root/radiance/ray/src/util/rfluxmtx.c
Revision: 2.47
Committed: Sun Mar 3 17:01:13 2019 UTC (6 years, 4 months ago) by greg
Changed test to strict zero because it can sometimes be that!
2 static const char RCSid[] = "$Id: rfluxmtx.c,v 2.46 2018/10/01 15:51:48 greg Exp $";
5 * Calculate flux transfer matrix or matrices using rcontrib
6 */
7
8 #include "copyright.h"
9
10 #include <ctype.h>
11 #include <stdlib.h>
12 #include "rtio.h"
13 #include "rtmath.h"
14 #include "paths.h"
15 #include "bsdf.h"
16 #include "bsdf_m.h"
17 #include "random.h"
18 #include "triangulate.h"
19 #include "platform.h"
20
21 #ifndef MAXRCARG
22 #define MAXRCARG 10000
23 #endif
24
25 char *progname; /* global argv[0] */
26
27 int verbose = 0; /* verbose mode (< 0 no warnings) */
28
29 char *rcarg[MAXRCARG+1] = {"rcontrib", "-fo+"};
30 int nrcargs = 2;
31
32 const char overflowerr[] = "%s: too many arguments!\n";
33
34 #define CHECKARGC(n) if (nrcargs >= MAXRCARG-(n)) \
35 { fprintf(stderr, overflowerr, progname); exit(1); }
36
37 int sampcnt = 0; /* sample count (0==unset) */
38
39 char *reinhfn = "reinhartb.cal";
40 char *shirchiufn = "disk2square.cal";
41 char *kfullfn = "klems_full.cal";
42 char *khalffn = "klems_half.cal";
43 char *kquarterfn = "klems_quarter.cal";
44
45 /* string indicating parameters */
46 const char PARAMSTART[] = "@rfluxmtx";
47
48 /* surface type IDs */
49 #define ST_NONE 0
50 #define ST_POLY 1
51 #define ST_RING 2
52 #define ST_SOURCE 3
53
54 typedef struct surf_s {
55 struct surf_s *next; /* next surface in list */
56 void *priv; /* private data (malloc'ed) */
57 char sname[32]; /* surface name */
58 FVECT snrm; /* surface normal */
59 double area; /* surface area / proj. solid angle */
60 short styp; /* surface type */
61 short nfargs; /* number of real arguments */
62 double farg[1]; /* real values (extends struct) */
63 } SURF; /* surface structure */
64
65 typedef struct {
66 FVECT uva[2]; /* tangent axes */
67 int ntris; /* number of triangles */
68 struct ptri {
69 double afrac; /* fraction of total area */
70 short vndx[3]; /* vertex indices */
71 } tri[1]; /* triangle array (extends struct) */
72 } POLYTRIS; /* triangulated polygon */
73
74 typedef struct param_s {
75 char sign; /* '-' for axis reversal */
76 char hemis[31]; /* hemispherical sampling spec. */
77 int hsiz; /* hemisphere basis size */
78 int nsurfs; /* number of surfaces */
79 SURF *slist; /* list of surfaces */
80 FVECT vup; /* up vector (zero if unset) */
81 FVECT nrm; /* average normal direction */
82 FVECT udir, vdir; /* tangent axes */
83 char *outfn; /* output file name (receiver) */
84 int (*sample_basis)(struct param_s *p, int, FILE *);
85 } PARAMS; /* sender/receiver parameters */
86
87 PARAMS curparams;
88 char curmod[128];
89 char newparams[1024];
90
91 typedef int SURFSAMP(FVECT, SURF *, double);
92
93 static SURFSAMP ssamp_bad, ssamp_poly, ssamp_ring;
94
95 SURFSAMP *orig_in_surf[4] = {
96 ssamp_bad, ssamp_poly, ssamp_ring, ssamp_bad
97 };
98
99 /* Clear parameter set */
100 static void
101 clear_params(PARAMS *p, int reset_only)
102 {
103 while (p->slist != NULL) {
104 SURF *sdel = p->slist;
105 p->slist = sdel->next;
106 if (sdel->priv != NULL)
107 free(sdel->priv);
108 free(sdel);
109 }
110 if (reset_only) {
111 p->nsurfs = 0;
112 memset(p->nrm, 0, sizeof(FVECT));
113 memset(p->vup, 0, sizeof(FVECT));
114 p->outfn = NULL;
115 return;
116 }
117 memset(p, 0, sizeof(PARAMS));
118 }
119
120 /* Get surface type from name */
121 static int
122 surf_type(const char *otype)
123 {
124 if (!strcmp(otype, "polygon"))
125 return(ST_POLY);
126 if (!strcmp(otype, "ring"))
127 return(ST_RING);
128 if (!strcmp(otype, "source"))
129 return(ST_SOURCE);
130 return(ST_NONE);
131 }
132
133 /* Add arguments to oconv command */
134 static char *
135 oconv_command(int ac, char *av[])
136 {
137 static char oconvbuf[2048] = "!oconv -f ";
138 char *cp = oconvbuf + 10;
139 char *recv = *av++;
140
141 if (ac-- <= 0)
142 return(NULL);
143 if (verbose < 0) { /* turn off warnings */
144 strcpy(cp, "-w- ");
145 cp += 4;
146 }
147 while (ac-- > 0) {
148 strcpy(cp, *av++);
149 while (*cp) cp++;
150 *cp++ = ' ';
151 if (cp >= oconvbuf+(sizeof(oconvbuf)-32))
152 goto overrun;
153 }
154 /* receiver goes last */
155 if (matchany(recv, SPECIALS)) {
156 *cp++ = QUOTCHAR;
157 while (*recv) {
158 if (cp >= oconvbuf+(sizeof(oconvbuf)-3))
159 goto overrun;
160 *cp++ = *recv++;
161 }
162 *cp++ = QUOTCHAR;
163 *cp = '\0';
164 } else
165 strcpy(cp, recv);
166 return(oconvbuf);
167 overrun:
168 fputs(progname, stderr);
169 fputs(": too many file arguments!\n", stderr);
170 exit(1);
171 }
172
173 /* Open a pipe to/from a command given as an argument list */
174 static FILE *
175 popen_arglist(char *av[], char *mode)
176 {
177 char cmd[10240];
178
179 if (!convert_commandline(cmd, sizeof(cmd), av)) {
180 fputs(progname, stderr);
181 fputs(": command line too long in popen_arglist()\n", stderr);
182 return(NULL);
183 }
184 if (verbose > 0)
185 fprintf(stderr, "%s: opening pipe %s: %s\n",
186 progname, (*mode=='w') ? "to" : "from", cmd);
187 return(popen(cmd, mode));
188 }
189
190 #if defined(_WIN32) || defined(_WIN64)
191 /* Execute system command (Windows version) */
192 static int
193 my_exec(char *av[])
194 {
195 char cmd[10240];
196
197 if (!convert_commandline(cmd, sizeof(cmd), av)) {
198 fputs(progname, stderr);
199 fputs(": command line too long in my_exec()\n", stderr);
200 return(1);
201 }
202 if (verbose > 0)
203 fprintf(stderr, "%s: running: %s\n", progname, cmd);
204 return(system(cmd));
205 }
206 #else
207 /* Execute system command in our stead (Unix version) */
208 static int
209 my_exec(char *av[])
210 {
211 char *compath;
212
213 if ((compath = getpath((char *)av[0], getenv("PATH"), X_OK)) == NULL) {
214 fprintf(stderr, "%s: cannot locate %s\n", progname, av[0]);
215 return(1);
216 }
217 if (verbose > 0) {
218 char cmd[4096];
219 if (!convert_commandline(cmd, sizeof(cmd), av))
220 strcpy(cmd, "COMMAND TOO LONG TO SHOW");
221 fprintf(stderr, "%s: running: %s\n", progname, cmd);
222 }
223 execv(compath, av); /* successful call never returns */
224 perror(compath);
225 return(1);
226 }
227 #endif
228
229 /* Get normalized direction vector from string specification */
230 static int
231 get_direction(FVECT dv, const char *s)
232 {
233 int sign = 1;
234 int axis = 0;
235
236 memset(dv, 0, sizeof(FVECT));
237 nextchar:
238 switch (*s) {
239 case '+':
240 ++s;
241 goto nextchar;
242 case '-':
243 sign = -sign;
244 ++s;
245 goto nextchar;
246 case 'z':
247 case 'Z':
248 ++axis;
249 case 'y':
250 case 'Y':
251 ++axis;
252 case 'x':
253 case 'X':
254 dv[axis] = sign;
255 return(!s[1] | isspace(s[1]));
256 default:
257 break;
258 }
259 #ifdef SMLFLT
260 if (sscanf(s, "%f,%f,%f", &dv[0], &dv[1], &dv[2]) != 3)
261 #else
262 if (sscanf(s, "%lf,%lf,%lf", &dv[0], &dv[1], &dv[2]) != 3)
263 #endif
264 return(0);
265 dv[0] *= (RREAL)sign;
266 return(normalize(dv) > 0);
267 }
268
269 /* Parse program parameters (directives) */
270 static int
271 parse_params(PARAMS *p, char *pargs)
272 {
273 char *cp = pargs;
274 int nparams = 0;
275 int quot;
276 int i;
277
278 for ( ; ; ) {
279 switch (*cp++) {
280 case 'h':
281 if (*cp++ != '=')
282 break;
283 if ((*cp == '+') | (*cp == '-'))
284 p->sign = *cp++;
285 else
286 p->sign = '+';
287 p->hsiz = 0;
288 i = 0;
289 while (*cp && !isspace(*cp)) {
290 if (isdigit(*cp))
291 p->hsiz = 10*p->hsiz + *cp - '0';
292 p->hemis[i++] = *cp++;
293 }
294 if (!i)
295 break;
296 p->hemis[i] = '\0';
297 p->hsiz += !p->hsiz;
298 ++nparams;
299 continue;
300 case 'u':
301 if (*cp++ != '=')
302 break;
303 if (!get_direction(p->vup, cp))
304 break;
305 while (*cp && !isspace(*cp++))
306 ;
307 ++nparams;
308 continue;
309 case 'o':
310 if (*cp++ != '=')
311 break;
312 quot = 0;
313 if ((*cp == '"') | (*cp == '\''))
314 quot = *cp++;
315 i = 0;
316 while (*cp && (quot ? (*cp != quot) : !isspace(*cp))) {
317 i++; cp++;
318 }
319 if (!i)
320 break;
321 if (!*cp) {
322 if (quot)
323 break;
324 cp[1] = '\0';
325 }
326 *cp = '\0';
327 p->outfn = savqstr(cp-i);
328 *cp++ = quot ? quot : ' ';
329 ++nparams;
330 continue;
331 case ' ':
332 case '\t':
333 case '\r':
334 case '\n':
335 continue;
336 case '\0':
337 return(nparams);
338 default:
339 break;
340 }
341 break;
342 }
343 fprintf(stderr, "%s: bad parameter string: %s", progname, pargs);
344 exit(1);
345 return(-1); /* pro forma return */
346 }
347
348 /* Add receiver arguments (directives) corresponding to the current modifier */
349 static void
350 finish_receiver(void)
351 {
352 char sbuf[256];
353 int uniform = 0;
354 char *calfn = NULL;
355 char *params = NULL;
356 char *binv = NULL;
357 char *binf = NULL;
358 char *nbins = NULL;
359
360 if (!curmod[0]) {
361 fputs(progname, stderr);
362 fputs(": missing receiver surface!\n", stderr);
363 exit(1);
364 }
365 if (curparams.outfn != NULL) { /* add output file spec. */
366 CHECKARGC(2);
367 rcarg[nrcargs++] = "-o";
368 rcarg[nrcargs++] = curparams.outfn;
369 }
370 /* check arguments */
371 if (!curparams.hemis[0]) {
372 fputs(progname, stderr);
373 fputs(": missing hemisphere sampling type!\n", stderr);
374 exit(1);
375 }
376 if (normalize(curparams.nrm) == 0) {
377 fputs(progname, stderr);
378 fputs(": undefined normal for hemisphere sampling\n", stderr);
379 exit(1);
380 }
381 if (normalize(curparams.vup) == 0) {
382 if (fabs(curparams.nrm[2]) < .7)
383 curparams.vup[2] = 1;
384 else
385 curparams.vup[1] = 1;
386 }
387 /* determine sample type/bin */
388 if ((tolower(curparams.hemis[0]) == 'u') | (curparams.hemis[0] == '1')) {
389 sprintf(sbuf, "if(-Dx*%g-Dy*%g-Dz*%g,0,-1)",
390 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2]);
391 binv = savqstr(sbuf);
392 nbins = "1"; /* uniform sampling -- one bin */
393 uniform = 1;
394 } else if (tolower(curparams.hemis[0]) == 's' &&
395 tolower(curparams.hemis[1]) == 'c') {
396 /* assign parameters */
397 if (curparams.hsiz <= 1) {
398 fputs(progname, stderr);
399 fputs(": missing size for Shirley-Chiu sampling!\n", stderr);
400 exit(1);
401 }
402 calfn = shirchiufn; shirchiufn = NULL;
403 sprintf(sbuf, "SCdim=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1",
404 curparams.hsiz,
405 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
406 curparams.vup[0], curparams.vup[1], curparams.vup[2],
407 curparams.sign);
408 params = savqstr(sbuf);
409 binv = "scbin";
410 nbins = "SCdim*SCdim";
411 } else if ((tolower(curparams.hemis[0]) == 'r') |
412 (tolower(curparams.hemis[0]) == 't')) {
413 calfn = reinhfn; reinhfn = NULL;
414 sprintf(sbuf, "MF=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1",
415 curparams.hsiz,
416 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
417 curparams.vup[0], curparams.vup[1], curparams.vup[2],
418 curparams.sign);
419 params = savqstr(sbuf);
420 binv = "rbin";
421 nbins = "Nrbins";
422 } else if (tolower(curparams.hemis[0]) == 'k' &&
423 !curparams.hemis[1] |
424 (tolower(curparams.hemis[1]) == 'f') |
425 (curparams.hemis[1] == '1')) {
426 calfn = kfullfn; kfullfn = NULL;
427 binf = "kbin";
428 nbins = "Nkbins";
429 } else if (tolower(curparams.hemis[0]) == 'k' &&
430 (tolower(curparams.hemis[1]) == 'h') |
431 (curparams.hemis[1] == '2')) {
432 calfn = khalffn; khalffn = NULL;
433 binf = "khbin";
434 nbins = "Nkhbins";
435 } else if (tolower(curparams.hemis[0]) == 'k' &&
436 (tolower(curparams.hemis[1]) == 'q') |
437 (curparams.hemis[1] == '4')) {
438 calfn = kquarterfn; kquarterfn = NULL;
439 binf = "kqbin";
440 nbins = "Nkqbins";
441 } else {
442 fprintf(stderr, "%s: unrecognized hemisphere sampling: h=%s\n",
443 progname, curparams.hemis);
444 exit(1);
445 }
446 if (tolower(curparams.hemis[0]) == 'k') {
447 sprintf(sbuf, "RHS=%c1", curparams.sign);
448 params = savqstr(sbuf);
449 }
450 if (!uniform & (curparams.slist->styp == ST_SOURCE)) {
451 SURF *sp;
452 for (sp = curparams.slist; sp != NULL; sp = sp->next)
453 if (fabs(sp->area - PI) > 1e-3) {
454 fprintf(stderr, "%s: source '%s' must be 180-degrees\n",
455 progname, sp->sname);
456 exit(1);
457 }
458 }
459 if (calfn != NULL) { /* add cal file if needed */
460 CHECKARGC(2);
461 rcarg[nrcargs++] = "-f";
462 rcarg[nrcargs++] = calfn;
463 }
464 if (params != NULL) { /* parameters _after_ cal file */
465 CHECKARGC(2);
466 rcarg[nrcargs++] = "-p";
467 rcarg[nrcargs++] = params;
468 }
469 if (nbins != NULL) { /* add #bins if set */
470 CHECKARGC(2);
471 rcarg[nrcargs++] = "-bn";
472 rcarg[nrcargs++] = nbins;
473 }
474 if (binv != NULL) {
475 CHECKARGC(2); /* assign bin variable */
476 rcarg[nrcargs++] = "-b";
477 rcarg[nrcargs++] = binv;
478 } else if (binf != NULL) {
479 CHECKARGC(2); /* assign bin function */
480 rcarg[nrcargs++] = "-b";
481 sprintf(sbuf, "%s(%g,%g,%g,%g,%g,%g)", binf,
482 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
483 curparams.vup[0], curparams.vup[1], curparams.vup[2]);
484 rcarg[nrcargs++] = savqstr(sbuf);
485 }
486 CHECKARGC(2); /* modifier argument goes last */
487 rcarg[nrcargs++] = "-m";
488 rcarg[nrcargs++] = savqstr(curmod);
489 }
490
491 /* Make randomly oriented tangent plane axes for given normal direction */
492 static void
493 make_axes(FVECT uva[2], const FVECT nrm)
494 {
495 int i;
496
497 if (!getperpendicular(uva[0], nrm, 1)) {
498 fputs(progname, stderr);
499 fputs(": bad surface normal in make_axes!\n", stderr);
500 exit(1);
501 }
502 fcross(uva[1], nrm, uva[0]);
503 }
504
505 /* Illegal sender surfaces end up here */
506 static int
507 ssamp_bad(FVECT orig, SURF *sp, double x)
508 {
509 fprintf(stderr, "%s: illegal sender surface '%s'\n",
510 progname, sp->sname);
511 return(0);
512 }
513
514 /* Generate origin on ring surface from uniform random variable */
515 static int
516 ssamp_ring(FVECT orig, SURF *sp, double x)
517 {
518 FVECT *uva = (FVECT *)sp->priv;
519 double samp2[2];
520 double uv[2];
521 int i;
522
523 if (uva == NULL) { /* need tangent axes */
524 uva = (FVECT *)malloc(sizeof(FVECT)*2);
525 if (uva == NULL) {
526 fputs(progname, stderr);
527 fputs(": out of memory in ssamp_ring!\n", stderr);
528 return(0);
529 }
530 make_axes(uva, sp->snrm);
531 sp->priv = (void *)uva;
532 }
533 SDmultiSamp(samp2, 2, x);
534 samp2[0] = sqrt(samp2[0]*sp->area*(1./PI) + sp->farg[6]*sp->farg[6]);
535 samp2[1] *= 2.*PI;
536 uv[0] = samp2[0]*tcos(samp2[1]);
537 uv[1] = samp2[0]*tsin(samp2[1]);
538 for (i = 3; i--; )
539 orig[i] = sp->farg[i] + uv[0]*uva[0][i] + uv[1]*uva[1][i];
540 return(1);
541 }
542
543 /* Add triangle to polygon's list (call-back function) */
544 static int
545 add_triangle(const Vert2_list *tp, int a, int b, int c)
546 {
547 POLYTRIS *ptp = (POLYTRIS *)tp->p;
548 struct ptri *trip = ptp->tri + ptp->ntris++;
549
550 trip->vndx[0] = a;
551 trip->vndx[1] = b;
552 trip->vndx[2] = c;
553 return(1);
554 }
555
556 /* Generate origin on polygon surface from uniform random variable */
557 static int
558 ssamp_poly(FVECT orig, SURF *sp, double x)
559 {
560 POLYTRIS *ptp = (POLYTRIS *)sp->priv;
561 double samp2[2];
562 double *v0, *v1, *v2;
563 int i;
564
565 if (ptp == NULL) { /* need to triangulate */
566 ptp = (POLYTRIS *)malloc(sizeof(POLYTRIS) +
567 sizeof(struct ptri)*(sp->nfargs/3 - 3));
568 if (ptp == NULL)
569 goto memerr;
570 if (sp->nfargs == 3) { /* simple case */
571 ptp->ntris = 1;
572 ptp->tri[0].vndx[0] = 0;
573 ptp->tri[0].vndx[1] = 1;
574 ptp->tri[0].vndx[2] = 2;
575 ptp->tri[0].afrac = 1;
576 } else {
577 Vert2_list *v2l = polyAlloc(sp->nfargs/3);
578 if (v2l == NULL)
579 goto memerr;
580 make_axes(ptp->uva, sp->snrm);
581 for (i = v2l->nv; i--; ) {
582 v2l->v[i].mX = DOT(sp->farg+3*i, ptp->uva[0]);
583 v2l->v[i].mY = DOT(sp->farg+3*i, ptp->uva[1]);
584 }
585 ptp->ntris = 0;
586 v2l->p = (void *)ptp;
587 if (!polyTriangulate(v2l, add_triangle)) {
588 fprintf(stderr,
589 "%s: cannot triangulate polygon '%s'\n",
590 progname, sp->sname);
591 return(0);
592 }
593 for (i = ptp->ntris; i--; ) {
594 int a = ptp->tri[i].vndx[0];
595 int b = ptp->tri[i].vndx[1];
596 int c = ptp->tri[i].vndx[2];
597 ptp->tri[i].afrac =
598 (v2l->v[a].mX*v2l->v[b].mY -
599 v2l->v[b].mX*v2l->v[a].mY +
600 v2l->v[b].mX*v2l->v[c].mY -
601 v2l->v[c].mX*v2l->v[b].mY +
602 v2l->v[c].mX*v2l->v[a].mY -
603 v2l->v[a].mX*v2l->v[c].mY) /
604 (2.*sp->area);
605 }
606 polyFree(v2l);
607 }
608 sp->priv = (void *)ptp;
609 }
610 /* pick triangle by partial area */
611 for (i = 0; i < ptp->ntris-1 && x > ptp->tri[i].afrac; i++)
612 x -= ptp->tri[i].afrac;
613 SDmultiSamp(samp2, 2, x/ptp->tri[i].afrac);
614 samp2[0] *= samp2[1] = sqrt(samp2[1]);
615 samp2[1] = 1. - samp2[1];
616 v0 = sp->farg + 3*ptp->tri[i].vndx[0];
617 v1 = sp->farg + 3*ptp->tri[i].vndx[1];
618 v2 = sp->farg + 3*ptp->tri[i].vndx[2];
619 for (i = 3; i--; )
620 orig[i] = v0[i] + samp2[0]*(v1[i] - v0[i])
621 + samp2[1]*(v2[i] - v0[i]) ;
622 return(1);
623 memerr:
624 fputs(progname, stderr);
625 fputs(": out of memory in ssamp_poly!\n", stderr);
626 return(0);
627 }
628
629 /* Compute sample origin based on projected areas of sender subsurfaces */
630 static int
631 sample_origin(PARAMS *p, FVECT orig, const FVECT rdir, double x)
632 {
633 static double *projsa;
634 static int nall;
635 double tarea = 0;
636 int i;
637 SURF *sp;
638 /* special case for lone surface */
639 if (p->nsurfs == 1) {
640 sp = p->slist;
641 if (DOT(sp->snrm, rdir) >= FTINY) {
642 fprintf(stderr,
643 "%s: internal - sample behind sender '%s'\n",
644 progname, sp->sname);
645 return(0);
646 }
647 return((*orig_in_surf[sp->styp])(orig, sp, x));
648 }
649 if (p->nsurfs > nall) { /* (re)allocate surface area cache */
650 if (projsa) free(projsa);
651 projsa = (double *)malloc(sizeof(double)*p->nsurfs);
652 if (projsa == NULL) {
653 fputs(progname, stderr);
654 fputs(": out of memory in sample_origin!\n", stderr);
655 exit(1);
656 }
657 nall = p->nsurfs;
658 }
659 /* compute projected areas */
660 for (i = 0, sp = p->slist; sp != NULL; i++, sp = sp->next) {
661 projsa[i] = -DOT(sp->snrm, rdir) * sp->area;
662 tarea += projsa[i] *= (double)(projsa[i] > FTINY);
663 }
664 if (tarea < 0) { /* wrong side of sender? */
665 fputs(progname, stderr);
666 fputs(": internal - sample behind all sender elements!\n",
667 stderr);
668 return(0);
669 }
670 tarea *= x; /* get surface from list */
671 for (i = 0, sp = p->slist; tarea > projsa[i]; sp = sp->next)
672 tarea -= projsa[i++];
673 return((*orig_in_surf[sp->styp])(orig, sp, tarea/projsa[i]));
674 }
675
676 /* Uniform sample generator */
677 static int
678 sample_uniform(PARAMS *p, int b, FILE *fp)
679 {
680 int n = sampcnt;
681 double samp3[3];
682 double duvw[3];
683 FVECT orig_dir[2];
684 int i;
685
686 if (fp == NULL) /* just requesting number of bins? */
687 return(1);
688
689 while (n--) { /* stratified hemisphere sampling */
690 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
691 SDsquare2disk(duvw, samp3[1], samp3[2]);
692 duvw[2] = -sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
693 for (i = 3; i--; )
694 orig_dir[1][i] = duvw[0]*p->udir[i] +
695 duvw[1]*p->vdir[i] +
696 duvw[2]*p->nrm[i] ;
697 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
698 return(0);
699 if (putbinary(orig_dir, sizeof(FVECT), 2, fp) != 2)
700 return(0);
701 }
702 return(1);
703 }
704
705 /* Shirly-Chiu sample generator */
706 static int
707 sample_shirchiu(PARAMS *p, int b, FILE *fp)
708 {
709 int n = sampcnt;
710 double samp3[3];
711 double duvw[3];
712 FVECT orig_dir[2];
713 int i;
714
715 if (fp == NULL) /* just requesting number of bins? */
716 return(p->hsiz*p->hsiz);
717
718 while (n--) { /* stratified sampling */
719 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
720 SDsquare2disk(duvw, (b/p->hsiz + samp3[1])/curparams.hsiz,
721 (b%p->hsiz + samp3[2])/curparams.hsiz);
722 duvw[2] = sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
723 for (i = 3; i--; )
724 orig_dir[1][i] = -duvw[0]*p->udir[i] -
725 duvw[1]*p->vdir[i] -
726 duvw[2]*p->nrm[i] ;
727 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
728 return(0);
729 if (putbinary(orig_dir, sizeof(FVECT), 2, fp) != 2)
730 return(0);
731 }
732 return(1);
733 }
734
735 /* Reinhart/Tregenza sample generator */
736 static int
737 sample_reinhart(PARAMS *p, int b, FILE *fp)
738 {
739 #define T_NALT 7
740 static const int tnaz[T_NALT] = {30, 30, 24, 24, 18, 12, 6};
741 const int RowMax = T_NALT*p->hsiz + 1;
742 const double RAH = (.5*PI)/(RowMax-.5);
743 #define rnaz(r) (r >= RowMax-1 ? 1 : p->hsiz*tnaz[r/p->hsiz])
744 int n = sampcnt;
745 int row, col;
746 double samp3[3];
747 double alt, azi;
748 double duvw[3];
749 FVECT orig_dir[2];
750 int i;
751
752 if (fp == NULL) { /* just requesting number of bins? */
753 n = 0;
754 for (row = RowMax; row--; ) n += rnaz(row);
755 return(n);
756 }
757 row = 0; /* identify row & column */
758 col = b;
759 while (col >= rnaz(row)) {
760 col -= rnaz(row);
761 ++row;
762 }
763 while (n--) { /* stratified sampling */
764 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
765 if (row >= RowMax-1) /* avoid crowding at zenith */
766 samp3[1] *= samp3[1];
767 alt = (row+samp3[1])*RAH;
768 azi = (2.*PI)*(col+samp3[2]-.5)/rnaz(row);
769 duvw[2] = cos(alt); /* measured from horizon */
770 duvw[0] = tsin(azi)*duvw[2];
771 duvw[1] = -tcos(azi)*duvw[2];
772 duvw[2] = sqrt(1. - duvw[2]*duvw[2]);
773 for (i = 3; i--; )
774 orig_dir[1][i] = -duvw[0]*p->udir[i] -
775 duvw[1]*p->vdir[i] -
776 duvw[2]*p->nrm[i] ;
777 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
778 return(0);
779 if (putbinary(orig_dir, sizeof(FVECT), 2, fp) != 2)
780 return(0);
781 }
782 return(1);
783 #undef rnaz
784 #undef T_NALT
785 }
786
787 /* Klems sample generator */
788 static int
789 sample_klems(PARAMS *p, int b, FILE *fp)
790 {
791 static const char bname[4][20] = {
792 "LBNL/Klems Full",
793 "LBNL/Klems Half",
794 "INTERNAL ERROR",
795 "LBNL/Klems Quarter"
796 };
797 static ANGLE_BASIS *kbasis[4];
798 const int bi = p->hemis[1] - '1';
799 int n = sampcnt;
800 double samp2[2];
801 double duvw[3];
802 FVECT orig_dir[2];
803 int i;
804
805 if (!kbasis[bi]) { /* need to get basis, first */
806 for (i = 4; i--; )
807 if (!strcasecmp(abase_list[i].name, bname[bi])) {
808 kbasis[bi] = &abase_list[i];
809 break;
810 }
811 if (i < 0) {
812 fprintf(stderr, "%s: unknown hemisphere basis '%s'\n",
813 progname, bname[bi]);
814 return(0);
815 }
816 }
817 if (fp == NULL) /* just requesting number of bins? */
818 return(kbasis[bi]->nangles);
819
820 while (n--) { /* stratified sampling */
821 SDmultiSamp(samp2, 2, (n+frandom())/sampcnt);
822 if (!fo_getvec(duvw, b+samp2[1], kbasis[bi]))
823 return(0);
824 for (i = 3; i--; )
825 orig_dir[1][i] = -duvw[0]*p->udir[i] -
826 duvw[1]*p->vdir[i] -
827 duvw[2]*p->nrm[i] ;
828 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp2[0]))
829 return(0);
830 if (putbinary(orig_dir, sizeof(FVECT), 2, fp) != 2)
831 return(0);
832 }
833 return(1);
834 }
835
836 /* Prepare hemisphere basis sampler that will send rays to rcontrib */
837 static int
838 prepare_sampler(void)
839 {
840 if (curparams.slist == NULL) { /* missing sample surface! */
841 fputs(progname, stderr);
842 fputs(": no sender surface!\n", stderr);
843 return(-1);
844 }
845 /* misplaced output file spec. */
846 if ((curparams.outfn != NULL) & (verbose >= 0))
847 fprintf(stderr, "%s: warning - ignoring output file in sender ('%s')\n",
848 progname, curparams.outfn);
849 /* check/set basis hemisphere */
850 if (!curparams.hemis[0]) {
851 fputs(progname, stderr);
852 fputs(": missing sender sampling type!\n", stderr);
853 return(-1);
854 }
855 if (normalize(curparams.nrm) == 0) {
856 fputs(progname, stderr);
857 fputs(": undefined normal for sender sampling\n", stderr);
858 return(-1);
859 }
860 if (normalize(curparams.vup) == 0) {
861 if (fabs(curparams.nrm[2]) < .7)
862 curparams.vup[2] = 1;
863 else
864 curparams.vup[1] = 1;
865 }
866 fcross(curparams.udir, curparams.vup, curparams.nrm);
867 if (normalize(curparams.udir) == 0) {
868 fputs(progname, stderr);
869 fputs(": up vector coincides with sender normal\n", stderr);
870 return(-1);
871 }
872 fcross(curparams.vdir, curparams.nrm, curparams.udir);
873 if (curparams.sign == '-') { /* left-handed coordinate system? */
874 curparams.udir[0] *= -1.;
875 curparams.udir[1] *= -1.;
876 curparams.udir[2] *= -1.;
877 }
878 if ((tolower(curparams.hemis[0]) == 'u') | (curparams.hemis[0] == '1'))
879 curparams.sample_basis = sample_uniform;
880 else if (tolower(curparams.hemis[0]) == 's' &&
881 tolower(curparams.hemis[1]) == 'c')
882 curparams.sample_basis = sample_shirchiu;
883 else if ((tolower(curparams.hemis[0]) == 'r') |
884 (tolower(curparams.hemis[0]) == 't'))
885 curparams.sample_basis = sample_reinhart;
886 else if (tolower(curparams.hemis[0]) == 'k') {
887 switch (curparams.hemis[1]) {
888 case '1':
889 case '2':
890 case '4':
891 break;
892 case 'f':
893 case 'F':
894 case '\0':
895 curparams.hemis[1] = '1';
896 break;
897 case 'h':
898 case 'H':
899 curparams.hemis[1] = '2';
900 break;
901 case 'q':
902 case 'Q':
903 curparams.hemis[1] = '4';
904 break;
905 default:
906 goto unrecognized;
907 }
908 curparams.hemis[2] = '\0';
909 curparams.sample_basis = sample_klems;
910 } else
911 goto unrecognized;
912 /* return number of bins */
913 return((*curparams.sample_basis)(&curparams,0,NULL));
914 unrecognized:
915 fprintf(stderr, "%s: unrecognized sender sampling: h=%s\n",
916 progname, curparams.hemis);
917 return(-1);
918 }
919
920 /* Compute normal and area for polygon */
921 static int
922 finish_polygon(SURF *p)
923 {
924 const int nv = p->nfargs / 3;
925 FVECT e1, e2, vc;
926 int i;
927
928 memset(p->snrm, 0, sizeof(FVECT));
929 VSUB(e1, p->farg+3, p->farg);
930 for (i = 2; i < nv; i++) {
931 VSUB(e2, p->farg+3*i, p->farg);
932 VCROSS(vc, e1, e2);
933 p->snrm[0] += vc[0];
934 p->snrm[1] += vc[1];
935 p->snrm[2] += vc[2];
936 VCOPY(e1, e2);
937 }
938 p->area = normalize(p->snrm)*0.5;
939 return(p->area > FTINY);
940 }
941
942 /* Add a surface to our current parameters */
943 static void
944 add_surface(int st, const char *oname, FILE *fp)
945 {
946 SURF *snew;
947 int n;
948 /* get floating-point arguments */
949 if (!fscanf(fp, "%d", &n)) return;
950 while (n-- > 0) fscanf(fp, "%*s");
951 if (!fscanf(fp, "%d", &n)) return;
952 while (n-- > 0) fscanf(fp, "%*d");
953 if (!fscanf(fp, "%d", &n) || n <= 0) return;
954 snew = (SURF *)malloc(sizeof(SURF) + sizeof(double)*(n-1));
955 if (snew == NULL) {
956 fputs(progname, stderr);
957 fputs(": out of memory in add_surface!\n", stderr);
958 exit(1);
959 }
960 strncpy(snew->sname, oname, sizeof(snew->sname)-1);
961 snew->sname[sizeof(snew->sname)-1] = '\0';
962 snew->styp = st;
963 snew->priv = NULL;
964 snew->nfargs = n;
965 for (n = 0; n < snew->nfargs; n++)
966 if (fscanf(fp, "%lf", &snew->farg[n]) != 1) {
967 fprintf(stderr, "%s: error reading arguments for '%s'\n",
968 progname, oname);
969 exit(1);
970 }
971 switch (st) {
972 case ST_RING:
973 if (snew->nfargs != 8)
974 goto badcount;
975 VCOPY(snew->snrm, snew->farg+3);
976 if (normalize(snew->snrm) == 0)
977 goto badnorm;
978 if (snew->farg[7] < snew->farg[6]) {
979 double t = snew->farg[7];
980 snew->farg[7] = snew->farg[6];
981 snew->farg[6] = t;
982 }
983 snew->area = PI*(snew->farg[7]*snew->farg[7] -
984 snew->farg[6]*snew->farg[6]);
985 break;
986 case ST_POLY:
987 if (snew->nfargs < 9 || snew->nfargs % 3)
988 goto badcount;
989 finish_polygon(snew);
990 break;
991 case ST_SOURCE:
992 if (snew->nfargs != 4)
993 goto badcount;
994 for (n = 3; n--; ) /* need to reverse "normal" */
995 snew->snrm[n] = -snew->farg[n];
996 if (normalize(snew->snrm) == 0)
997 goto badnorm;
998 snew->area = sin((PI/180./2.)*snew->farg[3]);
999 snew->area *= PI*snew->area;
1000 break;
1001 }
1002 if ((snew->area <= FTINY) & (verbose >= 0)) {
1003 fprintf(stderr, "%s: warning - zero area for surface '%s'\n",
1004 progname, oname);
1005 free(snew);
1006 return;
1007 }
1008 VSUM(curparams.nrm, curparams.nrm, snew->snrm, snew->area);
1009 snew->next = curparams.slist;
1010 curparams.slist = snew;
1011 curparams.nsurfs++;
1012 return;
1013 badcount:
1014 fprintf(stderr, "%s: bad argument count for surface element '%s'\n",
1015 progname, oname);
1016 exit(1);
1017 badnorm:
1018 fprintf(stderr, "%s: bad orientation for surface element '%s'\n",
1019 progname, oname);
1020 exit(1);
1021 }
1022
1023 /* Parse a receiver object (look for modifiers to add to rcontrib command) */
1024 static int
1025 add_recv_object(FILE *fp)
1026 {
1027 int st;
1028 char thismod[128], otype[32], oname[128];
1029 int n;
1030
1031 if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3)
1032 return(0); /* must have hit EOF! */
1033 if (!strcmp(otype, "alias")) {
1034 fscanf(fp, "%*s"); /* skip alias */
1035 return(0);
1036 }
1037 /* is it a new receiver? */
1038 if ((st = surf_type(otype)) != ST_NONE) {
1039 if (curparams.slist != NULL && (st == ST_SOURCE) ^
1040 (curparams.slist->styp == ST_SOURCE)) {
1041 fputs(progname, stderr);
1042 fputs(": cannot mix source/non-source receivers!\n", stderr);
1043 return(-1);
1044 }
1045 if (strcmp(thismod, curmod)) {
1046 if (curmod[0]) { /* output last receiver? */
1047 finish_receiver();
1048 clear_params(&curparams, 1);
1049 }
1050 parse_params(&curparams, newparams);
1051 newparams[0] = '\0';
1052 strcpy(curmod, thismod);
1053 }
1054 add_surface(st, oname, fp); /* read & store surface */
1055 return(1);
1056 }
1057 /* else skip arguments */
1058 if (!fscanf(fp, "%d", &n)) return(0);
1059 while (n-- > 0) fscanf(fp, "%*s");
1060 if (!fscanf(fp, "%d", &n)) return(0);
1061 while (n-- > 0) fscanf(fp, "%*d");
1062 if (!fscanf(fp, "%d", &n)) return(0);
1063 while (n-- > 0) fscanf(fp, "%*f");
1064 return(0);
1065 }
1066
1067 /* Parse a sender object */
1068 static int
1069 add_send_object(FILE *fp)
1070 {
1071 int st;
1072 char thismod[128], otype[32], oname[128];
1073 int n;
1074
1075 if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3)
1076 return(0); /* must have hit EOF! */
1077 if (!strcmp(otype, "alias")) {
1078 fscanf(fp, "%*s"); /* skip alias */
1079 return(0);
1080 }
1081 /* is it a new surface? */
1082 if ((st = surf_type(otype)) != ST_NONE) {
1083 if (st == ST_SOURCE) {
1084 fputs(progname, stderr);
1085 fputs(": cannot use source as a sender!\n", stderr);
1086 return(-1);
1087 }
1088 if (strcmp(thismod, curmod)) {
1089 if (curmod[0]) {
1090 fputs(progname, stderr);
1091 fputs(": warning - multiple modifiers in sender\n",
1092 stderr);
1093 }
1094 strcpy(curmod, thismod);
1095 }
1096 parse_params(&curparams, newparams);
1097 newparams[0] = '\0';
1098 add_surface(st, oname, fp); /* read & store surface */
1099 return(0);
1100 }
1101 /* else skip arguments */
1102 if (!fscanf(fp, "%d", &n)) return(0);
1103 while (n-- > 0) fscanf(fp, "%*s");
1104 if (!fscanf(fp, "%d", &n)) return(0);
1105 while (n-- > 0) fscanf(fp, "%*d");
1106 if (!fscanf(fp, "%d", &n)) return(0);
1107 while (n-- > 0) fscanf(fp, "%*f");
1108 return(0);
1109 }
1110
1111 /* Load a Radiance scene using the given callback function for objects */
1112 static int
1113 load_scene(const char *inspec, int (*ocb)(FILE *))
1114 {
1115 int rv = 0;
1116 char inpbuf[1024];
1117 FILE *fp;
1118 int c;
1119
1120 if (*inspec == '!')
1121 fp = popen(inspec+1, "r");
1122 else
1123 fp = fopen(inspec, "r");
1124 if (fp == NULL) {
1125 fprintf(stderr, "%s: cannot load '%s'\n", progname, inspec);
1126 return(-1);
1127 }
1128 while ((c = getc(fp)) != EOF) { /* load receiver data */
1129 if (isspace(c)) /* skip leading white space */
1130 continue;
1131 if (c == '!') { /* read from a new command */
1132 inpbuf[0] = c;
1133 if (fgetline(inpbuf+1, sizeof(inpbuf)-1, fp) != NULL) {
1134 if ((c = load_scene(inpbuf, ocb)) < 0)
1135 return(c);
1136 rv += c;
1137 }
1138 continue;
1139 }
1140 if (c == '#') { /* parameters/comment */
1141 if ((c = getc(fp)) == EOF || ungetc(c,fp) == EOF)
1142 break;
1143 if (!isspace(c) && fscanf(fp, "%s", inpbuf) == 1 &&
1144 !strcmp(inpbuf, PARAMSTART)) {
1145 if (fgets(inpbuf, sizeof(inpbuf), fp) != NULL)
1146 strcat(newparams, inpbuf);
1147 continue;
1148 }
1149 while ((c = getc(fp)) != EOF && c != '\n')
1150 ; /* else skipping comment */
1151 continue;
1152 }
1153 ungetc(c, fp); /* else check object for receiver */
1154 c = (*ocb)(fp);
1155 if (c < 0)
1156 return(c);
1157 rv += c;
1158 }
1159 /* close our input stream */
1160 c = (*inspec == '!') ? pclose(fp) : fclose(fp);
1161 if (c != 0) {
1162 fprintf(stderr, "%s: error loading '%s'\n", progname, inspec);
1163 return(-1);
1164 }
1165 return(rv);
1166 }
1167
1168 /* Get command arguments and run program */
1169 int
1170 main(int argc, char *argv[])
1171 {
1172 char fmtopt[6] = "-faa"; /* default output is ASCII */
1173 char *xrs=NULL, *yrs=NULL, *ldopt=NULL;
1174 char *iropt = NULL;
1175 char *sendfn;
1176 char sampcntbuf[32], nsbinbuf[32];
1177 FILE *rcfp;
1178 int nsbins;
1179 int a, i;
1180 /* screen rcontrib options */
1181 progname = argv[0];
1182 for (a = 1; a < argc-2; a++) {
1183 int na;
1184 /* check for argument expansion */
1185 while ((na = expandarg(&argc, &argv, a)) > 0)
1186 ;
1187 if (na < 0) {
1188 fprintf(stderr, "%s: cannot expand '%s'\n",
1189 progname, argv[a]);
1190 return(1);
1191 }
1192 if (argv[a][0] != '-' || !argv[a][1])
1193 break;
1194 na = 1;
1195 switch (argv[a][1]) { /* !! Keep consistent !! */
1196 case 'v': /* verbose mode */
1197 verbose = 1;
1198 na = 0;
1199 continue;
1200 case 'f': /* special case for -fo, -ff, etc. */
1201 switch (argv[a][2]) {
1202 case '\0': /* cal file */
1203 goto userr;
1204 case 'o': /* force output */
1205 goto userr;
1206 case 'a': /* output format */
1207 case 'f':
1208 case 'd':
1209 case 'c':
1210 if (!(fmtopt[3] = argv[a][3]))
1211 fmtopt[3] = argv[a][2];
1212 fmtopt[2] = argv[a][2];
1213 na = 0;
1214 continue; /* will pass later */
1215 default:
1216 goto userr;
1217 }
1218 break;
1219 case 'x': /* x-resolution */
1220 xrs = argv[++a];
1221 na = 0;
1222 continue;
1223 case 'y': /* y-resolution */
1224 yrs = argv[++a];
1225 na = 0;
1226 continue;
1227 case 'c': /* number of samples */
1228 sampcnt = atoi(argv[++a]);
1229 if (sampcnt <= 0)
1230 goto userr;
1231 na = 0; /* we re-add this later */
1232 continue;
1233 case 'I': /* only for pass-through mode */
1234 case 'i':
1235 iropt = argv[a];
1236 na = 0;
1237 continue;
1238 case 'w': /* options without arguments */
1239 if (argv[a][2] != '+') verbose = -1;
1240 case 'V':
1241 case 'u':
1242 case 'h':
1243 case 'r':
1244 break;
1245 case 'n': /* options with 1 argument */
1246 case 's':
1247 case 'o':
1248 na = 2;
1249 break;
1250 case 'b': /* special case */
1251 if (argv[a][2] != 'v') goto userr;
1252 break;
1253 case 'l': /* special case */
1254 if (argv[a][2] == 'd') {
1255 ldopt = argv[a];
1256 na = 0;
1257 continue;
1258 }
1259 na = 2;
1260 break;
1261 case 'd': /* special case */
1262 if (argv[a][2] != 'v') na = 2;
1263 break;
1264 case 'a': /* special case */
1265 if (argv[a][2] == 'p') {
1266 na = 2; /* photon map [+ bandwidth(s)] */
1267 if (a < argc-3 && atoi(argv[a+1]) > 0)
1268 na += 1 + (a < argc-4 && atoi(argv[a+2]) > 0);
1269 } else
1270 na = (argv[a][2] == 'v') ? 4 : 2;
1271 break;
1272 case 'm': /* special case */
1273 if (!argv[a][2]) goto userr;
1274 na = (argv[a][2] == 'e') | (argv[a][2] == 'a') ? 4 : 2;
1275 break;
1276 default: /* anything else is verbotten */
1277 goto userr;
1278 }
1279 if (na <= 0) continue;
1280 CHECKARGC(na); /* pass on option */
1281 rcarg[nrcargs++] = argv[a];
1282 while (--na) /* + arguments if any */
1283 rcarg[nrcargs++] = argv[++a];
1284 }
1285 if (a > argc-2)
1286 goto userr; /* check at end of options */
1287 sendfn = argv[a++]; /* assign sender & receiver inputs */
1288 if (sendfn[0] == '-') { /* user wants pass-through mode? */
1289 if (sendfn[1]) goto userr;
1290 sendfn = NULL;
1291 if (iropt) {
1292 CHECKARGC(1);
1293 rcarg[nrcargs++] = iropt;
1294 }
1295 if (xrs) {
1296 CHECKARGC(2);
1297 rcarg[nrcargs++] = "-x";
1298 rcarg[nrcargs++] = xrs;
1299 }
1300 if (yrs) {
1301 CHECKARGC(2);
1302 rcarg[nrcargs++] = "-y";
1303 rcarg[nrcargs++] = yrs;
1304 }
1305 if (ldopt) {
1306 CHECKARGC(1);
1307 rcarg[nrcargs++] = ldopt;
1308 }
1309 if (sampcnt <= 0) sampcnt = 1;
1310 } else { /* else in sampling mode */
1311 if (iropt) {
1312 fputs(progname, stderr);
1313 fputs(": -i, -I supported for pass-through only\n", stderr);
1314 return(1);
1315 }
1316 #ifdef SMLFLT
1317 fmtopt[2] = 'f';
1318 #else
1319 fmtopt[2] = 'd';
1320 #endif
1321 if (sampcnt <= 0) sampcnt = 10000;
1322 }
1323 sprintf(sampcntbuf, "%d", sampcnt);
1324 CHECKARGC(3); /* add our format & sample count */
1325 rcarg[nrcargs++] = fmtopt;
1326 rcarg[nrcargs++] = "-c";
1327 rcarg[nrcargs++] = sampcntbuf;
1328 /* add receiver arguments to rcontrib */
1329 if (load_scene(argv[a], add_recv_object) < 0)
1330 return(1);
1331 finish_receiver();
1332 if (sendfn == NULL) { /* pass-through mode? */
1333 CHECKARGC(1); /* add octree */
1334 rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1335 rcarg[nrcargs] = NULL;
1336 return(my_exec(rcarg)); /* rcontrib does everything */
1337 }
1338 clear_params(&curparams, 0); /* else load sender surface & params */
1339 curmod[0] = '\0';
1340 if (load_scene(sendfn, add_send_object) < 0)
1341 return(1);
1342 if ((nsbins = prepare_sampler()) <= 0)
1343 return(1);
1344 CHECKARGC(3); /* add row count and octree */
1345 rcarg[nrcargs++] = "-y";
1346 sprintf(nsbinbuf, "%d", nsbins);
1347 rcarg[nrcargs++] = nsbinbuf;
1348 rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1349 rcarg[nrcargs] = NULL;
1350 /* open pipe to rcontrib process */
1351 if ((rcfp = popen_arglist(rcarg, "w")) == NULL)
1352 return(1);
1353 SET_FILE_BINARY(rcfp);
1354 #ifdef getc_unlocked
1355 flockfile(rcfp);
1356 #endif
1357 if (verbose > 0) {
1358 fprintf(stderr, "%s: sampling %d directions", progname, nsbins);
1359 if (curparams.nsurfs > 1)
1360 fprintf(stderr, " (%d elements)\n", curparams.nsurfs);
1361 else
1362 fputc('\n', stderr);
1363 }
1364 for (i = 0; i < nsbins; i++) /* send rcontrib ray samples */
1365 if (!(*curparams.sample_basis)(&curparams, i, rcfp))
1366 return(1);
1367 return(pclose(rcfp) < 0); /* all finished! */
1368 userr:
1369 if (a < argc-2)
1370 fprintf(stderr, "%s: unsupported option '%s'", progname, argv[a]);
1371 fprintf(stderr, "Usage: %s [-v][rcontrib options] sender.rad receiver.rad [-i system.oct] [system.rad ..]\n",
1372 progname);
1373 return(1);
1374 }
