root/radiance/ray/src/util/rfluxmtx.c
Revision: 2.49
Committed: Tue Dec 10 19:15:54 2019 UTC (5 years, 4 months ago) by greg
Changes since 2.48: +5 -3 lines
Made -w option a little more robust
2 static const char RCSid[] = "$Id: rfluxmtx.c,v 2.48 2019/07/29 22:52:39 greg Exp $";
5 * Calculate flux transfer matrix or matrices using rcontrib
6 */
7
8 #include "copyright.h"
9
10 #include <ctype.h>
11 #include <stdlib.h>
12 #include "rtio.h"
13 #include "rtmath.h"
14 #include "paths.h"
15 #include "bsdf.h"
16 #include "bsdf_m.h"
17 #include "random.h"
18 #include "triangulate.h"
19 #include "platform.h"
20
21 #ifndef MAXRCARG
22 #define MAXRCARG 10000
23 #endif
24
25 char *progname; /* global argv[0] */
26
27 int verbose = 0; /* verbose mode (< 0 no warnings) */
28
29 char *rcarg[MAXRCARG+1] = {"rcontrib", "-fo+"};
30 int nrcargs = 2;
31
32 const char overflowerr[] = "%s: too many arguments!\n";
33
34 #define CHECKARGC(n) if (nrcargs >= MAXRCARG-(n)) \
35 { fprintf(stderr, overflowerr, progname); exit(1); }
36
37 int sampcnt = 0; /* sample count (0==unset) */
38
39 char *reinhfn = "reinhartb.cal";
40 char *shirchiufn = "disk2square.cal";
41 char *kfullfn = "klems_full.cal";
42 char *khalffn = "klems_half.cal";
43 char *kquarterfn = "klems_quarter.cal";
44
45 /* string indicating parameters */
46 const char PARAMSTART[] = "@rfluxmtx";
47
48 /* surface type IDs */
49 #define ST_NONE 0
50 #define ST_POLY 1
51 #define ST_RING 2
52 #define ST_SOURCE 3
53
54 typedef struct surf_s {
55 struct surf_s *next; /* next surface in list */
56 void *priv; /* private data (malloc'ed) */
57 char sname[32]; /* surface name */
58 FVECT snrm; /* surface normal */
59 double area; /* surface area / proj. solid angle */
60 short styp; /* surface type */
61 short nfargs; /* number of real arguments */
62 double farg[1]; /* real values (extends struct) */
63 } SURF; /* surface structure */
64
65 typedef struct {
66 FVECT uva[2]; /* tangent axes */
67 int ntris; /* number of triangles */
68 struct ptri {
69 double afrac; /* fraction of total area */
70 short vndx[3]; /* vertex indices */
71 } tri[1]; /* triangle array (extends struct) */
72 } POLYTRIS; /* triangulated polygon */
73
74 typedef struct param_s {
75 char sign; /* '-' for axis reversal */
76 char hemis[31]; /* hemispherical sampling spec. */
77 int hsiz; /* hemisphere basis size */
78 int nsurfs; /* number of surfaces */
79 SURF *slist; /* list of surfaces */
80 FVECT vup; /* up vector (zero if unset) */
81 FVECT nrm; /* average normal direction */
82 FVECT udir, vdir; /* tangent axes */
83 char *outfn; /* output file name (receiver) */
84 int (*sample_basis)(struct param_s *p, int, FILE *);
85 } PARAMS; /* sender/receiver parameters */
86
87 PARAMS curparams;
88 char curmod[128];
89 char newparams[1024];
90
91 typedef int SURFSAMP(FVECT, SURF *, double);
92
93 static SURFSAMP ssamp_bad, ssamp_poly, ssamp_ring;
94
95 SURFSAMP *orig_in_surf[4] = {
96 ssamp_bad, ssamp_poly, ssamp_ring, ssamp_bad
97 };
98
99 /* Clear parameter set */
100 static void
101 clear_params(PARAMS *p, int reset_only)
102 {
103 while (p->slist != NULL) {
104 SURF *sdel = p->slist;
105 p->slist = sdel->next;
106 if (sdel->priv != NULL)
107 free(sdel->priv);
108 free(sdel);
109 }
110 if (reset_only) {
111 p->nsurfs = 0;
112 memset(p->nrm, 0, sizeof(FVECT));
113 memset(p->vup, 0, sizeof(FVECT));
114 p->outfn = NULL;
115 return;
116 }
117 memset(p, 0, sizeof(PARAMS));
118 }
119
120 /* Get surface type from name */
121 static int
122 surf_type(const char *otype)
123 {
124 if (!strcmp(otype, "polygon"))
125 return(ST_POLY);
126 if (!strcmp(otype, "ring"))
127 return(ST_RING);
128 if (!strcmp(otype, "source"))
129 return(ST_SOURCE);
130 return(ST_NONE);
131 }
132
133 /* Add arguments to oconv command */
134 static char *
135 oconv_command(int ac, char *av[])
136 {
137 static char oconvbuf[2048] = "!oconv -f ";
138 char *cp = oconvbuf + 10;
139 char *recv = *av++;
140
141 if (ac-- <= 0)
142 return(NULL);
143 if (verbose < 0) { /* turn off warnings */
144 strcpy(cp, "-w ");
145 cp += 4;
146 }
147 while (ac-- > 0) { /* copy each argument */
148 int len = strlen(*av);
149 if (cp+len+4 >= oconvbuf+sizeof(oconvbuf))
150 goto overrun;
151 if (matchany(*av, SPECIALS)) {
152 *cp++ = QUOTCHAR;
153 strcpy(cp, *av++);
154 cp += len;
155 *cp++ = QUOTCHAR;
156 } else {
157 strcpy(cp, *av++);
158 cp += len;
159 }
160 *cp++ = ' ';
161 }
162 /* receiver goes last */
163 if (matchany(recv, SPECIALS)) {
164 *cp++ = QUOTCHAR;
165 while (*recv) {
166 if (cp >= oconvbuf+(sizeof(oconvbuf)-3))
167 goto overrun;
168 *cp++ = *recv++;
169 }
170 *cp++ = QUOTCHAR;
171 *cp = '\0';
172 } else
173 strcpy(cp, recv);
174 return(oconvbuf);
175 overrun:
176 fputs(progname, stderr);
177 fputs(": too many file arguments!\n", stderr);
178 exit(1);
179 }
180
181 /* Open a pipe to/from a command given as an argument list */
182 static FILE *
183 popen_arglist(char *av[], char *mode)
184 {
185 char cmd[10240];
186
187 if (!convert_commandline(cmd, sizeof(cmd), av)) {
188 fputs(progname, stderr);
189 fputs(": command line too long in popen_arglist()\n", stderr);
190 return(NULL);
191 }
192 if (verbose > 0)
193 fprintf(stderr, "%s: opening pipe %s: %s\n",
194 progname, (*mode=='w') ? "to" : "from", cmd);
195 return(popen(cmd, mode));
196 }
197
198 #if defined(_WIN32) || defined(_WIN64)
199 /* Execute system command (Windows version) */
200 static int
201 my_exec(char *av[])
202 {
203 char cmd[10240];
204
205 if (!convert_commandline(cmd, sizeof(cmd), av)) {
206 fputs(progname, stderr);
207 fputs(": command line too long in my_exec()\n", stderr);
208 return(1);
209 }
210 if (verbose > 0)
211 fprintf(stderr, "%s: running: %s\n", progname, cmd);
212 return(system(cmd));
213 }
214 #else
215 /* Execute system command in our stead (Unix version) */
216 static int
217 my_exec(char *av[])
218 {
219 char *compath;
220
221 if ((compath = getpath((char *)av[0], getenv("PATH"), X_OK)) == NULL) {
222 fprintf(stderr, "%s: cannot locate %s\n", progname, av[0]);
223 return(1);
224 }
225 if (verbose > 0) {
226 char cmd[4096];
227 if (!convert_commandline(cmd, sizeof(cmd), av))
228 strcpy(cmd, "COMMAND TOO LONG TO SHOW");
229 fprintf(stderr, "%s: running: %s\n", progname, cmd);
230 }
231 execv(compath, av); /* successful call never returns */
232 perror(compath);
233 return(1);
234 }
235 #endif
236
237 /* Get normalized direction vector from string specification */
238 static int
239 get_direction(FVECT dv, const char *s)
240 {
241 int sign = 1;
242 int axis = 0;
243
244 memset(dv, 0, sizeof(FVECT));
245 nextchar:
246 switch (*s) {
247 case '+':
248 ++s;
249 goto nextchar;
250 case '-':
251 sign = -sign;
252 ++s;
253 goto nextchar;
254 case 'z':
255 case 'Z':
256 ++axis;
257 case 'y':
258 case 'Y':
259 ++axis;
260 case 'x':
261 case 'X':
262 dv[axis] = sign;
263 return(!s[1] | isspace(s[1]));
264 default:
265 break;
266 }
267 #ifdef SMLFLT
268 if (sscanf(s, "%f,%f,%f", &dv[0], &dv[1], &dv[2]) != 3)
269 #else
270 if (sscanf(s, "%lf,%lf,%lf", &dv[0], &dv[1], &dv[2]) != 3)
271 #endif
272 return(0);
273 dv[0] *= (RREAL)sign;
274 return(normalize(dv) > 0);
275 }
276
277 /* Parse program parameters (directives) */
278 static int
279 parse_params(PARAMS *p, char *pargs)
280 {
281 char *cp = pargs;
282 int nparams = 0;
283 int quot;
284 int i;
285
286 for ( ; ; ) {
287 switch (*cp++) {
288 case 'h':
289 if (*cp++ != '=')
290 break;
291 if ((*cp == '+') | (*cp == '-'))
292 p->sign = *cp++;
293 else
294 p->sign = '+';
295 p->hsiz = 0;
296 i = 0;
297 while (*cp && !isspace(*cp)) {
298 if (isdigit(*cp))
299 p->hsiz = 10*p->hsiz + *cp - '0';
300 p->hemis[i++] = *cp++;
301 }
302 if (!i)
303 break;
304 p->hemis[i] = '\0';
305 p->hsiz += !p->hsiz;
306 ++nparams;
307 continue;
308 case 'u':
309 if (*cp++ != '=')
310 break;
311 if (!get_direction(p->vup, cp))
312 break;
313 while (*cp && !isspace(*cp++))
314 ;
315 ++nparams;
316 continue;
317 case 'o':
318 if (*cp++ != '=')
319 break;
320 quot = 0;
321 if ((*cp == '"') | (*cp == '\''))
322 quot = *cp++;
323 i = 0;
324 while (*cp && (quot ? (*cp != quot) : !isspace(*cp))) {
325 i++; cp++;
326 }
327 if (!i)
328 break;
329 if (!*cp) {
330 if (quot)
331 break;
332 cp[1] = '\0';
333 }
334 *cp = '\0';
335 p->outfn = savqstr(cp-i);
336 *cp++ = quot ? quot : ' ';
337 ++nparams;
338 continue;
339 case ' ':
340 case '\t':
341 case '\r':
342 case '\n':
343 continue;
344 case '\0':
345 return(nparams);
346 default:
347 break;
348 }
349 break;
350 }
351 fprintf(stderr, "%s: bad parameter string: %s", progname, pargs);
352 exit(1);
353 return(-1); /* pro forma return */
354 }
355
356 /* Add receiver arguments (directives) corresponding to the current modifier */
357 static void
358 finish_receiver(void)
359 {
360 char sbuf[256];
361 int uniform = 0;
362 char *calfn = NULL;
363 char *params = NULL;
364 char *binv = NULL;
365 char *binf = NULL;
366 char *nbins = NULL;
367
368 if (!curmod[0]) {
369 fputs(progname, stderr);
370 fputs(": missing receiver surface!\n", stderr);
371 exit(1);
372 }
373 if (curparams.outfn != NULL) { /* add output file spec. */
374 CHECKARGC(2);
375 rcarg[nrcargs++] = "-o";
376 rcarg[nrcargs++] = curparams.outfn;
377 }
378 /* check arguments */
379 if (!curparams.hemis[0]) {
380 fputs(progname, stderr);
381 fputs(": missing hemisphere sampling type!\n", stderr);
382 exit(1);
383 }
384 if (normalize(curparams.nrm) == 0) {
385 fputs(progname, stderr);
386 fputs(": undefined normal for hemisphere sampling\n", stderr);
387 exit(1);
388 }
389 if (normalize(curparams.vup) == 0) {
390 if (fabs(curparams.nrm[2]) < .7)
391 curparams.vup[2] = 1;
392 else
393 curparams.vup[1] = 1;
394 }
395 /* determine sample type/bin */
396 if ((tolower(curparams.hemis[0]) == 'u') | (curparams.hemis[0] == '1')) {
397 sprintf(sbuf, "if(-Dx*%g-Dy*%g-Dz*%g,0,-1)",
398 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2]);
399 binv = savqstr(sbuf);
400 nbins = "1"; /* uniform sampling -- one bin */
401 uniform = 1;
402 } else if (tolower(curparams.hemis[0]) == 's' &&
403 tolower(curparams.hemis[1]) == 'c') {
404 /* assign parameters */
405 if (curparams.hsiz <= 1) {
406 fputs(progname, stderr);
407 fputs(": missing size for Shirley-Chiu sampling!\n", stderr);
408 exit(1);
409 }
410 calfn = shirchiufn; shirchiufn = NULL;
411 sprintf(sbuf, "SCdim=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1",
412 curparams.hsiz,
413 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
414 curparams.vup[0], curparams.vup[1], curparams.vup[2],
415 curparams.sign);
416 params = savqstr(sbuf);
417 binv = "scbin";
418 nbins = "SCdim*SCdim";
419 } else if ((tolower(curparams.hemis[0]) == 'r') |
420 (tolower(curparams.hemis[0]) == 't')) {
421 calfn = reinhfn; reinhfn = NULL;
422 sprintf(sbuf, "MF=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1",
423 curparams.hsiz,
424 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
425 curparams.vup[0], curparams.vup[1], curparams.vup[2],
426 curparams.sign);
427 params = savqstr(sbuf);
428 binv = "rbin";
429 nbins = "Nrbins";
430 } else if (tolower(curparams.hemis[0]) == 'k' &&
431 !curparams.hemis[1] |
432 (tolower(curparams.hemis[1]) == 'f') |
433 (curparams.hemis[1] == '1')) {
434 calfn = kfullfn; kfullfn = NULL;
435 binf = "kbin";
436 nbins = "Nkbins";
437 } else if (tolower(curparams.hemis[0]) == 'k' &&
438 (tolower(curparams.hemis[1]) == 'h') |
439 (curparams.hemis[1] == '2')) {
440 calfn = khalffn; khalffn = NULL;
441 binf = "khbin";
442 nbins = "Nkhbins";
443 } else if (tolower(curparams.hemis[0]) == 'k' &&
444 (tolower(curparams.hemis[1]) == 'q') |
445 (curparams.hemis[1] == '4')) {
446 calfn = kquarterfn; kquarterfn = NULL;
447 binf = "kqbin";
448 nbins = "Nkqbins";
449 } else {
450 fprintf(stderr, "%s: unrecognized hemisphere sampling: h=%s\n",
451 progname, curparams.hemis);
452 exit(1);
453 }
454 if (tolower(curparams.hemis[0]) == 'k') {
455 sprintf(sbuf, "RHS=%c1", curparams.sign);
456 params = savqstr(sbuf);
457 }
458 if (!uniform & (curparams.slist->styp == ST_SOURCE)) {
459 SURF *sp;
460 for (sp = curparams.slist; sp != NULL; sp = sp->next)
461 if (fabs(sp->area - PI) > 1e-3) {
462 fprintf(stderr, "%s: source '%s' must be 180-degrees\n",
463 progname, sp->sname);
464 exit(1);
465 }
466 }
467 if (calfn != NULL) { /* add cal file if needed */
468 CHECKARGC(2);
469 rcarg[nrcargs++] = "-f";
470 rcarg[nrcargs++] = calfn;
471 }
472 if (params != NULL) { /* parameters _after_ cal file */
473 CHECKARGC(2);
474 rcarg[nrcargs++] = "-p";
475 rcarg[nrcargs++] = params;
476 }
477 if (nbins != NULL) { /* add #bins if set */
478 CHECKARGC(2);
479 rcarg[nrcargs++] = "-bn";
480 rcarg[nrcargs++] = nbins;
481 }
482 if (binv != NULL) {
483 CHECKARGC(2); /* assign bin variable */
484 rcarg[nrcargs++] = "-b";
485 rcarg[nrcargs++] = binv;
486 } else if (binf != NULL) {
487 CHECKARGC(2); /* assign bin function */
488 rcarg[nrcargs++] = "-b";
489 sprintf(sbuf, "%s(%g,%g,%g,%g,%g,%g)", binf,
490 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
491 curparams.vup[0], curparams.vup[1], curparams.vup[2]);
492 rcarg[nrcargs++] = savqstr(sbuf);
493 }
494 CHECKARGC(2); /* modifier argument goes last */
495 rcarg[nrcargs++] = "-m";
496 rcarg[nrcargs++] = savqstr(curmod);
497 }
498
499 /* Make randomly oriented tangent plane axes for given normal direction */
500 static void
501 make_axes(FVECT uva[2], const FVECT nrm)
502 {
503 int i;
504
505 if (!getperpendicular(uva[0], nrm, 1)) {
506 fputs(progname, stderr);
507 fputs(": bad surface normal in make_axes!\n", stderr);
508 exit(1);
509 }
510 fcross(uva[1], nrm, uva[0]);
511 }
512
513 /* Illegal sender surfaces end up here */
514 static int
515 ssamp_bad(FVECT orig, SURF *sp, double x)
516 {
517 fprintf(stderr, "%s: illegal sender surface '%s'\n",
518 progname, sp->sname);
519 return(0);
520 }
521
522 /* Generate origin on ring surface from uniform random variable */
523 static int
524 ssamp_ring(FVECT orig, SURF *sp, double x)
525 {
526 FVECT *uva = (FVECT *)sp->priv;
527 double samp2[2];
528 double uv[2];
529 int i;
530
531 if (uva == NULL) { /* need tangent axes */
532 uva = (FVECT *)malloc(sizeof(FVECT)*2);
533 if (uva == NULL) {
534 fputs(progname, stderr);
535 fputs(": out of memory in ssamp_ring!\n", stderr);
536 return(0);
537 }
538 make_axes(uva, sp->snrm);
539 sp->priv = (void *)uva;
540 }
541 SDmultiSamp(samp2, 2, x);
542 samp2[0] = sqrt(samp2[0]*sp->area*(1./PI) + sp->farg[6]*sp->farg[6]);
543 samp2[1] *= 2.*PI;
544 uv[0] = samp2[0]*tcos(samp2[1]);
545 uv[1] = samp2[0]*tsin(samp2[1]);
546 for (i = 3; i--; )
547 orig[i] = sp->farg[i] + uv[0]*uva[0][i] + uv[1]*uva[1][i];
548 return(1);
549 }
550
551 /* Add triangle to polygon's list (call-back function) */
552 static int
553 add_triangle(const Vert2_list *tp, int a, int b, int c)
554 {
555 POLYTRIS *ptp = (POLYTRIS *)tp->p;
556 struct ptri *trip = ptp->tri + ptp->ntris++;
557
558 trip->vndx[0] = a;
559 trip->vndx[1] = b;
560 trip->vndx[2] = c;
561 return(1);
562 }
563
564 /* Generate origin on polygon surface from uniform random variable */
565 static int
566 ssamp_poly(FVECT orig, SURF *sp, double x)
567 {
568 POLYTRIS *ptp = (POLYTRIS *)sp->priv;
569 double samp2[2];
570 double *v0, *v1, *v2;
571 int i;
572
573 if (ptp == NULL) { /* need to triangulate */
574 ptp = (POLYTRIS *)malloc(sizeof(POLYTRIS) +
575 sizeof(struct ptri)*(sp->nfargs/3 - 3));
576 if (ptp == NULL)
577 goto memerr;
578 if (sp->nfargs == 3) { /* simple case */
579 ptp->ntris = 1;
580 ptp->tri[0].vndx[0] = 0;
581 ptp->tri[0].vndx[1] = 1;
582 ptp->tri[0].vndx[2] = 2;
583 ptp->tri[0].afrac = 1;
584 } else {
585 Vert2_list *v2l = polyAlloc(sp->nfargs/3);
586 if (v2l == NULL)
587 goto memerr;
588 make_axes(ptp->uva, sp->snrm);
589 for (i = v2l->nv; i--; ) {
590 v2l->v[i].mX = DOT(sp->farg+3*i, ptp->uva[0]);
591 v2l->v[i].mY = DOT(sp->farg+3*i, ptp->uva[1]);
592 }
593 ptp->ntris = 0;
594 v2l->p = (void *)ptp;
595 if (!polyTriangulate(v2l, add_triangle)) {
596 fprintf(stderr,
597 "%s: cannot triangulate polygon '%s'\n",
598 progname, sp->sname);
599 return(0);
600 }
601 for (i = ptp->ntris; i--; ) {
602 int a = ptp->tri[i].vndx[0];
603 int b = ptp->tri[i].vndx[1];
604 int c = ptp->tri[i].vndx[2];
605 ptp->tri[i].afrac =
606 (v2l->v[a].mX*v2l->v[b].mY -
607 v2l->v[b].mX*v2l->v[a].mY +
608 v2l->v[b].mX*v2l->v[c].mY -
609 v2l->v[c].mX*v2l->v[b].mY +
610 v2l->v[c].mX*v2l->v[a].mY -
611 v2l->v[a].mX*v2l->v[c].mY) /
612 (2.*sp->area);
613 }
614 polyFree(v2l);
615 }
616 sp->priv = (void *)ptp;
617 }
618 /* pick triangle by partial area */
619 for (i = 0; i < ptp->ntris-1 && x > ptp->tri[i].afrac; i++)
620 x -= ptp->tri[i].afrac;
621 SDmultiSamp(samp2, 2, x/ptp->tri[i].afrac);
622 samp2[0] *= samp2[1] = sqrt(samp2[1]);
623 samp2[1] = 1. - samp2[1];
624 v0 = sp->farg + 3*ptp->tri[i].vndx[0];
625 v1 = sp->farg + 3*ptp->tri[i].vndx[1];
626 v2 = sp->farg + 3*ptp->tri[i].vndx[2];
627 for (i = 3; i--; )
628 orig[i] = v0[i] + samp2[0]*(v1[i] - v0[i])
629 + samp2[1]*(v2[i] - v0[i]) ;
630 return(1);
631 memerr:
632 fputs(progname, stderr);
633 fputs(": out of memory in ssamp_poly!\n", stderr);
634 return(0);
635 }
636
637 /* Compute sample origin based on projected areas of sender subsurfaces */
638 static int
639 sample_origin(PARAMS *p, FVECT orig, const FVECT rdir, double x)
640 {
641 static double *projsa;
642 static int nall;
643 double tarea = 0;
644 int i;
645 SURF *sp;
646 /* special case for lone surface */
647 if (p->nsurfs == 1) {
648 sp = p->slist;
649 if (DOT(sp->snrm, rdir) >= FTINY) {
650 fprintf(stderr,
651 "%s: internal - sample behind sender '%s'\n",
652 progname, sp->sname);
653 return(0);
654 }
655 return((*orig_in_surf[sp->styp])(orig, sp, x));
656 }
657 if (p->nsurfs > nall) { /* (re)allocate surface area cache */
658 if (projsa) free(projsa);
659 projsa = (double *)malloc(sizeof(double)*p->nsurfs);
660 if (projsa == NULL) {
661 fputs(progname, stderr);
662 fputs(": out of memory in sample_origin!\n", stderr);
663 exit(1);
664 }
665 nall = p->nsurfs;
666 }
667 /* compute projected areas */
668 for (i = 0, sp = p->slist; sp != NULL; i++, sp = sp->next) {
669 projsa[i] = -DOT(sp->snrm, rdir) * sp->area;
670 tarea += projsa[i] *= (double)(projsa[i] > FTINY);
671 }
672 if (tarea < 0) { /* wrong side of sender? */
673 fputs(progname, stderr);
674 fputs(": internal - sample behind all sender elements!\n",
675 stderr);
676 return(0);
677 }
678 tarea *= x; /* get surface from list */
679 for (i = 0, sp = p->slist; tarea > projsa[i]; sp = sp->next)
680 tarea -= projsa[i++];
681 return((*orig_in_surf[sp->styp])(orig, sp, tarea/projsa[i]));
682 }
683
684 /* Uniform sample generator */
685 static int
686 sample_uniform(PARAMS *p, int b, FILE *fp)
687 {
688 int n = sampcnt;
689 double samp3[3];
690 double duvw[3];
691 FVECT orig_dir[2];
692 int i;
693
694 if (fp == NULL) /* just requesting number of bins? */
695 return(1);
696
697 while (n--) { /* stratified hemisphere sampling */
698 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
699 SDsquare2disk(duvw, samp3[1], samp3[2]);
700 duvw[2] = -sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
701 for (i = 3; i--; )
702 orig_dir[1][i] = duvw[0]*p->udir[i] +
703 duvw[1]*p->vdir[i] +
704 duvw[2]*p->nrm[i] ;
705 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
706 return(0);
707 if (putbinary(orig_dir, sizeof(FVECT), 2, fp) != 2)
708 return(0);
709 }
710 return(1);
711 }
712
713 /* Shirly-Chiu sample generator */
714 static int
715 sample_shirchiu(PARAMS *p, int b, FILE *fp)
716 {
717 int n = sampcnt;
718 double samp3[3];
719 double duvw[3];
720 FVECT orig_dir[2];
721 int i;
722
723 if (fp == NULL) /* just requesting number of bins? */
724 return(p->hsiz*p->hsiz);
725
726 while (n--) { /* stratified sampling */
727 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
728 SDsquare2disk(duvw, (b/p->hsiz + samp3[1])/curparams.hsiz,
729 (b%p->hsiz + samp3[2])/curparams.hsiz);
730 duvw[2] = sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
731 for (i = 3; i--; )
732 orig_dir[1][i] = -duvw[0]*p->udir[i] -
733 duvw[1]*p->vdir[i] -
734 duvw[2]*p->nrm[i] ;
735 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
736 return(0);
737 if (putbinary(orig_dir, sizeof(FVECT), 2, fp) != 2)
738 return(0);
739 }
740 return(1);
741 }
742
743 /* Reinhart/Tregenza sample generator */
744 static int
745 sample_reinhart(PARAMS *p, int b, FILE *fp)
746 {
747 #define T_NALT 7
748 static const int tnaz[T_NALT] = {30, 30, 24, 24, 18, 12, 6};
749 const int RowMax = T_NALT*p->hsiz + 1;
750 const double RAH = (.5*PI)/(RowMax-.5);
751 #define rnaz(r) (r >= RowMax-1 ? 1 : p->hsiz*tnaz[r/p->hsiz])
752 int n = sampcnt;
753 int row, col;
754 double samp3[3];
755 double alt, azi;
756 double duvw[3];
757 FVECT orig_dir[2];
758 int i;
759
760 if (fp == NULL) { /* just requesting number of bins? */
761 n = 0;
762 for (row = RowMax; row--; ) n += rnaz(row);
763 return(n);
764 }
765 row = 0; /* identify row & column */
766 col = b;
767 while (col >= rnaz(row)) {
768 col -= rnaz(row);
769 ++row;
770 }
771 while (n--) { /* stratified sampling */
772 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
773 if (row >= RowMax-1) /* avoid crowding at zenith */
774 samp3[1] *= samp3[1];
775 alt = (row+samp3[1])*RAH;
776 azi = (2.*PI)*(col+samp3[2]-.5)/rnaz(row);
777 duvw[2] = cos(alt); /* measured from horizon */
778 duvw[0] = tsin(azi)*duvw[2];
779 duvw[1] = -tcos(azi)*duvw[2];
780 duvw[2] = sqrt(1. - duvw[2]*duvw[2]);
781 for (i = 3; i--; )
782 orig_dir[1][i] = -duvw[0]*p->udir[i] -
783 duvw[1]*p->vdir[i] -
784 duvw[2]*p->nrm[i] ;
785 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
786 return(0);
787 if (putbinary(orig_dir, sizeof(FVECT), 2, fp) != 2)
788 return(0);
789 }
790 return(1);
791 #undef rnaz
792 #undef T_NALT
793 }
794
795 /* Klems sample generator */
796 static int
797 sample_klems(PARAMS *p, int b, FILE *fp)
798 {
799 static const char bname[4][20] = {
800 "LBNL/Klems Full",
801 "LBNL/Klems Half",
802 "INTERNAL ERROR",
803 "LBNL/Klems Quarter"
804 };
805 static ANGLE_BASIS *kbasis[4];
806 const int bi = p->hemis[1] - '1';
807 int n = sampcnt;
808 double samp2[2];
809 double duvw[3];
810 FVECT orig_dir[2];
811 int i;
812
813 if (!kbasis[bi]) { /* need to get basis, first */
814 for (i = 4; i--; )
815 if (!strcasecmp(abase_list[i].name, bname[bi])) {
816 kbasis[bi] = &abase_list[i];
817 break;
818 }
819 if (i < 0) {
820 fprintf(stderr, "%s: unknown hemisphere basis '%s'\n",
821 progname, bname[bi]);
822 return(0);
823 }
824 }
825 if (fp == NULL) /* just requesting number of bins? */
826 return(kbasis[bi]->nangles);
827
828 while (n--) { /* stratified sampling */
829 SDmultiSamp(samp2, 2, (n+frandom())/sampcnt);
830 if (!fo_getvec(duvw, b+samp2[1], kbasis[bi]))
831 return(0);
832 for (i = 3; i--; )
833 orig_dir[1][i] = -duvw[0]*p->udir[i] -
834 duvw[1]*p->vdir[i] -
835 duvw[2]*p->nrm[i] ;
836 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp2[0]))
837 return(0);
838 if (putbinary(orig_dir, sizeof(FVECT), 2, fp) != 2)
839 return(0);
840 }
841 return(1);
842 }
843
844 /* Prepare hemisphere basis sampler that will send rays to rcontrib */
845 static int
846 prepare_sampler(void)
847 {
848 if (curparams.slist == NULL) { /* missing sample surface! */
849 fputs(progname, stderr);
850 fputs(": no sender surface!\n", stderr);
851 return(-1);
852 }
853 /* misplaced output file spec. */
854 if ((curparams.outfn != NULL) & (verbose >= 0))
855 fprintf(stderr, "%s: warning - ignoring output file in sender ('%s')\n",
856 progname, curparams.outfn);
857 /* check/set basis hemisphere */
858 if (!curparams.hemis[0]) {
859 fputs(progname, stderr);
860 fputs(": missing sender sampling type!\n", stderr);
861 return(-1);
862 }
863 if (normalize(curparams.nrm) == 0) {
864 fputs(progname, stderr);
865 fputs(": undefined normal for sender sampling\n", stderr);
866 return(-1);
867 }
868 if (normalize(curparams.vup) == 0) {
869 if (fabs(curparams.nrm[2]) < .7)
870 curparams.vup[2] = 1;
871 else
872 curparams.vup[1] = 1;
873 }
874 fcross(curparams.udir, curparams.vup, curparams.nrm);
875 if (normalize(curparams.udir) == 0) {
876 fputs(progname, stderr);
877 fputs(": up vector coincides with sender normal\n", stderr);
878 return(-1);
879 }
880 fcross(curparams.vdir, curparams.nrm, curparams.udir);
881 if (curparams.sign == '-') { /* left-handed coordinate system? */
882 curparams.udir[0] *= -1.;
883 curparams.udir[1] *= -1.;
884 curparams.udir[2] *= -1.;
885 }
886 if ((tolower(curparams.hemis[0]) == 'u') | (curparams.hemis[0] == '1'))
887 curparams.sample_basis = sample_uniform;
888 else if (tolower(curparams.hemis[0]) == 's' &&
889 tolower(curparams.hemis[1]) == 'c')
890 curparams.sample_basis = sample_shirchiu;
891 else if ((tolower(curparams.hemis[0]) == 'r') |
892 (tolower(curparams.hemis[0]) == 't'))
893 curparams.sample_basis = sample_reinhart;
894 else if (tolower(curparams.hemis[0]) == 'k') {
895 switch (curparams.hemis[1]) {
896 case '1':
897 case '2':
898 case '4':
899 break;
900 case 'f':
901 case 'F':
902 case '\0':
903 curparams.hemis[1] = '1';
904 break;
905 case 'h':
906 case 'H':
907 curparams.hemis[1] = '2';
908 break;
909 case 'q':
910 case 'Q':
911 curparams.hemis[1] = '4';
912 break;
913 default:
914 goto unrecognized;
915 }
916 curparams.hemis[2] = '\0';
917 curparams.sample_basis = sample_klems;
918 } else
919 goto unrecognized;
920 /* return number of bins */
921 return((*curparams.sample_basis)(&curparams,0,NULL));
922 unrecognized:
923 fprintf(stderr, "%s: unrecognized sender sampling: h=%s\n",
924 progname, curparams.hemis);
925 return(-1);
926 }
927
928 /* Compute normal and area for polygon */
929 static int
930 finish_polygon(SURF *p)
931 {
932 const int nv = p->nfargs / 3;
933 FVECT e1, e2, vc;
934 int i;
935
936 memset(p->snrm, 0, sizeof(FVECT));
937 VSUB(e1, p->farg+3, p->farg);
938 for (i = 2; i < nv; i++) {
939 VSUB(e2, p->farg+3*i, p->farg);
940 VCROSS(vc, e1, e2);
941 p->snrm[0] += vc[0];
942 p->snrm[1] += vc[1];
943 p->snrm[2] += vc[2];
944 VCOPY(e1, e2);
945 }
946 p->area = normalize(p->snrm)*0.5;
947 return(p->area > FTINY);
948 }
949
950 /* Add a surface to our current parameters */
951 static void
952 add_surface(int st, const char *oname, FILE *fp)
953 {
954 SURF *snew;
955 int n;
956 /* get floating-point arguments */
957 if (!fscanf(fp, "%d", &n)) return;
958 while (n-- > 0) fscanf(fp, "%*s");
959 if (!fscanf(fp, "%d", &n)) return;
960 while (n-- > 0) fscanf(fp, "%*d");
961 if (!fscanf(fp, "%d", &n) || n <= 0) return;
962 snew = (SURF *)malloc(sizeof(SURF) + sizeof(double)*(n-1));
963 if (snew == NULL) {
964 fputs(progname, stderr);
965 fputs(": out of memory in add_surface!\n", stderr);
966 exit(1);
967 }
968 strncpy(snew->sname, oname, sizeof(snew->sname)-1);
969 snew->sname[sizeof(snew->sname)-1] = '\0';
970 snew->styp = st;
971 snew->priv = NULL;
972 snew->nfargs = n;
973 for (n = 0; n < snew->nfargs; n++)
974 if (fscanf(fp, "%lf", &snew->farg[n]) != 1) {
975 fprintf(stderr, "%s: error reading arguments for '%s'\n",
976 progname, oname);
977 exit(1);
978 }
979 switch (st) {
980 case ST_RING:
981 if (snew->nfargs != 8)
982 goto badcount;
983 VCOPY(snew->snrm, snew->farg+3);
984 if (normalize(snew->snrm) == 0)
985 goto badnorm;
986 if (snew->farg[7] < snew->farg[6]) {
987 double t = snew->farg[7];
988 snew->farg[7] = snew->farg[6];
989 snew->farg[6] = t;
990 }
991 snew->area = PI*(snew->farg[7]*snew->farg[7] -
992 snew->farg[6]*snew->farg[6]);
993 break;
994 case ST_POLY:
995 if (snew->nfargs < 9 || snew->nfargs % 3)
996 goto badcount;
997 finish_polygon(snew);
998 break;
999 case ST_SOURCE:
1000 if (snew->nfargs != 4)
1001 goto badcount;
1002 for (n = 3; n--; ) /* need to reverse "normal" */
1003 snew->snrm[n] = -snew->farg[n];
1004 if (normalize(snew->snrm) == 0)
1005 goto badnorm;
1006 snew->area = sin((PI/180./2.)*snew->farg[3]);
1007 snew->area *= PI*snew->area;
1008 break;
1009 }
1010 if ((snew->area <= FTINY) & (verbose >= 0)) {
1011 fprintf(stderr, "%s: warning - zero area for surface '%s'\n",
1012 progname, oname);
1013 free(snew);
1014 return;
1015 }
1016 VSUM(curparams.nrm, curparams.nrm, snew->snrm, snew->area);
1017 snew->next = curparams.slist;
1018 curparams.slist = snew;
1019 curparams.nsurfs++;
1020 return;
1021 badcount:
1022 fprintf(stderr, "%s: bad argument count for surface element '%s'\n",
1023 progname, oname);
1024 exit(1);
1025 badnorm:
1026 fprintf(stderr, "%s: bad orientation for surface element '%s'\n",
1027 progname, oname);
1028 exit(1);
1029 }
1030
1031 /* Parse a receiver object (look for modifiers to add to rcontrib command) */
1032 static int
1033 add_recv_object(FILE *fp)
1034 {
1035 int st;
1036 char thismod[128], otype[32], oname[128];
1037 int n;
1038
1039 if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3)
1040 return(0); /* must have hit EOF! */
1041 if (!strcmp(otype, "alias")) {
1042 fscanf(fp, "%*s"); /* skip alias */
1043 return(0);
1044 }
1045 /* is it a new receiver? */
1046 if ((st = surf_type(otype)) != ST_NONE) {
1047 if (curparams.slist != NULL && (st == ST_SOURCE) ^
1048 (curparams.slist->styp == ST_SOURCE)) {
1049 fputs(progname, stderr);
1050 fputs(": cannot mix source/non-source receivers!\n", stderr);
1051 return(-1);
1052 }
1053 if (strcmp(thismod, curmod)) {
1054 if (curmod[0]) { /* output last receiver? */
1055 finish_receiver();
1056 clear_params(&curparams, 1);
1057 }
1058 parse_params(&curparams, newparams);
1059 newparams[0] = '\0';
1060 strcpy(curmod, thismod);
1061 }
1062 add_surface(st, oname, fp); /* read & store surface */
1063 return(1);
1064 }
1065 /* else skip arguments */
1066 if (!fscanf(fp, "%d", &n)) return(0);
1067 while (n-- > 0) fscanf(fp, "%*s");
1068 if (!fscanf(fp, "%d", &n)) return(0);
1069 while (n-- > 0) fscanf(fp, "%*d");
1070 if (!fscanf(fp, "%d", &n)) return(0);
1071 while (n-- > 0) fscanf(fp, "%*f");
1072 return(0);
1073 }
1074
1075 /* Parse a sender object */
1076 static int
1077 add_send_object(FILE *fp)
1078 {
1079 int st;
1080 char thismod[128], otype[32], oname[128];
1081 int n;
1082
1083 if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3)
1084 return(0); /* must have hit EOF! */
1085 if (!strcmp(otype, "alias")) {
1086 fscanf(fp, "%*s"); /* skip alias */
1087 return(0);
1088 }
1089 /* is it a new surface? */
1090 if ((st = surf_type(otype)) != ST_NONE) {
1091 if (st == ST_SOURCE) {
1092 fputs(progname, stderr);
1093 fputs(": cannot use source as a sender!\n", stderr);
1094 return(-1);
1095 }
1096 if (strcmp(thismod, curmod)) {
1097 if (curmod[0]) {
1098 fputs(progname, stderr);
1099 fputs(": warning - multiple modifiers in sender\n",
1100 stderr);
1101 }
1102 strcpy(curmod, thismod);
1103 }
1104 parse_params(&curparams, newparams);
1105 newparams[0] = '\0';
1106 add_surface(st, oname, fp); /* read & store surface */
1107 return(0);
1108 }
1109 /* else skip arguments */
1110 if (!fscanf(fp, "%d", &n)) return(0);
1111 while (n-- > 0) fscanf(fp, "%*s");
1112 if (!fscanf(fp, "%d", &n)) return(0);
1113 while (n-- > 0) fscanf(fp, "%*d");
1114 if (!fscanf(fp, "%d", &n)) return(0);
1115 while (n-- > 0) fscanf(fp, "%*f");
1116 return(0);
1117 }
1118
1119 /* Load a Radiance scene using the given callback function for objects */
1120 static int
1121 load_scene(const char *inspec, int (*ocb)(FILE *))
1122 {
1123 int rv = 0;
1124 char inpbuf[1024];
1125 FILE *fp;
1126 int c;
1127
1128 if (*inspec == '!')
1129 fp = popen(inspec+1, "r");
1130 else
1131 fp = fopen(inspec, "r");
1132 if (fp == NULL) {
1133 fprintf(stderr, "%s: cannot load '%s'\n", progname, inspec);
1134 return(-1);
1135 }
1136 while ((c = getc(fp)) != EOF) { /* load receiver data */
1137 if (isspace(c)) /* skip leading white space */
1138 continue;
1139 if (c == '!') { /* read from a new command */
1140 inpbuf[0] = c;
1141 if (fgetline(inpbuf+1, sizeof(inpbuf)-1, fp) != NULL) {
1142 if ((c = load_scene(inpbuf, ocb)) < 0)
1143 return(c);
1144 rv += c;
1145 }
1146 continue;
1147 }
1148 if (c == '#') { /* parameters/comment */
1149 if ((c = getc(fp)) == EOF || ungetc(c,fp) == EOF)
1150 break;
1151 if (!isspace(c) && fscanf(fp, "%s", inpbuf) == 1 &&
1152 !strcmp(inpbuf, PARAMSTART)) {
1153 if (fgets(inpbuf, sizeof(inpbuf), fp) != NULL)
1154 strcat(newparams, inpbuf);
1155 continue;
1156 }
1157 while ((c = getc(fp)) != EOF && c != '\n')
1158 ; /* else skipping comment */
1159 continue;
1160 }
1161 ungetc(c, fp); /* else check object for receiver */
1162 c = (*ocb)(fp);
1163 if (c < 0)
1164 return(c);
1165 rv += c;
1166 }
1167 /* close our input stream */
1168 c = (*inspec == '!') ? pclose(fp) : fclose(fp);
1169 if (c != 0) {
1170 fprintf(stderr, "%s: error loading '%s'\n", progname, inspec);
1171 return(-1);
1172 }
1173 return(rv);
1174 }
1175
1176 /* Get command arguments and run program */
1177 int
1178 main(int argc, char *argv[])
1179 {
1180 char fmtopt[6] = "-faa"; /* default output is ASCII */
1181 char *xrs=NULL, *yrs=NULL, *ldopt=NULL;
1182 char *iropt = NULL;
1183 char *sendfn;
1184 char sampcntbuf[32], nsbinbuf[32];
1185 FILE *rcfp;
1186 int nsbins;
1187 int a, i;
1188 /* screen rcontrib options */
1189 progname = argv[0];
1190 for (a = 1; a < argc-2; a++) {
1191 int na;
1192 /* check for argument expansion */
1193 while ((na = expandarg(&argc, &argv, a)) > 0)
1194 ;
1195 if (na < 0) {
1196 fprintf(stderr, "%s: cannot expand '%s'\n",
1197 progname, argv[a]);
1198 return(1);
1199 }
1200 if (argv[a][0] != '-' || !argv[a][1])
1201 break;
1202 na = 1;
1203 switch (argv[a][1]) { /* !! Keep consistent !! */
1204 case 'v': /* verbose mode */
1205 verbose = 1;
1206 na = 0;
1207 continue;
1208 case 'f': /* special case for -fo, -ff, etc. */
1209 switch (argv[a][2]) {
1210 case '\0': /* cal file */
1211 goto userr;
1212 case 'o': /* force output */
1213 goto userr;
1214 case 'a': /* output format */
1215 case 'f':
1216 case 'd':
1217 case 'c':
1218 if (!(fmtopt[3] = argv[a][3]))
1219 fmtopt[3] = argv[a][2];
1220 fmtopt[2] = argv[a][2];
1221 na = 0;
1222 continue; /* will pass later */
1223 default:
1224 goto userr;
1225 }
1226 break;
1227 case 'x': /* x-resolution */
1228 xrs = argv[++a];
1229 na = 0;
1230 continue;
1231 case 'y': /* y-resolution */
1232 yrs = argv[++a];
1233 na = 0;
1234 continue;
1235 case 'c': /* number of samples */
1236 sampcnt = atoi(argv[++a]);
1237 if (sampcnt <= 0)
1238 goto userr;
1239 na = 0; /* we re-add this later */
1240 continue;
1241 case 'I': /* only for pass-through mode */
1242 case 'i':
1243 iropt = argv[a];
1244 na = 0;
1245 continue;
1246 case 'w': /* options without arguments */
1247 if (!argv[a][2] || strchr("+1tTyY", argv[a][2]) == NULL)
1248 verbose = -1;
1249 break;
1250 case 'V':
1251 case 'u':
1252 case 'h':
1253 case 'r':
1254 break;
1255 case 'n': /* options with 1 argument */
1256 case 's':
1257 case 'o':
1258 na = 2;
1259 break;
1260 case 'b': /* special case */
1261 if (argv[a][2] != 'v') goto userr;
1262 break;
1263 case 'l': /* special case */
1264 if (argv[a][2] == 'd') {
1265 ldopt = argv[a];
1266 na = 0;
1267 continue;
1268 }
1269 na = 2;
1270 break;
1271 case 'd': /* special case */
1272 if (argv[a][2] != 'v') na = 2;
1273 break;
1274 case 'a': /* special case */
1275 if (argv[a][2] == 'p') {
1276 na = 2; /* photon map [+ bandwidth(s)] */
1277 if (a < argc-3 && atoi(argv[a+1]) > 0)
1278 na += 1 + (a < argc-4 && atoi(argv[a+2]) > 0);
1279 } else
1280 na = (argv[a][2] == 'v') ? 4 : 2;
1281 break;
1282 case 'm': /* special case */
1283 if (!argv[a][2]) goto userr;
1284 na = (argv[a][2] == 'e') | (argv[a][2] == 'a') ? 4 : 2;
1285 break;
1286 default: /* anything else is verbotten */
1287 goto userr;
1288 }
1289 if (na <= 0) continue;
1290 CHECKARGC(na); /* pass on option */
1291 rcarg[nrcargs++] = argv[a];
1292 while (--na) /* + arguments if any */
1293 rcarg[nrcargs++] = argv[++a];
1294 }
1295 if (a > argc-2)
1296 goto userr; /* check at end of options */
1297 sendfn = argv[a++]; /* assign sender & receiver inputs */
1298 if (sendfn[0] == '-') { /* user wants pass-through mode? */
1299 if (sendfn[1]) goto userr;
1300 sendfn = NULL;
1301 if (iropt) {
1302 CHECKARGC(1);
1303 rcarg[nrcargs++] = iropt;
1304 }
1305 if (xrs) {
1306 CHECKARGC(2);
1307 rcarg[nrcargs++] = "-x";
1308 rcarg[nrcargs++] = xrs;
1309 }
1310 if (yrs) {
1311 CHECKARGC(2);
1312 rcarg[nrcargs++] = "-y";
1313 rcarg[nrcargs++] = yrs;
1314 }
1315 if (ldopt) {
1316 CHECKARGC(1);
1317 rcarg[nrcargs++] = ldopt;
1318 }
1319 if (sampcnt <= 0) sampcnt = 1;
1320 } else { /* else in sampling mode */
1321 if (iropt) {
1322 fputs(progname, stderr);
1323 fputs(": -i, -I supported for pass-through only\n", stderr);
1324 return(1);
1325 }
1326 #ifdef SMLFLT
1327 fmtopt[2] = 'f';
1328 #else
1329 fmtopt[2] = 'd';
1330 #endif
1331 if (sampcnt <= 0) sampcnt = 10000;
1332 }
1333 sprintf(sampcntbuf, "%d", sampcnt);
1334 CHECKARGC(3); /* add our format & sample count */
1335 rcarg[nrcargs++] = fmtopt;
1336 rcarg[nrcargs++] = "-c";
1337 rcarg[nrcargs++] = sampcntbuf;
1338 /* add receiver arguments to rcontrib */
1339 if (load_scene(argv[a], add_recv_object) < 0)
1340 return(1);
1341 finish_receiver();
1342 if (sendfn == NULL) { /* pass-through mode? */
1343 CHECKARGC(1); /* add octree */
1344 rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1345 rcarg[nrcargs] = NULL;
1346 return(my_exec(rcarg)); /* rcontrib does everything */
1347 }
1348 clear_params(&curparams, 0); /* else load sender surface & params */
1349 curmod[0] = '\0';
1350 if (load_scene(sendfn, add_send_object) < 0)
1351 return(1);
1352 if ((nsbins = prepare_sampler()) <= 0)
1353 return(1);
1354 CHECKARGC(3); /* add row count and octree */
1355 rcarg[nrcargs++] = "-y";
1356 sprintf(nsbinbuf, "%d", nsbins);
1357 rcarg[nrcargs++] = nsbinbuf;
1358 rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1359 rcarg[nrcargs] = NULL;
1360 /* open pipe to rcontrib process */
1361 if ((rcfp = popen_arglist(rcarg, "w")) == NULL)
1362 return(1);
1363 SET_FILE_BINARY(rcfp);
1364 #ifdef getc_unlocked
1365 flockfile(rcfp);
1366 #endif
1367 if (verbose > 0) {
1368 fprintf(stderr, "%s: sampling %d directions", progname, nsbins);
1369 if (curparams.nsurfs > 1)
1370 fprintf(stderr, " (%d elements)\n", curparams.nsurfs);
1371 else
1372 fputc('\n', stderr);
1373 }
1374 for (i = 0; i < nsbins; i++) /* send rcontrib ray samples */
1375 if (!(*curparams.sample_basis)(&curparams, i, rcfp))
1376 return(1);
1377 return(pclose(rcfp) < 0); /* all finished! */
1378 userr:
1379 if (a < argc-2)
1380 fprintf(stderr, "%s: unsupported option '%s'", progname, argv[a]);
1381 fprintf(stderr, "Usage: %s [-v][rcontrib options] sender.rad receiver.rad [-i system.oct] [system.rad ..]\n",
1382 progname);
1383 return(1);
1384 }
