--- ray/src/util/rfluxmtx.c 2014/07/25 16:58:20 2.9 +++ ray/src/util/rfluxmtx.c 2021/12/15 01:38:50 2.54 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rfluxmtx.c,v 2.9 2014/07/25 16:58:20 greg Exp $"; +static const char RCSid[] = "$Id: rfluxmtx.c,v 2.54 2021/12/15 01:38:50 greg Exp $"; #endif /* * Calculate flux transfer matrix or matrices using rcontrib @@ -11,31 +11,20 @@ static const char RCSid[] = "$Id: rfluxmtx.c,v 2.9 201 #include #include "rtio.h" #include "rtmath.h" +#include "rtprocess.h" #include "bsdf.h" #include "bsdf_m.h" #include "random.h" #include "triangulate.h" #include "platform.h" -#ifdef getc_unlocked /* avoid horrendous overhead of flockfile */ -#undef getc -#define getc getc_unlocked +#ifndef MAXRCARG +#define MAXRCARG 10000 #endif -#ifdef _WIN32 -#define SPECIALS " \t\"$*?" -#define QUOTCHAR '"' -#else -#define SPECIALS " \t\n'\"()${}*?[];|&" -#define QUOTCHAR '\'' -#define ALTQUOT '"' -#endif - -#define MAXRCARG 512 - char *progname; /* global argv[0] */ -int verbose = 0; /* verbose mode? */ +int verbose = 0; /* verbose mode (< 0 no warnings) */ char *rcarg[MAXRCARG+1] = {"rcontrib", "-fo+"}; int nrcargs = 2; @@ -77,19 +66,20 @@ typedef struct { FVECT uva[2]; /* tangent axes */ int ntris; /* number of triangles */ struct ptri { - float afrac; /* fraction of total area */ + double afrac; /* fraction of total area */ short vndx[3]; /* vertex indices */ } tri[1]; /* triangle array (extends struct) */ } POLYTRIS; /* triangulated polygon */ typedef struct param_s { - char hemis[32]; /* hemispherical sampling spec. */ + char sign; /* '-' for axis reversal */ + char hemis[31]; /* hemispherical sampling spec. */ int hsiz; /* hemisphere basis size */ int nsurfs; /* number of surfaces */ SURF *slist; /* list of surfaces */ FVECT vup; /* up vector (zero if unset) */ FVECT nrm; /* average normal direction */ - FVECT udir, vdir; /* v-up tangent axes */ + FVECT udir, vdir; /* tangent axes */ char *outfn; /* output file name (receiver) */ int (*sample_basis)(struct param_s *p, int, FILE *); } PARAMS; /* sender/receiver parameters */ @@ -144,73 +134,52 @@ surf_type(const char *otype) static char * oconv_command(int ac, char *av[]) { - static char oconvbuf[2048] = "!oconv -f"; - char *cp = oconvbuf + 9; - - while (ac-- > 0) { - if (cp >= oconvbuf+(sizeof(oconvbuf)-32)) { - fputs(progname, stderr); - fputs(": too many file arguments!\n", stderr); - exit(1); - } - *cp++ = ' '; - strcpy(cp, *av++); - while (*cp) cp++; + static char oconvbuf[2048] = "!oconv -f "; + char *cp = oconvbuf + 10; + char *recv = *av++; + + if (ac-- <= 0) + return(NULL); + if (verbose < 0) { /* turn off warnings */ + strcpy(cp, "-w "); + cp += 3; } - *cp = '\0'; - return(oconvbuf); -} - -/* Check if any of the characters in str2 are found in str1 */ -static int -matchany(const char *str1, const char *str2) -{ - while (*str1) { - const char *cp = str2; - while (*cp) - if (*cp++ == *str1) - return(*str1); - ++str1; - } - return(0); -} - - -/* Convert a set of arguments into a command line for pipe() or system() */ -static char * -convert_commandline(char *cmd, const int len, char *av[]) -{ - int match; - char *cp; - - for (cp = cmd; *av != NULL; av++) { - const int n = strlen(*av); - if (cp+n >= cmd+(len-3)) { - fputs(progname, stderr); - return(NULL); - } - if ((match = matchany(*av, SPECIALS))) { - const int quote = -#ifdef ALTQUOT - (match == QUOTCHAR) ? ALTQUOT : -#endif - QUOTCHAR; - *cp++ = quote; - strcpy(cp, *av); - cp += n; - *cp++ = quote; + while (ac-- > 0) { /* copy each argument */ + int len = strlen(*av); + if (cp+len+4 >= oconvbuf+sizeof(oconvbuf)) + goto overrun; + if (matchany(*av, SPECIALS)) { + *cp++ = QUOTCHAR; + strcpy(cp, *av++); + cp += len; + *cp++ = QUOTCHAR; } else { - strcpy(cp, *av); - cp += n; + strcpy(cp, *av++); + cp += len; } *cp++ = ' '; } - if (cp <= cmd) - return(NULL); - *--cp = '\0'; - return(cmd); + /* receiver goes last */ + if (matchany(recv, SPECIALS)) { + *cp++ = QUOTCHAR; + while (*recv) { + if (cp >= oconvbuf+(sizeof(oconvbuf)-3)) + goto overrun; + *cp++ = *recv++; + } + *cp++ = QUOTCHAR; + *cp = '\0'; + } else + strcpy(cp, recv); + return(oconvbuf); +overrun: + fputs(progname, stderr); + fputs(": too many file arguments!\n", stderr); + exit(1); } +#if defined(_WIN32) || defined(_WIN64) + /* Open a pipe to/from a command given as an argument list */ static FILE * popen_arglist(char *av[], char *mode) @@ -222,13 +191,14 @@ popen_arglist(char *av[], char *mode) fputs(": command line too long in popen_arglist()\n", stderr); return(NULL); } - if (verbose) + if (verbose > 0) fprintf(stderr, "%s: opening pipe %s: %s\n", progname, (*mode=='w') ? "to" : "from", cmd); return(popen(cmd, mode)); } -#ifdef _WIN32 +#define pclose_al pclose + /* Execute system command (Windows version) */ static int my_exec(char *av[]) @@ -240,11 +210,60 @@ my_exec(char *av[]) fputs(": command line too long in my_exec()\n", stderr); return(1); } - if (verbose) + if (verbose > 0) fprintf(stderr, "%s: running: %s\n", progname, cmd); return(system(cmd)); } -#else + +#else /* UNIX */ + +static SUBPROC rt_proc = SP_INACTIVE; /* we only support one of these */ + +/* Open a pipe to a command using an argument list */ +static FILE * +popen_arglist(char *av[], char *mode) +{ + int fd; + + if (rt_proc.pid > 0) { + fprintf(stderr, "%s: only one i/o pipe at a time!\n", progname); + return(NULL); + } + if (verbose > 0) { + char cmd[4096]; + if (!convert_commandline(cmd, sizeof(cmd), av)) + strcpy(cmd, "COMMAND TOO LONG TO SHOW"); + fprintf(stderr, "%s: opening pipe %s: %s\n", + progname, (*mode=='w') ? "to" : "from", cmd); + } + if (*mode == 'w') { + fd = rt_proc.w = dup(fileno(stdout)); + rt_proc.flags |= PF_FILT_OUT; + } else if (*mode == 'r') { + fd = rt_proc.r = dup(fileno(stdin)); + rt_proc.flags |= PF_FILT_INP; + } + if (fd < 0 || open_process(&rt_proc, av) <= 0) { + perror(av[0]); + return(NULL); + } + return(fdopen(fd, mode)); +} + +/* Close command pipe (returns -1 on error to match pclose) */ +static int +pclose_al(FILE *fp) +{ + int prob = (fclose(fp) == EOF); + + if (rt_proc.pid <= 0) + return(-1); + + prob |= (close_process(&rt_proc) != 0); + + return(-prob); +} + /* Execute system command in our stead (Unix version) */ static int my_exec(char *av[]) @@ -255,7 +274,7 @@ my_exec(char *av[]) fprintf(stderr, "%s: cannot locate %s\n", progname, av[0]); return(1); } - if (verbose) { + if (verbose > 0) { char cmd[4096]; if (!convert_commandline(cmd, sizeof(cmd), av)) strcpy(cmd, "COMMAND TOO LONG TO SHOW"); @@ -265,6 +284,7 @@ my_exec(char *av[]) perror(compath); return(1); } + #endif /* Get normalized direction vector from string specification */ @@ -313,13 +333,18 @@ parse_params(PARAMS *p, char *pargs) { char *cp = pargs; int nparams = 0; + int quot; int i; - for ( ; ; ) + for ( ; ; ) { switch (*cp++) { case 'h': if (*cp++ != '=') break; + if ((*cp == '+') | (*cp == '-')) + p->sign = *cp++; + else + p->sign = '+'; p->hsiz = 0; i = 0; while (*cp && !isspace(*cp)) { @@ -338,19 +363,30 @@ parse_params(PARAMS *p, char *pargs) break; if (!get_direction(p->vup, cp)) break; + while (*cp && !isspace(*cp++)) + ; ++nparams; continue; case 'o': if (*cp++ != '=') break; + quot = 0; + if ((*cp == '"') | (*cp == '\'')) + quot = *cp++; i = 0; - while (*cp && !isspace(*cp++)) - i++; + while (*cp && (quot ? (*cp != quot) : !isspace(*cp))) { + i++; cp++; + } if (!i) break; - *--cp = '\0'; + if (!*cp) { + if (quot) + break; + cp[1] = '\0'; + } + *cp = '\0'; p->outfn = savqstr(cp-i); - *cp++ = ' '; + *cp++ = quot ? quot : ' '; ++nparams; continue; case ' ': @@ -363,7 +399,9 @@ parse_params(PARAMS *p, char *pargs) default: break; } - fprintf(stderr, "%s: bad parameter string '%s'\n", progname, pargs); + break; + } + fprintf(stderr, "%s: bad parameter string: %s", progname, pargs); exit(1); return(-1); /* pro forma return */ } @@ -401,14 +439,18 @@ finish_receiver(void) fputs(": undefined normal for hemisphere sampling\n", stderr); exit(1); } - if (normalize(curparams.vup) == 0) + if (normalize(curparams.vup) == 0) { if (fabs(curparams.nrm[2]) < .7) curparams.vup[2] = 1; else curparams.vup[1] = 1; + } /* determine sample type/bin */ - if (tolower(curparams.hemis[0]) == 'u' | curparams.hemis[0] == '1') { - binv = "0"; /* uniform sampling -- one bin */ + if ((tolower(curparams.hemis[0]) == 'u') | (curparams.hemis[0] == '1')) { + sprintf(sbuf, "if(-Dx*%g-Dy*%g-Dz*%g,0,-1)", + curparams.nrm[0], curparams.nrm[1], curparams.nrm[2]); + binv = savqstr(sbuf); + nbins = "1"; /* uniform sampling -- one bin */ uniform = 1; } else if (tolower(curparams.hemis[0]) == 's' && tolower(curparams.hemis[1]) == 'c') { @@ -419,20 +461,22 @@ finish_receiver(void) exit(1); } calfn = shirchiufn; shirchiufn = NULL; - sprintf(sbuf, "SCdim=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g", + sprintf(sbuf, "SCdim=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1", curparams.hsiz, curparams.nrm[0], curparams.nrm[1], curparams.nrm[2], - curparams.vup[0], curparams.vup[1], curparams.vup[2]); + curparams.vup[0], curparams.vup[1], curparams.vup[2], + curparams.sign); params = savqstr(sbuf); binv = "scbin"; nbins = "SCdim*SCdim"; } else if ((tolower(curparams.hemis[0]) == 'r') | (tolower(curparams.hemis[0]) == 't')) { calfn = reinhfn; reinhfn = NULL; - sprintf(sbuf, "MF=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g", + sprintf(sbuf, "MF=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1", curparams.hsiz, curparams.nrm[0], curparams.nrm[1], curparams.nrm[2], - curparams.vup[0], curparams.vup[1], curparams.vup[2]); + curparams.vup[0], curparams.vup[1], curparams.vup[2], + curparams.sign); params = savqstr(sbuf); binv = "rbin"; nbins = "Nrbins"; @@ -460,6 +504,10 @@ finish_receiver(void) progname, curparams.hemis); exit(1); } + if (tolower(curparams.hemis[0]) == 'k') { + sprintf(sbuf, "RHS=%c1", curparams.sign); + params = savqstr(sbuf); + } if (!uniform & (curparams.slist->styp == ST_SOURCE)) { SURF *sp; for (sp = curparams.slist; sp != NULL; sp = sp->next) @@ -507,21 +555,12 @@ make_axes(FVECT uva[2], const FVECT nrm) { int i; - uva[1][0] = 0.5 - frandom(); - uva[1][1] = 0.5 - frandom(); - uva[1][2] = 0.5 - frandom(); - for (i = 3; i--; ) - if ((-0.6 < nrm[i]) & (nrm[i] < 0.6)) - break; - if (i < 0) { + if (!getperpendicular(uva[0], nrm, 1)) { fputs(progname, stderr); fputs(": bad surface normal in make_axes!\n", stderr); exit(1); } - uva[1][i] = 1.0; - VCROSS(uva[0], uva[1], nrm); - normalize(uva[0]); - VCROSS(uva[1], nrm, uva[0]); + fcross(uva[1], nrm, uva[0]); } /* Illegal sender surfaces end up here */ @@ -630,7 +669,7 @@ ssamp_poly(FVECT orig, SURF *sp, double x) sp->priv = (void *)ptp; } /* pick triangle by partial area */ - for (i = 0; i < ptp->ntris && x > ptp->tri[i].afrac; i++) + for (i = 0; i < ptp->ntris-1 && x > ptp->tri[i].afrac; i++) x -= ptp->tri[i].afrac; SDmultiSamp(samp2, 2, x/ptp->tri[i].afrac); samp2[0] *= samp2[1] = sqrt(samp2[1]); @@ -660,7 +699,7 @@ sample_origin(PARAMS *p, FVECT orig, const FVECT rdir, /* special case for lone surface */ if (p->nsurfs == 1) { sp = p->slist; - if (DOT(sp->snrm, rdir) >= -FTINY) { + if (DOT(sp->snrm, rdir) >= FTINY) { fprintf(stderr, "%s: internal - sample behind sender '%s'\n", progname, sp->sname); @@ -671,15 +710,19 @@ sample_origin(PARAMS *p, FVECT orig, const FVECT rdir, if (p->nsurfs > nall) { /* (re)allocate surface area cache */ if (projsa) free(projsa); projsa = (double *)malloc(sizeof(double)*p->nsurfs); - if (!projsa) return(0); + if (projsa == NULL) { + fputs(progname, stderr); + fputs(": out of memory in sample_origin!\n", stderr); + exit(1); + } nall = p->nsurfs; } /* compute projected areas */ for (i = 0, sp = p->slist; sp != NULL; i++, sp = sp->next) { projsa[i] = -DOT(sp->snrm, rdir) * sp->area; - tarea += projsa[i] *= (double)(projsa[i] > FTINY); + tarea += projsa[i] *= (double)(projsa[i] > 0); } - if (tarea <= FTINY) { /* wrong side of sender? */ + if (tarea < FTINY*FTINY) { /* wrong side of sender? */ fputs(progname, stderr); fputs(": internal - sample behind all sender elements!\n", stderr); @@ -697,8 +740,7 @@ sample_uniform(PARAMS *p, int b, FILE *fp) { int n = sampcnt; double samp3[3]; - double duvw[3]; - FVECT orig_dir[2]; + FVECT duvw, orig_dir[2]; int i; if (fp == NULL) /* just requesting number of bins? */ @@ -706,7 +748,7 @@ sample_uniform(PARAMS *p, int b, FILE *fp) while (n--) { /* stratified hemisphere sampling */ SDmultiSamp(samp3, 3, (n+frandom())/sampcnt); - SDsquare2disk(duvw, samp3[1], samp3[2]); + square2disk(duvw, samp3[1], samp3[2]); duvw[2] = -sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]); for (i = 3; i--; ) orig_dir[1][i] = duvw[0]*p->udir[i] + @@ -714,7 +756,7 @@ sample_uniform(PARAMS *p, int b, FILE *fp) duvw[2]*p->nrm[i] ; if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0])) return(0); - if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2) + if (putbinary(orig_dir, sizeof(FVECT), 2, fp) != 2) return(0); } return(1); @@ -726,8 +768,7 @@ sample_shirchiu(PARAMS *p, int b, FILE *fp) { int n = sampcnt; double samp3[3]; - double duvw[3]; - FVECT orig_dir[2]; + FVECT duvw, orig_dir[2]; int i; if (fp == NULL) /* just requesting number of bins? */ @@ -735,7 +776,7 @@ sample_shirchiu(PARAMS *p, int b, FILE *fp) while (n--) { /* stratified sampling */ SDmultiSamp(samp3, 3, (n+frandom())/sampcnt); - SDsquare2disk(duvw, (b/p->hsiz + samp3[1])/curparams.hsiz, + square2disk(duvw, (b/p->hsiz + samp3[1])/curparams.hsiz, (b%p->hsiz + samp3[2])/curparams.hsiz); duvw[2] = sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]); for (i = 3; i--; ) @@ -744,7 +785,7 @@ sample_shirchiu(PARAMS *p, int b, FILE *fp) duvw[2]*p->nrm[i] ; if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0])) return(0); - if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2) + if (putbinary(orig_dir, sizeof(FVECT), 2, fp) != 2) return(0); } return(1); @@ -780,11 +821,13 @@ sample_reinhart(PARAMS *p, int b, FILE *fp) } while (n--) { /* stratified sampling */ SDmultiSamp(samp3, 3, (n+frandom())/sampcnt); + if (row >= RowMax-1) /* avoid crowding at zenith */ + samp3[1] *= samp3[1]; alt = (row+samp3[1])*RAH; azi = (2.*PI)*(col+samp3[2]-.5)/rnaz(row); duvw[2] = cos(alt); /* measured from horizon */ - duvw[0] = tcos(azi)*duvw[2]; - duvw[1] = tsin(azi)*duvw[2]; + duvw[0] = tsin(azi)*duvw[2]; + duvw[1] = -tcos(azi)*duvw[2]; duvw[2] = sqrt(1. - duvw[2]*duvw[2]); for (i = 3; i--; ) orig_dir[1][i] = -duvw[0]*p->udir[i] - @@ -792,7 +835,7 @@ sample_reinhart(PARAMS *p, int b, FILE *fp) duvw[2]*p->nrm[i] ; if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0])) return(0); - if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2) + if (putbinary(orig_dir, sizeof(FVECT), 2, fp) != 2) return(0); } return(1); @@ -835,15 +878,15 @@ sample_klems(PARAMS *p, int b, FILE *fp) while (n--) { /* stratified sampling */ SDmultiSamp(samp2, 2, (n+frandom())/sampcnt); - if (!bo_getvec(duvw, b+samp2[1], kbasis[bi])) + if (!fo_getvec(duvw, b+samp2[1], kbasis[bi])) return(0); for (i = 3; i--; ) - orig_dir[1][i] = duvw[0]*p->udir[i] + - duvw[1]*p->vdir[i] + + orig_dir[1][i] = -duvw[0]*p->udir[i] - + duvw[1]*p->vdir[i] - duvw[2]*p->nrm[i] ; if (!sample_origin(p, orig_dir[0], orig_dir[1], samp2[0])) return(0); - if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2) + if (putbinary(orig_dir, sizeof(FVECT), 2, fp) != 2) return(0); } return(1); @@ -858,7 +901,8 @@ prepare_sampler(void) fputs(": no sender surface!\n", stderr); return(-1); } - if (curparams.outfn != NULL) /* misplaced output file spec. */ + /* misplaced output file spec. */ + if ((curparams.outfn != NULL) & (verbose >= 0)) fprintf(stderr, "%s: warning - ignoring output file in sender ('%s')\n", progname, curparams.outfn); /* check/set basis hemisphere */ @@ -872,19 +916,25 @@ prepare_sampler(void) fputs(": undefined normal for sender sampling\n", stderr); return(-1); } - if (normalize(curparams.vup) == 0) + if (normalize(curparams.vup) == 0) { if (fabs(curparams.nrm[2]) < .7) curparams.vup[2] = 1; else curparams.vup[1] = 1; - VCROSS(curparams.udir, curparams.vup, curparams.nrm); + } + fcross(curparams.udir, curparams.vup, curparams.nrm); if (normalize(curparams.udir) == 0) { fputs(progname, stderr); fputs(": up vector coincides with sender normal\n", stderr); return(-1); } - VCROSS(curparams.vdir, curparams.nrm, curparams.udir); - if (tolower(curparams.hemis[0]) == 'u' | curparams.hemis[0] == '1') + fcross(curparams.vdir, curparams.nrm, curparams.udir); + if (curparams.sign == '-') { /* left-handed coordinate system? */ + curparams.udir[0] *= -1.; + curparams.udir[1] *= -1.; + curparams.udir[2] *= -1.; + } + if ((tolower(curparams.hemis[0]) == 'u') | (curparams.hemis[0] == '1')) curparams.sample_basis = sample_uniform; else if (tolower(curparams.hemis[0]) == 's' && tolower(curparams.hemis[1]) == 'c') @@ -945,7 +995,7 @@ finish_polygon(SURF *p) VCOPY(e1, e2); } p->area = normalize(p->snrm)*0.5; - return(p->area > FTINY); + return(p->area > FTINY*FTINY); } /* Add a surface to our current parameters */ @@ -963,7 +1013,7 @@ add_surface(int st, const char *oname, FILE *fp) snew = (SURF *)malloc(sizeof(SURF) + sizeof(double)*(n-1)); if (snew == NULL) { fputs(progname, stderr); - fputs(": out of memory!\n", stderr); + fputs(": out of memory in add_surface!\n", stderr); exit(1); } strncpy(snew->sname, oname, sizeof(snew->sname)-1); @@ -1008,7 +1058,7 @@ add_surface(int st, const char *oname, FILE *fp) snew->area *= PI*snew->area; break; } - if (snew->area <= FTINY) { + if ((snew->area <= FTINY*FTINY) & (verbose >= 0)) { fprintf(stderr, "%s: warning - zero area for surface '%s'\n", progname, oname); free(snew); @@ -1066,9 +1116,9 @@ add_recv_object(FILE *fp) /* else skip arguments */ if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*s"); - if (!fscanf(fp, "%d", &n)) return; + if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*d"); - if (!fscanf(fp, "%d", &n)) return; + if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*f"); return(0); } @@ -1078,10 +1128,10 @@ static int add_send_object(FILE *fp) { int st; - char otype[32], oname[128]; + char thismod[128], otype[32], oname[128]; int n; - if (fscanf(fp, "%*s %s %s", otype, oname) != 2) + if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3) return(0); /* must have hit EOF! */ if (!strcmp(otype, "alias")) { fscanf(fp, "%*s"); /* skip alias */ @@ -1094,6 +1144,14 @@ add_send_object(FILE *fp) fputs(": cannot use source as a sender!\n", stderr); return(-1); } + if (strcmp(thismod, curmod)) { + if (curmod[0]) { + fputs(progname, stderr); + fputs(": warning - multiple modifiers in sender\n", + stderr); + } + strcpy(curmod, thismod); + } parse_params(&curparams, newparams); newparams[0] = '\0'; add_surface(st, oname, fp); /* read & store surface */ @@ -1102,9 +1160,9 @@ add_send_object(FILE *fp) /* else skip arguments */ if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*s"); - if (!fscanf(fp, "%d", &n)) return; + if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*d"); - if (!fscanf(fp, "%d", &n)) return; + if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*f"); return(0); } @@ -1147,7 +1205,7 @@ load_scene(const char *inspec, int (*ocb)(FILE *)) strcat(newparams, inpbuf); continue; } - while ((c = getc(fp)) != EOF && c != '\n'); + while ((c = getc(fp)) != EOF && c != '\n') ; /* else skipping comment */ continue; } @@ -1172,7 +1230,7 @@ main(int argc, char *argv[]) { char fmtopt[6] = "-faa"; /* default output is ASCII */ char *xrs=NULL, *yrs=NULL, *ldopt=NULL; - int wantIrradiance = 0; + char *iropt = NULL; char *sendfn; char sampcntbuf[32], nsbinbuf[32]; FILE *rcfp; @@ -1180,11 +1238,22 @@ main(int argc, char *argv[]) int a, i; /* screen rcontrib options */ progname = argv[0]; - for (a = 1; a < argc-2 && argv[a][0] == '-'; a++) { - int na = 1; /* !! Keep consistent !! */ - switch (argv[a][1]) { + for (a = 1; a < argc-2; a++) { + int na; + /* check for argument expansion */ + while ((na = expandarg(&argc, &argv, a)) > 0) + ; + if (na < 0) { + fprintf(stderr, "%s: cannot expand '%s'\n", + progname, argv[a]); + return(1); + } + if (argv[a][0] != '-' || !argv[a][1]) + break; + na = 1; + switch (argv[a][1]) { /* !! Keep consistent !! */ case 'v': /* verbose mode */ - verbose = !verbose; + verbose = 1; na = 0; continue; case 'f': /* special case for -fo, -ff, etc. */ @@ -1221,19 +1290,23 @@ main(int argc, char *argv[]) na = 0; /* we re-add this later */ continue; case 'I': /* only for pass-through mode */ - wantIrradiance = 1; + case 'i': + iropt = argv[a]; na = 0; continue; - case 'V': /* options without arguments */ - case 'w': + case 'w': /* options without arguments */ + if (!argv[a][2] || strchr("+1tTyY", argv[a][2]) == NULL) + verbose = -1; + break; + case 'V': case 'u': - case 'i': case 'h': case 'r': break; case 'n': /* options with 1 argument */ case 's': case 'o': + case 't': na = 2; break; case 'b': /* special case */ @@ -1251,14 +1324,17 @@ main(int argc, char *argv[]) if (argv[a][2] != 'v') na = 2; break; case 'a': /* special case */ - na = (argv[a][2] == 'v') ? 4 : 2; + if (argv[a][2] == 'p') { + na = 2; /* photon map [+ bandwidth(s)] */ + if (a < argc-3 && atoi(argv[a+1]) > 0) + na += 1 + (a < argc-4 && atoi(argv[a+2]) > 0); + } else + na = (argv[a][2] == 'v') ? 4 : 2; break; case 'm': /* special case */ if (!argv[a][2]) goto userr; na = (argv[a][2] == 'e') | (argv[a][2] == 'a') ? 4 : 2; break; - case '\0': /* pass-through mode */ - goto done_opts; default: /* anything else is verbotten */ goto userr; } @@ -1268,16 +1344,15 @@ main(int argc, char *argv[]) while (--na) /* + arguments if any */ rcarg[nrcargs++] = argv[++a]; } -done_opts: if (a > argc-2) goto userr; /* check at end of options */ sendfn = argv[a++]; /* assign sender & receiver inputs */ if (sendfn[0] == '-') { /* user wants pass-through mode? */ if (sendfn[1]) goto userr; sendfn = NULL; - if (wantIrradiance) { + if (iropt) { CHECKARGC(1); - rcarg[nrcargs++] = "-I"; + rcarg[nrcargs++] = iropt; } if (xrs) { CHECKARGC(2); @@ -1295,12 +1370,16 @@ done_opts: } if (sampcnt <= 0) sampcnt = 1; } else { /* else in sampling mode */ - if (wantIrradiance) { + if (iropt) { fputs(progname, stderr); - fputs(": -I supported for pass-through only\n", stderr); + fputs(": -i, -I supported for pass-through only\n", stderr); return(1); } - fmtopt[2] = (sizeof(RREAL)==sizeof(double)) ? 'd' : 'f'; +#ifdef SMLFLT + fmtopt[2] = 'f'; +#else + fmtopt[2] = 'd'; +#endif if (sampcnt <= 0) sampcnt = 10000; } sprintf(sampcntbuf, "%d", sampcnt); @@ -1319,6 +1398,7 @@ done_opts: return(my_exec(rcarg)); /* rcontrib does everything */ } clear_params(&curparams, 0); /* else load sender surface & params */ + curmod[0] = '\0'; if (load_scene(sendfn, add_send_object) < 0) return(1); if ((nsbins = prepare_sampler()) <= 0) @@ -1336,7 +1416,7 @@ done_opts: #ifdef getc_unlocked flockfile(rcfp); #endif - if (verbose) { + if (verbose > 0) { fprintf(stderr, "%s: sampling %d directions", progname, nsbins); if (curparams.nsurfs > 1) fprintf(stderr, " (%d elements)\n", curparams.nsurfs); @@ -1346,11 +1426,11 @@ done_opts: for (i = 0; i < nsbins; i++) /* send rcontrib ray samples */ if (!(*curparams.sample_basis)(&curparams, i, rcfp)) return(1); - return(pclose(rcfp) == 0); /* all finished! */ + return(pclose_al(rcfp) < 0); /* all finished! */ userr: if (a < argc-2) fprintf(stderr, "%s: unsupported option '%s'", progname, argv[a]); - fprintf(stderr, "Usage: %s [-v][rcontrib options] sender.rad receiver.rad [system.rad ..]\n", + fprintf(stderr, "Usage: %s [-v][rcontrib options] sender.rad receiver.rad [-i system.oct] [system.rad ..]\n", progname); return(1); }
