root/radiance/ray/src/util/rcomb.c
Sat Mar 1 01:37:49 2025 UTC (3 weeks, 5 days ago) by greg
Diff to previous 2.26
refactor: Simplified some error messages
Fri Nov 8 17:52:26 2024 UTC (4 months, 2 weeks ago) by greg
Diff to previous 2.25
fix(rcomb,rmtxop): Fix to matrix deallocation
Wed Aug 21 01:09:25 2024 UTC (7 months ago) by greg
Diff to previous 2.24
fix(rcomb,rmtxop): Fixing compile error with const array type
Mon Jun 10 18:20:06 2024 UTC (9 months, 2 weeks ago) by greg
Changes since 2.23: +6 -4 lines
Diff to previous 2.23
fix(rcomb): pay better attention to -w option
Fri Jun 7 03:55:59 2024 UTC (9 months, 2 weeks ago) by greg
Changes since 2.22: +56 -55 lines
Diff to previous 2.22
fix(rcomb: Cleaned up logic and error reporting and fixed bug caused by subtle fclose(3) behavior that moved underlying file pointer shared with parent
Tue Jun 4 22:05:23 2024 UTC (9 months, 3 weeks ago) by greg
Changes since 2.21: +68 -65 lines
Diff to previous 2.21
refactor(rcomb): Minor changes should not affect performance
Tue Jun 4 21:47:55 2024 UTC (9 months, 3 weeks ago) by greg
Changes since 2.20: +5 -3 lines
Diff to previous 2.20
perf: minor optimization to avoid unnecessary system calls
Tue Jun 4 21:23:11 2024 UTC (9 months, 3 weeks ago) by greg
Changes since 2.19: +91 -64 lines
Diff to previous 2.19
fix(rcomb): Added child process to sequence output; seems to finally work
Mon Jun 3 18:55:51 2024 UTC (9 months, 3 weeks ago) by greg
Changes since 2.18: +57 -58 lines
Diff to previous 2.18
refactor: Changed buffer types in process(), readbuf(), writebuf()
Thu May 23 19:29:41 2024 UTC (10 months ago) by greg
Changes since 2.17: +18 -6 lines
Diff to previous 2.17
fix(rcomb): Avoid inappropriate byte-swapping and improved final fclose() wait
Thu May 23 17:13:52 2024 UTC (10 months ago) by greg
Changes since 2.16: +8 -7 lines
Diff to previous 2.16
fix(rcomb): Error in record size calc and cleanup of child processes on failure
Thu May 23 15:48:44 2024 UTC (10 months ago) by greg
Changes since 2.15: +17 -27 lines
Diff to previous 2.15
fix(rcomb): Reverted to original synchronization method as signals proved unreliable for multi-processing
Thu May 23 01:28:07 2024 UTC (10 months ago) by greg
Diff to previous 2.14
fix(rcomb): Fixed confusion over #components with symbolic -c in final xform
Wed May 22 15:38:04 2024 UTC (10 months ago) by greg
Changes since 2.13: +4 -5 lines
Diff to previous 2.13
perf(rcomb): Minor optimization of signal blocking during child input
Wed May 22 00:39:30 2024 UTC (10 months ago) by greg
Changes since 2.12: +16 -8 lines
Diff to previous 2.12
fix(rcomb): added sigprocmask() calls to avoid child synchronization issue
Tue May 21 17:39:17 2024 UTC (10 months ago) by greg
Changes since 2.11: +22 -8 lines
fix(rcomb): Switched to group-signaling to make multi-processing more reliable
Tue May 21 16:27:26 2024 UTC (10 months ago) by greg
Changes since 2.10: +10 -8 lines
perf(rcomb): Minor performance improvements for multi-processing mode
Mon May 20 23:21:29 2024 UTC (10 months ago) by greg
Changes since 2.9: +166 -44 lines
Sun May 19 15:32:24 2024 UTC (10 months, 1 week ago) by greg
feat: Added facility for app-managed matrix memory
Thu May 16 18:59:19 2024 UTC (10 months, 1 week ago) by greg
fix: Made use of resolu.h more consistent and reliable
Fri Feb 23 03:47:57 2024 UTC (13 months ago) by greg
Fri Feb 9 19:58:56 2024 UTC (13 months, 2 weeks ago) by greg
Changes since 2.5: +6 -4 lines
fix(rcomb): Fixed issue with final operations (reallocation error)
Tue Dec 19 20:38:38 2023 UTC (15 months, 1 week ago) by greg
fix(rcomb): Restored error message if no rows read from input
Tue Dec 19 16:09:20 2023 UTC (15 months, 1 week ago) by greg
fix(rmtxop,rcomb): Added checks for "xyz" and "rgb" format output
Tue Dec 19 00:39:03 2023 UTC (15 months, 1 week ago) by greg
Changes since 2.2: +26 -9 lines
feat(rmtxop,rcomb): Added lower-case versions of component outputs w/o efficacy conversions
Mon Dec 18 23:04:05 2023 UTC (15 months, 1 week ago) by greg
Changes since 2.1: +13 -8 lines
fix(rcomb): Fixed handling of matrix inputs where NROWS is unspecified
Tue Dec 12 16:31:45 2023 UTC (15 months, 2 weeks ago) by greg
