root/radiance/ray/src/util/rfluxmtx.c
Revision: 2.14
Committed: Wed Aug 6 02:38:24 2014 UTC (9 years, 8 months ago) by greg
Changes since 2.13: +15 -7 lines
2 static const char RCSid[] = "$Id: rfluxmtx.c,v 2.13 2014/08/06 00:59:53 greg Exp $";
5 * Calculate flux transfer matrix or matrices using rcontrib
6 */
7
8 #include "copyright.h"
9
10 #include <ctype.h>
11 #include <stdlib.h>
12 #include "rtio.h"
13 #include "rtmath.h"
14 #include "rtprocess.h"
15 #include "bsdf.h"
16 #include "bsdf_m.h"
17 #include "random.h"
18 #include "triangulate.h"
19 #include "platform.h"
20
21 #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
22 #undef getc
23 #define getc getc_unlocked
24 #endif
25
26 #ifdef _WIN32
27 #define SPECIALS " \t\"$*?"
28 #define QUOTCHAR '"'
29 #else
30 #define SPECIALS " \t\n'\"()${}*?[];|&"
31 #define QUOTCHAR '\''
32 #define ALTQUOT '"'
33 #endif
34
35 #define MAXRCARG 512
36
37 char *progname; /* global argv[0] */
38
39 int verbose = 0; /* verbose mode? */
40
41 char *rcarg[MAXRCARG+1] = {"rcontrib", "-fo+"};
42 int nrcargs = 2;
43
44 const char overflowerr[] = "%s: too many arguments!\n";
45
46 #define CHECKARGC(n) if (nrcargs >= MAXRCARG-(n)) \
47 { fprintf(stderr, overflowerr, progname); exit(1); }
48
49 int sampcnt = 0; /* sample count (0==unset) */
50
51 char *reinhfn = "reinhartb.cal";
52 char *shirchiufn = "disk2square.cal";
53 char *kfullfn = "klems_full.cal";
54 char *khalffn = "klems_half.cal";
55 char *kquarterfn = "klems_quarter.cal";
56
57 /* string indicating parameters */
58 const char PARAMSTART[] = "@rfluxmtx";
59
60 /* surface type IDs */
61 #define ST_NONE 0
62 #define ST_POLY 1
63 #define ST_RING 2
64 #define ST_SOURCE 3
65
66 typedef struct surf_s {
67 struct surf_s *next; /* next surface in list */
68 void *priv; /* private data (malloc'ed) */
69 char sname[32]; /* surface name */
70 FVECT snrm; /* surface normal */
71 double area; /* surface area / proj. solid angle */
72 short styp; /* surface type */
73 short nfargs; /* number of real arguments */
74 double farg[1]; /* real values (extends struct) */
75 } SURF; /* surface structure */
76
77 typedef struct {
78 FVECT uva[2]; /* tangent axes */
79 int ntris; /* number of triangles */
80 struct ptri {
81 float afrac; /* fraction of total area */
82 short vndx[3]; /* vertex indices */
83 } tri[1]; /* triangle array (extends struct) */
84 } POLYTRIS; /* triangulated polygon */
85
86 typedef struct param_s {
87 char hemis[32]; /* hemispherical sampling spec. */
88 int hsiz; /* hemisphere basis size */
89 int nsurfs; /* number of surfaces */
90 SURF *slist; /* list of surfaces */
91 FVECT vup; /* up vector (zero if unset) */
92 FVECT nrm; /* average normal direction */
93 FVECT udir, vdir; /* v-up tangent axes */
94 char *outfn; /* output file name (receiver) */
95 int (*sample_basis)(struct param_s *p, int, FILE *);
96 } PARAMS; /* sender/receiver parameters */
97
98 PARAMS curparams;
99 char curmod[128];
100 char newparams[1024];
101
102 typedef int SURFSAMP(FVECT, SURF *, double);
103
104 static SURFSAMP ssamp_bad, ssamp_poly, ssamp_ring;
105
106 SURFSAMP *orig_in_surf[4] = {
107 ssamp_bad, ssamp_poly, ssamp_ring, ssamp_bad
108 };
109
110 /* Clear parameter set */
111 static void
112 clear_params(PARAMS *p, int reset_only)
113 {
114 while (p->slist != NULL) {
115 SURF *sdel = p->slist;
116 p->slist = sdel->next;
117 if (sdel->priv != NULL)
118 free(sdel->priv);
119 free(sdel);
120 }
121 if (reset_only) {
122 p->nsurfs = 0;
123 memset(p->nrm, 0, sizeof(FVECT));
124 memset(p->vup, 0, sizeof(FVECT));
125 p->outfn = NULL;
126 return;
127 }
128 memset(p, 0, sizeof(PARAMS));
129 }
130
131 /* Get surface type from name */
132 static int
133 surf_type(const char *otype)
134 {
135 if (!strcmp(otype, "polygon"))
136 return(ST_POLY);
137 if (!strcmp(otype, "ring"))
138 return(ST_RING);
139 if (!strcmp(otype, "source"))
140 return(ST_SOURCE);
141 return(ST_NONE);
142 }
143
144 /* Add arguments to oconv command */
145 static char *
146 oconv_command(int ac, char *av[])
147 {
148 static char oconvbuf[2048] = "!oconv -f ";
149 char *cp = oconvbuf + 10;
150 char *recv = *av++;
151
152 if (ac-- <= 0)
153 return(NULL);
154 while (ac-- > 0) {
155 strcpy(cp, *av++);
156 while (*cp) cp++;
157 *cp++ = ' ';
158 if (cp >= oconvbuf+(sizeof(oconvbuf)-32)) {
159 fputs(progname, stderr);
160 fputs(": too many file arguments!\n", stderr);
161 exit(1);
162 }
163 }
164 strcpy(cp, recv); /* receiver goes last */
165 return(oconvbuf);
166 }
167
168 /* Check if any of the characters in str2 are found in str1 */
169 static int
170 matchany(const char *str1, const char *str2)
171 {
172 while (*str1) {
173 const char *cp = str2;
174 while (*cp)
175 if (*cp++ == *str1)
176 return(*str1);
177 ++str1;
178 }
179 return(0);
180 }
181
182
183 /* Convert a set of arguments into a command line for pipe() or system() */
184 static char *
185 convert_commandline(char *cmd, const int len, char *av[])
186 {
187 int match;
188 char *cp;
189
190 for (cp = cmd; *av != NULL; av++) {
191 const int n = strlen(*av);
192 if (cp+n >= cmd+(len-3)) {
193 fputs(progname, stderr);
194 return(NULL);
195 }
196 if ((match = matchany(*av, SPECIALS))) {
197 const int quote =
198 #ifdef ALTQUOT
199 (match == QUOTCHAR) ? ALTQUOT :
200 #endif
201 QUOTCHAR;
202 *cp++ = quote;
203 strcpy(cp, *av);
204 cp += n;
205 *cp++ = quote;
206 } else {
207 strcpy(cp, *av);
208 cp += n;
209 }
210 *cp++ = ' ';
211 }
212 if (cp <= cmd)
213 return(NULL);
214 *--cp = '\0';
215 return(cmd);
216 }
217
218 /* Open a pipe to/from a command given as an argument list */
219 static FILE *
220 popen_arglist(char *av[], char *mode)
221 {
222 char cmd[10240];
223
224 if (!convert_commandline(cmd, sizeof(cmd), av)) {
225 fputs(progname, stderr);
226 fputs(": command line too long in popen_arglist()\n", stderr);
227 return(NULL);
228 }
229 if (verbose)
230 fprintf(stderr, "%s: opening pipe %s: %s\n",
231 progname, (*mode=='w') ? "to" : "from", cmd);
232 return(popen(cmd, mode));
233 }
234
235 #ifdef _WIN32
236 /* Execute system command (Windows version) */
237 static int
238 my_exec(char *av[])
239 {
240 char cmd[10240];
241
242 if (!convert_commandline(cmd, sizeof(cmd), av)) {
243 fputs(progname, stderr);
244 fputs(": command line too long in my_exec()\n", stderr);
245 return(1);
246 }
247 if (verbose)
248 fprintf(stderr, "%s: running: %s\n", progname, cmd);
249 return(system(cmd));
250 }
251 #else
252 /* Execute system command in our stead (Unix version) */
253 static int
254 my_exec(char *av[])
255 {
256 char *compath;
257
258 if ((compath = getpath((char *)av[0], getenv("PATH"), X_OK)) == NULL) {
259 fprintf(stderr, "%s: cannot locate %s\n", progname, av[0]);
260 return(1);
261 }
262 if (verbose) {
263 char cmd[4096];
264 if (!convert_commandline(cmd, sizeof(cmd), av))
265 strcpy(cmd, "COMMAND TOO LONG TO SHOW");
266 fprintf(stderr, "%s: running: %s\n", progname, cmd);
267 }
268 execv(compath, av); /* successful call never returns */
269 perror(compath);
270 return(1);
271 }
272 #endif
273
274 /* Get normalized direction vector from string specification */
275 static int
276 get_direction(FVECT dv, const char *s)
277 {
278 int sign = 1;
279 int axis = 0;
280
281 memset(dv, 0, sizeof(FVECT));
282 nextchar:
283 switch (*s) {
284 case '+':
285 ++s;
286 goto nextchar;
287 case '-':
288 sign = -sign;
289 ++s;
290 goto nextchar;
291 case 'z':
292 case 'Z':
293 ++axis;
294 case 'y':
295 case 'Y':
296 ++axis;
297 case 'x':
298 case 'X':
299 dv[axis] = sign;
300 return(!s[1] | isspace(s[1]));
301 default:
302 break;
303 }
304 #ifdef SMLFLT
305 if (sscanf(s, "%f,%f,%f", &dv[0], &dv[1], &dv[2]) != 3)
306 #else
307 if (sscanf(s, "%lf,%lf,%lf", &dv[0], &dv[1], &dv[2]) != 3)
308 #endif
309 return(0);
310 dv[0] *= (RREAL)sign;
311 return(normalize(dv) > 0);
312 }
313
314 /* Parse program parameters (directives) */
315 static int
316 parse_params(PARAMS *p, char *pargs)
317 {
318 char *cp = pargs;
319 int nparams = 0;
320 int i;
321
322 for ( ; ; )
323 switch (*cp++) {
324 case 'h':
325 if (*cp++ != '=')
326 break;
327 p->hsiz = 0;
328 i = 0;
329 while (*cp && !isspace(*cp)) {
330 if (isdigit(*cp))
331 p->hsiz = 10*p->hsiz + *cp - '0';
332 p->hemis[i++] = *cp++;
333 }
334 if (!i)
335 break;
336 p->hemis[i] = '\0';
337 p->hsiz += !p->hsiz;
338 ++nparams;
339 continue;
340 case 'u':
341 if (*cp++ != '=')
342 break;
343 if (!get_direction(p->vup, cp))
344 break;
345 ++nparams;
346 continue;
347 case 'o':
348 if (*cp++ != '=')
349 break;
350 i = 0;
351 while (*cp && !isspace(*cp++))
352 i++;
353 if (!i)
354 break;
355 *--cp = '\0';
356 p->outfn = savqstr(cp-i);
357 *cp++ = ' ';
358 ++nparams;
359 continue;
360 case ' ':
361 case '\t':
362 case '\r':
363 case '\n':
364 continue;
365 case '\0':
366 return(nparams);
367 default:
368 break;
369 }
370 fprintf(stderr, "%s: bad parameter string '%s'\n", progname, pargs);
371 exit(1);
372 return(-1); /* pro forma return */
373 }
374
375 /* Add receiver arguments (directives) corresponding to the current modifier */
376 static void
377 finish_receiver(void)
378 {
379 char sbuf[256];
380 int uniform = 0;
381 char *calfn = NULL;
382 char *params = NULL;
383 char *binv = NULL;
384 char *binf = NULL;
385 char *nbins = NULL;
386
387 if (!curmod[0]) {
388 fputs(progname, stderr);
389 fputs(": missing receiver surface!\n", stderr);
390 exit(1);
391 }
392 if (curparams.outfn != NULL) { /* add output file spec. */
393 CHECKARGC(2);
394 rcarg[nrcargs++] = "-o";
395 rcarg[nrcargs++] = curparams.outfn;
396 }
397 /* check arguments */
398 if (!curparams.hemis[0]) {
399 fputs(progname, stderr);
400 fputs(": missing hemisphere sampling type!\n", stderr);
401 exit(1);
402 }
403 if (normalize(curparams.nrm) == 0) {
404 fputs(progname, stderr);
405 fputs(": undefined normal for hemisphere sampling\n", stderr);
406 exit(1);
407 }
408 if (normalize(curparams.vup) == 0) {
409 if (fabs(curparams.nrm[2]) < .7)
410 curparams.vup[2] = 1;
411 else
412 curparams.vup[1] = 1;
413 }
414 /* determine sample type/bin */
415 if (tolower(curparams.hemis[0]) == 'u' | curparams.hemis[0] == '1') {
416 binv = "0"; /* uniform sampling -- one bin */
417 uniform = 1;
418 } else if (tolower(curparams.hemis[0]) == 's' &&
419 tolower(curparams.hemis[1]) == 'c') {
420 /* assign parameters */
421 if (curparams.hsiz <= 1) {
422 fputs(progname, stderr);
423 fputs(": missing size for Shirley-Chiu sampling!\n", stderr);
424 exit(1);
425 }
426 calfn = shirchiufn; shirchiufn = NULL;
427 sprintf(sbuf, "SCdim=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g",
428 curparams.hsiz,
429 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
430 curparams.vup[0], curparams.vup[1], curparams.vup[2]);
431 params = savqstr(sbuf);
432 binv = "scbin";
433 nbins = "SCdim*SCdim";
434 } else if ((tolower(curparams.hemis[0]) == 'r') |
435 (tolower(curparams.hemis[0]) == 't')) {
436 calfn = reinhfn; reinhfn = NULL;
437 sprintf(sbuf, "MF=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g",
438 curparams.hsiz,
439 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
440 curparams.vup[0], curparams.vup[1], curparams.vup[2]);
441 params = savqstr(sbuf);
442 binv = "rbin";
443 nbins = "Nrbins";
444 } else if (tolower(curparams.hemis[0]) == 'k' &&
445 !curparams.hemis[1] |
446 (tolower(curparams.hemis[1]) == 'f') |
447 (curparams.hemis[1] == '1')) {
448 calfn = kfullfn; kfullfn = NULL;
449 binf = "kbin";
450 nbins = "Nkbins";
451 } else if (tolower(curparams.hemis[0]) == 'k' &&
452 (tolower(curparams.hemis[1]) == 'h') |
453 (curparams.hemis[1] == '2')) {
454 calfn = khalffn; khalffn = NULL;
455 binf = "khbin";
456 nbins = "Nkhbins";
457 } else if (tolower(curparams.hemis[0]) == 'k' &&
458 (tolower(curparams.hemis[1]) == 'q') |
459 (curparams.hemis[1] == '4')) {
460 calfn = kquarterfn; kquarterfn = NULL;
461 binf = "kqbin";
462 nbins = "Nkqbins";
463 } else {
464 fprintf(stderr, "%s: unrecognized hemisphere sampling: h=%s\n",
465 progname, curparams.hemis);
466 exit(1);
467 }
468 if (!uniform & (curparams.slist->styp == ST_SOURCE)) {
469 SURF *sp;
470 for (sp = curparams.slist; sp != NULL; sp = sp->next)
471 if (fabs(sp->area - PI) > 1e-3) {
472 fprintf(stderr, "%s: source '%s' must be 180-degrees\n",
473 progname, sp->sname);
474 exit(1);
475 }
476 }
477 if (calfn != NULL) { /* add cal file if needed */
478 CHECKARGC(2);
479 rcarg[nrcargs++] = "-f";
480 rcarg[nrcargs++] = calfn;
481 }
482 if (params != NULL) { /* parameters _after_ cal file */
483 CHECKARGC(2);
484 rcarg[nrcargs++] = "-p";
485 rcarg[nrcargs++] = params;
486 }
487 if (nbins != NULL) { /* add #bins if set */
488 CHECKARGC(2);
489 rcarg[nrcargs++] = "-bn";
490 rcarg[nrcargs++] = nbins;
491 }
492 if (binv != NULL) {
493 CHECKARGC(2); /* assign bin variable */
494 rcarg[nrcargs++] = "-b";
495 rcarg[nrcargs++] = binv;
496 } else if (binf != NULL) {
497 CHECKARGC(2); /* assign bin function */
498 rcarg[nrcargs++] = "-b";
499 sprintf(sbuf, "%s(%g,%g,%g,%g,%g,%g)", binf,
500 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
501 curparams.vup[0], curparams.vup[1], curparams.vup[2]);
502 rcarg[nrcargs++] = savqstr(sbuf);
503 }
504 CHECKARGC(2); /* modifier argument goes last */
505 rcarg[nrcargs++] = "-m";
506 rcarg[nrcargs++] = savqstr(curmod);
507 }
508
509 /* Make randomly oriented tangent plane axes for given normal direction */
510 static void
511 make_axes(FVECT uva[2], const FVECT nrm)
512 {
513 int i;
514
515 uva[1][0] = 0.5 - frandom();
516 uva[1][1] = 0.5 - frandom();
517 uva[1][2] = 0.5 - frandom();
518 for (i = 3; i--; )
519 if ((-0.6 < nrm[i]) & (nrm[i] < 0.6))
520 break;
521 if (i < 0) {
522 fputs(progname, stderr);
523 fputs(": bad surface normal in make_axes!\n", stderr);
524 exit(1);
525 }
526 uva[1][i] = 1.0;
527 VCROSS(uva[0], uva[1], nrm);
528 normalize(uva[0]);
529 VCROSS(uva[1], nrm, uva[0]);
530 }
531
532 /* Illegal sender surfaces end up here */
533 static int
534 ssamp_bad(FVECT orig, SURF *sp, double x)
535 {
536 fprintf(stderr, "%s: illegal sender surface '%s'\n",
537 progname, sp->sname);
538 return(0);
539 }
540
541 /* Generate origin on ring surface from uniform random variable */
542 static int
543 ssamp_ring(FVECT orig, SURF *sp, double x)
544 {
545 FVECT *uva = (FVECT *)sp->priv;
546 double samp2[2];
547 double uv[2];
548 int i;
549
550 if (uva == NULL) { /* need tangent axes */
551 uva = (FVECT *)malloc(sizeof(FVECT)*2);
552 if (uva == NULL) {
553 fputs(progname, stderr);
554 fputs(": out of memory in ssamp_ring!\n", stderr);
555 return(0);
556 }
557 make_axes(uva, sp->snrm);
558 sp->priv = (void *)uva;
559 }
560 SDmultiSamp(samp2, 2, x);
561 samp2[0] = sqrt(samp2[0]*sp->area*(1./PI) + sp->farg[6]*sp->farg[6]);
562 samp2[1] *= 2.*PI;
563 uv[0] = samp2[0]*tcos(samp2[1]);
564 uv[1] = samp2[0]*tsin(samp2[1]);
565 for (i = 3; i--; )
566 orig[i] = sp->farg[i] + uv[0]*uva[0][i] + uv[1]*uva[1][i];
567 return(1);
568 }
569
570 /* Add triangle to polygon's list (call-back function) */
571 static int
572 add_triangle(const Vert2_list *tp, int a, int b, int c)
573 {
574 POLYTRIS *ptp = (POLYTRIS *)tp->p;
575 struct ptri *trip = ptp->tri + ptp->ntris++;
576
577 trip->vndx[0] = a;
578 trip->vndx[1] = b;
579 trip->vndx[2] = c;
580 return(1);
581 }
582
583 /* Generate origin on polygon surface from uniform random variable */
584 static int
585 ssamp_poly(FVECT orig, SURF *sp, double x)
586 {
587 POLYTRIS *ptp = (POLYTRIS *)sp->priv;
588 double samp2[2];
589 double *v0, *v1, *v2;
590 int i;
591
592 if (ptp == NULL) { /* need to triangulate */
593 ptp = (POLYTRIS *)malloc(sizeof(POLYTRIS) +
594 sizeof(struct ptri)*(sp->nfargs/3 - 3));
595 if (ptp == NULL)
596 goto memerr;
597 if (sp->nfargs == 3) { /* simple case */
598 ptp->ntris = 1;
599 ptp->tri[0].vndx[0] = 0;
600 ptp->tri[0].vndx[1] = 1;
601 ptp->tri[0].vndx[2] = 2;
602 ptp->tri[0].afrac = 1;
603 } else {
604 Vert2_list *v2l = polyAlloc(sp->nfargs/3);
605 if (v2l == NULL)
606 goto memerr;
607 make_axes(ptp->uva, sp->snrm);
608 for (i = v2l->nv; i--; ) {
609 v2l->v[i].mX = DOT(sp->farg+3*i, ptp->uva[0]);
610 v2l->v[i].mY = DOT(sp->farg+3*i, ptp->uva[1]);
611 }
612 ptp->ntris = 0;
613 v2l->p = (void *)ptp;
614 if (!polyTriangulate(v2l, add_triangle)) {
615 fprintf(stderr,
616 "%s: cannot triangulate polygon '%s'\n",
617 progname, sp->sname);
618 return(0);
619 }
620 for (i = ptp->ntris; i--; ) {
621 int a = ptp->tri[i].vndx[0];
622 int b = ptp->tri[i].vndx[1];
623 int c = ptp->tri[i].vndx[2];
624 ptp->tri[i].afrac =
625 (v2l->v[a].mX*v2l->v[b].mY -
626 v2l->v[b].mX*v2l->v[a].mY +
627 v2l->v[b].mX*v2l->v[c].mY -
628 v2l->v[c].mX*v2l->v[b].mY +
629 v2l->v[c].mX*v2l->v[a].mY -
630 v2l->v[a].mX*v2l->v[c].mY) /
631 (2.*sp->area);
632 }
633 polyFree(v2l);
634 }
635 sp->priv = (void *)ptp;
636 }
637 /* pick triangle by partial area */
638 for (i = 0; i < ptp->ntris && x > ptp->tri[i].afrac; i++)
639 x -= ptp->tri[i].afrac;
640 SDmultiSamp(samp2, 2, x/ptp->tri[i].afrac);
641 samp2[0] *= samp2[1] = sqrt(samp2[1]);
642 samp2[1] = 1. - samp2[1];
643 v0 = sp->farg + 3*ptp->tri[i].vndx[0];
644 v1 = sp->farg + 3*ptp->tri[i].vndx[1];
645 v2 = sp->farg + 3*ptp->tri[i].vndx[2];
646 for (i = 3; i--; )
647 orig[i] = v0[i] + samp2[0]*(v1[i] - v0[i])
648 + samp2[1]*(v2[i] - v0[i]) ;
649 return(1);
650 memerr:
651 fputs(progname, stderr);
652 fputs(": out of memory in ssamp_poly!\n", stderr);
653 return(0);
654 }
655
656 /* Compute sample origin based on projected areas of sender subsurfaces */
657 static int
658 sample_origin(PARAMS *p, FVECT orig, const FVECT rdir, double x)
659 {
660 static double *projsa;
661 static int nall;
662 double tarea = 0;
663 int i;
664 SURF *sp;
665 /* special case for lone surface */
666 if (p->nsurfs == 1) {
667 sp = p->slist;
668 if (DOT(sp->snrm, rdir) >= -FTINY) {
669 fprintf(stderr,
670 "%s: internal - sample behind sender '%s'\n",
671 progname, sp->sname);
672 return(0);
673 }
674 return((*orig_in_surf[sp->styp])(orig, sp, x));
675 }
676 if (p->nsurfs > nall) { /* (re)allocate surface area cache */
677 if (projsa) free(projsa);
678 projsa = (double *)malloc(sizeof(double)*p->nsurfs);
679 if (!projsa) return(0);
680 nall = p->nsurfs;
681 }
682 /* compute projected areas */
683 for (i = 0, sp = p->slist; sp != NULL; i++, sp = sp->next) {
684 projsa[i] = -DOT(sp->snrm, rdir) * sp->area;
685 tarea += projsa[i] *= (double)(projsa[i] > FTINY);
686 }
687 if (tarea <= FTINY) { /* wrong side of sender? */
688 fputs(progname, stderr);
689 fputs(": internal - sample behind all sender elements!\n",
690 stderr);
691 return(0);
692 }
693 tarea *= x; /* get surface from list */
694 for (i = 0, sp = p->slist; tarea > projsa[i]; sp = sp->next)
695 tarea -= projsa[i++];
696 return((*orig_in_surf[sp->styp])(orig, sp, tarea/projsa[i]));
697 }
698
699 /* Uniform sample generator */
700 static int
701 sample_uniform(PARAMS *p, int b, FILE *fp)
702 {
703 int n = sampcnt;
704 double samp3[3];
705 double duvw[3];
706 FVECT orig_dir[2];
707 int i;
708
709 if (fp == NULL) /* just requesting number of bins? */
710 return(1);
711
712 while (n--) { /* stratified hemisphere sampling */
713 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
714 SDsquare2disk(duvw, samp3[1], samp3[2]);
715 duvw[2] = -sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
716 for (i = 3; i--; )
717 orig_dir[1][i] = duvw[0]*p->udir[i] +
718 duvw[1]*p->vdir[i] +
719 duvw[2]*p->nrm[i] ;
720 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
721 return(0);
722 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
723 return(0);
724 }
725 return(1);
726 }
727
728 /* Shirly-Chiu sample generator */
729 static int
730 sample_shirchiu(PARAMS *p, int b, FILE *fp)
731 {
732 int n = sampcnt;
733 double samp3[3];
734 double duvw[3];
735 FVECT orig_dir[2];
736 int i;
737
738 if (fp == NULL) /* just requesting number of bins? */
739 return(p->hsiz*p->hsiz);
740
741 while (n--) { /* stratified sampling */
742 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
743 SDsquare2disk(duvw, (b/p->hsiz + samp3[1])/curparams.hsiz,
744 (b%p->hsiz + samp3[2])/curparams.hsiz);
745 duvw[2] = sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
746 for (i = 3; i--; )
747 orig_dir[1][i] = -duvw[0]*p->udir[i] -
748 duvw[1]*p->vdir[i] -
749 duvw[2]*p->nrm[i] ;
750 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
751 return(0);
752 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
753 return(0);
754 }
755 return(1);
756 }
757
758 /* Reinhart/Tregenza sample generator */
759 static int
760 sample_reinhart(PARAMS *p, int b, FILE *fp)
761 {
762 #define T_NALT 7
763 static const int tnaz[T_NALT] = {30, 30, 24, 24, 18, 12, 6};
764 const int RowMax = T_NALT*p->hsiz + 1;
765 const double RAH = (.5*PI)/(RowMax-.5);
766 #define rnaz(r) (r >= RowMax-1 ? 1 : p->hsiz*tnaz[r/p->hsiz])
767 int n = sampcnt;
768 int row, col;
769 double samp3[3];
770 double alt, azi;
771 double duvw[3];
772 FVECT orig_dir[2];
773 int i;
774
775 if (fp == NULL) { /* just requesting number of bins? */
776 n = 0;
777 for (row = RowMax; row--; ) n += rnaz(row);
778 return(n);
779 }
780 row = 0; /* identify row & column */
781 col = b;
782 while (col >= rnaz(row)) {
783 col -= rnaz(row);
784 ++row;
785 }
786 while (n--) { /* stratified sampling */
787 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
788 alt = (row+samp3[1])*RAH;
789 azi = (2.*PI)*(col+samp3[2]-.5)/rnaz(row);
790 duvw[2] = cos(alt); /* measured from horizon */
791 duvw[0] = tcos(azi)*duvw[2];
792 duvw[1] = tsin(azi)*duvw[2];
793 duvw[2] = sqrt(1. - duvw[2]*duvw[2]);
794 for (i = 3; i--; )
795 orig_dir[1][i] = -duvw[0]*p->udir[i] -
796 duvw[1]*p->vdir[i] -
797 duvw[2]*p->nrm[i] ;
798 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
799 return(0);
800 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
801 return(0);
802 }
803 return(1);
804 #undef rnaz
805 #undef T_NALT
806 }
807
808 /* Klems sample generator */
809 static int
810 sample_klems(PARAMS *p, int b, FILE *fp)
811 {
812 static const char bname[4][20] = {
813 "LBNL/Klems Full",
814 "LBNL/Klems Half",
815 "INTERNAL ERROR",
816 "LBNL/Klems Quarter"
817 };
818 static ANGLE_BASIS *kbasis[4];
819 const int bi = p->hemis[1] - '1';
820 int n = sampcnt;
821 double samp2[2];
822 double duvw[3];
823 FVECT orig_dir[2];
824 int i;
825
826 if (!kbasis[bi]) { /* need to get basis, first */
827 for (i = 4; i--; )
828 if (!strcasecmp(abase_list[i].name, bname[bi])) {
829 kbasis[bi] = &abase_list[i];
830 break;
831 }
832 if (i < 0) {
833 fprintf(stderr, "%s: unknown hemisphere basis '%s'\n",
834 progname, bname[bi]);
835 return(0);
836 }
837 }
838 if (fp == NULL) /* just requesting number of bins? */
839 return(kbasis[bi]->nangles);
840
841 while (n--) { /* stratified sampling */
842 SDmultiSamp(samp2, 2, (n+frandom())/sampcnt);
843 if (!bo_getvec(duvw, b+samp2[1], kbasis[bi]))
844 return(0);
845 for (i = 3; i--; )
846 orig_dir[1][i] = duvw[0]*p->udir[i] +
847 duvw[1]*p->vdir[i] +
848 duvw[2]*p->nrm[i] ;
849 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp2[0]))
850 return(0);
851 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
852 return(0);
853 }
854 return(1);
855 }
856
857 /* Prepare hemisphere basis sampler that will send rays to rcontrib */
858 static int
859 prepare_sampler(void)
860 {
861 if (curparams.slist == NULL) { /* missing sample surface! */
862 fputs(progname, stderr);
863 fputs(": no sender surface!\n", stderr);
864 return(-1);
865 }
866 if (curparams.outfn != NULL) /* misplaced output file spec. */
867 fprintf(stderr, "%s: warning - ignoring output file in sender ('%s')\n",
868 progname, curparams.outfn);
869 /* check/set basis hemisphere */
870 if (!curparams.hemis[0]) {
871 fputs(progname, stderr);
872 fputs(": missing sender sampling type!\n", stderr);
873 return(-1);
874 }
875 if (normalize(curparams.nrm) == 0) {
876 fputs(progname, stderr);
877 fputs(": undefined normal for sender sampling\n", stderr);
878 return(-1);
879 }
880 if (normalize(curparams.vup) == 0) {
881 if (fabs(curparams.nrm[2]) < .7)
882 curparams.vup[2] = 1;
883 else
884 curparams.vup[1] = 1;
885 }
886 VCROSS(curparams.udir, curparams.vup, curparams.nrm);
887 if (normalize(curparams.udir) == 0) {
888 fputs(progname, stderr);
889 fputs(": up vector coincides with sender normal\n", stderr);
890 return(-1);
891 }
892 VCROSS(curparams.vdir, curparams.nrm, curparams.udir);
893 if (tolower(curparams.hemis[0]) == 'u' | curparams.hemis[0] == '1')
894 curparams.sample_basis = sample_uniform;
895 else if (tolower(curparams.hemis[0]) == 's' &&
896 tolower(curparams.hemis[1]) == 'c')
897 curparams.sample_basis = sample_shirchiu;
898 else if ((tolower(curparams.hemis[0]) == 'r') |
899 (tolower(curparams.hemis[0]) == 't'))
900 curparams.sample_basis = sample_reinhart;
901 else if (tolower(curparams.hemis[0]) == 'k') {
902 switch (curparams.hemis[1]) {
903 case '1':
904 case '2':
905 case '4':
906 break;
907 case 'f':
908 case 'F':
909 case '\0':
910 curparams.hemis[1] = '1';
911 break;
912 case 'h':
913 case 'H':
914 curparams.hemis[1] = '2';
915 break;
916 case 'q':
917 case 'Q':
918 curparams.hemis[1] = '4';
919 break;
920 default:
921 goto unrecognized;
922 }
923 curparams.hemis[2] = '\0';
924 curparams.sample_basis = sample_klems;
925 } else
926 goto unrecognized;
927 /* return number of bins */
928 return((*curparams.sample_basis)(&curparams,0,NULL));
929 unrecognized:
930 fprintf(stderr, "%s: unrecognized sender sampling: h=%s\n",
931 progname, curparams.hemis);
932 return(-1);
933 }
934
935 /* Compute normal and area for polygon */
936 static int
937 finish_polygon(SURF *p)
938 {
939 const int nv = p->nfargs / 3;
940 FVECT e1, e2, vc;
941 int i;
942
943 memset(p->snrm, 0, sizeof(FVECT));
944 VSUB(e1, p->farg+3, p->farg);
945 for (i = 2; i < nv; i++) {
946 VSUB(e2, p->farg+3*i, p->farg);
947 VCROSS(vc, e1, e2);
948 p->snrm[0] += vc[0];
949 p->snrm[1] += vc[1];
950 p->snrm[2] += vc[2];
951 VCOPY(e1, e2);
952 }
953 p->area = normalize(p->snrm)*0.5;
954 return(p->area > FTINY);
955 }
956
957 /* Add a surface to our current parameters */
958 static void
959 add_surface(int st, const char *oname, FILE *fp)
960 {
961 SURF *snew;
962 int n;
963 /* get floating-point arguments */
964 if (!fscanf(fp, "%d", &n)) return;
965 while (n-- > 0) fscanf(fp, "%*s");
966 if (!fscanf(fp, "%d", &n)) return;
967 while (n-- > 0) fscanf(fp, "%*d");
968 if (!fscanf(fp, "%d", &n) || n <= 0) return;
969 snew = (SURF *)malloc(sizeof(SURF) + sizeof(double)*(n-1));
970 if (snew == NULL) {
971 fputs(progname, stderr);
972 fputs(": out of memory!\n", stderr);
973 exit(1);
974 }
975 strncpy(snew->sname, oname, sizeof(snew->sname)-1);
976 snew->sname[sizeof(snew->sname)-1] = '\0';
977 snew->styp = st;
978 snew->priv = NULL;
979 snew->nfargs = n;
980 for (n = 0; n < snew->nfargs; n++)
981 if (fscanf(fp, "%lf", &snew->farg[n]) != 1) {
982 fprintf(stderr, "%s: error reading arguments for '%s'\n",
983 progname, oname);
984 exit(1);
985 }
986 switch (st) {
987 case ST_RING:
988 if (snew->nfargs != 8)
989 goto badcount;
990 VCOPY(snew->snrm, snew->farg+3);
991 if (normalize(snew->snrm) == 0)
992 goto badnorm;
993 if (snew->farg[7] < snew->farg[6]) {
994 double t = snew->farg[7];
995 snew->farg[7] = snew->farg[6];
996 snew->farg[6] = t;
997 }
998 snew->area = PI*(snew->farg[7]*snew->farg[7] -
999 snew->farg[6]*snew->farg[6]);
1000 break;
1001 case ST_POLY:
1002 if (snew->nfargs < 9 || snew->nfargs % 3)
1003 goto badcount;
1004 finish_polygon(snew);
1005 break;
1006 case ST_SOURCE:
1007 if (snew->nfargs != 4)
1008 goto badcount;
1009 for (n = 3; n--; ) /* need to reverse "normal" */
1010 snew->snrm[n] = -snew->farg[n];
1011 if (normalize(snew->snrm) == 0)
1012 goto badnorm;
1013 snew->area = sin((PI/180./2.)*snew->farg[3]);
1014 snew->area *= PI*snew->area;
1015 break;
1016 }
1017 if (snew->area <= FTINY) {
1018 fprintf(stderr, "%s: warning - zero area for surface '%s'\n",
1019 progname, oname);
1020 free(snew);
1021 return;
1022 }
1023 VSUM(curparams.nrm, curparams.nrm, snew->snrm, snew->area);
1024 snew->next = curparams.slist;
1025 curparams.slist = snew;
1026 curparams.nsurfs++;
1027 return;
1028 badcount:
1029 fprintf(stderr, "%s: bad argument count for surface element '%s'\n",
1030 progname, oname);
1031 exit(1);
1032 badnorm:
1033 fprintf(stderr, "%s: bad orientation for surface element '%s'\n",
1034 progname, oname);
1035 exit(1);
1036 }
1037
1038 /* Parse a receiver object (look for modifiers to add to rcontrib command) */
1039 static int
1040 add_recv_object(FILE *fp)
1041 {
1042 int st;
1043 char thismod[128], otype[32], oname[128];
1044 int n;
1045
1046 if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3)
1047 return(0); /* must have hit EOF! */
1048 if (!strcmp(otype, "alias")) {
1049 fscanf(fp, "%*s"); /* skip alias */
1050 return(0);
1051 }
1052 /* is it a new receiver? */
1053 if ((st = surf_type(otype)) != ST_NONE) {
1054 if (curparams.slist != NULL && (st == ST_SOURCE) ^
1055 (curparams.slist->styp == ST_SOURCE)) {
1056 fputs(progname, stderr);
1057 fputs(": cannot mix source/non-source receivers!\n", stderr);
1058 return(-1);
1059 }
1060 if (strcmp(thismod, curmod)) {
1061 if (curmod[0]) { /* output last receiver? */
1062 finish_receiver();
1063 clear_params(&curparams, 1);
1064 }
1065 parse_params(&curparams, newparams);
1066 newparams[0] = '\0';
1067 strcpy(curmod, thismod);
1068 }
1069 add_surface(st, oname, fp); /* read & store surface */
1070 return(1);
1071 }
1072 /* else skip arguments */
1073 if (!fscanf(fp, "%d", &n)) return(0);
1074 while (n-- > 0) fscanf(fp, "%*s");
1075 if (!fscanf(fp, "%d", &n)) return(0);
1076 while (n-- > 0) fscanf(fp, "%*d");
1077 if (!fscanf(fp, "%d", &n)) return(0);
1078 while (n-- > 0) fscanf(fp, "%*f");
1079 return(0);
1080 }
1081
1082 /* Parse a sender object */
1083 static int
1084 add_send_object(FILE *fp)
1085 {
1086 int st;
1087 char otype[32], oname[128];
1088 int n;
1089
1090 if (fscanf(fp, "%*s %s %s", otype, oname) != 2)
1091 return(0); /* must have hit EOF! */
1092 if (!strcmp(otype, "alias")) {
1093 fscanf(fp, "%*s"); /* skip alias */
1094 return(0);
1095 }
1096 /* is it a new surface? */
1097 if ((st = surf_type(otype)) != ST_NONE) {
1098 if (st == ST_SOURCE) {
1099 fputs(progname, stderr);
1100 fputs(": cannot use source as a sender!\n", stderr);
1101 return(-1);
1102 }
1103 parse_params(&curparams, newparams);
1104 newparams[0] = '\0';
1105 add_surface(st, oname, fp); /* read & store surface */
1106 return(0);
1107 }
1108 /* else skip arguments */
1109 if (!fscanf(fp, "%d", &n)) return(0);
1110 while (n-- > 0) fscanf(fp, "%*s");
1111 if (!fscanf(fp, "%d", &n)) return(0);
1112 while (n-- > 0) fscanf(fp, "%*d");
1113 if (!fscanf(fp, "%d", &n)) return(0);
1114 while (n-- > 0) fscanf(fp, "%*f");
1115 return(0);
1116 }
1117
1118 /* Load a Radiance scene using the given callback function for objects */
1119 static int
1120 load_scene(const char *inspec, int (*ocb)(FILE *))
1121 {
1122 int rv = 0;
1123 char inpbuf[1024];
1124 FILE *fp;
1125 int c;
1126
1127 if (*inspec == '!')
1128 fp = popen(inspec+1, "r");
1129 else
1130 fp = fopen(inspec, "r");
1131 if (fp == NULL) {
1132 fprintf(stderr, "%s: cannot load '%s'\n", progname, inspec);
1133 return(-1);
1134 }
1135 while ((c = getc(fp)) != EOF) { /* load receiver data */
1136 if (isspace(c)) /* skip leading white space */
1137 continue;
1138 if (c == '!') { /* read from a new command */
1139 inpbuf[0] = c;
1140 if (fgetline(inpbuf+1, sizeof(inpbuf)-1, fp) != NULL) {
1141 if ((c = load_scene(inpbuf, ocb)) < 0)
1142 return(c);
1143 rv += c;
1144 }
1145 continue;
1146 }
1147 if (c == '#') { /* parameters/comment */
1148 if ((c = getc(fp)) == EOF || ungetc(c,fp) == EOF)
1149 break;
1150 if (!isspace(c) && fscanf(fp, "%s", inpbuf) == 1 &&
1151 !strcmp(inpbuf, PARAMSTART)) {
1152 if (fgets(inpbuf, sizeof(inpbuf), fp) != NULL)
1153 strcat(newparams, inpbuf);
1154 continue;
1155 }
1156 while ((c = getc(fp)) != EOF && c != '\n')
1157 ; /* else skipping comment */
1158 continue;
1159 }
1160 ungetc(c, fp); /* else check object for receiver */
1161 c = (*ocb)(fp);
1162 if (c < 0)
1163 return(c);
1164 rv += c;
1165 }
1166 /* close our input stream */
1167 c = (*inspec == '!') ? pclose(fp) : fclose(fp);
1168 if (c != 0) {
1169 fprintf(stderr, "%s: error loading '%s'\n", progname, inspec);
1170 return(-1);
1171 }
1172 return(rv);
1173 }
1174
1175 /* Get command arguments and run program */
1176 int
1177 main(int argc, char *argv[])
1178 {
1179 char fmtopt[6] = "-faa"; /* default output is ASCII */
1180 char *xrs=NULL, *yrs=NULL, *ldopt=NULL;
1181 char *iropt = NULL;
1182 char *sendfn;
1183 char sampcntbuf[32], nsbinbuf[32];
1184 FILE *rcfp;
1185 int nsbins;
1186 int a, i;
1187 /* screen rcontrib options */
1188 progname = argv[0];
1189 for (a = 1; a < argc-2; a++) {
1190 int na;
1191 /* check for argument expansion */
1192 while ((na = expandarg(&argc, &argv, a)) > 0)
1193 ;
1194 if (na < 0) {
1195 fprintf(stderr, "%s: cannot expand '%s'\n",
1196 progname, argv[a]);
1197 return(1);
1198 }
1199 if (argv[a][0] != '-' || !argv[a][1])
1200 break;
1201 na = 1;
1202 switch (argv[a][1]) { /* !! Keep consistent !! */
1203 case 'v': /* verbose mode */
1204 verbose = !verbose;
1205 na = 0;
1206 continue;
1207 case 'f': /* special case for -fo, -ff, etc. */
1208 switch (argv[a][2]) {
1209 case '\0': /* cal file */
1210 goto userr;
1211 case 'o': /* force output */
1212 goto userr;
1213 case 'a': /* output format */
1214 case 'f':
1215 case 'd':
1216 case 'c':
1217 if (!(fmtopt[3] = argv[a][3]))
1218 fmtopt[3] = argv[a][2];
1219 fmtopt[2] = argv[a][2];
1220 na = 0;
1221 continue; /* will pass later */
1222 default:
1223 goto userr;
1224 }
1225 break;
1226 case 'x': /* x-resolution */
1227 xrs = argv[++a];
1228 na = 0;
1229 continue;
1230 case 'y': /* y-resolution */
1231 yrs = argv[++a];
1232 na = 0;
1233 continue;
1234 case 'c': /* number of samples */
1235 sampcnt = atoi(argv[++a]);
1236 if (sampcnt <= 0)
1237 goto userr;
1238 na = 0; /* we re-add this later */
1239 continue;
1240 case 'I': /* only for pass-through mode */
1241 case 'i':
1242 iropt = argv[a];
1243 na = 0;
1244 continue;
1245 case 'V': /* options without arguments */
1246 case 'w':
1247 case 'u':
1248 case 'h':
1249 case 'r':
1250 break;
1251 case 'n': /* options with 1 argument */
1252 case 's':
1253 case 'o':
1254 na = 2;
1255 break;
1256 case 'b': /* special case */
1257 if (argv[a][2] != 'v') goto userr;
1258 break;
1259 case 'l': /* special case */
1260 if (argv[a][2] == 'd') {
1261 ldopt = argv[a];
1262 na = 0;
1263 continue;
1264 }
1265 na = 2;
1266 break;
1267 case 'd': /* special case */
1268 if (argv[a][2] != 'v') na = 2;
1269 break;
1270 case 'a': /* special case */
1271 na = (argv[a][2] == 'v') ? 4 : 2;
1272 break;
1273 case 'm': /* special case */
1274 if (!argv[a][2]) goto userr;
1275 na = (argv[a][2] == 'e') | (argv[a][2] == 'a') ? 4 : 2;
1276 break;
1277 default: /* anything else is verbotten */
1278 goto userr;
1279 }
1280 if (na <= 0) continue;
1281 CHECKARGC(na); /* pass on option */
1282 rcarg[nrcargs++] = argv[a];
1283 while (--na) /* + arguments if any */
1284 rcarg[nrcargs++] = argv[++a];
1285 }
1286 if (a > argc-2)
1287 goto userr; /* check at end of options */
1288 sendfn = argv[a++]; /* assign sender & receiver inputs */
1289 if (sendfn[0] == '-') { /* user wants pass-through mode? */
1290 if (sendfn[1]) goto userr;
1291 sendfn = NULL;
1292 if (iropt) {
1293 CHECKARGC(1);
1294 rcarg[nrcargs++] = iropt;
1295 }
1296 if (xrs) {
1297 CHECKARGC(2);
1298 rcarg[nrcargs++] = "-x";
1299 rcarg[nrcargs++] = xrs;
1300 }
1301 if (yrs) {
1302 CHECKARGC(2);
1303 rcarg[nrcargs++] = "-y";
1304 rcarg[nrcargs++] = yrs;
1305 }
1306 if (ldopt) {
1307 CHECKARGC(1);
1308 rcarg[nrcargs++] = ldopt;
1309 }
1310 if (sampcnt <= 0) sampcnt = 1;
1311 } else { /* else in sampling mode */
1312 if (iropt) {
1313 fputs(progname, stderr);
1314 fputs(": -i, -I supported for pass-through only\n", stderr);
1315 return(1);
1316 }
1317 fmtopt[2] = (sizeof(RREAL)==sizeof(double)) ? 'd' : 'f';
1318 if (sampcnt <= 0) sampcnt = 10000;
1319 }
1320 sprintf(sampcntbuf, "%d", sampcnt);
1321 CHECKARGC(3); /* add our format & sample count */
1322 rcarg[nrcargs++] = fmtopt;
1323 rcarg[nrcargs++] = "-c";
1324 rcarg[nrcargs++] = sampcntbuf;
1325 /* add receiver arguments to rcontrib */
1326 if (load_scene(argv[a], add_recv_object) < 0)
1327 return(1);
1328 finish_receiver();
1329 if (sendfn == NULL) { /* pass-through mode? */
1330 CHECKARGC(1); /* add octree */
1331 rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1332 rcarg[nrcargs] = NULL;
1333 return(my_exec(rcarg)); /* rcontrib does everything */
1334 }
1335 clear_params(&curparams, 0); /* else load sender surface & params */
1336 if (load_scene(sendfn, add_send_object) < 0)
1337 return(1);
1338 if ((nsbins = prepare_sampler()) <= 0)
1339 return(1);
1340 CHECKARGC(3); /* add row count and octree */
1341 rcarg[nrcargs++] = "-y";
1342 sprintf(nsbinbuf, "%d", nsbins);
1343 rcarg[nrcargs++] = nsbinbuf;
1344 rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1345 rcarg[nrcargs] = NULL;
1346 /* open pipe to rcontrib process */
1347 if ((rcfp = popen_arglist(rcarg, "w")) == NULL)
1348 return(1);
1349 SET_FILE_BINARY(rcfp);
1350 #ifdef getc_unlocked
1351 flockfile(rcfp);
1352 #endif
1353 if (verbose) {
1354 fprintf(stderr, "%s: sampling %d directions", progname, nsbins);
1355 if (curparams.nsurfs > 1)
1356 fprintf(stderr, " (%d elements)\n", curparams.nsurfs);
1357 else
1358 fputc('\n', stderr);
1359 }
1360 for (i = 0; i < nsbins; i++) /* send rcontrib ray samples */
1361 if (!(*curparams.sample_basis)(&curparams, i, rcfp))
1362 return(1);
1363 return(pclose(rcfp) == 0); /* all finished! */
1364 userr:
1365 if (a < argc-2)
1366 fprintf(stderr, "%s: unsupported option '%s'", progname, argv[a]);
1367 fprintf(stderr, "Usage: %s [-v][rcontrib options] sender.rad receiver.rad [-i system.oct] [system.rad ..]\n",
1368 progname);
1369 return(1);
1370 }
