root/radiance/ray/src/util/rfluxmtx.c
Tue Aug 26 19:10:10 2014 UTC (10 years, 8 months ago) by greg
CVS Tags: rad4R2P1, rad4R2P2
Diff to previous 2.17 , to selected 2.3
Fixed Reinhart sky sender sampling
Tue Aug 26 18:56:19 2014 UTC (10 years, 8 months ago) by greg
Diff to previous 2.16 , to selected 2.3
Fixed vector sampling directions for Klems senders and Reinhart sky receivers
Tue Aug 26 07:41:29 2014 UTC (10 years, 8 months ago) by greg
Changes since 2.15: +12 -10 lines
Diff to previous 2.15 , to selected 2.3
Pays attention to -w option internally
Fri Aug 15 19:59:56 2014 UTC (10 years, 8 months ago) by greg
Changes since 2.14: +8 -4 lines
Diff to previous 2.14 , to selected 2.3
Fixed bugs in parameter parsing
Wed Aug 6 02:38:24 2014 UTC (10 years, 8 months ago) by greg
Changes since 2.13: +15 -7 lines
Diff to previous 2.13 , to selected 2.3
Wed Aug 6 00:59:53 2014 UTC (10 years, 8 months ago) by greg
Changes since 2.12: +12 -9 lines
Diff to previous 2.12 , to selected 2.3
Mon Jul 28 16:30:18 2014 UTC (10 years, 9 months ago) by greg
CVS Tags: rad4R2
Diff to previous 2.11 , to selected 2.3
Added inclusion of rtprocess.h
Fri Jul 25 19:23:14 2014 UTC (10 years, 9 months ago) by greg
Diff to previous 2.10 , to selected 2.3
Also limit "-i" support to pass-through mode
Fri Jul 25 17:03:06 2014 UTC (10 years, 9 months ago) by greg
Changes since 2.9: +10 -8 lines
Diff to previous 2.9 , to selected 2.3
Fixed other missing return values
Fri Jul 25 16:58:20 2014 UTC (10 years, 9 months ago) by greg
Fixed bug in setting of receiver normal for sources
Fri Jul 25 15:46:10 2014 UTC (10 years, 9 months ago) by greg
Changes since 2.7: +20 -5 lines
Added -I option support in pass-through and fixed source orientation
Wed Jul 23 22:39:40 2014 UTC (10 years, 9 months ago) by greg
Changes since 2.6: +22 -10 lines
Added better error messages and fixed bug in Reinhart/Tregenza sampling
Wed Jul 23 00:40:17 2014 UTC (10 years, 9 months ago) by greg
Changes since 2.5: +22 -19 lines
Fixed most of the other bugs
Tue Jul 22 23:21:56 2014 UTC (10 years, 9 months ago) by greg
Changes since 2.4: +7 -4 lines
Fixed some bugs... more to go
Tue Jul 22 21:55:31 2014 UTC (10 years, 9 months ago) by greg
Changes since 2.3: +47 -6 lines
Tue Jul 22 02:12:48 2014 UTC (10 years, 9 months ago) by greg
Changes since 2.2: +19 -11 lines
Added Reinhart sky cal file
Mon Jul 21 15:59:47 2014 UTC (10 years, 9 months ago) by greg
Changes since 2.1: +61 -69 lines
Getting close to working version of rfluxmtx
Sat Jul 19 01:19:49 2014 UTC (10 years, 9 months ago) by greg
Diff to selected 2.3
Checking in incomplete and untested version of rfluxmtx
