root/radiance/ray/src/util/rfluxmtx.c
Revision: 2.60
Committed: Tue Jun 3 21:31:51 2025 UTC (3 days, 22 hours ago) by greg
Changes since 2.59: +3 -4 lines
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.60 static const char RCSid[] = "$Id: rfluxmtx.c,v 2.59 2025/04/04 01:08:33 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Calculate flux transfer matrix or matrices using rcontrib
6     */
7
8     #include "copyright.h"
9
10     #include <ctype.h>
11     #include <stdlib.h>
12     #include "rtio.h"
13     #include "rtmath.h"
14 greg 2.51 #include "rtprocess.h"
15 greg 2.1 #include "bsdf.h"
16     #include "bsdf_m.h"
17     #include "random.h"
18     #include "triangulate.h"
19     #include "platform.h"
20
21 greg 2.46 #ifndef MAXRCARG
22     #define MAXRCARG 10000
23     #endif
24 greg 2.1
25 greg 2.16 int verbose = 0; /* verbose mode (< 0 no warnings) */
26 greg 2.1
27     char *rcarg[MAXRCARG+1] = {"rcontrib", "-fo+"};
28     int nrcargs = 2;
29
30     const char overflowerr[] = "%s: too many arguments!\n";
31
32     #define CHECKARGC(n) if (nrcargs >= MAXRCARG-(n)) \
33     { fprintf(stderr, overflowerr, progname); exit(1); }
34
35 greg 2.2 int sampcnt = 0; /* sample count (0==unset) */
36 greg 2.1
37 greg 2.2 char *reinhfn = "reinhartb.cal";
38     char *shirchiufn = "disk2square.cal";
39 greg 2.1 char *kfullfn = "klems_full.cal";
40     char *khalffn = "klems_half.cal";
41     char *kquarterfn = "klems_quarter.cal";
42 greg 2.56 char *ciefn = "cieskyscan.cal";
43 greg 2.1
44 greg 2.5 /* string indicating parameters */
45     const char PARAMSTART[] = "@rfluxmtx";
46 greg 2.1
47     /* surface type IDs */
48     #define ST_NONE 0
49     #define ST_POLY 1
50     #define ST_RING 2
51     #define ST_SOURCE 3
52
53     typedef struct surf_s {
54     struct surf_s *next; /* next surface in list */
55     void *priv; /* private data (malloc'ed) */
56     char sname[32]; /* surface name */
57     FVECT snrm; /* surface normal */
58 greg 2.4 double area; /* surface area / proj. solid angle */
59 greg 2.1 short styp; /* surface type */
60 greg 2.2 short nfargs; /* number of real arguments */
61     double farg[1]; /* real values (extends struct) */
62 greg 2.1 } SURF; /* surface structure */
63
64     typedef struct {
65     FVECT uva[2]; /* tangent axes */
66     int ntris; /* number of triangles */
67     struct ptri {
68 greg 2.41 double afrac; /* fraction of total area */
69 greg 2.1 short vndx[3]; /* vertex indices */
70     } tri[1]; /* triangle array (extends struct) */
71     } POLYTRIS; /* triangulated polygon */
72
73     typedef struct param_s {
74 greg 2.26 char sign; /* '-' for axis reversal */
75     char hemis[31]; /* hemispherical sampling spec. */
76 greg 2.1 int hsiz; /* hemisphere basis size */
77     int nsurfs; /* number of surfaces */
78     SURF *slist; /* list of surfaces */
79     FVECT vup; /* up vector (zero if unset) */
80     FVECT nrm; /* average normal direction */
81 greg 2.26 FVECT udir, vdir; /* tangent axes */
82 greg 2.1 char *outfn; /* output file name (receiver) */
83     int (*sample_basis)(struct param_s *p, int, FILE *);
84     } PARAMS; /* sender/receiver parameters */
85
86     PARAMS curparams;
87     char curmod[128];
88 greg 2.6 char newparams[1024];
89 greg 2.1
90     typedef int SURFSAMP(FVECT, SURF *, double);
91
92     static SURFSAMP ssamp_bad, ssamp_poly, ssamp_ring;
93
94     SURFSAMP *orig_in_surf[4] = {
95     ssamp_bad, ssamp_poly, ssamp_ring, ssamp_bad
96     };
97
98     /* Clear parameter set */
99     static void
100     clear_params(PARAMS *p, int reset_only)
101     {
102     while (p->slist != NULL) {
103     SURF *sdel = p->slist;
104     p->slist = sdel->next;
105     if (sdel->priv != NULL)
106     free(sdel->priv);
107     free(sdel);
108     }
109     if (reset_only) {
110     p->nsurfs = 0;
111     memset(p->nrm, 0, sizeof(FVECT));
112     memset(p->vup, 0, sizeof(FVECT));
113     p->outfn = NULL;
114     return;
115     }
116 greg 2.6 memset(p, 0, sizeof(PARAMS));
117 greg 2.1 }
118
119     /* Get surface type from name */
120     static int
121     surf_type(const char *otype)
122     {
123     if (!strcmp(otype, "polygon"))
124     return(ST_POLY);
125     if (!strcmp(otype, "ring"))
126     return(ST_RING);
127     if (!strcmp(otype, "source"))
128     return(ST_SOURCE);
129     return(ST_NONE);
130     }
131
132     /* Add arguments to oconv command */
133     static char *
134     oconv_command(int ac, char *av[])
135     {
136 greg 2.13 static char oconvbuf[2048] = "!oconv -f ";
137     char *cp = oconvbuf + 10;
138     char *recv = *av++;
139
140     if (ac-- <= 0)
141     return(NULL);
142 greg 2.43 if (verbose < 0) { /* turn off warnings */
143 greg 2.49 strcpy(cp, "-w ");
144 greg 2.50 cp += 3;
145 greg 2.43 }
146 greg 2.48 while (ac-- > 0) { /* copy each argument */
147     int len = strlen(*av);
148     if (cp+len+4 >= oconvbuf+sizeof(oconvbuf))
149     goto overrun;
150     if (matchany(*av, SPECIALS)) {
151     *cp++ = QUOTCHAR;
152     strcpy(cp, *av++);
153     cp += len;
154     *cp++ = QUOTCHAR;
155     } else {
156     strcpy(cp, *av++);
157     cp += len;
158     }
159 greg 2.13 *cp++ = ' ';
160 greg 2.30 }
161     /* receiver goes last */
162     if (matchany(recv, SPECIALS)) {
163     *cp++ = QUOTCHAR;
164     while (*recv) {
165     if (cp >= oconvbuf+(sizeof(oconvbuf)-3))
166     goto overrun;
167     *cp++ = *recv++;
168 greg 2.1 }
169 greg 2.30 *cp++ = QUOTCHAR;
170     *cp = '\0';
171     } else
172     strcpy(cp, recv);
173 greg 2.1 return(oconvbuf);
174 greg 2.30 overrun:
175     fputs(progname, stderr);
176     fputs(": too many file arguments!\n", stderr);
177     exit(1);
178 greg 2.1 }
179
180 greg 2.51 #if defined(_WIN32) || defined(_WIN64)
181
182 greg 2.1 /* Open a pipe to/from a command given as an argument list */
183     static FILE *
184     popen_arglist(char *av[], char *mode)
185     {
186     char cmd[10240];
187
188     if (!convert_commandline(cmd, sizeof(cmd), av)) {
189     fputs(progname, stderr);
190     fputs(": command line too long in popen_arglist()\n", stderr);
191     return(NULL);
192     }
193 greg 2.16 if (verbose > 0)
194 greg 2.1 fprintf(stderr, "%s: opening pipe %s: %s\n",
195     progname, (*mode=='w') ? "to" : "from", cmd);
196     return(popen(cmd, mode));
197     }
198
199 greg 2.51 #define pclose_al pclose
200
201 greg 2.1 /* Execute system command (Windows version) */
202     static int
203     my_exec(char *av[])
204     {
205     char cmd[10240];
206
207     if (!convert_commandline(cmd, sizeof(cmd), av)) {
208     fputs(progname, stderr);
209     fputs(": command line too long in my_exec()\n", stderr);
210     return(1);
211     }
212 greg 2.16 if (verbose > 0)
213 greg 2.1 fprintf(stderr, "%s: running: %s\n", progname, cmd);
214     return(system(cmd));
215     }
216 greg 2.51
217     #else /* UNIX */
218
219     static SUBPROC rt_proc = SP_INACTIVE; /* we only support one of these */
220
221     /* Open a pipe to a command using an argument list */
222     static FILE *
223     popen_arglist(char *av[], char *mode)
224     {
225     int fd;
226
227     if (rt_proc.pid > 0) {
228     fprintf(stderr, "%s: only one i/o pipe at a time!\n", progname);
229     return(NULL);
230     }
231     if (verbose > 0) {
232     char cmd[4096];
233     if (!convert_commandline(cmd, sizeof(cmd), av))
234     strcpy(cmd, "COMMAND TOO LONG TO SHOW");
235     fprintf(stderr, "%s: opening pipe %s: %s\n",
236     progname, (*mode=='w') ? "to" : "from", cmd);
237     }
238     if (*mode == 'w') {
239     fd = rt_proc.w = dup(fileno(stdout));
240     rt_proc.flags |= PF_FILT_OUT;
241     } else if (*mode == 'r') {
242     fd = rt_proc.r = dup(fileno(stdin));
243     rt_proc.flags |= PF_FILT_INP;
244     }
245     if (fd < 0 || open_process(&rt_proc, av) <= 0) {
246     perror(av[0]);
247     return(NULL);
248     }
249     return(fdopen(fd, mode));
250     }
251
252     /* Close command pipe (returns -1 on error to match pclose) */
253     static int
254     pclose_al(FILE *fp)
255     {
256     int prob = (fclose(fp) == EOF);
257
258     if (rt_proc.pid <= 0)
259     return(-1);
260
261     prob |= (close_process(&rt_proc) != 0);
262
263     return(-prob);
264     }
265
266 greg 2.1 /* Execute system command in our stead (Unix version) */
267     static int
268     my_exec(char *av[])
269     {
270     char *compath;
271
272     if ((compath = getpath((char *)av[0], getenv("PATH"), X_OK)) == NULL) {
273     fprintf(stderr, "%s: cannot locate %s\n", progname, av[0]);
274     return(1);
275     }
276 greg 2.16 if (verbose > 0) {
277 greg 2.1 char cmd[4096];
278     if (!convert_commandline(cmd, sizeof(cmd), av))
279     strcpy(cmd, "COMMAND TOO LONG TO SHOW");
280     fprintf(stderr, "%s: running: %s\n", progname, cmd);
281     }
282     execv(compath, av); /* successful call never returns */
283     perror(compath);
284     return(1);
285     }
286 greg 2.51
287 greg 2.1 #endif
288
289     /* Get normalized direction vector from string specification */
290     static int
291     get_direction(FVECT dv, const char *s)
292     {
293     int sign = 1;
294     int axis = 0;
295
296     memset(dv, 0, sizeof(FVECT));
297     nextchar:
298     switch (*s) {
299     case '+':
300     ++s;
301     goto nextchar;
302     case '-':
303     sign = -sign;
304     ++s;
305     goto nextchar;
306     case 'z':
307     case 'Z':
308     ++axis;
309     case 'y':
310     case 'Y':
311     ++axis;
312     case 'x':
313     case 'X':
314     dv[axis] = sign;
315     return(!s[1] | isspace(s[1]));
316     default:
317     break;
318     }
319     #ifdef SMLFLT
320     if (sscanf(s, "%f,%f,%f", &dv[0], &dv[1], &dv[2]) != 3)
321     #else
322     if (sscanf(s, "%lf,%lf,%lf", &dv[0], &dv[1], &dv[2]) != 3)
323     #endif
324     return(0);
325     dv[0] *= (RREAL)sign;
326     return(normalize(dv) > 0);
327     }
328
329     /* Parse program parameters (directives) */
330     static int
331 greg 2.6 parse_params(PARAMS *p, char *pargs)
332 greg 2.1 {
333     char *cp = pargs;
334     int nparams = 0;
335 greg 2.32 int quot;
336 greg 2.1 int i;
337
338 greg 2.15 for ( ; ; ) {
339 greg 2.1 switch (*cp++) {
340     case 'h':
341     if (*cp++ != '=')
342     break;
343 greg 2.26 if ((*cp == '+') | (*cp == '-'))
344     p->sign = *cp++;
345     else
346     p->sign = '+';
347 greg 2.6 p->hsiz = 0;
348 greg 2.1 i = 0;
349     while (*cp && !isspace(*cp)) {
350     if (isdigit(*cp))
351 greg 2.6 p->hsiz = 10*p->hsiz + *cp - '0';
352     p->hemis[i++] = *cp++;
353 greg 2.1 }
354     if (!i)
355     break;
356 greg 2.6 p->hemis[i] = '\0';
357     p->hsiz += !p->hsiz;
358 greg 2.1 ++nparams;
359     continue;
360     case 'u':
361     if (*cp++ != '=')
362     break;
363 greg 2.6 if (!get_direction(p->vup, cp))
364 greg 2.1 break;
365 greg 2.15 while (*cp && !isspace(*cp++))
366     ;
367 greg 2.1 ++nparams;
368     continue;
369     case 'o':
370     if (*cp++ != '=')
371     break;
372 greg 2.32 quot = 0;
373     if ((*cp == '"') | (*cp == '\''))
374     quot = *cp++;
375 greg 2.1 i = 0;
376 greg 2.32 while (*cp && (quot ? (*cp != quot) : !isspace(*cp))) {
377     i++; cp++;
378     }
379 greg 2.1 if (!i)
380     break;
381 greg 2.32 if (!*cp) {
382     if (quot)
383     break;
384     cp[1] = '\0';
385     }
386     *cp = '\0';
387 greg 2.6 p->outfn = savqstr(cp-i);
388 greg 2.32 *cp++ = quot ? quot : ' ';
389 greg 2.1 ++nparams;
390     continue;
391     case ' ':
392     case '\t':
393     case '\r':
394 greg 2.21 case '\n':
395 greg 2.15 continue;
396 greg 2.1 case '\0':
397     return(nparams);
398     default:
399     break;
400     }
401 greg 2.15 break;
402     }
403     fprintf(stderr, "%s: bad parameter string: %s", progname, pargs);
404 greg 2.1 exit(1);
405     return(-1); /* pro forma return */
406     }
407
408     /* Add receiver arguments (directives) corresponding to the current modifier */
409     static void
410     finish_receiver(void)
411     {
412 greg 2.4 char sbuf[256];
413     int uniform = 0;
414 greg 2.2 char *calfn = NULL;
415 greg 2.3 char *params = NULL;
416 greg 2.2 char *binv = NULL;
417     char *binf = NULL;
418     char *nbins = NULL;
419 greg 2.1
420     if (!curmod[0]) {
421     fputs(progname, stderr);
422     fputs(": missing receiver surface!\n", stderr);
423     exit(1);
424     }
425     if (curparams.outfn != NULL) { /* add output file spec. */
426     CHECKARGC(2);
427     rcarg[nrcargs++] = "-o";
428     rcarg[nrcargs++] = curparams.outfn;
429     }
430 greg 2.4 /* check arguments */
431 greg 2.1 if (!curparams.hemis[0]) {
432     fputs(progname, stderr);
433     fputs(": missing hemisphere sampling type!\n", stderr);
434     exit(1);
435     }
436     if (normalize(curparams.nrm) == 0) {
437     fputs(progname, stderr);
438     fputs(": undefined normal for hemisphere sampling\n", stderr);
439     exit(1);
440     }
441 greg 2.10 if (normalize(curparams.vup) == 0) {
442 greg 2.1 if (fabs(curparams.nrm[2]) < .7)
443     curparams.vup[2] = 1;
444     else
445     curparams.vup[1] = 1;
446 greg 2.10 }
447 greg 2.4 /* determine sample type/bin */
448 greg 2.44 if ((tolower(curparams.hemis[0]) == 'u') | (curparams.hemis[0] == '1')) {
449 greg 2.20 sprintf(sbuf, "if(-Dx*%g-Dy*%g-Dz*%g,0,-1)",
450     curparams.nrm[0], curparams.nrm[1], curparams.nrm[2]);
451     binv = savqstr(sbuf);
452     nbins = "1"; /* uniform sampling -- one bin */
453 greg 2.4 uniform = 1;
454 greg 2.1 } else if (tolower(curparams.hemis[0]) == 's' &&
455     tolower(curparams.hemis[1]) == 'c') {
456 greg 2.2 /* assign parameters */
457 greg 2.1 if (curparams.hsiz <= 1) {
458     fputs(progname, stderr);
459     fputs(": missing size for Shirley-Chiu sampling!\n", stderr);
460     exit(1);
461     }
462 greg 2.3 calfn = shirchiufn; shirchiufn = NULL;
463 greg 2.26 sprintf(sbuf, "SCdim=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1",
464 greg 2.2 curparams.hsiz,
465     curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
466 greg 2.26 curparams.vup[0], curparams.vup[1], curparams.vup[2],
467     curparams.sign);
468 greg 2.3 params = savqstr(sbuf);
469 greg 2.2 binv = "scbin";
470     nbins = "SCdim*SCdim";
471 greg 2.1 } else if ((tolower(curparams.hemis[0]) == 'r') |
472     (tolower(curparams.hemis[0]) == 't')) {
473 greg 2.2 calfn = reinhfn; reinhfn = NULL;
474 greg 2.26 sprintf(sbuf, "MF=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1",
475 greg 2.3 curparams.hsiz,
476     curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
477 greg 2.26 curparams.vup[0], curparams.vup[1], curparams.vup[2],
478     curparams.sign);
479 greg 2.3 params = savqstr(sbuf);
480     binv = "rbin";
481     nbins = "Nrbins";
482 greg 2.1 } else if (tolower(curparams.hemis[0]) == 'k' &&
483     !curparams.hemis[1] |
484     (tolower(curparams.hemis[1]) == 'f') |
485     (curparams.hemis[1] == '1')) {
486 greg 2.2 calfn = kfullfn; kfullfn = NULL;
487     binf = "kbin";
488     nbins = "Nkbins";
489 greg 2.1 } else if (tolower(curparams.hemis[0]) == 'k' &&
490     (tolower(curparams.hemis[1]) == 'h') |
491     (curparams.hemis[1] == '2')) {
492 greg 2.2 calfn = khalffn; khalffn = NULL;
493     binf = "khbin";
494     nbins = "Nkhbins";
495 greg 2.1 } else if (tolower(curparams.hemis[0]) == 'k' &&
496     (tolower(curparams.hemis[1]) == 'q') |
497     (curparams.hemis[1] == '4')) {
498 greg 2.2 calfn = kquarterfn; kquarterfn = NULL;
499     binf = "kqbin";
500     nbins = "Nkqbins";
501 greg 2.56 } else if (!strcasecmp(curparams.hemis, "cie")) {
502     calfn = ciefn; ciefn = NULL;
503     sprintf(sbuf, "rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1",
504     curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
505     curparams.vup[0], curparams.vup[1], curparams.vup[2],
506     curparams.sign);
507     binv = "cbin";
508     nbins = "Ncbins";
509 greg 2.1 } else {
510     fprintf(stderr, "%s: unrecognized hemisphere sampling: h=%s\n",
511     progname, curparams.hemis);
512     exit(1);
513     }
514 greg 2.26 if (tolower(curparams.hemis[0]) == 'k') {
515     sprintf(sbuf, "RHS=%c1", curparams.sign);
516     params = savqstr(sbuf);
517     }
518 greg 2.59 if (!uniform) {
519 greg 2.4 SURF *sp;
520     for (sp = curparams.slist; sp != NULL; sp = sp->next)
521 greg 2.59 if (sp->styp == ST_SOURCE && fabs(sp->area - PI) > 1e-3) {
522 greg 2.4 fprintf(stderr, "%s: source '%s' must be 180-degrees\n",
523     progname, sp->sname);
524     exit(1);
525     }
526     }
527 greg 2.2 if (calfn != NULL) { /* add cal file if needed */
528     CHECKARGC(2);
529     rcarg[nrcargs++] = "-f";
530     rcarg[nrcargs++] = calfn;
531     }
532 greg 2.3 if (params != NULL) { /* parameters _after_ cal file */
533     CHECKARGC(2);
534     rcarg[nrcargs++] = "-p";
535     rcarg[nrcargs++] = params;
536     }
537 greg 2.2 if (nbins != NULL) { /* add #bins if set */
538     CHECKARGC(2);
539     rcarg[nrcargs++] = "-bn";
540     rcarg[nrcargs++] = nbins;
541     }
542 greg 2.3 if (binv != NULL) {
543 greg 2.2 CHECKARGC(2); /* assign bin variable */
544     rcarg[nrcargs++] = "-b";
545     rcarg[nrcargs++] = binv;
546     } else if (binf != NULL) {
547     CHECKARGC(2); /* assign bin function */
548 greg 2.3 rcarg[nrcargs++] = "-b";
549 greg 2.2 sprintf(sbuf, "%s(%g,%g,%g,%g,%g,%g)", binf,
550     curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
551     curparams.vup[0], curparams.vup[1], curparams.vup[2]);
552     rcarg[nrcargs++] = savqstr(sbuf);
553     }
554     CHECKARGC(2); /* modifier argument goes last */
555 greg 2.1 rcarg[nrcargs++] = "-m";
556     rcarg[nrcargs++] = savqstr(curmod);
557     }
558
559     /* Make randomly oriented tangent plane axes for given normal direction */
560     static void
561     make_axes(FVECT uva[2], const FVECT nrm)
562     {
563     int i;
564
565 greg 2.29 if (!getperpendicular(uva[0], nrm, 1)) {
566 greg 2.1 fputs(progname, stderr);
567     fputs(": bad surface normal in make_axes!\n", stderr);
568     exit(1);
569     }
570 greg 2.19 fcross(uva[1], nrm, uva[0]);
571 greg 2.1 }
572
573     /* Illegal sender surfaces end up here */
574     static int
575     ssamp_bad(FVECT orig, SURF *sp, double x)
576     {
577     fprintf(stderr, "%s: illegal sender surface '%s'\n",
578     progname, sp->sname);
579     return(0);
580     }
581
582     /* Generate origin on ring surface from uniform random variable */
583     static int
584     ssamp_ring(FVECT orig, SURF *sp, double x)
585     {
586     FVECT *uva = (FVECT *)sp->priv;
587     double samp2[2];
588     double uv[2];
589     int i;
590
591     if (uva == NULL) { /* need tangent axes */
592     uva = (FVECT *)malloc(sizeof(FVECT)*2);
593     if (uva == NULL) {
594     fputs(progname, stderr);
595     fputs(": out of memory in ssamp_ring!\n", stderr);
596     return(0);
597     }
598     make_axes(uva, sp->snrm);
599     sp->priv = (void *)uva;
600     }
601     SDmultiSamp(samp2, 2, x);
602 greg 2.6 samp2[0] = sqrt(samp2[0]*sp->area*(1./PI) + sp->farg[6]*sp->farg[6]);
603 greg 2.1 samp2[1] *= 2.*PI;
604     uv[0] = samp2[0]*tcos(samp2[1]);
605     uv[1] = samp2[0]*tsin(samp2[1]);
606     for (i = 3; i--; )
607     orig[i] = sp->farg[i] + uv[0]*uva[0][i] + uv[1]*uva[1][i];
608     return(1);
609     }
610
611     /* Add triangle to polygon's list (call-back function) */
612     static int
613     add_triangle(const Vert2_list *tp, int a, int b, int c)
614     {
615     POLYTRIS *ptp = (POLYTRIS *)tp->p;
616     struct ptri *trip = ptp->tri + ptp->ntris++;
617
618     trip->vndx[0] = a;
619     trip->vndx[1] = b;
620     trip->vndx[2] = c;
621     return(1);
622     }
623
624     /* Generate origin on polygon surface from uniform random variable */
625     static int
626     ssamp_poly(FVECT orig, SURF *sp, double x)
627     {
628     POLYTRIS *ptp = (POLYTRIS *)sp->priv;
629     double samp2[2];
630     double *v0, *v1, *v2;
631     int i;
632
633     if (ptp == NULL) { /* need to triangulate */
634     ptp = (POLYTRIS *)malloc(sizeof(POLYTRIS) +
635 greg 2.40 sizeof(struct ptri)*(sp->nfargs/3 - 3));
636 greg 2.1 if (ptp == NULL)
637     goto memerr;
638     if (sp->nfargs == 3) { /* simple case */
639     ptp->ntris = 1;
640     ptp->tri[0].vndx[0] = 0;
641     ptp->tri[0].vndx[1] = 1;
642     ptp->tri[0].vndx[2] = 2;
643     ptp->tri[0].afrac = 1;
644     } else {
645     Vert2_list *v2l = polyAlloc(sp->nfargs/3);
646     if (v2l == NULL)
647     goto memerr;
648     make_axes(ptp->uva, sp->snrm);
649     for (i = v2l->nv; i--; ) {
650     v2l->v[i].mX = DOT(sp->farg+3*i, ptp->uva[0]);
651     v2l->v[i].mY = DOT(sp->farg+3*i, ptp->uva[1]);
652     }
653     ptp->ntris = 0;
654     v2l->p = (void *)ptp;
655 greg 2.7 if (!polyTriangulate(v2l, add_triangle)) {
656     fprintf(stderr,
657     "%s: cannot triangulate polygon '%s'\n",
658     progname, sp->sname);
659 greg 2.1 return(0);
660 greg 2.7 }
661 greg 2.1 for (i = ptp->ntris; i--; ) {
662     int a = ptp->tri[i].vndx[0];
663     int b = ptp->tri[i].vndx[1];
664     int c = ptp->tri[i].vndx[2];
665     ptp->tri[i].afrac =
666     (v2l->v[a].mX*v2l->v[b].mY -
667     v2l->v[b].mX*v2l->v[a].mY +
668     v2l->v[b].mX*v2l->v[c].mY -
669     v2l->v[c].mX*v2l->v[b].mY +
670     v2l->v[c].mX*v2l->v[a].mY -
671     v2l->v[a].mX*v2l->v[c].mY) /
672     (2.*sp->area);
673     }
674     polyFree(v2l);
675     }
676     sp->priv = (void *)ptp;
677     }
678     /* pick triangle by partial area */
679 greg 2.40 for (i = 0; i < ptp->ntris-1 && x > ptp->tri[i].afrac; i++)
680 greg 2.1 x -= ptp->tri[i].afrac;
681     SDmultiSamp(samp2, 2, x/ptp->tri[i].afrac);
682     samp2[0] *= samp2[1] = sqrt(samp2[1]);
683     samp2[1] = 1. - samp2[1];
684     v0 = sp->farg + 3*ptp->tri[i].vndx[0];
685     v1 = sp->farg + 3*ptp->tri[i].vndx[1];
686     v2 = sp->farg + 3*ptp->tri[i].vndx[2];
687     for (i = 3; i--; )
688     orig[i] = v0[i] + samp2[0]*(v1[i] - v0[i])
689     + samp2[1]*(v2[i] - v0[i]) ;
690     return(1);
691     memerr:
692     fputs(progname, stderr);
693     fputs(": out of memory in ssamp_poly!\n", stderr);
694     return(0);
695     }
696
697     /* Compute sample origin based on projected areas of sender subsurfaces */
698     static int
699     sample_origin(PARAMS *p, FVECT orig, const FVECT rdir, double x)
700     {
701     static double *projsa;
702     static int nall;
703     double tarea = 0;
704     int i;
705     SURF *sp;
706     /* special case for lone surface */
707     if (p->nsurfs == 1) {
708     sp = p->slist;
709 greg 2.31 if (DOT(sp->snrm, rdir) >= FTINY) {
710 greg 2.7 fprintf(stderr,
711     "%s: internal - sample behind sender '%s'\n",
712     progname, sp->sname);
713     return(0);
714     }
715 greg 2.1 return((*orig_in_surf[sp->styp])(orig, sp, x));
716     }
717     if (p->nsurfs > nall) { /* (re)allocate surface area cache */
718     if (projsa) free(projsa);
719     projsa = (double *)malloc(sizeof(double)*p->nsurfs);
720 greg 2.37 if (projsa == NULL) {
721     fputs(progname, stderr);
722     fputs(": out of memory in sample_origin!\n", stderr);
723     exit(1);
724     }
725 greg 2.1 nall = p->nsurfs;
726     }
727     /* compute projected areas */
728     for (i = 0, sp = p->slist; sp != NULL; i++, sp = sp->next) {
729     projsa[i] = -DOT(sp->snrm, rdir) * sp->area;
730 greg 2.52 tarea += projsa[i] *= (double)(projsa[i] > 0);
731 greg 2.1 }
732 greg 2.52 if (tarea < FTINY*FTINY) { /* wrong side of sender? */
733 greg 2.7 fputs(progname, stderr);
734     fputs(": internal - sample behind all sender elements!\n",
735     stderr);
736 greg 2.1 return(0);
737 greg 2.7 }
738 greg 2.1 tarea *= x; /* get surface from list */
739     for (i = 0, sp = p->slist; tarea > projsa[i]; sp = sp->next)
740     tarea -= projsa[i++];
741     return((*orig_in_surf[sp->styp])(orig, sp, tarea/projsa[i]));
742     }
743
744     /* Uniform sample generator */
745     static int
746     sample_uniform(PARAMS *p, int b, FILE *fp)
747     {
748     int n = sampcnt;
749     double samp3[3];
750 greg 2.54 FVECT duvw, orig_dir[2];
751 greg 2.1 int i;
752
753     if (fp == NULL) /* just requesting number of bins? */
754     return(1);
755
756     while (n--) { /* stratified hemisphere sampling */
757     SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
758 greg 2.54 square2disk(duvw, samp3[1], samp3[2]);
759 greg 2.1 duvw[2] = -sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
760     for (i = 3; i--; )
761     orig_dir[1][i] = duvw[0]*p->udir[i] +
762     duvw[1]*p->vdir[i] +
763     duvw[2]*p->nrm[i] ;
764     if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
765     return(0);
766 greg 2.38 if (putbinary(orig_dir, sizeof(FVECT), 2, fp) != 2)
767 greg 2.1 return(0);
768     }
769     return(1);
770     }
771
772     /* Shirly-Chiu sample generator */
773     static int
774     sample_shirchiu(PARAMS *p, int b, FILE *fp)
775     {
776     int n = sampcnt;
777     double samp3[3];
778 greg 2.54 FVECT duvw, orig_dir[2];
779 greg 2.1 int i;
780
781     if (fp == NULL) /* just requesting number of bins? */
782     return(p->hsiz*p->hsiz);
783
784     while (n--) { /* stratified sampling */
785     SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
786 greg 2.54 square2disk(duvw, (b/p->hsiz + samp3[1])/curparams.hsiz,
787 greg 2.1 (b%p->hsiz + samp3[2])/curparams.hsiz);
788     duvw[2] = sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
789     for (i = 3; i--; )
790     orig_dir[1][i] = -duvw[0]*p->udir[i] -
791     duvw[1]*p->vdir[i] -
792     duvw[2]*p->nrm[i] ;
793     if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
794     return(0);
795 greg 2.38 if (putbinary(orig_dir, sizeof(FVECT), 2, fp) != 2)
796 greg 2.1 return(0);
797     }
798     return(1);
799     }
800
801     /* Reinhart/Tregenza sample generator */
802     static int
803     sample_reinhart(PARAMS *p, int b, FILE *fp)
804     {
805     #define T_NALT 7
806     static const int tnaz[T_NALT] = {30, 30, 24, 24, 18, 12, 6};
807     const int RowMax = T_NALT*p->hsiz + 1;
808 greg 2.7 const double RAH = (.5*PI)/(RowMax-.5);
809 greg 2.1 #define rnaz(r) (r >= RowMax-1 ? 1 : p->hsiz*tnaz[r/p->hsiz])
810     int n = sampcnt;
811     int row, col;
812     double samp3[3];
813     double alt, azi;
814     double duvw[3];
815     FVECT orig_dir[2];
816     int i;
817
818     if (fp == NULL) { /* just requesting number of bins? */
819     n = 0;
820     for (row = RowMax; row--; ) n += rnaz(row);
821     return(n);
822     }
823     row = 0; /* identify row & column */
824     col = b;
825     while (col >= rnaz(row)) {
826     col -= rnaz(row);
827     ++row;
828     }
829     while (n--) { /* stratified sampling */
830     SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
831 greg 2.45 if (row >= RowMax-1) /* avoid crowding at zenith */
832     samp3[1] *= samp3[1];
833 greg 2.1 alt = (row+samp3[1])*RAH;
834     azi = (2.*PI)*(col+samp3[2]-.5)/rnaz(row);
835 greg 2.7 duvw[2] = cos(alt); /* measured from horizon */
836 greg 2.18 duvw[0] = tsin(azi)*duvw[2];
837 greg 2.45 duvw[1] = -tcos(azi)*duvw[2];
838 greg 2.1 duvw[2] = sqrt(1. - duvw[2]*duvw[2]);
839     for (i = 3; i--; )
840     orig_dir[1][i] = -duvw[0]*p->udir[i] -
841     duvw[1]*p->vdir[i] -
842     duvw[2]*p->nrm[i] ;
843     if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
844     return(0);
845 greg 2.38 if (putbinary(orig_dir, sizeof(FVECT), 2, fp) != 2)
846 greg 2.1 return(0);
847     }
848     return(1);
849     #undef rnaz
850     #undef T_NALT
851     }
852
853     /* Klems sample generator */
854     static int
855     sample_klems(PARAMS *p, int b, FILE *fp)
856     {
857     static const char bname[4][20] = {
858     "LBNL/Klems Full",
859     "LBNL/Klems Half",
860     "INTERNAL ERROR",
861     "LBNL/Klems Quarter"
862     };
863     static ANGLE_BASIS *kbasis[4];
864     const int bi = p->hemis[1] - '1';
865     int n = sampcnt;
866     double samp2[2];
867     double duvw[3];
868     FVECT orig_dir[2];
869     int i;
870
871     if (!kbasis[bi]) { /* need to get basis, first */
872     for (i = 4; i--; )
873     if (!strcasecmp(abase_list[i].name, bname[bi])) {
874     kbasis[bi] = &abase_list[i];
875     break;
876     }
877     if (i < 0) {
878     fprintf(stderr, "%s: unknown hemisphere basis '%s'\n",
879     progname, bname[bi]);
880     return(0);
881     }
882     }
883     if (fp == NULL) /* just requesting number of bins? */
884     return(kbasis[bi]->nangles);
885
886     while (n--) { /* stratified sampling */
887     SDmultiSamp(samp2, 2, (n+frandom())/sampcnt);
888 greg 2.27 if (!fo_getvec(duvw, b+samp2[1], kbasis[bi]))
889 greg 2.1 return(0);
890     for (i = 3; i--; )
891 greg 2.26 orig_dir[1][i] = -duvw[0]*p->udir[i] -
892     duvw[1]*p->vdir[i] -
893 greg 2.1 duvw[2]*p->nrm[i] ;
894     if (!sample_origin(p, orig_dir[0], orig_dir[1], samp2[0]))
895     return(0);
896 greg 2.38 if (putbinary(orig_dir, sizeof(FVECT), 2, fp) != 2)
897 greg 2.1 return(0);
898     }
899     return(1);
900     }
901
902     /* Prepare hemisphere basis sampler that will send rays to rcontrib */
903     static int
904     prepare_sampler(void)
905     {
906     if (curparams.slist == NULL) { /* missing sample surface! */
907     fputs(progname, stderr);
908     fputs(": no sender surface!\n", stderr);
909     return(-1);
910     }
911 greg 2.16 /* misplaced output file spec. */
912     if ((curparams.outfn != NULL) & (verbose >= 0))
913 greg 2.1 fprintf(stderr, "%s: warning - ignoring output file in sender ('%s')\n",
914     progname, curparams.outfn);
915     /* check/set basis hemisphere */
916     if (!curparams.hemis[0]) {
917     fputs(progname, stderr);
918     fputs(": missing sender sampling type!\n", stderr);
919     return(-1);
920     }
921     if (normalize(curparams.nrm) == 0) {
922     fputs(progname, stderr);
923     fputs(": undefined normal for sender sampling\n", stderr);
924     return(-1);
925     }
926 greg 2.10 if (normalize(curparams.vup) == 0) {
927 greg 2.1 if (fabs(curparams.nrm[2]) < .7)
928     curparams.vup[2] = 1;
929     else
930     curparams.vup[1] = 1;
931 greg 2.10 }
932 greg 2.26 fcross(curparams.udir, curparams.vup, curparams.nrm);
933 greg 2.1 if (normalize(curparams.udir) == 0) {
934     fputs(progname, stderr);
935     fputs(": up vector coincides with sender normal\n", stderr);
936     return(-1);
937     }
938 greg 2.26 fcross(curparams.vdir, curparams.nrm, curparams.udir);
939     if (curparams.sign == '-') { /* left-handed coordinate system? */
940     curparams.udir[0] *= -1.;
941     curparams.udir[1] *= -1.;
942     curparams.udir[2] *= -1.;
943     }
944 greg 2.44 if ((tolower(curparams.hemis[0]) == 'u') | (curparams.hemis[0] == '1'))
945 greg 2.1 curparams.sample_basis = sample_uniform;
946     else if (tolower(curparams.hemis[0]) == 's' &&
947     tolower(curparams.hemis[1]) == 'c')
948     curparams.sample_basis = sample_shirchiu;
949     else if ((tolower(curparams.hemis[0]) == 'r') |
950     (tolower(curparams.hemis[0]) == 't'))
951     curparams.sample_basis = sample_reinhart;
952     else if (tolower(curparams.hemis[0]) == 'k') {
953     switch (curparams.hemis[1]) {
954     case '1':
955     case '2':
956     case '4':
957     break;
958     case 'f':
959     case 'F':
960     case '\0':
961     curparams.hemis[1] = '1';
962     break;
963     case 'h':
964     case 'H':
965     curparams.hemis[1] = '2';
966     break;
967     case 'q':
968     case 'Q':
969     curparams.hemis[1] = '4';
970     break;
971     default:
972     goto unrecognized;
973     }
974     curparams.hemis[2] = '\0';
975     curparams.sample_basis = sample_klems;
976     } else
977     goto unrecognized;
978     /* return number of bins */
979     return((*curparams.sample_basis)(&curparams,0,NULL));
980     unrecognized:
981     fprintf(stderr, "%s: unrecognized sender sampling: h=%s\n",
982     progname, curparams.hemis);
983     return(-1);
984     }
985
986     /* Compute normal and area for polygon */
987     static int
988     finish_polygon(SURF *p)
989     {
990     const int nv = p->nfargs / 3;
991     FVECT e1, e2, vc;
992     int i;
993
994     memset(p->snrm, 0, sizeof(FVECT));
995     VSUB(e1, p->farg+3, p->farg);
996     for (i = 2; i < nv; i++) {
997     VSUB(e2, p->farg+3*i, p->farg);
998     VCROSS(vc, e1, e2);
999     p->snrm[0] += vc[0];
1000     p->snrm[1] += vc[1];
1001     p->snrm[2] += vc[2];
1002     VCOPY(e1, e2);
1003     }
1004     p->area = normalize(p->snrm)*0.5;
1005 greg 2.52 return(p->area > FTINY*FTINY);
1006 greg 2.1 }
1007
1008     /* Add a surface to our current parameters */
1009     static void
1010     add_surface(int st, const char *oname, FILE *fp)
1011     {
1012     SURF *snew;
1013     int n;
1014     /* get floating-point arguments */
1015     if (!fscanf(fp, "%d", &n)) return;
1016     while (n-- > 0) fscanf(fp, "%*s");
1017     if (!fscanf(fp, "%d", &n)) return;
1018     while (n-- > 0) fscanf(fp, "%*d");
1019     if (!fscanf(fp, "%d", &n) || n <= 0) return;
1020     snew = (SURF *)malloc(sizeof(SURF) + sizeof(double)*(n-1));
1021     if (snew == NULL) {
1022     fputs(progname, stderr);
1023 greg 2.37 fputs(": out of memory in add_surface!\n", stderr);
1024 greg 2.1 exit(1);
1025     }
1026     strncpy(snew->sname, oname, sizeof(snew->sname)-1);
1027     snew->sname[sizeof(snew->sname)-1] = '\0';
1028     snew->styp = st;
1029     snew->priv = NULL;
1030     snew->nfargs = n;
1031     for (n = 0; n < snew->nfargs; n++)
1032     if (fscanf(fp, "%lf", &snew->farg[n]) != 1) {
1033     fprintf(stderr, "%s: error reading arguments for '%s'\n",
1034     progname, oname);
1035     exit(1);
1036     }
1037     switch (st) {
1038     case ST_RING:
1039     if (snew->nfargs != 8)
1040     goto badcount;
1041     VCOPY(snew->snrm, snew->farg+3);
1042     if (normalize(snew->snrm) == 0)
1043     goto badnorm;
1044     if (snew->farg[7] < snew->farg[6]) {
1045     double t = snew->farg[7];
1046     snew->farg[7] = snew->farg[6];
1047     snew->farg[6] = t;
1048     }
1049     snew->area = PI*(snew->farg[7]*snew->farg[7] -
1050     snew->farg[6]*snew->farg[6]);
1051     break;
1052     case ST_POLY:
1053     if (snew->nfargs < 9 || snew->nfargs % 3)
1054     goto badcount;
1055     finish_polygon(snew);
1056     break;
1057     case ST_SOURCE:
1058     if (snew->nfargs != 4)
1059     goto badcount;
1060 greg 2.8 for (n = 3; n--; ) /* need to reverse "normal" */
1061     snew->snrm[n] = -snew->farg[n];
1062 greg 2.1 if (normalize(snew->snrm) == 0)
1063     goto badnorm;
1064 greg 2.4 snew->area = sin((PI/180./2.)*snew->farg[3]);
1065     snew->area *= PI*snew->area;
1066 greg 2.1 break;
1067     }
1068 greg 2.52 if ((snew->area <= FTINY*FTINY) & (verbose >= 0)) {
1069 greg 2.1 fprintf(stderr, "%s: warning - zero area for surface '%s'\n",
1070     progname, oname);
1071     free(snew);
1072     return;
1073     }
1074     VSUM(curparams.nrm, curparams.nrm, snew->snrm, snew->area);
1075     snew->next = curparams.slist;
1076     curparams.slist = snew;
1077     curparams.nsurfs++;
1078     return;
1079     badcount:
1080 greg 2.7 fprintf(stderr, "%s: bad argument count for surface element '%s'\n",
1081 greg 2.1 progname, oname);
1082     exit(1);
1083     badnorm:
1084 greg 2.7 fprintf(stderr, "%s: bad orientation for surface element '%s'\n",
1085 greg 2.1 progname, oname);
1086     exit(1);
1087     }
1088
1089     /* Parse a receiver object (look for modifiers to add to rcontrib command) */
1090     static int
1091     add_recv_object(FILE *fp)
1092     {
1093     int st;
1094     char thismod[128], otype[32], oname[128];
1095     int n;
1096
1097     if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3)
1098     return(0); /* must have hit EOF! */
1099     if (!strcmp(otype, "alias")) {
1100     fscanf(fp, "%*s"); /* skip alias */
1101     return(0);
1102     }
1103     /* is it a new receiver? */
1104     if ((st = surf_type(otype)) != ST_NONE) {
1105     if (strcmp(thismod, curmod)) {
1106     if (curmod[0]) { /* output last receiver? */
1107     finish_receiver();
1108     clear_params(&curparams, 1);
1109     }
1110 greg 2.6 parse_params(&curparams, newparams);
1111     newparams[0] = '\0';
1112 greg 2.1 strcpy(curmod, thismod);
1113     }
1114     add_surface(st, oname, fp); /* read & store surface */
1115     return(1);
1116     }
1117     /* else skip arguments */
1118 greg 2.8 if (!fscanf(fp, "%d", &n)) return(0);
1119 greg 2.1 while (n-- > 0) fscanf(fp, "%*s");
1120 greg 2.10 if (!fscanf(fp, "%d", &n)) return(0);
1121 greg 2.1 while (n-- > 0) fscanf(fp, "%*d");
1122 greg 2.10 if (!fscanf(fp, "%d", &n)) return(0);
1123 greg 2.1 while (n-- > 0) fscanf(fp, "%*f");
1124     return(0);
1125     }
1126
1127     /* Parse a sender object */
1128     static int
1129     add_send_object(FILE *fp)
1130     {
1131     int st;
1132 greg 2.24 char thismod[128], otype[32], oname[128];
1133 greg 2.1 int n;
1134
1135 greg 2.25 if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3)
1136 greg 2.1 return(0); /* must have hit EOF! */
1137     if (!strcmp(otype, "alias")) {
1138     fscanf(fp, "%*s"); /* skip alias */
1139     return(0);
1140     }
1141     /* is it a new surface? */
1142     if ((st = surf_type(otype)) != ST_NONE) {
1143     if (st == ST_SOURCE) {
1144     fputs(progname, stderr);
1145     fputs(": cannot use source as a sender!\n", stderr);
1146     return(-1);
1147     }
1148 greg 2.24 if (strcmp(thismod, curmod)) {
1149     if (curmod[0]) {
1150     fputs(progname, stderr);
1151     fputs(": warning - multiple modifiers in sender\n",
1152     stderr);
1153     }
1154     strcpy(curmod, thismod);
1155     }
1156 greg 2.6 parse_params(&curparams, newparams);
1157     newparams[0] = '\0';
1158 greg 2.1 add_surface(st, oname, fp); /* read & store surface */
1159     return(0);
1160     }
1161     /* else skip arguments */
1162 greg 2.8 if (!fscanf(fp, "%d", &n)) return(0);
1163 greg 2.1 while (n-- > 0) fscanf(fp, "%*s");
1164 greg 2.10 if (!fscanf(fp, "%d", &n)) return(0);
1165 greg 2.1 while (n-- > 0) fscanf(fp, "%*d");
1166 greg 2.10 if (!fscanf(fp, "%d", &n)) return(0);
1167 greg 2.1 while (n-- > 0) fscanf(fp, "%*f");
1168     return(0);
1169     }
1170
1171     /* Load a Radiance scene using the given callback function for objects */
1172     static int
1173     load_scene(const char *inspec, int (*ocb)(FILE *))
1174     {
1175     int rv = 0;
1176     char inpbuf[1024];
1177     FILE *fp;
1178     int c;
1179
1180     if (*inspec == '!')
1181     fp = popen(inspec+1, "r");
1182     else
1183     fp = fopen(inspec, "r");
1184     if (fp == NULL) {
1185     fprintf(stderr, "%s: cannot load '%s'\n", progname, inspec);
1186     return(-1);
1187     }
1188     while ((c = getc(fp)) != EOF) { /* load receiver data */
1189     if (isspace(c)) /* skip leading white space */
1190     continue;
1191     if (c == '!') { /* read from a new command */
1192     inpbuf[0] = c;
1193     if (fgetline(inpbuf+1, sizeof(inpbuf)-1, fp) != NULL) {
1194     if ((c = load_scene(inpbuf, ocb)) < 0)
1195     return(c);
1196     rv += c;
1197     }
1198     continue;
1199     }
1200     if (c == '#') { /* parameters/comment */
1201 greg 2.5 if ((c = getc(fp)) == EOF || ungetc(c,fp) == EOF)
1202     break;
1203     if (!isspace(c) && fscanf(fp, "%s", inpbuf) == 1 &&
1204 greg 2.1 !strcmp(inpbuf, PARAMSTART)) {
1205     if (fgets(inpbuf, sizeof(inpbuf), fp) != NULL)
1206 greg 2.6 strcat(newparams, inpbuf);
1207 greg 2.1 continue;
1208     }
1209 greg 2.10 while ((c = getc(fp)) != EOF && c != '\n')
1210 greg 2.1 ; /* else skipping comment */
1211     continue;
1212     }
1213     ungetc(c, fp); /* else check object for receiver */
1214     c = (*ocb)(fp);
1215     if (c < 0)
1216     return(c);
1217     rv += c;
1218     }
1219     /* close our input stream */
1220     c = (*inspec == '!') ? pclose(fp) : fclose(fp);
1221     if (c != 0) {
1222     fprintf(stderr, "%s: error loading '%s'\n", progname, inspec);
1223     return(-1);
1224     }
1225     return(rv);
1226     }
1227
1228     /* Get command arguments and run program */
1229     int
1230     main(int argc, char *argv[])
1231     {
1232     char fmtopt[6] = "-faa"; /* default output is ASCII */
1233 greg 2.4 char *xrs=NULL, *yrs=NULL, *ldopt=NULL;
1234 greg 2.11 char *iropt = NULL;
1235 greg 2.1 char *sendfn;
1236     char sampcntbuf[32], nsbinbuf[32];
1237     FILE *rcfp;
1238     int nsbins;
1239     int a, i;
1240 greg 2.60 /* set global progname */
1241     fixargv0(argv[0]);
1242 greg 2.1 /* screen rcontrib options */
1243 greg 2.14 for (a = 1; a < argc-2; a++) {
1244     int na;
1245     /* check for argument expansion */
1246     while ((na = expandarg(&argc, &argv, a)) > 0)
1247     ;
1248     if (na < 0) {
1249     fprintf(stderr, "%s: cannot expand '%s'\n",
1250     progname, argv[a]);
1251     return(1);
1252     }
1253     if (argv[a][0] != '-' || !argv[a][1])
1254     break;
1255     na = 1;
1256     switch (argv[a][1]) { /* !! Keep consistent !! */
1257 greg 2.1 case 'v': /* verbose mode */
1258 greg 2.16 verbose = 1;
1259 greg 2.1 na = 0;
1260     continue;
1261     case 'f': /* special case for -fo, -ff, etc. */
1262     switch (argv[a][2]) {
1263     case '\0': /* cal file */
1264     goto userr;
1265     case 'o': /* force output */
1266     goto userr;
1267     case 'a': /* output format */
1268     case 'f':
1269     case 'd':
1270     case 'c':
1271 greg 2.6 if (!(fmtopt[3] = argv[a][3]))
1272     fmtopt[3] = argv[a][2];
1273     fmtopt[2] = argv[a][2];
1274 greg 2.1 na = 0;
1275     continue; /* will pass later */
1276     default:
1277     goto userr;
1278     }
1279     break;
1280 greg 2.4 case 'x': /* x-resolution */
1281     xrs = argv[++a];
1282     na = 0;
1283     continue;
1284     case 'y': /* y-resolution */
1285     yrs = argv[++a];
1286     na = 0;
1287     continue;
1288 greg 2.55 case 'c': /* spectral sampling or count */
1289     switch (argv[a][2]) {
1290     case 's':
1291     na = 2;
1292     break;
1293     case 'w':
1294     na = 3;
1295     break;
1296     case '\0':
1297     sampcnt = atoi(argv[++a]);
1298     if (sampcnt <= 0)
1299     goto userr;
1300     na = 0; /* we re-add this later */
1301 greg 2.57 continue;
1302 greg 2.55 }
1303 greg 2.57 break;
1304 greg 2.8 case 'I': /* only for pass-through mode */
1305 greg 2.11 case 'i':
1306     iropt = argv[a];
1307 greg 2.8 na = 0;
1308     continue;
1309 greg 2.16 case 'w': /* options without arguments */
1310 greg 2.49 if (!argv[a][2] || strchr("+1tTyY", argv[a][2]) == NULL)
1311     verbose = -1;
1312     break;
1313 greg 2.16 case 'V':
1314 greg 2.1 case 'u':
1315     case 'h':
1316 greg 2.4 case 'r':
1317 greg 2.1 break;
1318     case 'n': /* options with 1 argument */
1319     case 's':
1320     case 'o':
1321 greg 2.53 case 't':
1322 greg 2.1 na = 2;
1323     break;
1324     case 'b': /* special case */
1325     if (argv[a][2] != 'v') goto userr;
1326     break;
1327     case 'l': /* special case */
1328 greg 2.4 if (argv[a][2] == 'd') {
1329     ldopt = argv[a];
1330     na = 0;
1331     continue;
1332     }
1333 greg 2.1 na = 2;
1334     break;
1335     case 'd': /* special case */
1336     if (argv[a][2] != 'v') na = 2;
1337     break;
1338     case 'a': /* special case */
1339 greg 2.28 if (argv[a][2] == 'p') {
1340     na = 2; /* photon map [+ bandwidth(s)] */
1341     if (a < argc-3 && atoi(argv[a+1]) > 0)
1342     na += 1 + (a < argc-4 && atoi(argv[a+2]) > 0);
1343     } else
1344     na = (argv[a][2] == 'v') ? 4 : 2;
1345 greg 2.1 break;
1346     case 'm': /* special case */
1347     if (!argv[a][2]) goto userr;
1348     na = (argv[a][2] == 'e') | (argv[a][2] == 'a') ? 4 : 2;
1349     break;
1350     default: /* anything else is verbotten */
1351     goto userr;
1352     }
1353     if (na <= 0) continue;
1354     CHECKARGC(na); /* pass on option */
1355     rcarg[nrcargs++] = argv[a];
1356     while (--na) /* + arguments if any */
1357     rcarg[nrcargs++] = argv[++a];
1358     }
1359     if (a > argc-2)
1360     goto userr; /* check at end of options */
1361     sendfn = argv[a++]; /* assign sender & receiver inputs */
1362     if (sendfn[0] == '-') { /* user wants pass-through mode? */
1363     if (sendfn[1]) goto userr;
1364     sendfn = NULL;
1365 greg 2.11 if (iropt) {
1366 greg 2.8 CHECKARGC(1);
1367 greg 2.11 rcarg[nrcargs++] = iropt;
1368 greg 2.8 }
1369 greg 2.4 if (xrs) {
1370     CHECKARGC(2);
1371     rcarg[nrcargs++] = "-x";
1372     rcarg[nrcargs++] = xrs;
1373     }
1374     if (yrs) {
1375     CHECKARGC(2);
1376     rcarg[nrcargs++] = "-y";
1377     rcarg[nrcargs++] = yrs;
1378     }
1379     if (ldopt) {
1380     CHECKARGC(1);
1381     rcarg[nrcargs++] = ldopt;
1382     }
1383 greg 2.1 if (sampcnt <= 0) sampcnt = 1;
1384 greg 2.8 } else { /* else in sampling mode */
1385 greg 2.11 if (iropt) {
1386 greg 2.8 fputs(progname, stderr);
1387 greg 2.11 fputs(": -i, -I supported for pass-through only\n", stderr);
1388 greg 2.8 return(1);
1389     }
1390 greg 2.42 #ifdef SMLFLT
1391     fmtopt[2] = 'f';
1392     #else
1393     fmtopt[2] = 'd';
1394     #endif
1395 greg 2.1 if (sampcnt <= 0) sampcnt = 10000;
1396     }
1397     sprintf(sampcntbuf, "%d", sampcnt);
1398     CHECKARGC(3); /* add our format & sample count */
1399     rcarg[nrcargs++] = fmtopt;
1400     rcarg[nrcargs++] = "-c";
1401     rcarg[nrcargs++] = sampcntbuf;
1402     /* add receiver arguments to rcontrib */
1403     if (load_scene(argv[a], add_recv_object) < 0)
1404     return(1);
1405     finish_receiver();
1406     if (sendfn == NULL) { /* pass-through mode? */
1407     CHECKARGC(1); /* add octree */
1408     rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1409     rcarg[nrcargs] = NULL;
1410     return(my_exec(rcarg)); /* rcontrib does everything */
1411     }
1412     clear_params(&curparams, 0); /* else load sender surface & params */
1413 greg 2.24 curmod[0] = '\0';
1414 greg 2.1 if (load_scene(sendfn, add_send_object) < 0)
1415     return(1);
1416     if ((nsbins = prepare_sampler()) <= 0)
1417     return(1);
1418     CHECKARGC(3); /* add row count and octree */
1419     rcarg[nrcargs++] = "-y";
1420     sprintf(nsbinbuf, "%d", nsbins);
1421     rcarg[nrcargs++] = nsbinbuf;
1422     rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1423     rcarg[nrcargs] = NULL;
1424     /* open pipe to rcontrib process */
1425     if ((rcfp = popen_arglist(rcarg, "w")) == NULL)
1426     return(1);
1427     SET_FILE_BINARY(rcfp);
1428     #ifdef getc_unlocked
1429     flockfile(rcfp);
1430     #endif
1431 greg 2.22 if (verbose > 0) {
1432 greg 2.1 fprintf(stderr, "%s: sampling %d directions", progname, nsbins);
1433     if (curparams.nsurfs > 1)
1434 greg 2.7 fprintf(stderr, " (%d elements)\n", curparams.nsurfs);
1435 greg 2.1 else
1436     fputc('\n', stderr);
1437     }
1438     for (i = 0; i < nsbins; i++) /* send rcontrib ray samples */
1439     if (!(*curparams.sample_basis)(&curparams, i, rcfp))
1440     return(1);
1441 greg 2.51 return(pclose_al(rcfp) < 0); /* all finished! */
1442 greg 2.1 userr:
1443     if (a < argc-2)
1444     fprintf(stderr, "%s: unsupported option '%s'", progname, argv[a]);
1445 greg 2.13 fprintf(stderr, "Usage: %s [-v][rcontrib options] sender.rad receiver.rad [-i system.oct] [system.rad ..]\n",
1446 greg 2.1 progname);
1447     return(1);
1448     }
