root/radiance/ray/src/util/rcomb.c
Revision: 2.8
Committed: Thu May 16 18:59:19 2024 UTC (11 months, 2 weeks ago) by greg
fix: Made use of resolu.h more consistent and reliable
2 static const char RCSid[] = "$Id: rcomb.c,v 2.7 2024/02/23 03:47:57 greg Exp $";
5 * General component matrix combiner, operating on a row at a time.
6 */
7
8 #include <errno.h>
9 #include <math.h>
10 #include "platform.h"
11 #include "rtio.h"
12 #include "rmatrix.h"
13 #include "calcomp.h"
14 #include "paths.h"
15
16 #ifndef M_PI
17 #define M_PI 3.14159265358979323846
18 #endif
19
20 #define MAXCOMP MAXCSAMP /* #components we support */
21
22 /* Unary matrix operation(s) */
23 typedef struct {
24 double cmat[MAXCOMP*MAXCOMP]; /* component transformation */
25 double sca[MAXCOMP]; /* scalar coefficients */
26 const char *csym; /* symbolic coefficients */
27 short clen; /* number of coefficients */
28 short nsf; /* number of scalars */
29 } RUNARYOP;
30
31 /* Input matrix */
32 typedef struct {
33 const char *inspec; /* input specification */
34 RUNARYOP preop; /* transform operation */
35 RMATRIX imx; /* input matrix header info */
36 RMATRIX *rmp; /* active single-row matrix */
37 FILE *infp; /* open input stream */
38 } ROPMAT;
39
40 ROPMAT *mop = NULL; /* allocated input array */
41 int nall = 0; /* number allocated */
42 int nmats = 0; /* number of actual inputs */
43
44 RMATRIX *mcat = NULL; /* final concatenation */
45 int mcat_last = 0; /* goes after trailing ops? */
46
47 int in_nrows; /* number of input rows (or 0) */
48 #define in_ncols (mop[0].rmp->ncols) /* number of input columns */
49 #define in_ncomp (mop[0].rmp->ncomp) /* input #components */
50
51 extern int nowarn; /* turn off warnings? */
52
53 int cur_row; /* current input/output row */
54 int cur_col; /* current input/output column */
55 int cur_chan; /* if we're looping channels */
56
57 static int checksymbolic(ROPMAT *rop);
58
59 static int
60 split_input(ROPMAT *rop)
61 {
62 if (rop->rmp == &rop->imx && !(rop->rmp = rmx_copy(&rop->imx))) {
63 fputs("Out of memory in split_input()\n", stderr);
64 return(0);
65 }
66 rmx_reset(rop->rmp);
67 return(1);
68 }
69
70 /* Check/set transform based on a reference input file */
71 static int
72 checkreffile(ROPMAT *rop)
73 {
74 static const char *curRF = NULL;
75 static RMATRIX refm;
76 const int nc = rop->imx.ncomp;
77 int i;
78
79 if (!curRF || strcmp(rop->preop.csym, curRF)) {
80 FILE *fp = fopen(rop->preop.csym, "rb");
81 if (!rmx_load_header(&refm, fp)) {
82 fprintf(stderr, "%s: cannot read info header\n",
83 rop->preop.csym);
84 curRF = NULL;
85 if (fp) fclose(fp);
86 return(0);
87 }
88 fclose(fp);
89 curRF = rop->preop.csym;
90 }
91 if (refm.ncomp == 3) {
92 rop->preop.csym = (refm.dtype == DTxyze) ? "XYZ" : "RGB";
93 return(checksymbolic(rop));
94 }
95 if (refm.ncomp == 2) {
96 fprintf(stderr, "%s: cannot convert to 2 components\n",
97 curRF);
98 return(0);
99 }
100 if (refm.ncomp == 1) {
101 rop->preop.csym = "Y"; /* XXX big assumption */
102 return(checksymbolic(rop));
103 }
104 if (refm.ncomp == nc &&
105 !memcmp(refm.wlpart, rop->imx.wlpart, sizeof(refm.wlpart)))
106 return(1); /* nothing to do */
107
108 if ((nc <= 3) | (nc > MAXCSAMP) | (refm.ncomp > MAXCSAMP)) {
109 fprintf(stderr, "%s: cannot resample from %d to %d components\n",
110 curRF, nc, refm.ncomp);
111 return(0);
112 }
113 if (!split_input(rop)) /* get our own struct */
114 return(0);
115 rop->preop.clen = refm.ncomp * nc; /* compute spec to ref */
116
117 for (i = 0; i < nc; i++) {
118 SCOLOR scstim, scresp;
119 int j;
120 memset(scstim, 0, sizeof(COLORV)*nc);
121 scstim[i] = 1.f;
122 convertscolor(scresp, refm.ncomp, refm.wlpart[0], refm.wlpart[3],
123 scstim, nc, rop->imx.wlpart[0], rop->imx.wlpart[3]);
124 for (j = refm.ncomp; j-- > 0; )
125 rop->preop.cmat[j*nc + i] = scresp[j];
126 }
127 /* remember new spectral params */
128 memcpy(rop->rmp->wlpart, refm.wlpart, sizeof(rop->rmp->wlpart));
129 rop->rmp->ncomp = refm.ncomp;
130 return(1);
131 }
132
133 /* Compute conversion row from spectrum to one channel of RGB */
134 static void
135 rgbrow(ROPMAT *rop, int r, int p)
136 {
137 const int nc = rop->imx.ncomp;
138 const float * wlp = rop->imx.wlpart;
139 int i;
140
141 for (i = nc; i--; ) {
142 int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc;
143 int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc;
144 COLOR crgb;
145 spec_rgb(crgb, nmStart, nmEnd);
146 rop->preop.cmat[r*nc+i] = crgb[p];
147 }
148 }
149
150 /* Compute conversion row from spectrum to one channel of XYZ */
151 static void
152 xyzrow(ROPMAT *rop, int r, int p)
153 {
154 const int nc = rop->imx.ncomp;
155 const float * wlp = rop->imx.wlpart;
156 int i;
157
158 for (i = nc; i--; ) {
159 int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc;
160 int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc;
161 COLOR cxyz;
162 spec_cie(cxyz, nmStart, nmEnd);
163 rop->preop.cmat[r*nc+i] = cxyz[p];
164 }
165 }
166
167 /* Use the spectral sensitivity function to compute matrix coefficients */
168 static void
169 sensrow(ROPMAT *rop, int r, double (*sf)(SCOLOR sc, int ncs, const float wlpt[4]))
170 {
171 const int nc = rop->imx.ncomp;
172 int i;
173
174 for (i = nc; i--; ) {
175 SCOLOR sclr;
176 memset(sclr, 0, sizeof(COLORV)*nc);
177 sclr[i] = 1.f;
178 rop->preop.cmat[r*nc+i] = (*sf)(sclr, nc, rop->imx.wlpart);
179 }
180 }
181
182 /* Check/set symbolic transform */
183 static int
184 checksymbolic(ROPMAT *rop)
185 {
186 const int nc = rop->imx.ncomp;
187 const int dt = rop->imx.dtype;
188 double cf = 1;
189 int i, j;
190 /* check suffix => reference file */
191 if (strchr(rop->preop.csym, '.') > rop->preop.csym)
192 return(checkreffile(rop));
193
194 if (nc < 3) {
195 fprintf(stderr, "%s: -c '%s' requires at least 3 components\n",
196 rop->inspec, rop->preop.csym);
197 return(0);
198 }
199 rop->preop.clen = strlen(rop->preop.csym) * nc;
200 if (rop->preop.clen > MAXCOMP*MAXCOMP) {
201 fprintf(stderr, "%s: -c '%s' results in too many components\n",
202 rop->inspec, rop->preop.csym);
203 return(0);
204 }
205 for (j = 0; rop->preop.csym[j]; j++) {
206 int comp = 0;
207 switch (rop->preop.csym[j]) {
208 case 'B':
209 case 'b':
210 ++comp;
211 /* fall through */
212 case 'G':
213 case 'g':
214 ++comp;
215 /* fall through */
216 case 'R':
217 case 'r':
218 if (rop->preop.csym[j] <= 'Z')
219 cf = 1./WHTEFFICACY;
220 if (dt == DTxyze) {
221 for (i = 3; i--; )
222 rop->preop.cmat[j*nc+i] = cf*xyz2rgbmat[comp][i];
223 } else if (nc == 3)
224 rop->preop.cmat[j*nc+comp] = 1.;
225 else
226 rgbrow(rop, j, comp);
227 break;
228 case 'Z':
229 case 'z':
230 ++comp;
231 /* fall through */
232 case 'Y':
233 case 'y':
234 ++comp;
235 /* fall through */
236 case 'X':
237 case 'x':
238 if ((rop->preop.csym[j] <= 'Z') & (dt != DTxyze))
239 cf = WHTEFFICACY;
240 if (dt == DTxyze) {
241 rop->preop.cmat[j*nc+comp] = 1.;
242 } else if (nc == 3) {
243 for (i = 3; i--; )
244 rop->preop.cmat[j*nc+i] =
245 rgb2xyzmat[comp][i];
246 } else if (comp == CIEY)
247 sensrow(rop, j, scolor2photopic);
248 else
249 xyzrow(rop, j, comp);
250
251 for (i = nc*(cf != 1); i--; )
252 rop->preop.cmat[j*nc+i] *= cf;
253 break;
254 case 'S': /* scotopic (il)luminance */
255 cf = WHTSCOTOPIC;
256 /* fall through */
257 case 's':
258 sensrow(rop, j, scolor2scotopic);
259 for (i = nc*(cf != 1); i--; )
260 rop->preop.cmat[j*nc+i] *= cf;
261 break;
262 case 'M': /* melanopic (il)luminance */
263 cf = WHTMELANOPIC;
264 /* fall through */
265 case 'm':
266 sensrow(rop, j, scolor2melanopic);
267 for (i = nc*(cf != 1); i--; )
268 rop->preop.cmat[j*nc+i] *= cf;
269 break;
270 case 'A': /* average component */
271 case 'a':
272 for (i = nc; i--; )
273 rop->preop.cmat[j*nc+i] = 1./(double)nc;
274 break;
275 default:
276 fprintf(stderr, "%s: -c '%c' unsupported\n",
277 rop->inspec, rop->preop.csym[j]);
278 return(0);
279 }
280 }
281 if (!split_input(rop)) /* get our own struct */
282 return(0);
283 memcpy(rop->rmp->wlpart, WLPART, sizeof(rop->rmp->wlpart));
284 rop->rmp->ncomp = rop->preop.clen / nc;
285 /* decide on output type */
286 if (!strcasecmp(rop->preop.csym, "XYZ")) {
287 if (dt <= DTspec)
288 rop->rmp->dtype = DTxyze;
289 } else if (!strcasecmp(rop->preop.csym, "RGB")) {
290 if (dt <= DTspec)
291 rop->rmp->dtype = DTrgbe;
292 } else if (rop->rmp->dtype == DTspec)
293 rop->rmp->dtype = DTfloat;
294 return(1);
295 }
296
297 static int
298 get_component_xfm(ROPMAT *rop)
299 {
300 int i, j;
301
302 if (rop->rmp != &rop->imx) { /* reset destination matrix */
303 rmx_free(rop->rmp);
304 rop->rmp = &rop->imx;
305 }
306 if (rop->preop.csym && /* symbolic transform? */
307 !checksymbolic(rop))
308 return(0);
309 /* undo exposure? */
310 if (fabs(1. - bright(rop->rmp->cexp)) > .025) {
311 if (rop->rmp->ncomp == 1)
312 rop->rmp->cexp[RED] = rop->rmp->cexp[GRN] =
313 rop->rmp->cexp[BLU] = bright(rop->rmp->cexp);
314 if (rop->preop.nsf <= 0) {
315 rop->preop.nsf = i = rop->rmp->ncomp;
316 while (i--)
317 rop->preop.sca[i] = 1.;
318 }
319 if (rop->preop.nsf == 1) {
320 if (rop->rmp->ncomp == 3) {
321 rop->preop.sca[2] = rop->preop.sca[1] =
322 rop->preop.sca[0];
323 rop->preop.nsf = 3;
324 } else
325 rop->preop.sca[0] /= bright(rop->rmp->cexp);
326 }
327 if (rop->preop.nsf == 3) {
328 opcolor(rop->preop.sca, /=, rop->rmp->cexp);
329 } else if (rop->preop.nsf > 3) { /* punt */
330 double mult = 1./bright(rop->rmp->cexp);
331 for (i = rop->preop.nsf; i--; )
332 rop->preop.sca[i] *= mult;
333 }
334 setcolor(rop->rmp->cexp, 1., 1., 1.);
335 }
336 if (rop->preop.clen > 0) { /* use component transform? */
337 if (rop->preop.clen % rop->imx.ncomp) {
338 fprintf(stderr, "%s: -c must have N x %d coefficients\n",
339 rop->inspec, rop->imx.ncomp);
340 return(0);
341 }
342 if (rop->preop.nsf > 0) { /* scale transform, instead */
343 if (rop->preop.nsf == 1) {
344 for (i = rop->preop.clen; i--; )
345 rop->preop.cmat[i] *= rop->preop.sca[0];
346 } else if (rop->preop.nsf*rop->imx.ncomp != rop->preop.clen) {
347 fprintf(stderr, "%s: -s must have one or %d factors\n",
348 rop->inspec,
349 rop->preop.clen/rop->imx.ncomp);
350 return(0);
351 } else {
352 for (i = rop->preop.nsf; i--; )
353 for (j = rop->imx.ncomp; j--; )
354 rop->preop.cmat[i*rop->imx.ncomp+j]
355 *= rop->preop.sca[i];
356 }
357 }
358 rop->preop.nsf = 0; /* now folded in */
359 if (!split_input(rop)) /* get our own struct */
360 return(0);
361 rop->rmp->ncomp = rop->preop.clen / rop->imx.ncomp;
362 if ((rop->rmp->ncomp > 3) & (rop->rmp->dtype <= DTspec)) {
363 rop->rmp->dtype = DTfloat; /* probably not actual spectrum */
364 memcpy(rop->rmp->wlpart, WLPART, sizeof(rop->rmp->wlpart));
365 }
366 } else if (rop->preop.nsf > 0) { /* else use scalar(s)? */
367 if (rop->preop.nsf == 1) {
368 for (i = rop->rmp->ncomp; --i; )
369 rop->preop.sca[i] = rop->preop.sca[0];
370 rop->preop.nsf = rop->rmp->ncomp;
371 } else if (rop->preop.nsf != rop->rmp->ncomp) {
372 fprintf(stderr, "%s: -s must have one or %d factors\n",
373 rop->inspec, rop->rmp->ncomp);
374 return(0);
375 }
376 }
377 return(1);
378 }
379
380 static int
381 apply_op(RMATRIX *dst, const RMATRIX *src, const RUNARYOP *ro)
382 {
383 if (ro->clen > 0) {
384 RMATRIX *res = rmx_transform(src, dst->ncomp, ro->cmat);
385 if (!res) {
386 fputs("Error in call to rmx_transform()\n", stderr);
387 return(0);
388 }
389 if (!rmx_transfer_data(dst, res, 0))
390 return(0);
391 rmx_free(res);
392 } else if (dst != src)
393 memcpy(dst->mtx, src->mtx,
394 sizeof(double)*dst->ncomp*dst->ncols*dst->nrows);
395 if (ro->nsf == dst->ncomp)
396 rmx_scale(dst, ro->sca);
397 return(1);
398 }
399
400 static int
401 open_input(ROPMAT *rop)
402 {
403 int outtype;
404
405 if (!rop || !rop->inspec || !rop->inspec[0])
406 return(0);
407 if (rop->inspec == stdin_name)
408 rop->infp = stdin;
409 else if (rop->inspec[0] == '!')
410 rop->infp = popen(rop->inspec+1, "r");
411 else
412 rop->infp = fopen(rop->inspec, "rb");
413
414 if (!rmx_load_header(&rop->imx, rop->infp)) {
415 fprintf(stderr, "Bad header from: %s\n", rop->inspec);
416 return(0);
417 }
418 return(get_component_xfm(rop));
419 }
420
421 /* Return nominal wavelength associated with input component (return nm) */
422 static double
423 l_wavelength(char *nam)
424 {
425 double comp = argument(1);
426
427 if ((comp < -.5) | (comp >= in_ncomp+.5)) {
428 errno = EDOM;
429 return(.0);
430 }
431 if (comp < .5) /* asking for #components? */
432 return(in_ncomp);
433
434 if (in_ncomp == 3) { /* special case for RGB */
435 const int w0 = (int)(comp - .5);
436 return(mop[0].rmp->wlpart[w0] +
437 (comp-.5)*(mop[0].rmp->wlpart[w0+1] -
438 mop[0].rmp->wlpart[w0]));
439 }
440 return(mop[0].rmp->wlpart[0] + /* general case, even div. */
441 (comp-.5)/(double)in_ncomp *
442 (mop[0].rmp->wlpart[3] - mop[0].rmp->wlpart[0]));
443 }
444
445 /* Return ith input with optional channel selector */
446 static double
447 l_chanin(char *nam)
448 {
449 double inp = argument(1);
450 int mi, chan;
451
452 if ((mi = (int)(inp-.5)) < 0 || mi >= nmats) {
453 errno = EDOM;
454 return(.0);
455 }
456 if (inp < .5) /* asking for #inputs? */
457 return(nmats);
458
459 if (nargum() >= 2) {
460 double cval = argument(2);
461 if (cval < .5 || (chan = (int)(cval-.5)) >= in_ncomp) {
462 errno = EDOM;
463 return(.0);
464 }
465 } else
466 chan = cur_chan;
467
468 return(mop[mi].rmp->mtx[cur_col*in_ncomp + chan]);
469 }
470
471 static int
472 initialize(RMATRIX *imp)
473 {
474 int i;
475 /* XXX struct is zeroed coming in */
476 setcolor(imp->cexp, 1.f, 1.f, 1.f);
477 for (i = 0; i < nmats; i++) { /* open each input */
478 int restype;
479 if (!open_input(&mop[i]))
480 return(0);
481 restype = mop[i].rmp->dtype;
482 if (!imp->dtype || (restype = rmx_newtype(restype, imp->dtype)) > 0)
483 imp->dtype = restype;
484 else
485 fprintf(stderr, "%s: warning - data type mismatch\n",
486 mop[i].inspec);
487 if (!i) {
488 imp->ncols = mop[0].rmp->ncols;
489 imp->ncomp = mop[0].rmp->ncomp;
490 memcpy(imp->wlpart, mop[0].rmp->wlpart, sizeof(imp->wlpart));
491 } else if ((mop[i].rmp->ncols != imp->ncols) |
492 (mop[i].rmp->ncomp != imp->ncomp) |
493 ((in_nrows > 0) & (mop[i].rmp->nrows > 0) &
494 (mop[i].rmp->nrows != in_nrows))) {
495 fprintf(stderr, "%s: mismatch in size or #components\n",
496 mop[i].inspec);
497 return(0);
498 } /* XXX should check wlpart? */
499 if (in_nrows <= 0)
500 in_nrows = imp->nrows = mop[i].rmp->nrows;
501 } /* set up .cal environment */
502 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
503 esupport &= ~(E_OUTCHAN|E_INCHAN);
504 varset("PI", ':', M_PI);
505 varset("nfiles", ':', nmats);
506 varset("nrows", ':', in_nrows);
507 varset("ncols", ':', in_ncols);
508 varset("ncomp", ':', in_ncomp);
509 varset("R", ':', 1.);
510 varset("G", ':', 2.);
511 varset("B", ':', 3.);
512 funset("wl", 1, ':', l_wavelength);
513 funset("ci", 1, '=', l_chanin);
514 scompile("ri(i)=ci(i,R);gi(i)=ci(i,G);bi(i)=ci(i,B)", NULL, 0);
515 return(1);
516 }
517
518 static void
519 output_headinfo(FILE *fp)
520 {
521 int i;
522
523 for (i = 0; i < nmats; i++) {
524 const char *cp = mop[i].imx.info;
525 fputs(mop[i].inspec, fp);
526 fputs(":\n", fp);
527 if (!cp) continue;
528 while (*cp) {
529 if (*cp == '\n') {
530 cp++; /* avoid inadvertant terminus */
531 continue;
532 }
533 fputc('\t', fp); /* indent this input's info */
534 do
535 putc(*cp, fp);
536 while (*cp++ != '\n');
537 }
538 }
539 }
540
541 static int
542 combine_input(ROPMAT *res, FILE *fout)
543 {
544 int set_r, set_c;
545 RMATRIX *tmp = NULL;
546 int co_set;
547 int i;
548 /* allocate input row buffers */
549 for (i = 0; i < nmats; i++) {
550 mop[i].imx.nrows = 1; /* we'll be doing a row at a time */
551 if (!rmx_prepare(&mop[i].imx))
552 goto memerror;
553 if (mop[i].rmp != &mop[i].imx) {
554 mop[i].rmp->nrows = 1;
555 if (!rmx_prepare(mop[i].rmp))
556 goto memerror;
557 }
558 }
559 /* prep output row buffers */
560 if (mcat || res->preop.clen > 0) {
561 if (!split_input(res)) /* need separate buffer */
562 return(0);
563 if (res->preop.clen > 0)
564 res->rmp->ncomp = res->preop.clen / res->imx.ncomp;
565 res->rmp->nrows = 1;
566 if (!mcat | !mcat_last && !rmx_prepare(res->rmp))
567 goto memerror;
568 }
569 if (mcat && mcat_last &&
570 !(tmp = rmx_alloc(1, res->imx.ncols, res->rmp->ncomp)))
571 goto memerror;
572 res->imx.nrows = 1;
573 if (!rmx_prepare(&res->imx))
574 goto memerror;
575 /* figure out what the user set */
576 co_set = fundefined("co");
577 if (!co_set)
578 co_set = -vardefined("co");
579 if (!co_set & (in_ncomp == 3) && vardefined("ro") &&
580 vardefined("go") && vardefined("bo")) {
581 scompile("co(p)=select(p,ro,go,bo)", NULL, 0);
582 co_set = 1;
583 }
584 if (co_set) { /* set if user wants, didn't set */
585 set_r = varlookup("r") != NULL && !vardefined("r");
586 set_c = varlookup("c") != NULL && !vardefined("c");
587 } else /* save a little time */
588 set_r = set_c = 0;
589 /* read/process row-by-row */
590 for (cur_row = 0; (in_nrows <= 0) | (cur_row < in_nrows); cur_row++) {
591 RMATRIX *mres = NULL;
592 for (i = 0; i < nmats; i++) {
593 if (!rmx_load_row(mop[i].imx.mtx, &mop[i].imx, mop[i].infp)) {
594 if (cur_row > in_nrows) /* unknown #input rows? */
595 goto loop_exit;
596 fprintf(stderr, "%s: read error at row %d\n",
597 mop[i].inspec, cur_row);
598 return(0);
599 }
600 if (!apply_op(mop[i].rmp, &mop[i].imx, &mop[i].preop))
601 return(0);
602 }
603 if (set_r) varset("r", '=', cur_row);
604 for (cur_col = 0; cur_col < in_ncols; cur_col++) {
605 if (set_c) varset("c", '=', cur_col);
606 for (cur_chan = 0; cur_chan < in_ncomp; cur_chan++) {
607 const int ndx = cur_col*in_ncomp + cur_chan;
608 eclock++;
609 if (!co_set) { /* just summing elements? */
610 res->imx.mtx[ndx] = 0;
611 for (i = nmats; i--; )
612 res->imx.mtx[ndx] += mop[i].rmp->mtx[ndx];
613 } else if (co_set > 0) {
614 double dchan = cur_chan+1;
615 res->imx.mtx[ndx] = funvalue("co", 1, &dchan);
616 } else
617 res->imx.mtx[ndx] = varvalue("co");
618 }
619 } /* final conversions */
620 if (!mcat) {
621 if (!apply_op(res->rmp, &res->imx, &res->preop))
622 return(0);
623 } else if (mcat_last) {
624 if (!apply_op(tmp, &res->imx, &res->preop))
625 return(0);
626 mres = rmx_multiply(tmp, mcat);
627 if (!mres)
628 goto multerror;
629 if (!rmx_transfer_data(res->rmp, mres, 0))
630 return(0);
631 } else /* mcat && !mcat_last */ {
632 mres = rmx_multiply(&res->imx, mcat);
633 if (!mres)
634 goto multerror;
635 if (!apply_op(res->rmp, mres, &res->preop))
636 return(0);
637 }
638 rmx_free(mres); mres = NULL;
639 if (!rmx_write_data(res->rmp->mtx, res->rmp->ncomp,
640 res->rmp->ncols, res->rmp->dtype, fout))
641 return(0);
642 }
643 loop_exit:
644 #if 0 /* we're about to exit, so who cares? */
645 rmx_free(tmp); /* clean up */
646 rmx_reset(res->rmp);
647 rmx_reset(&res->imx);
648 for (i = 0; i < nmats; i++) {
649 rmx_reset(mop[i].rmp);
650 rmx_reset(&mop[i].imx);
651 if (mop[i].inspec[0] == '!')
652 pclose(mop[i].infp);
653 else if (mop[i].inspec != stdin_name)
654 fclose(mop[i].infp);
655 mop[i].infp = NULL;
656 }
657 #endif
658 return(fflush(fout) != EOF);
659 memerror:
660 fputs("Out of buffer space in combine_input()\n", stderr);
661 return(0);
662 multerror:
663 fputs("Unexpected matrix multiply error in combine_input()\n", stderr);
664 return(0);
665 }
666
667 static int
668 get_factors(double da[], int n, char *av[])
669 {
670 int ac;
671
672 for (ac = 0; ac < n && isflt(av[ac]); ac++)
673 da[ac] = atof(av[ac]);
674 return(ac);
675 }
676
677 static void
678 resize_inparr(int n2alloc)
679 {
680 int i;
681
682 if (n2alloc == nall)
683 return;
684 for (i = nall; i > n2alloc; i--) {
685 rmx_reset(&mop[i].imx);
686 if (mop[i].rmp != &mop[i].imx)
687 rmx_free(mop[i].rmp);
688 }
689 mop = (ROPMAT *)realloc(mop, n2alloc*sizeof(ROPMAT));
690 if (mop == NULL) {
691 fputs("Out of memory in resize_inparr()\n", stderr);
692 exit(1);
693 }
694 if (n2alloc > nall)
695 memset(mop+nall, 0, (n2alloc-nall)*sizeof(ROPMAT));
696 nall = n2alloc;
697 }
698
699 /* Load one or more matrices and operate on them, sending results to stdout */
700 int
701 main(int argc, char *argv[])
702 {
703
704 int outfmt = DTfromHeader;
705 const char *defCsym = NULL;
706 int echoheader = 1;
707 int stdin_used = 0;
708 const char *mcat_spec = NULL;
709 int n2comp = 0;
710 uby8 comp_ndx[128];
711 int i;
712 /* get starting input array */
713 mop = (ROPMAT *)calloc(nall=2, sizeof(ROPMAT));
714 /* get options and arguments */
715 for (i = 1; i < argc; i++)
716 if (argv[i][0] != '-' || !argv[i][1]) {
717 if (argv[i][0] == '-') {
718 if (stdin_used++) goto stdin_error;
719 mop[nmats].inspec = stdin_name;
720 } else
721 mop[nmats].inspec = argv[i];
722 if (!mop[nmats].preop.csym)
723 mop[nmats].preop.csym = defCsym;
724 if (++nmats >= nall)
725 resize_inparr(nmats + (nmats>>2) + 2);
726 } else {
727 int n = argc-1 - i;
728 switch (argv[i][1]) { /* get option */
729 case 'w':
730 nowarn = !nowarn;
731 break;
732 case 'h':
733 echoheader = !echoheader;
734 break;
735 case 'e':
736 if (!n) goto userr;
737 comp_ndx[n2comp++] = i++;
738 break;
739 case 'f':
740 switch (argv[i][2]) {
741 case '\0':
742 if (!n) goto userr;
743 comp_ndx[n2comp++] = i++;
744 break;
745 case 'd':
746 outfmt = DTdouble;
747 break;
748 case 'f':
749 outfmt = DTfloat;
750 break;
751 case 'a':
752 outfmt = DTascii;
753 break;
754 case 'c':
755 outfmt = DTrgbe;
756 break;
757 default:
758 goto userr;
759 }
760 break;
761 case 's':
762 if (n > MAXCOMP) n = MAXCOMP;
763 i += mop[nmats].preop.nsf =
764 get_factors(mop[nmats].preop.sca,
765 n, argv+i+1);
766 if (mop[nmats].preop.nsf <= 0) {
767 fprintf(stderr, "%s: -s missing arguments\n",
768 argv[0]);
769 goto userr;
770 }
771 break;
772 case 'C':
773 if (!n || isflt(argv[i+1]))
774 goto userr;
775 defCsym = mop[nmats].preop.csym = argv[++i];
776 mop[nmats].preop.clen = 0;
777 mcat_last = 0;
778 break;
779 case 'c':
780 if (n && !isflt(argv[i+1])) {
781 mop[nmats].preop.csym = argv[++i];
782 mop[nmats].preop.clen = 0;
783 break;
784 }
785 if (n > MAXCOMP*MAXCOMP) n = MAXCOMP*MAXCOMP;
786 i += mop[nmats].preop.clen =
787 get_factors(mop[nmats].preop.cmat,
788 n, argv+i+1);
789 if (mop[nmats].preop.clen <= 0) {
790 fprintf(stderr, "%s: -c missing arguments\n",
791 argv[0]);
792 goto userr;
793 }
794 mop[nmats].preop.csym = NULL;
795 mcat_last = 0;
796 break;
797 case 'm':
798 if (!n) goto userr;
799 if (argv[++i][0] == '-' && !argv[i][1]) {
800 if (stdin_used++) goto stdin_error;
801 mcat_spec = stdin_name;
802 } else
803 mcat_spec = argv[i];
804 mcat_last = 1;
805 break;
806 default:
807 fprintf(stderr, "%s: unknown option '%s'\n",
808 argv[0], argv[i]);
809 goto userr;
810 }
811 }
812 if (!nmats) {
813 fprintf(stderr, "%s: need at least one input matrix\n", argv[0]);
814 goto userr;
815 }
816 resize_inparr(nmats+1); /* extra matrix at end for result */
817 mop[nmats].inspec = "trailing_ops";
818 /* load final concatenation matrix */
819 if (mcat_spec && !(mcat = rmx_load(mcat_spec, RMPnone))) {
820 fprintf(stderr, "%s: error loading concatenation matrix: %s\n",
821 argv[0], mcat_spec);
822 return(1);
823 }
824 /* get/check inputs, set constants */
825 if (!initialize(&mop[nmats].imx))
826 return(1);
827
828 for (i = 0; i < n2comp; i++) /* user .cal files and expressions */
829 if (argv[comp_ndx[i]][1] == 'f') {
830 char *fpath = getpath(argv[comp_ndx[i]+1],
831 getrlibpath(), 0);
832 if (fpath == NULL) {
833 fprintf(stderr, "%s: cannot find file '%s'\n",
834 argv[0], argv[comp_ndx[i]+1]);
835 return(1);
836 }
837 fcompile(fpath);
838 } else /* (argv[comp_ndx[i]][1] == 'e') */
839 scompile(argv[comp_ndx[i]+1], NULL, 0);
840
841 /* get trailing color transform */
842 if (!get_component_xfm(&mop[nmats]))
843 return(1);
844 /* adjust output dimensions and #components */
845 if (mcat) {
846 if (mop[nmats].imx.ncols != mcat->nrows) {
847 fprintf(stderr,
848 "%s: number of input columns does not match number of rows in '%s'\n",
849 argv[0], mcat_spec);
850 return(1);
851 }
852 if (mcat->ncomp != (mcat_last ? mop[nmats].rmp->ncomp : mop[nmats].imx.ncomp)) {
853 fprintf(stderr,
854 "%s: number of components does not match those in '%s'\n",
855 argv[0], mcat_spec);
856 return(1);
857 }
858 if (!split_input(&mop[nmats]))
859 return(1);
860 mop[nmats].rmp->ncols = mcat->ncols;
861 }
862 newheader("RADIANCE", stdout); /* write output header */
863 if (echoheader)
864 output_headinfo(stdout);
865 printargs(argc, argv, stdout);
866 fputnow(stdout);
867 mop[nmats].rmp->dtype = rmx_write_header(mop[nmats].rmp, outfmt, stdout);
868 if (!mop[nmats].rmp->dtype) {
869 fprintf(stderr, "%s: unsupported output format\n", argv[0]);
870 return(1);
871 }
872 doptimize(1); /* optimize definitions */
873 /* process & write rows */
874 return(combine_input(&mop[nmats], stdout) ? 0 : 1);
875 stdin_error:
876 fprintf(stderr, "%s: %s used for more than one input\n",
877 argv[0], stdin_name);
878 return(1);
879 userr:
880 fprintf(stderr,
881 "Usage: %s [-h][-f{adfc}][-e expr][-f file][-s sf .. | -c ce ..] m1 .. -m mcat > mres\n",
882 argv[0]);
883 return(1);
884 }
