clear parameter set */
108 static void
109 clear_params(PARAMS *p, int reset_only)
110 {
111 curmod[0] = '\0';
112 while (p->slist != NULL) {
113 SURF *sdel = p->slist;
114 p->slist = sdel->next;
115 if (sdel->priv != NULL)
116 free(sdel->priv);
117 free(sdel);
118 }
119 if (reset_only) {
120 p->nsurfs = 0;
121 memset(p->nrm, 0, sizeof(FVECT));
122 memset(p->vup, 0, sizeof(FVECT));
123 p->outfn = NULL;
124 return;
125 }
126 memset(p, 0, sizeof(curparams));
127 }
128
129 /* Get surface type from name */
130 static int
131 surf_type(const char *otype)
132 {
133 if (!strcmp(otype, "polygon"))
134 return(ST_POLY);
135 if (!strcmp(otype, "ring"))
136 return(ST_RING);
137 if (!strcmp(otype, "source"))
138 return(ST_SOURCE);
139 return(ST_NONE);
140 }
141
142 /* Add arguments to oconv command */
143 static char *
144 oconv_command(int ac, char *av[])
145 {
146 static char oconvbuf[2048] = "!oconv -f";
147 char *cp = oconvbuf + 9;
148
149 while (ac-- > 0) {
150 if (cp >= oconvbuf+(sizeof(oconvbuf)-32)) {
151 fputs(progname, stderr);
152 fputs(": too many file arguments!\n", stderr);
153 exit(1);
154 }
155 *cp++ = ' ';
156 strcpy(cp, *av++);
157 while (*cp) cp++;
158 }
159 *cp = '\0';
160 return(oconvbuf);
161 }
162
163 /* Check if any of the characters in str2 are found in str1 */
164 static int
165 matchany(const char *str1, const char *str2)
166 {
167 while (*str1) {
168 const char *cp = str2;
169 while (*cp)
170 if (*cp++ == *str1)
171 return(*str1);
172 ++str1;
173 }
174 return(0);
175 }
176
177
178 /* Convert a set of arguments into a command line for pipe() or system() */
179 static char *
180 convert_commandline(char *cmd, const int len, char *av[])
181 {
182 int match;
183 char *cp;
184
185 for (cp = cmd; *av != NULL; av++) {
186 const int n = strlen(*av);
187 if (cp+n >= cmd+(len-3)) {
188 fputs(progname, stderr);
189 return(NULL);
190 }
191 if ((match = matchany(*av, SPECIALS))) {
192 const int quote =
193 #ifdef ALTQUOT
194 (match == QUOTCHAR) ? ALTQUOT :
195 #endif
196 QUOTCHAR;
197 *cp++ = quote;
198 strcpy(cp, *av);
199 cp += n;
200 *cp++ = quote;
201 } else {
202 strcpy(cp, *av);
203 cp += n;
204 }
205 *cp++ = ' ';
206 }
207 if (cp <= cmd)
208 return(NULL);
209 *--cp = '\0';
210 return(cmd);
211 }
212
213 /* Open a pipe to/from a command given as an argument list */
214 static FILE *
215 popen_arglist(char *av[], char *mode)
216 {
217 char cmd[10240];
218
219 if (!convert_commandline(cmd, sizeof(cmd), av)) {
220 fputs(progname, stderr);
221 fputs(": command line too long in popen_arglist()\n", stderr);
222 return(NULL);
223 }
224 if (verbose)
225 fprintf(stderr, "%s: opening pipe %s: %s\n",
226 progname, (*mode=='w') ? "to" : "from", cmd);
227 return(popen(cmd, mode));
228 }
229
230 #ifdef _WIN32
231 /* Execute system command (Windows version) */
232 static int
233 my_exec(char *av[])
234 {
235 char cmd[10240];
236
237 if (!convert_commandline(cmd, sizeof(cmd), av)) {
238 fputs(progname, stderr);
239 fputs(": command line too long in my_exec()\n", stderr);
240 return(1);
241 }
242 if (verbose)
243 fprintf(stderr, "%s: running: %s\n", progname, cmd);
244 return(system(cmd));
245 }
246 #else
247 /* Execute system command in our stead (Unix version) */
248 static int
249 my_exec(char *av[])
250 {
251 char *compath;
252
253 if ((compath = getpath((char *)av[0], getenv("PATH"), X_OK)) == NULL) {
254 fprintf(stderr, "%s: cannot locate %s\n", progname, av[0]);
255 return(1);
256 }
257 if (verbose) {
258 char cmd[4096];
259 if (!convert_commandline(cmd, sizeof(cmd), av))
260 strcpy(cmd, "COMMAND TOO LONG TO SHOW");
261 fprintf(stderr, "%s: running: %s\n", progname, cmd);
262 }
263 execv(compath, av); /* successful call never returns */
264 perror(compath);
265 return(1);
266 }
267 #endif
268
269 /* Get normalized direction vector from string specification */
270 static int
271 get_direction(FVECT dv, const char *s)
272 {
273 int sign = 1;
274 int axis = 0;
275
276 memset(dv, 0, sizeof(FVECT));
277 nextchar:
278 switch (*s) {
279 case '+':
280 ++s;
281 goto nextchar;
282 case '-':
283 sign = -sign;
284 ++s;
285 goto nextchar;
286 case 'z':
287 case 'Z':
288 ++axis;
289 case 'y':
290 case 'Y':
291 ++axis;
292 case 'x':
293 case 'X':
294 dv[axis] = sign;
295 return(!s[1] | isspace(s[1]));
296 default:
297 break;
298 }
299 #ifdef SMLFLT
300 if (sscanf(s, "%f,%f,%f", &dv[0], &dv[1], &dv[2]) != 3)
301 #else
302 if (sscanf(s, "%lf,%lf,%lf", &dv[0], &dv[1], &dv[2]) != 3)
303 #endif
304 return(0);
305 dv[0] *= (RREAL)sign;
306 return(normalize(dv) > 0);
307 }
308
309 /* Parse program parameters (directives) */
310 static int
311 parse_params(char *pargs)
312 {
313 char *cp = pargs;
314 int nparams = 0;
315 int i;
316
317 for ( ; ; )
318 switch (*cp++) {
319 case 'h':
320 if (*cp++ != '=')
321 break;
322 curparams.hsiz = 0;
323 i = 0;
324 while (*cp && !isspace(*cp)) {
325 if (isdigit(*cp))
326 curparams.hsiz = 10*curparams.hsiz +
327 *cp - '0';
328 curparams.hemis[i++] = *cp++;
329 }
330 if (!i)
331 break;
332 curparams.hemis[i] = '\0';
333 curparams.hsiz += !curparams.hsiz;
334 ++nparams;
335 continue;
336 case 'u':
337 if (*cp++ != '=')
338 break;
339 if (!get_direction(curparams.vup, cp))
340 break;
341 ++nparams;
342 continue;
343 case 'o':
344 if (*cp++ != '=')
345 break;
346 i = 0;
347 while (*cp && !isspace(*cp++))
348 i++;
349 if (!i)
350 break;
351 *--cp = '\0';
352 curparams.outfn = savqstr(cp-i);
353 *cp++ = ' ';
354 ++nparams;
355 continue;
356 case ' ':
357 case '\t':
358 case '\r':
359 case '\n':
360 continue;
361 case '\0':
362 return(nparams);
363 default:
364 break;
365 }
366 fprintf(stderr, "%s: bad parameter string '%s'\n", progname, pargs);
367 exit(1);
368 return(-1); /* pro forma return */
369 }
370
371 /* Add receiver arguments (directives) corresponding to the current modifier */
372 static void
373 finish_receiver(void)
374 {
375 char sbuf[256];
376 int uniform = 0;
377 char *calfn = NULL;
378 char *params = NULL;
379 char *binv = NULL;
380 char *binf = NULL;
381 char *nbins = NULL;
382
383 if (!curmod[0]) {
384 fputs(progname, stderr);
385 fputs(": missing receiver surface!\n", stderr);
386 exit(1);
387 }
388 if (curparams.outfn != NULL) { /* add output file spec. */
389 CHECKARGC(2);
390 rcarg[nrcargs++] = "-o";
391 rcarg[nrcargs++] = curparams.outfn;
392 }
393 /* check arguments */
394 if (!curparams.hemis[0]) {
395 fputs(progname, stderr);
396 fputs(": missing hemisphere sampling type!\n", stderr);
397 exit(1);
398 }
399 if (normalize(curparams.nrm) == 0) {
400 fputs(progname, stderr);
401 fputs(": undefined normal for hemisphere sampling\n", stderr);
402 exit(1);
403 }
404 if (normalize(curparams.vup) == 0)
405 if (fabs(curparams.nrm[2]) < .7)
406 curparams.vup[2] = 1;
407 else
408 curparams.vup[1] = 1;
409 /* determine sample type/bin */
410 if (tolower(curparams.hemis[0]) == 'u' | curparams.hemis[0] == '1') {
411 binv = "0"; /* uniform sampling -- one bin */
412 uniform = 1;
413 } else if (tolower(curparams.hemis[0]) == 's' &&
414 tolower(curparams.hemis[1]) == 'c') {
415 /* assign parameters */
416 if (curparams.hsiz <= 1) {
417 fputs(progname, stderr);
418 fputs(": missing size for Shirley-Chiu sampling!\n", stderr);
419 exit(1);
420 }
421 calfn = shirchiufn; shirchiufn = NULL;
422 sprintf(sbuf, "SCdim=%d,Nx=%g,Ny=%g,Nz=%g,Ux=%g,Uy=%g,Uz=%g",
423 curparams.hsiz,
424 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
425 curparams.vup[0], curparams.vup[1], curparams.vup[2]);
426 params = savqstr(sbuf);
427 binv = "scbin";
428 nbins = "SCdim*SCdim";
429 } else if ((tolower(curparams.hemis[0]) == 'r') |
430 (tolower(curparams.hemis[0]) == 't')) {
431 calfn = reinhfn; reinhfn = NULL;
432 sprintf(sbuf, "MF=%d,Nx=%g,Ny=%g,Nz=%g,Ux=%g,Uy=%g,Uz=%g",
433 curparams.hsiz,
434 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
435 curparams.vup[0], curparams.vup[1], curparams.vup[2]);
436 params = savqstr(sbuf);
437 binv = "rbin";
438 nbins = "Nrbins";
439 } else if (tolower(curparams.hemis[0]) == 'k' &&
440 !curparams.hemis[1] |
441 (tolower(curparams.hemis[1]) == 'f') |
442 (curparams.hemis[1] == '1')) {
443 calfn = kfullfn; kfullfn = NULL;
444 binf = "kbin";
445 nbins = "Nkbins";
446 } else if (tolower(curparams.hemis[0]) == 'k' &&
447 (tolower(curparams.hemis[1]) == 'h') |
448 (curparams.hemis[1] == '2')) {
449 calfn = khalffn; khalffn = NULL;
450 binf = "khbin";
451 nbins = "Nkhbins";
452 } else if (tolower(curparams.hemis[0]) == 'k' &&
453 (tolower(curparams.hemis[1]) == 'q') |
454 (curparams.hemis[1] == '4')) {
455 calfn = kquarterfn; kquarterfn = NULL;
456 binf = "kqbin";
457 nbins = "Nkqbins";
458 } else {
459 fprintf(stderr, "%s: unrecognized hemisphere sampling: h=%s\n",
460 progname, curparams.hemis);
461 exit(1);
462 }
463 if (!uniform & (curparams.slist->styp == ST_SOURCE)) {
464 SURF *sp;
465 for (sp = curparams.slist; sp != NULL; sp = sp->next)
466 if (fabs(sp->area - PI) > 1e-3) {
467 fprintf(stderr, "%s: source '%s' must be 180-degrees\n",
468 progname, sp->sname);
469 exit(1);
470 }
471 }
472 if (calfn != NULL) { /* add cal file if needed */
473 CHECKARGC(2);
474 rcarg[nrcargs++] = "-f";
475 rcarg[nrcargs++] = calfn;
476 }
477 if (params != NULL) { /* parameters _after_ cal file */
478 CHECKARGC(2);
479 rcarg[nrcargs++] = "-p";
480 rcarg[nrcargs++] = params;
481 }
482 if (nbins != NULL) { /* add #bins if set */
483 CHECKARGC(2);
484 rcarg[nrcargs++] = "-bn";
485 rcarg[nrcargs++] = nbins;
486 }
487 if (binv != NULL) {
488 CHECKARGC(2); /* assign bin variable */
489 rcarg[nrcargs++] = "-b";
490 rcarg[nrcargs++] = binv;
491 } else if (binf != NULL) {
492 CHECKARGC(2); /* assign bin function */
493 rcarg[nrcargs++] = "-b";
494 sprintf(sbuf, "%s(%g,%g,%g,%g,%g,%g)", binf,
495 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
496 curparams.vup[0], curparams.vup[1], curparams.vup[2]);
497 rcarg[nrcargs++] = savqstr(sbuf);
498 }
499 CHECKARGC(2); /* modifier argument goes last */
500 rcarg[nrcargs++] = "-m";
501 rcarg[nrcargs++] = savqstr(curmod);
502 }
503
504 /* Make randomly oriented tangent plane axes for given normal direction */
505 static void
506 make_axes(FVECT uva[2], const FVECT nrm)
507 {
508 int i;
509
510 uva[1][0] = 0.5 - frandom();
511 uva[1][1] = 0.5 - frandom();
512 uva[1][2] = 0.5 - frandom();
513 for (i = 3; i--; )
514 if ((-0.6 < nrm[i]) & (nrm[i] < 0.6))
515 break;
516 if (i < 0) {
517 fputs(progname, stderr);
518 fputs(": bad surface normal in make_axes!\n", stderr);
519 exit(1);
520 }
521 uva[1][i] = 1.0;
522 VCROSS(uva[0], uva[1], nrm);
523 normalize(uva[0]);
524 VCROSS(uva[1], nrm, uva[0]);
525 }
526
527 /* Illegal sender surfaces end up here */
528 static int
529 ssamp_bad(FVECT orig, SURF *sp, double x)
530 {
531 fprintf(stderr, "%s: illegal sender surface '%s'\n",
532 progname, sp->sname);
533 return(0);
534 }
535
536 /* Generate origin on ring surface from uniform random variable */
537 static int
538 ssamp_ring(FVECT orig, SURF *sp, double x)
539 {
540 FVECT *uva = (FVECT *)sp->priv;
541 double samp2[2];
542 double uv[2];
543 int i;
544
545 if (uva == NULL) { /* need tangent axes */
546 uva = (FVECT *)malloc(sizeof(FVECT)*2);
547 if (uva == NULL) {
548 fputs(progname, stderr);
549 fputs(": out of memory in ssamp_ring!\n", stderr);
550 return(0);
551 }
552 make_axes(uva, sp->snrm);
553 sp->priv = (void *)uva;
554 }
555 SDmultiSamp(samp2, 2, x);
556 samp2[0] = sp->farg[6] + sqrt(samp2[0]*sp->area*(1./PI));
557 samp2[1] *= 2.*PI;
558 uv[0] = samp2[0]*tcos(samp2[1]);
559 uv[1] = samp2[0]*tsin(samp2[1]);
560 for (i = 3; i--; )
561 orig[i] = sp->farg[i] + uv[0]*uva[0][i] + uv[1]*uva[1][i];
562 return(1);
563 }
564
565 /* Add triangle to polygon's list (call-back function) */
566 static int
567 add_triangle(const Vert2_list *tp, int a, int b, int c)
568 {
569 POLYTRIS *ptp = (POLYTRIS *)tp->p;
570 struct ptri *trip = ptp->tri + ptp->ntris++;
571
572 trip->vndx[0] = a;
573 trip->vndx[1] = b;
574 trip->vndx[2] = c;
575 return(1);
576 }
577
578 /* Generate origin on polygon surface from uniform random variable */
579 static int
580 ssamp_poly(FVECT orig, SURF *sp, double x)
581 {
582 POLYTRIS *ptp = (POLYTRIS *)sp->priv;
583 double samp2[2];
584 double *v0, *v1, *v2;
585 int i;
586
587 if (ptp == NULL) { /* need to triangulate */
588 ptp = (POLYTRIS *)malloc(sizeof(POLYTRIS) +
589 sizeof(struct ptri)*(sp->nfargs/3 - 3));
590 if (ptp == NULL)
591 goto memerr;
592 if (sp->nfargs == 3) { /* simple case */
593 ptp->ntris = 1;
594 ptp->tri[0].vndx[0] = 0;
595 ptp->tri[0].vndx[1] = 1;
596 ptp->tri[0].vndx[2] = 2;
597 ptp->tri[0].afrac = 1;
598 } else {
599 Vert2_list *v2l = polyAlloc(sp->nfargs/3);
600 if (v2l == NULL)
601 goto memerr;
602 make_axes(ptp->uva, sp->snrm);
603 for (i = v2l->nv; i--; ) {
604 v2l->v[i].mX = DOT(sp->farg+3*i, ptp->uva[0]);
605 v2l->v[i].mY = DOT(sp->farg+3*i, ptp->uva[1]);
606 }
607 ptp->ntris = 0;
608 v2l->p = (void *)ptp;
609 if (!polyTriangulate(v2l, add_triangle))
610 return(0);
611 for (i = ptp->ntris; i--; ) {
612 int a = ptp->tri[i].vndx[0];
613 int b = ptp->tri[i].vndx[1];
614 int c = ptp->tri[i].vndx[2];
615 ptp->tri[i].afrac =
616 (v2l->v[a].mX*v2l->v[b].mY -
617 v2l->v[b].mX*v2l->v[a].mY +
618 v2l->v[b].mX*v2l->v[c].mY -
619 v2l->v[c].mX*v2l->v[b].mY +
620 v2l->v[c].mX*v2l->v[a].mY -
621 v2l->v[a].mX*v2l->v[c].mY) /
622 (2.*sp->area);
623 }
624 polyFree(v2l);
625 }
626 sp->priv = (void *)ptp;
627 }
628 /* pick triangle by partial area */
629 for (i = 0; i < ptp->ntris && x > ptp->tri[i].afrac; i++)
630 x -= ptp->tri[i].afrac;
631 SDmultiSamp(samp2, 2, x/ptp->tri[i].afrac);
632 samp2[0] *= samp2[1] = sqrt(samp2[1]);
633 samp2[1] = 1. - samp2[1];
634 v0 = sp->farg + 3*ptp->tri[i].vndx[0];
635 v1 = sp->farg + 3*ptp->tri[i].vndx[1];
636 v2 = sp->farg + 3*ptp->tri[i].vndx[2];
637 for (i = 3; i--; )
638 orig[i] = v0[i] + samp2[0]*(v1[i] - v0[i])
639 + samp2[1]*(v2[i] - v0[i]) ;
640 return(1);
641 memerr:
642 fputs(progname, stderr);
643 fputs(": out of memory in ssamp_poly!\n", stderr);
644 return(0);
645 }
646
647 /* Compute sample origin based on projected areas of sender subsurfaces */
648 static int
649 sample_origin(PARAMS *p, FVECT orig, const FVECT rdir, double x)
650 {
651 static double *projsa;
652 static int nall;
653 double tarea = 0;
654 int i;
655 SURF *sp;
656 /* special case for lone surface */
657 if (p->nsurfs == 1) {
658 sp = p->slist;
659 if (DOT(sp->snrm, rdir) >= -FTINY)
660 return(0); /* behind surface! */
661 return((*orig_in_surf[sp->styp])(orig, sp, x));
662 }
663 if (p->nsurfs > nall) { /* (re)allocate surface area cache */
664 if (projsa) free(projsa);
665 projsa = (double *)malloc(sizeof(double)*p->nsurfs);
666 if (!projsa) return(0);
667 nall = p->nsurfs;
668 }
669 /* compute projected areas */
670 for (i = 0, sp = p->slist; sp != NULL; i++, sp = sp->next) {
671 projsa[i] = -DOT(sp->snrm, rdir) * sp->area;
672 tarea += projsa[i] *= (double)(projsa[i] > FTINY);
673 }
674 if (tarea <= FTINY) /* wrong side of sender? */
675 return(0);
676 tarea *= x; /* get surface from list */
677 for (i = 0, sp = p->slist; tarea > projsa[i]; sp = sp->next)
678 tarea -= projsa[i++];
679 return((*orig_in_surf[sp->styp])(orig, sp, tarea/projsa[i]));
680 }
681
682 /* Uniform sample generator */
683 static int
684 sample_uniform(PARAMS *p, int b, FILE *fp)
685 {
686 int n = sampcnt;
687 double samp3[3];
688 double duvw[3];
689 FVECT orig_dir[2];
690 int i;
691
692 if (fp == NULL) /* just requesting number of bins? */
693 return(1);
694
695 while (n--) { /* stratified hemisphere sampling */
696 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
697 SDsquare2disk(duvw, samp3[1], samp3[2]);
698 duvw[2] = -sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
699 for (i = 3; i--; )
700 orig_dir[1][i] = duvw[0]*p->udir[i] +
701 duvw[1]*p->vdir[i] +
702 duvw[2]*p->nrm[i] ;
703 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
704 return(0);
705 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
706 return(0);
707 }
708 return(1);
709 }
710
711 /* Shirly-Chiu sample generator */
712 static int
713 sample_shirchiu(PARAMS *p, int b, FILE *fp)
714 {
715 int n = sampcnt;
716 double samp3[3];
717 double duvw[3];
718 FVECT orig_dir[2];
719 int i;
720
721 if (fp == NULL) /* just requesting number of bins? */
722 return(p->hsiz*p->hsiz);
723
724 while (n--) { /* stratified sampling */
725 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
726 SDsquare2disk(duvw, (b/p->hsiz + samp3[1])/curparams.hsiz,
727 (b%p->hsiz + samp3[2])/curparams.hsiz);
728 duvw[2] = sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
729 for (i = 3; i--; )
730 orig_dir[1][i] = -duvw[0]*p->udir[i] -
731 duvw[1]*p->vdir[i] -
732 duvw[2]*p->nrm[i] ;
733 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
734 return(0);
735 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
736 return(0);
737 }
738 return(1);
739 }
740
741 /* Reinhart/Tregenza sample generator */
742 static int
743 sample_reinhart(PARAMS *p, int b, FILE *fp)
744 {
745 #define T_NALT 7
746 static const int tnaz[T_NALT] = {30, 30, 24, 24, 18, 12, 6};
747 const int RowMax = T_NALT*p->hsiz + 1;
748 const double RAH = (.25*PI)/(RowMax-.5);
749 #define rnaz(r) (r >= RowMax-1 ? 1 : p->hsiz*tnaz[r/p->hsiz])
750 int n = sampcnt;
751 int row, col;
752 double samp3[3];
753 double alt, azi;
754 double duvw[3];
755 FVECT orig_dir[2];
756 int i;
757
758 if (fp == NULL) { /* just requesting number of bins? */
759 n = 0;
760 for (row = RowMax; row--; ) n += rnaz(row);
761 return(n);
762 }
763 row = 0; /* identify row & column */
764 col = b;
765 while (col >= rnaz(row)) {
766 col -= rnaz(row);
767 ++row;
768 }
769 while (n--) { /* stratified sampling */
770 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
771 alt = (row+samp3[1])*RAH;
772 azi = (2.*PI)*(col+samp3[2]-.5)/rnaz(row);
773 duvw[2] = tcos(alt); /* measured from horizon */
774 duvw[0] = tcos(azi)*duvw[2];
775 duvw[1] = tsin(azi)*duvw[2];
776 duvw[2] = sqrt(1. - duvw[2]*duvw[2]);
777 for (i = 3; i--; )
778 orig_dir[1][i] = -duvw[0]*p->udir[i] -
779 duvw[1]*p->vdir[i] -
780 duvw[2]*p->nrm[i] ;
781 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
782 return(0);
783 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
784 return(0);
785 }
786 return(1);
787 #undef rnaz
788 #undef T_NALT
789 }
790
791 /* Klems sample generator */
792 static int
793 sample_klems(PARAMS *p, int b, FILE *fp)
794 {
795 static const char bname[4][20] = {
796 "LBNL/Klems Full",
797 "LBNL/Klems Half",
798 "INTERNAL ERROR",
799 "LBNL/Klems Quarter"
800 };
801 static ANGLE_BASIS *kbasis[4];
802 const int bi = p->hemis[1] - '1';
803 int n = sampcnt;
804 double samp2[2];
805 double duvw[3];
806 FVECT orig_dir[2];
807 int i;
808
809 if (!kbasis[bi]) { /* need to get basis, first */
810 for (i = 4; i--; )
811 if (!strcasecmp(abase_list[i].name, bname[bi])) {
812 kbasis[bi] = &abase_list[i];
813 break;
814 }
815 if (i < 0) {
816 fprintf(stderr, "%s: unknown hemisphere basis '%s'\n",
817 progname, bname[bi]);
818 return(0);
819 }
820 }
821 if (fp == NULL) /* just requesting number of bins? */
822 return(kbasis[bi]->nangles);
823
824 while (n--) { /* stratified sampling */
825 SDmultiSamp(samp2, 2, (n+frandom())/sampcnt);
826 if (!bo_getvec(duvw, b+samp2[1], kbasis[bi]))
827 return(0);
828 for (i = 3; i--; )
829 orig_dir[1][i] = duvw[0]*p->udir[i] +
830 duvw[1]*p->vdir[i] +
831 duvw[2]*p->nrm[i] ;
832 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp2[0]))
833 return(0);
834 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
835 return(0);
836 }
837 return(1);
838 }
839
840 /* Prepare hemisphere basis sampler that will send rays to rcontrib */
841 static int
842 prepare_sampler(void)
843 {
844 if (curparams.slist == NULL) { /* missing sample surface! */
845 fputs(progname, stderr);
846 fputs(": no sender surface!\n", stderr);
847 return(-1);
848 }
849 if (curparams.outfn != NULL) /* misplaced output file spec. */
850 fprintf(stderr, "%s: warning - ignoring output file in sender ('%s')\n",
851 progname, curparams.outfn);
852 /* check/set basis hemisphere */
853 if (!curparams.hemis[0]) {
854 fputs(progname, stderr);
855 fputs(": missing sender sampling type!\n", stderr);
856 return(-1);
857 }
858 if (normalize(curparams.nrm) == 0) {
859 fputs(progname, stderr);
860 fputs(": undefined normal for sender sampling\n", stderr);
861 return(-1);
862 }
863 if (normalize(curparams.vup) == 0)
864 if (fabs(curparams.nrm[2]) < .7)
865 curparams.vup[2] = 1;
866 else
867 curparams.vup[1] = 1;
868 VCROSS(curparams.udir, curparams.vup, curparams.nrm);
869 if (normalize(curparams.udir) == 0) {
870 fputs(progname, stderr);
871 fputs(": up vector coincides with sender normal\n", stderr);
872 return(-1);
873 }
874 VCROSS(curparams.vdir, curparams.nrm, curparams.udir);
875 if (tolower(curparams.hemis[0]) == 'u' | curparams.hemis[0] == '1')
876 curparams.sample_basis = sample_uniform;
877 else if (tolower(curparams.hemis[0]) == 's' &&
878 tolower(curparams.hemis[1]) == 'c')
879 curparams.sample_basis = sample_shirchiu;
880 else if ((tolower(curparams.hemis[0]) == 'r') |
881 (tolower(curparams.hemis[0]) == 't'))
882 curparams.sample_basis = sample_reinhart;
883 else if (tolower(curparams.hemis[0]) == 'k') {
884 switch (curparams.hemis[1]) {
885 case '1':
886 case '2':
887 case '4':
888 break;
889 case 'f':
890 case 'F':
891 case '\0':
892 curparams.hemis[1] = '1';
893 break;
894 case 'h':
895 case 'H':
896 curparams.hemis[1] = '2';
897 break;
898 case 'q':
899 case 'Q':
900 curparams.hemis[1] = '4';
901 break;
902 default:
903 goto unrecognized;
904 }
905 curparams.hemis[2] = '\0';
906 curparams.sample_basis = sample_klems;
907 } else
908 goto unrecognized;
909 /* return number of bins */
910 return((*curparams.sample_basis)(&curparams,0,NULL));
911 unrecognized:
912 fprintf(stderr, "%s: unrecognized sender sampling: h=%s\n",
913 progname, curparams.hemis);
914 return(-1);
915 }
916
917 /* Compute normal and area for polygon */
918 static int
919 finish_polygon(SURF *p)
920 {
921 const int nv = p->nfargs / 3;
922 FVECT e1, e2, vc;
923 int i;
924
925 memset(p->snrm, 0, sizeof(FVECT));
926 VSUB(e1, p->farg+3, p->farg);
927 for (i = 2; i < nv; i++) {
928 VSUB(e2, p->farg+3*i, p->farg);
929 VCROSS(vc, e1, e2);
930 p->snrm[0] += vc[0];
931 p->snrm[1] += vc[1];
932 p->snrm[2] += vc[2];
933 VCOPY(e1, e2);
934 }
935 p->area = normalize(p->snrm)*0.5;
936 return(p->area > FTINY);
937 }
938
939 /* Add a surface to our current parameters */
940 static void
941 add_surface(int st, const char *oname, FILE *fp)
942 {
943 SURF *snew;
944 int n;
945 /* get floating-point arguments */
946 if (!fscanf(fp, "%d", &n)) return;
947 while (n-- > 0) fscanf(fp, "%*s");
948 if (!fscanf(fp, "%d", &n)) return;
949 while (n-- > 0) fscanf(fp, "%*d");
950 if (!fscanf(fp, "%d", &n) || n <= 0) return;
951 snew = (SURF *)malloc(sizeof(SURF) + sizeof(double)*(n-1));
952 if (snew == NULL) {
953 fputs(progname, stderr);
954 fputs(": out of memory!\n", stderr);
955 exit(1);
956 }
957 strncpy(snew->sname, oname, sizeof(snew->sname)-1);
958 snew->sname[sizeof(snew->sname)-1] = '\0';
959 snew->styp = st;
960 snew->priv = NULL;
961 snew->nfargs = n;
962 for (n = 0; n < snew->nfargs; n++)
963 if (fscanf(fp, "%lf", &snew->farg[n]) != 1) {
964 fprintf(stderr, "%s: error reading arguments for '%s'\n",
965 progname, oname);
966 exit(1);
967 }
968 switch (st) {
969 case ST_RING:
970 if (snew->nfargs != 8)
971 goto badcount;
972 VCOPY(snew->snrm, snew->farg+3);
973 if (normalize(snew->snrm) == 0)
974 goto badnorm;
975 if (snew->farg[7] < snew->farg[6]) {
976 double t = snew->farg[7];
977 snew->farg[7] = snew->farg[6];
978 snew->farg[6] = t;
979 }
980 snew->area = PI*(snew->farg[7]*snew->farg[7] -
981 snew->farg[6]*snew->farg[6]);
982 break;
983 case ST_POLY:
984 if (snew->nfargs < 9 || snew->nfargs % 3)
985 goto badcount;
986 finish_polygon(snew);
987 break;
988 case ST_SOURCE:
989 if (snew->nfargs != 4)
990 goto badcount;
991 VCOPY(snew->snrm, snew->farg);
992 if (normalize(snew->snrm) == 0)
993 goto badnorm;
994 snew->area = sin((PI/180./2.)*snew->farg[3]);
995 snew->area *= PI*snew->area;
996 break;
997 }
998 if (snew->area <= FTINY) {
999 fprintf(stderr, "%s: warning - zero area for surface '%s'\n",
1000 progname, oname);
1001 free(snew);
1002 return;
1003 }
1004 VSUM(curparams.nrm, curparams.nrm, snew->snrm, snew->area);
1005 snew->next = curparams.slist;
1006 curparams.slist = snew;
1007 curparams.nsurfs++;
1008 return;
1009 badcount:
1010 fprintf(stderr, "%s: bad argument count for surface '%s'\n",
1011 progname, oname);
1012 exit(1);
1013 badnorm:
1014 fprintf(stderr, "%s: bad orientation for surface '%s'\n",
1015 progname, oname);
1016 exit(1);
1017 }
1018
1019 /* Parse a receiver object (look for modifiers to add to rcontrib command) */
1020 static int
1021 add_recv_object(FILE *fp)
1022 {
1023 int st;
1024 char thismod[128], otype[32], oname[128];
1025 int n;
1026
1027 if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3)
1028 return(0); /* must have hit EOF! */
1029 if (!strcmp(otype, "alias")) {
1030 fscanf(fp, "%*s"); /* skip alias */
1031 return(0);
1032 }
1033 /* is it a new receiver? */
1034 if ((st = surf_type(otype)) != ST_NONE) {
1035 if (curparams.slist != NULL && (st == ST_SOURCE) ^
1036 (curparams.slist->styp == ST_SOURCE)) {
1037 fputs(progname, stderr);
1038 fputs(": cannot mix source/non-source receivers!\n", stderr);
1039 return(-1);
1040 }
1041 if (strcmp(thismod, curmod)) {
1042 if (curmod[0]) { /* output last receiver? */
1043 finish_receiver();
1044 clear_params(&curparams, 1);
1045 }
1046 strcpy(curmod, thismod);
1047 }
1048 add_surface(st, oname, fp); /* read & store surface */
1049 return(1);
1050 }
1051 /* else skip arguments */
1052 if (!fscanf(fp, "%d", &n)) return;
1053 while (n-- > 0) fscanf(fp, "%*s");
1054 if (!fscanf(fp, "%d", &n)) return;
1055 while (n-- > 0) fscanf(fp, "%*d");
1056 if (!fscanf(fp, "%d", &n)) return;
1057 while (n-- > 0) fscanf(fp, "%*f");
1058 return(0);
1059 }
1060
1061 /* Parse a sender object */
1062 static int
1063 add_send_object(FILE *fp)
1064 {
1065 int st;
1066 char otype[32], oname[128];
1067 int n;
1068
1069 if (fscanf(fp, "%*s %s %s", otype, oname) != 2)
1070 return(0); /* must have hit EOF! */
1071 if (!strcmp(otype, "alias")) {
1072 fscanf(fp, "%*s"); /* skip alias */
1073 return(0);
1074 }
1075 /* is it a new surface? */
1076 if ((st = surf_type(otype)) != ST_NONE) {
1077 if (st == ST_SOURCE) {
1078 fputs(progname, stderr);
1079 fputs(": cannot use source as a sender!\n", stderr);
1080 return(-1);
1081 }
1082 add_surface(st, oname, fp); /* read & store surface */
1083 return(0);
1084 }
1085 /* else skip arguments */
1086 if (!fscanf(fp, "%d", &n)) return;
1087 while (n-- > 0) fscanf(fp, "%*s");
1088 if (!fscanf(fp, "%d", &n)) return;
1089 while (n-- > 0) fscanf(fp, "%*d");
1090 if (!fscanf(fp, "%d", &n)) return;
1091 while (n-- > 0) fscanf(fp, "%*f");
1092 return(0);
1093 }
1094
1095 /* Load a Radiance scene using the given callback function for objects */
1096 static int
1097 load_scene(const char *inspec, int (*ocb)(FILE *))
1098 {
1099 int rv = 0;
1100 char inpbuf[1024];
1101 FILE *fp;
1102 int c;
1103
1104 if (*inspec == '!')
1105 fp = popen(inspec+1, "r");
1106 else
1107 fp = fopen(inspec, "r");
1108 if (fp == NULL) {
1109 fprintf(stderr, "%s: cannot load '%s'\n", progname, inspec);
1110 return(-1);
1111 }
1112 while ((c = getc(fp)) != EOF) { /* load receiver data */
1113 if (isspace(c)) /* skip leading white space */
1114 continue;
1115 if (c == '!') { /* read from a new command */
1116 inpbuf[0] = c;
1117 if (fgetline(inpbuf+1, sizeof(inpbuf)-1, fp) != NULL) {
1118 if ((c = load_scene(inpbuf, ocb)) < 0)
1119 return(c);
1120 rv += c;
1121 }
1122 continue;
1123 }
1124 if (c == '#') { /* parameters/comment */
1125 if (fscanf(fp, "%s", inpbuf) == 1 &&
1126 !strcmp(inpbuf, PARAMSTART)) {
1127 if (fgets(inpbuf, sizeof(inpbuf), fp) != NULL)
1128 parse_params(inpbuf);
1129 continue;
1130 }
1131 while ((c = getc(fp)) != EOF && c != '\n');
1132 ; /* else skipping comment */
1133 continue;
1134 }
1135 ungetc(c, fp); /* else check object for receiver */
1136 c = (*ocb)(fp);
1137 if (c < 0)
1138 return(c);
1139 rv += c;
1140 }
1141 /* close our input stream */
1142 c = (*inspec == '!') ? pclose(fp) : fclose(fp);
1143 if (c != 0) {
1144 fprintf(stderr, "%s: error loading '%s'\n", progname, inspec);
1145 return(-1);
1146 }
1147 return(rv);
1148 }
1149
1150 /* Get command arguments and run program */
1151 int
1152 main(int argc, char *argv[])
1153 {
1154 char fmtopt[6] = "-faa"; /* default output is ASCII */
1155 char *xrs=NULL, *yrs=NULL, *ldopt=NULL;
1156 char *sendfn;
1157 char sampcntbuf[32], nsbinbuf[32];
1158 FILE *rcfp;
1159 int nsbins;
1160 int a, i;
1161 /* screen rcontrib options */
1162 progname = argv[0];
1163 for (a = 1; a < argc-2 && argv[a][0] == '-'; a++) {
1164 int na = 1; /* !! Keep consistent !! */
1165 switch (argv[a][1]) {
1166 case 'v': /* verbose mode */
1167 verbose = !verbose;
1168 na = 0;
1169 continue;
1170 case 'f': /* special case for -fo, -ff, etc. */
1171 switch (argv[a][2]) {
1172 case '\0': /* cal file */
1173 goto userr;
1174 case 'o': /* force output */
1175 goto userr;
1176 case 'a': /* output format */
1177 case 'f':
1178 case 'd':
1179 case 'c':
1180 if (!(fmtopt[4] = argv[a][3]))
1181 fmtopt[4] = argv[a][2];
1182 fmtopt[3] = argv[a][2];
1183 na = 0;
1184 continue; /* will pass later */
1185 default:
1186 goto userr;
1187 }
1188 break;
1189 case 'x': /* x-resolution */
1190 xrs = argv[++a];
1191 na = 0;
1192 continue;
1193 case 'y': /* y-resolution */
1194 yrs = argv[++a];
1195 na = 0;
1196 continue;
1197 case 'c': /* number of samples */
1198 sampcnt = atoi(argv[a+1]);
1199 if (sampcnt <= 0)
1200 goto userr;
1201 na = 0; /* we re-add this later */
1202 continue;
1203 case 'V': /* options without arguments */
1204 case 'w':
1205 case 'u':
1206 case 'i':
1207 case 'h':
1208 case 'r':
1209 break;
1210 case 'n': /* options with 1 argument */
1211 case 's':
1212 case 'o':
1213 na = 2;
1214 break;
1215 case 'b': /* special case */
1216 if (argv[a][2] != 'v') goto userr;
1217 break;
1218 case 'l': /* special case */
1219 if (argv[a][2] == 'd') {
1220 ldopt = argv[a];
1221 na = 0;
1222 continue;
1223 }
1224 na = 2;
1225 break;
1226 case 'd': /* special case */
1227 if (argv[a][2] != 'v') na = 2;
1228 break;
1229 case 'a': /* special case */
1230 na = (argv[a][2] == 'v') ? 4 : 2;
1231 break;
1232 case 'm': /* special case */
1233 if (!argv[a][2]) goto userr;
1234 na = (argv[a][2] == 'e') | (argv[a][2] == 'a') ? 4 : 2;
1235 break;
1236 case '\0': /* pass-through mode */
1237 goto done_opts;
1238 default: /* anything else is verbotten */
1239 goto userr;
1240 }
1241 if (na <= 0) continue;
1242 CHECKARGC(na); /* pass on option */
1243 rcarg[nrcargs++] = argv[a];
1244 while (--na) /* + arguments if any */
1245 rcarg[nrcargs++] = argv[++a];
1246 }
1247 done_opts:
1248 if (a > argc-2)
1249 goto userr; /* check at end of options */
1250 sendfn = argv[a++]; /* assign sender & receiver inputs */
1251 if (sendfn[0] == '-') { /* user wants pass-through mode? */
1252 if (sendfn[1]) goto userr;
1253 sendfn = NULL;
1254 if (xrs) {
1255 CHECKARGC(2);
1256 rcarg[nrcargs++] = "-x";
1257 rcarg[nrcargs++] = xrs;
1258 }
1259 if (yrs) {
1260 CHECKARGC(2);
1261 rcarg[nrcargs++] = "-y";
1262 rcarg[nrcargs++] = yrs;
1263 }
1264 if (ldopt) {
1265 CHECKARGC(1);
1266 rcarg[nrcargs++] = ldopt;
1267 }
1268 if (sampcnt <= 0) sampcnt = 1;
1269 } else { /* else FVECT determines input format */
1270 fmtopt[3] = (sizeof(RREAL)==sizeof(double)) ? 'd' : 'f';
1271 if (sampcnt <= 0) sampcnt = 10000;
1272 }
1273 sprintf(sampcntbuf, "%d", sampcnt);
1274 CHECKARGC(3); /* add our format & sample count */
1275 rcarg[nrcargs++] = fmtopt;
1276 rcarg[nrcargs++] = "-c";
1277 rcarg[nrcargs++] = sampcntbuf;
1278 /* add receiver arguments to rcontrib */
1279 if (load_scene(argv[a], add_recv_object) < 0)
1280 return(1);
1281 finish_receiver();
1282 if (sendfn == NULL) { /* pass-through mode? */
1283 CHECKARGC(1); /* add octree */
1284 rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1285 rcarg[nrcargs] = NULL;
1286 return(my_exec(rcarg)); /* rcontrib does everything */
1287 }
1288 clear_params(&curparams, 0); /* else load sender surface & params */
1289 if (load_scene(sendfn, add_send_object) < 0)
1290 return(1);
1291 if ((nsbins = prepare_sampler()) <= 0)
1292 return(1);
1293 CHECKARGC(3); /* add row count and octree */
1294 rcarg[nrcargs++] = "-y";
1295 sprintf(nsbinbuf, "%d", nsbins);
1296 rcarg[nrcargs++] = nsbinbuf;
1297 rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1298 rcarg[nrcargs] = NULL;
1299 /* open pipe to rcontrib process */
1300 if ((rcfp = popen_arglist(rcarg, "w")) == NULL)
1301 return(1);
1302 SET_FILE_BINARY(rcfp);
1303 #ifdef getc_unlocked
1304 flockfile(rcfp);
1305 #endif
1306 if (verbose) {
1307 fprintf(stderr, "%s: sampling %d directions", progname, nsbins);
1308 if (curparams.nsurfs > 1)
1309 fprintf(stderr, " (%d surfaces)\n", curparams.nsurfs);
1310 else
1311 fputc('\n', stderr);
1312 }
1313 for (i = 0; i < nsbins; i++) /* send rcontrib ray samples */
1314 if (!(*curparams.sample_basis)(&curparams, i, rcfp))
1315 return(1);
1316 return(pclose(rcfp) == 0); /* all finished! */
1317 userr:
1318 if (a < argc-2)
1319 fprintf(stderr, "%s: unsupported option '%s'", progname, argv[a]);
1320 fprintf(stderr, "Usage: %s [rcontrib options] sender.rad receiver.rad [system.rad ..]\n",
1321 progname);
1322 return(1);
1323 }
