root/radiance/ray/src/util/rfluxmtx.c
Revision: 2.57
Committed: Tue Mar 19 10:48:05 2024 UTC (2 months, 2 weeks ago) by greg
Changes since 2.56: +3 -3 lines
fix(rfluxmtx,genBSDF): Fixed issue with -c{s,w} argument parsing
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.57 static const char RCSid[] = "$Id: rfluxmtx.c,v 2.56 2024/02/08 02:26:01 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Calculate flux transfer matrix or matrices using rcontrib
6     */
7
8     #include "copyright.h"
9
10     #include <ctype.h>
11     #include <stdlib.h>
12     #include "rtio.h"
13     #include "rtmath.h"
14 greg 2.51 #include "rtprocess.h"
15 greg 2.1 #include "bsdf.h"
16     #include "bsdf_m.h"
17     #include "random.h"
18     #include "triangulate.h"
19     #include "platform.h"
20
21 greg 2.46 #ifndef MAXRCARG
22     #define MAXRCARG 10000
23     #endif
24 greg 2.1
25     char *progname; /* global argv[0] */
26
27 greg 2.16 int verbose = 0; /* verbose mode (< 0 no warnings) */
28 greg 2.1
29     char *rcarg[MAXRCARG+1] = {"rcontrib", "-fo+"};
30     int nrcargs = 2;
31
32     const char overflowerr[] = "%s: too many arguments!\n";
33
34     #define CHECKARGC(n) if (nrcargs >= MAXRCARG-(n)) \
35     { fprintf(stderr, overflowerr, progname); exit(1); }
36
37 greg 2.2 int sampcnt = 0; /* sample count (0==unset) */
38 greg 2.1
39 greg 2.2 char *reinhfn = "reinhartb.cal";
40     char *shirchiufn = "disk2square.cal";
41 greg 2.1 char *kfullfn = "klems_full.cal";
42     char *khalffn = "klems_half.cal";
43     char *kquarterfn = "klems_quarter.cal";
44 greg 2.56 char *ciefn = "cieskyscan.cal";
45 greg 2.1
46 greg 2.5 /* string indicating parameters */
47     const char PARAMSTART[] = "@rfluxmtx";
48 greg 2.1
49     /* surface type IDs */
50     #define ST_NONE 0
51     #define ST_POLY 1
52     #define ST_RING 2
53     #define ST_SOURCE 3
54
55     typedef struct surf_s {
56     struct surf_s *next; /* next surface in list */
57     void *priv; /* private data (malloc'ed) */
58     char sname[32]; /* surface name */
59     FVECT snrm; /* surface normal */
60 greg 2.4 double area; /* surface area / proj. solid angle */
61 greg 2.1 short styp; /* surface type */
62 greg 2.2 short nfargs; /* number of real arguments */
63     double farg[1]; /* real values (extends struct) */
64 greg 2.1 } SURF; /* surface structure */
65
66     typedef struct {
67     FVECT uva[2]; /* tangent axes */
68     int ntris; /* number of triangles */
69     struct ptri {
70 greg 2.41 double afrac; /* fraction of total area */
71 greg 2.1 short vndx[3]; /* vertex indices */
72     } tri[1]; /* triangle array (extends struct) */
73     } POLYTRIS; /* triangulated polygon */
74
75     typedef struct param_s {
76 greg 2.26 char sign; /* '-' for axis reversal */
77     char hemis[31]; /* hemispherical sampling spec. */
78 greg 2.1 int hsiz; /* hemisphere basis size */
79     int nsurfs; /* number of surfaces */
80     SURF *slist; /* list of surfaces */
81     FVECT vup; /* up vector (zero if unset) */
82     FVECT nrm; /* average normal direction */
83 greg 2.26 FVECT udir, vdir; /* tangent axes */
84 greg 2.1 char *outfn; /* output file name (receiver) */
85     int (*sample_basis)(struct param_s *p, int, FILE *);
86     } PARAMS; /* sender/receiver parameters */
87
88     PARAMS curparams;
89     char curmod[128];
90 greg 2.6 char newparams[1024];
91 greg 2.1
92     typedef int SURFSAMP(FVECT, SURF *, double);
93
94     static SURFSAMP ssamp_bad, ssamp_poly, ssamp_ring;
95
96     SURFSAMP *orig_in_surf[4] = {
97     ssamp_bad, ssamp_poly, ssamp_ring, ssamp_bad
98     };
99
100     /* Clear parameter set */
101     static void
102     clear_params(PARAMS *p, int reset_only)
103     {
104     while (p->slist != NULL) {
105     SURF *sdel = p->slist;
106     p->slist = sdel->next;
107     if (sdel->priv != NULL)
108     free(sdel->priv);
109     free(sdel);
110     }
111     if (reset_only) {
112     p->nsurfs = 0;
113     memset(p->nrm, 0, sizeof(FVECT));
114     memset(p->vup, 0, sizeof(FVECT));
115     p->outfn = NULL;
116     return;
117     }
118 greg 2.6 memset(p, 0, sizeof(PARAMS));
119 greg 2.1 }
120
121     /* Get surface type from name */
122     static int
123     surf_type(const char *otype)
124     {
125     if (!strcmp(otype, "polygon"))
126     return(ST_POLY);
127     if (!strcmp(otype, "ring"))
128     return(ST_RING);
129     if (!strcmp(otype, "source"))
130     return(ST_SOURCE);
131     return(ST_NONE);
132     }
133
134     /* Add arguments to oconv command */
135     static char *
136     oconv_command(int ac, char *av[])
137     {
138 greg 2.13 static char oconvbuf[2048] = "!oconv -f ";
139     char *cp = oconvbuf + 10;
140     char *recv = *av++;
141
142     if (ac-- <= 0)
143     return(NULL);
144 greg 2.43 if (verbose < 0) { /* turn off warnings */
145 greg 2.49 strcpy(cp, "-w ");
146 greg 2.50 cp += 3;
147 greg 2.43 }
148 greg 2.48 while (ac-- > 0) { /* copy each argument */
149     int len = strlen(*av);
150     if (cp+len+4 >= oconvbuf+sizeof(oconvbuf))
151     goto overrun;
152     if (matchany(*av, SPECIALS)) {
153     *cp++ = QUOTCHAR;
154     strcpy(cp, *av++);
155     cp += len;
156     *cp++ = QUOTCHAR;
157     } else {
158     strcpy(cp, *av++);
159     cp += len;
160     }
161 greg 2.13 *cp++ = ' ';
162 greg 2.30 }
163     /* receiver goes last */
164     if (matchany(recv, SPECIALS)) {
165     *cp++ = QUOTCHAR;
166     while (*recv) {
167     if (cp >= oconvbuf+(sizeof(oconvbuf)-3))
168     goto overrun;
169     *cp++ = *recv++;
170 greg 2.1 }
171 greg 2.30 *cp++ = QUOTCHAR;
172     *cp = '\0';
173     } else
174     strcpy(cp, recv);
175 greg 2.1 return(oconvbuf);
176 greg 2.30 overrun:
177     fputs(progname, stderr);
178     fputs(": too many file arguments!\n", stderr);
179     exit(1);
180 greg 2.1 }
181
182 greg 2.51 #if defined(_WIN32) || defined(_WIN64)
183
184 greg 2.1 /* Open a pipe to/from a command given as an argument list */
185     static FILE *
186     popen_arglist(char *av[], char *mode)
187     {
188     char cmd[10240];
189
190     if (!convert_commandline(cmd, sizeof(cmd), av)) {
191     fputs(progname, stderr);
192     fputs(": command line too long in popen_arglist()\n", stderr);
193     return(NULL);
194     }
195 greg 2.16 if (verbose > 0)
196 greg 2.1 fprintf(stderr, "%s: opening pipe %s: %s\n",
197     progname, (*mode=='w') ? "to" : "from", cmd);
198     return(popen(cmd, mode));
199     }
200
201 greg 2.51 #define pclose_al pclose
202
203 greg 2.1 /* Execute system command (Windows version) */
204     static int
205     my_exec(char *av[])
206     {
207     char cmd[10240];
208
209     if (!convert_commandline(cmd, sizeof(cmd), av)) {
210     fputs(progname, stderr);
211     fputs(": command line too long in my_exec()\n", stderr);
212     return(1);
213     }
214 greg 2.16 if (verbose > 0)
215 greg 2.1 fprintf(stderr, "%s: running: %s\n", progname, cmd);
216     return(system(cmd));
217     }
218 greg 2.51
219     #else /* UNIX */
220
221     static SUBPROC rt_proc = SP_INACTIVE; /* we only support one of these */
222
223     /* Open a pipe to a command using an argument list */
224     static FILE *
225     popen_arglist(char *av[], char *mode)
226     {
227     int fd;
228
229     if (rt_proc.pid > 0) {
230     fprintf(stderr, "%s: only one i/o pipe at a time!\n", progname);
231     return(NULL);
232     }
233     if (verbose > 0) {
234     char cmd[4096];
235     if (!convert_commandline(cmd, sizeof(cmd), av))
236     strcpy(cmd, "COMMAND TOO LONG TO SHOW");
237     fprintf(stderr, "%s: opening pipe %s: %s\n",
238     progname, (*mode=='w') ? "to" : "from", cmd);
239     }
240     if (*mode == 'w') {
241     fd = rt_proc.w = dup(fileno(stdout));
242     rt_proc.flags |= PF_FILT_OUT;
243     } else if (*mode == 'r') {
244     fd = rt_proc.r = dup(fileno(stdin));
245     rt_proc.flags |= PF_FILT_INP;
246     }
247     if (fd < 0 || open_process(&rt_proc, av) <= 0) {
248     perror(av[0]);
249     return(NULL);
250     }
251     return(fdopen(fd, mode));
252     }
253
254     /* Close command pipe (returns -1 on error to match pclose) */
255     static int
256     pclose_al(FILE *fp)
257     {
258     int prob = (fclose(fp) == EOF);
259
260     if (rt_proc.pid <= 0)
261     return(-1);
262
263     prob |= (close_process(&rt_proc) != 0);
264
265     return(-prob);
266     }
267
268 greg 2.1 /* Execute system command in our stead (Unix version) */
269     static int
270     my_exec(char *av[])
271     {
272     char *compath;
273
274     if ((compath = getpath((char *)av[0], getenv("PATH"), X_OK)) == NULL) {
275     fprintf(stderr, "%s: cannot locate %s\n", progname, av[0]);
276     return(1);
277     }
278 greg 2.16 if (verbose > 0) {
279 greg 2.1 char cmd[4096];
280     if (!convert_commandline(cmd, sizeof(cmd), av))
281     strcpy(cmd, "COMMAND TOO LONG TO SHOW");
282     fprintf(stderr, "%s: running: %s\n", progname, cmd);
283     }
284     execv(compath, av); /* successful call never returns */
285     perror(compath);
286     return(1);
287     }
288 greg 2.51
289 greg 2.1 #endif
290
291     /* Get normalized direction vector from string specification */
292     static int
293     get_direction(FVECT dv, const char *s)
294     {
295     int sign = 1;
296     int axis = 0;
297
298     memset(dv, 0, sizeof(FVECT));
299     nextchar:
300     switch (*s) {
301     case '+':
302     ++s;
303     goto nextchar;
304     case '-':
305     sign = -sign;
306     ++s;
307     goto nextchar;
308     case 'z':
309     case 'Z':
310     ++axis;
311     case 'y':
312     case 'Y':
313     ++axis;
314     case 'x':
315     case 'X':
316     dv[axis] = sign;
317     return(!s[1] | isspace(s[1]));
318     default:
319     break;
320     }
321     #ifdef SMLFLT
322     if (sscanf(s, "%f,%f,%f", &dv[0], &dv[1], &dv[2]) != 3)
323     #else
324     if (sscanf(s, "%lf,%lf,%lf", &dv[0], &dv[1], &dv[2]) != 3)
325     #endif
326     return(0);
327     dv[0] *= (RREAL)sign;
328     return(normalize(dv) > 0);
329     }
330
331     /* Parse program parameters (directives) */
332     static int
333 greg 2.6 parse_params(PARAMS *p, char *pargs)
334 greg 2.1 {
335     char *cp = pargs;
336     int nparams = 0;
337 greg 2.32 int quot;
338 greg 2.1 int i;
339
340 greg 2.15 for ( ; ; ) {
341 greg 2.1 switch (*cp++) {
342     case 'h':
343     if (*cp++ != '=')
344     break;
345 greg 2.26 if ((*cp == '+') | (*cp == '-'))
346     p->sign = *cp++;
347     else
348     p->sign = '+';
349 greg 2.6 p->hsiz = 0;
350 greg 2.1 i = 0;
351     while (*cp && !isspace(*cp)) {
352     if (isdigit(*cp))
353 greg 2.6 p->hsiz = 10*p->hsiz + *cp - '0';
354     p->hemis[i++] = *cp++;
355 greg 2.1 }
356     if (!i)
357     break;
358 greg 2.6 p->hemis[i] = '\0';
359     p->hsiz += !p->hsiz;
360 greg 2.1 ++nparams;
361     continue;
362     case 'u':
363     if (*cp++ != '=')
364     break;
365 greg 2.6 if (!get_direction(p->vup, cp))
366 greg 2.1 break;
367 greg 2.15 while (*cp && !isspace(*cp++))
368     ;
369 greg 2.1 ++nparams;
370     continue;
371     case 'o':
372     if (*cp++ != '=')
373     break;
374 greg 2.32 quot = 0;
375     if ((*cp == '"') | (*cp == '\''))
376     quot = *cp++;
377 greg 2.1 i = 0;
378 greg 2.32 while (*cp && (quot ? (*cp != quot) : !isspace(*cp))) {
379     i++; cp++;
380     }
381 greg 2.1 if (!i)
382     break;
383 greg 2.32 if (!*cp) {
384     if (quot)
385     break;
386     cp[1] = '\0';
387     }
388     *cp = '\0';
389 greg 2.6 p->outfn = savqstr(cp-i);
390 greg 2.32 *cp++ = quot ? quot : ' ';
391 greg 2.1 ++nparams;
392     continue;
393     case ' ':
394     case '\t':
395     case '\r':
396 greg 2.21 case '\n':
397 greg 2.15 continue;
398 greg 2.1 case '\0':
399     return(nparams);
400     default:
401     break;
402     }
403 greg 2.15 break;
404     }
405     fprintf(stderr, "%s: bad parameter string: %s", progname, pargs);
406 greg 2.1 exit(1);
407     return(-1); /* pro forma return */
408     }
409
410     /* Add receiver arguments (directives) corresponding to the current modifier */
411     static void
412     finish_receiver(void)
413     {
414 greg 2.4 char sbuf[256];
415     int uniform = 0;
416 greg 2.2 char *calfn = NULL;
417 greg 2.3 char *params = NULL;
418 greg 2.2 char *binv = NULL;
419     char *binf = NULL;
420     char *nbins = NULL;
421 greg 2.1
422     if (!curmod[0]) {
423     fputs(progname, stderr);
424     fputs(": missing receiver surface!\n", stderr);
425     exit(1);
426     }
427     if (curparams.outfn != NULL) { /* add output file spec. */
428     CHECKARGC(2);
429     rcarg[nrcargs++] = "-o";
430     rcarg[nrcargs++] = curparams.outfn;
431     }
432 greg 2.4 /* check arguments */
433 greg 2.1 if (!curparams.hemis[0]) {
434     fputs(progname, stderr);
435     fputs(": missing hemisphere sampling type!\n", stderr);
436     exit(1);
437     }
438     if (normalize(curparams.nrm) == 0) {
439     fputs(progname, stderr);
440     fputs(": undefined normal for hemisphere sampling\n", stderr);
441     exit(1);
442     }
443 greg 2.10 if (normalize(curparams.vup) == 0) {
444 greg 2.1 if (fabs(curparams.nrm[2]) < .7)
445     curparams.vup[2] = 1;
446     else
447     curparams.vup[1] = 1;
448 greg 2.10 }
449 greg 2.4 /* determine sample type/bin */
450 greg 2.44 if ((tolower(curparams.hemis[0]) == 'u') | (curparams.hemis[0] == '1')) {
451 greg 2.20 sprintf(sbuf, "if(-Dx*%g-Dy*%g-Dz*%g,0,-1)",
452     curparams.nrm[0], curparams.nrm[1], curparams.nrm[2]);
453     binv = savqstr(sbuf);
454     nbins = "1"; /* uniform sampling -- one bin */
455 greg 2.4 uniform = 1;
456 greg 2.1 } else if (tolower(curparams.hemis[0]) == 's' &&
457     tolower(curparams.hemis[1]) == 'c') {
458 greg 2.2 /* assign parameters */
459 greg 2.1 if (curparams.hsiz <= 1) {
460     fputs(progname, stderr);
461     fputs(": missing size for Shirley-Chiu sampling!\n", stderr);
462     exit(1);
463     }
464 greg 2.3 calfn = shirchiufn; shirchiufn = NULL;
465 greg 2.26 sprintf(sbuf, "SCdim=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1",
466 greg 2.2 curparams.hsiz,
467     curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
468 greg 2.26 curparams.vup[0], curparams.vup[1], curparams.vup[2],
469     curparams.sign);
470 greg 2.3 params = savqstr(sbuf);
471 greg 2.2 binv = "scbin";
472     nbins = "SCdim*SCdim";
473 greg 2.1 } else if ((tolower(curparams.hemis[0]) == 'r') |
474     (tolower(curparams.hemis[0]) == 't')) {
475 greg 2.2 calfn = reinhfn; reinhfn = NULL;
476 greg 2.26 sprintf(sbuf, "MF=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1",
477 greg 2.3 curparams.hsiz,
478     curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
479 greg 2.26 curparams.vup[0], curparams.vup[1], curparams.vup[2],
480     curparams.sign);
481 greg 2.3 params = savqstr(sbuf);
482     binv = "rbin";
483     nbins = "Nrbins";
484 greg 2.1 } else if (tolower(curparams.hemis[0]) == 'k' &&
485     !curparams.hemis[1] |
486     (tolower(curparams.hemis[1]) == 'f') |
487     (curparams.hemis[1] == '1')) {
488 greg 2.2 calfn = kfullfn; kfullfn = NULL;
489     binf = "kbin";
490     nbins = "Nkbins";
491 greg 2.1 } else if (tolower(curparams.hemis[0]) == 'k' &&
492     (tolower(curparams.hemis[1]) == 'h') |
493     (curparams.hemis[1] == '2')) {
494 greg 2.2 calfn = khalffn; khalffn = NULL;
495     binf = "khbin";
496     nbins = "Nkhbins";
497 greg 2.1 } else if (tolower(curparams.hemis[0]) == 'k' &&
498     (tolower(curparams.hemis[1]) == 'q') |
499     (curparams.hemis[1] == '4')) {
500 greg 2.2 calfn = kquarterfn; kquarterfn = NULL;
501     binf = "kqbin";
502     nbins = "Nkqbins";
503 greg 2.56 } else if (!strcasecmp(curparams.hemis, "cie")) {
504     calfn = ciefn; ciefn = NULL;
505     sprintf(sbuf, "rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1",
506     curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
507     curparams.vup[0], curparams.vup[1], curparams.vup[2],
508     curparams.sign);
509     binv = "cbin";
510     nbins = "Ncbins";
511 greg 2.1 } else {
512     fprintf(stderr, "%s: unrecognized hemisphere sampling: h=%s\n",
513     progname, curparams.hemis);
514     exit(1);
515     }
516 greg 2.26 if (tolower(curparams.hemis[0]) == 'k') {
517     sprintf(sbuf, "RHS=%c1", curparams.sign);
518     params = savqstr(sbuf);
519     }
520 greg 2.4 if (!uniform & (curparams.slist->styp == ST_SOURCE)) {
521     SURF *sp;
522     for (sp = curparams.slist; sp != NULL; sp = sp->next)
523     if (fabs(sp->area - PI) > 1e-3) {
524     fprintf(stderr, "%s: source '%s' must be 180-degrees\n",
525     progname, sp->sname);
526     exit(1);
527     }
528     }
529 greg 2.2 if (calfn != NULL) { /* add cal file if needed */
530     CHECKARGC(2);
531     rcarg[nrcargs++] = "-f";
532     rcarg[nrcargs++] = calfn;
533     }
534 greg 2.3 if (params != NULL) { /* parameters _after_ cal file */
535     CHECKARGC(2);
536     rcarg[nrcargs++] = "-p";
537     rcarg[nrcargs++] = params;
538     }
539 greg 2.2 if (nbins != NULL) { /* add #bins if set */
540     CHECKARGC(2);
541     rcarg[nrcargs++] = "-bn";
542     rcarg[nrcargs++] = nbins;
543     }
544 greg 2.3 if (binv != NULL) {
545 greg 2.2 CHECKARGC(2); /* assign bin variable */
546     rcarg[nrcargs++] = "-b";
547     rcarg[nrcargs++] = binv;
548     } else if (binf != NULL) {
549     CHECKARGC(2); /* assign bin function */
550 greg 2.3 rcarg[nrcargs++] = "-b";
551 greg 2.2 sprintf(sbuf, "%s(%g,%g,%g,%g,%g,%g)", binf,
552     curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
553     curparams.vup[0], curparams.vup[1], curparams.vup[2]);
554     rcarg[nrcargs++] = savqstr(sbuf);
555     }
556     CHECKARGC(2); /* modifier argument goes last */
557 greg 2.1 rcarg[nrcargs++] = "-m";
558     rcarg[nrcargs++] = savqstr(curmod);
559     }
560
561     /* Make randomly oriented tangent plane axes for given normal direction */
562     static void
563     make_axes(FVECT uva[2], const FVECT nrm)
564     {
565     int i;
566
567 greg 2.29 if (!getperpendicular(uva[0], nrm, 1)) {
568 greg 2.1 fputs(progname, stderr);
569     fputs(": bad surface normal in make_axes!\n", stderr);
570     exit(1);
571     }
572 greg 2.19 fcross(uva[1], nrm, uva[0]);
573 greg 2.1 }
574
575     /* Illegal sender surfaces end up here */
576     static int
577     ssamp_bad(FVECT orig, SURF *sp, double x)
578     {
579     fprintf(stderr, "%s: illegal sender surface '%s'\n",
580     progname, sp->sname);
581     return(0);
582     }
583
584     /* Generate origin on ring surface from uniform random variable */
585     static int
586     ssamp_ring(FVECT orig, SURF *sp, double x)
587     {
588     FVECT *uva = (FVECT *)sp->priv;
589     double samp2[2];
590     double uv[2];
591     int i;
592
593     if (uva == NULL) { /* need tangent axes */
594     uva = (FVECT *)malloc(sizeof(FVECT)*2);
595     if (uva == NULL) {
596     fputs(progname, stderr);
597     fputs(": out of memory in ssamp_ring!\n", stderr);
598     return(0);
599     }
600     make_axes(uva, sp->snrm);
601     sp->priv = (void *)uva;
602     }
603     SDmultiSamp(samp2, 2, x);
604 greg 2.6 samp2[0] = sqrt(samp2[0]*sp->area*(1./PI) + sp->farg[6]*sp->farg[6]);
605 greg 2.1 samp2[1] *= 2.*PI;
606     uv[0] = samp2[0]*tcos(samp2[1]);
607     uv[1] = samp2[0]*tsin(samp2[1]);
608     for (i = 3; i--; )
609     orig[i] = sp->farg[i] + uv[0]*uva[0][i] + uv[1]*uva[1][i];
610     return(1);
611     }
612
613     /* Add triangle to polygon's list (call-back function) */
614     static int
615     add_triangle(const Vert2_list *tp, int a, int b, int c)
616     {
617     POLYTRIS *ptp = (POLYTRIS *)tp->p;
618     struct ptri *trip = ptp->tri + ptp->ntris++;
619
620     trip->vndx[0] = a;
621     trip->vndx[1] = b;
622     trip->vndx[2] = c;
623     return(1);
624     }
625
626     /* Generate origin on polygon surface from uniform random variable */
627     static int
628     ssamp_poly(FVECT orig, SURF *sp, double x)
629     {
630     POLYTRIS *ptp = (POLYTRIS *)sp->priv;
631     double samp2[2];
632     double *v0, *v1, *v2;
633     int i;
634
635     if (ptp == NULL) { /* need to triangulate */
636     ptp = (POLYTRIS *)malloc(sizeof(POLYTRIS) +
637 greg 2.40 sizeof(struct ptri)*(sp->nfargs/3 - 3));
638 greg 2.1 if (ptp == NULL)
639     goto memerr;
640     if (sp->nfargs == 3) { /* simple case */
641     ptp->ntris = 1;
642     ptp->tri[0].vndx[0] = 0;
643     ptp->tri[0].vndx[1] = 1;
644     ptp->tri[0].vndx[2] = 2;
645     ptp->tri[0].afrac = 1;
646     } else {
647     Vert2_list *v2l = polyAlloc(sp->nfargs/3);
648     if (v2l == NULL)
649     goto memerr;
650     make_axes(ptp->uva, sp->snrm);
651     for (i = v2l->nv; i--; ) {
652     v2l->v[i].mX = DOT(sp->farg+3*i, ptp->uva[0]);
653     v2l->v[i].mY = DOT(sp->farg+3*i, ptp->uva[1]);
654     }
655     ptp->ntris = 0;
656     v2l->p = (void *)ptp;
657 greg 2.7 if (!polyTriangulate(v2l, add_triangle)) {
658     fprintf(stderr,
659     "%s: cannot triangulate polygon '%s'\n",
660     progname, sp->sname);
661 greg 2.1 return(0);
662 greg 2.7 }
663 greg 2.1 for (i = ptp->ntris; i--; ) {
664     int a = ptp->tri[i].vndx[0];
665     int b = ptp->tri[i].vndx[1];
666     int c = ptp->tri[i].vndx[2];
667     ptp->tri[i].afrac =
668     (v2l->v[a].mX*v2l->v[b].mY -
669     v2l->v[b].mX*v2l->v[a].mY +
670     v2l->v[b].mX*v2l->v[c].mY -
671     v2l->v[c].mX*v2l->v[b].mY +
672     v2l->v[c].mX*v2l->v[a].mY -
673     v2l->v[a].mX*v2l->v[c].mY) /
674     (2.*sp->area);
675     }
676     polyFree(v2l);
677     }
678     sp->priv = (void *)ptp;
679     }
680     /* pick triangle by partial area */
681 greg 2.40 for (i = 0; i < ptp->ntris-1 && x > ptp->tri[i].afrac; i++)
682 greg 2.1 x -= ptp->tri[i].afrac;
683     SDmultiSamp(samp2, 2, x/ptp->tri[i].afrac);
684     samp2[0] *= samp2[1] = sqrt(samp2[1]);
685     samp2[1] = 1. - samp2[1];
686     v0 = sp->farg + 3*ptp->tri[i].vndx[0];
687     v1 = sp->farg + 3*ptp->tri[i].vndx[1];
688     v2 = sp->farg + 3*ptp->tri[i].vndx[2];
689     for (i = 3; i--; )
690     orig[i] = v0[i] + samp2[0]*(v1[i] - v0[i])
691     + samp2[1]*(v2[i] - v0[i]) ;
692     return(1);
693     memerr:
694     fputs(progname, stderr);
695     fputs(": out of memory in ssamp_poly!\n", stderr);
696     return(0);
697     }
698
699     /* Compute sample origin based on projected areas of sender subsurfaces */
700     static int
701     sample_origin(PARAMS *p, FVECT orig, const FVECT rdir, double x)
702     {
703     static double *projsa;
704     static int nall;
705     double tarea = 0;
706     int i;
707     SURF *sp;
708     /* special case for lone surface */
709     if (p->nsurfs == 1) {
710     sp = p->slist;
711 greg 2.31 if (DOT(sp->snrm, rdir) >= FTINY) {
712 greg 2.7 fprintf(stderr,
713     "%s: internal - sample behind sender '%s'\n",
714     progname, sp->sname);
715     return(0);
716     }
717 greg 2.1 return((*orig_in_surf[sp->styp])(orig, sp, x));
718     }
719     if (p->nsurfs > nall) { /* (re)allocate surface area cache */
720     if (projsa) free(projsa);
721     projsa = (double *)malloc(sizeof(double)*p->nsurfs);
722 greg 2.37 if (projsa == NULL) {
723     fputs(progname, stderr);
724     fputs(": out of memory in sample_origin!\n", stderr);
725     exit(1);
726     }
727 greg 2.1 nall = p->nsurfs;
728     }
729     /* compute projected areas */
730     for (i = 0, sp = p->slist; sp != NULL; i++, sp = sp->next) {
731     projsa[i] = -DOT(sp->snrm, rdir) * sp->area;
732 greg 2.52 tarea += projsa[i] *= (double)(projsa[i] > 0);
733 greg 2.1 }
734 greg 2.52 if (tarea < FTINY*FTINY) { /* wrong side of sender? */
735 greg 2.7 fputs(progname, stderr);
736     fputs(": internal - sample behind all sender elements!\n",
737     stderr);
738 greg 2.1 return(0);
739 greg 2.7 }
740 greg 2.1 tarea *= x; /* get surface from list */
741     for (i = 0, sp = p->slist; tarea > projsa[i]; sp = sp->next)
742     tarea -= projsa[i++];
743     return((*orig_in_surf[sp->styp])(orig, sp, tarea/projsa[i]));
744     }
745
746     /* Uniform sample generator */
747     static int
748     sample_uniform(PARAMS *p, int b, FILE *fp)
749     {
750     int n = sampcnt;
751     double samp3[3];
752 greg 2.54 FVECT duvw, orig_dir[2];
753 greg 2.1 int i;
754
755     if (fp == NULL) /* just requesting number of bins? */
756     return(1);
757
758     while (n--) { /* stratified hemisphere sampling */
759     SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
760 greg 2.54 square2disk(duvw, samp3[1], samp3[2]);
761 greg 2.1 duvw[2] = -sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
762     for (i = 3; i--; )
763     orig_dir[1][i] = duvw[0]*p->udir[i] +
764     duvw[1]*p->vdir[i] +
765     duvw[2]*p->nrm[i] ;
766     if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
767     return(0);
768 greg 2.38 if (putbinary(orig_dir, sizeof(FVECT), 2, fp) != 2)
769 greg 2.1 return(0);
770     }
771     return(1);
772     }
773
774     /* Shirly-Chiu sample generator */
775     static int
776     sample_shirchiu(PARAMS *p, int b, FILE *fp)
777     {
778     int n = sampcnt;
779     double samp3[3];
780 greg 2.54 FVECT duvw, orig_dir[2];
781 greg 2.1 int i;
782
783     if (fp == NULL) /* just requesting number of bins? */
784     return(p->hsiz*p->hsiz);
785
786     while (n--) { /* stratified sampling */
787     SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
788 greg 2.54 square2disk(duvw, (b/p->hsiz + samp3[1])/curparams.hsiz,
789 greg 2.1 (b%p->hsiz + samp3[2])/curparams.hsiz);
790     duvw[2] = sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
791     for (i = 3; i--; )
792     orig_dir[1][i] = -duvw[0]*p->udir[i] -
793     duvw[1]*p->vdir[i] -
794     duvw[2]*p->nrm[i] ;
795     if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
796     return(0);
797 greg 2.38 if (putbinary(orig_dir, sizeof(FVECT), 2, fp) != 2)
798 greg 2.1 return(0);
799     }
800     return(1);
801     }
802
803     /* Reinhart/Tregenza sample generator */
804     static int
805     sample_reinhart(PARAMS *p, int b, FILE *fp)
806     {
807     #define T_NALT 7
808     static const int tnaz[T_NALT] = {30, 30, 24, 24, 18, 12, 6};
809     const int RowMax = T_NALT*p->hsiz + 1;
810 greg 2.7 const double RAH = (.5*PI)/(RowMax-.5);
811 greg 2.1 #define rnaz(r) (r >= RowMax-1 ? 1 : p->hsiz*tnaz[r/p->hsiz])
812     int n = sampcnt;
813     int row, col;
814     double samp3[3];
815     double alt, azi;
816     double duvw[3];
817     FVECT orig_dir[2];
818     int i;
819
820     if (fp == NULL) { /* just requesting number of bins? */
821     n = 0;
822     for (row = RowMax; row--; ) n += rnaz(row);
823     return(n);
824     }
825     row = 0; /* identify row & column */
826     col = b;
827     while (col >= rnaz(row)) {
828     col -= rnaz(row);
829     ++row;
830     }
831     while (n--) { /* stratified sampling */
832     SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
833 greg 2.45 if (row >= RowMax-1) /* avoid crowding at zenith */
834     samp3[1] *= samp3[1];
835 greg 2.1 alt = (row+samp3[1])*RAH;
836     azi = (2.*PI)*(col+samp3[2]-.5)/rnaz(row);
837 greg 2.7 duvw[2] = cos(alt); /* measured from horizon */
838 greg 2.18 duvw[0] = tsin(azi)*duvw[2];
839 greg 2.45 duvw[1] = -tcos(azi)*duvw[2];
840 greg 2.1 duvw[2] = sqrt(1. - duvw[2]*duvw[2]);
841     for (i = 3; i--; )
842     orig_dir[1][i] = -duvw[0]*p->udir[i] -
843     duvw[1]*p->vdir[i] -
844     duvw[2]*p->nrm[i] ;
845     if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
846     return(0);
847 greg 2.38 if (putbinary(orig_dir, sizeof(FVECT), 2, fp) != 2)
848 greg 2.1 return(0);
849     }
850     return(1);
851     #undef rnaz
852     #undef T_NALT
853     }
854
855     /* Klems sample generator */
856     static int
857     sample_klems(PARAMS *p, int b, FILE *fp)
858     {
859     static const char bname[4][20] = {
860     "LBNL/Klems Full",
861     "LBNL/Klems Half",
862     "INTERNAL ERROR",
863     "LBNL/Klems Quarter"
864     };
865     static ANGLE_BASIS *kbasis[4];
866     const int bi = p->hemis[1] - '1';
867     int n = sampcnt;
868     double samp2[2];
869     double duvw[3];
870     FVECT orig_dir[2];
871     int i;
872
873     if (!kbasis[bi]) { /* need to get basis, first */
874     for (i = 4; i--; )
875     if (!strcasecmp(abase_list[i].name, bname[bi])) {
876     kbasis[bi] = &abase_list[i];
877     break;
878     }
879     if (i < 0) {
880     fprintf(stderr, "%s: unknown hemisphere basis '%s'\n",
881     progname, bname[bi]);
882     return(0);
883     }
884     }
885     if (fp == NULL) /* just requesting number of bins? */
886     return(kbasis[bi]->nangles);
887
888     while (n--) { /* stratified sampling */
889     SDmultiSamp(samp2, 2, (n+frandom())/sampcnt);
890 greg 2.27 if (!fo_getvec(duvw, b+samp2[1], kbasis[bi]))
891 greg 2.1 return(0);
892     for (i = 3; i--; )
893 greg 2.26 orig_dir[1][i] = -duvw[0]*p->udir[i] -
894     duvw[1]*p->vdir[i] -
895 greg 2.1 duvw[2]*p->nrm[i] ;
896     if (!sample_origin(p, orig_dir[0], orig_dir[1], samp2[0]))
897     return(0);
898 greg 2.38 if (putbinary(orig_dir, sizeof(FVECT), 2, fp) != 2)
899 greg 2.1 return(0);
900     }
901     return(1);
902     }
903
904     /* Prepare hemisphere basis sampler that will send rays to rcontrib */
905     static int
906     prepare_sampler(void)
907     {
908     if (curparams.slist == NULL) { /* missing sample surface! */
909     fputs(progname, stderr);
910     fputs(": no sender surface!\n", stderr);
911     return(-1);
912     }
913 greg 2.16 /* misplaced output file spec. */
914     if ((curparams.outfn != NULL) & (verbose >= 0))
915 greg 2.1 fprintf(stderr, "%s: warning - ignoring output file in sender ('%s')\n",
916     progname, curparams.outfn);
917     /* check/set basis hemisphere */
918     if (!curparams.hemis[0]) {
919     fputs(progname, stderr);
920     fputs(": missing sender sampling type!\n", stderr);
921     return(-1);
922     }
923     if (normalize(curparams.nrm) == 0) {
924     fputs(progname, stderr);
925     fputs(": undefined normal for sender sampling\n", stderr);
926     return(-1);
927     }
928 greg 2.10 if (normalize(curparams.vup) == 0) {
929 greg 2.1 if (fabs(curparams.nrm[2]) < .7)
930     curparams.vup[2] = 1;
931     else
932     curparams.vup[1] = 1;
933 greg 2.10 }
934 greg 2.26 fcross(curparams.udir, curparams.vup, curparams.nrm);
935 greg 2.1 if (normalize(curparams.udir) == 0) {
936     fputs(progname, stderr);
937     fputs(": up vector coincides with sender normal\n", stderr);
938     return(-1);
939     }
940 greg 2.26 fcross(curparams.vdir, curparams.nrm, curparams.udir);
941     if (curparams.sign == '-') { /* left-handed coordinate system? */
942     curparams.udir[0] *= -1.;
943     curparams.udir[1] *= -1.;
944     curparams.udir[2] *= -1.;
945     }
946 greg 2.44 if ((tolower(curparams.hemis[0]) == 'u') | (curparams.hemis[0] == '1'))
947 greg 2.1 curparams.sample_basis = sample_uniform;
948     else if (tolower(curparams.hemis[0]) == 's' &&
949     tolower(curparams.hemis[1]) == 'c')
950     curparams.sample_basis = sample_shirchiu;
951     else if ((tolower(curparams.hemis[0]) == 'r') |
952     (tolower(curparams.hemis[0]) == 't'))
953     curparams.sample_basis = sample_reinhart;
954     else if (tolower(curparams.hemis[0]) == 'k') {
955     switch (curparams.hemis[1]) {
956     case '1':
957     case '2':
958     case '4':
959     break;
960     case 'f':
961     case 'F':
962     case '\0':
963     curparams.hemis[1] = '1';
964     break;
965     case 'h':
966     case 'H':
967     curparams.hemis[1] = '2';
968     break;
969     case 'q':
970     case 'Q':
971     curparams.hemis[1] = '4';
972     break;
973     default:
974     goto unrecognized;
975     }
976     curparams.hemis[2] = '\0';
977     curparams.sample_basis = sample_klems;
978     } else
979     goto unrecognized;
980     /* return number of bins */
981     return((*curparams.sample_basis)(&curparams,0,NULL));
982     unrecognized:
983     fprintf(stderr, "%s: unrecognized sender sampling: h=%s\n",
984     progname, curparams.hemis);
985     return(-1);
986     }
987
988     /* Compute normal and area for polygon */
989     static int
990     finish_polygon(SURF *p)
991     {
992     const int nv = p->nfargs / 3;
993     FVECT e1, e2, vc;
994     int i;
995
996     memset(p->snrm, 0, sizeof(FVECT));
997     VSUB(e1, p->farg+3, p->farg);
998     for (i = 2; i < nv; i++) {
999     VSUB(e2, p->farg+3*i, p->farg);
1000     VCROSS(vc, e1, e2);
1001     p->snrm[0] += vc[0];
1002     p->snrm[1] += vc[1];
1003     p->snrm[2] += vc[2];
1004     VCOPY(e1, e2);
1005     }
1006     p->area = normalize(p->snrm)*0.5;
1007 greg 2.52 return(p->area > FTINY*FTINY);
1008 greg 2.1 }
1009
1010     /* Add a surface to our current parameters */
1011     static void
1012     add_surface(int st, const char *oname, FILE *fp)
1013     {
1014     SURF *snew;
1015     int n;
1016     /* get floating-point arguments */
1017     if (!fscanf(fp, "%d", &n)) return;
1018     while (n-- > 0) fscanf(fp, "%*s");
1019     if (!fscanf(fp, "%d", &n)) return;
1020     while (n-- > 0) fscanf(fp, "%*d");
1021     if (!fscanf(fp, "%d", &n) || n <= 0) return;
1022     snew = (SURF *)malloc(sizeof(SURF) + sizeof(double)*(n-1));
1023     if (snew == NULL) {
1024     fputs(progname, stderr);
1025 greg 2.37 fputs(": out of memory in add_surface!\n", stderr);
1026 greg 2.1 exit(1);
1027     }
1028     strncpy(snew->sname, oname, sizeof(snew->sname)-1);
1029     snew->sname[sizeof(snew->sname)-1] = '\0';
1030     snew->styp = st;
1031     snew->priv = NULL;
1032     snew->nfargs = n;
1033     for (n = 0; n < snew->nfargs; n++)
1034     if (fscanf(fp, "%lf", &snew->farg[n]) != 1) {
1035     fprintf(stderr, "%s: error reading arguments for '%s'\n",
1036     progname, oname);
1037     exit(1);
1038     }
1039     switch (st) {
1040     case ST_RING:
1041     if (snew->nfargs != 8)
1042     goto badcount;
1043     VCOPY(snew->snrm, snew->farg+3);
1044     if (normalize(snew->snrm) == 0)
1045     goto badnorm;
1046     if (snew->farg[7] < snew->farg[6]) {
1047     double t = snew->farg[7];
1048     snew->farg[7] = snew->farg[6];
1049     snew->farg[6] = t;
1050     }
1051     snew->area = PI*(snew->farg[7]*snew->farg[7] -
1052     snew->farg[6]*snew->farg[6]);
1053     break;
1054     case ST_POLY:
1055     if (snew->nfargs < 9 || snew->nfargs % 3)
1056     goto badcount;
1057     finish_polygon(snew);
1058     break;
1059     case ST_SOURCE:
1060     if (snew->nfargs != 4)
1061     goto badcount;
1062 greg 2.8 for (n = 3; n--; ) /* need to reverse "normal" */
1063     snew->snrm[n] = -snew->farg[n];
1064 greg 2.1 if (normalize(snew->snrm) == 0)
1065     goto badnorm;
1066 greg 2.4 snew->area = sin((PI/180./2.)*snew->farg[3]);
1067     snew->area *= PI*snew->area;
1068 greg 2.1 break;
1069     }
1070 greg 2.52 if ((snew->area <= FTINY*FTINY) & (verbose >= 0)) {
1071 greg 2.1 fprintf(stderr, "%s: warning - zero area for surface '%s'\n",
1072     progname, oname);
1073     free(snew);
1074     return;
1075     }
1076     VSUM(curparams.nrm, curparams.nrm, snew->snrm, snew->area);
1077     snew->next = curparams.slist;
1078     curparams.slist = snew;
1079     curparams.nsurfs++;
1080     return;
1081     badcount:
1082 greg 2.7 fprintf(stderr, "%s: bad argument count for surface element '%s'\n",
1083 greg 2.1 progname, oname);
1084     exit(1);
1085     badnorm:
1086 greg 2.7 fprintf(stderr, "%s: bad orientation for surface element '%s'\n",
1087 greg 2.1 progname, oname);
1088     exit(1);
1089     }
1090
1091     /* Parse a receiver object (look for modifiers to add to rcontrib command) */
1092     static int
1093     add_recv_object(FILE *fp)
1094     {
1095     int st;
1096     char thismod[128], otype[32], oname[128];
1097     int n;
1098
1099     if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3)
1100     return(0); /* must have hit EOF! */
1101     if (!strcmp(otype, "alias")) {
1102     fscanf(fp, "%*s"); /* skip alias */
1103     return(0);
1104     }
1105     /* is it a new receiver? */
1106     if ((st = surf_type(otype)) != ST_NONE) {
1107     if (curparams.slist != NULL && (st == ST_SOURCE) ^
1108     (curparams.slist->styp == ST_SOURCE)) {
1109     fputs(progname, stderr);
1110     fputs(": cannot mix source/non-source receivers!\n", stderr);
1111     return(-1);
1112     }
1113     if (strcmp(thismod, curmod)) {
1114     if (curmod[0]) { /* output last receiver? */
1115     finish_receiver();
1116     clear_params(&curparams, 1);
1117     }
1118 greg 2.6 parse_params(&curparams, newparams);
1119     newparams[0] = '\0';
1120 greg 2.1 strcpy(curmod, thismod);
1121     }
1122     add_surface(st, oname, fp); /* read & store surface */
1123     return(1);
1124     }
1125     /* else skip arguments */
1126 greg 2.8 if (!fscanf(fp, "%d", &n)) return(0);
1127 greg 2.1 while (n-- > 0) fscanf(fp, "%*s");
1128 greg 2.10 if (!fscanf(fp, "%d", &n)) return(0);
1129 greg 2.1 while (n-- > 0) fscanf(fp, "%*d");
1130 greg 2.10 if (!fscanf(fp, "%d", &n)) return(0);
1131 greg 2.1 while (n-- > 0) fscanf(fp, "%*f");
1132     return(0);
1133     }
1134
1135     /* Parse a sender object */
1136     static int
1137     add_send_object(FILE *fp)
1138     {
1139     int st;
1140 greg 2.24 char thismod[128], otype[32], oname[128];
1141 greg 2.1 int n;
1142
1143 greg 2.25 if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3)
1144 greg 2.1 return(0); /* must have hit EOF! */
1145     if (!strcmp(otype, "alias")) {
1146     fscanf(fp, "%*s"); /* skip alias */
1147     return(0);
1148     }
1149     /* is it a new surface? */
1150     if ((st = surf_type(otype)) != ST_NONE) {
1151     if (st == ST_SOURCE) {
1152     fputs(progname, stderr);
1153     fputs(": cannot use source as a sender!\n", stderr);
1154     return(-1);
1155     }
1156 greg 2.24 if (strcmp(thismod, curmod)) {
1157     if (curmod[0]) {
1158     fputs(progname, stderr);
1159     fputs(": warning - multiple modifiers in sender\n",
1160     stderr);
1161     }
1162     strcpy(curmod, thismod);
1163     }
1164 greg 2.6 parse_params(&curparams, newparams);
1165     newparams[0] = '\0';
1166 greg 2.1 add_surface(st, oname, fp); /* read & store surface */
1167     return(0);
1168     }
1169     /* else skip arguments */
1170 greg 2.8 if (!fscanf(fp, "%d", &n)) return(0);
1171 greg 2.1 while (n-- > 0) fscanf(fp, "%*s");
1172 greg 2.10 if (!fscanf(fp, "%d", &n)) return(0);
1173 greg 2.1 while (n-- > 0) fscanf(fp, "%*d");
1174 greg 2.10 if (!fscanf(fp, "%d", &n)) return(0);
1175 greg 2.1 while (n-- > 0) fscanf(fp, "%*f");
1176     return(0);
1177     }
1178
1179     /* Load a Radiance scene using the given callback function for objects */
1180     static int
1181     load_scene(const char *inspec, int (*ocb)(FILE *))
1182     {
1183     int rv = 0;
1184     char inpbuf[1024];
1185     FILE *fp;
1186     int c;
1187
1188     if (*inspec == '!')
1189     fp = popen(inspec+1, "r");
1190     else
1191     fp = fopen(inspec, "r");
1192     if (fp == NULL) {
1193     fprintf(stderr, "%s: cannot load '%s'\n", progname, inspec);
1194     return(-1);
1195     }
1196     while ((c = getc(fp)) != EOF) { /* load receiver data */
1197     if (isspace(c)) /* skip leading white space */
1198     continue;
1199     if (c == '!') { /* read from a new command */
1200     inpbuf[0] = c;
1201     if (fgetline(inpbuf+1, sizeof(inpbuf)-1, fp) != NULL) {
1202     if ((c = load_scene(inpbuf, ocb)) < 0)
1203     return(c);
1204     rv += c;
1205     }
1206     continue;
1207     }
1208     if (c == '#') { /* parameters/comment */
1209 greg 2.5 if ((c = getc(fp)) == EOF || ungetc(c,fp) == EOF)
1210     break;
1211     if (!isspace(c) && fscanf(fp, "%s", inpbuf) == 1 &&
1212 greg 2.1 !strcmp(inpbuf, PARAMSTART)) {
1213     if (fgets(inpbuf, sizeof(inpbuf), fp) != NULL)
1214 greg 2.6 strcat(newparams, inpbuf);
1215 greg 2.1 continue;
1216     }
1217 greg 2.10 while ((c = getc(fp)) != EOF && c != '\n')
1218 greg 2.1 ; /* else skipping comment */
1219     continue;
1220     }
1221     ungetc(c, fp); /* else check object for receiver */
1222     c = (*ocb)(fp);
1223     if (c < 0)
1224     return(c);
1225     rv += c;
1226     }
1227     /* close our input stream */
1228     c = (*inspec == '!') ? pclose(fp) : fclose(fp);
1229     if (c != 0) {
1230     fprintf(stderr, "%s: error loading '%s'\n", progname, inspec);
1231     return(-1);
1232     }
1233     return(rv);
1234     }
1235
1236     /* Get command arguments and run program */
1237     int
1238     main(int argc, char *argv[])
1239     {
1240     char fmtopt[6] = "-faa"; /* default output is ASCII */
1241 greg 2.4 char *xrs=NULL, *yrs=NULL, *ldopt=NULL;
1242 greg 2.11 char *iropt = NULL;
1243 greg 2.1 char *sendfn;
1244     char sampcntbuf[32], nsbinbuf[32];
1245     FILE *rcfp;
1246     int nsbins;
1247     int a, i;
1248     /* screen rcontrib options */
1249     progname = argv[0];
1250 greg 2.14 for (a = 1; a < argc-2; a++) {
1251     int na;
1252     /* check for argument expansion */
1253     while ((na = expandarg(&argc, &argv, a)) > 0)
1254     ;
1255     if (na < 0) {
1256     fprintf(stderr, "%s: cannot expand '%s'\n",
1257     progname, argv[a]);
1258     return(1);
1259     }
1260     if (argv[a][0] != '-' || !argv[a][1])
1261     break;
1262     na = 1;
1263     switch (argv[a][1]) { /* !! Keep consistent !! */
1264 greg 2.1 case 'v': /* verbose mode */
1265 greg 2.16 verbose = 1;
1266 greg 2.1 na = 0;
1267     continue;
1268     case 'f': /* special case for -fo, -ff, etc. */
1269     switch (argv[a][2]) {
1270     case '\0': /* cal file */
1271     goto userr;
1272     case 'o': /* force output */
1273     goto userr;
1274     case 'a': /* output format */
1275     case 'f':
1276     case 'd':
1277     case 'c':
1278 greg 2.6 if (!(fmtopt[3] = argv[a][3]))
1279     fmtopt[3] = argv[a][2];
1280     fmtopt[2] = argv[a][2];
1281 greg 2.1 na = 0;
1282     continue; /* will pass later */
1283     default:
1284     goto userr;
1285     }
1286     break;
1287 greg 2.4 case 'x': /* x-resolution */
1288     xrs = argv[++a];
1289     na = 0;
1290     continue;
1291     case 'y': /* y-resolution */
1292     yrs = argv[++a];
1293     na = 0;
1294     continue;
1295 greg 2.55 case 'c': /* spectral sampling or count */
1296     switch (argv[a][2]) {
1297     case 's':
1298     na = 2;
1299     break;
1300     case 'w':
1301     na = 3;
1302     break;
1303     case '\0':
1304     sampcnt = atoi(argv[++a]);
1305     if (sampcnt <= 0)
1306     goto userr;
1307     na = 0; /* we re-add this later */
1308 greg 2.57 continue;
1309 greg 2.55 }
1310 greg 2.57 break;
1311 greg 2.8 case 'I': /* only for pass-through mode */
1312 greg 2.11 case 'i':
1313     iropt = argv[a];
1314 greg 2.8 na = 0;
1315     continue;
1316 greg 2.16 case 'w': /* options without arguments */
1317 greg 2.49 if (!argv[a][2] || strchr("+1tTyY", argv[a][2]) == NULL)
1318     verbose = -1;
1319     break;
1320 greg 2.16 case 'V':
1321 greg 2.1 case 'u':
1322     case 'h':
1323 greg 2.4 case 'r':
1324 greg 2.1 break;
1325     case 'n': /* options with 1 argument */
1326     case 's':
1327     case 'o':
1328 greg 2.53 case 't':
1329 greg 2.1 na = 2;
1330     break;
1331     case 'b': /* special case */
1332     if (argv[a][2] != 'v') goto userr;
1333     break;
1334     case 'l': /* special case */
1335 greg 2.4 if (argv[a][2] == 'd') {
1336     ldopt = argv[a];
1337     na = 0;
1338     continue;
1339     }
1340 greg 2.1 na = 2;
1341     break;
1342     case 'd': /* special case */
1343     if (argv[a][2] != 'v') na = 2;
1344     break;
1345     case 'a': /* special case */
1346 greg 2.28 if (argv[a][2] == 'p') {
1347     na = 2; /* photon map [+ bandwidth(s)] */
1348     if (a < argc-3 && atoi(argv[a+1]) > 0)
1349     na += 1 + (a < argc-4 && atoi(argv[a+2]) > 0);
1350     } else
1351     na = (argv[a][2] == 'v') ? 4 : 2;
1352 greg 2.1 break;
1353     case 'm': /* special case */
1354     if (!argv[a][2]) goto userr;
1355     na = (argv[a][2] == 'e') | (argv[a][2] == 'a') ? 4 : 2;
1356     break;
1357     default: /* anything else is verbotten */
1358     goto userr;
1359     }
1360     if (na <= 0) continue;
1361     CHECKARGC(na); /* pass on option */
1362     rcarg[nrcargs++] = argv[a];
1363     while (--na) /* + arguments if any */
1364     rcarg[nrcargs++] = argv[++a];
1365     }
1366     if (a > argc-2)
1367     goto userr; /* check at end of options */
1368     sendfn = argv[a++]; /* assign sender & receiver inputs */
1369     if (sendfn[0] == '-') { /* user wants pass-through mode? */
1370     if (sendfn[1]) goto userr;
1371     sendfn = NULL;
1372 greg 2.11 if (iropt) {
1373 greg 2.8 CHECKARGC(1);
1374 greg 2.11 rcarg[nrcargs++] = iropt;
1375 greg 2.8 }
1376 greg 2.4 if (xrs) {
1377     CHECKARGC(2);
1378     rcarg[nrcargs++] = "-x";
1379     rcarg[nrcargs++] = xrs;
1380     }
1381     if (yrs) {
1382     CHECKARGC(2);
1383     rcarg[nrcargs++] = "-y";
1384     rcarg[nrcargs++] = yrs;
1385     }
1386     if (ldopt) {
1387     CHECKARGC(1);
1388     rcarg[nrcargs++] = ldopt;
1389     }
1390 greg 2.1 if (sampcnt <= 0) sampcnt = 1;
1391 greg 2.8 } else { /* else in sampling mode */
1392 greg 2.11 if (iropt) {
1393 greg 2.8 fputs(progname, stderr);
1394 greg 2.11 fputs(": -i, -I supported for pass-through only\n", stderr);
1395 greg 2.8 return(1);
1396     }
1397 greg 2.42 #ifdef SMLFLT
1398     fmtopt[2] = 'f';
1399     #else
1400     fmtopt[2] = 'd';
1401     #endif
1402 greg 2.1 if (sampcnt <= 0) sampcnt = 10000;
1403     }
1404     sprintf(sampcntbuf, "%d", sampcnt);
1405     CHECKARGC(3); /* add our format & sample count */
1406     rcarg[nrcargs++] = fmtopt;
1407     rcarg[nrcargs++] = "-c";
1408     rcarg[nrcargs++] = sampcntbuf;
1409     /* add receiver arguments to rcontrib */
1410     if (load_scene(argv[a], add_recv_object) < 0)
1411     return(1);
1412     finish_receiver();
1413     if (sendfn == NULL) { /* pass-through mode? */
1414     CHECKARGC(1); /* add octree */
1415     rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1416     rcarg[nrcargs] = NULL;
1417     return(my_exec(rcarg)); /* rcontrib does everything */
1418     }
1419     clear_params(&curparams, 0); /* else load sender surface & params */
1420 greg 2.24 curmod[0] = '\0';
1421 greg 2.1 if (load_scene(sendfn, add_send_object) < 0)
1422     return(1);
1423     if ((nsbins = prepare_sampler()) <= 0)
1424     return(1);
1425     CHECKARGC(3); /* add row count and octree */
1426     rcarg[nrcargs++] = "-y";
1427     sprintf(nsbinbuf, "%d", nsbins);
1428     rcarg[nrcargs++] = nsbinbuf;
1429     rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1430     rcarg[nrcargs] = NULL;
1431     /* open pipe to rcontrib process */
1432     if ((rcfp = popen_arglist(rcarg, "w")) == NULL)
1433     return(1);
1434     SET_FILE_BINARY(rcfp);
1435     #ifdef getc_unlocked
1436     flockfile(rcfp);
1437     #endif
1438 greg 2.22 if (verbose > 0) {
1439 greg 2.1 fprintf(stderr, "%s: sampling %d directions", progname, nsbins);
1440     if (curparams.nsurfs > 1)
1441 greg 2.7 fprintf(stderr, " (%d elements)\n", curparams.nsurfs);
1442 greg 2.1 else
1443     fputc('\n', stderr);
1444     }
1445     for (i = 0; i < nsbins; i++) /* send rcontrib ray samples */
1446     if (!(*curparams.sample_basis)(&curparams, i, rcfp))
1447     return(1);
1448 greg 2.51 return(pclose_al(rcfp) < 0); /* all finished! */
1449 greg 2.1 userr:
1450     if (a < argc-2)
1451     fprintf(stderr, "%s: unsupported option '%s'", progname, argv[a]);
1452 greg 2.13 fprintf(stderr, "Usage: %s [-v][rcontrib options] sender.rad receiver.rad [-i system.oct] [system.rad ..]\n",
1453 greg 2.1 progname);
1454     return(1);
1455     }
