root/Development/ray/src/util/rcomb.c
Revision: 2.6
Committed: Fri Feb 9 19:58:56 2024 UTC (22 months, 3 weeks ago) by greg
Changes since 2.5: +6 -4 lines
fix(rcomb): Fixed issue with final operations (reallocation error)
2 static const char RCSid[] = "$Id: rcomb.c,v 2.5 2023/12/19 20:38:38 greg Exp $";
5 * General component matrix combiner, operating on a row at a time.
6 */
7
8 #include <errno.h>
9 #include <math.h>
10 #include "platform.h"
11 #include "rtio.h"
12 #include "resolu.h"
13 #include "rmatrix.h"
14 #include "calcomp.h"
15 #include "paths.h"
16
17 #ifndef M_PI
18 #define M_PI 3.14159265358979323846
19 #endif
20
21 #define MAXCOMP MAXCSAMP /* #components we support */
22
23 /* Unary matrix operation(s) */
24 typedef struct {
25 double cmat[MAXCOMP*MAXCOMP]; /* component transformation */
26 double sca[MAXCOMP]; /* scalar coefficients */
27 const char *csym; /* symbolic coefficients */
28 short clen; /* number of coefficients */
29 short nsf; /* number of scalars */
30 } RUNARYOP;
31
32 /* Input matrix */
33 typedef struct {
34 const char *inspec; /* input specification */
35 RUNARYOP preop; /* transform operation */
36 RMATRIX imx; /* input matrix header info */
37 RMATRIX *rmp; /* active single-row matrix */
38 FILE *infp; /* open input stream */
39 } ROPMAT;
40
41 ROPMAT *mop = NULL; /* allocated input array */
42 int nall = 0; /* number allocated */
43 int nmats = 0; /* number of actual inputs */
44
45 RMATRIX *mcat = NULL; /* final concatenation */
46 int mcat_last = 0; /* goes after trailing ops? */
47
48 int in_nrows; /* number of input rows (or 0) */
49 #define in_ncols (mop[0].rmp->ncols) /* number of input columns */
50 #define in_ncomp (mop[0].rmp->ncomp) /* input #components */
51
52 extern int nowarn; /* turn off warnings? */
53
54 int cur_row; /* current input/output row */
55 int cur_col; /* current input/output column */
56 int cur_chan; /* if we're looping channels */
57
58 static int checksymbolic(ROPMAT *rop);
59
60 static int
61 split_input(ROPMAT *rop)
62 {
63 if (rop->rmp == &rop->imx && !(rop->rmp = rmx_copy(&rop->imx))) {
64 fputs("Out of memory in split_input()\n", stderr);
65 return(0);
66 }
67 rmx_reset(rop->rmp);
68 return(1);
69 }
70
71 /* Check/set transform based on a reference input file */
72 static int
73 checkreffile(ROPMAT *rop)
74 {
75 static const char *curRF = NULL;
76 static RMATRIX refm;
77 const int nc = rop->imx.ncomp;
78 int i;
79
80 if (!curRF || strcmp(rop->preop.csym, curRF)) {
81 FILE *fp = fopen(rop->preop.csym, "rb");
82 if (!rmx_load_header(&refm, fp)) {
83 fprintf(stderr, "%s: cannot read info header\n",
84 rop->preop.csym);
85 curRF = NULL;
86 if (fp) fclose(fp);
87 return(0);
88 }
89 fclose(fp);
90 curRF = rop->preop.csym;
91 }
92 if (refm.ncomp == 3) {
93 rop->preop.csym = (refm.dtype == DTxyze) ? "XYZ" : "RGB";
94 return(checksymbolic(rop));
95 }
96 if (refm.ncomp == 2) {
97 fprintf(stderr, "%s: cannot convert to 2 components\n",
98 curRF);
99 return(0);
100 }
101 if (refm.ncomp == 1) {
102 rop->preop.csym = "Y"; /* XXX big assumption */
103 return(checksymbolic(rop));
104 }
105 if (refm.ncomp == nc &&
106 !memcmp(refm.wlpart, rop->imx.wlpart, sizeof(refm.wlpart)))
107 return(1); /* nothing to do */
108
109 if ((nc <= 3) | (nc > MAXCSAMP) | (refm.ncomp > MAXCSAMP)) {
110 fprintf(stderr, "%s: cannot resample from %d to %d components\n",
111 curRF, nc, refm.ncomp);
112 return(0);
113 }
114 if (!split_input(rop)) /* get our own struct */
115 return(0);
116 rop->preop.clen = refm.ncomp * nc; /* compute spec to ref */
117
118 for (i = 0; i < nc; i++) {
119 SCOLOR scstim, scresp;
120 int j;
121 memset(scstim, 0, sizeof(COLORV)*nc);
122 scstim[i] = 1.f;
123 convertscolor(scresp, refm.ncomp, refm.wlpart[0], refm.wlpart[3],
124 scstim, nc, rop->imx.wlpart[0], rop->imx.wlpart[3]);
125 for (j = refm.ncomp; j-- > 0; )
126 rop->preop.cmat[j*nc + i] = scresp[j];
127 }
128 /* remember new spectral params */
129 memcpy(rop->rmp->wlpart, refm.wlpart, sizeof(rop->rmp->wlpart));
130 rop->rmp->ncomp = refm.ncomp;
131 return(1);
132 }
133
134 /* Compute conversion row from spectrum to one channel of RGB */
135 static void
136 rgbrow(ROPMAT *rop, int r, int p)
137 {
138 const int nc = rop->imx.ncomp;
139 const float * wlp = rop->imx.wlpart;
140 int i;
141
142 for (i = nc; i--; ) {
143 int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc;
144 int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc;
145 COLOR crgb;
146 spec_rgb(crgb, nmStart, nmEnd);
147 rop->preop.cmat[r*nc+i] = crgb[p];
148 }
149 }
150
151 /* Compute conversion row from spectrum to one channel of XYZ */
152 static void
153 xyzrow(ROPMAT *rop, int r, int p)
154 {
155 const int nc = rop->imx.ncomp;
156 const float * wlp = rop->imx.wlpart;
157 int i;
158
159 for (i = nc; i--; ) {
160 int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc;
161 int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc;
162 COLOR cxyz;
163 spec_cie(cxyz, nmStart, nmEnd);
164 rop->preop.cmat[r*nc+i] = cxyz[p];
165 }
166 }
167
168 /* Use the spectral sensitivity function to compute matrix coefficients */
169 static void
170 sensrow(ROPMAT *rop, int r, double (*sf)(SCOLOR sc, int ncs, const float wlpt[4]))
171 {
172 const int nc = rop->imx.ncomp;
173 int i;
174
175 for (i = nc; i--; ) {
176 SCOLOR sclr;
177 memset(sclr, 0, sizeof(COLORV)*nc);
178 sclr[i] = 1.f;
179 rop->preop.cmat[r*nc+i] = (*sf)(sclr, nc, rop->imx.wlpart);
180 }
181 }
182
183 /* Check/set symbolic transform */
184 static int
185 checksymbolic(ROPMAT *rop)
186 {
187 const int nc = rop->imx.ncomp;
188 const int dt = rop->imx.dtype;
189 double cf = 1;
190 int i, j;
191 /* check suffix => reference file */
192 if (strchr(rop->preop.csym, '.') > rop->preop.csym)
193 return(checkreffile(rop));
194
195 if (nc < 3) {
196 fprintf(stderr, "%s: -c '%s' requires at least 3 components\n",
197 rop->inspec, rop->preop.csym);
198 return(0);
199 }
200 rop->preop.clen = strlen(rop->preop.csym) * nc;
201 if (rop->preop.clen > MAXCOMP*MAXCOMP) {
202 fprintf(stderr, "%s: -c '%s' results in too many components\n",
203 rop->inspec, rop->preop.csym);
204 return(0);
205 }
206 for (j = 0; rop->preop.csym[j]; j++) {
207 int comp = 0;
208 switch (rop->preop.csym[j]) {
209 case 'B':
210 case 'b':
211 ++comp;
212 /* fall through */
213 case 'G':
214 case 'g':
215 ++comp;
216 /* fall through */
217 case 'R':
218 case 'r':
219 if (rop->preop.csym[j] <= 'Z')
220 cf = 1./WHTEFFICACY;
221 if (dt == DTxyze) {
222 for (i = 3; i--; )
223 rop->preop.cmat[j*nc+i] = cf*xyz2rgbmat[comp][i];
224 } else if (nc == 3)
225 rop->preop.cmat[j*nc+comp] = 1.;
226 else
227 rgbrow(rop, j, comp);
228 break;
229 case 'Z':
230 case 'z':
231 ++comp;
232 /* fall through */
233 case 'Y':
234 case 'y':
235 ++comp;
236 /* fall through */
237 case 'X':
238 case 'x':
239 if ((rop->preop.csym[j] <= 'Z') & (dt != DTxyze))
240 cf = WHTEFFICACY;
241 if (dt == DTxyze) {
242 rop->preop.cmat[j*nc+comp] = 1.;
243 } else if (nc == 3) {
244 for (i = 3; i--; )
245 rop->preop.cmat[j*nc+i] =
246 rgb2xyzmat[comp][i];
247 } else if (comp == CIEY)
248 sensrow(rop, j, scolor2photopic);
249 else
250 xyzrow(rop, j, comp);
251
252 for (i = nc*(cf != 1); i--; )
253 rop->preop.cmat[j*nc+i] *= cf;
254 break;
255 case 'S': /* scotopic (il)luminance */
256 cf = WHTSCOTOPIC;
257 /* fall through */
258 case 's':
259 sensrow(rop, j, scolor2scotopic);
260 for (i = nc*(cf != 1); i--; )
261 rop->preop.cmat[j*nc+i] *= cf;
262 break;
263 case 'M': /* melanopic (il)luminance */
264 cf = WHTMELANOPIC;
265 /* fall through */
266 case 'm':
267 sensrow(rop, j, scolor2melanopic);
268 for (i = nc*(cf != 1); i--; )
269 rop->preop.cmat[j*nc+i] *= cf;
270 break;
271 case 'A': /* average component */
272 case 'a':
273 for (i = nc; i--; )
274 rop->preop.cmat[j*nc+i] = 1./(double)nc;
275 break;
276 default:
277 fprintf(stderr, "%s: -c '%c' unsupported\n",
278 rop->inspec, rop->preop.csym[j]);
279 return(0);
280 }
281 }
282 if (!split_input(rop)) /* get our own struct */
283 return(0);
284 memcpy(rop->rmp->wlpart, WLPART, sizeof(rop->rmp->wlpart));
285 rop->rmp->ncomp = rop->preop.clen / nc;
286 /* decide on output type */
287 if (!strcasecmp(rop->preop.csym, "XYZ")) {
288 if (dt <= DTspec)
289 rop->rmp->dtype = DTxyze;
290 } else if (!strcasecmp(rop->preop.csym, "RGB")) {
291 if (dt <= DTspec)
292 rop->rmp->dtype = DTrgbe;
293 } else if (rop->rmp->dtype == DTspec)
294 rop->rmp->dtype = DTfloat;
295 return(1);
296 }
297
298 static int
299 get_component_xfm(ROPMAT *rop)
300 {
301 int i, j;
302
303 if (rop->rmp != &rop->imx) { /* reset destination matrix */
304 rmx_free(rop->rmp);
305 rop->rmp = &rop->imx;
306 }
307 if (rop->preop.csym && /* symbolic transform? */
308 !checksymbolic(rop))
309 return(0);
310 /* undo exposure? */
311 if (fabs(1. - bright(rop->rmp->cexp)) > .025) {
312 if (rop->rmp->ncomp == 1)
313 rop->rmp->cexp[RED] = rop->rmp->cexp[GRN] =
314 rop->rmp->cexp[BLU] = bright(rop->rmp->cexp);
315 if (rop->preop.nsf <= 0) {
316 rop->preop.nsf = i = rop->rmp->ncomp;
317 while (i--)
318 rop->preop.sca[i] = 1.;
319 }
320 if (rop->preop.nsf == 1) {
321 if (rop->rmp->ncomp == 3) {
322 rop->preop.sca[2] = rop->preop.sca[1] =
323 rop->preop.sca[0];
324 rop->preop.nsf = 3;
325 } else
326 rop->preop.sca[0] /= bright(rop->rmp->cexp);
327 }
328 if (rop->preop.nsf == 3) {
329 opcolor(rop->preop.sca, /=, rop->rmp->cexp);
330 } else if (rop->preop.nsf > 3) { /* punt */
331 double mult = 1./bright(rop->rmp->cexp);
332 for (i = rop->preop.nsf; i--; )
333 rop->preop.sca[i] *= mult;
334 }
335 setcolor(rop->rmp->cexp, 1., 1., 1.);
336 }
337 if (rop->preop.clen > 0) { /* use component transform? */
338 if (rop->preop.clen % rop->imx.ncomp) {
339 fprintf(stderr, "%s: -c must have N x %d coefficients\n",
340 rop->inspec, rop->imx.ncomp);
341 return(0);
342 }
343 if (rop->preop.nsf > 0) { /* scale transform, instead */
344 if (rop->preop.nsf == 1) {
345 for (i = rop->preop.clen; i--; )
346 rop->preop.cmat[i] *= rop->preop.sca[0];
347 } else if (rop->preop.nsf*rop->imx.ncomp != rop->preop.clen) {
348 fprintf(stderr, "%s: -s must have one or %d factors\n",
349 rop->inspec,
350 rop->preop.clen/rop->imx.ncomp);
351 return(0);
352 } else {
353 for (i = rop->preop.nsf; i--; )
354 for (j = rop->imx.ncomp; j--; )
355 rop->preop.cmat[i*rop->imx.ncomp+j]
356 *= rop->preop.sca[i];
357 }
358 }
359 rop->preop.nsf = 0; /* now folded in */
360 if (!split_input(rop)) /* get our own struct */
361 return(0);
362 rop->rmp->ncomp = rop->preop.clen / rop->imx.ncomp;
363 if ((rop->rmp->ncomp > 3) & (rop->rmp->dtype <= DTspec)) {
364 rop->rmp->dtype = DTfloat; /* probably not actual spectrum */
365 memcpy(rop->rmp->wlpart, WLPART, sizeof(rop->rmp->wlpart));
366 }
367 } else if (rop->preop.nsf > 0) { /* else use scalar(s)? */
368 if (rop->preop.nsf == 1) {
369 for (i = rop->rmp->ncomp; --i; )
370 rop->preop.sca[i] = rop->preop.sca[0];
371 rop->preop.nsf = rop->rmp->ncomp;
372 } else if (rop->preop.nsf != rop->rmp->ncomp) {
373 fprintf(stderr, "%s: -s must have one or %d factors\n",
374 rop->inspec, rop->rmp->ncomp);
375 return(0);
376 }
377 }
378 return(1);
379 }
380
381 static int
382 apply_op(RMATRIX *dst, const RMATRIX *src, const RUNARYOP *ro)
383 {
384 if (ro->clen > 0) {
385 RMATRIX *res = rmx_transform(src, dst->ncomp, ro->cmat);
386 if (!res) {
387 fputs("Error in call to rmx_transform()\n", stderr);
388 return(0);
389 }
390 if (!rmx_transfer_data(dst, res, 0))
391 return(0);
392 rmx_free(res);
393 } else if (dst != src)
394 memcpy(dst->mtx, src->mtx,
395 sizeof(double)*dst->ncomp*dst->ncols*dst->nrows);
396 if (ro->nsf == dst->ncomp)
397 rmx_scale(dst, ro->sca);
398 return(1);
399 }
400
401 static int
402 open_input(ROPMAT *rop)
403 {
404 int outtype;
405
406 if (!rop || !rop->inspec || !rop->inspec[0])
407 return(0);
408 if (rop->inspec == stdin_name)
409 rop->infp = stdin;
410 else if (rop->inspec[0] == '!')
411 rop->infp = popen(rop->inspec+1, "r");
412 else
413 rop->infp = fopen(rop->inspec, "rb");
414
415 if (!rmx_load_header(&rop->imx, rop->infp)) {
416 fprintf(stderr, "Bad header from: %s\n", rop->inspec);
417 return(0);
418 }
419 return(get_component_xfm(rop));
420 }
421
422 /* Return nominal wavelength associated with input component (return nm) */
423 static double
424 l_wavelength(char *nam)
425 {
426 double comp = argument(1);
427
428 if ((comp < -.5) | (comp >= in_ncomp+.5)) {
429 errno = EDOM;
430 return(.0);
431 }
432 if (comp < .5) /* asking for #components? */
433 return(in_ncomp);
434
435 if (in_ncomp == 3) { /* special case for RGB */
436 const int w0 = (int)(comp - .5);
437 return(mop[0].rmp->wlpart[w0] +
438 (comp-.5)*(mop[0].rmp->wlpart[w0+1] -
439 mop[0].rmp->wlpart[w0]));
440 }
441 return(mop[0].rmp->wlpart[0] + /* general case, even div. */
442 (comp-.5)/(double)in_ncomp *
443 (mop[0].rmp->wlpart[3] - mop[0].rmp->wlpart[0]));
444 }
445
446 /* Return ith input with optional channel selector */
447 static double
448 l_chanin(char *nam)
449 {
450 double inp = argument(1);
451 int mi, chan;
452
453 if ((mi = (int)(inp-.5)) < 0 || mi >= nmats) {
454 errno = EDOM;
455 return(.0);
456 }
457 if (inp < .5) /* asking for #inputs? */
458 return(nmats);
459
460 if (nargum() >= 2) {
461 double cval = argument(2);
462 if (cval < .5 || (chan = (int)(cval-.5)) >= in_ncomp) {
463 errno = EDOM;
464 return(.0);
465 }
466 } else
467 chan = cur_chan;
468
469 return(mop[mi].rmp->mtx[cur_col*in_ncomp + chan]);
470 }
471
472 static int
473 initialize(RMATRIX *imp)
474 {
475 int i;
476 /* XXX struct is zeroed coming in */
477 setcolor(imp->cexp, 1.f, 1.f, 1.f);
478 for (i = 0; i < nmats; i++) { /* open each input */
479 int restype;
480 if (!open_input(&mop[i]))
481 return(0);
482 restype = mop[i].rmp->dtype;
483 if (!imp->dtype || (restype = rmx_newtype(restype, imp->dtype)) > 0)
484 imp->dtype = restype;
485 else
486 fprintf(stderr, "%s: warning - data type mismatch\n",
487 mop[i].inspec);
488 if (!i) {
489 imp->ncols = mop[0].rmp->ncols;
490 imp->ncomp = mop[0].rmp->ncomp;
491 memcpy(imp->wlpart, mop[0].rmp->wlpart, sizeof(imp->wlpart));
492 } else if ((mop[i].rmp->ncols != imp->ncols) |
493 (mop[i].rmp->ncomp != imp->ncomp) |
494 ((in_nrows > 0) & (mop[i].rmp->nrows > 0) &
495 (mop[i].rmp->nrows != in_nrows))) {
496 fprintf(stderr, "%s: mismatch in size or #components\n",
497 mop[i].inspec);
498 return(0);
499 } /* XXX should check wlpart? */
500 if (in_nrows <= 0)
501 in_nrows = imp->nrows = mop[i].rmp->nrows;
502 } /* set up .cal environment */
503 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
504 esupport &= ~(E_OUTCHAN|E_INCHAN);
505 varset("PI", ':', M_PI);
506 varset("nfiles", ':', nmats);
507 varset("nrows", ':', in_nrows);
508 varset("ncols", ':', in_ncols);
509 varset("ncomp", ':', in_ncomp);
510 varset("R", ':', 1.);
511 varset("G", ':', 2.);
512 varset("B", ':', 3.);
513 funset("wl", 1, ':', l_wavelength);
514 funset("ci", 1, '=', l_chanin);
515 scompile("ri(i)=ci(i,R);gi(i)=ci(i,G);bi(i)=ci(i,B)", NULL, 0);
516 return(1);
517 }
518
519 static void
520 output_headinfo(FILE *fp)
521 {
522 int i;
523
524 for (i = 0; i < nmats; i++) {
525 const char *cp = mop[i].imx.info;
526 fputs(mop[i].inspec, fp);
527 fputs(":\n", fp);
528 if (!cp) continue;
529 while (*cp) {
530 if (*cp == '\n') {
531 cp++; /* avoid inadvertant terminus */
532 continue;
533 }
534 fputc('\t', fp); /* indent this input's info */
535 do
536 putc(*cp, fp);
537 while (*cp++ != '\n');
538 }
539 }
540 }
541
542 static int
543 combine_input(ROPMAT *res, FILE *fout)
544 {
545 int set_r, set_c;
546 RMATRIX *tmp = NULL;
547 int co_set;
548 int i;
549 /* allocate input row buffers */
550 for (i = 0; i < nmats; i++) {
551 mop[i].imx.nrows = 1; /* we'll be doing a row at a time */
552 if (!rmx_prepare(&mop[i].imx))
553 goto memerror;
554 if (mop[i].rmp != &mop[i].imx) {
555 mop[i].rmp->nrows = 1;
556 if (!rmx_prepare(mop[i].rmp))
557 goto memerror;
558 }
559 }
560 /* prep output row buffers */
561 if (mcat || res->preop.clen > 0) {
562 if (!split_input(res)) /* need separate buffer */
563 return(0);
564 if (res->preop.clen > 0)
565 res->rmp->ncomp = res->preop.clen / res->imx.ncomp;
566 res->rmp->nrows = 1;
567 if (!mcat | !mcat_last && !rmx_prepare(res->rmp))
568 goto memerror;
569 }
570 if (mcat && mcat_last &&
571 !(tmp = rmx_alloc(1, res->imx.ncols, res->rmp->ncomp)))
572 goto memerror;
573 res->imx.nrows = 1;
574 if (!rmx_prepare(&res->imx))
575 goto memerror;
576 /* figure out what the user set */
577 co_set = fundefined("co");
578 if (!co_set)
579 co_set = -vardefined("co");
580 if (!co_set & (in_ncomp == 3) && vardefined("ro") &&
581 vardefined("go") && vardefined("bo")) {
582 scompile("co(p)=select(p,ro,go,bo)", NULL, 0);
583 co_set = 1;
584 }
585 if (co_set) { /* set if user wants, didn't set */
586 set_r = varlookup("r") != NULL && !vardefined("r");
587 set_c = varlookup("c") != NULL && !vardefined("c");
588 } else /* save a little time */
589 set_r = set_c = 0;
590 /* read/process row-by-row */
591 for (cur_row = 0; (in_nrows <= 0) | (cur_row < in_nrows); cur_row++) {
592 RMATRIX *mres = NULL;
593 for (i = 0; i < nmats; i++) {
594 if (!rmx_load_row(mop[i].imx.mtx, &mop[i].imx, mop[i].infp)) {
595 if (cur_row > in_nrows) /* unknown #input rows? */
596 goto loop_exit;
597 fprintf(stderr, "%s: read error at row %d\n",
598 mop[i].inspec, cur_row);
599 return(0);
600 }
601 if (!apply_op(mop[i].rmp, &mop[i].imx, &mop[i].preop))
602 return(0);
603 }
604 if (set_r) varset("r", '=', cur_row);
605 for (cur_col = 0; cur_col < in_ncols; cur_col++) {
606 if (set_c) varset("c", '=', cur_col);
607 for (cur_chan = 0; cur_chan < in_ncomp; cur_chan++) {
608 const int ndx = cur_col*in_ncomp + cur_chan;
609 eclock++;
610 if (!co_set) { /* just summing elements? */
611 res->imx.mtx[ndx] = 0;
612 for (i = nmats; i--; )
613 res->imx.mtx[ndx] += mop[i].rmp->mtx[ndx];
614 } else if (co_set > 0) {
615 double dchan = cur_chan+1;
616 res->imx.mtx[ndx] = funvalue("co", 1, &dchan);
617 } else
618 res->imx.mtx[ndx] = varvalue("co");
619 }
620 } /* final conversions */
621 if (!mcat) {
622 if (!apply_op(res->rmp, &res->imx, &res->preop))
623 return(0);
624 } else if (mcat_last) {
625 if (!apply_op(tmp, &res->imx, &res->preop))
626 return(0);
627 mres = rmx_multiply(tmp, mcat);
628 if (!mres)
629 goto multerror;
630 if (!rmx_transfer_data(res->rmp, mres, 0))
631 return(0);
632 } else /* mcat && !mcat_last */ {
633 mres = rmx_multiply(&res->imx, mcat);
634 if (!mres)
635 goto multerror;
636 if (!apply_op(res->rmp, mres, &res->preop))
637 return(0);
638 }
639 rmx_free(mres); mres = NULL;
640 if (!rmx_write_data(res->rmp->mtx, res->rmp->ncomp,
641 res->rmp->ncols, res->rmp->dtype, fout))
642 return(0);
643 }
644 loop_exit:
645 #if 0 /* we're about to exit, so who cares? */
646 rmx_free(tmp); /* clean up */
647 rmx_reset(res->rmp);
648 rmx_reset(&res->imx);
649 for (i = 0; i < nmats; i++) {
650 rmx_reset(mop[i].rmp);
651 rmx_reset(&mop[i].imx);
652 if (mop[i].inspec[0] == '!')
653 pclose(mop[i].infp);
654 else if (mop[i].inspec != stdin_name)
655 fclose(mop[i].infp);
656 mop[i].infp = NULL;
657 }
658 #endif
659 return(fflush(fout) != EOF);
660 memerror:
661 fputs("Out of buffer space in combine_input()\n", stderr);
662 return(0);
663 multerror:
664 fputs("Unexpected matrix multiply error in combine_input()\n", stderr);
665 return(0);
666 }
667
668 static int
669 get_factors(double da[], int n, char *av[])
670 {
671 int ac;
672
673 for (ac = 0; ac < n && isflt(av[ac]); ac++)
674 da[ac] = atof(av[ac]);
675 return(ac);
676 }
677
678 static void
679 resize_inparr(int n2alloc)
680 {
681 int i;
682
683 if (n2alloc == nall)
684 return;
685 for (i = nall; i > n2alloc; i--) {
686 rmx_reset(&mop[i].imx);
687 if (mop[i].rmp != &mop[i].imx)
688 rmx_free(mop[i].rmp);
689 }
690 mop = (ROPMAT *)realloc(mop, n2alloc*sizeof(ROPMAT));
691 if (mop == NULL) {
692 fputs("Out of memory in resize_inparr()\n", stderr);
693 exit(1);
694 }
695 if (n2alloc > nall)
696 memset(mop+nall, 0, (n2alloc-nall)*sizeof(ROPMAT));
697 nall = n2alloc;
698 }
699
700 /* Load one or more matrices and operate on them, sending results to stdout */
701 int
702 main(int argc, char *argv[])
703 {
704
705 int outfmt = DTfromHeader;
706 const char *defCsym = NULL;
707 int echoheader = 1;
708 int stdin_used = 0;
709 const char *mcat_spec = NULL;
710 int n2comp = 0;
711 uby8 comp_ndx[128];
712 int i;
713 /* get starting input array */
714 mop = (ROPMAT *)calloc(nall=2, sizeof(ROPMAT));
715 /* get options and arguments */
716 for (i = 1; i < argc; i++)
717 if (argv[i][0] != '-' || !argv[i][1]) {
718 if (argv[i][0] == '-') {
719 if (stdin_used++) goto stdin_error;
720 mop[nmats].inspec = stdin_name;
721 } else
722 mop[nmats].inspec = argv[i];
723 if (!mop[nmats].preop.csym)
724 mop[nmats].preop.csym = defCsym;
725 if (++nmats >= nall)
726 resize_inparr(nmats + (nmats>>2) + 2);
727 } else {
728 int n = argc-1 - i;
729 switch (argv[i][1]) { /* get option */
730 case 'w':
731 nowarn = !nowarn;
732 break;
733 case 'h':
734 echoheader = !echoheader;
735 break;
736 case 'e':
737 if (!n) goto userr;
738 comp_ndx[n2comp++] = i++;
739 break;
740 case 'f':
741 switch (argv[i][2]) {
742 case '\0':
743 if (!n) goto userr;
744 comp_ndx[n2comp++] = i++;
745 break;
746 case 'd':
747 outfmt = DTdouble;
748 break;
749 case 'f':
750 outfmt = DTfloat;
751 break;
752 case 'a':
753 outfmt = DTascii;
754 break;
755 case 'c':
756 outfmt = DTrgbe;
757 break;
758 default:
759 goto userr;
760 }
761 break;
762 case 's':
763 if (n > MAXCOMP) n = MAXCOMP;
764 i += mop[nmats].preop.nsf =
765 get_factors(mop[nmats].preop.sca,
766 n, argv+i+1);
767 if (mop[nmats].preop.nsf <= 0) {
768 fprintf(stderr, "%s: -s missing arguments\n",
769 argv[0]);
770 goto userr;
771 }
772 break;
773 case 'C':
774 if (!n || isflt(argv[i+1]))
775 goto userr;
776 defCsym = mop[nmats].preop.csym = argv[++i];
777 mop[nmats].preop.clen = 0;
778 mcat_last = 0;
779 break;
780 case 'c':
781 if (n && !isflt(argv[i+1])) {
782 mop[nmats].preop.csym = argv[++i];
783 mop[nmats].preop.clen = 0;
784 break;
785 }
786 if (n > MAXCOMP*MAXCOMP) n = MAXCOMP*MAXCOMP;
787 i += mop[nmats].preop.clen =
788 get_factors(mop[nmats].preop.cmat,
789 n, argv+i+1);
790 if (mop[nmats].preop.clen <= 0) {
791 fprintf(stderr, "%s: -c missing arguments\n",
792 argv[0]);
793 goto userr;
794 }
795 mop[nmats].preop.csym = NULL;
796 mcat_last = 0;
797 break;
798 case 'm':
799 if (!n) goto userr;
800 if (argv[++i][0] == '-' && !argv[i][1]) {
801 if (stdin_used++) goto stdin_error;
802 mcat_spec = stdin_name;
803 } else
804 mcat_spec = argv[i];
805 mcat_last = 1;
806 break;
807 default:
808 fprintf(stderr, "%s: unknown option '%s'\n",
809 argv[0], argv[i]);
810 goto userr;
811 }
812 }
813 if (!nmats) {
814 fprintf(stderr, "%s: need at least one input matrix\n", argv[0]);
815 goto userr;
816 }
817 resize_inparr(nmats+1); /* extra matrix at end for result */
818 mop[nmats].inspec = "trailing_ops";
819 /* load final concatenation matrix */
820 if (mcat_spec && !(mcat = rmx_load(mcat_spec, RMPnone))) {
821 fprintf(stderr, "%s: error loading concatenation matrix: %s\n",
822 argv[0], mcat_spec);
823 return(1);
824 }
825 /* get/check inputs, set constants */
826 if (!initialize(&mop[nmats].imx))
827 return(1);
828
829 for (i = 0; i < n2comp; i++) /* user .cal files and expressions */
830 if (argv[comp_ndx[i]][1] == 'f') {
831 char *fpath = getpath(argv[comp_ndx[i]+1],
832 getrlibpath(), 0);
833 if (fpath == NULL) {
834 fprintf(stderr, "%s: cannot find file '%s'\n",
835 argv[0], argv[comp_ndx[i]+1]);
836 return(1);
837 }
838 fcompile(fpath);
839 } else /* (argv[comp_ndx[i]][1] == 'e') */
840 scompile(argv[comp_ndx[i]+1], NULL, 0);
841
842 /* get trailing color transform */
843 if (!get_component_xfm(&mop[nmats]))
844 return(1);
845 /* adjust output dimensions and #components */
846 if (mcat) {
847 if (mop[nmats].imx.ncols != mcat->nrows) {
848 fprintf(stderr,
849 "%s: number of input columns does not match number of rows in '%s'\n",
850 argv[0], mcat_spec);
851 return(1);
852 }
853 if (mcat->ncomp != (mcat_last ? mop[nmats].rmp->ncomp : mop[nmats].imx.ncomp)) {
854 fprintf(stderr,
855 "%s: number of components does not match those in '%s'\n",
856 argv[0], mcat_spec);
857 return(1);
858 }
859 if (!split_input(&mop[nmats]))
860 return(1);
861 mop[nmats].rmp->ncols = mcat->ncols;
862 }
863 newheader("RADIANCE", stdout); /* write output header */
864 if (echoheader)
865 output_headinfo(stdout);
866 printargs(argc, argv, stdout);
867 fputnow(stdout);
868 mop[nmats].rmp->dtype = rmx_write_header(mop[nmats].rmp, outfmt, stdout);
869 if (!mop[nmats].rmp->dtype) {
870 fprintf(stderr, "%s: unsupported output format\n", argv[0]);
871 return(1);
872 }
873 /* process & write rows */
874 return(combine_input(&mop[nmats], stdout) ? 0 : 1);
875 stdin_error:
876 fprintf(stderr, "%s: %s used for more than one input\n",
877 argv[0], stdin_name);
878 return(1);
879 userr:
880 fprintf(stderr,
881 "Usage: %s [-h][-f{adfc}][-e expr][-f file][-s sf .. | -c ce ..] m1 .. -m mcat > mres\n",
882 argv[0]);
883 return(1);
884 }
