root/radiance/ray/src/util/reinhartb.cal
Fri Mar 27 18:58:06 2015 UTC (10 years, 2 months ago) by greg
CVS Tags: HEAD, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Tue Aug 26 18:56:19 2014 UTC (10 years, 9 months ago) by greg
CVS Tags: rad4R2P1, rad4R2P2
Fixed vector sampling directions for Klems senders and Reinhart sky receivers
Wed Aug 20 06:32:07 2014 UTC (10 years, 9 months ago) by greg
Removed double-conversion from degrees
Fri Jul 25 16:58:20 2014 UTC (10 years, 10 months ago) by greg
CVS Tags: rad4R2
Changes since 2.2: +6 -6 lines
Fixed bug in setting of receiver normal for sources
Tue Jul 22 23:21:56 2014 UTC (10 years, 10 months ago) by greg
Changes since 2.1: +4 -4 lines
Diff to previous 2.1
Fixed some bugs... more to go
Tue Jul 22 02:12:48 2014 UTC (10 years, 10 months ago) by greg
Added Reinhart sky cal file
