root/radiance/ray/src/util/rfluxmtx.c
Tue Jun 3 21:31:51 2025 UTC (2 months ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.59: +3 -4 lines
Diff to previous 2.59 , to selected 2.43
Fri Apr 4 01:08:33 2025 UTC (4 months ago) by greg
Diff to previous 2.58 , to selected 2.43
fix(rfluxmtx): Fixed check of hemispherical sources when mixed (needed to complete last change)
Wed Mar 19 01:18:20 2025 UTC (4 months, 3 weeks ago) by greg
Changes since 2.57: +1 -7 lines
Diff to previous 2.57 , to selected 2.43
feat(rfluxmtx): Allow source and non-source receivers, which is valid in some cases
Tue Mar 19 10:48:05 2024 UTC (16 months, 3 weeks ago) by greg
Changes since 2.56: +3 -3 lines
Diff to previous 2.56 , to selected 2.43
fix(rfluxmtx,genBSDF): Fixed issue with -c{s,w} argument parsing
Thu Feb 8 02:26:01 2024 UTC (18 months ago) by greg
Changes since 2.55: +10 -1 lines
Diff to previous 2.55 , to selected 2.43
Wed Nov 15 18:02:53 2023 UTC (20 months, 3 weeks ago) by greg
Changes since 2.54: +16 -6 lines
Diff to previous 2.54 , to selected 2.43
Wed Dec 15 01:38:50 2021 UTC (3 years, 7 months ago) by greg
Changes since 2.53: +5 -7 lines
Diff to previous 2.53 , to selected 2.43
refactor: removed prefix from SDdisk2square() and SDsquare2disk() & made consistent
Wed Sep 9 21:28:19 2020 UTC (4 years, 10 months ago) by greg
Changes since 2.52: +2 -1 lines
Diff to previous 2.52 , to selected 2.43
Mon Sep 7 04:06:17 2020 UTC (4 years, 11 months ago) by greg
Changes since 2.51: +5 -5 lines
Diff to previous 2.51 , to selected 2.43
fix(rfluxmtx): Fixed issue with too-small polygons
Mon Mar 2 22:00:05 2020 UTC (5 years, 5 months ago) by greg
Changes since 2.50: +58 -5 lines
Diff to previous 2.50 , to selected 2.43
Switched pipe output to use open_process() call on Unix
Tue Dec 10 19:18:43 2019 UTC (5 years, 8 months ago) by greg
Diff to previous 2.49 , to selected 2.43
Fixed glitch in previous change
Tue Dec 10 19:15:54 2019 UTC (5 years, 8 months ago) by greg
Changes since 2.48: +5 -3 lines
Diff to previous 2.48 , to selected 2.43
Made -w option a little more robust
Mon Jul 29 22:52:39 2019 UTC (6 years ago) by greg
Changes since 2.47: +14 -6 lines
Diff to previous 2.47 , to selected 2.43
Made more robust to special characters (and spaces) in file names
Sun Mar 3 17:01:13 2019 UTC (6 years, 5 months ago) by greg
Diff to previous 2.46 , to selected 2.43
Changed test to strict zero because it can sometimes be that!
Mon Oct 1 15:51:48 2018 UTC (6 years, 10 months ago) by greg
Changes since 2.45: +4 -2 lines
Diff to previous 2.45 , to selected 2.43
Made rcontrib command-line length more generous to handle more receivers
Sat May 13 01:50:54 2017 UTC (8 years, 2 months ago) by greg
Changes since 2.44: +4 -2 lines
Diff to previous 2.44 , to selected 2.43
Fixed axis reversal in Reinhart sample generator (wrong since August 2014)
Thu Apr 13 22:47:17 2017 UTC (8 years, 3 months ago) by greg
Changes since 2.43: +3 -3 lines
Diff to previous 2.43
Added parens to eliminate compiler warnings
Revision 2.43 - (view) (download) (annotate) - [selected]
Tue Feb 7 19:53:59 2017 UTC (8 years, 6 months ago) by greg
Diff to previous 2.42
More consistent use of warnings
Thu Dec 22 17:28:06 2016 UTC (8 years, 7 months ago) by greg
Changes since 2.41: +6 -2 lines
Diff to previous 2.41 , to selected 2.43
Minor change -- should not affect anything
Sat Aug 20 03:43:24 2016 UTC (8 years, 11 months ago) by greg
Diff to previous 2.40 , to selected 2.43
Another tweak to reduce floating point error accumulation
Sat Aug 20 03:36:04 2016 UTC (8 years, 11 months ago) by greg
Diff to previous 2.39 , to selected 2.43
Reverted unnecessary change and introduced new potential fix for FP inaccuracy
Fri Aug 19 18:31:26 2016 UTC (8 years, 11 months ago) by greg
Diff to previous 2.38 , to selected 2.43
Possible fix to memory error (manifests on Windows)
Thu Aug 18 00:52:48 2016 UTC (8 years, 11 months ago) by greg
Diff to previous 2.37 , to selected 2.43
Fri Apr 15 00:06:36 2016 UTC (9 years, 3 months ago) by greg
Changes since 2.36: +7 -3 lines
Diff to previous 2.36 , to selected 2.43
Added missing call to exit on memory error
Sun Mar 6 01:13:18 2016 UTC (9 years, 5 months ago) by schorsch
Diff to previous 2.35 , to selected 2.43
Fri Mar 4 00:21:21 2016 UTC (9 years, 5 months ago) by greg
Changes since 2.34: +1 -6 lines
Diff to previous 2.34 , to selected 2.43
Tue Feb 2 18:02:32 2016 UTC (9 years, 6 months ago) by greg
Changes since 2.33: +2 -58 lines
Diff to previous 2.33 , to selected 2.43
Tue Feb 2 01:43:24 2016 UTC (9 years, 6 months ago) by greg
Changes since 2.32: +2 -4 lines
Diff to previous 2.32 , to selected 2.43
Removed redundant error output
Fri Dec 4 22:16:18 2015 UTC (9 years, 8 months ago) by greg
Changes since 2.31: +15 -5 lines
Diff to previous 2.31 , to selected 2.43
Added support for (quoted) output commands in rfluxmtx
Sun Sep 13 21:09:20 2015 UTC (9 years, 10 months ago) by greg
Diff to previous 2.30 , to selected 2.43
Fixed bug in sample testing discovered by Rob G.
Wed Jul 22 04:23:27 2015 UTC (10 years ago) by greg
Changes since 2.29: +35 -24 lines
Diff to previous 2.29 , to selected 2.43
Improved matrix multiplication accuracy by forcing promotions to double
Thu May 21 05:54:54 2015 UTC (10 years, 2 months ago) by greg
Diff to previous 2.28 , to selected 2.43
Tue May 19 12:13:53 2015 UTC (10 years, 2 months ago) by greg
Changes since 2.27: +7 -2 lines
Diff to previous 2.27 , to selected 2.43
Added option passing for photon map
Wed Apr 1 01:38:36 2015 UTC (10 years, 4 months ago) by greg
Diff to previous 2.26 , to selected 2.43
Fixes for Klems & tensor tree coordinate orientations
Fri Mar 27 18:58:06 2015 UTC (10 years, 4 months ago) by greg
Changes since 2.25: +28 -12 lines
Diff to previous 2.25 , to selected 2.43
Fri Mar 20 15:19:22 2015 UTC (10 years, 4 months ago) by greg
Diff to previous 2.24 , to selected 2.43
Fixed bug introduced in last change.
Thu Mar 12 15:36:11 2015 UTC (10 years, 5 months ago) by greg
Changes since 2.23: +12 -3 lines
Diff to previous 2.23 , to selected 2.43
Added warning for sender files with multiple modifier names
Wed Feb 18 06:18:38 2015 UTC (10 years, 5 months ago) by greg
Diff to previous 2.22 , to selected 2.43
Fixed return code
Wed Feb 18 06:16:02 2015 UTC (10 years, 5 months ago) by greg
Diff to previous 2.21 , to selected 2.43
Fixed verbose report
Wed Feb 18 05:56:12 2015 UTC (10 years, 5 months ago) by greg
Diff to previous 2.20 , to selected 2.43
Fixed bug where second and later #@rfluxmtx lines in succession were ignored
Mon Feb 2 16:04:11 2015 UTC (10 years, 6 months ago) by greg
Changes since 2.19: +5 -2 lines
Diff to previous 2.19 , to selected 2.43
Fixed uniform receivers so backside does not get contributions
Thu Dec 4 05:26:28 2014 UTC (10 years, 8 months ago) by greg
Changes since 2.18: +3 -12 lines
Diff to previous 2.18 , to selected 2.43
Tue Aug 26 19:10:10 2014 UTC (10 years, 11 months ago) by greg
CVS Tags: rad4R2P1, rad4R2P2
Diff to previous 2.17 , to selected 2.43
Fixed Reinhart sky sender sampling
Tue Aug 26 18:56:19 2014 UTC (10 years, 11 months ago) by greg
Diff to previous 2.16 , to selected 2.43
Fixed vector sampling directions for Klems senders and Reinhart sky receivers
Tue Aug 26 07:41:29 2014 UTC (10 years, 11 months ago) by greg
Changes since 2.15: +12 -10 lines
Diff to previous 2.15 , to selected 2.43
Pays attention to -w option internally
Fri Aug 15 19:59:56 2014 UTC (10 years, 11 months ago) by greg
Changes since 2.14: +8 -4 lines
Diff to previous 2.14 , to selected 2.43
Fixed bugs in parameter parsing
Wed Aug 6 02:38:24 2014 UTC (11 years ago) by greg
Changes since 2.13: +15 -7 lines
Diff to previous 2.13 , to selected 2.43
Wed Aug 6 00:59:53 2014 UTC (11 years ago) by greg
Changes since 2.12: +12 -9 lines
Diff to previous 2.12 , to selected 2.43
Mon Jul 28 16:30:18 2014 UTC (11 years ago) by greg
CVS Tags: rad4R2
Diff to previous 2.11 , to selected 2.43
Added inclusion of rtprocess.h
Fri Jul 25 19:23:14 2014 UTC (11 years ago) by greg
Diff to previous 2.10 , to selected 2.43
Also limit "-i" support to pass-through mode
Fri Jul 25 17:03:06 2014 UTC (11 years ago) by greg
Changes since 2.9: +10 -8 lines
Diff to previous 2.9 , to selected 2.43
Fixed other missing return values
Fri Jul 25 16:58:20 2014 UTC (11 years ago) by greg
Diff to previous 2.8 , to selected 2.43
Fixed bug in setting of receiver normal for sources
Fri Jul 25 15:46:10 2014 UTC (11 years ago) by greg
Changes since 2.7: +20 -5 lines
Diff to previous 2.7 , to selected 2.43
Added -I option support in pass-through and fixed source orientation
Wed Jul 23 22:39:40 2014 UTC (11 years ago) by greg
Changes since 2.6: +22 -10 lines
Diff to previous 2.6 , to selected 2.43
Added better error messages and fixed bug in Reinhart/Tregenza sampling
Wed Jul 23 00:40:17 2014 UTC (11 years ago) by greg
Changes since 2.5: +22 -19 lines
Diff to previous 2.5 , to selected 2.43
Fixed most of the other bugs
Tue Jul 22 23:21:56 2014 UTC (11 years ago) by greg
Changes since 2.4: +7 -4 lines
Diff to previous 2.4 , to selected 2.43
Fixed some bugs... more to go
Tue Jul 22 21:55:31 2014 UTC (11 years ago) by greg
Changes since 2.3: +47 -6 lines
Diff to previous 2.3 , to selected 2.43
Tue Jul 22 02:12:48 2014 UTC (11 years ago) by greg
Changes since 2.2: +19 -11 lines
Diff to previous 2.2 , to selected 2.43
Added Reinhart sky cal file
Mon Jul 21 15:59:47 2014 UTC (11 years ago) by greg
Changes since 2.1: +61 -69 lines
Diff to previous 2.1 , to selected 2.43
Getting close to working version of rfluxmtx
Sat Jul 19 01:19:49 2014 UTC (11 years ago) by greg
Diff to selected 2.43
Checking in incomplete and untested version of rfluxmtx
