root/radiance/ray/src/util/rfluxmtx.c
Revision: 2.35
Committed: Fri Mar 4 00:21:21 2016 UTC (9 years, 4 months ago) by greg
Changes since 2.34: +1 -6 lines
2 static const char RCSid[] = "$Id: rfluxmtx.c,v 2.34 2016/02/02 18:02:32 greg Exp $";
5 * Calculate flux transfer matrix or matrices using rcontrib
6 */
7
8 #include "copyright.h"
9
10 #include <ctype.h>
11 #include <stdlib.h>
12 #include "rtio.h"
13 #include "rtmath.h"
14 #include "paths.h"
15 #include "bsdf.h"
16 #include "bsdf_m.h"
17 #include "random.h"
18 #include "triangulate.h"
19 #include "platform.h"
20
21 #define MAXRCARG 512
22
23 char *progname; /* global argv[0] */
24
25 int verbose = 0; /* verbose mode (< 0 no warnings) */
26
27 char *rcarg[MAXRCARG+1] = {"rcontrib", "-fo+"};
28 int nrcargs = 2;
29
30 const char overflowerr[] = "%s: too many arguments!\n";
31
32 #define CHECKARGC(n) if (nrcargs >= MAXRCARG-(n)) \
33 { fprintf(stderr, overflowerr, progname); exit(1); }
34
35 int sampcnt = 0; /* sample count (0==unset) */
36
37 char *reinhfn = "reinhartb.cal";
38 char *shirchiufn = "disk2square.cal";
39 char *kfullfn = "klems_full.cal";
40 char *khalffn = "klems_half.cal";
41 char *kquarterfn = "klems_quarter.cal";
42
43 /* string indicating parameters */
44 const char PARAMSTART[] = "@rfluxmtx";
45
46 /* surface type IDs */
47 #define ST_NONE 0
48 #define ST_POLY 1
49 #define ST_RING 2
50 #define ST_SOURCE 3
51
52 typedef struct surf_s {
53 struct surf_s *next; /* next surface in list */
54 void *priv; /* private data (malloc'ed) */
55 char sname[32]; /* surface name */
56 FVECT snrm; /* surface normal */
57 double area; /* surface area / proj. solid angle */
58 short styp; /* surface type */
59 short nfargs; /* number of real arguments */
60 double farg[1]; /* real values (extends struct) */
61 } SURF; /* surface structure */
62
63 typedef struct {
64 FVECT uva[2]; /* tangent axes */
65 int ntris; /* number of triangles */
66 struct ptri {
67 float afrac; /* fraction of total area */
68 short vndx[3]; /* vertex indices */
69 } tri[1]; /* triangle array (extends struct) */
70 } POLYTRIS; /* triangulated polygon */
71
72 typedef struct param_s {
73 char sign; /* '-' for axis reversal */
74 char hemis[31]; /* hemispherical sampling spec. */
75 int hsiz; /* hemisphere basis size */
76 int nsurfs; /* number of surfaces */
77 SURF *slist; /* list of surfaces */
78 FVECT vup; /* up vector (zero if unset) */
79 FVECT nrm; /* average normal direction */
80 FVECT udir, vdir; /* tangent axes */
81 char *outfn; /* output file name (receiver) */
82 int (*sample_basis)(struct param_s *p, int, FILE *);
83 } PARAMS; /* sender/receiver parameters */
84
85 PARAMS curparams;
86 char curmod[128];
87 char newparams[1024];
88
89 typedef int SURFSAMP(FVECT, SURF *, double);
90
91 static SURFSAMP ssamp_bad, ssamp_poly, ssamp_ring;
92
93 SURFSAMP *orig_in_surf[4] = {
94 ssamp_bad, ssamp_poly, ssamp_ring, ssamp_bad
95 };
96
97 /* Clear parameter set */
98 static void
99 clear_params(PARAMS *p, int reset_only)
100 {
101 while (p->slist != NULL) {
102 SURF *sdel = p->slist;
103 p->slist = sdel->next;
104 if (sdel->priv != NULL)
105 free(sdel->priv);
106 free(sdel);
107 }
108 if (reset_only) {
109 p->nsurfs = 0;
110 memset(p->nrm, 0, sizeof(FVECT));
111 memset(p->vup, 0, sizeof(FVECT));
112 p->outfn = NULL;
113 return;
114 }
115 memset(p, 0, sizeof(PARAMS));
116 }
117
118 /* Get surface type from name */
119 static int
120 surf_type(const char *otype)
121 {
122 if (!strcmp(otype, "polygon"))
123 return(ST_POLY);
124 if (!strcmp(otype, "ring"))
125 return(ST_RING);
126 if (!strcmp(otype, "source"))
127 return(ST_SOURCE);
128 return(ST_NONE);
129 }
130
131 /* Add arguments to oconv command */
132 static char *
133 oconv_command(int ac, char *av[])
134 {
135 static char oconvbuf[2048] = "!oconv -f ";
136 char *cp = oconvbuf + 10;
137 char *recv = *av++;
138
139 if (ac-- <= 0)
140 return(NULL);
141 while (ac-- > 0) {
142 strcpy(cp, *av++);
143 while (*cp) cp++;
144 *cp++ = ' ';
145 if (cp >= oconvbuf+(sizeof(oconvbuf)-32))
146 goto overrun;
147 }
148 /* receiver goes last */
149 if (matchany(recv, SPECIALS)) {
150 *cp++ = QUOTCHAR;
151 while (*recv) {
152 if (cp >= oconvbuf+(sizeof(oconvbuf)-3))
153 goto overrun;
154 *cp++ = *recv++;
155 }
156 *cp++ = QUOTCHAR;
157 *cp = '\0';
158 } else
159 strcpy(cp, recv);
160 return(oconvbuf);
161 overrun:
162 fputs(progname, stderr);
163 fputs(": too many file arguments!\n", stderr);
164 exit(1);
165 }
166
167 /* Open a pipe to/from a command given as an argument list */
168 static FILE *
169 popen_arglist(char *av[], char *mode)
170 {
171 char cmd[10240];
172
173 if (!convert_commandline(cmd, sizeof(cmd), av)) {
174 fputs(progname, stderr);
175 fputs(": command line too long in popen_arglist()\n", stderr);
176 return(NULL);
177 }
178 if (verbose > 0)
179 fprintf(stderr, "%s: opening pipe %s: %s\n",
180 progname, (*mode=='w') ? "to" : "from", cmd);
181 return(popen(cmd, mode));
182 }
183
184 #ifdef _WIN32
185 /* Execute system command (Windows version) */
186 static int
187 my_exec(char *av[])
188 {
189 char cmd[10240];
190
191 if (!convert_commandline(cmd, sizeof(cmd), av)) {
192 fputs(progname, stderr);
193 fputs(": command line too long in my_exec()\n", stderr);
194 return(1);
195 }
196 if (verbose > 0)
197 fprintf(stderr, "%s: running: %s\n", progname, cmd);
198 return(system(cmd));
199 }
200 #else
201 /* Execute system command in our stead (Unix version) */
202 static int
203 my_exec(char *av[])
204 {
205 char *compath;
206
207 if ((compath = getpath((char *)av[0], getenv("PATH"), X_OK)) == NULL) {
208 fprintf(stderr, "%s: cannot locate %s\n", progname, av[0]);
209 return(1);
210 }
211 if (verbose > 0) {
212 char cmd[4096];
213 if (!convert_commandline(cmd, sizeof(cmd), av))
214 strcpy(cmd, "COMMAND TOO LONG TO SHOW");
215 fprintf(stderr, "%s: running: %s\n", progname, cmd);
216 }
217 execv(compath, av); /* successful call never returns */
218 perror(compath);
219 return(1);
220 }
221 #endif
222
223 /* Get normalized direction vector from string specification */
224 static int
225 get_direction(FVECT dv, const char *s)
226 {
227 int sign = 1;
228 int axis = 0;
229
230 memset(dv, 0, sizeof(FVECT));
231 nextchar:
232 switch (*s) {
233 case '+':
234 ++s;
235 goto nextchar;
236 case '-':
237 sign = -sign;
238 ++s;
239 goto nextchar;
240 case 'z':
241 case 'Z':
242 ++axis;
243 case 'y':
244 case 'Y':
245 ++axis;
246 case 'x':
247 case 'X':
248 dv[axis] = sign;
249 return(!s[1] | isspace(s[1]));
250 default:
251 break;
252 }
253 #ifdef SMLFLT
254 if (sscanf(s, "%f,%f,%f", &dv[0], &dv[1], &dv[2]) != 3)
255 #else
256 if (sscanf(s, "%lf,%lf,%lf", &dv[0], &dv[1], &dv[2]) != 3)
257 #endif
258 return(0);
259 dv[0] *= (RREAL)sign;
260 return(normalize(dv) > 0);
261 }
262
263 /* Parse program parameters (directives) */
264 static int
265 parse_params(PARAMS *p, char *pargs)
266 {
267 char *cp = pargs;
268 int nparams = 0;
269 int quot;
270 int i;
271
272 for ( ; ; ) {
273 switch (*cp++) {
274 case 'h':
275 if (*cp++ != '=')
276 break;
277 if ((*cp == '+') | (*cp == '-'))
278 p->sign = *cp++;
279 else
280 p->sign = '+';
281 p->hsiz = 0;
282 i = 0;
283 while (*cp && !isspace(*cp)) {
284 if (isdigit(*cp))
285 p->hsiz = 10*p->hsiz + *cp - '0';
286 p->hemis[i++] = *cp++;
287 }
288 if (!i)
289 break;
290 p->hemis[i] = '\0';
291 p->hsiz += !p->hsiz;
292 ++nparams;
293 continue;
294 case 'u':
295 if (*cp++ != '=')
296 break;
297 if (!get_direction(p->vup, cp))
298 break;
299 while (*cp && !isspace(*cp++))
300 ;
301 ++nparams;
302 continue;
303 case 'o':
304 if (*cp++ != '=')
305 break;
306 quot = 0;
307 if ((*cp == '"') | (*cp == '\''))
308 quot = *cp++;
309 i = 0;
310 while (*cp && (quot ? (*cp != quot) : !isspace(*cp))) {
311 i++; cp++;
312 }
313 if (!i)
314 break;
315 if (!*cp) {
316 if (quot)
317 break;
318 cp[1] = '\0';
319 }
320 *cp = '\0';
321 p->outfn = savqstr(cp-i);
322 *cp++ = quot ? quot : ' ';
323 ++nparams;
324 continue;
325 case ' ':
326 case '\t':
327 case '\r':
328 case '\n':
329 continue;
330 case '\0':
331 return(nparams);
332 default:
333 break;
334 }
335 break;
336 }
337 fprintf(stderr, "%s: bad parameter string: %s", progname, pargs);
338 exit(1);
339 return(-1); /* pro forma return */
340 }
341
342 /* Add receiver arguments (directives) corresponding to the current modifier */
343 static void
344 finish_receiver(void)
345 {
346 char sbuf[256];
347 int uniform = 0;
348 char *calfn = NULL;
349 char *params = NULL;
350 char *binv = NULL;
351 char *binf = NULL;
352 char *nbins = NULL;
353
354 if (!curmod[0]) {
355 fputs(progname, stderr);
356 fputs(": missing receiver surface!\n", stderr);
357 exit(1);
358 }
359 if (curparams.outfn != NULL) { /* add output file spec. */
360 CHECKARGC(2);
361 rcarg[nrcargs++] = "-o";
362 rcarg[nrcargs++] = curparams.outfn;
363 }
364 /* check arguments */
365 if (!curparams.hemis[0]) {
366 fputs(progname, stderr);
367 fputs(": missing hemisphere sampling type!\n", stderr);
368 exit(1);
369 }
370 if (normalize(curparams.nrm) == 0) {
371 fputs(progname, stderr);
372 fputs(": undefined normal for hemisphere sampling\n", stderr);
373 exit(1);
374 }
375 if (normalize(curparams.vup) == 0) {
376 if (fabs(curparams.nrm[2]) < .7)
377 curparams.vup[2] = 1;
378 else
379 curparams.vup[1] = 1;
380 }
381 /* determine sample type/bin */
382 if (tolower(curparams.hemis[0]) == 'u' | curparams.hemis[0] == '1') {
383 sprintf(sbuf, "if(-Dx*%g-Dy*%g-Dz*%g,0,-1)",
384 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2]);
385 binv = savqstr(sbuf);
386 nbins = "1"; /* uniform sampling -- one bin */
387 uniform = 1;
388 } else if (tolower(curparams.hemis[0]) == 's' &&
389 tolower(curparams.hemis[1]) == 'c') {
390 /* assign parameters */
391 if (curparams.hsiz <= 1) {
392 fputs(progname, stderr);
393 fputs(": missing size for Shirley-Chiu sampling!\n", stderr);
394 exit(1);
395 }
396 calfn = shirchiufn; shirchiufn = NULL;
397 sprintf(sbuf, "SCdim=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1",
398 curparams.hsiz,
399 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
400 curparams.vup[0], curparams.vup[1], curparams.vup[2],
401 curparams.sign);
402 params = savqstr(sbuf);
403 binv = "scbin";
404 nbins = "SCdim*SCdim";
405 } else if ((tolower(curparams.hemis[0]) == 'r') |
406 (tolower(curparams.hemis[0]) == 't')) {
407 calfn = reinhfn; reinhfn = NULL;
408 sprintf(sbuf, "MF=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1",
409 curparams.hsiz,
410 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
411 curparams.vup[0], curparams.vup[1], curparams.vup[2],
412 curparams.sign);
413 params = savqstr(sbuf);
414 binv = "rbin";
415 nbins = "Nrbins";
416 } else if (tolower(curparams.hemis[0]) == 'k' &&
417 !curparams.hemis[1] |
418 (tolower(curparams.hemis[1]) == 'f') |
419 (curparams.hemis[1] == '1')) {
420 calfn = kfullfn; kfullfn = NULL;
421 binf = "kbin";
422 nbins = "Nkbins";
423 } else if (tolower(curparams.hemis[0]) == 'k' &&
424 (tolower(curparams.hemis[1]) == 'h') |
425 (curparams.hemis[1] == '2')) {
426 calfn = khalffn; khalffn = NULL;
427 binf = "khbin";
428 nbins = "Nkhbins";
429 } else if (tolower(curparams.hemis[0]) == 'k' &&
430 (tolower(curparams.hemis[1]) == 'q') |
431 (curparams.hemis[1] == '4')) {
432 calfn = kquarterfn; kquarterfn = NULL;
433 binf = "kqbin";
434 nbins = "Nkqbins";
435 } else {
436 fprintf(stderr, "%s: unrecognized hemisphere sampling: h=%s\n",
437 progname, curparams.hemis);
438 exit(1);
439 }
440 if (tolower(curparams.hemis[0]) == 'k') {
441 sprintf(sbuf, "RHS=%c1", curparams.sign);
442 params = savqstr(sbuf);
443 }
444 if (!uniform & (curparams.slist->styp == ST_SOURCE)) {
445 SURF *sp;
446 for (sp = curparams.slist; sp != NULL; sp = sp->next)
447 if (fabs(sp->area - PI) > 1e-3) {
448 fprintf(stderr, "%s: source '%s' must be 180-degrees\n",
449 progname, sp->sname);
450 exit(1);
451 }
452 }
453 if (calfn != NULL) { /* add cal file if needed */
454 CHECKARGC(2);
455 rcarg[nrcargs++] = "-f";
456 rcarg[nrcargs++] = calfn;
457 }
458 if (params != NULL) { /* parameters _after_ cal file */
459 CHECKARGC(2);
460 rcarg[nrcargs++] = "-p";
461 rcarg[nrcargs++] = params;
462 }
463 if (nbins != NULL) { /* add #bins if set */
464 CHECKARGC(2);
465 rcarg[nrcargs++] = "-bn";
466 rcarg[nrcargs++] = nbins;
467 }
468 if (binv != NULL) {
469 CHECKARGC(2); /* assign bin variable */
470 rcarg[nrcargs++] = "-b";
471 rcarg[nrcargs++] = binv;
472 } else if (binf != NULL) {
473 CHECKARGC(2); /* assign bin function */
474 rcarg[nrcargs++] = "-b";
475 sprintf(sbuf, "%s(%g,%g,%g,%g,%g,%g)", binf,
476 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
477 curparams.vup[0], curparams.vup[1], curparams.vup[2]);
478 rcarg[nrcargs++] = savqstr(sbuf);
479 }
480 CHECKARGC(2); /* modifier argument goes last */
481 rcarg[nrcargs++] = "-m";
482 rcarg[nrcargs++] = savqstr(curmod);
483 }
484
485 /* Make randomly oriented tangent plane axes for given normal direction */
486 static void
487 make_axes(FVECT uva[2], const FVECT nrm)
488 {
489 int i;
490
491 if (!getperpendicular(uva[0], nrm, 1)) {
492 fputs(progname, stderr);
493 fputs(": bad surface normal in make_axes!\n", stderr);
494 exit(1);
495 }
496 fcross(uva[1], nrm, uva[0]);
497 }
498
499 /* Illegal sender surfaces end up here */
500 static int
501 ssamp_bad(FVECT orig, SURF *sp, double x)
502 {
503 fprintf(stderr, "%s: illegal sender surface '%s'\n",
504 progname, sp->sname);
505 return(0);
506 }
507
508 /* Generate origin on ring surface from uniform random variable */
509 static int
510 ssamp_ring(FVECT orig, SURF *sp, double x)
511 {
512 FVECT *uva = (FVECT *)sp->priv;
513 double samp2[2];
514 double uv[2];
515 int i;
516
517 if (uva == NULL) { /* need tangent axes */
518 uva = (FVECT *)malloc(sizeof(FVECT)*2);
519 if (uva == NULL) {
520 fputs(progname, stderr);
521 fputs(": out of memory in ssamp_ring!\n", stderr);
522 return(0);
523 }
524 make_axes(uva, sp->snrm);
525 sp->priv = (void *)uva;
526 }
527 SDmultiSamp(samp2, 2, x);
528 samp2[0] = sqrt(samp2[0]*sp->area*(1./PI) + sp->farg[6]*sp->farg[6]);
529 samp2[1] *= 2.*PI;
530 uv[0] = samp2[0]*tcos(samp2[1]);
531 uv[1] = samp2[0]*tsin(samp2[1]);
532 for (i = 3; i--; )
533 orig[i] = sp->farg[i] + uv[0]*uva[0][i] + uv[1]*uva[1][i];
534 return(1);
535 }
536
537 /* Add triangle to polygon's list (call-back function) */
538 static int
539 add_triangle(const Vert2_list *tp, int a, int b, int c)
540 {
541 POLYTRIS *ptp = (POLYTRIS *)tp->p;
542 struct ptri *trip = ptp->tri + ptp->ntris++;
543
544 trip->vndx[0] = a;
545 trip->vndx[1] = b;
546 trip->vndx[2] = c;
547 return(1);
548 }
549
550 /* Generate origin on polygon surface from uniform random variable */
551 static int
552 ssamp_poly(FVECT orig, SURF *sp, double x)
553 {
554 POLYTRIS *ptp = (POLYTRIS *)sp->priv;
555 double samp2[2];
556 double *v0, *v1, *v2;
557 int i;
558
559 if (ptp == NULL) { /* need to triangulate */
560 ptp = (POLYTRIS *)malloc(sizeof(POLYTRIS) +
561 sizeof(struct ptri)*(sp->nfargs/3 - 3));
562 if (ptp == NULL)
563 goto memerr;
564 if (sp->nfargs == 3) { /* simple case */
565 ptp->ntris = 1;
566 ptp->tri[0].vndx[0] = 0;
567 ptp->tri[0].vndx[1] = 1;
568 ptp->tri[0].vndx[2] = 2;
569 ptp->tri[0].afrac = 1;
570 } else {
571 Vert2_list *v2l = polyAlloc(sp->nfargs/3);
572 if (v2l == NULL)
573 goto memerr;
574 make_axes(ptp->uva, sp->snrm);
575 for (i = v2l->nv; i--; ) {
576 v2l->v[i].mX = DOT(sp->farg+3*i, ptp->uva[0]);
577 v2l->v[i].mY = DOT(sp->farg+3*i, ptp->uva[1]);
578 }
579 ptp->ntris = 0;
580 v2l->p = (void *)ptp;
581 if (!polyTriangulate(v2l, add_triangle)) {
582 fprintf(stderr,
583 "%s: cannot triangulate polygon '%s'\n",
584 progname, sp->sname);
585 return(0);
586 }
587 for (i = ptp->ntris; i--; ) {
588 int a = ptp->tri[i].vndx[0];
589 int b = ptp->tri[i].vndx[1];
590 int c = ptp->tri[i].vndx[2];
591 ptp->tri[i].afrac =
592 (v2l->v[a].mX*v2l->v[b].mY -
593 v2l->v[b].mX*v2l->v[a].mY +
594 v2l->v[b].mX*v2l->v[c].mY -
595 v2l->v[c].mX*v2l->v[b].mY +
596 v2l->v[c].mX*v2l->v[a].mY -
597 v2l->v[a].mX*v2l->v[c].mY) /
598 (2.*sp->area);
599 }
600 polyFree(v2l);
601 }
602 sp->priv = (void *)ptp;
603 }
604 /* pick triangle by partial area */
605 for (i = 0; i < ptp->ntris && x > ptp->tri[i].afrac; i++)
606 x -= ptp->tri[i].afrac;
607 SDmultiSamp(samp2, 2, x/ptp->tri[i].afrac);
608 samp2[0] *= samp2[1] = sqrt(samp2[1]);
609 samp2[1] = 1. - samp2[1];
610 v0 = sp->farg + 3*ptp->tri[i].vndx[0];
611 v1 = sp->farg + 3*ptp->tri[i].vndx[1];
612 v2 = sp->farg + 3*ptp->tri[i].vndx[2];
613 for (i = 3; i--; )
614 orig[i] = v0[i] + samp2[0]*(v1[i] - v0[i])
615 + samp2[1]*(v2[i] - v0[i]) ;
616 return(1);
617 memerr:
618 fputs(progname, stderr);
619 fputs(": out of memory in ssamp_poly!\n", stderr);
620 return(0);
621 }
622
623 /* Compute sample origin based on projected areas of sender subsurfaces */
624 static int
625 sample_origin(PARAMS *p, FVECT orig, const FVECT rdir, double x)
626 {
627 static double *projsa;
628 static int nall;
629 double tarea = 0;
630 int i;
631 SURF *sp;
632 /* special case for lone surface */
633 if (p->nsurfs == 1) {
634 sp = p->slist;
635 if (DOT(sp->snrm, rdir) >= FTINY) {
636 fprintf(stderr,
637 "%s: internal - sample behind sender '%s'\n",
638 progname, sp->sname);
639 return(0);
640 }
641 return((*orig_in_surf[sp->styp])(orig, sp, x));
642 }
643 if (p->nsurfs > nall) { /* (re)allocate surface area cache */
644 if (projsa) free(projsa);
645 projsa = (double *)malloc(sizeof(double)*p->nsurfs);
646 if (!projsa) return(0);
647 nall = p->nsurfs;
648 }
649 /* compute projected areas */
650 for (i = 0, sp = p->slist; sp != NULL; i++, sp = sp->next) {
651 projsa[i] = -DOT(sp->snrm, rdir) * sp->area;
652 tarea += projsa[i] *= (double)(projsa[i] > FTINY);
653 }
654 if (tarea <= FTINY) { /* wrong side of sender? */
655 fputs(progname, stderr);
656 fputs(": internal - sample behind all sender elements!\n",
657 stderr);
658 return(0);
659 }
660 tarea *= x; /* get surface from list */
661 for (i = 0, sp = p->slist; tarea > projsa[i]; sp = sp->next)
662 tarea -= projsa[i++];
663 return((*orig_in_surf[sp->styp])(orig, sp, tarea/projsa[i]));
664 }
665
666 /* Uniform sample generator */
667 static int
668 sample_uniform(PARAMS *p, int b, FILE *fp)
669 {
670 int n = sampcnt;
671 double samp3[3];
672 double duvw[3];
673 FVECT orig_dir[2];
674 int i;
675
676 if (fp == NULL) /* just requesting number of bins? */
677 return(1);
678
679 while (n--) { /* stratified hemisphere sampling */
680 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
681 SDsquare2disk(duvw, samp3[1], samp3[2]);
682 duvw[2] = -sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
683 for (i = 3; i--; )
684 orig_dir[1][i] = duvw[0]*p->udir[i] +
685 duvw[1]*p->vdir[i] +
686 duvw[2]*p->nrm[i] ;
687 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
688 return(0);
689 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
690 return(0);
691 }
692 return(1);
693 }
694
695 /* Shirly-Chiu sample generator */
696 static int
697 sample_shirchiu(PARAMS *p, int b, FILE *fp)
698 {
699 int n = sampcnt;
700 double samp3[3];
701 double duvw[3];
702 FVECT orig_dir[2];
703 int i;
704
705 if (fp == NULL) /* just requesting number of bins? */
706 return(p->hsiz*p->hsiz);
707
708 while (n--) { /* stratified sampling */
709 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
710 SDsquare2disk(duvw, (b/p->hsiz + samp3[1])/curparams.hsiz,
711 (b%p->hsiz + samp3[2])/curparams.hsiz);
712 duvw[2] = sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
713 for (i = 3; i--; )
714 orig_dir[1][i] = -duvw[0]*p->udir[i] -
715 duvw[1]*p->vdir[i] -
716 duvw[2]*p->nrm[i] ;
717 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
718 return(0);
719 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
720 return(0);
721 }
722 return(1);
723 }
724
725 /* Reinhart/Tregenza sample generator */
726 static int
727 sample_reinhart(PARAMS *p, int b, FILE *fp)
728 {
729 #define T_NALT 7
730 static const int tnaz[T_NALT] = {30, 30, 24, 24, 18, 12, 6};
731 const int RowMax = T_NALT*p->hsiz + 1;
732 const double RAH = (.5*PI)/(RowMax-.5);
733 #define rnaz(r) (r >= RowMax-1 ? 1 : p->hsiz*tnaz[r/p->hsiz])
734 int n = sampcnt;
735 int row, col;
736 double samp3[3];
737 double alt, azi;
738 double duvw[3];
739 FVECT orig_dir[2];
740 int i;
741
742 if (fp == NULL) { /* just requesting number of bins? */
743 n = 0;
744 for (row = RowMax; row--; ) n += rnaz(row);
745 return(n);
746 }
747 row = 0; /* identify row & column */
748 col = b;
749 while (col >= rnaz(row)) {
750 col -= rnaz(row);
751 ++row;
752 }
753 while (n--) { /* stratified sampling */
754 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
755 alt = (row+samp3[1])*RAH;
756 azi = (2.*PI)*(col+samp3[2]-.5)/rnaz(row);
757 duvw[2] = cos(alt); /* measured from horizon */
758 duvw[0] = tsin(azi)*duvw[2];
759 duvw[1] = tcos(azi)*duvw[2];
760 duvw[2] = sqrt(1. - duvw[2]*duvw[2]);
761 for (i = 3; i--; )
762 orig_dir[1][i] = -duvw[0]*p->udir[i] -
763 duvw[1]*p->vdir[i] -
764 duvw[2]*p->nrm[i] ;
765 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
766 return(0);
767 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
768 return(0);
769 }
770 return(1);
771 #undef rnaz
772 #undef T_NALT
773 }
774
775 /* Klems sample generator */
776 static int
777 sample_klems(PARAMS *p, int b, FILE *fp)
778 {
779 static const char bname[4][20] = {
780 "LBNL/Klems Full",
781 "LBNL/Klems Half",
782 "INTERNAL ERROR",
783 "LBNL/Klems Quarter"
784 };
785 static ANGLE_BASIS *kbasis[4];
786 const int bi = p->hemis[1] - '1';
787 int n = sampcnt;
788 double samp2[2];
789 double duvw[3];
790 FVECT orig_dir[2];
791 int i;
792
793 if (!kbasis[bi]) { /* need to get basis, first */
794 for (i = 4; i--; )
795 if (!strcasecmp(abase_list[i].name, bname[bi])) {
796 kbasis[bi] = &abase_list[i];
797 break;
798 }
799 if (i < 0) {
800 fprintf(stderr, "%s: unknown hemisphere basis '%s'\n",
801 progname, bname[bi]);
802 return(0);
803 }
804 }
805 if (fp == NULL) /* just requesting number of bins? */
806 return(kbasis[bi]->nangles);
807
808 while (n--) { /* stratified sampling */
809 SDmultiSamp(samp2, 2, (n+frandom())/sampcnt);
810 if (!fo_getvec(duvw, b+samp2[1], kbasis[bi]))
811 return(0);
812 for (i = 3; i--; )
813 orig_dir[1][i] = -duvw[0]*p->udir[i] -
814 duvw[1]*p->vdir[i] -
815 duvw[2]*p->nrm[i] ;
816 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp2[0]))
817 return(0);
818 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
819 return(0);
820 }
821 return(1);
822 }
823
824 /* Prepare hemisphere basis sampler that will send rays to rcontrib */
825 static int
826 prepare_sampler(void)
827 {
828 if (curparams.slist == NULL) { /* missing sample surface! */
829 fputs(progname, stderr);
830 fputs(": no sender surface!\n", stderr);
831 return(-1);
832 }
833 /* misplaced output file spec. */
834 if ((curparams.outfn != NULL) & (verbose >= 0))
835 fprintf(stderr, "%s: warning - ignoring output file in sender ('%s')\n",
836 progname, curparams.outfn);
837 /* check/set basis hemisphere */
838 if (!curparams.hemis[0]) {
839 fputs(progname, stderr);
840 fputs(": missing sender sampling type!\n", stderr);
841 return(-1);
842 }
843 if (normalize(curparams.nrm) == 0) {
844 fputs(progname, stderr);
845 fputs(": undefined normal for sender sampling\n", stderr);
846 return(-1);
847 }
848 if (normalize(curparams.vup) == 0) {
849 if (fabs(curparams.nrm[2]) < .7)
850 curparams.vup[2] = 1;
851 else
852 curparams.vup[1] = 1;
853 }
854 fcross(curparams.udir, curparams.vup, curparams.nrm);
855 if (normalize(curparams.udir) == 0) {
856 fputs(progname, stderr);
857 fputs(": up vector coincides with sender normal\n", stderr);
858 return(-1);
859 }
860 fcross(curparams.vdir, curparams.nrm, curparams.udir);
861 if (curparams.sign == '-') { /* left-handed coordinate system? */
862 curparams.udir[0] *= -1.;
863 curparams.udir[1] *= -1.;
864 curparams.udir[2] *= -1.;
865 }
866 if (tolower(curparams.hemis[0]) == 'u' | curparams.hemis[0] == '1')
867 curparams.sample_basis = sample_uniform;
868 else if (tolower(curparams.hemis[0]) == 's' &&
869 tolower(curparams.hemis[1]) == 'c')
870 curparams.sample_basis = sample_shirchiu;
871 else if ((tolower(curparams.hemis[0]) == 'r') |
872 (tolower(curparams.hemis[0]) == 't'))
873 curparams.sample_basis = sample_reinhart;
874 else if (tolower(curparams.hemis[0]) == 'k') {
875 switch (curparams.hemis[1]) {
876 case '1':
877 case '2':
878 case '4':
879 break;
880 case 'f':
881 case 'F':
882 case '\0':
883 curparams.hemis[1] = '1';
884 break;
885 case 'h':
886 case 'H':
887 curparams.hemis[1] = '2';
888 break;
889 case 'q':
890 case 'Q':
891 curparams.hemis[1] = '4';
892 break;
893 default:
894 goto unrecognized;
895 }
896 curparams.hemis[2] = '\0';
897 curparams.sample_basis = sample_klems;
898 } else
899 goto unrecognized;
900 /* return number of bins */
901 return((*curparams.sample_basis)(&curparams,0,NULL));
902 unrecognized:
903 fprintf(stderr, "%s: unrecognized sender sampling: h=%s\n",
904 progname, curparams.hemis);
905 return(-1);
906 }
907
908 /* Compute normal and area for polygon */
909 static int
910 finish_polygon(SURF *p)
911 {
912 const int nv = p->nfargs / 3;
913 FVECT e1, e2, vc;
914 int i;
915
916 memset(p->snrm, 0, sizeof(FVECT));
917 VSUB(e1, p->farg+3, p->farg);
918 for (i = 2; i < nv; i++) {
919 VSUB(e2, p->farg+3*i, p->farg);
920 VCROSS(vc, e1, e2);
921 p->snrm[0] += vc[0];
922 p->snrm[1] += vc[1];
923 p->snrm[2] += vc[2];
924 VCOPY(e1, e2);
925 }
926 p->area = normalize(p->snrm)*0.5;
927 return(p->area > FTINY);
928 }
929
930 /* Add a surface to our current parameters */
931 static void
932 add_surface(int st, const char *oname, FILE *fp)
933 {
934 SURF *snew;
935 int n;
936 /* get floating-point arguments */
937 if (!fscanf(fp, "%d", &n)) return;
938 while (n-- > 0) fscanf(fp, "%*s");
939 if (!fscanf(fp, "%d", &n)) return;
940 while (n-- > 0) fscanf(fp, "%*d");
941 if (!fscanf(fp, "%d", &n) || n <= 0) return;
942 snew = (SURF *)malloc(sizeof(SURF) + sizeof(double)*(n-1));
943 if (snew == NULL) {
944 fputs(progname, stderr);
945 fputs(": out of memory!\n", stderr);
946 exit(1);
947 }
948 strncpy(snew->sname, oname, sizeof(snew->sname)-1);
949 snew->sname[sizeof(snew->sname)-1] = '\0';
950 snew->styp = st;
951 snew->priv = NULL;
952 snew->nfargs = n;
953 for (n = 0; n < snew->nfargs; n++)
954 if (fscanf(fp, "%lf", &snew->farg[n]) != 1) {
955 fprintf(stderr, "%s: error reading arguments for '%s'\n",
956 progname, oname);
957 exit(1);
958 }
959 switch (st) {
960 case ST_RING:
961 if (snew->nfargs != 8)
962 goto badcount;
963 VCOPY(snew->snrm, snew->farg+3);
964 if (normalize(snew->snrm) == 0)
965 goto badnorm;
966 if (snew->farg[7] < snew->farg[6]) {
967 double t = snew->farg[7];
968 snew->farg[7] = snew->farg[6];
969 snew->farg[6] = t;
970 }
971 snew->area = PI*(snew->farg[7]*snew->farg[7] -
972 snew->farg[6]*snew->farg[6]);
973 break;
974 case ST_POLY:
975 if (snew->nfargs < 9 || snew->nfargs % 3)
976 goto badcount;
977 finish_polygon(snew);
978 break;
979 case ST_SOURCE:
980 if (snew->nfargs != 4)
981 goto badcount;
982 for (n = 3; n--; ) /* need to reverse "normal" */
983 snew->snrm[n] = -snew->farg[n];
984 if (normalize(snew->snrm) == 0)
985 goto badnorm;
986 snew->area = sin((PI/180./2.)*snew->farg[3]);
987 snew->area *= PI*snew->area;
988 break;
989 }
990 if ((snew->area <= FTINY) & (verbose >= 0)) {
991 fprintf(stderr, "%s: warning - zero area for surface '%s'\n",
992 progname, oname);
993 free(snew);
994 return;
995 }
996 VSUM(curparams.nrm, curparams.nrm, snew->snrm, snew->area);
997 snew->next = curparams.slist;
998 curparams.slist = snew;
999 curparams.nsurfs++;
1000 return;
1001 badcount:
1002 fprintf(stderr, "%s: bad argument count for surface element '%s'\n",
1003 progname, oname);
1004 exit(1);
1005 badnorm:
1006 fprintf(stderr, "%s: bad orientation for surface element '%s'\n",
1007 progname, oname);
1008 exit(1);
1009 }
1010
1011 /* Parse a receiver object (look for modifiers to add to rcontrib command) */
1012 static int
1013 add_recv_object(FILE *fp)
1014 {
1015 int st;
1016 char thismod[128], otype[32], oname[128];
1017 int n;
1018
1019 if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3)
1020 return(0); /* must have hit EOF! */
1021 if (!strcmp(otype, "alias")) {
1022 fscanf(fp, "%*s"); /* skip alias */
1023 return(0);
1024 }
1025 /* is it a new receiver? */
1026 if ((st = surf_type(otype)) != ST_NONE) {
1027 if (curparams.slist != NULL && (st == ST_SOURCE) ^
1028 (curparams.slist->styp == ST_SOURCE)) {
1029 fputs(progname, stderr);
1030 fputs(": cannot mix source/non-source receivers!\n", stderr);
1031 return(-1);
1032 }
1033 if (strcmp(thismod, curmod)) {
1034 if (curmod[0]) { /* output last receiver? */
1035 finish_receiver();
1036 clear_params(&curparams, 1);
1037 }
1038 parse_params(&curparams, newparams);
1039 newparams[0] = '\0';
1040 strcpy(curmod, thismod);
1041 }
1042 add_surface(st, oname, fp); /* read & store surface */
1043 return(1);
1044 }
1045 /* else skip arguments */
1046 if (!fscanf(fp, "%d", &n)) return(0);
1047 while (n-- > 0) fscanf(fp, "%*s");
1048 if (!fscanf(fp, "%d", &n)) return(0);
1049 while (n-- > 0) fscanf(fp, "%*d");
1050 if (!fscanf(fp, "%d", &n)) return(0);
1051 while (n-- > 0) fscanf(fp, "%*f");
1052 return(0);
1053 }
1054
1055 /* Parse a sender object */
1056 static int
1057 add_send_object(FILE *fp)
1058 {
1059 int st;
1060 char thismod[128], otype[32], oname[128];
1061 int n;
1062
1063 if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3)
1064 return(0); /* must have hit EOF! */
1065 if (!strcmp(otype, "alias")) {
1066 fscanf(fp, "%*s"); /* skip alias */
1067 return(0);
1068 }
1069 /* is it a new surface? */
1070 if ((st = surf_type(otype)) != ST_NONE) {
1071 if (st == ST_SOURCE) {
1072 fputs(progname, stderr);
1073 fputs(": cannot use source as a sender!\n", stderr);
1074 return(-1);
1075 }
1076 if (strcmp(thismod, curmod)) {
1077 if (curmod[0]) {
1078 fputs(progname, stderr);
1079 fputs(": warning - multiple modifiers in sender\n",
1080 stderr);
1081 }
1082 strcpy(curmod, thismod);
1083 }
1084 parse_params(&curparams, newparams);
1085 newparams[0] = '\0';
1086 add_surface(st, oname, fp); /* read & store surface */
1087 return(0);
1088 }
1089 /* else skip arguments */
1090 if (!fscanf(fp, "%d", &n)) return(0);
1091 while (n-- > 0) fscanf(fp, "%*s");
1092 if (!fscanf(fp, "%d", &n)) return(0);
1093 while (n-- > 0) fscanf(fp, "%*d");
1094 if (!fscanf(fp, "%d", &n)) return(0);
1095 while (n-- > 0) fscanf(fp, "%*f");
1096 return(0);
1097 }
1098
1099 /* Load a Radiance scene using the given callback function for objects */
1100 static int
1101 load_scene(const char *inspec, int (*ocb)(FILE *))
1102 {
1103 int rv = 0;
1104 char inpbuf[1024];
1105 FILE *fp;
1106 int c;
1107
1108 if (*inspec == '!')
1109 fp = popen(inspec+1, "r");
1110 else
1111 fp = fopen(inspec, "r");
1112 if (fp == NULL) {
1113 fprintf(stderr, "%s: cannot load '%s'\n", progname, inspec);
1114 return(-1);
1115 }
1116 while ((c = getc(fp)) != EOF) { /* load receiver data */
1117 if (isspace(c)) /* skip leading white space */
1118 continue;
1119 if (c == '!') { /* read from a new command */
1120 inpbuf[0] = c;
1121 if (fgetline(inpbuf+1, sizeof(inpbuf)-1, fp) != NULL) {
1122 if ((c = load_scene(inpbuf, ocb)) < 0)
1123 return(c);
1124 rv += c;
1125 }
1126 continue;
1127 }
1128 if (c == '#') { /* parameters/comment */
1129 if ((c = getc(fp)) == EOF || ungetc(c,fp) == EOF)
1130 break;
1131 if (!isspace(c) && fscanf(fp, "%s", inpbuf) == 1 &&
1132 !strcmp(inpbuf, PARAMSTART)) {
1133 if (fgets(inpbuf, sizeof(inpbuf), fp) != NULL)
1134 strcat(newparams, inpbuf);
1135 continue;
1136 }
1137 while ((c = getc(fp)) != EOF && c != '\n')
1138 ; /* else skipping comment */
1139 continue;
1140 }
1141 ungetc(c, fp); /* else check object for receiver */
1142 c = (*ocb)(fp);
1143 if (c < 0)
1144 return(c);
1145 rv += c;
1146 }
1147 /* close our input stream */
1148 c = (*inspec == '!') ? pclose(fp) : fclose(fp);
1149 if (c != 0) {
1150 fprintf(stderr, "%s: error loading '%s'\n", progname, inspec);
1151 return(-1);
1152 }
1153 return(rv);
1154 }
1155
1156 /* Get command arguments and run program */
1157 int
1158 main(int argc, char *argv[])
1159 {
1160 char fmtopt[6] = "-faa"; /* default output is ASCII */
1161 char *xrs=NULL, *yrs=NULL, *ldopt=NULL;
1162 char *iropt = NULL;
1163 char *sendfn;
1164 char sampcntbuf[32], nsbinbuf[32];
1165 FILE *rcfp;
1166 int nsbins;
1167 int a, i;
1168 /* screen rcontrib options */
1169 progname = argv[0];
1170 for (a = 1; a < argc-2; a++) {
1171 int na;
1172 /* check for argument expansion */
1173 while ((na = expandarg(&argc, &argv, a)) > 0)
1174 ;
1175 if (na < 0) {
1176 fprintf(stderr, "%s: cannot expand '%s'\n",
1177 progname, argv[a]);
1178 return(1);
1179 }
1180 if (argv[a][0] != '-' || !argv[a][1])
1181 break;
1182 na = 1;
1183 switch (argv[a][1]) { /* !! Keep consistent !! */
1184 case 'v': /* verbose mode */
1185 verbose = 1;
1186 na = 0;
1187 continue;
1188 case 'f': /* special case for -fo, -ff, etc. */
1189 switch (argv[a][2]) {
1190 case '\0': /* cal file */
1191 goto userr;
1192 case 'o': /* force output */
1193 goto userr;
1194 case 'a': /* output format */
1195 case 'f':
1196 case 'd':
1197 case 'c':
1198 if (!(fmtopt[3] = argv[a][3]))
1199 fmtopt[3] = argv[a][2];
1200 fmtopt[2] = argv[a][2];
1201 na = 0;
1202 continue; /* will pass later */
1203 default:
1204 goto userr;
1205 }
1206 break;
1207 case 'x': /* x-resolution */
1208 xrs = argv[++a];
1209 na = 0;
1210 continue;
1211 case 'y': /* y-resolution */
1212 yrs = argv[++a];
1213 na = 0;
1214 continue;
1215 case 'c': /* number of samples */
1216 sampcnt = atoi(argv[++a]);
1217 if (sampcnt <= 0)
1218 goto userr;
1219 na = 0; /* we re-add this later */
1220 continue;
1221 case 'I': /* only for pass-through mode */
1222 case 'i':
1223 iropt = argv[a];
1224 na = 0;
1225 continue;
1226 case 'w': /* options without arguments */
1227 if (argv[a][2] != '+') verbose = -1;
1228 case 'V':
1229 case 'u':
1230 case 'h':
1231 case 'r':
1232 break;
1233 case 'n': /* options with 1 argument */
1234 case 's':
1235 case 'o':
1236 na = 2;
1237 break;
1238 case 'b': /* special case */
1239 if (argv[a][2] != 'v') goto userr;
1240 break;
1241 case 'l': /* special case */
1242 if (argv[a][2] == 'd') {
1243 ldopt = argv[a];
1244 na = 0;
1245 continue;
1246 }
1247 na = 2;
1248 break;
1249 case 'd': /* special case */
1250 if (argv[a][2] != 'v') na = 2;
1251 break;
1252 case 'a': /* special case */
1253 if (argv[a][2] == 'p') {
1254 na = 2; /* photon map [+ bandwidth(s)] */
1255 if (a < argc-3 && atoi(argv[a+1]) > 0)
1256 na += 1 + (a < argc-4 && atoi(argv[a+2]) > 0);
1257 } else
1258 na = (argv[a][2] == 'v') ? 4 : 2;
1259 break;
1260 case 'm': /* special case */
1261 if (!argv[a][2]) goto userr;
1262 na = (argv[a][2] == 'e') | (argv[a][2] == 'a') ? 4 : 2;
1263 break;
1264 default: /* anything else is verbotten */
1265 goto userr;
1266 }
1267 if (na <= 0) continue;
1268 CHECKARGC(na); /* pass on option */
1269 rcarg[nrcargs++] = argv[a];
1270 while (--na) /* + arguments if any */
1271 rcarg[nrcargs++] = argv[++a];
1272 }
1273 if (a > argc-2)
1274 goto userr; /* check at end of options */
1275 sendfn = argv[a++]; /* assign sender & receiver inputs */
1276 if (sendfn[0] == '-') { /* user wants pass-through mode? */
1277 if (sendfn[1]) goto userr;
1278 sendfn = NULL;
1279 if (iropt) {
1280 CHECKARGC(1);
1281 rcarg[nrcargs++] = iropt;
1282 }
1283 if (xrs) {
1284 CHECKARGC(2);
1285 rcarg[nrcargs++] = "-x";
1286 rcarg[nrcargs++] = xrs;
1287 }
1288 if (yrs) {
1289 CHECKARGC(2);
1290 rcarg[nrcargs++] = "-y";
1291 rcarg[nrcargs++] = yrs;
1292 }
1293 if (ldopt) {
1294 CHECKARGC(1);
1295 rcarg[nrcargs++] = ldopt;
1296 }
1297 if (sampcnt <= 0) sampcnt = 1;
1298 } else { /* else in sampling mode */
1299 if (iropt) {
1300 fputs(progname, stderr);
1301 fputs(": -i, -I supported for pass-through only\n", stderr);
1302 return(1);
1303 }
1304 fmtopt[2] = (sizeof(RREAL)==sizeof(double)) ? 'd' : 'f';
1305 if (sampcnt <= 0) sampcnt = 10000;
1306 }
1307 sprintf(sampcntbuf, "%d", sampcnt);
1308 CHECKARGC(3); /* add our format & sample count */
1309 rcarg[nrcargs++] = fmtopt;
1310 rcarg[nrcargs++] = "-c";
1311 rcarg[nrcargs++] = sampcntbuf;
1312 /* add receiver arguments to rcontrib */
1313 if (load_scene(argv[a], add_recv_object) < 0)
1314 return(1);
1315 finish_receiver();
1316 if (sendfn == NULL) { /* pass-through mode? */
1317 CHECKARGC(1); /* add octree */
1318 rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1319 rcarg[nrcargs] = NULL;
1320 return(my_exec(rcarg)); /* rcontrib does everything */
1321 }
1322 clear_params(&curparams, 0); /* else load sender surface & params */
1323 curmod[0] = '\0';
1324 if (load_scene(sendfn, add_send_object) < 0)
1325 return(1);
1326 if ((nsbins = prepare_sampler()) <= 0)
1327 return(1);
1328 CHECKARGC(3); /* add row count and octree */
1329 rcarg[nrcargs++] = "-y";
1330 sprintf(nsbinbuf, "%d", nsbins);
1331 rcarg[nrcargs++] = nsbinbuf;
1332 rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1333 rcarg[nrcargs] = NULL;
1334 /* open pipe to rcontrib process */
1335 if ((rcfp = popen_arglist(rcarg, "w")) == NULL)
1336 return(1);
1337 SET_FILE_BINARY(rcfp);
1338 #ifdef getc_unlocked
1339 flockfile(rcfp);
1340 #endif
1341 if (verbose > 0) {
1342 fprintf(stderr, "%s: sampling %d directions", progname, nsbins);
1343 if (curparams.nsurfs > 1)
1344 fprintf(stderr, " (%d elements)\n", curparams.nsurfs);
1345 else
1346 fputc('\n', stderr);
1347 }
1348 for (i = 0; i < nsbins; i++) /* send rcontrib ray samples */
1349 if (!(*curparams.sample_basis)(&curparams, i, rcfp))
1350 return(1);
1351 return(pclose(rcfp) < 0); /* all finished! */
1352 userr:
1353 if (a < argc-2)
1354 fprintf(stderr, "%s: unsupported option '%s'", progname, argv[a]);
1355 fprintf(stderr, "Usage: %s [-v][rcontrib options] sender.rad receiver.rad [-i system.oct] [system.rad ..]\n",
1356 progname);
1357 return(1);
1358 }
