root/radiance/ray/src/util/rcrop.c
Tue Nov 21 02:06:14 2023 UTC (5 months, 3 weeks ago) by greg
Changes since 1.13: +7 -4 lines
Diff to previous 1.13 , to selected 1.4
feat(rcrop): Added spectral picture support
Thu Apr 7 16:58:30 2022 UTC (2 years, 1 month ago) by greg
Changes since 1.12: +13 -1 lines
Diff to previous 1.12 , to selected 1.4
perf(rcrop): Improved i/o performance for binary data under Unix with pread(2)
Mon Mar 21 20:19:19 2022 UTC (2 years, 1 month ago) by greg
Changes since 1.11: +5 -3 lines
Diff to previous 1.11 , to selected 1.4
fix(rcrop): Minor - added missing check for write errors
Wed Mar 16 16:48:39 2022 UTC (2 years, 2 months ago) by greg
Changes since 1.10: +10 -11 lines
Diff to previous 1.10 , to selected 1.4
refactor(rcrop): Other minor code clean-ups
Wed Mar 16 15:50:24 2022 UTC (2 years, 2 months ago) by greg
Changes since 1.9: +46 -38 lines
Diff to previous 1.9 , to selected 1.4
refactor(rcrop): Minor code rearrangements and improvements
Wed Mar 16 01:51:16 2022 UTC (2 years, 2 months ago) by greg
Changes since 1.8: +6 -6 lines
Diff to previous 1.8 , to selected 1.4
fix(rcrop): Bug in view cropping with rotated pictures
Tue Mar 15 20:54:49 2022 UTC (2 years, 2 months ago) by greg
Diff to previous 1.7 , to selected 1.4
feat(rcrop): Changed to assuming ASCII input if unspecified format, same as rmtxop
Tue Mar 15 20:21:18 2022 UTC (2 years, 2 months ago) by greg
Changes since 1.6: +5 -1 lines
Diff to previous 1.6 , to selected 1.4
perf(rcrop): added flockfile() call to avoid semaphores in fread() and fwrite()
Tue Mar 15 15:01:22 2022 UTC (2 years, 2 months ago) by greg
Changes since 1.5: +6 -1 lines
Diff to previous 1.5 , to selected 1.4
fix(rcrop): Eliminated "broken pipe" error when reading from command
Tue Mar 15 04:41:45 2022 UTC (2 years, 2 months ago) by greg
Changes since 1.4: +7 -1 lines
Diff to previous 1.4
feat(rcrop): Added support for cropping encoded depth and normal files
Revision 1.4 - (view) (download) (annotate) - [selected]
Tue Mar 15 02:28:05 2022 UTC (2 years, 2 months ago) by greg
Changes since 1.3: +9 -7 lines
Diff to previous 1.3
feat(rcrop): Made view error non-fatal and improved NCOMP check for pictures
Tue Mar 15 01:44:27 2022 UTC (2 years, 2 months ago) by greg
Diff to previous 1.2 , to selected 1.4
perf(rcrop): Increased seek threshold to something closer to expected page size
Tue Mar 15 01:40:17 2022 UTC (2 years, 2 months ago) by greg
Changes since 1.1: +33 -10 lines
Diff to previous 1.1 , to selected 1.4
perf(rcrop): Made binary file transfer more efficient
Tue Mar 15 00:25:50 2022 UTC (2 years, 2 months ago) by greg
Diff to selected 1.4
feat(rcrop): Created simple cropping utility for matrices and pictures
