--- ray/src/util/rfluxmtx.c 2014/07/19 01:19:49 2.1 +++ ray/src/util/rfluxmtx.c 2014/08/06 02:38:24 2.14 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rfluxmtx.c,v 2.1 2014/07/19 01:19:49 greg Exp $"; +static const char RCSid[] = "$Id: rfluxmtx.c,v 2.14 2014/08/06 02:38:24 greg Exp $"; #endif /* * Calculate flux transfer matrix or matrices using rcontrib @@ -11,6 +11,7 @@ static const char RCSid[] = "$Id: rfluxmtx.c,v 2.1 201 #include #include "rtio.h" #include "rtmath.h" +#include "rtprocess.h" #include "bsdf.h" #include "bsdf_m.h" #include "random.h" @@ -23,10 +24,10 @@ static const char RCSid[] = "$Id: rfluxmtx.c,v 2.1 201 #endif #ifdef _WIN32 -#define SPECIALS " \t$*?" +#define SPECIALS " \t\"$*?" #define QUOTCHAR '"' #else -#define SPECIALS " \t\n'\"()${}*?[]" +#define SPECIALS " \t\n'\"()${}*?[];|&" #define QUOTCHAR '\'' #define ALTQUOT '"' #endif @@ -45,15 +46,16 @@ const char overflowerr[] = "%s: too many arguments!\n" #define CHECKARGC(n) if (nrcargs >= MAXRCARG-(n)) \ { fprintf(stderr, overflowerr, progname); exit(1); } -int sampcnt = 0; /* sample count (unset) */ +int sampcnt = 0; /* sample count (0==unset) */ -char *reinhfn = "reinhart.cal"; -char *shirchufn = "disk2square.cal"; +char *reinhfn = "reinhartb.cal"; +char *shirchiufn = "disk2square.cal"; char *kfullfn = "klems_full.cal"; char *khalffn = "klems_half.cal"; char *kquarterfn = "klems_quarter.cal"; -#define PARAMSTART "@rfluxmtx" /* string indicating parameters */ + /* string indicating parameters */ +const char PARAMSTART[] = "@rfluxmtx"; /* surface type IDs */ #define ST_NONE 0 @@ -66,10 +68,10 @@ typedef struct surf_s { void *priv; /* private data (malloc'ed) */ char sname[32]; /* surface name */ FVECT snrm; /* surface normal */ - double area; /* surface area (or solid angle) */ + double area; /* surface area / proj. solid angle */ short styp; /* surface type */ - short nfargs; /* number of arguments */ - double farg[1]; /* arguments (extends struct) */ + short nfargs; /* number of real arguments */ + double farg[1]; /* real values (extends struct) */ } SURF; /* surface structure */ typedef struct { @@ -95,6 +97,7 @@ typedef struct param_s { PARAMS curparams; char curmod[128]; +char newparams[1024]; typedef int SURFSAMP(FVECT, SURF *, double); @@ -108,7 +111,6 @@ SURFSAMP *orig_in_surf[4] = { static void clear_params(PARAMS *p, int reset_only) { - curmod[0] = '\0'; while (p->slist != NULL) { SURF *sdel = p->slist; p->slist = sdel->next; @@ -123,7 +125,7 @@ clear_params(PARAMS *p, int reset_only) p->outfn = NULL; return; } - memset(p, 0, sizeof(curparams)); + memset(p, 0, sizeof(PARAMS)); } /* Get surface type from name */ @@ -143,20 +145,23 @@ surf_type(const char *otype) static char * oconv_command(int ac, char *av[]) { - static char oconvbuf[2048] = "!oconv -f"; - char *cp = oconvbuf + 9; - + static char oconvbuf[2048] = "!oconv -f "; + char *cp = oconvbuf + 10; + char *recv = *av++; + + if (ac-- <= 0) + return(NULL); while (ac-- > 0) { + strcpy(cp, *av++); + while (*cp) cp++; + *cp++ = ' '; if (cp >= oconvbuf+(sizeof(oconvbuf)-32)) { fputs(progname, stderr); fputs(": too many file arguments!\n", stderr); exit(1); } - *cp++ = ' '; - strcpy(cp, *av++); - while (*cp) cp++; } - *cp = '\0'; + strcpy(cp, recv); /* receiver goes last */ return(oconvbuf); } @@ -308,7 +313,7 @@ nextchar: /* Parse program parameters (directives) */ static int -parse_params(char *pargs) +parse_params(PARAMS *p, char *pargs) { char *cp = pargs; int nparams = 0; @@ -319,24 +324,23 @@ parse_params(char *pargs) case 'h': if (*cp++ != '=') break; - curparams.hsiz = 0; + p->hsiz = 0; i = 0; while (*cp && !isspace(*cp)) { if (isdigit(*cp)) - curparams.hsiz = 10*curparams.hsiz + - *cp - '0'; - curparams.hemis[i++] = *cp++; + p->hsiz = 10*p->hsiz + *cp - '0'; + p->hemis[i++] = *cp++; } if (!i) break; - curparams.hemis[i] = '\0'; - curparams.hsiz += !curparams.hsiz; + p->hemis[i] = '\0'; + p->hsiz += !p->hsiz; ++nparams; continue; case 'u': if (*cp++ != '=') break; - if (!get_direction(curparams.vup, cp)) + if (!get_direction(p->vup, cp)) break; ++nparams; continue; @@ -349,7 +353,7 @@ parse_params(char *pargs) if (!i) break; *--cp = '\0'; - curparams.outfn = savqstr(cp-i); + p->outfn = savqstr(cp-i); *cp++ = ' '; ++nparams; continue; @@ -372,7 +376,13 @@ parse_params(char *pargs) static void finish_receiver(void) { - char binbuf[128]; + char sbuf[256]; + int uniform = 0; + char *calfn = NULL; + char *params = NULL; + char *binv = NULL; + char *binf = NULL; + char *nbins = NULL; if (!curmod[0]) { fputs(progname, stderr); @@ -384,7 +394,7 @@ finish_receiver(void) rcarg[nrcargs++] = "-o"; rcarg[nrcargs++] = curparams.outfn; } - /* add bin specification */ + /* check arguments */ if (!curparams.hemis[0]) { fputs(progname, stderr); fputs(": missing hemisphere sampling type!\n", stderr); @@ -395,96 +405,103 @@ finish_receiver(void) fputs(": undefined normal for hemisphere sampling\n", stderr); exit(1); } - if (normalize(curparams.vup) == 0) + if (normalize(curparams.vup) == 0) { if (fabs(curparams.nrm[2]) < .7) curparams.vup[2] = 1; else curparams.vup[1] = 1; + } + /* determine sample type/bin */ if (tolower(curparams.hemis[0]) == 'u' | curparams.hemis[0] == '1') { - CHECKARGC(2); - rcarg[nrcargs++] = "-b"; - rcarg[nrcargs++] = "0"; + binv = "0"; /* uniform sampling -- one bin */ + uniform = 1; } else if (tolower(curparams.hemis[0]) == 's' && tolower(curparams.hemis[1]) == 'c') { - if (shirchufn != NULL) { - CHECKARGC(2); - rcarg[nrcargs++] = "-f"; - rcarg[nrcargs++] = shirchufn; - shirchufn = NULL; - } -fputs("Shirley-Chiu unimplemented...\n",stderr); exit(1); + /* assign parameters */ if (curparams.hsiz <= 1) { fputs(progname, stderr); fputs(": missing size for Shirley-Chiu sampling!\n", stderr); exit(1); } + calfn = shirchiufn; shirchiufn = NULL; + sprintf(sbuf, "SCdim=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g", + curparams.hsiz, + curparams.nrm[0], curparams.nrm[1], curparams.nrm[2], + curparams.vup[0], curparams.vup[1], curparams.vup[2]); + params = savqstr(sbuf); + binv = "scbin"; + nbins = "SCdim*SCdim"; } else if ((tolower(curparams.hemis[0]) == 'r') | (tolower(curparams.hemis[0]) == 't')) { - if (reinhfn != NULL) { - CHECKARGC(2); - rcarg[nrcargs++] = "-f"; - rcarg[nrcargs++] = reinhfn; - reinhfn = NULL; - } -fputs("Reinhart/Tregenza unimplemented...\n",stderr); exit(1); + calfn = reinhfn; reinhfn = NULL; + sprintf(sbuf, "MF=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g", + curparams.hsiz, + curparams.nrm[0], curparams.nrm[1], curparams.nrm[2], + curparams.vup[0], curparams.vup[1], curparams.vup[2]); + params = savqstr(sbuf); + binv = "rbin"; + nbins = "Nrbins"; } else if (tolower(curparams.hemis[0]) == 'k' && !curparams.hemis[1] | (tolower(curparams.hemis[1]) == 'f') | (curparams.hemis[1] == '1')) { - if (kfullfn != NULL) { - CHECKARGC(2); - rcarg[nrcargs++] = "-f"; - rcarg[nrcargs++] = kfullfn; - kfullfn = NULL; - } - CHECKARGC(4); - sprintf(binbuf, "kbin(%g,%g,%g,%g,%g,%g)", - curparams.nrm[0], curparams.nrm[1], curparams.nrm[2], - curparams.vup[0], curparams.vup[1], curparams.vup[2]); - rcarg[nrcargs++] = "-b"; - rcarg[nrcargs++] = savqstr(binbuf); - rcarg[nrcargs++] = "-bn"; - rcarg[nrcargs++] = "Nkbins"; + calfn = kfullfn; kfullfn = NULL; + binf = "kbin"; + nbins = "Nkbins"; } else if (tolower(curparams.hemis[0]) == 'k' && (tolower(curparams.hemis[1]) == 'h') | (curparams.hemis[1] == '2')) { - if (khalffn != NULL) { - CHECKARGC(2); - rcarg[nrcargs++] = "-f"; - rcarg[nrcargs++] = khalffn; - khalffn = NULL; - } - CHECKARGC(4); - sprintf(binbuf, "khbin(%g,%g,%g,%g,%g,%g)", - curparams.nrm[0], curparams.nrm[1], curparams.nrm[2], - curparams.vup[0], curparams.vup[1], curparams.vup[2]); - rcarg[nrcargs++] = "-b"; - rcarg[nrcargs++] = savqstr(binbuf); - rcarg[nrcargs++] = "-bn"; - rcarg[nrcargs++] = "Nkhbins"; + calfn = khalffn; khalffn = NULL; + binf = "khbin"; + nbins = "Nkhbins"; } else if (tolower(curparams.hemis[0]) == 'k' && (tolower(curparams.hemis[1]) == 'q') | (curparams.hemis[1] == '4')) { - if (kquarterfn != NULL) { - CHECKARGC(2); - rcarg[nrcargs++] = "-f"; - rcarg[nrcargs++] = kquarterfn; - kquarterfn = NULL; - } - CHECKARGC(4); - sprintf(binbuf, "kqbin(%g,%g,%g,%g,%g,%g)", - curparams.nrm[0], curparams.nrm[1], curparams.nrm[2], - curparams.vup[0], curparams.vup[1], curparams.vup[2]); - rcarg[nrcargs++] = "-b"; - rcarg[nrcargs++] = savqstr(binbuf); - rcarg[nrcargs++] = "-bn"; - rcarg[nrcargs++] = "Nkqbins"; + calfn = kquarterfn; kquarterfn = NULL; + binf = "kqbin"; + nbins = "Nkqbins"; } else { fprintf(stderr, "%s: unrecognized hemisphere sampling: h=%s\n", progname, curparams.hemis); exit(1); } - CHECKARGC(2); /* modifier argument goes last */ + if (!uniform & (curparams.slist->styp == ST_SOURCE)) { + SURF *sp; + for (sp = curparams.slist; sp != NULL; sp = sp->next) + if (fabs(sp->area - PI) > 1e-3) { + fprintf(stderr, "%s: source '%s' must be 180-degrees\n", + progname, sp->sname); + exit(1); + } + } + if (calfn != NULL) { /* add cal file if needed */ + CHECKARGC(2); + rcarg[nrcargs++] = "-f"; + rcarg[nrcargs++] = calfn; + } + if (params != NULL) { /* parameters _after_ cal file */ + CHECKARGC(2); + rcarg[nrcargs++] = "-p"; + rcarg[nrcargs++] = params; + } + if (nbins != NULL) { /* add #bins if set */ + CHECKARGC(2); + rcarg[nrcargs++] = "-bn"; + rcarg[nrcargs++] = nbins; + } + if (binv != NULL) { + CHECKARGC(2); /* assign bin variable */ + rcarg[nrcargs++] = "-b"; + rcarg[nrcargs++] = binv; + } else if (binf != NULL) { + CHECKARGC(2); /* assign bin function */ + rcarg[nrcargs++] = "-b"; + sprintf(sbuf, "%s(%g,%g,%g,%g,%g,%g)", binf, + curparams.nrm[0], curparams.nrm[1], curparams.nrm[2], + curparams.vup[0], curparams.vup[1], curparams.vup[2]); + rcarg[nrcargs++] = savqstr(sbuf); + } + CHECKARGC(2); /* modifier argument goes last */ rcarg[nrcargs++] = "-m"; rcarg[nrcargs++] = savqstr(curmod); } @@ -541,7 +558,7 @@ ssamp_ring(FVECT orig, SURF *sp, double x) sp->priv = (void *)uva; } SDmultiSamp(samp2, 2, x); - samp2[0] = sp->farg[6] + sqrt(samp2[0]*sp->area*(1./PI)); + samp2[0] = sqrt(samp2[0]*sp->area*(1./PI) + sp->farg[6]*sp->farg[6]); samp2[1] *= 2.*PI; uv[0] = samp2[0]*tcos(samp2[1]); uv[1] = samp2[0]*tsin(samp2[1]); @@ -594,8 +611,12 @@ ssamp_poly(FVECT orig, SURF *sp, double x) } ptp->ntris = 0; v2l->p = (void *)ptp; - if (!polyTriangulate(v2l, add_triangle)) + if (!polyTriangulate(v2l, add_triangle)) { + fprintf(stderr, + "%s: cannot triangulate polygon '%s'\n", + progname, sp->sname); return(0); + } for (i = ptp->ntris; i--; ) { int a = ptp->tri[i].vndx[0]; int b = ptp->tri[i].vndx[1]; @@ -644,8 +665,12 @@ sample_origin(PARAMS *p, FVECT orig, const FVECT rdir, /* special case for lone surface */ if (p->nsurfs == 1) { sp = p->slist; - if (DOT(sp->snrm, rdir) >= -FTINY) - return(0); /* behind surface! */ + if (DOT(sp->snrm, rdir) >= -FTINY) { + fprintf(stderr, + "%s: internal - sample behind sender '%s'\n", + progname, sp->sname); + return(0); + } return((*orig_in_surf[sp->styp])(orig, sp, x)); } if (p->nsurfs > nall) { /* (re)allocate surface area cache */ @@ -659,8 +684,12 @@ sample_origin(PARAMS *p, FVECT orig, const FVECT rdir, projsa[i] = -DOT(sp->snrm, rdir) * sp->area; tarea += projsa[i] *= (double)(projsa[i] > FTINY); } - if (tarea <= FTINY) /* wrong side of sender? */ + if (tarea <= FTINY) { /* wrong side of sender? */ + fputs(progname, stderr); + fputs(": internal - sample behind all sender elements!\n", + stderr); return(0); + } tarea *= x; /* get surface from list */ for (i = 0, sp = p->slist; tarea > projsa[i]; sp = sp->next) tarea -= projsa[i++]; @@ -733,7 +762,7 @@ sample_reinhart(PARAMS *p, int b, FILE *fp) #define T_NALT 7 static const int tnaz[T_NALT] = {30, 30, 24, 24, 18, 12, 6}; const int RowMax = T_NALT*p->hsiz + 1; - const double RAH = (.25*PI)/(RowMax-.5); + const double RAH = (.5*PI)/(RowMax-.5); #define rnaz(r) (r >= RowMax-1 ? 1 : p->hsiz*tnaz[r/p->hsiz]) int n = sampcnt; int row, col; @@ -758,7 +787,7 @@ sample_reinhart(PARAMS *p, int b, FILE *fp) SDmultiSamp(samp3, 3, (n+frandom())/sampcnt); alt = (row+samp3[1])*RAH; azi = (2.*PI)*(col+samp3[2]-.5)/rnaz(row); - duvw[2] = tcos(alt); /* measured from horizon */ + duvw[2] = cos(alt); /* measured from horizon */ duvw[0] = tcos(azi)*duvw[2]; duvw[1] = tsin(azi)*duvw[2]; duvw[2] = sqrt(1. - duvw[2]*duvw[2]); @@ -848,11 +877,12 @@ prepare_sampler(void) fputs(": undefined normal for sender sampling\n", stderr); return(-1); } - if (normalize(curparams.vup) == 0) + if (normalize(curparams.vup) == 0) { if (fabs(curparams.nrm[2]) < .7) curparams.vup[2] = 1; else curparams.vup[1] = 1; + } VCROSS(curparams.udir, curparams.vup, curparams.nrm); if (normalize(curparams.udir) == 0) { fputs(progname, stderr); @@ -976,10 +1006,12 @@ add_surface(int st, const char *oname, FILE *fp) case ST_SOURCE: if (snew->nfargs != 4) goto badcount; - VCOPY(snew->snrm, snew->farg); + for (n = 3; n--; ) /* need to reverse "normal" */ + snew->snrm[n] = -snew->farg[n]; if (normalize(snew->snrm) == 0) goto badnorm; - snew->area = 2.*PI*(1. - cos((PI/180./2.)*snew->farg[3])); + snew->area = sin((PI/180./2.)*snew->farg[3]); + snew->area *= PI*snew->area; break; } if (snew->area <= FTINY) { @@ -994,11 +1026,11 @@ add_surface(int st, const char *oname, FILE *fp) curparams.nsurfs++; return; badcount: - fprintf(stderr, "%s: bad argument count for surface '%s'\n", + fprintf(stderr, "%s: bad argument count for surface element '%s'\n", progname, oname); exit(1); badnorm: - fprintf(stderr, "%s: bad orientation for surface '%s'\n", + fprintf(stderr, "%s: bad orientation for surface element '%s'\n", progname, oname); exit(1); } @@ -1030,17 +1062,19 @@ add_recv_object(FILE *fp) finish_receiver(); clear_params(&curparams, 1); } + parse_params(&curparams, newparams); + newparams[0] = '\0'; strcpy(curmod, thismod); } add_surface(st, oname, fp); /* read & store surface */ return(1); } /* else skip arguments */ - if (!fscanf(fp, "%d", &n)) return; + if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*s"); - if (!fscanf(fp, "%d", &n)) return; + if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*d"); - if (!fscanf(fp, "%d", &n)) return; + if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*f"); return(0); } @@ -1066,15 +1100,17 @@ add_send_object(FILE *fp) fputs(": cannot use source as a sender!\n", stderr); return(-1); } + parse_params(&curparams, newparams); + newparams[0] = '\0'; add_surface(st, oname, fp); /* read & store surface */ return(0); } /* else skip arguments */ - if (!fscanf(fp, "%d", &n)) return; + if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*s"); - if (!fscanf(fp, "%d", &n)) return; + if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*d"); - if (!fscanf(fp, "%d", &n)) return; + if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*f"); return(0); } @@ -1109,13 +1145,15 @@ load_scene(const char *inspec, int (*ocb)(FILE *)) continue; } if (c == '#') { /* parameters/comment */ - if (fscanf(fp, "%s", inpbuf) == 1 && + if ((c = getc(fp)) == EOF || ungetc(c,fp) == EOF) + break; + if (!isspace(c) && fscanf(fp, "%s", inpbuf) == 1 && !strcmp(inpbuf, PARAMSTART)) { if (fgets(inpbuf, sizeof(inpbuf), fp) != NULL) - parse_params(inpbuf); + strcat(newparams, inpbuf); continue; } - while ((c = getc(fp)) != EOF && c != '\n'); + while ((c = getc(fp)) != EOF && c != '\n') ; /* else skipping comment */ continue; } @@ -1139,6 +1177,8 @@ int main(int argc, char *argv[]) { char fmtopt[6] = "-faa"; /* default output is ASCII */ + char *xrs=NULL, *yrs=NULL, *ldopt=NULL; + char *iropt = NULL; char *sendfn; char sampcntbuf[32], nsbinbuf[32]; FILE *rcfp; @@ -1146,9 +1186,20 @@ main(int argc, char *argv[]) int a, i; /* screen rcontrib options */ progname = argv[0]; - for (a = 1; a < argc-2 && argv[a][0] == '-'; a++) { - int na = 1; /* !! Keep consistent !! */ - switch (argv[a][1]) { + for (a = 1; a < argc-2; a++) { + int na; + /* check for argument expansion */ + while ((na = expandarg(&argc, &argv, a)) > 0) + ; + if (na < 0) { + fprintf(stderr, "%s: cannot expand '%s'\n", + progname, argv[a]); + return(1); + } + if (argv[a][0] != '-' || !argv[a][1]) + break; + na = 1; + switch (argv[a][1]) { /* !! Keep consistent !! */ case 'v': /* verbose mode */ verbose = !verbose; na = 0; @@ -1163,26 +1214,39 @@ main(int argc, char *argv[]) case 'f': case 'd': case 'c': - if (!(fmtopt[4] = argv[a][3])) - fmtopt[4] = argv[a][2]; - fmtopt[3] = argv[a][2]; + if (!(fmtopt[3] = argv[a][3])) + fmtopt[3] = argv[a][2]; + fmtopt[2] = argv[a][2]; na = 0; continue; /* will pass later */ default: goto userr; } break; + case 'x': /* x-resolution */ + xrs = argv[++a]; + na = 0; + continue; + case 'y': /* y-resolution */ + yrs = argv[++a]; + na = 0; + continue; case 'c': /* number of samples */ - sampcnt = atoi(argv[a+1]); + sampcnt = atoi(argv[++a]); if (sampcnt <= 0) goto userr; na = 0; /* we re-add this later */ continue; + case 'I': /* only for pass-through mode */ + case 'i': + iropt = argv[a]; + na = 0; + continue; case 'V': /* options without arguments */ case 'w': case 'u': - case 'i': case 'h': + case 'r': break; case 'n': /* options with 1 argument */ case 's': @@ -1193,7 +1257,11 @@ main(int argc, char *argv[]) if (argv[a][2] != 'v') goto userr; break; case 'l': /* special case */ - if (argv[a][2] == 'd') goto userr; + if (argv[a][2] == 'd') { + ldopt = argv[a]; + na = 0; + continue; + } na = 2; break; case 'd': /* special case */ @@ -1206,8 +1274,6 @@ main(int argc, char *argv[]) if (!argv[a][2]) goto userr; na = (argv[a][2] == 'e') | (argv[a][2] == 'a') ? 4 : 2; break; - case '\0': /* pass-through mode */ - goto done_opts; default: /* anything else is verbotten */ goto userr; } @@ -1217,16 +1283,38 @@ main(int argc, char *argv[]) while (--na) /* + arguments if any */ rcarg[nrcargs++] = argv[++a]; } -done_opts: if (a > argc-2) goto userr; /* check at end of options */ sendfn = argv[a++]; /* assign sender & receiver inputs */ if (sendfn[0] == '-') { /* user wants pass-through mode? */ if (sendfn[1]) goto userr; sendfn = NULL; + if (iropt) { + CHECKARGC(1); + rcarg[nrcargs++] = iropt; + } + if (xrs) { + CHECKARGC(2); + rcarg[nrcargs++] = "-x"; + rcarg[nrcargs++] = xrs; + } + if (yrs) { + CHECKARGC(2); + rcarg[nrcargs++] = "-y"; + rcarg[nrcargs++] = yrs; + } + if (ldopt) { + CHECKARGC(1); + rcarg[nrcargs++] = ldopt; + } if (sampcnt <= 0) sampcnt = 1; - } else { /* else FVECT determines input format */ - fmtopt[3] = (sizeof(RREAL)==sizeof(double)) ? 'd' : 'f'; + } else { /* else in sampling mode */ + if (iropt) { + fputs(progname, stderr); + fputs(": -i, -I supported for pass-through only\n", stderr); + return(1); + } + fmtopt[2] = (sizeof(RREAL)==sizeof(double)) ? 'd' : 'f'; if (sampcnt <= 0) sampcnt = 10000; } sprintf(sampcntbuf, "%d", sampcnt); @@ -1265,7 +1353,7 @@ done_opts: if (verbose) { fprintf(stderr, "%s: sampling %d directions", progname, nsbins); if (curparams.nsurfs > 1) - fprintf(stderr, " (%d surfaces)\n", curparams.nsurfs); + fprintf(stderr, " (%d elements)\n", curparams.nsurfs); else fputc('\n', stderr); } @@ -1276,7 +1364,7 @@ done_opts: userr: if (a < argc-2) fprintf(stderr, "%s: unsupported option '%s'", progname, argv[a]); - fprintf(stderr, "Usage: %s [rcontrib options] sender.rad receiver.rad [system.rad ..]\n", + fprintf(stderr, "Usage: %s [-v][rcontrib options] sender.rad receiver.rad [-i system.oct] [system.rad ..]\n", progname); return(1); }
