--- ray/src/util/rfluxmtx.c 2014/08/15 19:59:56 2.15 +++ ray/src/util/rfluxmtx.c 2014/08/26 18:56:19 2.17 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rfluxmtx.c,v 2.15 2014/08/15 19:59:56 greg Exp $"; +static const char RCSid[] = "$Id: rfluxmtx.c,v 2.17 2014/08/26 18:56:19 greg Exp $"; #endif /* * Calculate flux transfer matrix or matrices using rcontrib @@ -36,7 +36,7 @@ static const char RCSid[] = "$Id: rfluxmtx.c,v 2.15 20 char *progname; /* global argv[0] */ -int verbose = 0; /* verbose mode? */ +int verbose = 0; /* verbose mode (< 0 no warnings) */ char *rcarg[MAXRCARG+1] = {"rcontrib", "-fo+"}; int nrcargs = 2; @@ -226,7 +226,7 @@ popen_arglist(char *av[], char *mode) fputs(": command line too long in popen_arglist()\n", stderr); return(NULL); } - if (verbose) + if (verbose > 0) fprintf(stderr, "%s: opening pipe %s: %s\n", progname, (*mode=='w') ? "to" : "from", cmd); return(popen(cmd, mode)); @@ -244,7 +244,7 @@ my_exec(char *av[]) fputs(": command line too long in my_exec()\n", stderr); return(1); } - if (verbose) + if (verbose > 0) fprintf(stderr, "%s: running: %s\n", progname, cmd); return(system(cmd)); } @@ -259,7 +259,7 @@ my_exec(char *av[]) fprintf(stderr, "%s: cannot locate %s\n", progname, av[0]); return(1); } - if (verbose) { + if (verbose > 0) { char cmd[4096]; if (!convert_commandline(cmd, sizeof(cmd), av)) strcpy(cmd, "COMMAND TOO LONG TO SHOW"); @@ -844,7 +844,7 @@ sample_klems(PARAMS *p, int b, FILE *fp) while (n--) { /* stratified sampling */ SDmultiSamp(samp2, 2, (n+frandom())/sampcnt); - if (!bo_getvec(duvw, b+samp2[1], kbasis[bi])) + if (!bi_getvec(duvw, b+samp2[1], kbasis[bi])) return(0); for (i = 3; i--; ) orig_dir[1][i] = duvw[0]*p->udir[i] + @@ -867,7 +867,8 @@ prepare_sampler(void) fputs(": no sender surface!\n", stderr); return(-1); } - if (curparams.outfn != NULL) /* misplaced output file spec. */ + /* misplaced output file spec. */ + if ((curparams.outfn != NULL) & (verbose >= 0)) fprintf(stderr, "%s: warning - ignoring output file in sender ('%s')\n", progname, curparams.outfn); /* check/set basis hemisphere */ @@ -1018,7 +1019,7 @@ add_surface(int st, const char *oname, FILE *fp) snew->area *= PI*snew->area; break; } - if (snew->area <= FTINY) { + if ((snew->area <= FTINY) & (verbose >= 0)) { fprintf(stderr, "%s: warning - zero area for surface '%s'\n", progname, oname); free(snew); @@ -1205,7 +1206,7 @@ main(int argc, char *argv[]) na = 1; switch (argv[a][1]) { /* !! Keep consistent !! */ case 'v': /* verbose mode */ - verbose = !verbose; + verbose = 1; na = 0; continue; case 'f': /* special case for -fo, -ff, etc. */ @@ -1246,8 +1247,9 @@ main(int argc, char *argv[]) iropt = argv[a]; na = 0; continue; - case 'V': /* options without arguments */ - case 'w': + case 'w': /* options without arguments */ + if (argv[a][2] != '+') verbose = -1; + case 'V': case 'u': case 'h': case 'r':
