root/radiance/ray/src/util/rfluxmtx.c
Revision: 2.31
Committed: Sun Sep 13 21:09:20 2015 UTC (9 years, 10 months ago) by greg
Fixed bug in sample testing discovered by Rob G.
2 static const char RCSid[] = "$Id: rfluxmtx.c,v 2.30 2015/07/22 04:23:27 greg Exp $";
5 * Calculate flux transfer matrix or matrices using rcontrib
6 */
7
8 #include "copyright.h"
9
10 #include <ctype.h>
11 #include <stdlib.h>
12 #include "rtio.h"
13 #include "rtmath.h"
14 #include "rtprocess.h"
15 #include "bsdf.h"
16 #include "bsdf_m.h"
17 #include "random.h"
18 #include "triangulate.h"
19 #include "platform.h"
20
21 #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
22 #undef getc
23 #define getc getc_unlocked
24 #endif
25
26 #ifdef _WIN32
27 #define SPECIALS " \t\"$*?"
28 #define QUOTCHAR '"'
29 #else
30 #define SPECIALS " \t\n'\"()${}*?[];|&"
31 #define QUOTCHAR '\''
32 #define ALTQUOT '"'
33 #endif
34
35 #define MAXRCARG 512
36
37 char *progname; /* global argv[0] */
38
39 int verbose = 0; /* verbose mode (< 0 no warnings) */
40
41 char *rcarg[MAXRCARG+1] = {"rcontrib", "-fo+"};
42 int nrcargs = 2;
43
44 const char overflowerr[] = "%s: too many arguments!\n";
45
46 #define CHECKARGC(n) if (nrcargs >= MAXRCARG-(n)) \
47 { fprintf(stderr, overflowerr, progname); exit(1); }
48
49 int sampcnt = 0; /* sample count (0==unset) */
50
51 char *reinhfn = "reinhartb.cal";
52 char *shirchiufn = "disk2square.cal";
53 char *kfullfn = "klems_full.cal";
54 char *khalffn = "klems_half.cal";
55 char *kquarterfn = "klems_quarter.cal";
56
57 /* string indicating parameters */
58 const char PARAMSTART[] = "@rfluxmtx";
59
60 /* surface type IDs */
61 #define ST_NONE 0
62 #define ST_POLY 1
63 #define ST_RING 2
64 #define ST_SOURCE 3
65
66 typedef struct surf_s {
67 struct surf_s *next; /* next surface in list */
68 void *priv; /* private data (malloc'ed) */
69 char sname[32]; /* surface name */
70 FVECT snrm; /* surface normal */
71 double area; /* surface area / proj. solid angle */
72 short styp; /* surface type */
73 short nfargs; /* number of real arguments */
74 double farg[1]; /* real values (extends struct) */
75 } SURF; /* surface structure */
76
77 typedef struct {
78 FVECT uva[2]; /* tangent axes */
79 int ntris; /* number of triangles */
80 struct ptri {
81 float afrac; /* fraction of total area */
82 short vndx[3]; /* vertex indices */
83 } tri[1]; /* triangle array (extends struct) */
84 } POLYTRIS; /* triangulated polygon */
85
86 typedef struct param_s {
87 char sign; /* '-' for axis reversal */
88 char hemis[31]; /* hemispherical sampling spec. */
89 int hsiz; /* hemisphere basis size */
90 int nsurfs; /* number of surfaces */
91 SURF *slist; /* list of surfaces */
92 FVECT vup; /* up vector (zero if unset) */
93 FVECT nrm; /* average normal direction */
94 FVECT udir, vdir; /* tangent axes */
95 char *outfn; /* output file name (receiver) */
96 int (*sample_basis)(struct param_s *p, int, FILE *);
97 } PARAMS; /* sender/receiver parameters */
98
99 PARAMS curparams;
100 char curmod[128];
101 char newparams[1024];
102
103 typedef int SURFSAMP(FVECT, SURF *, double);
104
105 static SURFSAMP ssamp_bad, ssamp_poly, ssamp_ring;
106
107 SURFSAMP *orig_in_surf[4] = {
108 ssamp_bad, ssamp_poly, ssamp_ring, ssamp_bad
109 };
110
111 /* Clear parameter set */
112 static void
113 clear_params(PARAMS *p, int reset_only)
114 {
115 while (p->slist != NULL) {
116 SURF *sdel = p->slist;
117 p->slist = sdel->next;
118 if (sdel->priv != NULL)
119 free(sdel->priv);
120 free(sdel);
121 }
122 if (reset_only) {
123 p->nsurfs = 0;
124 memset(p->nrm, 0, sizeof(FVECT));
125 memset(p->vup, 0, sizeof(FVECT));
126 p->outfn = NULL;
127 return;
128 }
129 memset(p, 0, sizeof(PARAMS));
130 }
131
132 /* Get surface type from name */
133 static int
134 surf_type(const char *otype)
135 {
136 if (!strcmp(otype, "polygon"))
137 return(ST_POLY);
138 if (!strcmp(otype, "ring"))
139 return(ST_RING);
140 if (!strcmp(otype, "source"))
141 return(ST_SOURCE);
142 return(ST_NONE);
143 }
144
145 /* Check if any of the characters in str2 are found in str1 */
146 static int
147 matchany(const char *str1, const char *str2)
148 {
149 while (*str1) {
150 const char *cp = str2;
151 while (*cp)
152 if (*cp++ == *str1)
153 return(*str1);
154 ++str1;
155 }
156 return(0);
157 }
158
159 /* Add arguments to oconv command */
160 static char *
161 oconv_command(int ac, char *av[])
162 {
163 static char oconvbuf[2048] = "!oconv -f ";
164 char *cp = oconvbuf + 10;
165 char *recv = *av++;
166
167 if (ac-- <= 0)
168 return(NULL);
169 while (ac-- > 0) {
170 strcpy(cp, *av++);
171 while (*cp) cp++;
172 *cp++ = ' ';
173 if (cp >= oconvbuf+(sizeof(oconvbuf)-32))
174 goto overrun;
175 }
176 /* receiver goes last */
177 if (matchany(recv, SPECIALS)) {
178 *cp++ = QUOTCHAR;
179 while (*recv) {
180 if (cp >= oconvbuf+(sizeof(oconvbuf)-3))
181 goto overrun;
182 *cp++ = *recv++;
183 }
184 *cp++ = QUOTCHAR;
185 *cp = '\0';
186 } else
187 strcpy(cp, recv);
188 return(oconvbuf);
189 overrun:
190 fputs(progname, stderr);
191 fputs(": too many file arguments!\n", stderr);
192 exit(1);
193 }
194
195 /* Convert a set of arguments into a command line for pipe() or system() */
196 static char *
197 convert_commandline(char *cmd, const int len, char *av[])
198 {
199 int match;
200 char *cp;
201
202 for (cp = cmd; *av != NULL; av++) {
203 const int n = strlen(*av);
204 if (cp+n >= cmd+(len-3)) {
205 fputs(progname, stderr);
206 return(NULL);
207 }
208 if (matchany(*av, SPECIALS)) {
209 const int quote =
210 #ifdef ALTQUOT
211 strchr(*av, QUOTCHAR) ? ALTQUOT :
212 #endif
213 QUOTCHAR;
214 *cp++ = quote;
215 strcpy(cp, *av);
216 cp += n;
217 *cp++ = quote;
218 } else {
219 strcpy(cp, *av);
220 cp += n;
221 }
222 *cp++ = ' ';
223 }
224 if (cp <= cmd)
225 return(NULL);
226 *--cp = '\0';
227 return(cmd);
228 }
229
230 /* Open a pipe to/from a command given as an argument list */
231 static FILE *
232 popen_arglist(char *av[], char *mode)
233 {
234 char cmd[10240];
235
236 if (!convert_commandline(cmd, sizeof(cmd), av)) {
237 fputs(progname, stderr);
238 fputs(": command line too long in popen_arglist()\n", stderr);
239 return(NULL);
240 }
241 if (verbose > 0)
242 fprintf(stderr, "%s: opening pipe %s: %s\n",
243 progname, (*mode=='w') ? "to" : "from", cmd);
244 return(popen(cmd, mode));
245 }
246
247 #ifdef _WIN32
248 /* Execute system command (Windows version) */
249 static int
250 my_exec(char *av[])
251 {
252 char cmd[10240];
253
254 if (!convert_commandline(cmd, sizeof(cmd), av)) {
255 fputs(progname, stderr);
256 fputs(": command line too long in my_exec()\n", stderr);
257 return(1);
258 }
259 if (verbose > 0)
260 fprintf(stderr, "%s: running: %s\n", progname, cmd);
261 return(system(cmd));
262 }
263 #else
264 /* Execute system command in our stead (Unix version) */
265 static int
266 my_exec(char *av[])
267 {
268 char *compath;
269
270 if ((compath = getpath((char *)av[0], getenv("PATH"), X_OK)) == NULL) {
271 fprintf(stderr, "%s: cannot locate %s\n", progname, av[0]);
272 return(1);
273 }
274 if (verbose > 0) {
275 char cmd[4096];
276 if (!convert_commandline(cmd, sizeof(cmd), av))
277 strcpy(cmd, "COMMAND TOO LONG TO SHOW");
278 fprintf(stderr, "%s: running: %s\n", progname, cmd);
279 }
280 execv(compath, av); /* successful call never returns */
281 perror(compath);
282 return(1);
283 }
284 #endif
285
286 /* Get normalized direction vector from string specification */
287 static int
288 get_direction(FVECT dv, const char *s)
289 {
290 int sign = 1;
291 int axis = 0;
292
293 memset(dv, 0, sizeof(FVECT));
294 nextchar:
295 switch (*s) {
296 case '+':
297 ++s;
298 goto nextchar;
299 case '-':
300 sign = -sign;
301 ++s;
302 goto nextchar;
303 case 'z':
304 case 'Z':
305 ++axis;
306 case 'y':
307 case 'Y':
308 ++axis;
309 case 'x':
310 case 'X':
311 dv[axis] = sign;
312 return(!s[1] | isspace(s[1]));
313 default:
314 break;
315 }
316 #ifdef SMLFLT
317 if (sscanf(s, "%f,%f,%f", &dv[0], &dv[1], &dv[2]) != 3)
318 #else
319 if (sscanf(s, "%lf,%lf,%lf", &dv[0], &dv[1], &dv[2]) != 3)
320 #endif
321 return(0);
322 dv[0] *= (RREAL)sign;
323 return(normalize(dv) > 0);
324 }
325
326 /* Parse program parameters (directives) */
327 static int
328 parse_params(PARAMS *p, char *pargs)
329 {
330 char *cp = pargs;
331 int nparams = 0;
332 int i;
333
334 for ( ; ; ) {
335 switch (*cp++) {
336 case 'h':
337 if (*cp++ != '=')
338 break;
339 if ((*cp == '+') | (*cp == '-'))
340 p->sign = *cp++;
341 else
342 p->sign = '+';
343 p->hsiz = 0;
344 i = 0;
345 while (*cp && !isspace(*cp)) {
346 if (isdigit(*cp))
347 p->hsiz = 10*p->hsiz + *cp - '0';
348 p->hemis[i++] = *cp++;
349 }
350 if (!i)
351 break;
352 p->hemis[i] = '\0';
353 p->hsiz += !p->hsiz;
354 ++nparams;
355 continue;
356 case 'u':
357 if (*cp++ != '=')
358 break;
359 if (!get_direction(p->vup, cp))
360 break;
361 while (*cp && !isspace(*cp++))
362 ;
363 ++nparams;
364 continue;
365 case 'o':
366 if (*cp++ != '=')
367 break;
368 i = 0;
369 while (*cp && !isspace(*cp++))
370 i++;
371 if (!i)
372 break;
373 *--cp = '\0';
374 p->outfn = savqstr(cp-i);
375 *cp++ = ' ';
376 ++nparams;
377 continue;
378 case ' ':
379 case '\t':
380 case '\r':
381 case '\n':
382 continue;
383 case '\0':
384 return(nparams);
385 default:
386 break;
387 }
388 break;
389 }
390 fprintf(stderr, "%s: bad parameter string: %s", progname, pargs);
391 exit(1);
392 return(-1); /* pro forma return */
393 }
394
395 /* Add receiver arguments (directives) corresponding to the current modifier */
396 static void
397 finish_receiver(void)
398 {
399 char sbuf[256];
400 int uniform = 0;
401 char *calfn = NULL;
402 char *params = NULL;
403 char *binv = NULL;
404 char *binf = NULL;
405 char *nbins = NULL;
406
407 if (!curmod[0]) {
408 fputs(progname, stderr);
409 fputs(": missing receiver surface!\n", stderr);
410 exit(1);
411 }
412 if (curparams.outfn != NULL) { /* add output file spec. */
413 CHECKARGC(2);
414 rcarg[nrcargs++] = "-o";
415 rcarg[nrcargs++] = curparams.outfn;
416 }
417 /* check arguments */
418 if (!curparams.hemis[0]) {
419 fputs(progname, stderr);
420 fputs(": missing hemisphere sampling type!\n", stderr);
421 exit(1);
422 }
423 if (normalize(curparams.nrm) == 0) {
424 fputs(progname, stderr);
425 fputs(": undefined normal for hemisphere sampling\n", stderr);
426 exit(1);
427 }
428 if (normalize(curparams.vup) == 0) {
429 if (fabs(curparams.nrm[2]) < .7)
430 curparams.vup[2] = 1;
431 else
432 curparams.vup[1] = 1;
433 }
434 /* determine sample type/bin */
435 if (tolower(curparams.hemis[0]) == 'u' | curparams.hemis[0] == '1') {
436 sprintf(sbuf, "if(-Dx*%g-Dy*%g-Dz*%g,0,-1)",
437 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2]);
438 binv = savqstr(sbuf);
439 nbins = "1"; /* uniform sampling -- one bin */
440 uniform = 1;
441 } else if (tolower(curparams.hemis[0]) == 's' &&
442 tolower(curparams.hemis[1]) == 'c') {
443 /* assign parameters */
444 if (curparams.hsiz <= 1) {
445 fputs(progname, stderr);
446 fputs(": missing size for Shirley-Chiu sampling!\n", stderr);
447 exit(1);
448 }
449 calfn = shirchiufn; shirchiufn = NULL;
450 sprintf(sbuf, "SCdim=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1",
451 curparams.hsiz,
452 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
453 curparams.vup[0], curparams.vup[1], curparams.vup[2],
454 curparams.sign);
455 params = savqstr(sbuf);
456 binv = "scbin";
457 nbins = "SCdim*SCdim";
458 } else if ((tolower(curparams.hemis[0]) == 'r') |
459 (tolower(curparams.hemis[0]) == 't')) {
460 calfn = reinhfn; reinhfn = NULL;
461 sprintf(sbuf, "MF=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1",
462 curparams.hsiz,
463 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
464 curparams.vup[0], curparams.vup[1], curparams.vup[2],
465 curparams.sign);
466 params = savqstr(sbuf);
467 binv = "rbin";
468 nbins = "Nrbins";
469 } else if (tolower(curparams.hemis[0]) == 'k' &&
470 !curparams.hemis[1] |
471 (tolower(curparams.hemis[1]) == 'f') |
472 (curparams.hemis[1] == '1')) {
473 calfn = kfullfn; kfullfn = NULL;
474 binf = "kbin";
475 nbins = "Nkbins";
476 } else if (tolower(curparams.hemis[0]) == 'k' &&
477 (tolower(curparams.hemis[1]) == 'h') |
478 (curparams.hemis[1] == '2')) {
479 calfn = khalffn; khalffn = NULL;
480 binf = "khbin";
481 nbins = "Nkhbins";
482 } else if (tolower(curparams.hemis[0]) == 'k' &&
483 (tolower(curparams.hemis[1]) == 'q') |
484 (curparams.hemis[1] == '4')) {
485 calfn = kquarterfn; kquarterfn = NULL;
486 binf = "kqbin";
487 nbins = "Nkqbins";
488 } else {
489 fprintf(stderr, "%s: unrecognized hemisphere sampling: h=%s\n",
490 progname, curparams.hemis);
491 exit(1);
492 }
493 if (tolower(curparams.hemis[0]) == 'k') {
494 sprintf(sbuf, "RHS=%c1", curparams.sign);
495 params = savqstr(sbuf);
496 }
497 if (!uniform & (curparams.slist->styp == ST_SOURCE)) {
498 SURF *sp;
499 for (sp = curparams.slist; sp != NULL; sp = sp->next)
500 if (fabs(sp->area - PI) > 1e-3) {
501 fprintf(stderr, "%s: source '%s' must be 180-degrees\n",
502 progname, sp->sname);
503 exit(1);
504 }
505 }
506 if (calfn != NULL) { /* add cal file if needed */
507 CHECKARGC(2);
508 rcarg[nrcargs++] = "-f";
509 rcarg[nrcargs++] = calfn;
510 }
511 if (params != NULL) { /* parameters _after_ cal file */
512 CHECKARGC(2);
513 rcarg[nrcargs++] = "-p";
514 rcarg[nrcargs++] = params;
515 }
516 if (nbins != NULL) { /* add #bins if set */
517 CHECKARGC(2);
518 rcarg[nrcargs++] = "-bn";
519 rcarg[nrcargs++] = nbins;
520 }
521 if (binv != NULL) {
522 CHECKARGC(2); /* assign bin variable */
523 rcarg[nrcargs++] = "-b";
524 rcarg[nrcargs++] = binv;
525 } else if (binf != NULL) {
526 CHECKARGC(2); /* assign bin function */
527 rcarg[nrcargs++] = "-b";
528 sprintf(sbuf, "%s(%g,%g,%g,%g,%g,%g)", binf,
529 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
530 curparams.vup[0], curparams.vup[1], curparams.vup[2]);
531 rcarg[nrcargs++] = savqstr(sbuf);
532 }
533 CHECKARGC(2); /* modifier argument goes last */
534 rcarg[nrcargs++] = "-m";
535 rcarg[nrcargs++] = savqstr(curmod);
536 }
537
538 /* Make randomly oriented tangent plane axes for given normal direction */
539 static void
540 make_axes(FVECT uva[2], const FVECT nrm)
541 {
542 int i;
543
544 if (!getperpendicular(uva[0], nrm, 1)) {
545 fputs(progname, stderr);
546 fputs(": bad surface normal in make_axes!\n", stderr);
547 exit(1);
548 }
549 fcross(uva[1], nrm, uva[0]);
550 }
551
552 /* Illegal sender surfaces end up here */
553 static int
554 ssamp_bad(FVECT orig, SURF *sp, double x)
555 {
556 fprintf(stderr, "%s: illegal sender surface '%s'\n",
557 progname, sp->sname);
558 return(0);
559 }
560
561 /* Generate origin on ring surface from uniform random variable */
562 static int
563 ssamp_ring(FVECT orig, SURF *sp, double x)
564 {
565 FVECT *uva = (FVECT *)sp->priv;
566 double samp2[2];
567 double uv[2];
568 int i;
569
570 if (uva == NULL) { /* need tangent axes */
571 uva = (FVECT *)malloc(sizeof(FVECT)*2);
572 if (uva == NULL) {
573 fputs(progname, stderr);
574 fputs(": out of memory in ssamp_ring!\n", stderr);
575 return(0);
576 }
577 make_axes(uva, sp->snrm);
578 sp->priv = (void *)uva;
579 }
580 SDmultiSamp(samp2, 2, x);
581 samp2[0] = sqrt(samp2[0]*sp->area*(1./PI) + sp->farg[6]*sp->farg[6]);
582 samp2[1] *= 2.*PI;
583 uv[0] = samp2[0]*tcos(samp2[1]);
584 uv[1] = samp2[0]*tsin(samp2[1]);
585 for (i = 3; i--; )
586 orig[i] = sp->farg[i] + uv[0]*uva[0][i] + uv[1]*uva[1][i];
587 return(1);
588 }
589
590 /* Add triangle to polygon's list (call-back function) */
591 static int
592 add_triangle(const Vert2_list *tp, int a, int b, int c)
593 {
594 POLYTRIS *ptp = (POLYTRIS *)tp->p;
595 struct ptri *trip = ptp->tri + ptp->ntris++;
596
597 trip->vndx[0] = a;
598 trip->vndx[1] = b;
599 trip->vndx[2] = c;
600 return(1);
601 }
602
603 /* Generate origin on polygon surface from uniform random variable */
604 static int
605 ssamp_poly(FVECT orig, SURF *sp, double x)
606 {
607 POLYTRIS *ptp = (POLYTRIS *)sp->priv;
608 double samp2[2];
609 double *v0, *v1, *v2;
610 int i;
611
612 if (ptp == NULL) { /* need to triangulate */
613 ptp = (POLYTRIS *)malloc(sizeof(POLYTRIS) +
614 sizeof(struct ptri)*(sp->nfargs/3 - 3));
615 if (ptp == NULL)
616 goto memerr;
617 if (sp->nfargs == 3) { /* simple case */
618 ptp->ntris = 1;
619 ptp->tri[0].vndx[0] = 0;
620 ptp->tri[0].vndx[1] = 1;
621 ptp->tri[0].vndx[2] = 2;
622 ptp->tri[0].afrac = 1;
623 } else {
624 Vert2_list *v2l = polyAlloc(sp->nfargs/3);
625 if (v2l == NULL)
626 goto memerr;
627 make_axes(ptp->uva, sp->snrm);
628 for (i = v2l->nv; i--; ) {
629 v2l->v[i].mX = DOT(sp->farg+3*i, ptp->uva[0]);
630 v2l->v[i].mY = DOT(sp->farg+3*i, ptp->uva[1]);
631 }
632 ptp->ntris = 0;
633 v2l->p = (void *)ptp;
634 if (!polyTriangulate(v2l, add_triangle)) {
635 fprintf(stderr,
636 "%s: cannot triangulate polygon '%s'\n",
637 progname, sp->sname);
638 return(0);
639 }
640 for (i = ptp->ntris; i--; ) {
641 int a = ptp->tri[i].vndx[0];
642 int b = ptp->tri[i].vndx[1];
643 int c = ptp->tri[i].vndx[2];
644 ptp->tri[i].afrac =
645 (v2l->v[a].mX*v2l->v[b].mY -
646 v2l->v[b].mX*v2l->v[a].mY +
647 v2l->v[b].mX*v2l->v[c].mY -
648 v2l->v[c].mX*v2l->v[b].mY +
649 v2l->v[c].mX*v2l->v[a].mY -
650 v2l->v[a].mX*v2l->v[c].mY) /
651 (2.*sp->area);
652 }
653 polyFree(v2l);
654 }
655 sp->priv = (void *)ptp;
656 }
657 /* pick triangle by partial area */
658 for (i = 0; i < ptp->ntris && x > ptp->tri[i].afrac; i++)
659 x -= ptp->tri[i].afrac;
660 SDmultiSamp(samp2, 2, x/ptp->tri[i].afrac);
661 samp2[0] *= samp2[1] = sqrt(samp2[1]);
662 samp2[1] = 1. - samp2[1];
663 v0 = sp->farg + 3*ptp->tri[i].vndx[0];
664 v1 = sp->farg + 3*ptp->tri[i].vndx[1];
665 v2 = sp->farg + 3*ptp->tri[i].vndx[2];
666 for (i = 3; i--; )
667 orig[i] = v0[i] + samp2[0]*(v1[i] - v0[i])
668 + samp2[1]*(v2[i] - v0[i]) ;
669 return(1);
670 memerr:
671 fputs(progname, stderr);
672 fputs(": out of memory in ssamp_poly!\n", stderr);
673 return(0);
674 }
675
676 /* Compute sample origin based on projected areas of sender subsurfaces */
677 static int
678 sample_origin(PARAMS *p, FVECT orig, const FVECT rdir, double x)
679 {
680 static double *projsa;
681 static int nall;
682 double tarea = 0;
683 int i;
684 SURF *sp;
685 /* special case for lone surface */
686 if (p->nsurfs == 1) {
687 sp = p->slist;
688 if (DOT(sp->snrm, rdir) >= FTINY) {
689 fprintf(stderr,
690 "%s: internal - sample behind sender '%s'\n",
691 progname, sp->sname);
692 return(0);
693 }
694 return((*orig_in_surf[sp->styp])(orig, sp, x));
695 }
696 if (p->nsurfs > nall) { /* (re)allocate surface area cache */
697 if (projsa) free(projsa);
698 projsa = (double *)malloc(sizeof(double)*p->nsurfs);
699 if (!projsa) return(0);
700 nall = p->nsurfs;
701 }
702 /* compute projected areas */
703 for (i = 0, sp = p->slist; sp != NULL; i++, sp = sp->next) {
704 projsa[i] = -DOT(sp->snrm, rdir) * sp->area;
705 tarea += projsa[i] *= (double)(projsa[i] > FTINY);
706 }
707 if (tarea <= FTINY) { /* wrong side of sender? */
708 fputs(progname, stderr);
709 fputs(": internal - sample behind all sender elements!\n",
710 stderr);
711 return(0);
712 }
713 tarea *= x; /* get surface from list */
714 for (i = 0, sp = p->slist; tarea > projsa[i]; sp = sp->next)
715 tarea -= projsa[i++];
716 return((*orig_in_surf[sp->styp])(orig, sp, tarea/projsa[i]));
717 }
718
719 /* Uniform sample generator */
720 static int
721 sample_uniform(PARAMS *p, int b, FILE *fp)
722 {
723 int n = sampcnt;
724 double samp3[3];
725 double duvw[3];
726 FVECT orig_dir[2];
727 int i;
728
729 if (fp == NULL) /* just requesting number of bins? */
730 return(1);
731
732 while (n--) { /* stratified hemisphere sampling */
733 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
734 SDsquare2disk(duvw, samp3[1], samp3[2]);
735 duvw[2] = -sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
736 for (i = 3; i--; )
737 orig_dir[1][i] = duvw[0]*p->udir[i] +
738 duvw[1]*p->vdir[i] +
739 duvw[2]*p->nrm[i] ;
740 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
741 return(0);
742 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
743 return(0);
744 }
745 return(1);
746 }
747
748 /* Shirly-Chiu sample generator */
749 static int
750 sample_shirchiu(PARAMS *p, int b, FILE *fp)
751 {
752 int n = sampcnt;
753 double samp3[3];
754 double duvw[3];
755 FVECT orig_dir[2];
756 int i;
757
758 if (fp == NULL) /* just requesting number of bins? */
759 return(p->hsiz*p->hsiz);
760
761 while (n--) { /* stratified sampling */
762 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
763 SDsquare2disk(duvw, (b/p->hsiz + samp3[1])/curparams.hsiz,
764 (b%p->hsiz + samp3[2])/curparams.hsiz);
765 duvw[2] = sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
766 for (i = 3; i--; )
767 orig_dir[1][i] = -duvw[0]*p->udir[i] -
768 duvw[1]*p->vdir[i] -
769 duvw[2]*p->nrm[i] ;
770 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
771 return(0);
772 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
773 return(0);
774 }
775 return(1);
776 }
777
778 /* Reinhart/Tregenza sample generator */
779 static int
780 sample_reinhart(PARAMS *p, int b, FILE *fp)
781 {
782 #define T_NALT 7
783 static const int tnaz[T_NALT] = {30, 30, 24, 24, 18, 12, 6};
784 const int RowMax = T_NALT*p->hsiz + 1;
785 const double RAH = (.5*PI)/(RowMax-.5);
786 #define rnaz(r) (r >= RowMax-1 ? 1 : p->hsiz*tnaz[r/p->hsiz])
787 int n = sampcnt;
788 int row, col;
789 double samp3[3];
790 double alt, azi;
791 double duvw[3];
792 FVECT orig_dir[2];
793 int i;
794
795 if (fp == NULL) { /* just requesting number of bins? */
796 n = 0;
797 for (row = RowMax; row--; ) n += rnaz(row);
798 return(n);
799 }
800 row = 0; /* identify row & column */
801 col = b;
802 while (col >= rnaz(row)) {
803 col -= rnaz(row);
804 ++row;
805 }
806 while (n--) { /* stratified sampling */
807 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
808 alt = (row+samp3[1])*RAH;
809 azi = (2.*PI)*(col+samp3[2]-.5)/rnaz(row);
810 duvw[2] = cos(alt); /* measured from horizon */
811 duvw[0] = tsin(azi)*duvw[2];
812 duvw[1] = tcos(azi)*duvw[2];
813 duvw[2] = sqrt(1. - duvw[2]*duvw[2]);
814 for (i = 3; i--; )
815 orig_dir[1][i] = -duvw[0]*p->udir[i] -
816 duvw[1]*p->vdir[i] -
817 duvw[2]*p->nrm[i] ;
818 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
819 return(0);
820 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
821 return(0);
822 }
823 return(1);
824 #undef rnaz
825 #undef T_NALT
826 }
827
828 /* Klems sample generator */
829 static int
830 sample_klems(PARAMS *p, int b, FILE *fp)
831 {
832 static const char bname[4][20] = {
833 "LBNL/Klems Full",
834 "LBNL/Klems Half",
835 "INTERNAL ERROR",
836 "LBNL/Klems Quarter"
837 };
838 static ANGLE_BASIS *kbasis[4];
839 const int bi = p->hemis[1] - '1';
840 int n = sampcnt;
841 double samp2[2];
842 double duvw[3];
843 FVECT orig_dir[2];
844 int i;
845
846 if (!kbasis[bi]) { /* need to get basis, first */
847 for (i = 4; i--; )
848 if (!strcasecmp(abase_list[i].name, bname[bi])) {
849 kbasis[bi] = &abase_list[i];
850 break;
851 }
852 if (i < 0) {
853 fprintf(stderr, "%s: unknown hemisphere basis '%s'\n",
854 progname, bname[bi]);
855 return(0);
856 }
857 }
858 if (fp == NULL) /* just requesting number of bins? */
859 return(kbasis[bi]->nangles);
860
861 while (n--) { /* stratified sampling */
862 SDmultiSamp(samp2, 2, (n+frandom())/sampcnt);
863 if (!fo_getvec(duvw, b+samp2[1], kbasis[bi]))
864 return(0);
865 for (i = 3; i--; )
866 orig_dir[1][i] = -duvw[0]*p->udir[i] -
867 duvw[1]*p->vdir[i] -
868 duvw[2]*p->nrm[i] ;
869 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp2[0]))
870 return(0);
871 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
872 return(0);
873 }
874 return(1);
875 }
876
877 /* Prepare hemisphere basis sampler that will send rays to rcontrib */
878 static int
879 prepare_sampler(void)
880 {
881 if (curparams.slist == NULL) { /* missing sample surface! */
882 fputs(progname, stderr);
883 fputs(": no sender surface!\n", stderr);
884 return(-1);
885 }
886 /* misplaced output file spec. */
887 if ((curparams.outfn != NULL) & (verbose >= 0))
888 fprintf(stderr, "%s: warning - ignoring output file in sender ('%s')\n",
889 progname, curparams.outfn);
890 /* check/set basis hemisphere */
891 if (!curparams.hemis[0]) {
892 fputs(progname, stderr);
893 fputs(": missing sender sampling type!\n", stderr);
894 return(-1);
895 }
896 if (normalize(curparams.nrm) == 0) {
897 fputs(progname, stderr);
898 fputs(": undefined normal for sender sampling\n", stderr);
899 return(-1);
900 }
901 if (normalize(curparams.vup) == 0) {
902 if (fabs(curparams.nrm[2]) < .7)
903 curparams.vup[2] = 1;
904 else
905 curparams.vup[1] = 1;
906 }
907 fcross(curparams.udir, curparams.vup, curparams.nrm);
908 if (normalize(curparams.udir) == 0) {
909 fputs(progname, stderr);
910 fputs(": up vector coincides with sender normal\n", stderr);
911 return(-1);
912 }
913 fcross(curparams.vdir, curparams.nrm, curparams.udir);
914 if (curparams.sign == '-') { /* left-handed coordinate system? */
915 curparams.udir[0] *= -1.;
916 curparams.udir[1] *= -1.;
917 curparams.udir[2] *= -1.;
918 }
919 if (tolower(curparams.hemis[0]) == 'u' | curparams.hemis[0] == '1')
920 curparams.sample_basis = sample_uniform;
921 else if (tolower(curparams.hemis[0]) == 's' &&
922 tolower(curparams.hemis[1]) == 'c')
923 curparams.sample_basis = sample_shirchiu;
924 else if ((tolower(curparams.hemis[0]) == 'r') |
925 (tolower(curparams.hemis[0]) == 't'))
926 curparams.sample_basis = sample_reinhart;
927 else if (tolower(curparams.hemis[0]) == 'k') {
928 switch (curparams.hemis[1]) {
929 case '1':
930 case '2':
931 case '4':
932 break;
933 case 'f':
934 case 'F':
935 case '\0':
936 curparams.hemis[1] = '1';
937 break;
938 case 'h':
939 case 'H':
940 curparams.hemis[1] = '2';
941 break;
942 case 'q':
943 case 'Q':
944 curparams.hemis[1] = '4';
945 break;
946 default:
947 goto unrecognized;
948 }
949 curparams.hemis[2] = '\0';
950 curparams.sample_basis = sample_klems;
951 } else
952 goto unrecognized;
953 /* return number of bins */
954 return((*curparams.sample_basis)(&curparams,0,NULL));
955 unrecognized:
956 fprintf(stderr, "%s: unrecognized sender sampling: h=%s\n",
957 progname, curparams.hemis);
958 return(-1);
959 }
960
961 /* Compute normal and area for polygon */
962 static int
963 finish_polygon(SURF *p)
964 {
965 const int nv = p->nfargs / 3;
966 FVECT e1, e2, vc;
967 int i;
968
969 memset(p->snrm, 0, sizeof(FVECT));
970 VSUB(e1, p->farg+3, p->farg);
971 for (i = 2; i < nv; i++) {
972 VSUB(e2, p->farg+3*i, p->farg);
973 VCROSS(vc, e1, e2);
974 p->snrm[0] += vc[0];
975 p->snrm[1] += vc[1];
976 p->snrm[2] += vc[2];
977 VCOPY(e1, e2);
978 }
979 p->area = normalize(p->snrm)*0.5;
980 return(p->area > FTINY);
981 }
982
983 /* Add a surface to our current parameters */
984 static void
985 add_surface(int st, const char *oname, FILE *fp)
986 {
987 SURF *snew;
988 int n;
989 /* get floating-point arguments */
990 if (!fscanf(fp, "%d", &n)) return;
991 while (n-- > 0) fscanf(fp, "%*s");
992 if (!fscanf(fp, "%d", &n)) return;
993 while (n-- > 0) fscanf(fp, "%*d");
994 if (!fscanf(fp, "%d", &n) || n <= 0) return;
995 snew = (SURF *)malloc(sizeof(SURF) + sizeof(double)*(n-1));
996 if (snew == NULL) {
997 fputs(progname, stderr);
998 fputs(": out of memory!\n", stderr);
999 exit(1);
1000 }
1001 strncpy(snew->sname, oname, sizeof(snew->sname)-1);
1002 snew->sname[sizeof(snew->sname)-1] = '\0';
1003 snew->styp = st;
1004 snew->priv = NULL;
1005 snew->nfargs = n;
1006 for (n = 0; n < snew->nfargs; n++)
1007 if (fscanf(fp, "%lf", &snew->farg[n]) != 1) {
1008 fprintf(stderr, "%s: error reading arguments for '%s'\n",
1009 progname, oname);
1010 exit(1);
1011 }
1012 switch (st) {
1013 case ST_RING:
1014 if (snew->nfargs != 8)
1015 goto badcount;
1016 VCOPY(snew->snrm, snew->farg+3);
1017 if (normalize(snew->snrm) == 0)
1018 goto badnorm;
1019 if (snew->farg[7] < snew->farg[6]) {
1020 double t = snew->farg[7];
1021 snew->farg[7] = snew->farg[6];
1022 snew->farg[6] = t;
1023 }
1024 snew->area = PI*(snew->farg[7]*snew->farg[7] -
1025 snew->farg[6]*snew->farg[6]);
1026 break;
1027 case ST_POLY:
1028 if (snew->nfargs < 9 || snew->nfargs % 3)
1029 goto badcount;
1030 finish_polygon(snew);
1031 break;
1032 case ST_SOURCE:
1033 if (snew->nfargs != 4)
1034 goto badcount;
1035 for (n = 3; n--; ) /* need to reverse "normal" */
1036 snew->snrm[n] = -snew->farg[n];
1037 if (normalize(snew->snrm) == 0)
1038 goto badnorm;
1039 snew->area = sin((PI/180./2.)*snew->farg[3]);
1040 snew->area *= PI*snew->area;
1041 break;
1042 }
1043 if ((snew->area <= FTINY) & (verbose >= 0)) {
1044 fprintf(stderr, "%s: warning - zero area for surface '%s'\n",
1045 progname, oname);
1046 free(snew);
1047 return;
1048 }
1049 VSUM(curparams.nrm, curparams.nrm, snew->snrm, snew->area);
1050 snew->next = curparams.slist;
1051 curparams.slist = snew;
1052 curparams.nsurfs++;
1053 return;
1054 badcount:
1055 fprintf(stderr, "%s: bad argument count for surface element '%s'\n",
1056 progname, oname);
1057 exit(1);
1058 badnorm:
1059 fprintf(stderr, "%s: bad orientation for surface element '%s'\n",
1060 progname, oname);
1061 exit(1);
1062 }
1063
1064 /* Parse a receiver object (look for modifiers to add to rcontrib command) */
1065 static int
1066 add_recv_object(FILE *fp)
1067 {
1068 int st;
1069 char thismod[128], otype[32], oname[128];
1070 int n;
1071
1072 if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3)
1073 return(0); /* must have hit EOF! */
1074 if (!strcmp(otype, "alias")) {
1075 fscanf(fp, "%*s"); /* skip alias */
1076 return(0);
1077 }
1078 /* is it a new receiver? */
1079 if ((st = surf_type(otype)) != ST_NONE) {
1080 if (curparams.slist != NULL && (st == ST_SOURCE) ^
1081 (curparams.slist->styp == ST_SOURCE)) {
1082 fputs(progname, stderr);
1083 fputs(": cannot mix source/non-source receivers!\n", stderr);
1084 return(-1);
1085 }
1086 if (strcmp(thismod, curmod)) {
1087 if (curmod[0]) { /* output last receiver? */
1088 finish_receiver();
1089 clear_params(&curparams, 1);
1090 }
1091 parse_params(&curparams, newparams);
1092 newparams[0] = '\0';
1093 strcpy(curmod, thismod);
1094 }
1095 add_surface(st, oname, fp); /* read & store surface */
1096 return(1);
1097 }
1098 /* else skip arguments */
1099 if (!fscanf(fp, "%d", &n)) return(0);
1100 while (n-- > 0) fscanf(fp, "%*s");
1101 if (!fscanf(fp, "%d", &n)) return(0);
1102 while (n-- > 0) fscanf(fp, "%*d");
1103 if (!fscanf(fp, "%d", &n)) return(0);
1104 while (n-- > 0) fscanf(fp, "%*f");
1105 return(0);
1106 }
1107
1108 /* Parse a sender object */
1109 static int
1110 add_send_object(FILE *fp)
1111 {
1112 int st;
1113 char thismod[128], otype[32], oname[128];
1114 int n;
1115
1116 if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3)
1117 return(0); /* must have hit EOF! */
1118 if (!strcmp(otype, "alias")) {
1119 fscanf(fp, "%*s"); /* skip alias */
1120 return(0);
1121 }
1122 /* is it a new surface? */
1123 if ((st = surf_type(otype)) != ST_NONE) {
1124 if (st == ST_SOURCE) {
1125 fputs(progname, stderr);
1126 fputs(": cannot use source as a sender!\n", stderr);
1127 return(-1);
1128 }
1129 if (strcmp(thismod, curmod)) {
1130 if (curmod[0]) {
1131 fputs(progname, stderr);
1132 fputs(": warning - multiple modifiers in sender\n",
1133 stderr);
1134 }
1135 strcpy(curmod, thismod);
1136 }
1137 parse_params(&curparams, newparams);
1138 newparams[0] = '\0';
1139 add_surface(st, oname, fp); /* read & store surface */
1140 return(0);
1141 }
1142 /* else skip arguments */
1143 if (!fscanf(fp, "%d", &n)) return(0);
1144 while (n-- > 0) fscanf(fp, "%*s");
1145 if (!fscanf(fp, "%d", &n)) return(0);
1146 while (n-- > 0) fscanf(fp, "%*d");
1147 if (!fscanf(fp, "%d", &n)) return(0);
1148 while (n-- > 0) fscanf(fp, "%*f");
1149 return(0);
1150 }
1151
1152 /* Load a Radiance scene using the given callback function for objects */
1153 static int
1154 load_scene(const char *inspec, int (*ocb)(FILE *))
1155 {
1156 int rv = 0;
1157 char inpbuf[1024];
1158 FILE *fp;
1159 int c;
1160
1161 if (*inspec == '!')
1162 fp = popen(inspec+1, "r");
1163 else
1164 fp = fopen(inspec, "r");
1165 if (fp == NULL) {
1166 fprintf(stderr, "%s: cannot load '%s'\n", progname, inspec);
1167 return(-1);
1168 }
1169 while ((c = getc(fp)) != EOF) { /* load receiver data */
1170 if (isspace(c)) /* skip leading white space */
1171 continue;
1172 if (c == '!') { /* read from a new command */
1173 inpbuf[0] = c;
1174 if (fgetline(inpbuf+1, sizeof(inpbuf)-1, fp) != NULL) {
1175 if ((c = load_scene(inpbuf, ocb)) < 0)
1176 return(c);
1177 rv += c;
1178 }
1179 continue;
1180 }
1181 if (c == '#') { /* parameters/comment */
1182 if ((c = getc(fp)) == EOF || ungetc(c,fp) == EOF)
1183 break;
1184 if (!isspace(c) && fscanf(fp, "%s", inpbuf) == 1 &&
1185 !strcmp(inpbuf, PARAMSTART)) {
1186 if (fgets(inpbuf, sizeof(inpbuf), fp) != NULL)
1187 strcat(newparams, inpbuf);
1188 continue;
1189 }
1190 while ((c = getc(fp)) != EOF && c != '\n')
1191 ; /* else skipping comment */
1192 continue;
1193 }
1194 ungetc(c, fp); /* else check object for receiver */
1195 c = (*ocb)(fp);
1196 if (c < 0)
1197 return(c);
1198 rv += c;
1199 }
1200 /* close our input stream */
1201 c = (*inspec == '!') ? pclose(fp) : fclose(fp);
1202 if (c != 0) {
1203 fprintf(stderr, "%s: error loading '%s'\n", progname, inspec);
1204 return(-1);
1205 }
1206 return(rv);
1207 }
1208
1209 /* Get command arguments and run program */
1210 int
1211 main(int argc, char *argv[])
1212 {
1213 char fmtopt[6] = "-faa"; /* default output is ASCII */
1214 char *xrs=NULL, *yrs=NULL, *ldopt=NULL;
1215 char *iropt = NULL;
1216 char *sendfn;
1217 char sampcntbuf[32], nsbinbuf[32];
1218 FILE *rcfp;
1219 int nsbins;
1220 int a, i;
1221 /* screen rcontrib options */
1222 progname = argv[0];
1223 for (a = 1; a < argc-2; a++) {
1224 int na;
1225 /* check for argument expansion */
1226 while ((na = expandarg(&argc, &argv, a)) > 0)
1227 ;
1228 if (na < 0) {
1229 fprintf(stderr, "%s: cannot expand '%s'\n",
1230 progname, argv[a]);
1231 return(1);
1232 }
1233 if (argv[a][0] != '-' || !argv[a][1])
1234 break;
1235 na = 1;
1236 switch (argv[a][1]) { /* !! Keep consistent !! */
1237 case 'v': /* verbose mode */
1238 verbose = 1;
1239 na = 0;
1240 continue;
1241 case 'f': /* special case for -fo, -ff, etc. */
1242 switch (argv[a][2]) {
1243 case '\0': /* cal file */
1244 goto userr;
1245 case 'o': /* force output */
1246 goto userr;
1247 case 'a': /* output format */
1248 case 'f':
1249 case 'd':
1250 case 'c':
1251 if (!(fmtopt[3] = argv[a][3]))
1252 fmtopt[3] = argv[a][2];
1253 fmtopt[2] = argv[a][2];
1254 na = 0;
1255 continue; /* will pass later */
1256 default:
1257 goto userr;
1258 }
1259 break;
1260 case 'x': /* x-resolution */
1261 xrs = argv[++a];
1262 na = 0;
1263 continue;
1264 case 'y': /* y-resolution */
1265 yrs = argv[++a];
1266 na = 0;
1267 continue;
1268 case 'c': /* number of samples */
1269 sampcnt = atoi(argv[++a]);
1270 if (sampcnt <= 0)
1271 goto userr;
1272 na = 0; /* we re-add this later */
1273 continue;
1274 case 'I': /* only for pass-through mode */
1275 case 'i':
1276 iropt = argv[a];
1277 na = 0;
1278 continue;
1279 case 'w': /* options without arguments */
1280 if (argv[a][2] != '+') verbose = -1;
1281 case 'V':
1282 case 'u':
1283 case 'h':
1284 case 'r':
1285 break;
1286 case 'n': /* options with 1 argument */
1287 case 's':
1288 case 'o':
1289 na = 2;
1290 break;
1291 case 'b': /* special case */
1292 if (argv[a][2] != 'v') goto userr;
1293 break;
1294 case 'l': /* special case */
1295 if (argv[a][2] == 'd') {
1296 ldopt = argv[a];
1297 na = 0;
1298 continue;
1299 }
1300 na = 2;
1301 break;
1302 case 'd': /* special case */
1303 if (argv[a][2] != 'v') na = 2;
1304 break;
1305 case 'a': /* special case */
1306 if (argv[a][2] == 'p') {
1307 na = 2; /* photon map [+ bandwidth(s)] */
1308 if (a < argc-3 && atoi(argv[a+1]) > 0)
1309 na += 1 + (a < argc-4 && atoi(argv[a+2]) > 0);
1310 } else
1311 na = (argv[a][2] == 'v') ? 4 : 2;
1312 break;
1313 case 'm': /* special case */
1314 if (!argv[a][2]) goto userr;
1315 na = (argv[a][2] == 'e') | (argv[a][2] == 'a') ? 4 : 2;
1316 break;
1317 default: /* anything else is verbotten */
1318 goto userr;
1319 }
1320 if (na <= 0) continue;
1321 CHECKARGC(na); /* pass on option */
1322 rcarg[nrcargs++] = argv[a];
1323 while (--na) /* + arguments if any */
1324 rcarg[nrcargs++] = argv[++a];
1325 }
1326 if (a > argc-2)
1327 goto userr; /* check at end of options */
1328 sendfn = argv[a++]; /* assign sender & receiver inputs */
1329 if (sendfn[0] == '-') { /* user wants pass-through mode? */
1330 if (sendfn[1]) goto userr;
1331 sendfn = NULL;
1332 if (iropt) {
1333 CHECKARGC(1);
1334 rcarg[nrcargs++] = iropt;
1335 }
1336 if (xrs) {
1337 CHECKARGC(2);
1338 rcarg[nrcargs++] = "-x";
1339 rcarg[nrcargs++] = xrs;
1340 }
1341 if (yrs) {
1342 CHECKARGC(2);
1343 rcarg[nrcargs++] = "-y";
1344 rcarg[nrcargs++] = yrs;
1345 }
1346 if (ldopt) {
1347 CHECKARGC(1);
1348 rcarg[nrcargs++] = ldopt;
1349 }
1350 if (sampcnt <= 0) sampcnt = 1;
1351 } else { /* else in sampling mode */
1352 if (iropt) {
1353 fputs(progname, stderr);
1354 fputs(": -i, -I supported for pass-through only\n", stderr);
1355 return(1);
1356 }
1357 fmtopt[2] = (sizeof(RREAL)==sizeof(double)) ? 'd' : 'f';
1358 if (sampcnt <= 0) sampcnt = 10000;
1359 }
1360 sprintf(sampcntbuf, "%d", sampcnt);
1361 CHECKARGC(3); /* add our format & sample count */
1362 rcarg[nrcargs++] = fmtopt;
1363 rcarg[nrcargs++] = "-c";
1364 rcarg[nrcargs++] = sampcntbuf;
1365 /* add receiver arguments to rcontrib */
1366 if (load_scene(argv[a], add_recv_object) < 0)
1367 return(1);
1368 finish_receiver();
1369 if (sendfn == NULL) { /* pass-through mode? */
1370 CHECKARGC(1); /* add octree */
1371 rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1372 rcarg[nrcargs] = NULL;
1373 return(my_exec(rcarg)); /* rcontrib does everything */
1374 }
1375 clear_params(&curparams, 0); /* else load sender surface & params */
1376 curmod[0] = '\0';
1377 if (load_scene(sendfn, add_send_object) < 0)
1378 return(1);
1379 if ((nsbins = prepare_sampler()) <= 0)
1380 return(1);
1381 CHECKARGC(3); /* add row count and octree */
1382 rcarg[nrcargs++] = "-y";
1383 sprintf(nsbinbuf, "%d", nsbins);
1384 rcarg[nrcargs++] = nsbinbuf;
1385 rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1386 rcarg[nrcargs] = NULL;
1387 /* open pipe to rcontrib process */
1388 if ((rcfp = popen_arglist(rcarg, "w")) == NULL)
1389 return(1);
1390 SET_FILE_BINARY(rcfp);
1391 #ifdef getc_unlocked
1392 flockfile(rcfp);
1393 #endif
1394 if (verbose > 0) {
1395 fprintf(stderr, "%s: sampling %d directions", progname, nsbins);
1396 if (curparams.nsurfs > 1)
1397 fprintf(stderr, " (%d elements)\n", curparams.nsurfs);
1398 else
1399 fputc('\n', stderr);
1400 }
1401 for (i = 0; i < nsbins; i++) /* send rcontrib ray samples */
1402 if (!(*curparams.sample_basis)(&curparams, i, rcfp))
1403 return(1);
1404 return(pclose(rcfp) < 0); /* all finished! */
1405 userr:
1406 if (a < argc-2)
1407 fprintf(stderr, "%s: unsupported option '%s'", progname, argv[a]);
1408 fprintf(stderr, "Usage: %s [-v][rcontrib options] sender.rad receiver.rad [-i system.oct] [system.rad ..]\n",
1409 progname);
1410 return(1);
1411 }
