--- ray/src/util/rfluxmtx.c 2014/07/25 15:46:10 2.8 +++ ray/src/util/rfluxmtx.c 2014/07/25 19:23:14 2.11 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rfluxmtx.c,v 2.8 2014/07/25 15:46:10 greg Exp $"; +static const char RCSid[] = "$Id: rfluxmtx.c,v 2.11 2014/07/25 19:23:14 greg Exp $"; #endif /* * Calculate flux transfer matrix or matrices using rcontrib @@ -401,11 +401,12 @@ finish_receiver(void) fputs(": undefined normal for hemisphere sampling\n", stderr); exit(1); } - if (normalize(curparams.vup) == 0) + if (normalize(curparams.vup) == 0) { if (fabs(curparams.nrm[2]) < .7) curparams.vup[2] = 1; else curparams.vup[1] = 1; + } /* determine sample type/bin */ if (tolower(curparams.hemis[0]) == 'u' | curparams.hemis[0] == '1') { binv = "0"; /* uniform sampling -- one bin */ @@ -419,7 +420,7 @@ finish_receiver(void) exit(1); } calfn = shirchiufn; shirchiufn = NULL; - sprintf(sbuf, "SCdim=%d,Nx=%g,Ny=%g,Nz=%g,Ux=%g,Uy=%g,Uz=%g", + sprintf(sbuf, "SCdim=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g", curparams.hsiz, curparams.nrm[0], curparams.nrm[1], curparams.nrm[2], curparams.vup[0], curparams.vup[1], curparams.vup[2]); @@ -429,7 +430,7 @@ finish_receiver(void) } else if ((tolower(curparams.hemis[0]) == 'r') | (tolower(curparams.hemis[0]) == 't')) { calfn = reinhfn; reinhfn = NULL; - sprintf(sbuf, "MF=%d,Nx=%g,Ny=%g,Nz=%g,Ux=%g,Uy=%g,Uz=%g", + sprintf(sbuf, "MF=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g", curparams.hsiz, curparams.nrm[0], curparams.nrm[1], curparams.nrm[2], curparams.vup[0], curparams.vup[1], curparams.vup[2]); @@ -872,11 +873,12 @@ prepare_sampler(void) fputs(": undefined normal for sender sampling\n", stderr); return(-1); } - if (normalize(curparams.vup) == 0) + if (normalize(curparams.vup) == 0) { if (fabs(curparams.nrm[2]) < .7) curparams.vup[2] = 1; else curparams.vup[1] = 1; + } VCROSS(curparams.udir, curparams.vup, curparams.nrm); if (normalize(curparams.udir) == 0) { fputs(progname, stderr); @@ -1066,9 +1068,9 @@ add_recv_object(FILE *fp) /* else skip arguments */ if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*s"); - if (!fscanf(fp, "%d", &n)) return; + if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*d"); - if (!fscanf(fp, "%d", &n)) return; + if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*f"); return(0); } @@ -1102,9 +1104,9 @@ add_send_object(FILE *fp) /* else skip arguments */ if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*s"); - if (!fscanf(fp, "%d", &n)) return; + if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*d"); - if (!fscanf(fp, "%d", &n)) return; + if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*f"); return(0); } @@ -1147,7 +1149,7 @@ load_scene(const char *inspec, int (*ocb)(FILE *)) strcat(newparams, inpbuf); continue; } - while ((c = getc(fp)) != EOF && c != '\n'); + while ((c = getc(fp)) != EOF && c != '\n') ; /* else skipping comment */ continue; } @@ -1172,7 +1174,7 @@ main(int argc, char *argv[]) { char fmtopt[6] = "-faa"; /* default output is ASCII */ char *xrs=NULL, *yrs=NULL, *ldopt=NULL; - int wantIrradiance = 0; + char *iropt = NULL; char *sendfn; char sampcntbuf[32], nsbinbuf[32]; FILE *rcfp; @@ -1221,13 +1223,13 @@ main(int argc, char *argv[]) na = 0; /* we re-add this later */ continue; case 'I': /* only for pass-through mode */ - wantIrradiance = 1; + case 'i': + iropt = argv[a]; na = 0; continue; case 'V': /* options without arguments */ case 'w': case 'u': - case 'i': case 'h': case 'r': break; @@ -1275,9 +1277,9 @@ done_opts: if (sendfn[0] == '-') { /* user wants pass-through mode? */ if (sendfn[1]) goto userr; sendfn = NULL; - if (wantIrradiance) { + if (iropt) { CHECKARGC(1); - rcarg[nrcargs++] = "-I"; + rcarg[nrcargs++] = iropt; } if (xrs) { CHECKARGC(2); @@ -1295,9 +1297,9 @@ done_opts: } if (sampcnt <= 0) sampcnt = 1; } else { /* else in sampling mode */ - if (wantIrradiance) { + if (iropt) { fputs(progname, stderr); - fputs(": -I supported for pass-through only\n", stderr); + fputs(": -i, -I supported for pass-through only\n", stderr); return(1); } fmtopt[2] = (sizeof(RREAL)==sizeof(double)) ? 'd' : 'f';
