root/radiance/ray/src/util/rcomb.c
Revision: 2.9
Committed: Sun May 19 15:32:24 2024 UTC (13 months ago) by greg
feat: Added facility for app-managed matrix memory
2 static const char RCSid[] = "$Id: rcomb.c,v 2.8 2024/05/16 18:59:19 greg Exp $";
5 * General component matrix combiner, operating on a row at a time.
6 */
7
8 #include <errno.h>
9 #include <math.h>
10 #include "platform.h"
11 #include "rtio.h"
12 #include "rmatrix.h"
13 #include "calcomp.h"
14 #include "paths.h"
15
16 #ifndef M_PI
17 #define M_PI 3.14159265358979323846
18 #endif
19
20 #define MAXCOMP MAXCSAMP /* #components we support */
21
22 /* Unary matrix operation(s) */
23 typedef struct {
24 double cmat[MAXCOMP*MAXCOMP]; /* component transformation */
25 double sca[MAXCOMP]; /* scalar coefficients */
26 const char *csym; /* symbolic coefficients */
27 short clen; /* number of coefficients */
28 short nsf; /* number of scalars */
29 } RUNARYOP;
30
31 /* Input matrix */
32 typedef struct {
33 const char *inspec; /* input specification */
34 RUNARYOP preop; /* transform operation */
35 RMATRIX imx; /* input matrix header info */
36 RMATRIX *rmp; /* active single-row matrix */
37 FILE *infp; /* open input stream */
38 } ROPMAT;
39
40 ROPMAT *mop = NULL; /* allocated input array */
41 int nall = 0; /* number allocated */
42 int nmats = 0; /* number of actual inputs */
43
44 RMATRIX *mcat = NULL; /* final concatenation */
45 int mcat_last = 0; /* goes after trailing ops? */
46
47 int in_nrows; /* number of input rows (or 0) */
48 #define in_ncols (mop[0].rmp->ncols) /* number of input columns */
49 #define in_ncomp (mop[0].rmp->ncomp) /* input #components */
50
51 extern int nowarn; /* turn off warnings? */
52
53 int cur_row; /* current input/output row */
54 int cur_col; /* current input/output column */
55 int cur_chan; /* if we're looping channels */
56
57 static int checksymbolic(ROPMAT *rop);
58
59 static int
60 split_input(ROPMAT *rop)
61 {
62 if (rop->rmp == &rop->imx && !(rop->rmp = rmx_copy(&rop->imx))) {
63 fputs("Out of memory in split_input()\n", stderr);
64 return(0);
65 }
66 rmx_reset(rop->rmp);
67 return(1);
68 }
69
70 /* Check/set transform based on a reference input file */
71 static int
72 checkreffile(ROPMAT *rop)
73 {
74 static const char *curRF = NULL;
75 static RMATRIX refm;
76 const int nc = rop->imx.ncomp;
77 int i;
78
79 if (!curRF || strcmp(rop->preop.csym, curRF)) {
80 FILE *fp = fopen(rop->preop.csym, "rb");
81 if (!rmx_load_header(&refm, fp)) {
82 fprintf(stderr, "%s: cannot read info header\n",
83 rop->preop.csym);
84 curRF = NULL;
85 if (fp) fclose(fp);
86 return(0);
87 }
88 fclose(fp);
89 curRF = rop->preop.csym;
90 }
91 if (refm.ncomp == 3) {
92 rop->preop.csym = (refm.dtype == DTxyze) ? "XYZ" : "RGB";
93 return(checksymbolic(rop));
94 }
95 if (refm.ncomp == 2) {
96 fprintf(stderr, "%s: cannot convert to 2 components\n",
97 curRF);
98 return(0);
99 }
100 if (refm.ncomp == 1) {
101 rop->preop.csym = "Y"; /* XXX big assumption */
102 return(checksymbolic(rop));
103 }
104 if (refm.ncomp == nc &&
105 !memcmp(refm.wlpart, rop->imx.wlpart, sizeof(refm.wlpart)))
106 return(1); /* nothing to do */
107
108 if ((nc <= 3) | (nc > MAXCSAMP) | (refm.ncomp > MAXCSAMP)) {
109 fprintf(stderr, "%s: cannot resample from %d to %d components\n",
110 curRF, nc, refm.ncomp);
111 return(0);
112 }
113 if (!split_input(rop)) /* get our own struct */
114 return(0);
115 rop->preop.clen = refm.ncomp * nc; /* compute spec to ref */
116
117 for (i = 0; i < nc; i++) {
118 SCOLOR scstim, scresp;
119 int j;
120 memset(scstim, 0, sizeof(COLORV)*nc);
121 scstim[i] = 1.f;
122 convertscolor(scresp, refm.ncomp, refm.wlpart[0], refm.wlpart[3],
123 scstim, nc, rop->imx.wlpart[0], rop->imx.wlpart[3]);
124 for (j = refm.ncomp; j-- > 0; )
125 rop->preop.cmat[j*nc + i] = scresp[j];
126 }
127 /* remember new spectral params */
128 memcpy(rop->rmp->wlpart, refm.wlpart, sizeof(rop->rmp->wlpart));
129 rop->rmp->ncomp = refm.ncomp;
130 return(1);
131 }
132
133 /* Compute conversion row from spectrum to one channel of RGB */
134 static void
135 rgbrow(ROPMAT *rop, int r, int p)
136 {
137 const int nc = rop->imx.ncomp;
138 const float * wlp = rop->imx.wlpart;
139 int i;
140
141 for (i = nc; i--; ) {
142 int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc;
143 int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc;
144 COLOR crgb;
145 spec_rgb(crgb, nmStart, nmEnd);
146 rop->preop.cmat[r*nc+i] = crgb[p];
147 }
148 }
149
150 /* Compute conversion row from spectrum to one channel of XYZ */
151 static void
152 xyzrow(ROPMAT *rop, int r, int p)
153 {
154 const int nc = rop->imx.ncomp;
155 const float * wlp = rop->imx.wlpart;
156 int i;
157
158 for (i = nc; i--; ) {
159 int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc;
160 int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc;
161 COLOR cxyz;
162 spec_cie(cxyz, nmStart, nmEnd);
163 rop->preop.cmat[r*nc+i] = cxyz[p];
164 }
165 }
166
167 /* Use the spectral sensitivity function to compute matrix coefficients */
168 static void
169 sensrow(ROPMAT *rop, int r, double (*sf)(SCOLOR sc, int ncs, const float wlpt[4]))
170 {
171 const int nc = rop->imx.ncomp;
172 int i;
173
174 for (i = nc; i--; ) {
175 SCOLOR sclr;
176 memset(sclr, 0, sizeof(COLORV)*nc);
177 sclr[i] = 1.f;
178 rop->preop.cmat[r*nc+i] = (*sf)(sclr, nc, rop->imx.wlpart);
179 }
180 }
181
182 /* Check/set symbolic transform */
183 static int
184 checksymbolic(ROPMAT *rop)
185 {
186 const int nc = rop->imx.ncomp;
187 const int dt = rop->imx.dtype;
188 double cf = 1;
189 int i, j;
190 /* check suffix => reference file */
191 if (strchr(rop->preop.csym, '.') > rop->preop.csym)
192 return(checkreffile(rop));
193
194 if (nc < 3) {
195 fprintf(stderr, "%s: -c '%s' requires at least 3 components\n",
196 rop->inspec, rop->preop.csym);
197 return(0);
198 }
199 rop->preop.clen = strlen(rop->preop.csym) * nc;
200 if (rop->preop.clen > MAXCOMP*MAXCOMP) {
201 fprintf(stderr, "%s: -c '%s' results in too many components\n",
202 rop->inspec, rop->preop.csym);
203 return(0);
204 }
205 for (j = 0; rop->preop.csym[j]; j++) {
206 int comp = 0;
207 switch (rop->preop.csym[j]) {
208 case 'B':
209 case 'b':
210 ++comp;
211 /* fall through */
212 case 'G':
213 case 'g':
214 ++comp;
215 /* fall through */
216 case 'R':
217 case 'r':
218 if (rop->preop.csym[j] <= 'Z')
219 cf = 1./WHTEFFICACY;
220 if (dt == DTxyze) {
221 for (i = 3; i--; )
222 rop->preop.cmat[j*nc+i] = cf*xyz2rgbmat[comp][i];
223 } else if (nc == 3)
224 rop->preop.cmat[j*nc+comp] = 1.;
225 else
226 rgbrow(rop, j, comp);
227 break;
228 case 'Z':
229 case 'z':
230 ++comp;
231 /* fall through */
232 case 'Y':
233 case 'y':
234 ++comp;
235 /* fall through */
236 case 'X':
237 case 'x':
238 if ((rop->preop.csym[j] <= 'Z') & (dt != DTxyze))
239 cf = WHTEFFICACY;
240 if (dt == DTxyze) {
241 rop->preop.cmat[j*nc+comp] = 1.;
242 } else if (nc == 3) {
243 for (i = 3; i--; )
244 rop->preop.cmat[j*nc+i] =
245 rgb2xyzmat[comp][i];
246 } else if (comp == CIEY)
247 sensrow(rop, j, scolor2photopic);
248 else
249 xyzrow(rop, j, comp);
250
251 for (i = nc*(cf != 1); i--; )
252 rop->preop.cmat[j*nc+i] *= cf;
253 break;
254 case 'S': /* scotopic (il)luminance */
255 cf = WHTSCOTOPIC;
256 /* fall through */
257 case 's':
258 sensrow(rop, j, scolor2scotopic);
259 for (i = nc*(cf != 1); i--; )
260 rop->preop.cmat[j*nc+i] *= cf;
261 break;
262 case 'M': /* melanopic (il)luminance */
263 cf = WHTMELANOPIC;
264 /* fall through */
265 case 'm':
266 sensrow(rop, j, scolor2melanopic);
267 for (i = nc*(cf != 1); i--; )
268 rop->preop.cmat[j*nc+i] *= cf;
269 break;
270 case 'A': /* average component */
271 case 'a':
272 for (i = nc; i--; )
273 rop->preop.cmat[j*nc+i] = 1./(double)nc;
274 break;
275 default:
276 fprintf(stderr, "%s: -c '%c' unsupported\n",
277 rop->inspec, rop->preop.csym[j]);
278 return(0);
279 }
280 }
281 if (!split_input(rop)) /* get our own struct */
282 return(0);
283 memcpy(rop->rmp->wlpart, WLPART, sizeof(rop->rmp->wlpart));
284 rop->rmp->ncomp = rop->preop.clen / nc;
285 /* decide on output type */
286 if (!strcasecmp(rop->preop.csym, "XYZ")) {
287 if (dt <= DTspec)
288 rop->rmp->dtype = DTxyze;
289 } else if (!strcasecmp(rop->preop.csym, "RGB")) {
290 if (dt <= DTspec)
291 rop->rmp->dtype = DTrgbe;
292 } else if (rop->rmp->dtype == DTspec)
293 rop->rmp->dtype = DTfloat;
294 return(1);
295 }
296
297 static int
298 get_component_xfm(ROPMAT *rop)
299 {
300 int i, j;
301
302 if (rop->rmp != &rop->imx) { /* reset destination matrix */
303 rmx_free(rop->rmp);
304 rop->rmp = &rop->imx;
305 }
306 if (rop->preop.csym && /* symbolic transform? */
307 !checksymbolic(rop))
308 return(0);
309 /* undo exposure? */
310 if (fabs(1. - bright(rop->rmp->cexp)) > .025) {
311 if (rop->rmp->ncomp == 1)
312 rop->rmp->cexp[RED] = rop->rmp->cexp[GRN] =
313 rop->rmp->cexp[BLU] = bright(rop->rmp->cexp);
314 if (rop->preop.nsf <= 0) {
315 rop->preop.nsf = i = rop->rmp->ncomp;
316 while (i--)
317 rop->preop.sca[i] = 1.;
318 }
319 if (rop->preop.nsf == 1) {
320 if (rop->rmp->ncomp == 3) {
321 rop->preop.sca[2] = rop->preop.sca[1] =
322 rop->preop.sca[0];
323 rop->preop.nsf = 3;
324 } else
325 rop->preop.sca[0] /= bright(rop->rmp->cexp);
326 }
327 if (rop->preop.nsf == 3) {
328 opcolor(rop->preop.sca, /=, rop->rmp->cexp);
329 } else if (rop->preop.nsf > 3) { /* punt */
330 double mult = 1./bright(rop->rmp->cexp);
331 for (i = rop->preop.nsf; i--; )
332 rop->preop.sca[i] *= mult;
333 }
334 setcolor(rop->rmp->cexp, 1., 1., 1.);
335 }
336 if (rop->preop.clen > 0) { /* use component transform? */
337 if (rop->preop.clen % rop->imx.ncomp) {
338 fprintf(stderr, "%s: -c must have N x %d coefficients\n",
339 rop->inspec, rop->imx.ncomp);
340 return(0);
341 }
342 if (rop->preop.nsf > 0) { /* scale transform, instead */
343 if (rop->preop.nsf == 1) {
344 for (i = rop->preop.clen; i--; )
345 rop->preop.cmat[i] *= rop->preop.sca[0];
346 } else if (rop->preop.nsf*rop->imx.ncomp != rop->preop.clen) {
347 fprintf(stderr, "%s: -s must have one or %d factors\n",
348 rop->inspec,
349 rop->preop.clen/rop->imx.ncomp);
350 return(0);
351 } else {
352 for (i = rop->preop.nsf; i--; )
353 for (j = rop->imx.ncomp; j--; )
354 rop->preop.cmat[i*rop->imx.ncomp+j]
355 *= rop->preop.sca[i];
356 }
357 }
358 rop->preop.nsf = 0; /* now folded in */
359 if (!split_input(rop)) /* get our own struct */
360 return(0);
361 rop->rmp->ncomp = rop->preop.clen / rop->imx.ncomp;
362 if ((rop->rmp->ncomp > 3) & (rop->rmp->dtype <= DTspec)) {
363 rop->rmp->dtype = DTfloat; /* probably not actual spectrum */
364 memcpy(rop->rmp->wlpart, WLPART, sizeof(rop->rmp->wlpart));
365 }
366 } else if (rop->preop.nsf > 0) { /* else use scalar(s)? */
367 if (rop->preop.nsf == 1) {
368 for (i = rop->rmp->ncomp; --i; )
369 rop->preop.sca[i] = rop->preop.sca[0];
370 rop->preop.nsf = rop->rmp->ncomp;
371 } else if (rop->preop.nsf != rop->rmp->ncomp) {
372 fprintf(stderr, "%s: -s must have one or %d factors\n",
373 rop->inspec, rop->rmp->ncomp);
374 return(0);
375 }
376 }
377 return(1);
378 }
379
380 static int
381 apply_op(RMATRIX *dst, const RMATRIX *src, const RUNARYOP *ro)
382 {
383 if (ro->clen > 0) {
384 RMATRIX *res = rmx_transform(src, dst->ncomp, ro->cmat);
385 if (!res) {
386 fputs("Error in call to rmx_transform()\n", stderr);
387 return(0);
388 }
389 if (!rmx_transfer_data(dst, res, 0))
390 return(0);
391 rmx_free(res);
392 } else if (dst != src)
393 memcpy(dst->mtx, src->mtx, rmx_array_size(dst));
394 if (ro->nsf == dst->ncomp)
395 rmx_scale(dst, ro->sca);
396 return(1);
397 }
398
399 static int
400 open_input(ROPMAT *rop)
401 {
402 int outtype;
403
404 if (!rop || !rop->inspec || !rop->inspec[0])
405 return(0);
406 if (rop->inspec == stdin_name)
407 rop->infp = stdin;
408 else if (rop->inspec[0] == '!')
409 rop->infp = popen(rop->inspec+1, "r");
410 else
411 rop->infp = fopen(rop->inspec, "rb");
412
413 if (!rmx_load_header(&rop->imx, rop->infp)) {
414 fprintf(stderr, "Bad header from: %s\n", rop->inspec);
415 return(0);
416 }
417 return(get_component_xfm(rop));
418 }
419
420 /* Return nominal wavelength associated with input component (return nm) */
421 static double
422 l_wavelength(char *nam)
423 {
424 double comp = argument(1);
425
426 if ((comp < -.5) | (comp >= in_ncomp+.5)) {
427 errno = EDOM;
428 return(.0);
429 }
430 if (comp < .5) /* asking for #components? */
431 return(in_ncomp);
432
433 if (in_ncomp == 3) { /* special case for RGB */
434 const int w0 = (int)(comp - .5);
435 return(mop[0].rmp->wlpart[w0] +
436 (comp-.5)*(mop[0].rmp->wlpart[w0+1] -
437 mop[0].rmp->wlpart[w0]));
438 }
439 return(mop[0].rmp->wlpart[0] + /* general case, even div. */
440 (comp-.5)/(double)in_ncomp *
441 (mop[0].rmp->wlpart[3] - mop[0].rmp->wlpart[0]));
442 }
443
444 /* Return ith input with optional channel selector */
445 static double
446 l_chanin(char *nam)
447 {
448 double inp = argument(1);
449 int mi, chan;
450
451 if ((mi = (int)(inp-.5)) < 0 || mi >= nmats) {
452 errno = EDOM;
453 return(.0);
454 }
455 if (inp < .5) /* asking for #inputs? */
456 return(nmats);
457
458 if (nargum() >= 2) {
459 double cval = argument(2);
460 if (cval < .5 || (chan = (int)(cval-.5)) >= in_ncomp) {
461 errno = EDOM;
462 return(.0);
463 }
464 } else
465 chan = cur_chan;
466
467 return(mop[mi].rmp->mtx[cur_col*in_ncomp + chan]);
468 }
469
470 static int
471 initialize(RMATRIX *imp)
472 {
473 int i;
474 /* XXX struct is zeroed coming in */
475 setcolor(imp->cexp, 1.f, 1.f, 1.f);
476 for (i = 0; i < nmats; i++) { /* open each input */
477 int restype;
478 if (!open_input(&mop[i]))
479 return(0);
480 restype = mop[i].rmp->dtype;
481 if (!imp->dtype || (restype = rmx_newtype(restype, imp->dtype)) > 0)
482 imp->dtype = restype;
483 else
484 fprintf(stderr, "%s: warning - data type mismatch\n",
485 mop[i].inspec);
486 if (!i) {
487 imp->ncols = mop[0].rmp->ncols;
488 imp->ncomp = mop[0].rmp->ncomp;
489 memcpy(imp->wlpart, mop[0].rmp->wlpart, sizeof(imp->wlpart));
490 } else if ((mop[i].rmp->ncols != imp->ncols) |
491 (mop[i].rmp->ncomp != imp->ncomp) |
492 ((in_nrows > 0) & (mop[i].rmp->nrows > 0) &
493 (mop[i].rmp->nrows != in_nrows))) {
494 fprintf(stderr, "%s: mismatch in size or #components\n",
495 mop[i].inspec);
496 return(0);
497 } /* XXX should check wlpart? */
498 if (in_nrows <= 0)
499 in_nrows = imp->nrows = mop[i].rmp->nrows;
500 } /* set up .cal environment */
501 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
502 esupport &= ~(E_OUTCHAN|E_INCHAN);
503 varset("PI", ':', M_PI);
504 varset("nfiles", ':', nmats);
505 varset("nrows", ':', in_nrows);
506 varset("ncols", ':', in_ncols);
507 varset("ncomp", ':', in_ncomp);
508 varset("R", ':', 1.);
509 varset("G", ':', 2.);
510 varset("B", ':', 3.);
511 funset("wl", 1, ':', l_wavelength);
512 funset("ci", 1, '=', l_chanin);
513 scompile("ri(i)=ci(i,R);gi(i)=ci(i,G);bi(i)=ci(i,B)", NULL, 0);
514 return(1);
515 }
516
517 static void
518 output_headinfo(FILE *fp)
519 {
520 int i;
521
522 for (i = 0; i < nmats; i++) {
523 const char *cp = mop[i].imx.info;
524 fputs(mop[i].inspec, fp);
525 fputs(":\n", fp);
526 if (!cp) continue;
527 while (*cp) {
528 if (*cp == '\n') {
529 cp++; /* avoid inadvertant terminus */
530 continue;
531 }
532 fputc('\t', fp); /* indent this input's info */
533 do
534 putc(*cp, fp);
535 while (*cp++ != '\n');
536 }
537 }
538 }
539
540 static int
541 combine_input(ROPMAT *res, FILE *fout)
542 {
543 int set_r, set_c;
544 RMATRIX *tmp = NULL;
545 int co_set;
546 int i;
547 /* allocate input row buffers */
548 for (i = 0; i < nmats; i++) {
549 mop[i].imx.nrows = 1; /* we'll be doing a row at a time */
550 if (!rmx_prepare(&mop[i].imx))
551 goto memerror;
552 if (mop[i].rmp != &mop[i].imx) {
553 mop[i].rmp->nrows = 1;
554 if (!rmx_prepare(mop[i].rmp))
555 goto memerror;
556 }
557 }
558 /* prep output row buffers */
559 if (mcat || res->preop.clen > 0) {
560 if (!split_input(res)) /* need separate buffer */
561 return(0);
562 if (res->preop.clen > 0)
563 res->rmp->ncomp = res->preop.clen / res->imx.ncomp;
564 res->rmp->nrows = 1;
565 if (!mcat | !mcat_last && !rmx_prepare(res->rmp))
566 goto memerror;
567 }
568 if (mcat && mcat_last &&
569 !(tmp = rmx_alloc(1, res->imx.ncols, res->rmp->ncomp)))
570 goto memerror;
571 res->imx.nrows = 1;
572 if (!rmx_prepare(&res->imx))
573 goto memerror;
574 /* figure out what the user set */
575 co_set = fundefined("co");
576 if (!co_set)
577 co_set = -vardefined("co");
578 if (!co_set & (in_ncomp == 3) && vardefined("ro") &&
579 vardefined("go") && vardefined("bo")) {
580 scompile("co(p)=select(p,ro,go,bo)", NULL, 0);
581 co_set = 1;
582 }
583 if (co_set) { /* set if user wants, didn't set */
584 set_r = varlookup("r") != NULL && !vardefined("r");
585 set_c = varlookup("c") != NULL && !vardefined("c");
586 } else /* save a little time */
587 set_r = set_c = 0;
588 /* read/process row-by-row */
589 for (cur_row = 0; (in_nrows <= 0) | (cur_row < in_nrows); cur_row++) {
590 RMATRIX *mres = NULL;
591 for (i = 0; i < nmats; i++) {
592 if (!rmx_load_row(mop[i].imx.mtx, &mop[i].imx, mop[i].infp)) {
593 if (cur_row > in_nrows) /* unknown #input rows? */
594 goto loop_exit;
595 fprintf(stderr, "%s: read error at row %d\n",
596 mop[i].inspec, cur_row);
597 return(0);
598 }
599 if (!apply_op(mop[i].rmp, &mop[i].imx, &mop[i].preop))
600 return(0);
601 }
602 if (set_r) varset("r", '=', cur_row);
603 for (cur_col = 0; cur_col < in_ncols; cur_col++) {
604 if (set_c) varset("c", '=', cur_col);
605 for (cur_chan = 0; cur_chan < in_ncomp; cur_chan++) {
606 const int ndx = cur_col*in_ncomp + cur_chan;
607 eclock++;
608 if (!co_set) { /* just summing elements? */
609 res->imx.mtx[ndx] = 0;
610 for (i = nmats; i--; )
611 res->imx.mtx[ndx] += mop[i].rmp->mtx[ndx];
612 } else if (co_set > 0) {
613 double dchan = cur_chan+1;
614 res->imx.mtx[ndx] = funvalue("co", 1, &dchan);
615 } else
616 res->imx.mtx[ndx] = varvalue("co");
617 }
618 } /* final conversions */
619 if (!mcat) {
620 if (!apply_op(res->rmp, &res->imx, &res->preop))
621 return(0);
622 } else if (mcat_last) {
623 if (!apply_op(tmp, &res->imx, &res->preop))
624 return(0);
625 mres = rmx_multiply(tmp, mcat);
626 if (!mres)
627 goto multerror;
628 if (!rmx_transfer_data(res->rmp, mres, 0))
629 return(0);
630 } else /* mcat && !mcat_last */ {
631 mres = rmx_multiply(&res->imx, mcat);
632 if (!mres)
633 goto multerror;
634 if (!apply_op(res->rmp, mres, &res->preop))
635 return(0);
636 }
637 rmx_free(mres); mres = NULL;
638 if (!rmx_write_data(res->rmp->mtx, res->rmp->ncomp,
639 res->rmp->ncols, res->rmp->dtype, fout))
640 return(0);
641 }
642 loop_exit:
643 #if 0 /* we're about to exit, so who cares? */
644 rmx_free(tmp); /* clean up */
645 rmx_reset(res->rmp);
646 rmx_reset(&res->imx);
647 for (i = 0; i < nmats; i++) {
648 rmx_reset(mop[i].rmp);
649 rmx_reset(&mop[i].imx);
650 if (mop[i].inspec[0] == '!')
651 pclose(mop[i].infp);
652 else if (mop[i].inspec != stdin_name)
653 fclose(mop[i].infp);
654 mop[i].infp = NULL;
655 }
656 #endif
657 return(fflush(fout) != EOF);
658 memerror:
659 fputs("Out of buffer space in combine_input()\n", stderr);
660 return(0);
661 multerror:
662 fputs("Unexpected matrix multiply error in combine_input()\n", stderr);
663 return(0);
664 }
665
666 static int
667 get_factors(double da[], int n, char *av[])
668 {
669 int ac;
670
671 for (ac = 0; ac < n && isflt(av[ac]); ac++)
672 da[ac] = atof(av[ac]);
673 return(ac);
674 }
675
676 static void
677 resize_inparr(int n2alloc)
678 {
679 int i;
680
681 if (n2alloc == nall)
682 return;
683 for (i = nall; i > n2alloc; i--) {
684 rmx_reset(&mop[i].imx);
685 if (mop[i].rmp != &mop[i].imx)
686 rmx_free(mop[i].rmp);
687 }
688 mop = (ROPMAT *)realloc(mop, n2alloc*sizeof(ROPMAT));
689 if (mop == NULL) {
690 fputs("Out of memory in resize_inparr()\n", stderr);
691 exit(1);
692 }
693 if (n2alloc > nall)
694 memset(mop+nall, 0, (n2alloc-nall)*sizeof(ROPMAT));
695 nall = n2alloc;
696 }
697
698 /* Load one or more matrices and operate on them, sending results to stdout */
699 int
700 main(int argc, char *argv[])
701 {
702
703 int outfmt = DTfromHeader;
704 const char *defCsym = NULL;
705 int echoheader = 1;
706 int stdin_used = 0;
707 const char *mcat_spec = NULL;
708 int n2comp = 0;
709 uby8 comp_ndx[128];
710 int i;
711 /* get starting input array */
712 mop = (ROPMAT *)calloc(nall=2, sizeof(ROPMAT));
713 /* get options and arguments */
714 for (i = 1; i < argc; i++)
715 if (argv[i][0] != '-' || !argv[i][1]) {
716 if (argv[i][0] == '-') {
717 if (stdin_used++) goto stdin_error;
718 mop[nmats].inspec = stdin_name;
719 } else
720 mop[nmats].inspec = argv[i];
721 if (!mop[nmats].preop.csym)
722 mop[nmats].preop.csym = defCsym;
723 if (++nmats >= nall)
724 resize_inparr(nmats + (nmats>>2) + 2);
725 } else {
726 int n = argc-1 - i;
727 switch (argv[i][1]) { /* get option */
728 case 'w':
729 nowarn = !nowarn;
730 break;
731 case 'h':
732 echoheader = !echoheader;
733 break;
734 case 'e':
735 if (!n) goto userr;
736 comp_ndx[n2comp++] = i++;
737 break;
738 case 'f':
739 switch (argv[i][2]) {
740 case '\0':
741 if (!n) goto userr;
742 comp_ndx[n2comp++] = i++;
743 break;
744 case 'd':
745 outfmt = DTdouble;
746 break;
747 case 'f':
748 outfmt = DTfloat;
749 break;
750 case 'a':
751 outfmt = DTascii;
752 break;
753 case 'c':
754 outfmt = DTrgbe;
755 break;
756 default:
757 goto userr;
758 }
759 break;
760 case 's':
761 if (n > MAXCOMP) n = MAXCOMP;
762 i += mop[nmats].preop.nsf =
763 get_factors(mop[nmats].preop.sca,
764 n, argv+i+1);
765 if (mop[nmats].preop.nsf <= 0) {
766 fprintf(stderr, "%s: -s missing arguments\n",
767 argv[0]);
768 goto userr;
769 }
770 break;
771 case 'C':
772 if (!n || isflt(argv[i+1]))
773 goto userr;
774 defCsym = mop[nmats].preop.csym = argv[++i];
775 mop[nmats].preop.clen = 0;
776 mcat_last = 0;
777 break;
778 case 'c':
779 if (n && !isflt(argv[i+1])) {
780 mop[nmats].preop.csym = argv[++i];
781 mop[nmats].preop.clen = 0;
782 break;
783 }
784 if (n > MAXCOMP*MAXCOMP) n = MAXCOMP*MAXCOMP;
785 i += mop[nmats].preop.clen =
786 get_factors(mop[nmats].preop.cmat,
787 n, argv+i+1);
788 if (mop[nmats].preop.clen <= 0) {
789 fprintf(stderr, "%s: -c missing arguments\n",
790 argv[0]);
791 goto userr;
792 }
793 mop[nmats].preop.csym = NULL;
794 mcat_last = 0;
795 break;
796 case 'm':
797 if (!n) goto userr;
798 if (argv[++i][0] == '-' && !argv[i][1]) {
799 if (stdin_used++) goto stdin_error;
800 mcat_spec = stdin_name;
801 } else
802 mcat_spec = argv[i];
803 mcat_last = 1;
804 break;
805 default:
806 fprintf(stderr, "%s: unknown option '%s'\n",
807 argv[0], argv[i]);
808 goto userr;
809 }
810 }
811 if (!nmats) {
812 fprintf(stderr, "%s: need at least one input matrix\n", argv[0]);
813 goto userr;
814 }
815 resize_inparr(nmats+1); /* extra matrix at end for result */
816 mop[nmats].inspec = "trailing_ops";
817 /* load final concatenation matrix */
818 if (mcat_spec && !(mcat = rmx_load(mcat_spec, RMPnone))) {
819 fprintf(stderr, "%s: error loading concatenation matrix: %s\n",
820 argv[0], mcat_spec);
821 return(1);
822 }
823 /* get/check inputs, set constants */
824 if (!initialize(&mop[nmats].imx))
825 return(1);
826
827 for (i = 0; i < n2comp; i++) /* user .cal files and expressions */
828 if (argv[comp_ndx[i]][1] == 'f') {
829 char *fpath = getpath(argv[comp_ndx[i]+1],
830 getrlibpath(), 0);
831 if (fpath == NULL) {
832 fprintf(stderr, "%s: cannot find file '%s'\n",
833 argv[0], argv[comp_ndx[i]+1]);
834 return(1);
835 }
836 fcompile(fpath);
837 } else /* (argv[comp_ndx[i]][1] == 'e') */
838 scompile(argv[comp_ndx[i]+1], NULL, 0);
839
840 /* get trailing color transform */
841 if (!get_component_xfm(&mop[nmats]))
842 return(1);
843 /* adjust output dimensions and #components */
844 if (mcat) {
845 if (mop[nmats].imx.ncols != mcat->nrows) {
846 fprintf(stderr,
847 "%s: number of input columns does not match number of rows in '%s'\n",
848 argv[0], mcat_spec);
849 return(1);
850 }
851 if (mcat->ncomp != (mcat_last ? mop[nmats].rmp->ncomp : mop[nmats].imx.ncomp)) {
852 fprintf(stderr,
853 "%s: number of components does not match those in '%s'\n",
854 argv[0], mcat_spec);
855 return(1);
856 }
857 if (!split_input(&mop[nmats]))
858 return(1);
859 mop[nmats].rmp->ncols = mcat->ncols;
860 }
861 newheader("RADIANCE", stdout); /* write output header */
862 if (echoheader)
863 output_headinfo(stdout);
864 printargs(argc, argv, stdout);
865 fputnow(stdout);
866 mop[nmats].rmp->dtype = rmx_write_header(mop[nmats].rmp, outfmt, stdout);
867 if (!mop[nmats].rmp->dtype) {
868 fprintf(stderr, "%s: unsupported output format\n", argv[0]);
869 return(1);
870 }
871 doptimize(1); /* optimize definitions */
872 /* process & write rows */
873 return(combine_input(&mop[nmats], stdout) ? 0 : 1);
874 stdin_error:
875 fprintf(stderr, "%s: %s used for more than one input\n",
876 argv[0], stdin_name);
877 return(1);
878 userr:
879 fprintf(stderr,
880 "Usage: %s [-h][-f{adfc}][-e expr][-f file][-s sf .. | -c ce ..] m1 .. -m mcat > mres\n",
881 argv[0]);
882 return(1);
883 }
