--- ray/src/util/rfluxmtx.c 2014/07/23 22:39:40 2.7 +++ ray/src/util/rfluxmtx.c 2014/07/25 16:58:20 2.9 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rfluxmtx.c,v 2.7 2014/07/23 22:39:40 greg Exp $"; +static const char RCSid[] = "$Id: rfluxmtx.c,v 2.9 2014/07/25 16:58:20 greg Exp $"; #endif /* * Calculate flux transfer matrix or matrices using rcontrib @@ -419,7 +419,7 @@ finish_receiver(void) exit(1); } calfn = shirchiufn; shirchiufn = NULL; - sprintf(sbuf, "SCdim=%d,Nx=%g,Ny=%g,Nz=%g,Ux=%g,Uy=%g,Uz=%g", + sprintf(sbuf, "SCdim=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g", curparams.hsiz, curparams.nrm[0], curparams.nrm[1], curparams.nrm[2], curparams.vup[0], curparams.vup[1], curparams.vup[2]); @@ -429,7 +429,7 @@ finish_receiver(void) } else if ((tolower(curparams.hemis[0]) == 'r') | (tolower(curparams.hemis[0]) == 't')) { calfn = reinhfn; reinhfn = NULL; - sprintf(sbuf, "MF=%d,Nx=%g,Ny=%g,Nz=%g,Ux=%g,Uy=%g,Uz=%g", + sprintf(sbuf, "MF=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g", curparams.hsiz, curparams.nrm[0], curparams.nrm[1], curparams.nrm[2], curparams.vup[0], curparams.vup[1], curparams.vup[2]); @@ -1000,7 +1000,8 @@ add_surface(int st, const char *oname, FILE *fp) case ST_SOURCE: if (snew->nfargs != 4) goto badcount; - VCOPY(snew->snrm, snew->farg); + for (n = 3; n--; ) /* need to reverse "normal" */ + snew->snrm[n] = -snew->farg[n]; if (normalize(snew->snrm) == 0) goto badnorm; snew->area = sin((PI/180./2.)*snew->farg[3]); @@ -1063,7 +1064,7 @@ add_recv_object(FILE *fp) return(1); } /* else skip arguments */ - if (!fscanf(fp, "%d", &n)) return; + if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*s"); if (!fscanf(fp, "%d", &n)) return; while (n-- > 0) fscanf(fp, "%*d"); @@ -1099,7 +1100,7 @@ add_send_object(FILE *fp) return(0); } /* else skip arguments */ - if (!fscanf(fp, "%d", &n)) return; + if (!fscanf(fp, "%d", &n)) return(0); while (n-- > 0) fscanf(fp, "%*s"); if (!fscanf(fp, "%d", &n)) return; while (n-- > 0) fscanf(fp, "%*d"); @@ -1171,6 +1172,7 @@ main(int argc, char *argv[]) { char fmtopt[6] = "-faa"; /* default output is ASCII */ char *xrs=NULL, *yrs=NULL, *ldopt=NULL; + int wantIrradiance = 0; char *sendfn; char sampcntbuf[32], nsbinbuf[32]; FILE *rcfp; @@ -1218,6 +1220,10 @@ main(int argc, char *argv[]) goto userr; na = 0; /* we re-add this later */ continue; + case 'I': /* only for pass-through mode */ + wantIrradiance = 1; + na = 0; + continue; case 'V': /* options without arguments */ case 'w': case 'u': @@ -1269,6 +1275,10 @@ done_opts: if (sendfn[0] == '-') { /* user wants pass-through mode? */ if (sendfn[1]) goto userr; sendfn = NULL; + if (wantIrradiance) { + CHECKARGC(1); + rcarg[nrcargs++] = "-I"; + } if (xrs) { CHECKARGC(2); rcarg[nrcargs++] = "-x"; @@ -1284,7 +1294,12 @@ done_opts: rcarg[nrcargs++] = ldopt; } if (sampcnt <= 0) sampcnt = 1; - } else { /* else FVECT determines input format */ + } else { /* else in sampling mode */ + if (wantIrradiance) { + fputs(progname, stderr); + fputs(": -I supported for pass-through only\n", stderr); + return(1); + } fmtopt[2] = (sizeof(RREAL)==sizeof(double)) ? 'd' : 'f'; if (sampcnt <= 0) sampcnt = 10000; }
