root/radiance/ray/src/util/rfluxmtx.c
Revision: 2.9
Committed: Fri Jul 25 16:58:20 2014 UTC (9 years, 10 months ago) by greg
Fixed bug in setting of receiver normal for sources
2 static const char RCSid[] = "$Id: rfluxmtx.c,v 2.8 2014/07/25 15:46:10 greg Exp $";
5 * Calculate flux transfer matrix or matrices using rcontrib
6 */
7
8 #include "copyright.h"
9
10 #include <ctype.h>
11 #include <stdlib.h>
12 #include "rtio.h"
13 #include "rtmath.h"
14 #include "bsdf.h"
15 #include "bsdf_m.h"
16 #include "random.h"
17 #include "triangulate.h"
18 #include "platform.h"
19
20 #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
21 #undef getc
22 #define getc getc_unlocked
23 #endif
24
25 #ifdef _WIN32
26 #define SPECIALS " \t\"$*?"
27 #define QUOTCHAR '"'
28 #else
29 #define SPECIALS " \t\n'\"()${}*?[];|&"
30 #define QUOTCHAR '\''
31 #define ALTQUOT '"'
32 #endif
33
34 #define MAXRCARG 512
35
36 char *progname; /* global argv[0] */
37
38 int verbose = 0; /* verbose mode? */
39
40 char *rcarg[MAXRCARG+1] = {"rcontrib", "-fo+"};
41 int nrcargs = 2;
42
43 const char overflowerr[] = "%s: too many arguments!\n";
44
45 #define CHECKARGC(n) if (nrcargs >= MAXRCARG-(n)) \
46 { fprintf(stderr, overflowerr, progname); exit(1); }
47
48 int sampcnt = 0; /* sample count (0==unset) */
49
50 char *reinhfn = "reinhartb.cal";
51 char *shirchiufn = "disk2square.cal";
52 char *kfullfn = "klems_full.cal";
53 char *khalffn = "klems_half.cal";
54 char *kquarterfn = "klems_quarter.cal";
55
56 /* string indicating parameters */
57 const char PARAMSTART[] = "@rfluxmtx";
58
59 /* surface type IDs */
60 #define ST_NONE 0
61 #define ST_POLY 1
62 #define ST_RING 2
63 #define ST_SOURCE 3
64
65 typedef struct surf_s {
66 struct surf_s *next; /* next surface in list */
67 void *priv; /* private data (malloc'ed) */
68 char sname[32]; /* surface name */
69 FVECT snrm; /* surface normal */
70 double area; /* surface area / proj. solid angle */
71 short styp; /* surface type */
72 short nfargs; /* number of real arguments */
73 double farg[1]; /* real values (extends struct) */
74 } SURF; /* surface structure */
75
76 typedef struct {
77 FVECT uva[2]; /* tangent axes */
78 int ntris; /* number of triangles */
79 struct ptri {
80 float afrac; /* fraction of total area */
81 short vndx[3]; /* vertex indices */
82 } tri[1]; /* triangle array (extends struct) */
83 } POLYTRIS; /* triangulated polygon */
84
85 typedef struct param_s {
86 char hemis[32]; /* hemispherical sampling spec. */
87 int hsiz; /* hemisphere basis size */
88 int nsurfs; /* number of surfaces */
89 SURF *slist; /* list of surfaces */
90 FVECT vup; /* up vector (zero if unset) */
91 FVECT nrm; /* average normal direction */
92 FVECT udir, vdir; /* v-up tangent axes */
93 char *outfn; /* output file name (receiver) */
94 int (*sample_basis)(struct param_s *p, int, FILE *);
95 } PARAMS; /* sender/receiver parameters */
96
97 PARAMS curparams;
98 char curmod[128];
99 char newparams[1024];
100
101 typedef int SURFSAMP(FVECT, SURF *, double);
102
103 static SURFSAMP ssamp_bad, ssamp_poly, ssamp_ring;
104
105 SURFSAMP *orig_in_surf[4] = {
106 ssamp_bad, ssamp_poly, ssamp_ring, ssamp_bad
107 };
108
109 /* Clear parameter set */
110 static void
111 clear_params(PARAMS *p, int reset_only)
112 {
113 while (p->slist != NULL) {
114 SURF *sdel = p->slist;
115 p->slist = sdel->next;
116 if (sdel->priv != NULL)
117 free(sdel->priv);
118 free(sdel);
119 }
120 if (reset_only) {
121 p->nsurfs = 0;
122 memset(p->nrm, 0, sizeof(FVECT));
123 memset(p->vup, 0, sizeof(FVECT));
124 p->outfn = NULL;
125 return;
126 }
127 memset(p, 0, sizeof(PARAMS));
128 }
129
130 /* Get surface type from name */
131 static int
132 surf_type(const char *otype)
133 {
134 if (!strcmp(otype, "polygon"))
135 return(ST_POLY);
136 if (!strcmp(otype, "ring"))
137 return(ST_RING);
138 if (!strcmp(otype, "source"))
139 return(ST_SOURCE);
140 return(ST_NONE);
141 }
142
143 /* Add arguments to oconv command */
144 static char *
145 oconv_command(int ac, char *av[])
146 {
147 static char oconvbuf[2048] = "!oconv -f";
148 char *cp = oconvbuf + 9;
149
150 while (ac-- > 0) {
151 if (cp >= oconvbuf+(sizeof(oconvbuf)-32)) {
152 fputs(progname, stderr);
153 fputs(": too many file arguments!\n", stderr);
154 exit(1);
155 }
156 *cp++ = ' ';
157 strcpy(cp, *av++);
158 while (*cp) cp++;
159 }
160 *cp = '\0';
161 return(oconvbuf);
162 }
163
164 /* Check if any of the characters in str2 are found in str1 */
165 static int
166 matchany(const char *str1, const char *str2)
167 {
168 while (*str1) {
169 const char *cp = str2;
170 while (*cp)
171 if (*cp++ == *str1)
172 return(*str1);
173 ++str1;
174 }
175 return(0);
176 }
177
178
179 /* Convert a set of arguments into a command line for pipe() or system() */
180 static char *
181 convert_commandline(char *cmd, const int len, char *av[])
182 {
183 int match;
184 char *cp;
185
186 for (cp = cmd; *av != NULL; av++) {
187 const int n = strlen(*av);
188 if (cp+n >= cmd+(len-3)) {
189 fputs(progname, stderr);
190 return(NULL);
191 }
192 if ((match = matchany(*av, SPECIALS))) {
193 const int quote =
194 #ifdef ALTQUOT
195 (match == QUOTCHAR) ? ALTQUOT :
196 #endif
197 QUOTCHAR;
198 *cp++ = quote;
199 strcpy(cp, *av);
200 cp += n;
201 *cp++ = quote;
202 } else {
203 strcpy(cp, *av);
204 cp += n;
205 }
206 *cp++ = ' ';
207 }
208 if (cp <= cmd)
209 return(NULL);
210 *--cp = '\0';
211 return(cmd);
212 }
213
214 /* Open a pipe to/from a command given as an argument list */
215 static FILE *
216 popen_arglist(char *av[], char *mode)
217 {
218 char cmd[10240];
219
220 if (!convert_commandline(cmd, sizeof(cmd), av)) {
221 fputs(progname, stderr);
222 fputs(": command line too long in popen_arglist()\n", stderr);
223 return(NULL);
224 }
225 if (verbose)
226 fprintf(stderr, "%s: opening pipe %s: %s\n",
227 progname, (*mode=='w') ? "to" : "from", cmd);
228 return(popen(cmd, mode));
229 }
230
231 #ifdef _WIN32
232 /* Execute system command (Windows version) */
233 static int
234 my_exec(char *av[])
235 {
236 char cmd[10240];
237
238 if (!convert_commandline(cmd, sizeof(cmd), av)) {
239 fputs(progname, stderr);
240 fputs(": command line too long in my_exec()\n", stderr);
241 return(1);
242 }
243 if (verbose)
244 fprintf(stderr, "%s: running: %s\n", progname, cmd);
245 return(system(cmd));
246 }
247 #else
248 /* Execute system command in our stead (Unix version) */
249 static int
250 my_exec(char *av[])
251 {
252 char *compath;
253
254 if ((compath = getpath((char *)av[0], getenv("PATH"), X_OK)) == NULL) {
255 fprintf(stderr, "%s: cannot locate %s\n", progname, av[0]);
256 return(1);
257 }
258 if (verbose) {
259 char cmd[4096];
260 if (!convert_commandline(cmd, sizeof(cmd), av))
261 strcpy(cmd, "COMMAND TOO LONG TO SHOW");
262 fprintf(stderr, "%s: running: %s\n", progname, cmd);
263 }
264 execv(compath, av); /* successful call never returns */
265 perror(compath);
266 return(1);
267 }
268 #endif
269
270 /* Get normalized direction vector from string specification */
271 static int
272 get_direction(FVECT dv, const char *s)
273 {
274 int sign = 1;
275 int axis = 0;
276
277 memset(dv, 0, sizeof(FVECT));
278 nextchar:
279 switch (*s) {
280 case '+':
281 ++s;
282 goto nextchar;
283 case '-':
284 sign = -sign;
285 ++s;
286 goto nextchar;
287 case 'z':
288 case 'Z':
289 ++axis;
290 case 'y':
291 case 'Y':
292 ++axis;
293 case 'x':
294 case 'X':
295 dv[axis] = sign;
296 return(!s[1] | isspace(s[1]));
297 default:
298 break;
299 }
300 #ifdef SMLFLT
301 if (sscanf(s, "%f,%f,%f", &dv[0], &dv[1], &dv[2]) != 3)
302 #else
303 if (sscanf(s, "%lf,%lf,%lf", &dv[0], &dv[1], &dv[2]) != 3)
304 #endif
305 return(0);
306 dv[0] *= (RREAL)sign;
307 return(normalize(dv) > 0);
308 }
309
310 /* Parse program parameters (directives) */
311 static int
312 parse_params(PARAMS *p, char *pargs)
313 {
314 char *cp = pargs;
315 int nparams = 0;
316 int i;
317
318 for ( ; ; )
319 switch (*cp++) {
320 case 'h':
321 if (*cp++ != '=')
322 break;
323 p->hsiz = 0;
324 i = 0;
325 while (*cp && !isspace(*cp)) {
326 if (isdigit(*cp))
327 p->hsiz = 10*p->hsiz + *cp - '0';
328 p->hemis[i++] = *cp++;
329 }
330 if (!i)
331 break;
332 p->hemis[i] = '\0';
333 p->hsiz += !p->hsiz;
334 ++nparams;
335 continue;
336 case 'u':
337 if (*cp++ != '=')
338 break;
339 if (!get_direction(p->vup, cp))
340 break;
341 ++nparams;
342 continue;
343 case 'o':
344 if (*cp++ != '=')
345 break;
346 i = 0;
347 while (*cp && !isspace(*cp++))
348 i++;
349 if (!i)
350 break;
351 *--cp = '\0';
352 p->outfn = savqstr(cp-i);
353 *cp++ = ' ';
354 ++nparams;
355 continue;
356 case ' ':
357 case '\t':
358 case '\r':
359 case '\n':
360 continue;
361 case '\0':
362 return(nparams);
363 default:
364 break;
365 }
366 fprintf(stderr, "%s: bad parameter string '%s'\n", progname, pargs);
367 exit(1);
368 return(-1); /* pro forma return */
369 }
370
371 /* Add receiver arguments (directives) corresponding to the current modifier */
372 static void
373 finish_receiver(void)
374 {
375 char sbuf[256];
376 int uniform = 0;
377 char *calfn = NULL;
378 char *params = NULL;
379 char *binv = NULL;
380 char *binf = NULL;
381 char *nbins = NULL;
382
383 if (!curmod[0]) {
384 fputs(progname, stderr);
385 fputs(": missing receiver surface!\n", stderr);
386 exit(1);
387 }
388 if (curparams.outfn != NULL) { /* add output file spec. */
389 CHECKARGC(2);
390 rcarg[nrcargs++] = "-o";
391 rcarg[nrcargs++] = curparams.outfn;
392 }
393 /* check arguments */
394 if (!curparams.hemis[0]) {
395 fputs(progname, stderr);
396 fputs(": missing hemisphere sampling type!\n", stderr);
397 exit(1);
398 }
399 if (normalize(curparams.nrm) == 0) {
400 fputs(progname, stderr);
401 fputs(": undefined normal for hemisphere sampling\n", stderr);
402 exit(1);
403 }
404 if (normalize(curparams.vup) == 0)
405 if (fabs(curparams.nrm[2]) < .7)
406 curparams.vup[2] = 1;
407 else
408 curparams.vup[1] = 1;
409 /* determine sample type/bin */
410 if (tolower(curparams.hemis[0]) == 'u' | curparams.hemis[0] == '1') {
411 binv = "0"; /* uniform sampling -- one bin */
412 uniform = 1;
413 } else if (tolower(curparams.hemis[0]) == 's' &&
414 tolower(curparams.hemis[1]) == 'c') {
415 /* assign parameters */
416 if (curparams.hsiz <= 1) {
417 fputs(progname, stderr);
418 fputs(": missing size for Shirley-Chiu sampling!\n", stderr);
419 exit(1);
420 }
421 calfn = shirchiufn; shirchiufn = NULL;
422 sprintf(sbuf, "SCdim=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g",
423 curparams.hsiz,
424 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
425 curparams.vup[0], curparams.vup[1], curparams.vup[2]);
426 params = savqstr(sbuf);
427 binv = "scbin";
428 nbins = "SCdim*SCdim";
429 } else if ((tolower(curparams.hemis[0]) == 'r') |
430 (tolower(curparams.hemis[0]) == 't')) {
431 calfn = reinhfn; reinhfn = NULL;
432 sprintf(sbuf, "MF=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g",
433 curparams.hsiz,
434 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
435 curparams.vup[0], curparams.vup[1], curparams.vup[2]);
436 params = savqstr(sbuf);
437 binv = "rbin";
438 nbins = "Nrbins";
439 } else if (tolower(curparams.hemis[0]) == 'k' &&
440 !curparams.hemis[1] |
441 (tolower(curparams.hemis[1]) == 'f') |
442 (curparams.hemis[1] == '1')) {
443 calfn = kfullfn; kfullfn = NULL;
444 binf = "kbin";
445 nbins = "Nkbins";
446 } else if (tolower(curparams.hemis[0]) == 'k' &&
447 (tolower(curparams.hemis[1]) == 'h') |
448 (curparams.hemis[1] == '2')) {
449 calfn = khalffn; khalffn = NULL;
450 binf = "khbin";
451 nbins = "Nkhbins";
452 } else if (tolower(curparams.hemis[0]) == 'k' &&
453 (tolower(curparams.hemis[1]) == 'q') |
454 (curparams.hemis[1] == '4')) {
455 calfn = kquarterfn; kquarterfn = NULL;
456 binf = "kqbin";
457 nbins = "Nkqbins";
458 } else {
459 fprintf(stderr, "%s: unrecognized hemisphere sampling: h=%s\n",
460 progname, curparams.hemis);
461 exit(1);
462 }
463 if (!uniform & (curparams.slist->styp == ST_SOURCE)) {
464 SURF *sp;
465 for (sp = curparams.slist; sp != NULL; sp = sp->next)
466 if (fabs(sp->area - PI) > 1e-3) {
467 fprintf(stderr, "%s: source '%s' must be 180-degrees\n",
468 progname, sp->sname);
469 exit(1);
470 }
471 }
472 if (calfn != NULL) { /* add cal file if needed */
473 CHECKARGC(2);
474 rcarg[nrcargs++] = "-f";
475 rcarg[nrcargs++] = calfn;
476 }
477 if (params != NULL) { /* parameters _after_ cal file */
478 CHECKARGC(2);
479 rcarg[nrcargs++] = "-p";
480 rcarg[nrcargs++] = params;
481 }
482 if (nbins != NULL) { /* add #bins if set */
483 CHECKARGC(2);
484 rcarg[nrcargs++] = "-bn";
485 rcarg[nrcargs++] = nbins;
486 }
487 if (binv != NULL) {
488 CHECKARGC(2); /* assign bin variable */
489 rcarg[nrcargs++] = "-b";
490 rcarg[nrcargs++] = binv;
491 } else if (binf != NULL) {
492 CHECKARGC(2); /* assign bin function */
493 rcarg[nrcargs++] = "-b";
494 sprintf(sbuf, "%s(%g,%g,%g,%g,%g,%g)", binf,
495 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
496 curparams.vup[0], curparams.vup[1], curparams.vup[2]);
497 rcarg[nrcargs++] = savqstr(sbuf);
498 }
499 CHECKARGC(2); /* modifier argument goes last */
500 rcarg[nrcargs++] = "-m";
501 rcarg[nrcargs++] = savqstr(curmod);
502 }
503
504 /* Make randomly oriented tangent plane axes for given normal direction */
505 static void
506 make_axes(FVECT uva[2], const FVECT nrm)
507 {
508 int i;
509
510 uva[1][0] = 0.5 - frandom();
511 uva[1][1] = 0.5 - frandom();
512 uva[1][2] = 0.5 - frandom();
513 for (i = 3; i--; )
514 if ((-0.6 < nrm[i]) & (nrm[i] < 0.6))
515 break;
516 if (i < 0) {
517 fputs(progname, stderr);
518 fputs(": bad surface normal in make_axes!\n", stderr);
519 exit(1);
520 }
521 uva[1][i] = 1.0;
522 VCROSS(uva[0], uva[1], nrm);
523 normalize(uva[0]);
524 VCROSS(uva[1], nrm, uva[0]);
525 }
526
527 /* Illegal sender surfaces end up here */
528 static int
529 ssamp_bad(FVECT orig, SURF *sp, double x)
530 {
531 fprintf(stderr, "%s: illegal sender surface '%s'\n",
532 progname, sp->sname);
533 return(0);
534 }
535
536 /* Generate origin on ring surface from uniform random variable */
537 static int
538 ssamp_ring(FVECT orig, SURF *sp, double x)
539 {
540 FVECT *uva = (FVECT *)sp->priv;
541 double samp2[2];
542 double uv[2];
543 int i;
544
545 if (uva == NULL) { /* need tangent axes */
546 uva = (FVECT *)malloc(sizeof(FVECT)*2);
547 if (uva == NULL) {
548 fputs(progname, stderr);
549 fputs(": out of memory in ssamp_ring!\n", stderr);
550 return(0);
551 }
552 make_axes(uva, sp->snrm);
553 sp->priv = (void *)uva;
554 }
555 SDmultiSamp(samp2, 2, x);
556 samp2[0] = sqrt(samp2[0]*sp->area*(1./PI) + sp->farg[6]*sp->farg[6]);
557 samp2[1] *= 2.*PI;
558 uv[0] = samp2[0]*tcos(samp2[1]);
559 uv[1] = samp2[0]*tsin(samp2[1]);
560 for (i = 3; i--; )
561 orig[i] = sp->farg[i] + uv[0]*uva[0][i] + uv[1]*uva[1][i];
562 return(1);
563 }
564
565 /* Add triangle to polygon's list (call-back function) */
566 static int
567 add_triangle(const Vert2_list *tp, int a, int b, int c)
568 {
569 POLYTRIS *ptp = (POLYTRIS *)tp->p;
570 struct ptri *trip = ptp->tri + ptp->ntris++;
571
572 trip->vndx[0] = a;
573 trip->vndx[1] = b;
574 trip->vndx[2] = c;
575 return(1);
576 }
577
578 /* Generate origin on polygon surface from uniform random variable */
579 static int
580 ssamp_poly(FVECT orig, SURF *sp, double x)
581 {
582 POLYTRIS *ptp = (POLYTRIS *)sp->priv;
583 double samp2[2];
584 double *v0, *v1, *v2;
585 int i;
586
587 if (ptp == NULL) { /* need to triangulate */
588 ptp = (POLYTRIS *)malloc(sizeof(POLYTRIS) +
589 sizeof(struct ptri)*(sp->nfargs/3 - 3));
590 if (ptp == NULL)
591 goto memerr;
592 if (sp->nfargs == 3) { /* simple case */
593 ptp->ntris = 1;
594 ptp->tri[0].vndx[0] = 0;
595 ptp->tri[0].vndx[1] = 1;
596 ptp->tri[0].vndx[2] = 2;
597 ptp->tri[0].afrac = 1;
598 } else {
599 Vert2_list *v2l = polyAlloc(sp->nfargs/3);
600 if (v2l == NULL)
601 goto memerr;
602 make_axes(ptp->uva, sp->snrm);
603 for (i = v2l->nv; i--; ) {
604 v2l->v[i].mX = DOT(sp->farg+3*i, ptp->uva[0]);
605 v2l->v[i].mY = DOT(sp->farg+3*i, ptp->uva[1]);
606 }
607 ptp->ntris = 0;
608 v2l->p = (void *)ptp;
609 if (!polyTriangulate(v2l, add_triangle)) {
610 fprintf(stderr,
611 "%s: cannot triangulate polygon '%s'\n",
612 progname, sp->sname);
613 return(0);
614 }
615 for (i = ptp->ntris; i--; ) {
616 int a = ptp->tri[i].vndx[0];
617 int b = ptp->tri[i].vndx[1];
618 int c = ptp->tri[i].vndx[2];
619 ptp->tri[i].afrac =
620 (v2l->v[a].mX*v2l->v[b].mY -
621 v2l->v[b].mX*v2l->v[a].mY +
622 v2l->v[b].mX*v2l->v[c].mY -
623 v2l->v[c].mX*v2l->v[b].mY +
624 v2l->v[c].mX*v2l->v[a].mY -
625 v2l->v[a].mX*v2l->v[c].mY) /
626 (2.*sp->area);
627 }
628 polyFree(v2l);
629 }
630 sp->priv = (void *)ptp;
631 }
632 /* pick triangle by partial area */
633 for (i = 0; i < ptp->ntris && x > ptp->tri[i].afrac; i++)
634 x -= ptp->tri[i].afrac;
635 SDmultiSamp(samp2, 2, x/ptp->tri[i].afrac);
636 samp2[0] *= samp2[1] = sqrt(samp2[1]);
637 samp2[1] = 1. - samp2[1];
638 v0 = sp->farg + 3*ptp->tri[i].vndx[0];
639 v1 = sp->farg + 3*ptp->tri[i].vndx[1];
640 v2 = sp->farg + 3*ptp->tri[i].vndx[2];
641 for (i = 3; i--; )
642 orig[i] = v0[i] + samp2[0]*(v1[i] - v0[i])
643 + samp2[1]*(v2[i] - v0[i]) ;
644 return(1);
645 memerr:
646 fputs(progname, stderr);
647 fputs(": out of memory in ssamp_poly!\n", stderr);
648 return(0);
649 }
650
651 /* Compute sample origin based on projected areas of sender subsurfaces */
652 static int
653 sample_origin(PARAMS *p, FVECT orig, const FVECT rdir, double x)
654 {
655 static double *projsa;
656 static int nall;
657 double tarea = 0;
658 int i;
659 SURF *sp;
660 /* special case for lone surface */
661 if (p->nsurfs == 1) {
662 sp = p->slist;
663 if (DOT(sp->snrm, rdir) >= -FTINY) {
664 fprintf(stderr,
665 "%s: internal - sample behind sender '%s'\n",
666 progname, sp->sname);
667 return(0);
668 }
669 return((*orig_in_surf[sp->styp])(orig, sp, x));
670 }
671 if (p->nsurfs > nall) { /* (re)allocate surface area cache */
672 if (projsa) free(projsa);
673 projsa = (double *)malloc(sizeof(double)*p->nsurfs);
674 if (!projsa) return(0);
675 nall = p->nsurfs;
676 }
677 /* compute projected areas */
678 for (i = 0, sp = p->slist; sp != NULL; i++, sp = sp->next) {
679 projsa[i] = -DOT(sp->snrm, rdir) * sp->area;
680 tarea += projsa[i] *= (double)(projsa[i] > FTINY);
681 }
682 if (tarea <= FTINY) { /* wrong side of sender? */
683 fputs(progname, stderr);
684 fputs(": internal - sample behind all sender elements!\n",
685 stderr);
686 return(0);
687 }
688 tarea *= x; /* get surface from list */
689 for (i = 0, sp = p->slist; tarea > projsa[i]; sp = sp->next)
690 tarea -= projsa[i++];
691 return((*orig_in_surf[sp->styp])(orig, sp, tarea/projsa[i]));
692 }
693
694 /* Uniform sample generator */
695 static int
696 sample_uniform(PARAMS *p, int b, FILE *fp)
697 {
698 int n = sampcnt;
699 double samp3[3];
700 double duvw[3];
701 FVECT orig_dir[2];
702 int i;
703
704 if (fp == NULL) /* just requesting number of bins? */
705 return(1);
706
707 while (n--) { /* stratified hemisphere sampling */
708 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
709 SDsquare2disk(duvw, samp3[1], samp3[2]);
710 duvw[2] = -sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
711 for (i = 3; i--; )
712 orig_dir[1][i] = duvw[0]*p->udir[i] +
713 duvw[1]*p->vdir[i] +
714 duvw[2]*p->nrm[i] ;
715 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
716 return(0);
717 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
718 return(0);
719 }
720 return(1);
721 }
722
723 /* Shirly-Chiu sample generator */
724 static int
725 sample_shirchiu(PARAMS *p, int b, FILE *fp)
726 {
727 int n = sampcnt;
728 double samp3[3];
729 double duvw[3];
730 FVECT orig_dir[2];
731 int i;
732
733 if (fp == NULL) /* just requesting number of bins? */
734 return(p->hsiz*p->hsiz);
735
736 while (n--) { /* stratified sampling */
737 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
738 SDsquare2disk(duvw, (b/p->hsiz + samp3[1])/curparams.hsiz,
739 (b%p->hsiz + samp3[2])/curparams.hsiz);
740 duvw[2] = sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
741 for (i = 3; i--; )
742 orig_dir[1][i] = -duvw[0]*p->udir[i] -
743 duvw[1]*p->vdir[i] -
744 duvw[2]*p->nrm[i] ;
745 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
746 return(0);
747 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
748 return(0);
749 }
750 return(1);
751 }
752
753 /* Reinhart/Tregenza sample generator */
754 static int
755 sample_reinhart(PARAMS *p, int b, FILE *fp)
756 {
757 #define T_NALT 7
758 static const int tnaz[T_NALT] = {30, 30, 24, 24, 18, 12, 6};
759 const int RowMax = T_NALT*p->hsiz + 1;
760 const double RAH = (.5*PI)/(RowMax-.5);
761 #define rnaz(r) (r >= RowMax-1 ? 1 : p->hsiz*tnaz[r/p->hsiz])
762 int n = sampcnt;
763 int row, col;
764 double samp3[3];
765 double alt, azi;
766 double duvw[3];
767 FVECT orig_dir[2];
768 int i;
769
770 if (fp == NULL) { /* just requesting number of bins? */
771 n = 0;
772 for (row = RowMax; row--; ) n += rnaz(row);
773 return(n);
774 }
775 row = 0; /* identify row & column */
776 col = b;
777 while (col >= rnaz(row)) {
778 col -= rnaz(row);
779 ++row;
780 }
781 while (n--) { /* stratified sampling */
782 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
783 alt = (row+samp3[1])*RAH;
784 azi = (2.*PI)*(col+samp3[2]-.5)/rnaz(row);
785 duvw[2] = cos(alt); /* measured from horizon */
786 duvw[0] = tcos(azi)*duvw[2];
787 duvw[1] = tsin(azi)*duvw[2];
788 duvw[2] = sqrt(1. - duvw[2]*duvw[2]);
789 for (i = 3; i--; )
790 orig_dir[1][i] = -duvw[0]*p->udir[i] -
791 duvw[1]*p->vdir[i] -
792 duvw[2]*p->nrm[i] ;
793 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
794 return(0);
795 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
796 return(0);
797 }
798 return(1);
799 #undef rnaz
800 #undef T_NALT
801 }
802
803 /* Klems sample generator */
804 static int
805 sample_klems(PARAMS *p, int b, FILE *fp)
806 {
807 static const char bname[4][20] = {
808 "LBNL/Klems Full",
809 "LBNL/Klems Half",
810 "INTERNAL ERROR",
811 "LBNL/Klems Quarter"
812 };
813 static ANGLE_BASIS *kbasis[4];
814 const int bi = p->hemis[1] - '1';
815 int n = sampcnt;
816 double samp2[2];
817 double duvw[3];
818 FVECT orig_dir[2];
819 int i;
820
821 if (!kbasis[bi]) { /* need to get basis, first */
822 for (i = 4; i--; )
823 if (!strcasecmp(abase_list[i].name, bname[bi])) {
824 kbasis[bi] = &abase_list[i];
825 break;
826 }
827 if (i < 0) {
828 fprintf(stderr, "%s: unknown hemisphere basis '%s'\n",
829 progname, bname[bi]);
830 return(0);
831 }
832 }
833 if (fp == NULL) /* just requesting number of bins? */
834 return(kbasis[bi]->nangles);
835
836 while (n--) { /* stratified sampling */
837 SDmultiSamp(samp2, 2, (n+frandom())/sampcnt);
838 if (!bo_getvec(duvw, b+samp2[1], kbasis[bi]))
839 return(0);
840 for (i = 3; i--; )
841 orig_dir[1][i] = duvw[0]*p->udir[i] +
842 duvw[1]*p->vdir[i] +
843 duvw[2]*p->nrm[i] ;
844 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp2[0]))
845 return(0);
846 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
847 return(0);
848 }
849 return(1);
850 }
851
852 /* Prepare hemisphere basis sampler that will send rays to rcontrib */
853 static int
854 prepare_sampler(void)
855 {
856 if (curparams.slist == NULL) { /* missing sample surface! */
857 fputs(progname, stderr);
858 fputs(": no sender surface!\n", stderr);
859 return(-1);
860 }
861 if (curparams.outfn != NULL) /* misplaced output file spec. */
862 fprintf(stderr, "%s: warning - ignoring output file in sender ('%s')\n",
863 progname, curparams.outfn);
864 /* check/set basis hemisphere */
865 if (!curparams.hemis[0]) {
866 fputs(progname, stderr);
867 fputs(": missing sender sampling type!\n", stderr);
868 return(-1);
869 }
870 if (normalize(curparams.nrm) == 0) {
871 fputs(progname, stderr);
872 fputs(": undefined normal for sender sampling\n", stderr);
873 return(-1);
874 }
875 if (normalize(curparams.vup) == 0)
876 if (fabs(curparams.nrm[2]) < .7)
877 curparams.vup[2] = 1;
878 else
879 curparams.vup[1] = 1;
880 VCROSS(curparams.udir, curparams.vup, curparams.nrm);
881 if (normalize(curparams.udir) == 0) {
882 fputs(progname, stderr);
883 fputs(": up vector coincides with sender normal\n", stderr);
884 return(-1);
885 }
886 VCROSS(curparams.vdir, curparams.nrm, curparams.udir);
887 if (tolower(curparams.hemis[0]) == 'u' | curparams.hemis[0] == '1')
888 curparams.sample_basis = sample_uniform;
889 else if (tolower(curparams.hemis[0]) == 's' &&
890 tolower(curparams.hemis[1]) == 'c')
891 curparams.sample_basis = sample_shirchiu;
892 else if ((tolower(curparams.hemis[0]) == 'r') |
893 (tolower(curparams.hemis[0]) == 't'))
894 curparams.sample_basis = sample_reinhart;
895 else if (tolower(curparams.hemis[0]) == 'k') {
896 switch (curparams.hemis[1]) {
897 case '1':
898 case '2':
899 case '4':
900 break;
901 case 'f':
902 case 'F':
903 case '\0':
904 curparams.hemis[1] = '1';
905 break;
906 case 'h':
907 case 'H':
908 curparams.hemis[1] = '2';
909 break;
910 case 'q':
911 case 'Q':
912 curparams.hemis[1] = '4';
913 break;
914 default:
915 goto unrecognized;
916 }
917 curparams.hemis[2] = '\0';
918 curparams.sample_basis = sample_klems;
919 } else
920 goto unrecognized;
921 /* return number of bins */
922 return((*curparams.sample_basis)(&curparams,0,NULL));
923 unrecognized:
924 fprintf(stderr, "%s: unrecognized sender sampling: h=%s\n",
925 progname, curparams.hemis);
926 return(-1);
927 }
928
929 /* Compute normal and area for polygon */
930 static int
931 finish_polygon(SURF *p)
932 {
933 const int nv = p->nfargs / 3;
934 FVECT e1, e2, vc;
935 int i;
936
937 memset(p->snrm, 0, sizeof(FVECT));
938 VSUB(e1, p->farg+3, p->farg);
939 for (i = 2; i < nv; i++) {
940 VSUB(e2, p->farg+3*i, p->farg);
941 VCROSS(vc, e1, e2);
942 p->snrm[0] += vc[0];
943 p->snrm[1] += vc[1];
944 p->snrm[2] += vc[2];
945 VCOPY(e1, e2);
946 }
947 p->area = normalize(p->snrm)*0.5;
948 return(p->area > FTINY);
949 }
950
951 /* Add a surface to our current parameters */
952 static void
953 add_surface(int st, const char *oname, FILE *fp)
954 {
955 SURF *snew;
956 int n;
957 /* get floating-point arguments */
958 if (!fscanf(fp, "%d", &n)) return;
959 while (n-- > 0) fscanf(fp, "%*s");
960 if (!fscanf(fp, "%d", &n)) return;
961 while (n-- > 0) fscanf(fp, "%*d");
962 if (!fscanf(fp, "%d", &n) || n <= 0) return;
963 snew = (SURF *)malloc(sizeof(SURF) + sizeof(double)*(n-1));
964 if (snew == NULL) {
965 fputs(progname, stderr);
966 fputs(": out of memory!\n", stderr);
967 exit(1);
968 }
969 strncpy(snew->sname, oname, sizeof(snew->sname)-1);
970 snew->sname[sizeof(snew->sname)-1] = '\0';
971 snew->styp = st;
972 snew->priv = NULL;
973 snew->nfargs = n;
974 for (n = 0; n < snew->nfargs; n++)
975 if (fscanf(fp, "%lf", &snew->farg[n]) != 1) {
976 fprintf(stderr, "%s: error reading arguments for '%s'\n",
977 progname, oname);
978 exit(1);
979 }
980 switch (st) {
981 case ST_RING:
982 if (snew->nfargs != 8)
983 goto badcount;
984 VCOPY(snew->snrm, snew->farg+3);
985 if (normalize(snew->snrm) == 0)
986 goto badnorm;
987 if (snew->farg[7] < snew->farg[6]) {
988 double t = snew->farg[7];
989 snew->farg[7] = snew->farg[6];
990 snew->farg[6] = t;
991 }
992 snew->area = PI*(snew->farg[7]*snew->farg[7] -
993 snew->farg[6]*snew->farg[6]);
994 break;
995 case ST_POLY:
996 if (snew->nfargs < 9 || snew->nfargs % 3)
997 goto badcount;
998 finish_polygon(snew);
999 break;
1000 case ST_SOURCE:
1001 if (snew->nfargs != 4)
1002 goto badcount;
1003 for (n = 3; n--; ) /* need to reverse "normal" */
1004 snew->snrm[n] = -snew->farg[n];
1005 if (normalize(snew->snrm) == 0)
1006 goto badnorm;
1007 snew->area = sin((PI/180./2.)*snew->farg[3]);
1008 snew->area *= PI*snew->area;
1009 break;
1010 }
1011 if (snew->area <= FTINY) {
1012 fprintf(stderr, "%s: warning - zero area for surface '%s'\n",
1013 progname, oname);
1014 free(snew);
1015 return;
1016 }
1017 VSUM(curparams.nrm, curparams.nrm, snew->snrm, snew->area);
1018 snew->next = curparams.slist;
1019 curparams.slist = snew;
1020 curparams.nsurfs++;
1021 return;
1022 badcount:
1023 fprintf(stderr, "%s: bad argument count for surface element '%s'\n",
1024 progname, oname);
1025 exit(1);
1026 badnorm:
1027 fprintf(stderr, "%s: bad orientation for surface element '%s'\n",
1028 progname, oname);
1029 exit(1);
1030 }
1031
1032 /* Parse a receiver object (look for modifiers to add to rcontrib command) */
1033 static int
1034 add_recv_object(FILE *fp)
1035 {
1036 int st;
1037 char thismod[128], otype[32], oname[128];
1038 int n;
1039
1040 if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3)
1041 return(0); /* must have hit EOF! */
1042 if (!strcmp(otype, "alias")) {
1043 fscanf(fp, "%*s"); /* skip alias */
1044 return(0);
1045 }
1046 /* is it a new receiver? */
1047 if ((st = surf_type(otype)) != ST_NONE) {
1048 if (curparams.slist != NULL && (st == ST_SOURCE) ^
1049 (curparams.slist->styp == ST_SOURCE)) {
1050 fputs(progname, stderr);
1051 fputs(": cannot mix source/non-source receivers!\n", stderr);
1052 return(-1);
1053 }
1054 if (strcmp(thismod, curmod)) {
1055 if (curmod[0]) { /* output last receiver? */
1056 finish_receiver();
1057 clear_params(&curparams, 1);
1058 }
1059 parse_params(&curparams, newparams);
1060 newparams[0] = '\0';
1061 strcpy(curmod, thismod);
1062 }
1063 add_surface(st, oname, fp); /* read & store surface */
1064 return(1);
1065 }
1066 /* else skip arguments */
1067 if (!fscanf(fp, "%d", &n)) return(0);
1068 while (n-- > 0) fscanf(fp, "%*s");
1069 if (!fscanf(fp, "%d", &n)) return;
1070 while (n-- > 0) fscanf(fp, "%*d");
1071 if (!fscanf(fp, "%d", &n)) return;
1072 while (n-- > 0) fscanf(fp, "%*f");
1073 return(0);
1074 }
1075
1076 /* Parse a sender object */
1077 static int
1078 add_send_object(FILE *fp)
1079 {
1080 int st;
1081 char otype[32], oname[128];
1082 int n;
1083
1084 if (fscanf(fp, "%*s %s %s", otype, oname) != 2)
1085 return(0); /* must have hit EOF! */
1086 if (!strcmp(otype, "alias")) {
1087 fscanf(fp, "%*s"); /* skip alias */
1088 return(0);
1089 }
1090 /* is it a new surface? */
1091 if ((st = surf_type(otype)) != ST_NONE) {
1092 if (st == ST_SOURCE) {
1093 fputs(progname, stderr);
1094 fputs(": cannot use source as a sender!\n", stderr);
1095 return(-1);
1096 }
1097 parse_params(&curparams, newparams);
1098 newparams[0] = '\0';
1099 add_surface(st, oname, fp); /* read & store surface */
1100 return(0);
1101 }
1102 /* else skip arguments */
1103 if (!fscanf(fp, "%d", &n)) return(0);
1104 while (n-- > 0) fscanf(fp, "%*s");
1105 if (!fscanf(fp, "%d", &n)) return;
1106 while (n-- > 0) fscanf(fp, "%*d");
1107 if (!fscanf(fp, "%d", &n)) return;
1108 while (n-- > 0) fscanf(fp, "%*f");
1109 return(0);
1110 }
1111
1112 /* Load a Radiance scene using the given callback function for objects */
1113 static int
1114 load_scene(const char *inspec, int (*ocb)(FILE *))
1115 {
1116 int rv = 0;
1117 char inpbuf[1024];
1118 FILE *fp;
1119 int c;
1120
1121 if (*inspec == '!')
1122 fp = popen(inspec+1, "r");
1123 else
1124 fp = fopen(inspec, "r");
1125 if (fp == NULL) {
1126 fprintf(stderr, "%s: cannot load '%s'\n", progname, inspec);
1127 return(-1);
1128 }
1129 while ((c = getc(fp)) != EOF) { /* load receiver data */
1130 if (isspace(c)) /* skip leading white space */
1131 continue;
1132 if (c == '!') { /* read from a new command */
1133 inpbuf[0] = c;
1134 if (fgetline(inpbuf+1, sizeof(inpbuf)-1, fp) != NULL) {
1135 if ((c = load_scene(inpbuf, ocb)) < 0)
1136 return(c);
1137 rv += c;
1138 }
1139 continue;
1140 }
1141 if (c == '#') { /* parameters/comment */
1142 if ((c = getc(fp)) == EOF || ungetc(c,fp) == EOF)
1143 break;
1144 if (!isspace(c) && fscanf(fp, "%s", inpbuf) == 1 &&
1145 !strcmp(inpbuf, PARAMSTART)) {
1146 if (fgets(inpbuf, sizeof(inpbuf), fp) != NULL)
1147 strcat(newparams, inpbuf);
1148 continue;
1149 }
1150 while ((c = getc(fp)) != EOF && c != '\n');
1151 ; /* else skipping comment */
1152 continue;
1153 }
1154 ungetc(c, fp); /* else check object for receiver */
1155 c = (*ocb)(fp);
1156 if (c < 0)
1157 return(c);
1158 rv += c;
1159 }
1160 /* close our input stream */
1161 c = (*inspec == '!') ? pclose(fp) : fclose(fp);
1162 if (c != 0) {
1163 fprintf(stderr, "%s: error loading '%s'\n", progname, inspec);
1164 return(-1);
1165 }
1166 return(rv);
1167 }
1168
1169 /* Get command arguments and run program */
1170 int
1171 main(int argc, char *argv[])
1172 {
1173 char fmtopt[6] = "-faa"; /* default output is ASCII */
1174 char *xrs=NULL, *yrs=NULL, *ldopt=NULL;
1175 int wantIrradiance = 0;
1176 char *sendfn;
1177 char sampcntbuf[32], nsbinbuf[32];
1178 FILE *rcfp;
1179 int nsbins;
1180 int a, i;
1181 /* screen rcontrib options */
1182 progname = argv[0];
1183 for (a = 1; a < argc-2 && argv[a][0] == '-'; a++) {
1184 int na = 1; /* !! Keep consistent !! */
1185 switch (argv[a][1]) {
1186 case 'v': /* verbose mode */
1187 verbose = !verbose;
1188 na = 0;
1189 continue;
1190 case 'f': /* special case for -fo, -ff, etc. */
1191 switch (argv[a][2]) {
1192 case '\0': /* cal file */
1193 goto userr;
1194 case 'o': /* force output */
1195 goto userr;
1196 case 'a': /* output format */
1197 case 'f':
1198 case 'd':
1199 case 'c':
1200 if (!(fmtopt[3] = argv[a][3]))
1201 fmtopt[3] = argv[a][2];
1202 fmtopt[2] = argv[a][2];
1203 na = 0;
1204 continue; /* will pass later */
1205 default:
1206 goto userr;
1207 }
1208 break;
1209 case 'x': /* x-resolution */
1210 xrs = argv[++a];
1211 na = 0;
1212 continue;
1213 case 'y': /* y-resolution */
1214 yrs = argv[++a];
1215 na = 0;
1216 continue;
1217 case 'c': /* number of samples */
1218 sampcnt = atoi(argv[++a]);
1219 if (sampcnt <= 0)
1220 goto userr;
1221 na = 0; /* we re-add this later */
1222 continue;
1223 case 'I': /* only for pass-through mode */
1224 wantIrradiance = 1;
1225 na = 0;
1226 continue;
1227 case 'V': /* options without arguments */
1228 case 'w':
1229 case 'u':
1230 case 'i':
1231 case 'h':
1232 case 'r':
1233 break;
1234 case 'n': /* options with 1 argument */
1235 case 's':
1236 case 'o':
1237 na = 2;
1238 break;
1239 case 'b': /* special case */
1240 if (argv[a][2] != 'v') goto userr;
1241 break;
1242 case 'l': /* special case */
1243 if (argv[a][2] == 'd') {
1244 ldopt = argv[a];
1245 na = 0;
1246 continue;
1247 }
1248 na = 2;
1249 break;
1250 case 'd': /* special case */
1251 if (argv[a][2] != 'v') na = 2;
1252 break;
1253 case 'a': /* special case */
1254 na = (argv[a][2] == 'v') ? 4 : 2;
1255 break;
1256 case 'm': /* special case */
1257 if (!argv[a][2]) goto userr;
1258 na = (argv[a][2] == 'e') | (argv[a][2] == 'a') ? 4 : 2;
1259 break;
1260 case '\0': /* pass-through mode */
1261 goto done_opts;
1262 default: /* anything else is verbotten */
1263 goto userr;
1264 }
1265 if (na <= 0) continue;
1266 CHECKARGC(na); /* pass on option */
1267 rcarg[nrcargs++] = argv[a];
1268 while (--na) /* + arguments if any */
1269 rcarg[nrcargs++] = argv[++a];
1270 }
1271 done_opts:
1272 if (a > argc-2)
1273 goto userr; /* check at end of options */
1274 sendfn = argv[a++]; /* assign sender & receiver inputs */
1275 if (sendfn[0] == '-') { /* user wants pass-through mode? */
1276 if (sendfn[1]) goto userr;
1277 sendfn = NULL;
1278 if (wantIrradiance) {
1279 CHECKARGC(1);
1280 rcarg[nrcargs++] = "-I";
1281 }
1282 if (xrs) {
1283 CHECKARGC(2);
1284 rcarg[nrcargs++] = "-x";
1285 rcarg[nrcargs++] = xrs;
1286 }
1287 if (yrs) {
1288 CHECKARGC(2);
1289 rcarg[nrcargs++] = "-y";
1290 rcarg[nrcargs++] = yrs;
1291 }
1292 if (ldopt) {
1293 CHECKARGC(1);
1294 rcarg[nrcargs++] = ldopt;
1295 }
1296 if (sampcnt <= 0) sampcnt = 1;
1297 } else { /* else in sampling mode */
1298 if (wantIrradiance) {
1299 fputs(progname, stderr);
1300 fputs(": -I supported for pass-through only\n", stderr);
1301 return(1);
1302 }
1303 fmtopt[2] = (sizeof(RREAL)==sizeof(double)) ? 'd' : 'f';
1304 if (sampcnt <= 0) sampcnt = 10000;
1305 }
1306 sprintf(sampcntbuf, "%d", sampcnt);
1307 CHECKARGC(3); /* add our format & sample count */
1308 rcarg[nrcargs++] = fmtopt;
1309 rcarg[nrcargs++] = "-c";
1310 rcarg[nrcargs++] = sampcntbuf;
1311 /* add receiver arguments to rcontrib */
1312 if (load_scene(argv[a], add_recv_object) < 0)
1313 return(1);
1314 finish_receiver();
1315 if (sendfn == NULL) { /* pass-through mode? */
1316 CHECKARGC(1); /* add octree */
1317 rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1318 rcarg[nrcargs] = NULL;
1319 return(my_exec(rcarg)); /* rcontrib does everything */
1320 }
1321 clear_params(&curparams, 0); /* else load sender surface & params */
1322 if (load_scene(sendfn, add_send_object) < 0)
1323 return(1);
1324 if ((nsbins = prepare_sampler()) <= 0)
1325 return(1);
1326 CHECKARGC(3); /* add row count and octree */
1327 rcarg[nrcargs++] = "-y";
1328 sprintf(nsbinbuf, "%d", nsbins);
1329 rcarg[nrcargs++] = nsbinbuf;
1330 rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1331 rcarg[nrcargs] = NULL;
1332 /* open pipe to rcontrib process */
1333 if ((rcfp = popen_arglist(rcarg, "w")) == NULL)
1334 return(1);
1335 SET_FILE_BINARY(rcfp);
1336 #ifdef getc_unlocked
1337 flockfile(rcfp);
1338 #endif
1339 if (verbose) {
1340 fprintf(stderr, "%s: sampling %d directions", progname, nsbins);
1341 if (curparams.nsurfs > 1)
1342 fprintf(stderr, " (%d elements)\n", curparams.nsurfs);
1343 else
1344 fputc('\n', stderr);
1345 }
1346 for (i = 0; i < nsbins; i++) /* send rcontrib ray samples */
1347 if (!(*curparams.sample_basis)(&curparams, i, rcfp))
1348 return(1);
1349 return(pclose(rcfp) == 0); /* all finished! */
1350 userr:
1351 if (a < argc-2)
1352 fprintf(stderr, "%s: unsupported option '%s'", progname, argv[a]);
1353 fprintf(stderr, "Usage: %s [-v][rcontrib options] sender.rad receiver.rad [system.rad ..]\n",
1354 progname);
1355 return(1);
1356 }
