root/radiance/ray/src/util/rfluxmtx.c
Revision: 2.18
Committed: Tue Aug 26 19:10:10 2014 UTC (9 years, 9 months ago) by greg
CVS Tags: rad4R2P2, rad4R2P1
Fixed Reinhart sky sender sampling
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.18 static const char RCSid[] = "$Id: rfluxmtx.c,v 2.17 2014/08/26 18:56:19 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Calculate flux transfer matrix or matrices using rcontrib
6     */
7
8     #include "copyright.h"
9
10     #include <ctype.h>
11     #include <stdlib.h>
12     #include "rtio.h"
13     #include "rtmath.h"
14 greg 2.12 #include "rtprocess.h"
15 greg 2.1 #include "bsdf.h"
16     #include "bsdf_m.h"
17     #include "random.h"
18     #include "triangulate.h"
19     #include "platform.h"
20
21     #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
22     #undef getc
23     #define getc getc_unlocked
24     #endif
25
26     #ifdef _WIN32
27 greg 2.2 #define SPECIALS " \t\"$*?"
28 greg 2.1 #define QUOTCHAR '"'
29     #else
30 greg 2.2 #define SPECIALS " \t\n'\"()${}*?[];|&"
31 greg 2.1 #define QUOTCHAR '\''
32     #define ALTQUOT '"'
33     #endif
34
35     #define MAXRCARG 512
36
37     char *progname; /* global argv[0] */
38
39 greg 2.16 int verbose = 0; /* verbose mode (< 0 no warnings) */
40 greg 2.1
41     char *rcarg[MAXRCARG+1] = {"rcontrib", "-fo+"};
42     int nrcargs = 2;
43
44     const char overflowerr[] = "%s: too many arguments!\n";
45
46     #define CHECKARGC(n) if (nrcargs >= MAXRCARG-(n)) \
47     { fprintf(stderr, overflowerr, progname); exit(1); }
48
49 greg 2.2 int sampcnt = 0; /* sample count (0==unset) */
50 greg 2.1
51 greg 2.2 char *reinhfn = "reinhartb.cal";
52     char *shirchiufn = "disk2square.cal";
53 greg 2.1 char *kfullfn = "klems_full.cal";
54     char *khalffn = "klems_half.cal";
55     char *kquarterfn = "klems_quarter.cal";
56
57 greg 2.5 /* string indicating parameters */
58     const char PARAMSTART[] = "@rfluxmtx";
59 greg 2.1
60     /* surface type IDs */
61     #define ST_NONE 0
62     #define ST_POLY 1
63     #define ST_RING 2
64     #define ST_SOURCE 3
65
66     typedef struct surf_s {
67     struct surf_s *next; /* next surface in list */
68     void *priv; /* private data (malloc'ed) */
69     char sname[32]; /* surface name */
70     FVECT snrm; /* surface normal */
71 greg 2.4 double area; /* surface area / proj. solid angle */
72 greg 2.1 short styp; /* surface type */
73 greg 2.2 short nfargs; /* number of real arguments */
74     double farg[1]; /* real values (extends struct) */
75 greg 2.1 } SURF; /* surface structure */
76
77     typedef struct {
78     FVECT uva[2]; /* tangent axes */
79     int ntris; /* number of triangles */
80     struct ptri {
81     float afrac; /* fraction of total area */
82     short vndx[3]; /* vertex indices */
83     } tri[1]; /* triangle array (extends struct) */
84     } POLYTRIS; /* triangulated polygon */
85
86     typedef struct param_s {
87     char hemis[32]; /* hemispherical sampling spec. */
88     int hsiz; /* hemisphere basis size */
89     int nsurfs; /* number of surfaces */
90     SURF *slist; /* list of surfaces */
91     FVECT vup; /* up vector (zero if unset) */
92     FVECT nrm; /* average normal direction */
93     FVECT udir, vdir; /* v-up tangent axes */
94     char *outfn; /* output file name (receiver) */
95     int (*sample_basis)(struct param_s *p, int, FILE *);
96     } PARAMS; /* sender/receiver parameters */
97
98     PARAMS curparams;
99     char curmod[128];
100 greg 2.6 char newparams[1024];
101 greg 2.1
102     typedef int SURFSAMP(FVECT, SURF *, double);
103
104     static SURFSAMP ssamp_bad, ssamp_poly, ssamp_ring;
105
106     SURFSAMP *orig_in_surf[4] = {
107     ssamp_bad, ssamp_poly, ssamp_ring, ssamp_bad
108     };
109
110     /* Clear parameter set */
111     static void
112     clear_params(PARAMS *p, int reset_only)
113     {
114     while (p->slist != NULL) {
115     SURF *sdel = p->slist;
116     p->slist = sdel->next;
117     if (sdel->priv != NULL)
118     free(sdel->priv);
119     free(sdel);
120     }
121     if (reset_only) {
122     p->nsurfs = 0;
123     memset(p->nrm, 0, sizeof(FVECT));
124     memset(p->vup, 0, sizeof(FVECT));
125     p->outfn = NULL;
126     return;
127     }
128 greg 2.6 memset(p, 0, sizeof(PARAMS));
129 greg 2.1 }
130
131     /* Get surface type from name */
132     static int
133     surf_type(const char *otype)
134     {
135     if (!strcmp(otype, "polygon"))
136     return(ST_POLY);
137     if (!strcmp(otype, "ring"))
138     return(ST_RING);
139     if (!strcmp(otype, "source"))
140     return(ST_SOURCE);
141     return(ST_NONE);
142     }
143
144     /* Add arguments to oconv command */
145     static char *
146     oconv_command(int ac, char *av[])
147     {
148 greg 2.13 static char oconvbuf[2048] = "!oconv -f ";
149     char *cp = oconvbuf + 10;
150     char *recv = *av++;
151
152     if (ac-- <= 0)
153     return(NULL);
154 greg 2.1 while (ac-- > 0) {
155 greg 2.13 strcpy(cp, *av++);
156     while (*cp) cp++;
157     *cp++ = ' ';
158 greg 2.1 if (cp >= oconvbuf+(sizeof(oconvbuf)-32)) {
159     fputs(progname, stderr);
160     fputs(": too many file arguments!\n", stderr);
161     exit(1);
162     }
163     }
164 greg 2.13 strcpy(cp, recv); /* receiver goes last */
165 greg 2.1 return(oconvbuf);
166     }
167
168     /* Check if any of the characters in str2 are found in str1 */
169     static int
170     matchany(const char *str1, const char *str2)
171     {
172     while (*str1) {
173     const char *cp = str2;
174     while (*cp)
175     if (*cp++ == *str1)
176     return(*str1);
177     ++str1;
178     }
179     return(0);
180     }
181
182
183     /* Convert a set of arguments into a command line for pipe() or system() */
184     static char *
185     convert_commandline(char *cmd, const int len, char *av[])
186     {
187     int match;
188     char *cp;
189
190     for (cp = cmd; *av != NULL; av++) {
191     const int n = strlen(*av);
192     if (cp+n >= cmd+(len-3)) {
193     fputs(progname, stderr);
194     return(NULL);
195     }
196     if ((match = matchany(*av, SPECIALS))) {
197     const int quote =
198     #ifdef ALTQUOT
199     (match == QUOTCHAR) ? ALTQUOT :
200     #endif
201     QUOTCHAR;
202     *cp++ = quote;
203     strcpy(cp, *av);
204     cp += n;
205     *cp++ = quote;
206     } else {
207     strcpy(cp, *av);
208     cp += n;
209     }
210     *cp++ = ' ';
211     }
212     if (cp <= cmd)
213     return(NULL);
214     *--cp = '\0';
215     return(cmd);
216     }
217
218     /* Open a pipe to/from a command given as an argument list */
219     static FILE *
220     popen_arglist(char *av[], char *mode)
221     {
222     char cmd[10240];
223
224     if (!convert_commandline(cmd, sizeof(cmd), av)) {
225     fputs(progname, stderr);
226     fputs(": command line too long in popen_arglist()\n", stderr);
227     return(NULL);
228     }
229 greg 2.16 if (verbose > 0)
230 greg 2.1 fprintf(stderr, "%s: opening pipe %s: %s\n",
231     progname, (*mode=='w') ? "to" : "from", cmd);
232     return(popen(cmd, mode));
233     }
234
235     #ifdef _WIN32
236     /* Execute system command (Windows version) */
237     static int
238     my_exec(char *av[])
239     {
240     char cmd[10240];
241
242     if (!convert_commandline(cmd, sizeof(cmd), av)) {
243     fputs(progname, stderr);
244     fputs(": command line too long in my_exec()\n", stderr);
245     return(1);
246     }
247 greg 2.16 if (verbose > 0)
248 greg 2.1 fprintf(stderr, "%s: running: %s\n", progname, cmd);
249     return(system(cmd));
250     }
251     #else
252     /* Execute system command in our stead (Unix version) */
253     static int
254     my_exec(char *av[])
255     {
256     char *compath;
257
258     if ((compath = getpath((char *)av[0], getenv("PATH"), X_OK)) == NULL) {
259     fprintf(stderr, "%s: cannot locate %s\n", progname, av[0]);
260     return(1);
261     }
262 greg 2.16 if (verbose > 0) {
263 greg 2.1 char cmd[4096];
264     if (!convert_commandline(cmd, sizeof(cmd), av))
265     strcpy(cmd, "COMMAND TOO LONG TO SHOW");
266     fprintf(stderr, "%s: running: %s\n", progname, cmd);
267     }
268     execv(compath, av); /* successful call never returns */
269     perror(compath);
270     return(1);
271     }
272     #endif
273
274     /* Get normalized direction vector from string specification */
275     static int
276     get_direction(FVECT dv, const char *s)
277     {
278     int sign = 1;
279     int axis = 0;
280
281     memset(dv, 0, sizeof(FVECT));
282     nextchar:
283     switch (*s) {
284     case '+':
285     ++s;
286     goto nextchar;
287     case '-':
288     sign = -sign;
289     ++s;
290     goto nextchar;
291     case 'z':
292     case 'Z':
293     ++axis;
294     case 'y':
295     case 'Y':
296     ++axis;
297     case 'x':
298     case 'X':
299     dv[axis] = sign;
300     return(!s[1] | isspace(s[1]));
301     default:
302     break;
303     }
304     #ifdef SMLFLT
305     if (sscanf(s, "%f,%f,%f", &dv[0], &dv[1], &dv[2]) != 3)
306     #else
307     if (sscanf(s, "%lf,%lf,%lf", &dv[0], &dv[1], &dv[2]) != 3)
308     #endif
309     return(0);
310     dv[0] *= (RREAL)sign;
311     return(normalize(dv) > 0);
312     }
313
314     /* Parse program parameters (directives) */
315     static int
316 greg 2.6 parse_params(PARAMS *p, char *pargs)
317 greg 2.1 {
318     char *cp = pargs;
319     int nparams = 0;
320     int i;
321
322 greg 2.15 for ( ; ; ) {
323 greg 2.1 switch (*cp++) {
324     case 'h':
325     if (*cp++ != '=')
326     break;
327 greg 2.6 p->hsiz = 0;
328 greg 2.1 i = 0;
329     while (*cp && !isspace(*cp)) {
330     if (isdigit(*cp))
331 greg 2.6 p->hsiz = 10*p->hsiz + *cp - '0';
332     p->hemis[i++] = *cp++;
333 greg 2.1 }
334     if (!i)
335     break;
336 greg 2.6 p->hemis[i] = '\0';
337     p->hsiz += !p->hsiz;
338 greg 2.1 ++nparams;
339     continue;
340     case 'u':
341     if (*cp++ != '=')
342     break;
343 greg 2.6 if (!get_direction(p->vup, cp))
344 greg 2.1 break;
345 greg 2.15 while (*cp && !isspace(*cp++))
346     ;
347 greg 2.1 ++nparams;
348     continue;
349     case 'o':
350     if (*cp++ != '=')
351     break;
352     i = 0;
353     while (*cp && !isspace(*cp++))
354     i++;
355     if (!i)
356     break;
357     *--cp = '\0';
358 greg 2.6 p->outfn = savqstr(cp-i);
359 greg 2.1 *cp++ = ' ';
360     ++nparams;
361     continue;
362     case ' ':
363     case '\t':
364     case '\r':
365 greg 2.15 continue;
366 greg 2.1 case '\n':
367     case '\0':
368     return(nparams);
369     default:
370     break;
371     }
372 greg 2.15 break;
373     }
374     fprintf(stderr, "%s: bad parameter string: %s", progname, pargs);
375 greg 2.1 exit(1);
376     return(-1); /* pro forma return */
377     }
378
379     /* Add receiver arguments (directives) corresponding to the current modifier */
380     static void
381     finish_receiver(void)
382     {
383 greg 2.4 char sbuf[256];
384     int uniform = 0;
385 greg 2.2 char *calfn = NULL;
386 greg 2.3 char *params = NULL;
387 greg 2.2 char *binv = NULL;
388     char *binf = NULL;
389     char *nbins = NULL;
390 greg 2.1
391     if (!curmod[0]) {
392     fputs(progname, stderr);
393     fputs(": missing receiver surface!\n", stderr);
394     exit(1);
395     }
396     if (curparams.outfn != NULL) { /* add output file spec. */
397     CHECKARGC(2);
398     rcarg[nrcargs++] = "-o";
399     rcarg[nrcargs++] = curparams.outfn;
400     }
401 greg 2.4 /* check arguments */
402 greg 2.1 if (!curparams.hemis[0]) {
403     fputs(progname, stderr);
404     fputs(": missing hemisphere sampling type!\n", stderr);
405     exit(1);
406     }
407     if (normalize(curparams.nrm) == 0) {
408     fputs(progname, stderr);
409     fputs(": undefined normal for hemisphere sampling\n", stderr);
410     exit(1);
411     }
412 greg 2.10 if (normalize(curparams.vup) == 0) {
413 greg 2.1 if (fabs(curparams.nrm[2]) < .7)
414     curparams.vup[2] = 1;
415     else
416     curparams.vup[1] = 1;
417 greg 2.10 }
418 greg 2.4 /* determine sample type/bin */
419 greg 2.1 if (tolower(curparams.hemis[0]) == 'u' | curparams.hemis[0] == '1') {
420 greg 2.3 binv = "0"; /* uniform sampling -- one bin */
421 greg 2.4 uniform = 1;
422 greg 2.1 } else if (tolower(curparams.hemis[0]) == 's' &&
423     tolower(curparams.hemis[1]) == 'c') {
424 greg 2.2 /* assign parameters */
425 greg 2.1 if (curparams.hsiz <= 1) {
426     fputs(progname, stderr);
427     fputs(": missing size for Shirley-Chiu sampling!\n", stderr);
428     exit(1);
429     }
430 greg 2.3 calfn = shirchiufn; shirchiufn = NULL;
431 greg 2.9 sprintf(sbuf, "SCdim=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g",
432 greg 2.2 curparams.hsiz,
433     curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
434     curparams.vup[0], curparams.vup[1], curparams.vup[2]);
435 greg 2.3 params = savqstr(sbuf);
436 greg 2.2 binv = "scbin";
437     nbins = "SCdim*SCdim";
438 greg 2.1 } else if ((tolower(curparams.hemis[0]) == 'r') |
439     (tolower(curparams.hemis[0]) == 't')) {
440 greg 2.2 calfn = reinhfn; reinhfn = NULL;
441 greg 2.9 sprintf(sbuf, "MF=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g",
442 greg 2.3 curparams.hsiz,
443     curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
444     curparams.vup[0], curparams.vup[1], curparams.vup[2]);
445     params = savqstr(sbuf);
446     binv = "rbin";
447     nbins = "Nrbins";
448 greg 2.1 } else if (tolower(curparams.hemis[0]) == 'k' &&
449     !curparams.hemis[1] |
450     (tolower(curparams.hemis[1]) == 'f') |
451     (curparams.hemis[1] == '1')) {
452 greg 2.2 calfn = kfullfn; kfullfn = NULL;
453     binf = "kbin";
454     nbins = "Nkbins";
455 greg 2.1 } else if (tolower(curparams.hemis[0]) == 'k' &&
456     (tolower(curparams.hemis[1]) == 'h') |
457     (curparams.hemis[1] == '2')) {
458 greg 2.2 calfn = khalffn; khalffn = NULL;
459     binf = "khbin";
460     nbins = "Nkhbins";
461 greg 2.1 } else if (tolower(curparams.hemis[0]) == 'k' &&
462     (tolower(curparams.hemis[1]) == 'q') |
463     (curparams.hemis[1] == '4')) {
464 greg 2.2 calfn = kquarterfn; kquarterfn = NULL;
465     binf = "kqbin";
466     nbins = "Nkqbins";
467 greg 2.1 } else {
468     fprintf(stderr, "%s: unrecognized hemisphere sampling: h=%s\n",
469     progname, curparams.hemis);
470     exit(1);
471     }
472 greg 2.4 if (!uniform & (curparams.slist->styp == ST_SOURCE)) {
473     SURF *sp;
474     for (sp = curparams.slist; sp != NULL; sp = sp->next)
475     if (fabs(sp->area - PI) > 1e-3) {
476     fprintf(stderr, "%s: source '%s' must be 180-degrees\n",
477     progname, sp->sname);
478     exit(1);
479     }
480     }
481 greg 2.2 if (calfn != NULL) { /* add cal file if needed */
482     CHECKARGC(2);
483     rcarg[nrcargs++] = "-f";
484     rcarg[nrcargs++] = calfn;
485     }
486 greg 2.3 if (params != NULL) { /* parameters _after_ cal file */
487     CHECKARGC(2);
488     rcarg[nrcargs++] = "-p";
489     rcarg[nrcargs++] = params;
490     }
491 greg 2.2 if (nbins != NULL) { /* add #bins if set */
492     CHECKARGC(2);
493     rcarg[nrcargs++] = "-bn";
494     rcarg[nrcargs++] = nbins;
495     }
496 greg 2.3 if (binv != NULL) {
497 greg 2.2 CHECKARGC(2); /* assign bin variable */
498     rcarg[nrcargs++] = "-b";
499     rcarg[nrcargs++] = binv;
500     } else if (binf != NULL) {
501     CHECKARGC(2); /* assign bin function */
502 greg 2.3 rcarg[nrcargs++] = "-b";
503 greg 2.2 sprintf(sbuf, "%s(%g,%g,%g,%g,%g,%g)", binf,
504     curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
505     curparams.vup[0], curparams.vup[1], curparams.vup[2]);
506     rcarg[nrcargs++] = savqstr(sbuf);
507     }
508     CHECKARGC(2); /* modifier argument goes last */
509 greg 2.1 rcarg[nrcargs++] = "-m";
510     rcarg[nrcargs++] = savqstr(curmod);
511     }
512
513     /* Make randomly oriented tangent plane axes for given normal direction */
514     static void
515     make_axes(FVECT uva[2], const FVECT nrm)
516     {
517     int i;
518
519     uva[1][0] = 0.5 - frandom();
520     uva[1][1] = 0.5 - frandom();
521     uva[1][2] = 0.5 - frandom();
522     for (i = 3; i--; )
523     if ((-0.6 < nrm[i]) & (nrm[i] < 0.6))
524     break;
525     if (i < 0) {
526     fputs(progname, stderr);
527     fputs(": bad surface normal in make_axes!\n", stderr);
528     exit(1);
529     }
530     uva[1][i] = 1.0;
531     VCROSS(uva[0], uva[1], nrm);
532     normalize(uva[0]);
533     VCROSS(uva[1], nrm, uva[0]);
534     }
535
536     /* Illegal sender surfaces end up here */
537     static int
538     ssamp_bad(FVECT orig, SURF *sp, double x)
539     {
540     fprintf(stderr, "%s: illegal sender surface '%s'\n",
541     progname, sp->sname);
542     return(0);
543     }
544
545     /* Generate origin on ring surface from uniform random variable */
546     static int
547     ssamp_ring(FVECT orig, SURF *sp, double x)
548     {
549     FVECT *uva = (FVECT *)sp->priv;
550     double samp2[2];
551     double uv[2];
552     int i;
553
554     if (uva == NULL) { /* need tangent axes */
555     uva = (FVECT *)malloc(sizeof(FVECT)*2);
556     if (uva == NULL) {
557     fputs(progname, stderr);
558     fputs(": out of memory in ssamp_ring!\n", stderr);
559     return(0);
560     }
561     make_axes(uva, sp->snrm);
562     sp->priv = (void *)uva;
563     }
564     SDmultiSamp(samp2, 2, x);
565 greg 2.6 samp2[0] = sqrt(samp2[0]*sp->area*(1./PI) + sp->farg[6]*sp->farg[6]);
566 greg 2.1 samp2[1] *= 2.*PI;
567     uv[0] = samp2[0]*tcos(samp2[1]);
568     uv[1] = samp2[0]*tsin(samp2[1]);
569     for (i = 3; i--; )
570     orig[i] = sp->farg[i] + uv[0]*uva[0][i] + uv[1]*uva[1][i];
571     return(1);
572     }
573
574     /* Add triangle to polygon's list (call-back function) */
575     static int
576     add_triangle(const Vert2_list *tp, int a, int b, int c)
577     {
578     POLYTRIS *ptp = (POLYTRIS *)tp->p;
579     struct ptri *trip = ptp->tri + ptp->ntris++;
580
581     trip->vndx[0] = a;
582     trip->vndx[1] = b;
583     trip->vndx[2] = c;
584     return(1);
585     }
586
587     /* Generate origin on polygon surface from uniform random variable */
588     static int
589     ssamp_poly(FVECT orig, SURF *sp, double x)
590     {
591     POLYTRIS *ptp = (POLYTRIS *)sp->priv;
592     double samp2[2];
593     double *v0, *v1, *v2;
594     int i;
595
596     if (ptp == NULL) { /* need to triangulate */
597     ptp = (POLYTRIS *)malloc(sizeof(POLYTRIS) +
598     sizeof(struct ptri)*(sp->nfargs/3 - 3));
599     if (ptp == NULL)
600     goto memerr;
601     if (sp->nfargs == 3) { /* simple case */
602     ptp->ntris = 1;
603     ptp->tri[0].vndx[0] = 0;
604     ptp->tri[0].vndx[1] = 1;
605     ptp->tri[0].vndx[2] = 2;
606     ptp->tri[0].afrac = 1;
607     } else {
608     Vert2_list *v2l = polyAlloc(sp->nfargs/3);
609     if (v2l == NULL)
610     goto memerr;
611     make_axes(ptp->uva, sp->snrm);
612     for (i = v2l->nv; i--; ) {
613     v2l->v[i].mX = DOT(sp->farg+3*i, ptp->uva[0]);
614     v2l->v[i].mY = DOT(sp->farg+3*i, ptp->uva[1]);
615     }
616     ptp->ntris = 0;
617     v2l->p = (void *)ptp;
618 greg 2.7 if (!polyTriangulate(v2l, add_triangle)) {
619     fprintf(stderr,
620     "%s: cannot triangulate polygon '%s'\n",
621     progname, sp->sname);
622 greg 2.1 return(0);
623 greg 2.7 }
624 greg 2.1 for (i = ptp->ntris; i--; ) {
625     int a = ptp->tri[i].vndx[0];
626     int b = ptp->tri[i].vndx[1];
627     int c = ptp->tri[i].vndx[2];
628     ptp->tri[i].afrac =
629     (v2l->v[a].mX*v2l->v[b].mY -
630     v2l->v[b].mX*v2l->v[a].mY +
631     v2l->v[b].mX*v2l->v[c].mY -
632     v2l->v[c].mX*v2l->v[b].mY +
633     v2l->v[c].mX*v2l->v[a].mY -
634     v2l->v[a].mX*v2l->v[c].mY) /
635     (2.*sp->area);
636     }
637     polyFree(v2l);
638     }
639     sp->priv = (void *)ptp;
640     }
641     /* pick triangle by partial area */
642     for (i = 0; i < ptp->ntris && x > ptp->tri[i].afrac; i++)
643     x -= ptp->tri[i].afrac;
644     SDmultiSamp(samp2, 2, x/ptp->tri[i].afrac);
645     samp2[0] *= samp2[1] = sqrt(samp2[1]);
646     samp2[1] = 1. - samp2[1];
647     v0 = sp->farg + 3*ptp->tri[i].vndx[0];
648     v1 = sp->farg + 3*ptp->tri[i].vndx[1];
649     v2 = sp->farg + 3*ptp->tri[i].vndx[2];
650     for (i = 3; i--; )
651     orig[i] = v0[i] + samp2[0]*(v1[i] - v0[i])
652     + samp2[1]*(v2[i] - v0[i]) ;
653     return(1);
654     memerr:
655     fputs(progname, stderr);
656     fputs(": out of memory in ssamp_poly!\n", stderr);
657     return(0);
658     }
659
660     /* Compute sample origin based on projected areas of sender subsurfaces */
661     static int
662     sample_origin(PARAMS *p, FVECT orig, const FVECT rdir, double x)
663     {
664     static double *projsa;
665     static int nall;
666     double tarea = 0;
667     int i;
668     SURF *sp;
669     /* special case for lone surface */
670     if (p->nsurfs == 1) {
671     sp = p->slist;
672 greg 2.7 if (DOT(sp->snrm, rdir) >= -FTINY) {
673     fprintf(stderr,
674     "%s: internal - sample behind sender '%s'\n",
675     progname, sp->sname);
676     return(0);
677     }
678 greg 2.1 return((*orig_in_surf[sp->styp])(orig, sp, x));
679     }
680     if (p->nsurfs > nall) { /* (re)allocate surface area cache */
681     if (projsa) free(projsa);
682     projsa = (double *)malloc(sizeof(double)*p->nsurfs);
683     if (!projsa) return(0);
684     nall = p->nsurfs;
685     }
686     /* compute projected areas */
687     for (i = 0, sp = p->slist; sp != NULL; i++, sp = sp->next) {
688     projsa[i] = -DOT(sp->snrm, rdir) * sp->area;
689     tarea += projsa[i] *= (double)(projsa[i] > FTINY);
690     }
691 greg 2.7 if (tarea <= FTINY) { /* wrong side of sender? */
692     fputs(progname, stderr);
693     fputs(": internal - sample behind all sender elements!\n",
694     stderr);
695 greg 2.1 return(0);
696 greg 2.7 }
697 greg 2.1 tarea *= x; /* get surface from list */
698     for (i = 0, sp = p->slist; tarea > projsa[i]; sp = sp->next)
699     tarea -= projsa[i++];
700     return((*orig_in_surf[sp->styp])(orig, sp, tarea/projsa[i]));
701     }
702
703     /* Uniform sample generator */
704     static int
705     sample_uniform(PARAMS *p, int b, FILE *fp)
706     {
707     int n = sampcnt;
708     double samp3[3];
709     double duvw[3];
710     FVECT orig_dir[2];
711     int i;
712
713     if (fp == NULL) /* just requesting number of bins? */
714     return(1);
715
716     while (n--) { /* stratified hemisphere sampling */
717     SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
718     SDsquare2disk(duvw, samp3[1], samp3[2]);
719     duvw[2] = -sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
720     for (i = 3; i--; )
721     orig_dir[1][i] = duvw[0]*p->udir[i] +
722     duvw[1]*p->vdir[i] +
723     duvw[2]*p->nrm[i] ;
724     if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
725     return(0);
726     if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
727     return(0);
728     }
729     return(1);
730     }
731
732     /* Shirly-Chiu sample generator */
733     static int
734     sample_shirchiu(PARAMS *p, int b, FILE *fp)
735     {
736     int n = sampcnt;
737     double samp3[3];
738     double duvw[3];
739     FVECT orig_dir[2];
740     int i;
741
742     if (fp == NULL) /* just requesting number of bins? */
743     return(p->hsiz*p->hsiz);
744
745     while (n--) { /* stratified sampling */
746     SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
747     SDsquare2disk(duvw, (b/p->hsiz + samp3[1])/curparams.hsiz,
748     (b%p->hsiz + samp3[2])/curparams.hsiz);
749     duvw[2] = sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
750     for (i = 3; i--; )
751     orig_dir[1][i] = -duvw[0]*p->udir[i] -
752     duvw[1]*p->vdir[i] -
753     duvw[2]*p->nrm[i] ;
754     if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
755     return(0);
756     if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
757     return(0);
758     }
759     return(1);
760     }
761
762     /* Reinhart/Tregenza sample generator */
763     static int
764     sample_reinhart(PARAMS *p, int b, FILE *fp)
765     {
766     #define T_NALT 7
767     static const int tnaz[T_NALT] = {30, 30, 24, 24, 18, 12, 6};
768     const int RowMax = T_NALT*p->hsiz + 1;
769 greg 2.7 const double RAH = (.5*PI)/(RowMax-.5);
770 greg 2.1 #define rnaz(r) (r >= RowMax-1 ? 1 : p->hsiz*tnaz[r/p->hsiz])
771     int n = sampcnt;
772     int row, col;
773     double samp3[3];
774     double alt, azi;
775     double duvw[3];
776     FVECT orig_dir[2];
777     int i;
778
779     if (fp == NULL) { /* just requesting number of bins? */
780     n = 0;
781     for (row = RowMax; row--; ) n += rnaz(row);
782     return(n);
783     }
784     row = 0; /* identify row & column */
785     col = b;
786     while (col >= rnaz(row)) {
787     col -= rnaz(row);
788     ++row;
789     }
790     while (n--) { /* stratified sampling */
791     SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
792     alt = (row+samp3[1])*RAH;
793     azi = (2.*PI)*(col+samp3[2]-.5)/rnaz(row);
794 greg 2.7 duvw[2] = cos(alt); /* measured from horizon */
795 greg 2.18 duvw[0] = tsin(azi)*duvw[2];
796     duvw[1] = tcos(azi)*duvw[2];
797 greg 2.1 duvw[2] = sqrt(1. - duvw[2]*duvw[2]);
798     for (i = 3; i--; )
799     orig_dir[1][i] = -duvw[0]*p->udir[i] -
800     duvw[1]*p->vdir[i] -
801     duvw[2]*p->nrm[i] ;
802     if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
803     return(0);
804     if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
805     return(0);
806     }
807     return(1);
808     #undef rnaz
809     #undef T_NALT
810     }
811
812     /* Klems sample generator */
813     static int
814     sample_klems(PARAMS *p, int b, FILE *fp)
815     {
816     static const char bname[4][20] = {
817     "LBNL/Klems Full",
818     "LBNL/Klems Half",
819     "INTERNAL ERROR",
820     "LBNL/Klems Quarter"
821     };
822     static ANGLE_BASIS *kbasis[4];
823     const int bi = p->hemis[1] - '1';
824     int n = sampcnt;
825     double samp2[2];
826     double duvw[3];
827     FVECT orig_dir[2];
828     int i;
829
830     if (!kbasis[bi]) { /* need to get basis, first */
831     for (i = 4; i--; )
832     if (!strcasecmp(abase_list[i].name, bname[bi])) {
833     kbasis[bi] = &abase_list[i];
834     break;
835     }
836     if (i < 0) {
837     fprintf(stderr, "%s: unknown hemisphere basis '%s'\n",
838     progname, bname[bi]);
839     return(0);
840     }
841     }
842     if (fp == NULL) /* just requesting number of bins? */
843     return(kbasis[bi]->nangles);
844
845     while (n--) { /* stratified sampling */
846     SDmultiSamp(samp2, 2, (n+frandom())/sampcnt);
847 greg 2.17 if (!bi_getvec(duvw, b+samp2[1], kbasis[bi]))
848 greg 2.1 return(0);
849     for (i = 3; i--; )
850     orig_dir[1][i] = duvw[0]*p->udir[i] +
851     duvw[1]*p->vdir[i] +
852     duvw[2]*p->nrm[i] ;
853     if (!sample_origin(p, orig_dir[0], orig_dir[1], samp2[0]))
854     return(0);
855     if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
856     return(0);
857     }
858     return(1);
859     }
860
861     /* Prepare hemisphere basis sampler that will send rays to rcontrib */
862     static int
863     prepare_sampler(void)
864     {
865     if (curparams.slist == NULL) { /* missing sample surface! */
866     fputs(progname, stderr);
867     fputs(": no sender surface!\n", stderr);
868     return(-1);
869     }
870 greg 2.16 /* misplaced output file spec. */
871     if ((curparams.outfn != NULL) & (verbose >= 0))
872 greg 2.1 fprintf(stderr, "%s: warning - ignoring output file in sender ('%s')\n",
873     progname, curparams.outfn);
874     /* check/set basis hemisphere */
875     if (!curparams.hemis[0]) {
876     fputs(progname, stderr);
877     fputs(": missing sender sampling type!\n", stderr);
878     return(-1);
879     }
880     if (normalize(curparams.nrm) == 0) {
881     fputs(progname, stderr);
882     fputs(": undefined normal for sender sampling\n", stderr);
883     return(-1);
884     }
885 greg 2.10 if (normalize(curparams.vup) == 0) {
886 greg 2.1 if (fabs(curparams.nrm[2]) < .7)
887     curparams.vup[2] = 1;
888     else
889     curparams.vup[1] = 1;
890 greg 2.10 }
891 greg 2.1 VCROSS(curparams.udir, curparams.vup, curparams.nrm);
892     if (normalize(curparams.udir) == 0) {
893     fputs(progname, stderr);
894     fputs(": up vector coincides with sender normal\n", stderr);
895     return(-1);
896     }
897     VCROSS(curparams.vdir, curparams.nrm, curparams.udir);
898     if (tolower(curparams.hemis[0]) == 'u' | curparams.hemis[0] == '1')
899     curparams.sample_basis = sample_uniform;
900     else if (tolower(curparams.hemis[0]) == 's' &&
901     tolower(curparams.hemis[1]) == 'c')
902     curparams.sample_basis = sample_shirchiu;
903     else if ((tolower(curparams.hemis[0]) == 'r') |
904     (tolower(curparams.hemis[0]) == 't'))
905     curparams.sample_basis = sample_reinhart;
906     else if (tolower(curparams.hemis[0]) == 'k') {
907     switch (curparams.hemis[1]) {
908     case '1':
909     case '2':
910     case '4':
911     break;
912     case 'f':
913     case 'F':
914     case '\0':
915     curparams.hemis[1] = '1';
916     break;
917     case 'h':
918     case 'H':
919     curparams.hemis[1] = '2';
920     break;
921     case 'q':
922     case 'Q':
923     curparams.hemis[1] = '4';
924     break;
925     default:
926     goto unrecognized;
927     }
928     curparams.hemis[2] = '\0';
929     curparams.sample_basis = sample_klems;
930     } else
931     goto unrecognized;
932     /* return number of bins */
933     return((*curparams.sample_basis)(&curparams,0,NULL));
934     unrecognized:
935     fprintf(stderr, "%s: unrecognized sender sampling: h=%s\n",
936     progname, curparams.hemis);
937     return(-1);
938     }
939
940     /* Compute normal and area for polygon */
941     static int
942     finish_polygon(SURF *p)
943     {
944     const int nv = p->nfargs / 3;
945     FVECT e1, e2, vc;
946     int i;
947
948     memset(p->snrm, 0, sizeof(FVECT));
949     VSUB(e1, p->farg+3, p->farg);
950     for (i = 2; i < nv; i++) {
951     VSUB(e2, p->farg+3*i, p->farg);
952     VCROSS(vc, e1, e2);
953     p->snrm[0] += vc[0];
954     p->snrm[1] += vc[1];
955     p->snrm[2] += vc[2];
956     VCOPY(e1, e2);
957     }
958     p->area = normalize(p->snrm)*0.5;
959     return(p->area > FTINY);
960     }
961
962     /* Add a surface to our current parameters */
963     static void
964     add_surface(int st, const char *oname, FILE *fp)
965     {
966     SURF *snew;
967     int n;
968     /* get floating-point arguments */
969     if (!fscanf(fp, "%d", &n)) return;
970     while (n-- > 0) fscanf(fp, "%*s");
971     if (!fscanf(fp, "%d", &n)) return;
972     while (n-- > 0) fscanf(fp, "%*d");
973     if (!fscanf(fp, "%d", &n) || n <= 0) return;
974     snew = (SURF *)malloc(sizeof(SURF) + sizeof(double)*(n-1));
975     if (snew == NULL) {
976     fputs(progname, stderr);
977     fputs(": out of memory!\n", stderr);
978     exit(1);
979     }
980     strncpy(snew->sname, oname, sizeof(snew->sname)-1);
981     snew->sname[sizeof(snew->sname)-1] = '\0';
982     snew->styp = st;
983     snew->priv = NULL;
984     snew->nfargs = n;
985     for (n = 0; n < snew->nfargs; n++)
986     if (fscanf(fp, "%lf", &snew->farg[n]) != 1) {
987     fprintf(stderr, "%s: error reading arguments for '%s'\n",
988     progname, oname);
989     exit(1);
990     }
991     switch (st) {
992     case ST_RING:
993     if (snew->nfargs != 8)
994     goto badcount;
995     VCOPY(snew->snrm, snew->farg+3);
996     if (normalize(snew->snrm) == 0)
997     goto badnorm;
998     if (snew->farg[7] < snew->farg[6]) {
999     double t = snew->farg[7];
1000     snew->farg[7] = snew->farg[6];
1001     snew->farg[6] = t;
1002     }
1003     snew->area = PI*(snew->farg[7]*snew->farg[7] -
1004     snew->farg[6]*snew->farg[6]);
1005     break;
1006     case ST_POLY:
1007     if (snew->nfargs < 9 || snew->nfargs % 3)
1008     goto badcount;
1009     finish_polygon(snew);
1010     break;
1011     case ST_SOURCE:
1012     if (snew->nfargs != 4)
1013     goto badcount;
1014 greg 2.8 for (n = 3; n--; ) /* need to reverse "normal" */
1015     snew->snrm[n] = -snew->farg[n];
1016 greg 2.1 if (normalize(snew->snrm) == 0)
1017     goto badnorm;
1018 greg 2.4 snew->area = sin((PI/180./2.)*snew->farg[3]);
1019     snew->area *= PI*snew->area;
1020 greg 2.1 break;
1021     }
1022 greg 2.16 if ((snew->area <= FTINY) & (verbose >= 0)) {
1023 greg 2.1 fprintf(stderr, "%s: warning - zero area for surface '%s'\n",
1024     progname, oname);
1025     free(snew);
1026     return;
1027     }
1028     VSUM(curparams.nrm, curparams.nrm, snew->snrm, snew->area);
1029     snew->next = curparams.slist;
1030     curparams.slist = snew;
1031     curparams.nsurfs++;
1032     return;
1033     badcount:
1034 greg 2.7 fprintf(stderr, "%s: bad argument count for surface element '%s'\n",
1035 greg 2.1 progname, oname);
1036     exit(1);
1037     badnorm:
1038 greg 2.7 fprintf(stderr, "%s: bad orientation for surface element '%s'\n",
1039 greg 2.1 progname, oname);
1040     exit(1);
1041     }
1042
1043     /* Parse a receiver object (look for modifiers to add to rcontrib command) */
1044     static int
1045     add_recv_object(FILE *fp)
1046     {
1047     int st;
1048     char thismod[128], otype[32], oname[128];
1049     int n;
1050
1051     if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3)
1052     return(0); /* must have hit EOF! */
1053     if (!strcmp(otype, "alias")) {
1054     fscanf(fp, "%*s"); /* skip alias */
1055     return(0);
1056     }
1057     /* is it a new receiver? */
1058     if ((st = surf_type(otype)) != ST_NONE) {
1059     if (curparams.slist != NULL && (st == ST_SOURCE) ^
1060     (curparams.slist->styp == ST_SOURCE)) {
1061     fputs(progname, stderr);
1062     fputs(": cannot mix source/non-source receivers!\n", stderr);
1063     return(-1);
1064     }
1065     if (strcmp(thismod, curmod)) {
1066     if (curmod[0]) { /* output last receiver? */
1067     finish_receiver();
1068     clear_params(&curparams, 1);
1069     }
1070 greg 2.6 parse_params(&curparams, newparams);
1071     newparams[0] = '\0';
1072 greg 2.1 strcpy(curmod, thismod);
1073     }
1074     add_surface(st, oname, fp); /* read & store surface */
1075     return(1);
1076     }
1077     /* else skip arguments */
1078 greg 2.8 if (!fscanf(fp, "%d", &n)) return(0);
1079 greg 2.1 while (n-- > 0) fscanf(fp, "%*s");
1080 greg 2.10 if (!fscanf(fp, "%d", &n)) return(0);
1081 greg 2.1 while (n-- > 0) fscanf(fp, "%*d");
1082 greg 2.10 if (!fscanf(fp, "%d", &n)) return(0);
1083 greg 2.1 while (n-- > 0) fscanf(fp, "%*f");
1084     return(0);
1085     }
1086
1087     /* Parse a sender object */
1088     static int
1089     add_send_object(FILE *fp)
1090     {
1091     int st;
1092     char otype[32], oname[128];
1093     int n;
1094
1095     if (fscanf(fp, "%*s %s %s", otype, oname) != 2)
1096     return(0); /* must have hit EOF! */
1097     if (!strcmp(otype, "alias")) {
1098     fscanf(fp, "%*s"); /* skip alias */
1099     return(0);
1100     }
1101     /* is it a new surface? */
1102     if ((st = surf_type(otype)) != ST_NONE) {
1103     if (st == ST_SOURCE) {
1104     fputs(progname, stderr);
1105     fputs(": cannot use source as a sender!\n", stderr);
1106     return(-1);
1107     }
1108 greg 2.6 parse_params(&curparams, newparams);
1109     newparams[0] = '\0';
1110 greg 2.1 add_surface(st, oname, fp); /* read & store surface */
1111     return(0);
1112     }
1113     /* else skip arguments */
1114 greg 2.8 if (!fscanf(fp, "%d", &n)) return(0);
1115 greg 2.1 while (n-- > 0) fscanf(fp, "%*s");
1116 greg 2.10 if (!fscanf(fp, "%d", &n)) return(0);
1117 greg 2.1 while (n-- > 0) fscanf(fp, "%*d");
1118 greg 2.10 if (!fscanf(fp, "%d", &n)) return(0);
1119 greg 2.1 while (n-- > 0) fscanf(fp, "%*f");
1120     return(0);
1121     }
1122
1123     /* Load a Radiance scene using the given callback function for objects */
1124     static int
1125     load_scene(const char *inspec, int (*ocb)(FILE *))
1126     {
1127     int rv = 0;
1128     char inpbuf[1024];
1129     FILE *fp;
1130     int c;
1131
1132     if (*inspec == '!')
1133     fp = popen(inspec+1, "r");
1134     else
1135     fp = fopen(inspec, "r");
1136     if (fp == NULL) {
1137     fprintf(stderr, "%s: cannot load '%s'\n", progname, inspec);
1138     return(-1);
1139     }
1140     while ((c = getc(fp)) != EOF) { /* load receiver data */
1141     if (isspace(c)) /* skip leading white space */
1142     continue;
1143     if (c == '!') { /* read from a new command */
1144     inpbuf[0] = c;
1145     if (fgetline(inpbuf+1, sizeof(inpbuf)-1, fp) != NULL) {
1146     if ((c = load_scene(inpbuf, ocb)) < 0)
1147     return(c);
1148     rv += c;
1149     }
1150     continue;
1151     }
1152     if (c == '#') { /* parameters/comment */
1153 greg 2.5 if ((c = getc(fp)) == EOF || ungetc(c,fp) == EOF)
1154     break;
1155     if (!isspace(c) && fscanf(fp, "%s", inpbuf) == 1 &&
1156 greg 2.1 !strcmp(inpbuf, PARAMSTART)) {
1157     if (fgets(inpbuf, sizeof(inpbuf), fp) != NULL)
1158 greg 2.6 strcat(newparams, inpbuf);
1159 greg 2.1 continue;
1160     }
1161 greg 2.10 while ((c = getc(fp)) != EOF && c != '\n')
1162 greg 2.1 ; /* else skipping comment */
1163     continue;
1164     }
1165     ungetc(c, fp); /* else check object for receiver */
1166     c = (*ocb)(fp);
1167     if (c < 0)
1168     return(c);
1169     rv += c;
1170     }
1171     /* close our input stream */
1172     c = (*inspec == '!') ? pclose(fp) : fclose(fp);
1173     if (c != 0) {
1174     fprintf(stderr, "%s: error loading '%s'\n", progname, inspec);
1175     return(-1);
1176     }
1177     return(rv);
1178     }
1179
1180     /* Get command arguments and run program */
1181     int
1182     main(int argc, char *argv[])
1183     {
1184     char fmtopt[6] = "-faa"; /* default output is ASCII */
1185 greg 2.4 char *xrs=NULL, *yrs=NULL, *ldopt=NULL;
1186 greg 2.11 char *iropt = NULL;
1187 greg 2.1 char *sendfn;
1188     char sampcntbuf[32], nsbinbuf[32];
1189     FILE *rcfp;
1190     int nsbins;
1191     int a, i;
1192     /* screen rcontrib options */
1193     progname = argv[0];
1194 greg 2.14 for (a = 1; a < argc-2; a++) {
1195     int na;
1196     /* check for argument expansion */
1197     while ((na = expandarg(&argc, &argv, a)) > 0)
1198     ;
1199     if (na < 0) {
1200     fprintf(stderr, "%s: cannot expand '%s'\n",
1201     progname, argv[a]);
1202     return(1);
1203     }
1204     if (argv[a][0] != '-' || !argv[a][1])
1205     break;
1206     na = 1;
1207     switch (argv[a][1]) { /* !! Keep consistent !! */
1208 greg 2.1 case 'v': /* verbose mode */
1209 greg 2.16 verbose = 1;
1210 greg 2.1 na = 0;
1211     continue;
1212     case 'f': /* special case for -fo, -ff, etc. */
1213     switch (argv[a][2]) {
1214     case '\0': /* cal file */
1215     goto userr;
1216     case 'o': /* force output */
1217     goto userr;
1218     case 'a': /* output format */
1219     case 'f':
1220     case 'd':
1221     case 'c':
1222 greg 2.6 if (!(fmtopt[3] = argv[a][3]))
1223     fmtopt[3] = argv[a][2];
1224     fmtopt[2] = argv[a][2];
1225 greg 2.1 na = 0;
1226     continue; /* will pass later */
1227     default:
1228     goto userr;
1229     }
1230     break;
1231 greg 2.4 case 'x': /* x-resolution */
1232     xrs = argv[++a];
1233     na = 0;
1234     continue;
1235     case 'y': /* y-resolution */
1236     yrs = argv[++a];
1237     na = 0;
1238     continue;
1239 greg 2.1 case 'c': /* number of samples */
1240 greg 2.6 sampcnt = atoi(argv[++a]);
1241 greg 2.1 if (sampcnt <= 0)
1242     goto userr;
1243     na = 0; /* we re-add this later */
1244     continue;
1245 greg 2.8 case 'I': /* only for pass-through mode */
1246 greg 2.11 case 'i':
1247     iropt = argv[a];
1248 greg 2.8 na = 0;
1249     continue;
1250 greg 2.16 case 'w': /* options without arguments */
1251     if (argv[a][2] != '+') verbose = -1;
1252     case 'V':
1253 greg 2.1 case 'u':
1254     case 'h':
1255 greg 2.4 case 'r':
1256 greg 2.1 break;
1257     case 'n': /* options with 1 argument */
1258     case 's':
1259     case 'o':
1260     na = 2;
1261     break;
1262     case 'b': /* special case */
1263     if (argv[a][2] != 'v') goto userr;
1264     break;
1265     case 'l': /* special case */
1266 greg 2.4 if (argv[a][2] == 'd') {
1267     ldopt = argv[a];
1268     na = 0;
1269     continue;
1270     }
1271 greg 2.1 na = 2;
1272     break;
1273     case 'd': /* special case */
1274     if (argv[a][2] != 'v') na = 2;
1275     break;
1276     case 'a': /* special case */
1277     na = (argv[a][2] == 'v') ? 4 : 2;
1278     break;
1279     case 'm': /* special case */
1280     if (!argv[a][2]) goto userr;
1281     na = (argv[a][2] == 'e') | (argv[a][2] == 'a') ? 4 : 2;
1282     break;
1283     default: /* anything else is verbotten */
1284     goto userr;
1285     }
1286     if (na <= 0) continue;
1287     CHECKARGC(na); /* pass on option */
1288     rcarg[nrcargs++] = argv[a];
1289     while (--na) /* + arguments if any */
1290     rcarg[nrcargs++] = argv[++a];
1291     }
1292     if (a > argc-2)
1293     goto userr; /* check at end of options */
1294     sendfn = argv[a++]; /* assign sender & receiver inputs */
1295     if (sendfn[0] == '-') { /* user wants pass-through mode? */
1296     if (sendfn[1]) goto userr;
1297     sendfn = NULL;
1298 greg 2.11 if (iropt) {
1299 greg 2.8 CHECKARGC(1);
1300 greg 2.11 rcarg[nrcargs++] = iropt;
1301 greg 2.8 }
1302 greg 2.4 if (xrs) {
1303     CHECKARGC(2);
1304     rcarg[nrcargs++] = "-x";
1305     rcarg[nrcargs++] = xrs;
1306     }
1307     if (yrs) {
1308     CHECKARGC(2);
1309     rcarg[nrcargs++] = "-y";
1310     rcarg[nrcargs++] = yrs;
1311     }
1312     if (ldopt) {
1313     CHECKARGC(1);
1314     rcarg[nrcargs++] = ldopt;
1315     }
1316 greg 2.1 if (sampcnt <= 0) sampcnt = 1;
1317 greg 2.8 } else { /* else in sampling mode */
1318 greg 2.11 if (iropt) {
1319 greg 2.8 fputs(progname, stderr);
1320 greg 2.11 fputs(": -i, -I supported for pass-through only\n", stderr);
1321 greg 2.8 return(1);
1322     }
1323 greg 2.6 fmtopt[2] = (sizeof(RREAL)==sizeof(double)) ? 'd' : 'f';
1324 greg 2.1 if (sampcnt <= 0) sampcnt = 10000;
1325     }
1326     sprintf(sampcntbuf, "%d", sampcnt);
1327     CHECKARGC(3); /* add our format & sample count */
1328     rcarg[nrcargs++] = fmtopt;
1329     rcarg[nrcargs++] = "-c";
1330     rcarg[nrcargs++] = sampcntbuf;
1331     /* add receiver arguments to rcontrib */
1332     if (load_scene(argv[a], add_recv_object) < 0)
1333     return(1);
1334     finish_receiver();
1335     if (sendfn == NULL) { /* pass-through mode? */
1336     CHECKARGC(1); /* add octree */
1337     rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1338     rcarg[nrcargs] = NULL;
1339     return(my_exec(rcarg)); /* rcontrib does everything */
1340     }
1341     clear_params(&curparams, 0); /* else load sender surface & params */
1342     if (load_scene(sendfn, add_send_object) < 0)
1343     return(1);
1344     if ((nsbins = prepare_sampler()) <= 0)
1345     return(1);
1346     CHECKARGC(3); /* add row count and octree */
1347     rcarg[nrcargs++] = "-y";
1348     sprintf(nsbinbuf, "%d", nsbins);
1349     rcarg[nrcargs++] = nsbinbuf;
1350     rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1351     rcarg[nrcargs] = NULL;
1352     /* open pipe to rcontrib process */
1353     if ((rcfp = popen_arglist(rcarg, "w")) == NULL)
1354     return(1);
1355     SET_FILE_BINARY(rcfp);
1356     #ifdef getc_unlocked
1357     flockfile(rcfp);
1358     #endif
1359     if (verbose) {
1360     fprintf(stderr, "%s: sampling %d directions", progname, nsbins);
1361     if (curparams.nsurfs > 1)
1362 greg 2.7 fprintf(stderr, " (%d elements)\n", curparams.nsurfs);
1363 greg 2.1 else
1364     fputc('\n', stderr);
1365     }
1366     for (i = 0; i < nsbins; i++) /* send rcontrib ray samples */
1367     if (!(*curparams.sample_basis)(&curparams, i, rcfp))
1368     return(1);
1369     return(pclose(rcfp) == 0); /* all finished! */
1370     userr:
1371     if (a < argc-2)
1372     fprintf(stderr, "%s: unsupported option '%s'", progname, argv[a]);
1373 greg 2.13 fprintf(stderr, "Usage: %s [-v][rcontrib options] sender.rad receiver.rad [-i system.oct] [system.rad ..]\n",
1374 greg 2.1 progname);
1375     return(1);
1376     }
