Made rcontrib command-line length more generous to handle more receivers
Fixed axis reversal in Reinhart sample generator (wrong since August 2014)
Added parens to eliminate compiler warnings
More consistent use of warnings
Minor change -- should not affect anything
Another tweak to reduce floating point error accumulation
Reverted unnecessary change and introduced new potential fix for FP inaccuracy
Possible fix to memory error (manifests on Windows)
Added missing call to exit on memory error
Removed redundant error output
Added support for (quoted) output commands in rfluxmtx
Fixed bug in sample testing discovered by Rob G.
Improved matrix multiplication accuracy by forcing promotions to double
Added option passing for photon map
Fixes for Klems & tensor tree coordinate orientations
Fixed bug introduced in last change.
Added warning for sender files with multiple modifier names
Fixed return code
Fixed verbose report
Fixed bug where second and later #@rfluxmtx lines in succession were ignored
Fixed uniform receivers so backside does not get contributions
Fixed Reinhart sky sender sampling
Fixed vector sampling directions for Klems senders and Reinhart sky receivers
Pays attention to -w option internally
Fixed bugs in parameter parsing
Added inclusion of rtprocess.h
Also limit "-i" support to pass-through mode
Fixed other missing return values
Fixed bug in setting of receiver normal for sources
Added -I option support in pass-through and fixed source orientation
Added better error messages and fixed bug in Reinhart/Tregenza sampling
Fixed most of the other bugs
Fixed some bugs... more to go
Added Reinhart sky cal file
Getting close to working version of rfluxmtx
