feat(rcrop): Negative counts for #rows or #columns cut from the ends
fix: Made use of resolu.h more consistent and reliable
feat(rcrop): Added spectral picture support
perf(rcrop): Improved i/o performance for binary data under Unix with pread(2)
fix(rcrop): Minor - added missing check for write errors
refactor(rcrop): Other minor code clean-ups
refactor(rcrop): Minor code rearrangements and improvements
fix(rcrop): Bug in view cropping with rotated pictures
feat(rcrop): Changed to assuming ASCII input if unspecified format, same as rmtxop
perf(rcrop): added flockfile() call to avoid semaphores in fread() and fwrite()
fix(rcrop): Eliminated "broken pipe" error when reading from command
feat(rcrop): Added support for cropping encoded depth and normal files
feat(rcrop): Made view error non-fatal and improved NCOMP check for pictures
perf(rcrop): Increased seek threshold to something closer to expected page size
perf(rcrop): Made binary file transfer more efficient
feat(rcrop): Created simple cropping utility for matrices and pictures
