root/radiance/ray/src/util/rfluxmtx.c
Revision: 2.29
Committed: Thu May 21 05:54:54 2015 UTC (9 years ago) by greg
2 static const char RCSid[] = "$Id: rfluxmtx.c,v 2.28 2015/05/19 12:13:53 greg Exp $";
5 * Calculate flux transfer matrix or matrices using rcontrib
6 */
7
8 #include "copyright.h"
9
10 #include <ctype.h>
11 #include <stdlib.h>
12 #include "rtio.h"
13 #include "rtmath.h"
14 #include "rtprocess.h"
15 #include "bsdf.h"
16 #include "bsdf_m.h"
17 #include "random.h"
18 #include "triangulate.h"
19 #include "platform.h"
20
21 #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
22 #undef getc
23 #define getc getc_unlocked
24 #endif
25
26 #ifdef _WIN32
27 #define SPECIALS " \t\"$*?"
28 #define QUOTCHAR '"'
29 #else
30 #define SPECIALS " \t\n'\"()${}*?[];|&"
31 #define QUOTCHAR '\''
32 #define ALTQUOT '"'
33 #endif
34
35 #define MAXRCARG 512
36
37 char *progname; /* global argv[0] */
38
39 int verbose = 0; /* verbose mode (< 0 no warnings) */
40
41 char *rcarg[MAXRCARG+1] = {"rcontrib", "-fo+"};
42 int nrcargs = 2;
43
44 const char overflowerr[] = "%s: too many arguments!\n";
45
46 #define CHECKARGC(n) if (nrcargs >= MAXRCARG-(n)) \
47 { fprintf(stderr, overflowerr, progname); exit(1); }
48
49 int sampcnt = 0; /* sample count (0==unset) */
50
51 char *reinhfn = "reinhartb.cal";
52 char *shirchiufn = "disk2square.cal";
53 char *kfullfn = "klems_full.cal";
54 char *khalffn = "klems_half.cal";
55 char *kquarterfn = "klems_quarter.cal";
56
57 /* string indicating parameters */
58 const char PARAMSTART[] = "@rfluxmtx";
59
60 /* surface type IDs */
61 #define ST_NONE 0
62 #define ST_POLY 1
63 #define ST_RING 2
64 #define ST_SOURCE 3
65
66 typedef struct surf_s {
67 struct surf_s *next; /* next surface in list */
68 void *priv; /* private data (malloc'ed) */
69 char sname[32]; /* surface name */
70 FVECT snrm; /* surface normal */
71 double area; /* surface area / proj. solid angle */
72 short styp; /* surface type */
73 short nfargs; /* number of real arguments */
74 double farg[1]; /* real values (extends struct) */
75 } SURF; /* surface structure */
76
77 typedef struct {
78 FVECT uva[2]; /* tangent axes */
79 int ntris; /* number of triangles */
80 struct ptri {
81 float afrac; /* fraction of total area */
82 short vndx[3]; /* vertex indices */
83 } tri[1]; /* triangle array (extends struct) */
84 } POLYTRIS; /* triangulated polygon */
85
86 typedef struct param_s {
87 char sign; /* '-' for axis reversal */
88 char hemis[31]; /* hemispherical sampling spec. */
89 int hsiz; /* hemisphere basis size */
90 int nsurfs; /* number of surfaces */
91 SURF *slist; /* list of surfaces */
92 FVECT vup; /* up vector (zero if unset) */
93 FVECT nrm; /* average normal direction */
94 FVECT udir, vdir; /* tangent axes */
95 char *outfn; /* output file name (receiver) */
96 int (*sample_basis)(struct param_s *p, int, FILE *);
97 } PARAMS; /* sender/receiver parameters */
98
99 PARAMS curparams;
100 char curmod[128];
101 char newparams[1024];
102
103 typedef int SURFSAMP(FVECT, SURF *, double);
104
105 static SURFSAMP ssamp_bad, ssamp_poly, ssamp_ring;
106
107 SURFSAMP *orig_in_surf[4] = {
108 ssamp_bad, ssamp_poly, ssamp_ring, ssamp_bad
109 };
110
111 /* Clear parameter set */
112 static void
113 clear_params(PARAMS *p, int reset_only)
114 {
115 while (p->slist != NULL) {
116 SURF *sdel = p->slist;
117 p->slist = sdel->next;
118 if (sdel->priv != NULL)
119 free(sdel->priv);
120 free(sdel);
121 }
122 if (reset_only) {
123 p->nsurfs = 0;
124 memset(p->nrm, 0, sizeof(FVECT));
125 memset(p->vup, 0, sizeof(FVECT));
126 p->outfn = NULL;
127 return;
128 }
129 memset(p, 0, sizeof(PARAMS));
130 }
131
132 /* Get surface type from name */
133 static int
134 surf_type(const char *otype)
135 {
136 if (!strcmp(otype, "polygon"))
137 return(ST_POLY);
138 if (!strcmp(otype, "ring"))
139 return(ST_RING);
140 if (!strcmp(otype, "source"))
141 return(ST_SOURCE);
142 return(ST_NONE);
143 }
144
145 /* Add arguments to oconv command */
146 static char *
147 oconv_command(int ac, char *av[])
148 {
149 static char oconvbuf[2048] = "!oconv -f ";
150 char *cp = oconvbuf + 10;
151 char *recv = *av++;
152
153 if (ac-- <= 0)
154 return(NULL);
155 while (ac-- > 0) {
156 strcpy(cp, *av++);
157 while (*cp) cp++;
158 *cp++ = ' ';
159 if (cp >= oconvbuf+(sizeof(oconvbuf)-32)) {
160 fputs(progname, stderr);
161 fputs(": too many file arguments!\n", stderr);
162 exit(1);
163 }
164 }
165 strcpy(cp, recv); /* receiver goes last */
166 return(oconvbuf);
167 }
168
169 /* Check if any of the characters in str2 are found in str1 */
170 static int
171 matchany(const char *str1, const char *str2)
172 {
173 while (*str1) {
174 const char *cp = str2;
175 while (*cp)
176 if (*cp++ == *str1)
177 return(*str1);
178 ++str1;
179 }
180 return(0);
181 }
182
183
184 /* Convert a set of arguments into a command line for pipe() or system() */
185 static char *
186 convert_commandline(char *cmd, const int len, char *av[])
187 {
188 int match;
189 char *cp;
190
191 for (cp = cmd; *av != NULL; av++) {
192 const int n = strlen(*av);
193 if (cp+n >= cmd+(len-3)) {
194 fputs(progname, stderr);
195 return(NULL);
196 }
197 if ((match = matchany(*av, SPECIALS))) {
198 const int quote =
199 #ifdef ALTQUOT
200 (match == QUOTCHAR) ? ALTQUOT :
201 #endif
202 QUOTCHAR;
203 *cp++ = quote;
204 strcpy(cp, *av);
205 cp += n;
206 *cp++ = quote;
207 } else {
208 strcpy(cp, *av);
209 cp += n;
210 }
211 *cp++ = ' ';
212 }
213 if (cp <= cmd)
214 return(NULL);
215 *--cp = '\0';
216 return(cmd);
217 }
218
219 /* Open a pipe to/from a command given as an argument list */
220 static FILE *
221 popen_arglist(char *av[], char *mode)
222 {
223 char cmd[10240];
224
225 if (!convert_commandline(cmd, sizeof(cmd), av)) {
226 fputs(progname, stderr);
227 fputs(": command line too long in popen_arglist()\n", stderr);
228 return(NULL);
229 }
230 if (verbose > 0)
231 fprintf(stderr, "%s: opening pipe %s: %s\n",
232 progname, (*mode=='w') ? "to" : "from", cmd);
233 return(popen(cmd, mode));
234 }
235
236 #ifdef _WIN32
237 /* Execute system command (Windows version) */
238 static int
239 my_exec(char *av[])
240 {
241 char cmd[10240];
242
243 if (!convert_commandline(cmd, sizeof(cmd), av)) {
244 fputs(progname, stderr);
245 fputs(": command line too long in my_exec()\n", stderr);
246 return(1);
247 }
248 if (verbose > 0)
249 fprintf(stderr, "%s: running: %s\n", progname, cmd);
250 return(system(cmd));
251 }
252 #else
253 /* Execute system command in our stead (Unix version) */
254 static int
255 my_exec(char *av[])
256 {
257 char *compath;
258
259 if ((compath = getpath((char *)av[0], getenv("PATH"), X_OK)) == NULL) {
260 fprintf(stderr, "%s: cannot locate %s\n", progname, av[0]);
261 return(1);
262 }
263 if (verbose > 0) {
264 char cmd[4096];
265 if (!convert_commandline(cmd, sizeof(cmd), av))
266 strcpy(cmd, "COMMAND TOO LONG TO SHOW");
267 fprintf(stderr, "%s: running: %s\n", progname, cmd);
268 }
269 execv(compath, av); /* successful call never returns */
270 perror(compath);
271 return(1);
272 }
273 #endif
274
275 /* Get normalized direction vector from string specification */
276 static int
277 get_direction(FVECT dv, const char *s)
278 {
279 int sign = 1;
280 int axis = 0;
281
282 memset(dv, 0, sizeof(FVECT));
283 nextchar:
284 switch (*s) {
285 case '+':
286 ++s;
287 goto nextchar;
288 case '-':
289 sign = -sign;
290 ++s;
291 goto nextchar;
292 case 'z':
293 case 'Z':
294 ++axis;
295 case 'y':
296 case 'Y':
297 ++axis;
298 case 'x':
299 case 'X':
300 dv[axis] = sign;
301 return(!s[1] | isspace(s[1]));
302 default:
303 break;
304 }
305 #ifdef SMLFLT
306 if (sscanf(s, "%f,%f,%f", &dv[0], &dv[1], &dv[2]) != 3)
307 #else
308 if (sscanf(s, "%lf,%lf,%lf", &dv[0], &dv[1], &dv[2]) != 3)
309 #endif
310 return(0);
311 dv[0] *= (RREAL)sign;
312 return(normalize(dv) > 0);
313 }
314
315 /* Parse program parameters (directives) */
316 static int
317 parse_params(PARAMS *p, char *pargs)
318 {
319 char *cp = pargs;
320 int nparams = 0;
321 int i;
322
323 for ( ; ; ) {
324 switch (*cp++) {
325 case 'h':
326 if (*cp++ != '=')
327 break;
328 if ((*cp == '+') | (*cp == '-'))
329 p->sign = *cp++;
330 else
331 p->sign = '+';
332 p->hsiz = 0;
333 i = 0;
334 while (*cp && !isspace(*cp)) {
335 if (isdigit(*cp))
336 p->hsiz = 10*p->hsiz + *cp - '0';
337 p->hemis[i++] = *cp++;
338 }
339 if (!i)
340 break;
341 p->hemis[i] = '\0';
342 p->hsiz += !p->hsiz;
343 ++nparams;
344 continue;
345 case 'u':
346 if (*cp++ != '=')
347 break;
348 if (!get_direction(p->vup, cp))
349 break;
350 while (*cp && !isspace(*cp++))
351 ;
352 ++nparams;
353 continue;
354 case 'o':
355 if (*cp++ != '=')
356 break;
357 i = 0;
358 while (*cp && !isspace(*cp++))
359 i++;
360 if (!i)
361 break;
362 *--cp = '\0';
363 p->outfn = savqstr(cp-i);
364 *cp++ = ' ';
365 ++nparams;
366 continue;
367 case ' ':
368 case '\t':
369 case '\r':
370 case '\n':
371 continue;
372 case '\0':
373 return(nparams);
374 default:
375 break;
376 }
377 break;
378 }
379 fprintf(stderr, "%s: bad parameter string: %s", progname, pargs);
380 exit(1);
381 return(-1); /* pro forma return */
382 }
383
384 /* Add receiver arguments (directives) corresponding to the current modifier */
385 static void
386 finish_receiver(void)
387 {
388 char sbuf[256];
389 int uniform = 0;
390 char *calfn = NULL;
391 char *params = NULL;
392 char *binv = NULL;
393 char *binf = NULL;
394 char *nbins = NULL;
395
396 if (!curmod[0]) {
397 fputs(progname, stderr);
398 fputs(": missing receiver surface!\n", stderr);
399 exit(1);
400 }
401 if (curparams.outfn != NULL) { /* add output file spec. */
402 CHECKARGC(2);
403 rcarg[nrcargs++] = "-o";
404 rcarg[nrcargs++] = curparams.outfn;
405 }
406 /* check arguments */
407 if (!curparams.hemis[0]) {
408 fputs(progname, stderr);
409 fputs(": missing hemisphere sampling type!\n", stderr);
410 exit(1);
411 }
412 if (normalize(curparams.nrm) == 0) {
413 fputs(progname, stderr);
414 fputs(": undefined normal for hemisphere sampling\n", stderr);
415 exit(1);
416 }
417 if (normalize(curparams.vup) == 0) {
418 if (fabs(curparams.nrm[2]) < .7)
419 curparams.vup[2] = 1;
420 else
421 curparams.vup[1] = 1;
422 }
423 /* determine sample type/bin */
424 if (tolower(curparams.hemis[0]) == 'u' | curparams.hemis[0] == '1') {
425 sprintf(sbuf, "if(-Dx*%g-Dy*%g-Dz*%g,0,-1)",
426 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2]);
427 binv = savqstr(sbuf);
428 nbins = "1"; /* uniform sampling -- one bin */
429 uniform = 1;
430 } else if (tolower(curparams.hemis[0]) == 's' &&
431 tolower(curparams.hemis[1]) == 'c') {
432 /* assign parameters */
433 if (curparams.hsiz <= 1) {
434 fputs(progname, stderr);
435 fputs(": missing size for Shirley-Chiu sampling!\n", stderr);
436 exit(1);
437 }
438 calfn = shirchiufn; shirchiufn = NULL;
439 sprintf(sbuf, "SCdim=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1",
440 curparams.hsiz,
441 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
442 curparams.vup[0], curparams.vup[1], curparams.vup[2],
443 curparams.sign);
444 params = savqstr(sbuf);
445 binv = "scbin";
446 nbins = "SCdim*SCdim";
447 } else if ((tolower(curparams.hemis[0]) == 'r') |
448 (tolower(curparams.hemis[0]) == 't')) {
449 calfn = reinhfn; reinhfn = NULL;
450 sprintf(sbuf, "MF=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g,RHS=%c1",
451 curparams.hsiz,
452 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
453 curparams.vup[0], curparams.vup[1], curparams.vup[2],
454 curparams.sign);
455 params = savqstr(sbuf);
456 binv = "rbin";
457 nbins = "Nrbins";
458 } else if (tolower(curparams.hemis[0]) == 'k' &&
459 !curparams.hemis[1] |
460 (tolower(curparams.hemis[1]) == 'f') |
461 (curparams.hemis[1] == '1')) {
462 calfn = kfullfn; kfullfn = NULL;
463 binf = "kbin";
464 nbins = "Nkbins";
465 } else if (tolower(curparams.hemis[0]) == 'k' &&
466 (tolower(curparams.hemis[1]) == 'h') |
467 (curparams.hemis[1] == '2')) {
468 calfn = khalffn; khalffn = NULL;
469 binf = "khbin";
470 nbins = "Nkhbins";
471 } else if (tolower(curparams.hemis[0]) == 'k' &&
472 (tolower(curparams.hemis[1]) == 'q') |
473 (curparams.hemis[1] == '4')) {
474 calfn = kquarterfn; kquarterfn = NULL;
475 binf = "kqbin";
476 nbins = "Nkqbins";
477 } else {
478 fprintf(stderr, "%s: unrecognized hemisphere sampling: h=%s\n",
479 progname, curparams.hemis);
480 exit(1);
481 }
482 if (tolower(curparams.hemis[0]) == 'k') {
483 sprintf(sbuf, "RHS=%c1", curparams.sign);
484 params = savqstr(sbuf);
485 }
486 if (!uniform & (curparams.slist->styp == ST_SOURCE)) {
487 SURF *sp;
488 for (sp = curparams.slist; sp != NULL; sp = sp->next)
489 if (fabs(sp->area - PI) > 1e-3) {
490 fprintf(stderr, "%s: source '%s' must be 180-degrees\n",
491 progname, sp->sname);
492 exit(1);
493 }
494 }
495 if (calfn != NULL) { /* add cal file if needed */
496 CHECKARGC(2);
497 rcarg[nrcargs++] = "-f";
498 rcarg[nrcargs++] = calfn;
499 }
500 if (params != NULL) { /* parameters _after_ cal file */
501 CHECKARGC(2);
502 rcarg[nrcargs++] = "-p";
503 rcarg[nrcargs++] = params;
504 }
505 if (nbins != NULL) { /* add #bins if set */
506 CHECKARGC(2);
507 rcarg[nrcargs++] = "-bn";
508 rcarg[nrcargs++] = nbins;
509 }
510 if (binv != NULL) {
511 CHECKARGC(2); /* assign bin variable */
512 rcarg[nrcargs++] = "-b";
513 rcarg[nrcargs++] = binv;
514 } else if (binf != NULL) {
515 CHECKARGC(2); /* assign bin function */
516 rcarg[nrcargs++] = "-b";
517 sprintf(sbuf, "%s(%g,%g,%g,%g,%g,%g)", binf,
518 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
519 curparams.vup[0], curparams.vup[1], curparams.vup[2]);
520 rcarg[nrcargs++] = savqstr(sbuf);
521 }
522 CHECKARGC(2); /* modifier argument goes last */
523 rcarg[nrcargs++] = "-m";
524 rcarg[nrcargs++] = savqstr(curmod);
525 }
526
527 /* Make randomly oriented tangent plane axes for given normal direction */
528 static void
529 make_axes(FVECT uva[2], const FVECT nrm)
530 {
531 int i;
532
533 if (!getperpendicular(uva[0], nrm, 1)) {
534 fputs(progname, stderr);
535 fputs(": bad surface normal in make_axes!\n", stderr);
536 exit(1);
537 }
538 fcross(uva[1], nrm, uva[0]);
539 }
540
541 /* Illegal sender surfaces end up here */
542 static int
543 ssamp_bad(FVECT orig, SURF *sp, double x)
544 {
545 fprintf(stderr, "%s: illegal sender surface '%s'\n",
546 progname, sp->sname);
547 return(0);
548 }
549
550 /* Generate origin on ring surface from uniform random variable */
551 static int
552 ssamp_ring(FVECT orig, SURF *sp, double x)
553 {
554 FVECT *uva = (FVECT *)sp->priv;
555 double samp2[2];
556 double uv[2];
557 int i;
558
559 if (uva == NULL) { /* need tangent axes */
560 uva = (FVECT *)malloc(sizeof(FVECT)*2);
561 if (uva == NULL) {
562 fputs(progname, stderr);
563 fputs(": out of memory in ssamp_ring!\n", stderr);
564 return(0);
565 }
566 make_axes(uva, sp->snrm);
567 sp->priv = (void *)uva;
568 }
569 SDmultiSamp(samp2, 2, x);
570 samp2[0] = sqrt(samp2[0]*sp->area*(1./PI) + sp->farg[6]*sp->farg[6]);
571 samp2[1] *= 2.*PI;
572 uv[0] = samp2[0]*tcos(samp2[1]);
573 uv[1] = samp2[0]*tsin(samp2[1]);
574 for (i = 3; i--; )
575 orig[i] = sp->farg[i] + uv[0]*uva[0][i] + uv[1]*uva[1][i];
576 return(1);
577 }
578
579 /* Add triangle to polygon's list (call-back function) */
580 static int
581 add_triangle(const Vert2_list *tp, int a, int b, int c)
582 {
583 POLYTRIS *ptp = (POLYTRIS *)tp->p;
584 struct ptri *trip = ptp->tri + ptp->ntris++;
585
586 trip->vndx[0] = a;
587 trip->vndx[1] = b;
588 trip->vndx[2] = c;
589 return(1);
590 }
591
592 /* Generate origin on polygon surface from uniform random variable */
593 static int
594 ssamp_poly(FVECT orig, SURF *sp, double x)
595 {
596 POLYTRIS *ptp = (POLYTRIS *)sp->priv;
597 double samp2[2];
598 double *v0, *v1, *v2;
599 int i;
600
601 if (ptp == NULL) { /* need to triangulate */
602 ptp = (POLYTRIS *)malloc(sizeof(POLYTRIS) +
603 sizeof(struct ptri)*(sp->nfargs/3 - 3));
604 if (ptp == NULL)
605 goto memerr;
606 if (sp->nfargs == 3) { /* simple case */
607 ptp->ntris = 1;
608 ptp->tri[0].vndx[0] = 0;
609 ptp->tri[0].vndx[1] = 1;
610 ptp->tri[0].vndx[2] = 2;
611 ptp->tri[0].afrac = 1;
612 } else {
613 Vert2_list *v2l = polyAlloc(sp->nfargs/3);
614 if (v2l == NULL)
615 goto memerr;
616 make_axes(ptp->uva, sp->snrm);
617 for (i = v2l->nv; i--; ) {
618 v2l->v[i].mX = DOT(sp->farg+3*i, ptp->uva[0]);
619 v2l->v[i].mY = DOT(sp->farg+3*i, ptp->uva[1]);
620 }
621 ptp->ntris = 0;
622 v2l->p = (void *)ptp;
623 if (!polyTriangulate(v2l, add_triangle)) {
624 fprintf(stderr,
625 "%s: cannot triangulate polygon '%s'\n",
626 progname, sp->sname);
627 return(0);
628 }
629 for (i = ptp->ntris; i--; ) {
630 int a = ptp->tri[i].vndx[0];
631 int b = ptp->tri[i].vndx[1];
632 int c = ptp->tri[i].vndx[2];
633 ptp->tri[i].afrac =
634 (v2l->v[a].mX*v2l->v[b].mY -
635 v2l->v[b].mX*v2l->v[a].mY +
636 v2l->v[b].mX*v2l->v[c].mY -
637 v2l->v[c].mX*v2l->v[b].mY +
638 v2l->v[c].mX*v2l->v[a].mY -
639 v2l->v[a].mX*v2l->v[c].mY) /
640 (2.*sp->area);
641 }
642 polyFree(v2l);
643 }
644 sp->priv = (void *)ptp;
645 }
646 /* pick triangle by partial area */
647 for (i = 0; i < ptp->ntris && x > ptp->tri[i].afrac; i++)
648 x -= ptp->tri[i].afrac;
649 SDmultiSamp(samp2, 2, x/ptp->tri[i].afrac);
650 samp2[0] *= samp2[1] = sqrt(samp2[1]);
651 samp2[1] = 1. - samp2[1];
652 v0 = sp->farg + 3*ptp->tri[i].vndx[0];
653 v1 = sp->farg + 3*ptp->tri[i].vndx[1];
654 v2 = sp->farg + 3*ptp->tri[i].vndx[2];
655 for (i = 3; i--; )
656 orig[i] = v0[i] + samp2[0]*(v1[i] - v0[i])
657 + samp2[1]*(v2[i] - v0[i]) ;
658 return(1);
659 memerr:
660 fputs(progname, stderr);
661 fputs(": out of memory in ssamp_poly!\n", stderr);
662 return(0);
663 }
664
665 /* Compute sample origin based on projected areas of sender subsurfaces */
666 static int
667 sample_origin(PARAMS *p, FVECT orig, const FVECT rdir, double x)
668 {
669 static double *projsa;
670 static int nall;
671 double tarea = 0;
672 int i;
673 SURF *sp;
674 /* special case for lone surface */
675 if (p->nsurfs == 1) {
676 sp = p->slist;
677 if (DOT(sp->snrm, rdir) >= -FTINY) {
678 fprintf(stderr,
679 "%s: internal - sample behind sender '%s'\n",
680 progname, sp->sname);
681 return(0);
682 }
683 return((*orig_in_surf[sp->styp])(orig, sp, x));
684 }
685 if (p->nsurfs > nall) { /* (re)allocate surface area cache */
686 if (projsa) free(projsa);
687 projsa = (double *)malloc(sizeof(double)*p->nsurfs);
688 if (!projsa) return(0);
689 nall = p->nsurfs;
690 }
691 /* compute projected areas */
692 for (i = 0, sp = p->slist; sp != NULL; i++, sp = sp->next) {
693 projsa[i] = -DOT(sp->snrm, rdir) * sp->area;
694 tarea += projsa[i] *= (double)(projsa[i] > FTINY);
695 }
696 if (tarea <= FTINY) { /* wrong side of sender? */
697 fputs(progname, stderr);
698 fputs(": internal - sample behind all sender elements!\n",
699 stderr);
700 return(0);
701 }
702 tarea *= x; /* get surface from list */
703 for (i = 0, sp = p->slist; tarea > projsa[i]; sp = sp->next)
704 tarea -= projsa[i++];
705 return((*orig_in_surf[sp->styp])(orig, sp, tarea/projsa[i]));
706 }
707
708 /* Uniform sample generator */
709 static int
710 sample_uniform(PARAMS *p, int b, FILE *fp)
711 {
712 int n = sampcnt;
713 double samp3[3];
714 double duvw[3];
715 FVECT orig_dir[2];
716 int i;
717
718 if (fp == NULL) /* just requesting number of bins? */
719 return(1);
720
721 while (n--) { /* stratified hemisphere sampling */
722 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
723 SDsquare2disk(duvw, samp3[1], samp3[2]);
724 duvw[2] = -sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
725 for (i = 3; i--; )
726 orig_dir[1][i] = duvw[0]*p->udir[i] +
727 duvw[1]*p->vdir[i] +
728 duvw[2]*p->nrm[i] ;
729 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
730 return(0);
731 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
732 return(0);
733 }
734 return(1);
735 }
736
737 /* Shirly-Chiu sample generator */
738 static int
739 sample_shirchiu(PARAMS *p, int b, FILE *fp)
740 {
741 int n = sampcnt;
742 double samp3[3];
743 double duvw[3];
744 FVECT orig_dir[2];
745 int i;
746
747 if (fp == NULL) /* just requesting number of bins? */
748 return(p->hsiz*p->hsiz);
749
750 while (n--) { /* stratified sampling */
751 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
752 SDsquare2disk(duvw, (b/p->hsiz + samp3[1])/curparams.hsiz,
753 (b%p->hsiz + samp3[2])/curparams.hsiz);
754 duvw[2] = sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
755 for (i = 3; i--; )
756 orig_dir[1][i] = -duvw[0]*p->udir[i] -
757 duvw[1]*p->vdir[i] -
758 duvw[2]*p->nrm[i] ;
759 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
760 return(0);
761 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
762 return(0);
763 }
764 return(1);
765 }
766
767 /* Reinhart/Tregenza sample generator */
768 static int
769 sample_reinhart(PARAMS *p, int b, FILE *fp)
770 {
771 #define T_NALT 7
772 static const int tnaz[T_NALT] = {30, 30, 24, 24, 18, 12, 6};
773 const int RowMax = T_NALT*p->hsiz + 1;
774 const double RAH = (.5*PI)/(RowMax-.5);
775 #define rnaz(r) (r >= RowMax-1 ? 1 : p->hsiz*tnaz[r/p->hsiz])
776 int n = sampcnt;
777 int row, col;
778 double samp3[3];
779 double alt, azi;
780 double duvw[3];
781 FVECT orig_dir[2];
782 int i;
783
784 if (fp == NULL) { /* just requesting number of bins? */
785 n = 0;
786 for (row = RowMax; row--; ) n += rnaz(row);
787 return(n);
788 }
789 row = 0; /* identify row & column */
790 col = b;
791 while (col >= rnaz(row)) {
792 col -= rnaz(row);
793 ++row;
794 }
795 while (n--) { /* stratified sampling */
796 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
797 alt = (row+samp3[1])*RAH;
798 azi = (2.*PI)*(col+samp3[2]-.5)/rnaz(row);
799 duvw[2] = cos(alt); /* measured from horizon */
800 duvw[0] = tsin(azi)*duvw[2];
801 duvw[1] = tcos(azi)*duvw[2];
802 duvw[2] = sqrt(1. - duvw[2]*duvw[2]);
803 for (i = 3; i--; )
804 orig_dir[1][i] = -duvw[0]*p->udir[i] -
805 duvw[1]*p->vdir[i] -
806 duvw[2]*p->nrm[i] ;
807 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
808 return(0);
809 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
810 return(0);
811 }
812 return(1);
813 #undef rnaz
814 #undef T_NALT
815 }
816
817 /* Klems sample generator */
818 static int
819 sample_klems(PARAMS *p, int b, FILE *fp)
820 {
821 static const char bname[4][20] = {
822 "LBNL/Klems Full",
823 "LBNL/Klems Half",
824 "INTERNAL ERROR",
825 "LBNL/Klems Quarter"
826 };
827 static ANGLE_BASIS *kbasis[4];
828 const int bi = p->hemis[1] - '1';
829 int n = sampcnt;
830 double samp2[2];
831 double duvw[3];
832 FVECT orig_dir[2];
833 int i;
834
835 if (!kbasis[bi]) { /* need to get basis, first */
836 for (i = 4; i--; )
837 if (!strcasecmp(abase_list[i].name, bname[bi])) {
838 kbasis[bi] = &abase_list[i];
839 break;
840 }
841 if (i < 0) {
842 fprintf(stderr, "%s: unknown hemisphere basis '%s'\n",
843 progname, bname[bi]);
844 return(0);
845 }
846 }
847 if (fp == NULL) /* just requesting number of bins? */
848 return(kbasis[bi]->nangles);
849
850 while (n--) { /* stratified sampling */
851 SDmultiSamp(samp2, 2, (n+frandom())/sampcnt);
852 if (!fo_getvec(duvw, b+samp2[1], kbasis[bi]))
853 return(0);
854 for (i = 3; i--; )
855 orig_dir[1][i] = -duvw[0]*p->udir[i] -
856 duvw[1]*p->vdir[i] -
857 duvw[2]*p->nrm[i] ;
858 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp2[0]))
859 return(0);
860 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
861 return(0);
862 }
863 return(1);
864 }
865
866 /* Prepare hemisphere basis sampler that will send rays to rcontrib */
867 static int
868 prepare_sampler(void)
869 {
870 if (curparams.slist == NULL) { /* missing sample surface! */
871 fputs(progname, stderr);
872 fputs(": no sender surface!\n", stderr);
873 return(-1);
874 }
875 /* misplaced output file spec. */
876 if ((curparams.outfn != NULL) & (verbose >= 0))
877 fprintf(stderr, "%s: warning - ignoring output file in sender ('%s')\n",
878 progname, curparams.outfn);
879 /* check/set basis hemisphere */
880 if (!curparams.hemis[0]) {
881 fputs(progname, stderr);
882 fputs(": missing sender sampling type!\n", stderr);
883 return(-1);
884 }
885 if (normalize(curparams.nrm) == 0) {
886 fputs(progname, stderr);
887 fputs(": undefined normal for sender sampling\n", stderr);
888 return(-1);
889 }
890 if (normalize(curparams.vup) == 0) {
891 if (fabs(curparams.nrm[2]) < .7)
892 curparams.vup[2] = 1;
893 else
894 curparams.vup[1] = 1;
895 }
896 fcross(curparams.udir, curparams.vup, curparams.nrm);
897 if (normalize(curparams.udir) == 0) {
898 fputs(progname, stderr);
899 fputs(": up vector coincides with sender normal\n", stderr);
900 return(-1);
901 }
902 fcross(curparams.vdir, curparams.nrm, curparams.udir);
903 if (curparams.sign == '-') { /* left-handed coordinate system? */
904 curparams.udir[0] *= -1.;
905 curparams.udir[1] *= -1.;
906 curparams.udir[2] *= -1.;
907 }
908 if (tolower(curparams.hemis[0]) == 'u' | curparams.hemis[0] == '1')
909 curparams.sample_basis = sample_uniform;
910 else if (tolower(curparams.hemis[0]) == 's' &&
911 tolower(curparams.hemis[1]) == 'c')
912 curparams.sample_basis = sample_shirchiu;
913 else if ((tolower(curparams.hemis[0]) == 'r') |
914 (tolower(curparams.hemis[0]) == 't'))
915 curparams.sample_basis = sample_reinhart;
916 else if (tolower(curparams.hemis[0]) == 'k') {
917 switch (curparams.hemis[1]) {
918 case '1':
919 case '2':
920 case '4':
921 break;
922 case 'f':
923 case 'F':
924 case '\0':
925 curparams.hemis[1] = '1';
926 break;
927 case 'h':
928 case 'H':
929 curparams.hemis[1] = '2';
930 break;
931 case 'q':
932 case 'Q':
933 curparams.hemis[1] = '4';
934 break;
935 default:
936 goto unrecognized;
937 }
938 curparams.hemis[2] = '\0';
939 curparams.sample_basis = sample_klems;
940 } else
941 goto unrecognized;
942 /* return number of bins */
943 return((*curparams.sample_basis)(&curparams,0,NULL));
944 unrecognized:
945 fprintf(stderr, "%s: unrecognized sender sampling: h=%s\n",
946 progname, curparams.hemis);
947 return(-1);
948 }
949
950 /* Compute normal and area for polygon */
951 static int
952 finish_polygon(SURF *p)
953 {
954 const int nv = p->nfargs / 3;
955 FVECT e1, e2, vc;
956 int i;
957
958 memset(p->snrm, 0, sizeof(FVECT));
959 VSUB(e1, p->farg+3, p->farg);
960 for (i = 2; i < nv; i++) {
961 VSUB(e2, p->farg+3*i, p->farg);
962 VCROSS(vc, e1, e2);
963 p->snrm[0] += vc[0];
964 p->snrm[1] += vc[1];
965 p->snrm[2] += vc[2];
966 VCOPY(e1, e2);
967 }
968 p->area = normalize(p->snrm)*0.5;
969 return(p->area > FTINY);
970 }
971
972 /* Add a surface to our current parameters */
973 static void
974 add_surface(int st, const char *oname, FILE *fp)
975 {
976 SURF *snew;
977 int n;
978 /* get floating-point arguments */
979 if (!fscanf(fp, "%d", &n)) return;
980 while (n-- > 0) fscanf(fp, "%*s");
981 if (!fscanf(fp, "%d", &n)) return;
982 while (n-- > 0) fscanf(fp, "%*d");
983 if (!fscanf(fp, "%d", &n) || n <= 0) return;
984 snew = (SURF *)malloc(sizeof(SURF) + sizeof(double)*(n-1));
985 if (snew == NULL) {
986 fputs(progname, stderr);
987 fputs(": out of memory!\n", stderr);
988 exit(1);
989 }
990 strncpy(snew->sname, oname, sizeof(snew->sname)-1);
991 snew->sname[sizeof(snew->sname)-1] = '\0';
992 snew->styp = st;
993 snew->priv = NULL;
994 snew->nfargs = n;
995 for (n = 0; n < snew->nfargs; n++)
996 if (fscanf(fp, "%lf", &snew->farg[n]) != 1) {
997 fprintf(stderr, "%s: error reading arguments for '%s'\n",
998 progname, oname);
999 exit(1);
1000 }
1001 switch (st) {
1002 case ST_RING:
1003 if (snew->nfargs != 8)
1004 goto badcount;
1005 VCOPY(snew->snrm, snew->farg+3);
1006 if (normalize(snew->snrm) == 0)
1007 goto badnorm;
1008 if (snew->farg[7] < snew->farg[6]) {
1009 double t = snew->farg[7];
1010 snew->farg[7] = snew->farg[6];
1011 snew->farg[6] = t;
1012 }
1013 snew->area = PI*(snew->farg[7]*snew->farg[7] -
1014 snew->farg[6]*snew->farg[6]);
1015 break;
1016 case ST_POLY:
1017 if (snew->nfargs < 9 || snew->nfargs % 3)
1018 goto badcount;
1019 finish_polygon(snew);
1020 break;
1021 case ST_SOURCE:
1022 if (snew->nfargs != 4)
1023 goto badcount;
1024 for (n = 3; n--; ) /* need to reverse "normal" */
1025 snew->snrm[n] = -snew->farg[n];
1026 if (normalize(snew->snrm) == 0)
1027 goto badnorm;
1028 snew->area = sin((PI/180./2.)*snew->farg[3]);
1029 snew->area *= PI*snew->area;
1030 break;
1031 }
1032 if ((snew->area <= FTINY) & (verbose >= 0)) {
1033 fprintf(stderr, "%s: warning - zero area for surface '%s'\n",
1034 progname, oname);
1035 free(snew);
1036 return;
1037 }
1038 VSUM(curparams.nrm, curparams.nrm, snew->snrm, snew->area);
1039 snew->next = curparams.slist;
1040 curparams.slist = snew;
1041 curparams.nsurfs++;
1042 return;
1043 badcount:
1044 fprintf(stderr, "%s: bad argument count for surface element '%s'\n",
1045 progname, oname);
1046 exit(1);
1047 badnorm:
1048 fprintf(stderr, "%s: bad orientation for surface element '%s'\n",
1049 progname, oname);
1050 exit(1);
1051 }
1052
1053 /* Parse a receiver object (look for modifiers to add to rcontrib command) */
1054 static int
1055 add_recv_object(FILE *fp)
1056 {
1057 int st;
1058 char thismod[128], otype[32], oname[128];
1059 int n;
1060
1061 if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3)
1062 return(0); /* must have hit EOF! */
1063 if (!strcmp(otype, "alias")) {
1064 fscanf(fp, "%*s"); /* skip alias */
1065 return(0);
1066 }
1067 /* is it a new receiver? */
1068 if ((st = surf_type(otype)) != ST_NONE) {
1069 if (curparams.slist != NULL && (st == ST_SOURCE) ^
1070 (curparams.slist->styp == ST_SOURCE)) {
1071 fputs(progname, stderr);
1072 fputs(": cannot mix source/non-source receivers!\n", stderr);
1073 return(-1);
1074 }
1075 if (strcmp(thismod, curmod)) {
1076 if (curmod[0]) { /* output last receiver? */
1077 finish_receiver();
1078 clear_params(&curparams, 1);
1079 }
1080 parse_params(&curparams, newparams);
1081 newparams[0] = '\0';
1082 strcpy(curmod, thismod);
1083 }
1084 add_surface(st, oname, fp); /* read & store surface */
1085 return(1);
1086 }
1087 /* else skip arguments */
1088 if (!fscanf(fp, "%d", &n)) return(0);
1089 while (n-- > 0) fscanf(fp, "%*s");
1090 if (!fscanf(fp, "%d", &n)) return(0);
1091 while (n-- > 0) fscanf(fp, "%*d");
1092 if (!fscanf(fp, "%d", &n)) return(0);
1093 while (n-- > 0) fscanf(fp, "%*f");
1094 return(0);
1095 }
1096
1097 /* Parse a sender object */
1098 static int
1099 add_send_object(FILE *fp)
1100 {
1101 int st;
1102 char thismod[128], otype[32], oname[128];
1103 int n;
1104
1105 if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3)
1106 return(0); /* must have hit EOF! */
1107 if (!strcmp(otype, "alias")) {
1108 fscanf(fp, "%*s"); /* skip alias */
1109 return(0);
1110 }
1111 /* is it a new surface? */
1112 if ((st = surf_type(otype)) != ST_NONE) {
1113 if (st == ST_SOURCE) {
1114 fputs(progname, stderr);
1115 fputs(": cannot use source as a sender!\n", stderr);
1116 return(-1);
1117 }
1118 if (strcmp(thismod, curmod)) {
1119 if (curmod[0]) {
1120 fputs(progname, stderr);
1121 fputs(": warning - multiple modifiers in sender\n",
1122 stderr);
1123 }
1124 strcpy(curmod, thismod);
1125 }
1126 parse_params(&curparams, newparams);
1127 newparams[0] = '\0';
1128 add_surface(st, oname, fp); /* read & store surface */
1129 return(0);
1130 }
1131 /* else skip arguments */
1132 if (!fscanf(fp, "%d", &n)) return(0);
1133 while (n-- > 0) fscanf(fp, "%*s");
1134 if (!fscanf(fp, "%d", &n)) return(0);
1135 while (n-- > 0) fscanf(fp, "%*d");
1136 if (!fscanf(fp, "%d", &n)) return(0);
1137 while (n-- > 0) fscanf(fp, "%*f");
1138 return(0);
1139 }
1140
1141 /* Load a Radiance scene using the given callback function for objects */
1142 static int
1143 load_scene(const char *inspec, int (*ocb)(FILE *))
1144 {
1145 int rv = 0;
1146 char inpbuf[1024];
1147 FILE *fp;
1148 int c;
1149
1150 if (*inspec == '!')
1151 fp = popen(inspec+1, "r");
1152 else
1153 fp = fopen(inspec, "r");
1154 if (fp == NULL) {
1155 fprintf(stderr, "%s: cannot load '%s'\n", progname, inspec);
1156 return(-1);
1157 }
1158 while ((c = getc(fp)) != EOF) { /* load receiver data */
1159 if (isspace(c)) /* skip leading white space */
1160 continue;
1161 if (c == '!') { /* read from a new command */
1162 inpbuf[0] = c;
1163 if (fgetline(inpbuf+1, sizeof(inpbuf)-1, fp) != NULL) {
1164 if ((c = load_scene(inpbuf, ocb)) < 0)
1165 return(c);
1166 rv += c;
1167 }
1168 continue;
1169 }
1170 if (c == '#') { /* parameters/comment */
1171 if ((c = getc(fp)) == EOF || ungetc(c,fp) == EOF)
1172 break;
1173 if (!isspace(c) && fscanf(fp, "%s", inpbuf) == 1 &&
1174 !strcmp(inpbuf, PARAMSTART)) {
1175 if (fgets(inpbuf, sizeof(inpbuf), fp) != NULL)
1176 strcat(newparams, inpbuf);
1177 continue;
1178 }
1179 while ((c = getc(fp)) != EOF && c != '\n')
1180 ; /* else skipping comment */
1181 continue;
1182 }
1183 ungetc(c, fp); /* else check object for receiver */
1184 c = (*ocb)(fp);
1185 if (c < 0)
1186 return(c);
1187 rv += c;
1188 }
1189 /* close our input stream */
1190 c = (*inspec == '!') ? pclose(fp) : fclose(fp);
1191 if (c != 0) {
1192 fprintf(stderr, "%s: error loading '%s'\n", progname, inspec);
1193 return(-1);
1194 }
1195 return(rv);
1196 }
1197
1198 /* Get command arguments and run program */
1199 int
1200 main(int argc, char *argv[])
1201 {
1202 char fmtopt[6] = "-faa"; /* default output is ASCII */
1203 char *xrs=NULL, *yrs=NULL, *ldopt=NULL;
1204 char *iropt = NULL;
1205 char *sendfn;
1206 char sampcntbuf[32], nsbinbuf[32];
1207 FILE *rcfp;
1208 int nsbins;
1209 int a, i;
1210 /* screen rcontrib options */
1211 progname = argv[0];
1212 for (a = 1; a < argc-2; a++) {
1213 int na;
1214 /* check for argument expansion */
1215 while ((na = expandarg(&argc, &argv, a)) > 0)
1216 ;
1217 if (na < 0) {
1218 fprintf(stderr, "%s: cannot expand '%s'\n",
1219 progname, argv[a]);
1220 return(1);
1221 }
1222 if (argv[a][0] != '-' || !argv[a][1])
1223 break;
1224 na = 1;
1225 switch (argv[a][1]) { /* !! Keep consistent !! */
1226 case 'v': /* verbose mode */
1227 verbose = 1;
1228 na = 0;
1229 continue;
1230 case 'f': /* special case for -fo, -ff, etc. */
1231 switch (argv[a][2]) {
1232 case '\0': /* cal file */
1233 goto userr;
1234 case 'o': /* force output */
1235 goto userr;
1236 case 'a': /* output format */
1237 case 'f':
1238 case 'd':
1239 case 'c':
1240 if (!(fmtopt[3] = argv[a][3]))
1241 fmtopt[3] = argv[a][2];
1242 fmtopt[2] = argv[a][2];
1243 na = 0;
1244 continue; /* will pass later */
1245 default:
1246 goto userr;
1247 }
1248 break;
1249 case 'x': /* x-resolution */
1250 xrs = argv[++a];
1251 na = 0;
1252 continue;
1253 case 'y': /* y-resolution */
1254 yrs = argv[++a];
1255 na = 0;
1256 continue;
1257 case 'c': /* number of samples */
1258 sampcnt = atoi(argv[++a]);
1259 if (sampcnt <= 0)
1260 goto userr;
1261 na = 0; /* we re-add this later */
1262 continue;
1263 case 'I': /* only for pass-through mode */
1264 case 'i':
1265 iropt = argv[a];
1266 na = 0;
1267 continue;
1268 case 'w': /* options without arguments */
1269 if (argv[a][2] != '+') verbose = -1;
1270 case 'V':
1271 case 'u':
1272 case 'h':
1273 case 'r':
1274 break;
1275 case 'n': /* options with 1 argument */
1276 case 's':
1277 case 'o':
1278 na = 2;
1279 break;
1280 case 'b': /* special case */
1281 if (argv[a][2] != 'v') goto userr;
1282 break;
1283 case 'l': /* special case */
1284 if (argv[a][2] == 'd') {
1285 ldopt = argv[a];
1286 na = 0;
1287 continue;
1288 }
1289 na = 2;
1290 break;
1291 case 'd': /* special case */
1292 if (argv[a][2] != 'v') na = 2;
1293 break;
1294 case 'a': /* special case */
1295 if (argv[a][2] == 'p') {
1296 na = 2; /* photon map [+ bandwidth(s)] */
1297 if (a < argc-3 && atoi(argv[a+1]) > 0)
1298 na += 1 + (a < argc-4 && atoi(argv[a+2]) > 0);
1299 } else
1300 na = (argv[a][2] == 'v') ? 4 : 2;
1301 break;
1302 case 'm': /* special case */
1303 if (!argv[a][2]) goto userr;
1304 na = (argv[a][2] == 'e') | (argv[a][2] == 'a') ? 4 : 2;
1305 break;
1306 default: /* anything else is verbotten */
1307 goto userr;
1308 }
1309 if (na <= 0) continue;
1310 CHECKARGC(na); /* pass on option */
1311 rcarg[nrcargs++] = argv[a];
1312 while (--na) /* + arguments if any */
1313 rcarg[nrcargs++] = argv[++a];
1314 }
1315 if (a > argc-2)
1316 goto userr; /* check at end of options */
1317 sendfn = argv[a++]; /* assign sender & receiver inputs */
1318 if (sendfn[0] == '-') { /* user wants pass-through mode? */
1319 if (sendfn[1]) goto userr;
1320 sendfn = NULL;
1321 if (iropt) {
1322 CHECKARGC(1);
1323 rcarg[nrcargs++] = iropt;
1324 }
1325 if (xrs) {
1326 CHECKARGC(2);
1327 rcarg[nrcargs++] = "-x";
1328 rcarg[nrcargs++] = xrs;
1329 }
1330 if (yrs) {
1331 CHECKARGC(2);
1332 rcarg[nrcargs++] = "-y";
1333 rcarg[nrcargs++] = yrs;
1334 }
1335 if (ldopt) {
1336 CHECKARGC(1);
1337 rcarg[nrcargs++] = ldopt;
1338 }
1339 if (sampcnt <= 0) sampcnt = 1;
1340 } else { /* else in sampling mode */
1341 if (iropt) {
1342 fputs(progname, stderr);
1343 fputs(": -i, -I supported for pass-through only\n", stderr);
1344 return(1);
1345 }
1346 fmtopt[2] = (sizeof(RREAL)==sizeof(double)) ? 'd' : 'f';
1347 if (sampcnt <= 0) sampcnt = 10000;
1348 }
1349 sprintf(sampcntbuf, "%d", sampcnt);
1350 CHECKARGC(3); /* add our format & sample count */
1351 rcarg[nrcargs++] = fmtopt;
1352 rcarg[nrcargs++] = "-c";
1353 rcarg[nrcargs++] = sampcntbuf;
1354 /* add receiver arguments to rcontrib */
1355 if (load_scene(argv[a], add_recv_object) < 0)
1356 return(1);
1357 finish_receiver();
1358 if (sendfn == NULL) { /* pass-through mode? */
1359 CHECKARGC(1); /* add octree */
1360 rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1361 rcarg[nrcargs] = NULL;
1362 return(my_exec(rcarg)); /* rcontrib does everything */
1363 }
1364 clear_params(&curparams, 0); /* else load sender surface & params */
1365 curmod[0] = '\0';
1366 if (load_scene(sendfn, add_send_object) < 0)
1367 return(1);
1368 if ((nsbins = prepare_sampler()) <= 0)
1369 return(1);
1370 CHECKARGC(3); /* add row count and octree */
1371 rcarg[nrcargs++] = "-y";
1372 sprintf(nsbinbuf, "%d", nsbins);
1373 rcarg[nrcargs++] = nsbinbuf;
1374 rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1375 rcarg[nrcargs] = NULL;
1376 /* open pipe to rcontrib process */
1377 if ((rcfp = popen_arglist(rcarg, "w")) == NULL)
1378 return(1);
1379 SET_FILE_BINARY(rcfp);
1380 #ifdef getc_unlocked
1381 flockfile(rcfp);
1382 #endif
1383 if (verbose > 0) {
1384 fprintf(stderr, "%s: sampling %d directions", progname, nsbins);
1385 if (curparams.nsurfs > 1)
1386 fprintf(stderr, " (%d elements)\n", curparams.nsurfs);
1387 else
1388 fputc('\n', stderr);
1389 }
1390 for (i = 0; i < nsbins; i++) /* send rcontrib ray samples */
1391 if (!(*curparams.sample_basis)(&curparams, i, rcfp))
1392 return(1);
1393 return(pclose(rcfp) < 0); /* all finished! */
1394 userr:
1395 if (a < argc-2)
1396 fprintf(stderr, "%s: unsupported option '%s'", progname, argv[a]);
1397 fprintf(stderr, "Usage: %s [-v][rcontrib options] sender.rad receiver.rad [-i system.oct] [system.rad ..]\n",
1398 progname);
1399 return(1);
1400 }
