root/radiance/ray/src/util/rfluxmtx.c
Revision: 2.10
Committed: Fri Jul 25 17:03:06 2014 UTC (9 years, 10 months ago) by greg
Changes since 2.9: +10 -8 lines
Fixed other missing return values
2 static const char RCSid[] = "$Id: rfluxmtx.c,v 2.9 2014/07/25 16:58:20 greg Exp $";
5 * Calculate flux transfer matrix or matrices using rcontrib
6 */
7
8 #include "copyright.h"
9
10 #include <ctype.h>
11 #include <stdlib.h>
12 #include "rtio.h"
13 #include "rtmath.h"
14 #include "bsdf.h"
15 #include "bsdf_m.h"
16 #include "random.h"
17 #include "triangulate.h"
18 #include "platform.h"
19
20 #ifdef getc_unlocked /* avoid horrendous overhead of flockfile */
21 #undef getc
22 #define getc getc_unlocked
23 #endif
24
25 #ifdef _WIN32
26 #define SPECIALS " \t\"$*?"
27 #define QUOTCHAR '"'
28 #else
29 #define SPECIALS " \t\n'\"()${}*?[];|&"
30 #define QUOTCHAR '\''
31 #define ALTQUOT '"'
32 #endif
33
34 #define MAXRCARG 512
35
36 char *progname; /* global argv[0] */
37
38 int verbose = 0; /* verbose mode? */
39
40 char *rcarg[MAXRCARG+1] = {"rcontrib", "-fo+"};
41 int nrcargs = 2;
42
43 const char overflowerr[] = "%s: too many arguments!\n";
44
45 #define CHECKARGC(n) if (nrcargs >= MAXRCARG-(n)) \
46 { fprintf(stderr, overflowerr, progname); exit(1); }
47
48 int sampcnt = 0; /* sample count (0==unset) */
49
50 char *reinhfn = "reinhartb.cal";
51 char *shirchiufn = "disk2square.cal";
52 char *kfullfn = "klems_full.cal";
53 char *khalffn = "klems_half.cal";
54 char *kquarterfn = "klems_quarter.cal";
55
56 /* string indicating parameters */
57 const char PARAMSTART[] = "@rfluxmtx";
58
59 /* surface type IDs */
60 #define ST_NONE 0
61 #define ST_POLY 1
62 #define ST_RING 2
63 #define ST_SOURCE 3
64
65 typedef struct surf_s {
66 struct surf_s *next; /* next surface in list */
67 void *priv; /* private data (malloc'ed) */
68 char sname[32]; /* surface name */
69 FVECT snrm; /* surface normal */
70 double area; /* surface area / proj. solid angle */
71 short styp; /* surface type */
72 short nfargs; /* number of real arguments */
73 double farg[1]; /* real values (extends struct) */
74 } SURF; /* surface structure */
75
76 typedef struct {
77 FVECT uva[2]; /* tangent axes */
78 int ntris; /* number of triangles */
79 struct ptri {
80 float afrac; /* fraction of total area */
81 short vndx[3]; /* vertex indices */
82 } tri[1]; /* triangle array (extends struct) */
83 } POLYTRIS; /* triangulated polygon */
84
85 typedef struct param_s {
86 char hemis[32]; /* hemispherical sampling spec. */
87 int hsiz; /* hemisphere basis size */
88 int nsurfs; /* number of surfaces */
89 SURF *slist; /* list of surfaces */
90 FVECT vup; /* up vector (zero if unset) */
91 FVECT nrm; /* average normal direction */
92 FVECT udir, vdir; /* v-up tangent axes */
93 char *outfn; /* output file name (receiver) */
94 int (*sample_basis)(struct param_s *p, int, FILE *);
95 } PARAMS; /* sender/receiver parameters */
96
97 PARAMS curparams;
98 char curmod[128];
99 char newparams[1024];
100
101 typedef int SURFSAMP(FVECT, SURF *, double);
102
103 static SURFSAMP ssamp_bad, ssamp_poly, ssamp_ring;
104
105 SURFSAMP *orig_in_surf[4] = {
106 ssamp_bad, ssamp_poly, ssamp_ring, ssamp_bad
107 };
108
109 /* Clear parameter set */
110 static void
111 clear_params(PARAMS *p, int reset_only)
112 {
113 while (p->slist != NULL) {
114 SURF *sdel = p->slist;
115 p->slist = sdel->next;
116 if (sdel->priv != NULL)
117 free(sdel->priv);
118 free(sdel);
119 }
120 if (reset_only) {
121 p->nsurfs = 0;
122 memset(p->nrm, 0, sizeof(FVECT));
123 memset(p->vup, 0, sizeof(FVECT));
124 p->outfn = NULL;
125 return;
126 }
127 memset(p, 0, sizeof(PARAMS));
128 }
129
130 /* Get surface type from name */
131 static int
132 surf_type(const char *otype)
133 {
134 if (!strcmp(otype, "polygon"))
135 return(ST_POLY);
136 if (!strcmp(otype, "ring"))
137 return(ST_RING);
138 if (!strcmp(otype, "source"))
139 return(ST_SOURCE);
140 return(ST_NONE);
141 }
142
143 /* Add arguments to oconv command */
144 static char *
145 oconv_command(int ac, char *av[])
146 {
147 static char oconvbuf[2048] = "!oconv -f";
148 char *cp = oconvbuf + 9;
149
150 while (ac-- > 0) {
151 if (cp >= oconvbuf+(sizeof(oconvbuf)-32)) {
152 fputs(progname, stderr);
153 fputs(": too many file arguments!\n", stderr);
154 exit(1);
155 }
156 *cp++ = ' ';
157 strcpy(cp, *av++);
158 while (*cp) cp++;
159 }
160 *cp = '\0';
161 return(oconvbuf);
162 }
163
164 /* Check if any of the characters in str2 are found in str1 */
165 static int
166 matchany(const char *str1, const char *str2)
167 {
168 while (*str1) {
169 const char *cp = str2;
170 while (*cp)
171 if (*cp++ == *str1)
172 return(*str1);
173 ++str1;
174 }
175 return(0);
176 }
177
178
179 /* Convert a set of arguments into a command line for pipe() or system() */
180 static char *
181 convert_commandline(char *cmd, const int len, char *av[])
182 {
183 int match;
184 char *cp;
185
186 for (cp = cmd; *av != NULL; av++) {
187 const int n = strlen(*av);
188 if (cp+n >= cmd+(len-3)) {
189 fputs(progname, stderr);
190 return(NULL);
191 }
192 if ((match = matchany(*av, SPECIALS))) {
193 const int quote =
194 #ifdef ALTQUOT
195 (match == QUOTCHAR) ? ALTQUOT :
196 #endif
197 QUOTCHAR;
198 *cp++ = quote;
199 strcpy(cp, *av);
200 cp += n;
201 *cp++ = quote;
202 } else {
203 strcpy(cp, *av);
204 cp += n;
205 }
206 *cp++ = ' ';
207 }
208 if (cp <= cmd)
209 return(NULL);
210 *--cp = '\0';
211 return(cmd);
212 }
213
214 /* Open a pipe to/from a command given as an argument list */
215 static FILE *
216 popen_arglist(char *av[], char *mode)
217 {
218 char cmd[10240];
219
220 if (!convert_commandline(cmd, sizeof(cmd), av)) {
221 fputs(progname, stderr);
222 fputs(": command line too long in popen_arglist()\n", stderr);
223 return(NULL);
224 }
225 if (verbose)
226 fprintf(stderr, "%s: opening pipe %s: %s\n",
227 progname, (*mode=='w') ? "to" : "from", cmd);
228 return(popen(cmd, mode));
229 }
230
231 #ifdef _WIN32
232 /* Execute system command (Windows version) */
233 static int
234 my_exec(char *av[])
235 {
236 char cmd[10240];
237
238 if (!convert_commandline(cmd, sizeof(cmd), av)) {
239 fputs(progname, stderr);
240 fputs(": command line too long in my_exec()\n", stderr);
241 return(1);
242 }
243 if (verbose)
244 fprintf(stderr, "%s: running: %s\n", progname, cmd);
245 return(system(cmd));
246 }
247 #else
248 /* Execute system command in our stead (Unix version) */
249 static int
250 my_exec(char *av[])
251 {
252 char *compath;
253
254 if ((compath = getpath((char *)av[0], getenv("PATH"), X_OK)) == NULL) {
255 fprintf(stderr, "%s: cannot locate %s\n", progname, av[0]);
256 return(1);
257 }
258 if (verbose) {
259 char cmd[4096];
260 if (!convert_commandline(cmd, sizeof(cmd), av))
261 strcpy(cmd, "COMMAND TOO LONG TO SHOW");
262 fprintf(stderr, "%s: running: %s\n", progname, cmd);
263 }
264 execv(compath, av); /* successful call never returns */
265 perror(compath);
266 return(1);
267 }
268 #endif
269
270 /* Get normalized direction vector from string specification */
271 static int
272 get_direction(FVECT dv, const char *s)
273 {
274 int sign = 1;
275 int axis = 0;
276
277 memset(dv, 0, sizeof(FVECT));
278 nextchar:
279 switch (*s) {
280 case '+':
281 ++s;
282 goto nextchar;
283 case '-':
284 sign = -sign;
285 ++s;
286 goto nextchar;
287 case 'z':
288 case 'Z':
289 ++axis;
290 case 'y':
291 case 'Y':
292 ++axis;
293 case 'x':
294 case 'X':
295 dv[axis] = sign;
296 return(!s[1] | isspace(s[1]));
297 default:
298 break;
299 }
300 #ifdef SMLFLT
301 if (sscanf(s, "%f,%f,%f", &dv[0], &dv[1], &dv[2]) != 3)
302 #else
303 if (sscanf(s, "%lf,%lf,%lf", &dv[0], &dv[1], &dv[2]) != 3)
304 #endif
305 return(0);
306 dv[0] *= (RREAL)sign;
307 return(normalize(dv) > 0);
308 }
309
310 /* Parse program parameters (directives) */
311 static int
312 parse_params(PARAMS *p, char *pargs)
313 {
314 char *cp = pargs;
315 int nparams = 0;
316 int i;
317
318 for ( ; ; )
319 switch (*cp++) {
320 case 'h':
321 if (*cp++ != '=')
322 break;
323 p->hsiz = 0;
324 i = 0;
325 while (*cp && !isspace(*cp)) {
326 if (isdigit(*cp))
327 p->hsiz = 10*p->hsiz + *cp - '0';
328 p->hemis[i++] = *cp++;
329 }
330 if (!i)
331 break;
332 p->hemis[i] = '\0';
333 p->hsiz += !p->hsiz;
334 ++nparams;
335 continue;
336 case 'u':
337 if (*cp++ != '=')
338 break;
339 if (!get_direction(p->vup, cp))
340 break;
341 ++nparams;
342 continue;
343 case 'o':
344 if (*cp++ != '=')
345 break;
346 i = 0;
347 while (*cp && !isspace(*cp++))
348 i++;
349 if (!i)
350 break;
351 *--cp = '\0';
352 p->outfn = savqstr(cp-i);
353 *cp++ = ' ';
354 ++nparams;
355 continue;
356 case ' ':
357 case '\t':
358 case '\r':
359 case '\n':
360 continue;
361 case '\0':
362 return(nparams);
363 default:
364 break;
365 }
366 fprintf(stderr, "%s: bad parameter string '%s'\n", progname, pargs);
367 exit(1);
368 return(-1); /* pro forma return */
369 }
370
371 /* Add receiver arguments (directives) corresponding to the current modifier */
372 static void
373 finish_receiver(void)
374 {
375 char sbuf[256];
376 int uniform = 0;
377 char *calfn = NULL;
378 char *params = NULL;
379 char *binv = NULL;
380 char *binf = NULL;
381 char *nbins = NULL;
382
383 if (!curmod[0]) {
384 fputs(progname, stderr);
385 fputs(": missing receiver surface!\n", stderr);
386 exit(1);
387 }
388 if (curparams.outfn != NULL) { /* add output file spec. */
389 CHECKARGC(2);
390 rcarg[nrcargs++] = "-o";
391 rcarg[nrcargs++] = curparams.outfn;
392 }
393 /* check arguments */
394 if (!curparams.hemis[0]) {
395 fputs(progname, stderr);
396 fputs(": missing hemisphere sampling type!\n", stderr);
397 exit(1);
398 }
399 if (normalize(curparams.nrm) == 0) {
400 fputs(progname, stderr);
401 fputs(": undefined normal for hemisphere sampling\n", stderr);
402 exit(1);
403 }
404 if (normalize(curparams.vup) == 0) {
405 if (fabs(curparams.nrm[2]) < .7)
406 curparams.vup[2] = 1;
407 else
408 curparams.vup[1] = 1;
409 }
410 /* determine sample type/bin */
411 if (tolower(curparams.hemis[0]) == 'u' | curparams.hemis[0] == '1') {
412 binv = "0"; /* uniform sampling -- one bin */
413 uniform = 1;
414 } else if (tolower(curparams.hemis[0]) == 's' &&
415 tolower(curparams.hemis[1]) == 'c') {
416 /* assign parameters */
417 if (curparams.hsiz <= 1) {
418 fputs(progname, stderr);
419 fputs(": missing size for Shirley-Chiu sampling!\n", stderr);
420 exit(1);
421 }
422 calfn = shirchiufn; shirchiufn = NULL;
423 sprintf(sbuf, "SCdim=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g",
424 curparams.hsiz,
425 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
426 curparams.vup[0], curparams.vup[1], curparams.vup[2]);
427 params = savqstr(sbuf);
428 binv = "scbin";
429 nbins = "SCdim*SCdim";
430 } else if ((tolower(curparams.hemis[0]) == 'r') |
431 (tolower(curparams.hemis[0]) == 't')) {
432 calfn = reinhfn; reinhfn = NULL;
433 sprintf(sbuf, "MF=%d,rNx=%g,rNy=%g,rNz=%g,Ux=%g,Uy=%g,Uz=%g",
434 curparams.hsiz,
435 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
436 curparams.vup[0], curparams.vup[1], curparams.vup[2]);
437 params = savqstr(sbuf);
438 binv = "rbin";
439 nbins = "Nrbins";
440 } else if (tolower(curparams.hemis[0]) == 'k' &&
441 !curparams.hemis[1] |
442 (tolower(curparams.hemis[1]) == 'f') |
443 (curparams.hemis[1] == '1')) {
444 calfn = kfullfn; kfullfn = NULL;
445 binf = "kbin";
446 nbins = "Nkbins";
447 } else if (tolower(curparams.hemis[0]) == 'k' &&
448 (tolower(curparams.hemis[1]) == 'h') |
449 (curparams.hemis[1] == '2')) {
450 calfn = khalffn; khalffn = NULL;
451 binf = "khbin";
452 nbins = "Nkhbins";
453 } else if (tolower(curparams.hemis[0]) == 'k' &&
454 (tolower(curparams.hemis[1]) == 'q') |
455 (curparams.hemis[1] == '4')) {
456 calfn = kquarterfn; kquarterfn = NULL;
457 binf = "kqbin";
458 nbins = "Nkqbins";
459 } else {
460 fprintf(stderr, "%s: unrecognized hemisphere sampling: h=%s\n",
461 progname, curparams.hemis);
462 exit(1);
463 }
464 if (!uniform & (curparams.slist->styp == ST_SOURCE)) {
465 SURF *sp;
466 for (sp = curparams.slist; sp != NULL; sp = sp->next)
467 if (fabs(sp->area - PI) > 1e-3) {
468 fprintf(stderr, "%s: source '%s' must be 180-degrees\n",
469 progname, sp->sname);
470 exit(1);
471 }
472 }
473 if (calfn != NULL) { /* add cal file if needed */
474 CHECKARGC(2);
475 rcarg[nrcargs++] = "-f";
476 rcarg[nrcargs++] = calfn;
477 }
478 if (params != NULL) { /* parameters _after_ cal file */
479 CHECKARGC(2);
480 rcarg[nrcargs++] = "-p";
481 rcarg[nrcargs++] = params;
482 }
483 if (nbins != NULL) { /* add #bins if set */
484 CHECKARGC(2);
485 rcarg[nrcargs++] = "-bn";
486 rcarg[nrcargs++] = nbins;
487 }
488 if (binv != NULL) {
489 CHECKARGC(2); /* assign bin variable */
490 rcarg[nrcargs++] = "-b";
491 rcarg[nrcargs++] = binv;
492 } else if (binf != NULL) {
493 CHECKARGC(2); /* assign bin function */
494 rcarg[nrcargs++] = "-b";
495 sprintf(sbuf, "%s(%g,%g,%g,%g,%g,%g)", binf,
496 curparams.nrm[0], curparams.nrm[1], curparams.nrm[2],
497 curparams.vup[0], curparams.vup[1], curparams.vup[2]);
498 rcarg[nrcargs++] = savqstr(sbuf);
499 }
500 CHECKARGC(2); /* modifier argument goes last */
501 rcarg[nrcargs++] = "-m";
502 rcarg[nrcargs++] = savqstr(curmod);
503 }
504
505 /* Make randomly oriented tangent plane axes for given normal direction */
506 static void
507 make_axes(FVECT uva[2], const FVECT nrm)
508 {
509 int i;
510
511 uva[1][0] = 0.5 - frandom();
512 uva[1][1] = 0.5 - frandom();
513 uva[1][2] = 0.5 - frandom();
514 for (i = 3; i--; )
515 if ((-0.6 < nrm[i]) & (nrm[i] < 0.6))
516 break;
517 if (i < 0) {
518 fputs(progname, stderr);
519 fputs(": bad surface normal in make_axes!\n", stderr);
520 exit(1);
521 }
522 uva[1][i] = 1.0;
523 VCROSS(uva[0], uva[1], nrm);
524 normalize(uva[0]);
525 VCROSS(uva[1], nrm, uva[0]);
526 }
527
528 /* Illegal sender surfaces end up here */
529 static int
530 ssamp_bad(FVECT orig, SURF *sp, double x)
531 {
532 fprintf(stderr, "%s: illegal sender surface '%s'\n",
533 progname, sp->sname);
534 return(0);
535 }
536
537 /* Generate origin on ring surface from uniform random variable */
538 static int
539 ssamp_ring(FVECT orig, SURF *sp, double x)
540 {
541 FVECT *uva = (FVECT *)sp->priv;
542 double samp2[2];
543 double uv[2];
544 int i;
545
546 if (uva == NULL) { /* need tangent axes */
547 uva = (FVECT *)malloc(sizeof(FVECT)*2);
548 if (uva == NULL) {
549 fputs(progname, stderr);
550 fputs(": out of memory in ssamp_ring!\n", stderr);
551 return(0);
552 }
553 make_axes(uva, sp->snrm);
554 sp->priv = (void *)uva;
555 }
556 SDmultiSamp(samp2, 2, x);
557 samp2[0] = sqrt(samp2[0]*sp->area*(1./PI) + sp->farg[6]*sp->farg[6]);
558 samp2[1] *= 2.*PI;
559 uv[0] = samp2[0]*tcos(samp2[1]);
560 uv[1] = samp2[0]*tsin(samp2[1]);
561 for (i = 3; i--; )
562 orig[i] = sp->farg[i] + uv[0]*uva[0][i] + uv[1]*uva[1][i];
563 return(1);
564 }
565
566 /* Add triangle to polygon's list (call-back function) */
567 static int
568 add_triangle(const Vert2_list *tp, int a, int b, int c)
569 {
570 POLYTRIS *ptp = (POLYTRIS *)tp->p;
571 struct ptri *trip = ptp->tri + ptp->ntris++;
572
573 trip->vndx[0] = a;
574 trip->vndx[1] = b;
575 trip->vndx[2] = c;
576 return(1);
577 }
578
579 /* Generate origin on polygon surface from uniform random variable */
580 static int
581 ssamp_poly(FVECT orig, SURF *sp, double x)
582 {
583 POLYTRIS *ptp = (POLYTRIS *)sp->priv;
584 double samp2[2];
585 double *v0, *v1, *v2;
586 int i;
587
588 if (ptp == NULL) { /* need to triangulate */
589 ptp = (POLYTRIS *)malloc(sizeof(POLYTRIS) +
590 sizeof(struct ptri)*(sp->nfargs/3 - 3));
591 if (ptp == NULL)
592 goto memerr;
593 if (sp->nfargs == 3) { /* simple case */
594 ptp->ntris = 1;
595 ptp->tri[0].vndx[0] = 0;
596 ptp->tri[0].vndx[1] = 1;
597 ptp->tri[0].vndx[2] = 2;
598 ptp->tri[0].afrac = 1;
599 } else {
600 Vert2_list *v2l = polyAlloc(sp->nfargs/3);
601 if (v2l == NULL)
602 goto memerr;
603 make_axes(ptp->uva, sp->snrm);
604 for (i = v2l->nv; i--; ) {
605 v2l->v[i].mX = DOT(sp->farg+3*i, ptp->uva[0]);
606 v2l->v[i].mY = DOT(sp->farg+3*i, ptp->uva[1]);
607 }
608 ptp->ntris = 0;
609 v2l->p = (void *)ptp;
610 if (!polyTriangulate(v2l, add_triangle)) {
611 fprintf(stderr,
612 "%s: cannot triangulate polygon '%s'\n",
613 progname, sp->sname);
614 return(0);
615 }
616 for (i = ptp->ntris; i--; ) {
617 int a = ptp->tri[i].vndx[0];
618 int b = ptp->tri[i].vndx[1];
619 int c = ptp->tri[i].vndx[2];
620 ptp->tri[i].afrac =
621 (v2l->v[a].mX*v2l->v[b].mY -
622 v2l->v[b].mX*v2l->v[a].mY +
623 v2l->v[b].mX*v2l->v[c].mY -
624 v2l->v[c].mX*v2l->v[b].mY +
625 v2l->v[c].mX*v2l->v[a].mY -
626 v2l->v[a].mX*v2l->v[c].mY) /
627 (2.*sp->area);
628 }
629 polyFree(v2l);
630 }
631 sp->priv = (void *)ptp;
632 }
633 /* pick triangle by partial area */
634 for (i = 0; i < ptp->ntris && x > ptp->tri[i].afrac; i++)
635 x -= ptp->tri[i].afrac;
636 SDmultiSamp(samp2, 2, x/ptp->tri[i].afrac);
637 samp2[0] *= samp2[1] = sqrt(samp2[1]);
638 samp2[1] = 1. - samp2[1];
639 v0 = sp->farg + 3*ptp->tri[i].vndx[0];
640 v1 = sp->farg + 3*ptp->tri[i].vndx[1];
641 v2 = sp->farg + 3*ptp->tri[i].vndx[2];
642 for (i = 3; i--; )
643 orig[i] = v0[i] + samp2[0]*(v1[i] - v0[i])
644 + samp2[1]*(v2[i] - v0[i]) ;
645 return(1);
646 memerr:
647 fputs(progname, stderr);
648 fputs(": out of memory in ssamp_poly!\n", stderr);
649 return(0);
650 }
651
652 /* Compute sample origin based on projected areas of sender subsurfaces */
653 static int
654 sample_origin(PARAMS *p, FVECT orig, const FVECT rdir, double x)
655 {
656 static double *projsa;
657 static int nall;
658 double tarea = 0;
659 int i;
660 SURF *sp;
661 /* special case for lone surface */
662 if (p->nsurfs == 1) {
663 sp = p->slist;
664 if (DOT(sp->snrm, rdir) >= -FTINY) {
665 fprintf(stderr,
666 "%s: internal - sample behind sender '%s'\n",
667 progname, sp->sname);
668 return(0);
669 }
670 return((*orig_in_surf[sp->styp])(orig, sp, x));
671 }
672 if (p->nsurfs > nall) { /* (re)allocate surface area cache */
673 if (projsa) free(projsa);
674 projsa = (double *)malloc(sizeof(double)*p->nsurfs);
675 if (!projsa) return(0);
676 nall = p->nsurfs;
677 }
678 /* compute projected areas */
679 for (i = 0, sp = p->slist; sp != NULL; i++, sp = sp->next) {
680 projsa[i] = -DOT(sp->snrm, rdir) * sp->area;
681 tarea += projsa[i] *= (double)(projsa[i] > FTINY);
682 }
683 if (tarea <= FTINY) { /* wrong side of sender? */
684 fputs(progname, stderr);
685 fputs(": internal - sample behind all sender elements!\n",
686 stderr);
687 return(0);
688 }
689 tarea *= x; /* get surface from list */
690 for (i = 0, sp = p->slist; tarea > projsa[i]; sp = sp->next)
691 tarea -= projsa[i++];
692 return((*orig_in_surf[sp->styp])(orig, sp, tarea/projsa[i]));
693 }
694
695 /* Uniform sample generator */
696 static int
697 sample_uniform(PARAMS *p, int b, FILE *fp)
698 {
699 int n = sampcnt;
700 double samp3[3];
701 double duvw[3];
702 FVECT orig_dir[2];
703 int i;
704
705 if (fp == NULL) /* just requesting number of bins? */
706 return(1);
707
708 while (n--) { /* stratified hemisphere sampling */
709 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
710 SDsquare2disk(duvw, samp3[1], samp3[2]);
711 duvw[2] = -sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
712 for (i = 3; i--; )
713 orig_dir[1][i] = duvw[0]*p->udir[i] +
714 duvw[1]*p->vdir[i] +
715 duvw[2]*p->nrm[i] ;
716 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
717 return(0);
718 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
719 return(0);
720 }
721 return(1);
722 }
723
724 /* Shirly-Chiu sample generator */
725 static int
726 sample_shirchiu(PARAMS *p, int b, FILE *fp)
727 {
728 int n = sampcnt;
729 double samp3[3];
730 double duvw[3];
731 FVECT orig_dir[2];
732 int i;
733
734 if (fp == NULL) /* just requesting number of bins? */
735 return(p->hsiz*p->hsiz);
736
737 while (n--) { /* stratified sampling */
738 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
739 SDsquare2disk(duvw, (b/p->hsiz + samp3[1])/curparams.hsiz,
740 (b%p->hsiz + samp3[2])/curparams.hsiz);
741 duvw[2] = sqrt(1. - duvw[0]*duvw[0] - duvw[1]*duvw[1]);
742 for (i = 3; i--; )
743 orig_dir[1][i] = -duvw[0]*p->udir[i] -
744 duvw[1]*p->vdir[i] -
745 duvw[2]*p->nrm[i] ;
746 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
747 return(0);
748 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
749 return(0);
750 }
751 return(1);
752 }
753
754 /* Reinhart/Tregenza sample generator */
755 static int
756 sample_reinhart(PARAMS *p, int b, FILE *fp)
757 {
758 #define T_NALT 7
759 static const int tnaz[T_NALT] = {30, 30, 24, 24, 18, 12, 6};
760 const int RowMax = T_NALT*p->hsiz + 1;
761 const double RAH = (.5*PI)/(RowMax-.5);
762 #define rnaz(r) (r >= RowMax-1 ? 1 : p->hsiz*tnaz[r/p->hsiz])
763 int n = sampcnt;
764 int row, col;
765 double samp3[3];
766 double alt, azi;
767 double duvw[3];
768 FVECT orig_dir[2];
769 int i;
770
771 if (fp == NULL) { /* just requesting number of bins? */
772 n = 0;
773 for (row = RowMax; row--; ) n += rnaz(row);
774 return(n);
775 }
776 row = 0; /* identify row & column */
777 col = b;
778 while (col >= rnaz(row)) {
779 col -= rnaz(row);
780 ++row;
781 }
782 while (n--) { /* stratified sampling */
783 SDmultiSamp(samp3, 3, (n+frandom())/sampcnt);
784 alt = (row+samp3[1])*RAH;
785 azi = (2.*PI)*(col+samp3[2]-.5)/rnaz(row);
786 duvw[2] = cos(alt); /* measured from horizon */
787 duvw[0] = tcos(azi)*duvw[2];
788 duvw[1] = tsin(azi)*duvw[2];
789 duvw[2] = sqrt(1. - duvw[2]*duvw[2]);
790 for (i = 3; i--; )
791 orig_dir[1][i] = -duvw[0]*p->udir[i] -
792 duvw[1]*p->vdir[i] -
793 duvw[2]*p->nrm[i] ;
794 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp3[0]))
795 return(0);
796 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
797 return(0);
798 }
799 return(1);
800 #undef rnaz
801 #undef T_NALT
802 }
803
804 /* Klems sample generator */
805 static int
806 sample_klems(PARAMS *p, int b, FILE *fp)
807 {
808 static const char bname[4][20] = {
809 "LBNL/Klems Full",
810 "LBNL/Klems Half",
811 "INTERNAL ERROR",
812 "LBNL/Klems Quarter"
813 };
814 static ANGLE_BASIS *kbasis[4];
815 const int bi = p->hemis[1] - '1';
816 int n = sampcnt;
817 double samp2[2];
818 double duvw[3];
819 FVECT orig_dir[2];
820 int i;
821
822 if (!kbasis[bi]) { /* need to get basis, first */
823 for (i = 4; i--; )
824 if (!strcasecmp(abase_list[i].name, bname[bi])) {
825 kbasis[bi] = &abase_list[i];
826 break;
827 }
828 if (i < 0) {
829 fprintf(stderr, "%s: unknown hemisphere basis '%s'\n",
830 progname, bname[bi]);
831 return(0);
832 }
833 }
834 if (fp == NULL) /* just requesting number of bins? */
835 return(kbasis[bi]->nangles);
836
837 while (n--) { /* stratified sampling */
838 SDmultiSamp(samp2, 2, (n+frandom())/sampcnt);
839 if (!bo_getvec(duvw, b+samp2[1], kbasis[bi]))
840 return(0);
841 for (i = 3; i--; )
842 orig_dir[1][i] = duvw[0]*p->udir[i] +
843 duvw[1]*p->vdir[i] +
844 duvw[2]*p->nrm[i] ;
845 if (!sample_origin(p, orig_dir[0], orig_dir[1], samp2[0]))
846 return(0);
847 if (fwrite(orig_dir, sizeof(FVECT), 2, fp) != 2)
848 return(0);
849 }
850 return(1);
851 }
852
853 /* Prepare hemisphere basis sampler that will send rays to rcontrib */
854 static int
855 prepare_sampler(void)
856 {
857 if (curparams.slist == NULL) { /* missing sample surface! */
858 fputs(progname, stderr);
859 fputs(": no sender surface!\n", stderr);
860 return(-1);
861 }
862 if (curparams.outfn != NULL) /* misplaced output file spec. */
863 fprintf(stderr, "%s: warning - ignoring output file in sender ('%s')\n",
864 progname, curparams.outfn);
865 /* check/set basis hemisphere */
866 if (!curparams.hemis[0]) {
867 fputs(progname, stderr);
868 fputs(": missing sender sampling type!\n", stderr);
869 return(-1);
870 }
871 if (normalize(curparams.nrm) == 0) {
872 fputs(progname, stderr);
873 fputs(": undefined normal for sender sampling\n", stderr);
874 return(-1);
875 }
876 if (normalize(curparams.vup) == 0) {
877 if (fabs(curparams.nrm[2]) < .7)
878 curparams.vup[2] = 1;
879 else
880 curparams.vup[1] = 1;
881 }
882 VCROSS(curparams.udir, curparams.vup, curparams.nrm);
883 if (normalize(curparams.udir) == 0) {
884 fputs(progname, stderr);
885 fputs(": up vector coincides with sender normal\n", stderr);
886 return(-1);
887 }
888 VCROSS(curparams.vdir, curparams.nrm, curparams.udir);
889 if (tolower(curparams.hemis[0]) == 'u' | curparams.hemis[0] == '1')
890 curparams.sample_basis = sample_uniform;
891 else if (tolower(curparams.hemis[0]) == 's' &&
892 tolower(curparams.hemis[1]) == 'c')
893 curparams.sample_basis = sample_shirchiu;
894 else if ((tolower(curparams.hemis[0]) == 'r') |
895 (tolower(curparams.hemis[0]) == 't'))
896 curparams.sample_basis = sample_reinhart;
897 else if (tolower(curparams.hemis[0]) == 'k') {
898 switch (curparams.hemis[1]) {
899 case '1':
900 case '2':
901 case '4':
902 break;
903 case 'f':
904 case 'F':
905 case '\0':
906 curparams.hemis[1] = '1';
907 break;
908 case 'h':
909 case 'H':
910 curparams.hemis[1] = '2';
911 break;
912 case 'q':
913 case 'Q':
914 curparams.hemis[1] = '4';
915 break;
916 default:
917 goto unrecognized;
918 }
919 curparams.hemis[2] = '\0';
920 curparams.sample_basis = sample_klems;
921 } else
922 goto unrecognized;
923 /* return number of bins */
924 return((*curparams.sample_basis)(&curparams,0,NULL));
925 unrecognized:
926 fprintf(stderr, "%s: unrecognized sender sampling: h=%s\n",
927 progname, curparams.hemis);
928 return(-1);
929 }
930
931 /* Compute normal and area for polygon */
932 static int
933 finish_polygon(SURF *p)
934 {
935 const int nv = p->nfargs / 3;
936 FVECT e1, e2, vc;
937 int i;
938
939 memset(p->snrm, 0, sizeof(FVECT));
940 VSUB(e1, p->farg+3, p->farg);
941 for (i = 2; i < nv; i++) {
942 VSUB(e2, p->farg+3*i, p->farg);
943 VCROSS(vc, e1, e2);
944 p->snrm[0] += vc[0];
945 p->snrm[1] += vc[1];
946 p->snrm[2] += vc[2];
947 VCOPY(e1, e2);
948 }
949 p->area = normalize(p->snrm)*0.5;
950 return(p->area > FTINY);
951 }
952
953 /* Add a surface to our current parameters */
954 static void
955 add_surface(int st, const char *oname, FILE *fp)
956 {
957 SURF *snew;
958 int n;
959 /* get floating-point arguments */
960 if (!fscanf(fp, "%d", &n)) return;
961 while (n-- > 0) fscanf(fp, "%*s");
962 if (!fscanf(fp, "%d", &n)) return;
963 while (n-- > 0) fscanf(fp, "%*d");
964 if (!fscanf(fp, "%d", &n) || n <= 0) return;
965 snew = (SURF *)malloc(sizeof(SURF) + sizeof(double)*(n-1));
966 if (snew == NULL) {
967 fputs(progname, stderr);
968 fputs(": out of memory!\n", stderr);
969 exit(1);
970 }
971 strncpy(snew->sname, oname, sizeof(snew->sname)-1);
972 snew->sname[sizeof(snew->sname)-1] = '\0';
973 snew->styp = st;
974 snew->priv = NULL;
975 snew->nfargs = n;
976 for (n = 0; n < snew->nfargs; n++)
977 if (fscanf(fp, "%lf", &snew->farg[n]) != 1) {
978 fprintf(stderr, "%s: error reading arguments for '%s'\n",
979 progname, oname);
980 exit(1);
981 }
982 switch (st) {
983 case ST_RING:
984 if (snew->nfargs != 8)
985 goto badcount;
986 VCOPY(snew->snrm, snew->farg+3);
987 if (normalize(snew->snrm) == 0)
988 goto badnorm;
989 if (snew->farg[7] < snew->farg[6]) {
990 double t = snew->farg[7];
991 snew->farg[7] = snew->farg[6];
992 snew->farg[6] = t;
993 }
994 snew->area = PI*(snew->farg[7]*snew->farg[7] -
995 snew->farg[6]*snew->farg[6]);
996 break;
997 case ST_POLY:
998 if (snew->nfargs < 9 || snew->nfargs % 3)
999 goto badcount;
1000 finish_polygon(snew);
1001 break;
1002 case ST_SOURCE:
1003 if (snew->nfargs != 4)
1004 goto badcount;
1005 for (n = 3; n--; ) /* need to reverse "normal" */
1006 snew->snrm[n] = -snew->farg[n];
1007 if (normalize(snew->snrm) == 0)
1008 goto badnorm;
1009 snew->area = sin((PI/180./2.)*snew->farg[3]);
1010 snew->area *= PI*snew->area;
1011 break;
1012 }
1013 if (snew->area <= FTINY) {
1014 fprintf(stderr, "%s: warning - zero area for surface '%s'\n",
1015 progname, oname);
1016 free(snew);
1017 return;
1018 }
1019 VSUM(curparams.nrm, curparams.nrm, snew->snrm, snew->area);
1020 snew->next = curparams.slist;
1021 curparams.slist = snew;
1022 curparams.nsurfs++;
1023 return;
1024 badcount:
1025 fprintf(stderr, "%s: bad argument count for surface element '%s'\n",
1026 progname, oname);
1027 exit(1);
1028 badnorm:
1029 fprintf(stderr, "%s: bad orientation for surface element '%s'\n",
1030 progname, oname);
1031 exit(1);
1032 }
1033
1034 /* Parse a receiver object (look for modifiers to add to rcontrib command) */
1035 static int
1036 add_recv_object(FILE *fp)
1037 {
1038 int st;
1039 char thismod[128], otype[32], oname[128];
1040 int n;
1041
1042 if (fscanf(fp, "%s %s %s", thismod, otype, oname) != 3)
1043 return(0); /* must have hit EOF! */
1044 if (!strcmp(otype, "alias")) {
1045 fscanf(fp, "%*s"); /* skip alias */
1046 return(0);
1047 }
1048 /* is it a new receiver? */
1049 if ((st = surf_type(otype)) != ST_NONE) {
1050 if (curparams.slist != NULL && (st == ST_SOURCE) ^
1051 (curparams.slist->styp == ST_SOURCE)) {
1052 fputs(progname, stderr);
1053 fputs(": cannot mix source/non-source receivers!\n", stderr);
1054 return(-1);
1055 }
1056 if (strcmp(thismod, curmod)) {
1057 if (curmod[0]) { /* output last receiver? */
1058 finish_receiver();
1059 clear_params(&curparams, 1);
1060 }
1061 parse_params(&curparams, newparams);
1062 newparams[0] = '\0';
1063 strcpy(curmod, thismod);
1064 }
1065 add_surface(st, oname, fp); /* read & store surface */
1066 return(1);
1067 }
1068 /* else skip arguments */
1069 if (!fscanf(fp, "%d", &n)) return(0);
1070 while (n-- > 0) fscanf(fp, "%*s");
1071 if (!fscanf(fp, "%d", &n)) return(0);
1072 while (n-- > 0) fscanf(fp, "%*d");
1073 if (!fscanf(fp, "%d", &n)) return(0);
1074 while (n-- > 0) fscanf(fp, "%*f");
1075 return(0);
1076 }
1077
1078 /* Parse a sender object */
1079 static int
1080 add_send_object(FILE *fp)
1081 {
1082 int st;
1083 char otype[32], oname[128];
1084 int n;
1085
1086 if (fscanf(fp, "%*s %s %s", otype, oname) != 2)
1087 return(0); /* must have hit EOF! */
1088 if (!strcmp(otype, "alias")) {
1089 fscanf(fp, "%*s"); /* skip alias */
1090 return(0);
1091 }
1092 /* is it a new surface? */
1093 if ((st = surf_type(otype)) != ST_NONE) {
1094 if (st == ST_SOURCE) {
1095 fputs(progname, stderr);
1096 fputs(": cannot use source as a sender!\n", stderr);
1097 return(-1);
1098 }
1099 parse_params(&curparams, newparams);
1100 newparams[0] = '\0';
1101 add_surface(st, oname, fp); /* read & store surface */
1102 return(0);
1103 }
1104 /* else skip arguments */
1105 if (!fscanf(fp, "%d", &n)) return(0);
1106 while (n-- > 0) fscanf(fp, "%*s");
1107 if (!fscanf(fp, "%d", &n)) return(0);
1108 while (n-- > 0) fscanf(fp, "%*d");
1109 if (!fscanf(fp, "%d", &n)) return(0);
1110 while (n-- > 0) fscanf(fp, "%*f");
1111 return(0);
1112 }
1113
1114 /* Load a Radiance scene using the given callback function for objects */
1115 static int
1116 load_scene(const char *inspec, int (*ocb)(FILE *))
1117 {
1118 int rv = 0;
1119 char inpbuf[1024];
1120 FILE *fp;
1121 int c;
1122
1123 if (*inspec == '!')
1124 fp = popen(inspec+1, "r");
1125 else
1126 fp = fopen(inspec, "r");
1127 if (fp == NULL) {
1128 fprintf(stderr, "%s: cannot load '%s'\n", progname, inspec);
1129 return(-1);
1130 }
1131 while ((c = getc(fp)) != EOF) { /* load receiver data */
1132 if (isspace(c)) /* skip leading white space */
1133 continue;
1134 if (c == '!') { /* read from a new command */
1135 inpbuf[0] = c;
1136 if (fgetline(inpbuf+1, sizeof(inpbuf)-1, fp) != NULL) {
1137 if ((c = load_scene(inpbuf, ocb)) < 0)
1138 return(c);
1139 rv += c;
1140 }
1141 continue;
1142 }
1143 if (c == '#') { /* parameters/comment */
1144 if ((c = getc(fp)) == EOF || ungetc(c,fp) == EOF)
1145 break;
1146 if (!isspace(c) && fscanf(fp, "%s", inpbuf) == 1 &&
1147 !strcmp(inpbuf, PARAMSTART)) {
1148 if (fgets(inpbuf, sizeof(inpbuf), fp) != NULL)
1149 strcat(newparams, inpbuf);
1150 continue;
1151 }
1152 while ((c = getc(fp)) != EOF && c != '\n')
1153 ; /* else skipping comment */
1154 continue;
1155 }
1156 ungetc(c, fp); /* else check object for receiver */
1157 c = (*ocb)(fp);
1158 if (c < 0)
1159 return(c);
1160 rv += c;
1161 }
1162 /* close our input stream */
1163 c = (*inspec == '!') ? pclose(fp) : fclose(fp);
1164 if (c != 0) {
1165 fprintf(stderr, "%s: error loading '%s'\n", progname, inspec);
1166 return(-1);
1167 }
1168 return(rv);
1169 }
1170
1171 /* Get command arguments and run program */
1172 int
1173 main(int argc, char *argv[])
1174 {
1175 char fmtopt[6] = "-faa"; /* default output is ASCII */
1176 char *xrs=NULL, *yrs=NULL, *ldopt=NULL;
1177 int wantIrradiance = 0;
1178 char *sendfn;
1179 char sampcntbuf[32], nsbinbuf[32];
1180 FILE *rcfp;
1181 int nsbins;
1182 int a, i;
1183 /* screen rcontrib options */
1184 progname = argv[0];
1185 for (a = 1; a < argc-2 && argv[a][0] == '-'; a++) {
1186 int na = 1; /* !! Keep consistent !! */
1187 switch (argv[a][1]) {
1188 case 'v': /* verbose mode */
1189 verbose = !verbose;
1190 na = 0;
1191 continue;
1192 case 'f': /* special case for -fo, -ff, etc. */
1193 switch (argv[a][2]) {
1194 case '\0': /* cal file */
1195 goto userr;
1196 case 'o': /* force output */
1197 goto userr;
1198 case 'a': /* output format */
1199 case 'f':
1200 case 'd':
1201 case 'c':
1202 if (!(fmtopt[3] = argv[a][3]))
1203 fmtopt[3] = argv[a][2];
1204 fmtopt[2] = argv[a][2];
1205 na = 0;
1206 continue; /* will pass later */
1207 default:
1208 goto userr;
1209 }
1210 break;
1211 case 'x': /* x-resolution */
1212 xrs = argv[++a];
1213 na = 0;
1214 continue;
1215 case 'y': /* y-resolution */
1216 yrs = argv[++a];
1217 na = 0;
1218 continue;
1219 case 'c': /* number of samples */
1220 sampcnt = atoi(argv[++a]);
1221 if (sampcnt <= 0)
1222 goto userr;
1223 na = 0; /* we re-add this later */
1224 continue;
1225 case 'I': /* only for pass-through mode */
1226 wantIrradiance = 1;
1227 na = 0;
1228 continue;
1229 case 'V': /* options without arguments */
1230 case 'w':
1231 case 'u':
1232 case 'i':
1233 case 'h':
1234 case 'r':
1235 break;
1236 case 'n': /* options with 1 argument */
1237 case 's':
1238 case 'o':
1239 na = 2;
1240 break;
1241 case 'b': /* special case */
1242 if (argv[a][2] != 'v') goto userr;
1243 break;
1244 case 'l': /* special case */
1245 if (argv[a][2] == 'd') {
1246 ldopt = argv[a];
1247 na = 0;
1248 continue;
1249 }
1250 na = 2;
1251 break;
1252 case 'd': /* special case */
1253 if (argv[a][2] != 'v') na = 2;
1254 break;
1255 case 'a': /* special case */
1256 na = (argv[a][2] == 'v') ? 4 : 2;
1257 break;
1258 case 'm': /* special case */
1259 if (!argv[a][2]) goto userr;
1260 na = (argv[a][2] == 'e') | (argv[a][2] == 'a') ? 4 : 2;
1261 break;
1262 case '\0': /* pass-through mode */
1263 goto done_opts;
1264 default: /* anything else is verbotten */
1265 goto userr;
1266 }
1267 if (na <= 0) continue;
1268 CHECKARGC(na); /* pass on option */
1269 rcarg[nrcargs++] = argv[a];
1270 while (--na) /* + arguments if any */
1271 rcarg[nrcargs++] = argv[++a];
1272 }
1273 done_opts:
1274 if (a > argc-2)
1275 goto userr; /* check at end of options */
1276 sendfn = argv[a++]; /* assign sender & receiver inputs */
1277 if (sendfn[0] == '-') { /* user wants pass-through mode? */
1278 if (sendfn[1]) goto userr;
1279 sendfn = NULL;
1280 if (wantIrradiance) {
1281 CHECKARGC(1);
1282 rcarg[nrcargs++] = "-I";
1283 }
1284 if (xrs) {
1285 CHECKARGC(2);
1286 rcarg[nrcargs++] = "-x";
1287 rcarg[nrcargs++] = xrs;
1288 }
1289 if (yrs) {
1290 CHECKARGC(2);
1291 rcarg[nrcargs++] = "-y";
1292 rcarg[nrcargs++] = yrs;
1293 }
1294 if (ldopt) {
1295 CHECKARGC(1);
1296 rcarg[nrcargs++] = ldopt;
1297 }
1298 if (sampcnt <= 0) sampcnt = 1;
1299 } else { /* else in sampling mode */
1300 if (wantIrradiance) {
1301 fputs(progname, stderr);
1302 fputs(": -I supported for pass-through only\n", stderr);
1303 return(1);
1304 }
1305 fmtopt[2] = (sizeof(RREAL)==sizeof(double)) ? 'd' : 'f';
1306 if (sampcnt <= 0) sampcnt = 10000;
1307 }
1308 sprintf(sampcntbuf, "%d", sampcnt);
1309 CHECKARGC(3); /* add our format & sample count */
1310 rcarg[nrcargs++] = fmtopt;
1311 rcarg[nrcargs++] = "-c";
1312 rcarg[nrcargs++] = sampcntbuf;
1313 /* add receiver arguments to rcontrib */
1314 if (load_scene(argv[a], add_recv_object) < 0)
1315 return(1);
1316 finish_receiver();
1317 if (sendfn == NULL) { /* pass-through mode? */
1318 CHECKARGC(1); /* add octree */
1319 rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1320 rcarg[nrcargs] = NULL;
1321 return(my_exec(rcarg)); /* rcontrib does everything */
1322 }
1323 clear_params(&curparams, 0); /* else load sender surface & params */
1324 if (load_scene(sendfn, add_send_object) < 0)
1325 return(1);
1326 if ((nsbins = prepare_sampler()) <= 0)
1327 return(1);
1328 CHECKARGC(3); /* add row count and octree */
1329 rcarg[nrcargs++] = "-y";
1330 sprintf(nsbinbuf, "%d", nsbins);
1331 rcarg[nrcargs++] = nsbinbuf;
1332 rcarg[nrcargs++] = oconv_command(argc-a, argv+a);
1333 rcarg[nrcargs] = NULL;
1334 /* open pipe to rcontrib process */
1335 if ((rcfp = popen_arglist(rcarg, "w")) == NULL)
1336 return(1);
1337 SET_FILE_BINARY(rcfp);
1338 #ifdef getc_unlocked
1339 flockfile(rcfp);
1340 #endif
1341 if (verbose) {
1342 fprintf(stderr, "%s: sampling %d directions", progname, nsbins);
1343 if (curparams.nsurfs > 1)
1344 fprintf(stderr, " (%d elements)\n", curparams.nsurfs);
1345 else
1346 fputc('\n', stderr);
1347 }
1348 for (i = 0; i < nsbins; i++) /* send rcontrib ray samples */
1349 if (!(*curparams.sample_basis)(&curparams, i, rcfp))
1350 return(1);
1351 return(pclose(rcfp) == 0); /* all finished! */
1352 userr:
1353 if (a < argc-2)
1354 fprintf(stderr, "%s: unsupported option '%s'", progname, argv[a]);
1355 fprintf(stderr, "Usage: %s [-v][rcontrib options] sender.rad receiver.rad [system.rad ..]\n",
1356 progname);
1357 return(1);
1358 }
