| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rcomb.c,v 2.4 2023/12/19 16:09:20 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* General component matrix combiner, operating on a row at a time.
| 6 |
| 7 |
| 8 |
#include <errno.h>
| 9 |
#include <math.h>
| 10 |
#include "platform.h"
| 11 |
#include "rtio.h"
| 12 |
#include "resolu.h"
| 13 |
#include "rmatrix.h"
| 14 |
#include "calcomp.h"
| 15 |
#include "paths.h"
| 16 |
| 17 |
#ifndef M_PI
| 18 |
#define M_PI 3.14159265358979323846
| 19 |
#endif
| 20 |
| 21 |
#define MAXCOMP MAXCSAMP /* #components we support */
| 22 |
| 23 |
/* Unary matrix operation(s) */
| 24 |
typedef struct {
| 25 |
double cmat[MAXCOMP*MAXCOMP]; /* component transformation */
| 26 |
double sca[MAXCOMP]; /* scalar coefficients */
| 27 |
const char *csym; /* symbolic coefficients */
| 28 |
short clen; /* number of coefficients */
| 29 |
short nsf; /* number of scalars */
| 30 |
} RUNARYOP;
| 31 |
| 32 |
/* Input matrix */
| 33 |
typedef struct {
| 34 |
const char *inspec; /* input specification */
| 35 |
RUNARYOP preop; /* transform operation */
| 36 |
RMATRIX imx; /* input matrix header info */
| 37 |
RMATRIX *rmp; /* active single-row matrix */
| 38 |
FILE *infp; /* open input stream */
| 39 |
} ROPMAT;
| 40 |
| 41 |
ROPMAT *mop = NULL; /* allocated input array */
| 42 |
int nall = 0; /* number allocated */
| 43 |
int nmats = 0; /* number of actual inputs */
| 44 |
| 45 |
RMATRIX *mcat = NULL; /* final concatenation */
| 46 |
int mcat_last = 0; /* goes after trailing ops? */
| 47 |
| 48 |
int in_nrows; /* number of input rows (or 0) */
| 49 |
#define in_ncols (mop[0].rmp->ncols) /* number of input columns */
| 50 |
#define in_ncomp (mop[0].rmp->ncomp) /* input #components */
| 51 |
| 52 |
extern int nowarn; /* turn off warnings? */
| 53 |
| 54 |
int cur_row; /* current input/output row */
| 55 |
int cur_col; /* current input/output column */
| 56 |
int cur_chan; /* if we're looping channels */
| 57 |
| 58 |
static int checksymbolic(ROPMAT *rop);
| 59 |
| 60 |
static int
| 61 |
split_input(ROPMAT *rop)
| 62 |
| 63 |
if (rop->rmp == &rop->imx && !(rop->rmp = rmx_copy(&rop->imx))) {
| 64 |
fputs("Out of memory in split_input()\n", stderr);
| 65 |
return(0);
| 66 |
| 67 |
rmx_reset(rop->rmp);
| 68 |
return(1);
| 69 |
| 70 |
| 71 |
/* Check/set transform based on a reference input file */
| 72 |
static int
| 73 |
checkreffile(ROPMAT *rop)
| 74 |
| 75 |
static const char *curRF = NULL;
| 76 |
static RMATRIX refm;
| 77 |
const int nc = rop->imx.ncomp;
| 78 |
int i;
| 79 |
| 80 |
if (!curRF || strcmp(rop->preop.csym, curRF)) {
| 81 |
FILE *fp = fopen(rop->preop.csym, "rb");
| 82 |
if (!rmx_load_header(&refm, fp)) {
| 83 |
fprintf(stderr, "%s: cannot read info header\n",
| 84 |
rop->preop.csym);
| 85 |
curRF = NULL;
| 86 |
if (fp) fclose(fp);
| 87 |
return(0);
| 88 |
| 89 |
fclose(fp);
| 90 |
curRF = rop->preop.csym;
| 91 |
| 92 |
if (refm.ncomp == 3) {
| 93 |
rop->preop.csym = (refm.dtype == DTxyze) ? "XYZ" : "RGB";
| 94 |
return(checksymbolic(rop));
| 95 |
| 96 |
if (refm.ncomp == 2) {
| 97 |
fprintf(stderr, "%s: cannot convert to 2 components\n",
| 98 |
curRF);
| 99 |
return(0);
| 100 |
| 101 |
if (refm.ncomp == 1) {
| 102 |
rop->preop.csym = "Y"; /* XXX big assumption */
| 103 |
| 104 |
| 105 |
if (refm.ncomp == nc &&
| 106 |
!memcmp(refm.wlpart, rop->imx.wlpart, sizeof(refm.wlpart)))
| 107 |
return(1); /* nothing to do */
| 108 |
| 109 |
if ((nc <= 3) | (nc > MAXCSAMP) | (refm.ncomp > MAXCSAMP)) {
| 110 |
fprintf(stderr, "%s: cannot resample from %d to %d components\n",
| 111 |
curRF, nc, refm.ncomp);
| 112 |
return(0);
| 113 |
| 114 |
if (!split_input(rop)) /* get our own struct */
| 115 |
return(0);
| 116 |
rop->preop.clen = refm.ncomp * nc; /* compute spec to ref */
| 117 |
| 118 |
for (i = 0; i < nc; i++) {
| 119 |
SCOLOR scstim, scresp;
| 120 |
int j;
| 121 |
memset(scstim, 0, sizeof(COLORV)*nc);
| 122 |
scstim[i] = 1.f;
| 123 |
convertscolor(scresp, refm.ncomp, refm.wlpart[0], refm.wlpart[3],
| 124 |
scstim, nc, rop->imx.wlpart[0], rop->imx.wlpart[3]);
| 125 |
for (j = refm.ncomp; j-- > 0; )
| 126 |
rop->preop.cmat[j*nc + i] = scresp[j];
| 127 |
| 128 |
/* remember new spectral params */
| 129 |
memcpy(rop->rmp->wlpart, refm.wlpart, sizeof(rop->rmp->wlpart));
| 130 |
rop->rmp->ncomp = refm.ncomp;
| 131 |
return(1);
| 132 |
| 133 |
| 134 |
/* Compute conversion row from spectrum to one channel of RGB */
| 135 |
static void
| 136 |
rgbrow(ROPMAT *rop, int r, int p)
| 137 |
| 138 |
| 139 |
const float * wlp = rop->imx.wlpart;
| 140 |
int i;
| 141 |
| 142 |
for (i = nc; i--; ) {
| 143 |
int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc;
| 144 |
int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc;
| 145 |
COLOR crgb;
| 146 |
spec_rgb(crgb, nmStart, nmEnd);
| 147 |
rop->preop.cmat[r*nc+i] = crgb[p];
| 148 |
| 149 |
| 150 |
| 151 |
/* Compute conversion row from spectrum to one channel of XYZ */
| 152 |
static void
| 153 |
xyzrow(ROPMAT *rop, int r, int p)
| 154 |
| 155 |
| 156 |
| 157 |
int i;
| 158 |
| 159 |
| 160 |
| 161 |
| 162 |
COLOR cxyz;
| 163 |
spec_cie(cxyz, nmStart, nmEnd);
| 164 |
rop->preop.cmat[r*nc+i] = cxyz[p];
| 165 |
| 166 |
| 167 |
| 168 |
/* Use the spectral sensitivity function to compute matrix coefficients */
| 169 |
static void
| 170 |
sensrow(ROPMAT *rop, int r, double (*sf)(SCOLOR sc, int ncs, const float wlpt[4]))
| 171 |
| 172 |
| 173 |
int i;
| 174 |
| 175 |
| 176 |
SCOLOR sclr;
| 177 |
memset(sclr, 0, sizeof(COLORV)*nc);
| 178 |
sclr[i] = 1.f;
| 179 |
rop->preop.cmat[r*nc+i] = (*sf)(sclr, nc, rop->imx.wlpart);
| 180 |
| 181 |
| 182 |
| 183 |
/* Check/set symbolic transform */
| 184 |
static int
| 185 |
| 186 |
| 187 |
| 188 |
const int dt = rop->imx.dtype;
| 189 |
double cf = 1;
| 190 |
int i, j;
| 191 |
/* check suffix => reference file */
| 192 |
if (strchr(rop->preop.csym, '.') > rop->preop.csym)
| 193 |
return(checkreffile(rop));
| 194 |
| 195 |
if (nc < 3) {
| 196 |
fprintf(stderr, "%s: -c '%s' requires at least 3 components\n",
| 197 |
rop->inspec, rop->preop.csym);
| 198 |
return(0);
| 199 |
| 200 |
rop->preop.clen = strlen(rop->preop.csym) * nc;
| 201 |
if (rop->preop.clen > MAXCOMP*MAXCOMP) {
| 202 |
fprintf(stderr, "%s: -c '%s' results in too many components\n",
| 203 |
| 204 |
return(0);
| 205 |
| 206 |
for (j = 0; rop->preop.csym[j]; j++) {
| 207 |
int comp = 0;
| 208 |
switch (rop->preop.csym[j]) {
| 209 |
case 'B':
| 210 |
case 'b':
| 211 |
++comp;
| 212 |
/* fall through */
| 213 |
case 'G':
| 214 |
case 'g':
| 215 |
++comp;
| 216 |
/* fall through */
| 217 |
case 'R':
| 218 |
case 'r':
| 219 |
if (rop->preop.csym[j] <= 'Z')
| 220 |
cf = 1./WHTEFFICACY;
| 221 |
if (dt == DTxyze) {
| 222 |
for (i = 3; i--; )
| 223 |
rop->preop.cmat[j*nc+i] = cf*xyz2rgbmat[comp][i];
| 224 |
} else if (nc == 3)
| 225 |
rop->preop.cmat[j*nc+comp] = 1.;
| 226 |
else
| 227 |
rgbrow(rop, j, comp);
| 228 |
break;
| 229 |
case 'Z':
| 230 |
case 'z':
| 231 |
++comp;
| 232 |
/* fall through */
| 233 |
case 'Y':
| 234 |
case 'y':
| 235 |
++comp;
| 236 |
/* fall through */
| 237 |
case 'X':
| 238 |
case 'x':
| 239 |
if ((rop->preop.csym[j] <= 'Z') & (dt != DTxyze))
| 240 |
cf = WHTEFFICACY;
| 241 |
if (dt == DTxyze) {
| 242 |
| 243 |
} else if (nc == 3) {
| 244 |
for (i = 3; i--; )
| 245 |
| 246 |
rgb2xyzmat[comp][i];
| 247 |
} else if (comp == CIEY)
| 248 |
sensrow(rop, j, scolor2photopic);
| 249 |
else
| 250 |
xyzrow(rop, j, comp);
| 251 |
| 252 |
for (i = nc*(cf != 1); i--; )
| 253 |
rop->preop.cmat[j*nc+i] *= cf;
| 254 |
break;
| 255 |
case 'S': /* scotopic (il)luminance */
| 256 |
cf = WHTSCOTOPIC;
| 257 |
/* fall through */
| 258 |
case 's':
| 259 |
sensrow(rop, j, scolor2scotopic);
| 260 |
| 261 |
| 262 |
break;
| 263 |
case 'M': /* melanopic (il)luminance */
| 264 |
cf = WHTMELANOPIC;
| 265 |
/* fall through */
| 266 |
case 'm':
| 267 |
sensrow(rop, j, scolor2melanopic);
| 268 |
| 269 |
| 270 |
break;
| 271 |
case 'A': /* average component */
| 272 |
case 'a':
| 273 |
for (i = nc; i--; )
| 274 |
rop->preop.cmat[j*nc+i] = 1./(double)nc;
| 275 |
break;
| 276 |
default:
| 277 |
fprintf(stderr, "%s: -c '%c' unsupported\n",
| 278 |
rop->inspec, rop->preop.csym[j]);
| 279 |
return(0);
| 280 |
| 281 |
| 282 |
| 283 |
return(0);
| 284 |
memcpy(rop->rmp->wlpart, WLPART, sizeof(rop->rmp->wlpart));
| 285 |
rop->rmp->ncomp = rop->preop.clen / nc;
| 286 |
/* decide on output type */
| 287 |
if (!strcasecmp(rop->preop.csym, "XYZ")) {
| 288 |
if (dt <= DTspec)
| 289 |
rop->rmp->dtype = DTxyze;
| 290 |
} else if (!strcasecmp(rop->preop.csym, "RGB")) {
| 291 |
if (dt <= DTspec)
| 292 |
rop->rmp->dtype = DTrgbe;
| 293 |
} else if (rop->rmp->dtype == DTspec)
| 294 |
rop->rmp->dtype = DTfloat;
| 295 |
return(1);
| 296 |
| 297 |
| 298 |
static int
| 299 |
get_component_xfm(ROPMAT *rop)
| 300 |
| 301 |
int i, j;
| 302 |
| 303 |
if (rop->rmp != &rop->imx) { /* reset destination matrix */
| 304 |
rmx_free(rop->rmp);
| 305 |
rop->rmp = &rop->imx;
| 306 |
| 307 |
if (rop->preop.csym && /* symbolic transform? */
| 308 |
!checksymbolic(rop))
| 309 |
return(0);
| 310 |
/* undo exposure? */
| 311 |
if (fabs(1. - bright(rop->rmp->cexp)) > .025) {
| 312 |
if (rop->rmp->ncomp == 1)
| 313 |
rop->rmp->cexp[RED] = rop->rmp->cexp[GRN] =
| 314 |
rop->rmp->cexp[BLU] = bright(rop->rmp->cexp);
| 315 |
if (rop->preop.nsf <= 0) {
| 316 |
rop->preop.nsf = i = rop->rmp->ncomp;
| 317 |
while (i--)
| 318 |
rop->preop.sca[i] = 1.;
| 319 |
| 320 |
if (rop->preop.nsf == 1) {
| 321 |
if (rop->rmp->ncomp == 3) {
| 322 |
rop->preop.sca[2] = rop->preop.sca[1] =
| 323 |
rop->preop.sca[0];
| 324 |
rop->preop.nsf = 3;
| 325 |
} else
| 326 |
rop->preop.sca[0] /= bright(rop->rmp->cexp);
| 327 |
| 328 |
if (rop->preop.nsf == 3) {
| 329 |
opcolor(rop->preop.sca, /=, rop->rmp->cexp);
| 330 |
} else if (rop->preop.nsf > 3) { /* punt */
| 331 |
double mult = 1./bright(rop->rmp->cexp);
| 332 |
for (i = rop->preop.nsf; i--; )
| 333 |
rop->preop.sca[i] *= mult;
| 334 |
| 335 |
setcolor(rop->rmp->cexp, 1., 1., 1.);
| 336 |
| 337 |
if (rop->preop.clen > 0) { /* use component transform? */
| 338 |
if (rop->preop.clen % rop->imx.ncomp) {
| 339 |
fprintf(stderr, "%s: -c must have N x %d coefficients\n",
| 340 |
rop->inspec, rop->imx.ncomp);
| 341 |
return(0);
| 342 |
| 343 |
if (rop->preop.nsf > 0) { /* scale transform, instead */
| 344 |
| 345 |
for (i = rop->preop.clen; i--; )
| 346 |
rop->preop.cmat[i] *= rop->preop.sca[0];
| 347 |
} else if (rop->preop.nsf*rop->imx.ncomp != rop->preop.clen) {
| 348 |
fprintf(stderr, "%s: -s must have one or %d factors\n",
| 349 |
rop->inspec,
| 350 |
rop->preop.clen/rop->imx.ncomp);
| 351 |
return(0);
| 352 |
} else {
| 353 |
| 354 |
for (j = rop->imx.ncomp; j--; )
| 355 |
rop->preop.cmat[i*rop->imx.ncomp+j]
| 356 |
*= rop->preop.sca[i];
| 357 |
| 358 |
| 359 |
rop->preop.nsf = 0; /* now folded in */
| 360 |
| 361 |
return(0);
| 362 |
rop->rmp->ncomp = rop->preop.clen / rop->imx.ncomp;
| 363 |
if ((rop->rmp->ncomp > 3) & (rop->rmp->dtype <= DTspec)) {
| 364 |
rop->rmp->dtype = DTfloat; /* probably not actual spectrum */
| 365 |
| 366 |
| 367 |
} else if (rop->preop.nsf > 0) { /* else use scalar(s)? */
| 368 |
| 369 |
for (i = rop->rmp->ncomp; --i; )
| 370 |
rop->preop.sca[i] = rop->preop.sca[0];
| 371 |
rop->preop.nsf = rop->rmp->ncomp;
| 372 |
} else if (rop->preop.nsf != rop->rmp->ncomp) {
| 373 |
| 374 |
rop->inspec, rop->rmp->ncomp);
| 375 |
return(0);
| 376 |
| 377 |
| 378 |
return(1);
| 379 |
| 380 |
| 381 |
static int
| 382 |
apply_op(RMATRIX *dst, const RMATRIX *src, const RUNARYOP *ro)
| 383 |
| 384 |
if (ro->clen > 0) {
| 385 |
RMATRIX *res = rmx_transform(src, dst->ncomp, ro->cmat);
| 386 |
if (!res) {
| 387 |
fputs("Error in call to rmx_transform()\n", stderr);
| 388 |
return(0);
| 389 |
| 390 |
if (!rmx_transfer_data(dst, res, 0))
| 391 |
return(0);
| 392 |
rmx_free(res);
| 393 |
} else if (dst != src)
| 394 |
memcpy(dst->mtx, src->mtx,
| 395 |
sizeof(double)*dst->ncomp*dst->ncols*dst->nrows);
| 396 |
if (ro->nsf == dst->ncomp)
| 397 |
rmx_scale(dst, ro->sca);
| 398 |
return(1);
| 399 |
| 400 |
| 401 |
static int
| 402 |
open_input(ROPMAT *rop)
| 403 |
| 404 |
int outtype;
| 405 |
| 406 |
if (!rop || !rop->inspec || !rop->inspec[0])
| 407 |
return(0);
| 408 |
if (rop->inspec == stdin_name)
| 409 |
rop->infp = stdin;
| 410 |
else if (rop->inspec[0] == '!')
| 411 |
rop->infp = popen(rop->inspec+1, "r");
| 412 |
else
| 413 |
rop->infp = fopen(rop->inspec, "rb");
| 414 |
| 415 |
if (!rmx_load_header(&rop->imx, rop->infp)) {
| 416 |
fprintf(stderr, "Bad header from: %s\n", rop->inspec);
| 417 |
return(0);
| 418 |
| 419 |
return(get_component_xfm(rop));
| 420 |
| 421 |
| 422 |
/* Return nominal wavelength associated with input component (return nm) */
| 423 |
static double
| 424 |
l_wavelength(char *nam)
| 425 |
| 426 |
double comp = argument(1);
| 427 |
| 428 |
if ((comp < -.5) | (comp >= in_ncomp+.5)) {
| 429 |
errno = EDOM;
| 430 |
return(.0);
| 431 |
| 432 |
if (comp < .5) /* asking for #components? */
| 433 |
return(in_ncomp);
| 434 |
| 435 |
if (in_ncomp == 3) { /* special case for RGB */
| 436 |
const int w0 = (int)(comp - .5);
| 437 |
return(mop[0].rmp->wlpart[w0] +
| 438 |
(comp-.5)*(mop[0].rmp->wlpart[w0+1] -
| 439 |
mop[0].rmp->wlpart[w0]));
| 440 |
| 441 |
return(mop[0].rmp->wlpart[0] + /* general case, even div. */
| 442 |
(comp-.5)/(double)in_ncomp *
| 443 |
(mop[0].rmp->wlpart[3] - mop[0].rmp->wlpart[0]));
| 444 |
| 445 |
| 446 |
/* Return ith input with optional channel selector */
| 447 |
static double
| 448 |
l_chanin(char *nam)
| 449 |
| 450 |
double inp = argument(1);
| 451 |
int mi, chan;
| 452 |
| 453 |
if ((mi = (int)(inp-.5)) < 0 || mi >= nmats) {
| 454 |
errno = EDOM;
| 455 |
return(.0);
| 456 |
| 457 |
if (inp < .5) /* asking for #inputs? */
| 458 |
return(nmats);
| 459 |
| 460 |
if (nargum() >= 2) {
| 461 |
double cval = argument(2);
| 462 |
if (cval < .5 || (chan = (int)(cval-.5)) >= in_ncomp) {
| 463 |
errno = EDOM;
| 464 |
return(.0);
| 465 |
| 466 |
} else
| 467 |
chan = cur_chan;
| 468 |
| 469 |
return(mop[mi].rmp->mtx[cur_col*in_ncomp + chan]);
| 470 |
| 471 |
| 472 |
static int
| 473 |
initialize(RMATRIX *imp)
| 474 |
| 475 |
int i;
| 476 |
/* XXX struct is zeroed coming in */
| 477 |
setcolor(imp->cexp, 1.f, 1.f, 1.f);
| 478 |
for (i = 0; i < nmats; i++) { /* open each input */
| 479 |
int restype;
| 480 |
if (!open_input(&mop[i]))
| 481 |
return(0);
| 482 |
restype = mop[i].rmp->dtype;
| 483 |
if (!imp->dtype || (restype = rmx_newtype(restype, imp->dtype)) > 0)
| 484 |
imp->dtype = restype;
| 485 |
else
| 486 |
fprintf(stderr, "%s: warning - data type mismatch\n",
| 487 |
mop[i].inspec);
| 488 |
if (!i) {
| 489 |
imp->ncols = mop[0].rmp->ncols;
| 490 |
imp->ncomp = mop[0].rmp->ncomp;
| 491 |
memcpy(imp->wlpart, mop[0].rmp->wlpart, sizeof(imp->wlpart));
| 492 |
} else if ((mop[i].rmp->ncols != imp->ncols) |
| 493 |
(mop[i].rmp->ncomp != imp->ncomp) |
| 494 |
((in_nrows > 0) & (mop[i].rmp->nrows > 0) &
| 495 |
(mop[i].rmp->nrows != in_nrows))) {
| 496 |
fprintf(stderr, "%s: mismatch in size or #components\n",
| 497 |
mop[i].inspec);
| 498 |
return(0);
| 499 |
} /* XXX should check wlpart? */
| 500 |
if (in_nrows <= 0)
| 501 |
in_nrows = imp->nrows = mop[i].rmp->nrows;
| 502 |
} /* set up .cal environment */
| 503 |
esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
| 504 |
esupport &= ~(E_OUTCHAN|E_INCHAN);
| 505 |
varset("PI", ':', M_PI);
| 506 |
varset("nfiles", ':', nmats);
| 507 |
varset("nrows", ':', in_nrows);
| 508 |
varset("ncols", ':', in_ncols);
| 509 |
varset("ncomp", ':', in_ncomp);
| 510 |
varset("R", ':', 1.);
| 511 |
varset("G", ':', 2.);
| 512 |
varset("B", ':', 3.);
| 513 |
funset("wl", 1, ':', l_wavelength);
| 514 |
funset("ci", 1, '=', l_chanin);
| 515 |
scompile("ri(i)=ci(i,R);gi(i)=ci(i,G);bi(i)=ci(i,B)", NULL, 0);
| 516 |
return(1);
| 517 |
| 518 |
| 519 |
static void
| 520 |
output_headinfo(FILE *fp)
| 521 |
| 522 |
int i;
| 523 |
| 524 |
| 525 |
const char *cp = mop[i].imx.info;
| 526 |
fputs(mop[i].inspec, fp);
| 527 |
fputs(":\n", fp);
| 528 |
if (!cp) continue;
| 529 |
while (*cp) {
| 530 |
if (*cp == '\n') {
| 531 |
cp++; /* avoid inadvertant terminus */
| 532 |
continue;
| 533 |
| 534 |
fputc('\t', fp); /* indent this input's info */
| 535 |
do
| 536 |
putc(*cp, fp);
| 537 |
while (*cp++ != '\n');
| 538 |
| 539 |
| 540 |
| 541 |
| 542 |
static int
| 543 |
combine_input(ROPMAT *res, FILE *fout)
| 544 |
| 545 |
int set_r, set_c;
| 546 |
RMATRIX *tmp = NULL;
| 547 |
int co_set;
| 548 |
int i;
| 549 |
/* allocate input row buffers */
| 550 |
| 551 |
mop[i].imx.nrows = 1; /* we'll be doing a row at a time */
| 552 |
if (!rmx_prepare(&mop[i].imx))
| 553 |
goto memerror;
| 554 |
if (mop[i].rmp != &mop[i].imx) {
| 555 |
mop[i].rmp->nrows = 1;
| 556 |
if (!rmx_prepare(mop[i].rmp))
| 557 |
goto memerror;
| 558 |
| 559 |
| 560 |
/* prep output row buffers */
| 561 |
if (mcat || res->preop.clen > 0) {
| 562 |
if (!split_input(res)) /* need separate buffer */
| 563 |
return(0);
| 564 |
if (res->preop.clen > 0)
| 565 |
res->rmp->ncomp = res->preop.clen / res->imx.ncomp;
| 566 |
res->rmp->nrows = 1;
| 567 |
if (!mcat | !mcat_last && !rmx_prepare(res->rmp))
| 568 |
goto memerror;
| 569 |
| 570 |
if (mcat && mcat_last &&
| 571 |
!(tmp = rmx_alloc(1, res->imx.ncols, res->rmp->ncomp)))
| 572 |
goto memerror;
| 573 |
res->imx.nrows = 1;
| 574 |
if (!rmx_prepare(&res->imx))
| 575 |
goto memerror;
| 576 |
/* figure out what the user set */
| 577 |
co_set = fundefined("co");
| 578 |
if (!co_set)
| 579 |
co_set = -vardefined("co");
| 580 |
if (!co_set & (in_ncomp == 3) && vardefined("ro") &&
| 581 |
vardefined("go") && vardefined("bo")) {
| 582 |
scompile("co(p)=select(p,ro,go,bo)", NULL, 0);
| 583 |
co_set = 1;
| 584 |
| 585 |
if (co_set) { /* set if user wants, didn't set */
| 586 |
set_r = varlookup("r") != NULL && !vardefined("r");
| 587 |
set_c = varlookup("c") != NULL && !vardefined("c");
| 588 |
} else /* save a little time */
| 589 |
set_r = set_c = 0;
| 590 |
/* read/process row-by-row */
| 591 |
for (cur_row = 0; (in_nrows <= 0) | (cur_row < in_nrows); cur_row++) {
| 592 |
RMATRIX *mres = NULL;
| 593 |
| 594 |
if (!rmx_load_row(mop[i].imx.mtx, &mop[i].imx, mop[i].infp)) {
| 595 |
if (cur_row > in_nrows) /* unknown #input rows? */
| 596 |
goto loop_exit;
| 597 |
fprintf(stderr, "%s: read error at row %d\n",
| 598 |
mop[i].inspec, cur_row);
| 599 |
return(0);
| 600 |
| 601 |
if (!apply_op(mop[i].rmp, &mop[i].imx, &mop[i].preop))
| 602 |
return(0);
| 603 |
| 604 |
if (set_r) varset("r", '=', cur_row);
| 605 |
for (cur_col = 0; cur_col < in_ncols; cur_col++) {
| 606 |
if (set_c) varset("c", '=', cur_col);
| 607 |
for (cur_chan = 0; cur_chan < in_ncomp; cur_chan++) {
| 608 |
const int ndx = cur_col*in_ncomp + cur_chan;
| 609 |
eclock++;
| 610 |
if (!co_set) { /* just summing elements? */
| 611 |
res->imx.mtx[ndx] = 0;
| 612 |
for (i = nmats; i--; )
| 613 |
res->imx.mtx[ndx] += mop[i].rmp->mtx[ndx];
| 614 |
} else if (co_set > 0) {
| 615 |
double dchan = cur_chan+1;
| 616 |
res->imx.mtx[ndx] = funvalue("co", 1, &dchan);
| 617 |
} else
| 618 |
res->imx.mtx[ndx] = varvalue("co");
| 619 |
| 620 |
} /* final conversions */
| 621 |
if (!mcat) {
| 622 |
if (!apply_op(res->rmp, &res->imx, &res->preop))
| 623 |
return(0);
| 624 |
} else if (mcat_last) {
| 625 |
if (!apply_op(tmp, &res->imx, &res->preop))
| 626 |
return(0);
| 627 |
mres = rmx_multiply(tmp, mcat);
| 628 |
if (!mres)
| 629 |
goto multerror;
| 630 |
if (!rmx_transfer_data(res->rmp, mres, 0))
| 631 |
return(0);
| 632 |
} else /* mcat && !mcat_last */ {
| 633 |
mres = rmx_multiply(&res->imx, mcat);
| 634 |
if (!mres)
| 635 |
goto multerror;
| 636 |
if (!apply_op(res->rmp, mres, &res->preop))
| 637 |
return(0);
| 638 |
| 639 |
rmx_free(mres); mres = NULL;
| 640 |
if (!rmx_write_data(res->rmp->mtx, res->rmp->ncomp,
| 641 |
res->rmp->ncols, res->rmp->dtype, fout))
| 642 |
return(0);
| 643 |
| 644 |
loop_exit:
| 645 |
#if 0 /* we're about to exit, so who cares? */
| 646 |
rmx_free(tmp); /* clean up */
| 647 |
rmx_reset(res->rmp);
| 648 |
rmx_reset(&res->imx);
| 649 |
| 650 |
rmx_reset(mop[i].rmp);
| 651 |
rmx_reset(&mop[i].imx);
| 652 |
if (mop[i].inspec[0] == '!')
| 653 |
pclose(mop[i].infp);
| 654 |
else if (mop[i].inspec != stdin_name)
| 655 |
fclose(mop[i].infp);
| 656 |
mop[i].infp = NULL;
| 657 |
| 658 |
#endif
| 659 |
return(fflush(fout) != EOF);
| 660 |
memerror:
| 661 |
fputs("Out of buffer space in combine_input()\n", stderr);
| 662 |
return(0);
| 663 |
multerror:
| 664 |
fputs("Unexpected matrix multiply error in combine_input()\n", stderr);
| 665 |
return(0);
| 666 |
| 667 |
| 668 |
static int
| 669 |
get_factors(double da[], int n, char *av[])
| 670 |
| 671 |
int ac;
| 672 |
| 673 |
for (ac = 0; ac < n && isflt(av[ac]); ac++)
| 674 |
da[ac] = atof(av[ac]);
| 675 |
return(ac);
| 676 |
| 677 |
| 678 |
static void
| 679 |
resize_inparr(int n2alloc)
| 680 |
| 681 |
int i;
| 682 |
| 683 |
for (i = nmats; i > n2alloc; i--) {
| 684 |
| 685 |
| 686 |
rmx_free(mop[i].rmp);
| 687 |
| 688 |
mop = (ROPMAT *)realloc(mop, n2alloc*sizeof(ROPMAT));
| 689 |
if (mop == NULL) {
| 690 |
fputs("Out of memory in resize_inparr()\n", stderr);
| 691 |
exit(1);
| 692 |
| 693 |
if (n2alloc > nmats)
| 694 |
memset(mop+nmats, 0, (n2alloc-nmats)*sizeof(ROPMAT));
| 695 |
nall = n2alloc;
| 696 |
| 697 |
| 698 |
/* Load one or more matrices and operate on them, sending results to stdout */
| 699 |
int
| 700 |
main(int argc, char *argv[])
| 701 |
| 702 |
| 703 |
int outfmt = DTfromHeader;
| 704 |
const char *defCsym = NULL;
| 705 |
int echoheader = 1;
| 706 |
int stdin_used = 0;
| 707 |
const char *mcat_spec = NULL;
| 708 |
int n2comp = 0;
| 709 |
uby8 comp_ndx[128];
| 710 |
int i;
| 711 |
/* get starting input array */
| 712 |
mop = (ROPMAT *)calloc(nall=2, sizeof(ROPMAT));
| 713 |
/* get options and arguments */
| 714 |
for (i = 1; i < argc; i++)
| 715 |
if (argv[i][0] != '-' || !argv[i][1]) {
| 716 |
if (argv[i][0] == '-') {
| 717 |
if (stdin_used++) goto stdin_error;
| 718 |
mop[nmats].inspec = stdin_name;
| 719 |
} else
| 720 |
mop[nmats].inspec = argv[i];
| 721 |
if (!mop[nmats].preop.csym)
| 722 |
mop[nmats].preop.csym = defCsym;
| 723 |
if (++nmats >= nall)
| 724 |
resize_inparr(nmats + (nmats>>2) + 2);
| 725 |
} else {
| 726 |
int n = argc-1 - i;
| 727 |
switch (argv[i][1]) { /* get option */
| 728 |
case 'w':
| 729 |
nowarn = !nowarn;
| 730 |
break;
| 731 |
case 'h':
| 732 |
echoheader = !echoheader;
| 733 |
break;
| 734 |
case 'e':
| 735 |
if (!n) goto userr;
| 736 |
comp_ndx[n2comp++] = i++;
| 737 |
break;
| 738 |
case 'f':
| 739 |
switch (argv[i][2]) {
| 740 |
case '\0':
| 741 |
if (!n) goto userr;
| 742 |
| 743 |
break;
| 744 |
case 'd':
| 745 |
outfmt = DTdouble;
| 746 |
break;
| 747 |
case 'f':
| 748 |
outfmt = DTfloat;
| 749 |
break;
| 750 |
case 'a':
| 751 |
outfmt = DTascii;
| 752 |
break;
| 753 |
case 'c':
| 754 |
outfmt = DTrgbe;
| 755 |
break;
| 756 |
default:
| 757 |
goto userr;
| 758 |
| 759 |
break;
| 760 |
case 's':
| 761 |
if (n > MAXCOMP) n = MAXCOMP;
| 762 |
i += mop[nmats].preop.nsf =
| 763 |
get_factors(mop[nmats].preop.sca,
| 764 |
n, argv+i+1);
| 765 |
if (mop[nmats].preop.nsf <= 0) {
| 766 |
fprintf(stderr, "%s: -s missing arguments\n",
| 767 |
argv[0]);
| 768 |
goto userr;
| 769 |
| 770 |
break;
| 771 |
case 'C':
| 772 |
if (!n || isflt(argv[i+1]))
| 773 |
goto userr;
| 774 |
defCsym = mop[nmats].preop.csym = argv[++i];
| 775 |
mop[nmats].preop.clen = 0;
| 776 |
mcat_last = 0;
| 777 |
break;
| 778 |
case 'c':
| 779 |
if (n && !isflt(argv[i+1])) {
| 780 |
| 781 |
| 782 |
break;
| 783 |
| 784 |
if (n > MAXCOMP*MAXCOMP) n = MAXCOMP*MAXCOMP;
| 785 |
i += mop[nmats].preop.clen =
| 786 |
get_factors(mop[nmats].preop.cmat,
| 787 |
n, argv+i+1);
| 788 |
if (mop[nmats].preop.clen <= 0) {
| 789 |
fprintf(stderr, "%s: -c missing arguments\n",
| 790 |
argv[0]);
| 791 |
goto userr;
| 792 |
| 793 |
mop[nmats].preop.csym = NULL;
| 794 |
mcat_last = 0;
| 795 |
break;
| 796 |
case 'm':
| 797 |
if (!n) goto userr;
| 798 |
if (argv[++i][0] == '-' && !argv[i][1]) {
| 799 |
| 800 |
mcat_spec = stdin_name;
| 801 |
} else
| 802 |
mcat_spec = argv[i];
| 803 |
mcat_last = 1;
| 804 |
break;
| 805 |
default:
| 806 |
fprintf(stderr, "%s: unknown option '%s'\n",
| 807 |
argv[0], argv[i]);
| 808 |
goto userr;
| 809 |
| 810 |
| 811 |
if (!nmats) {
| 812 |
fprintf(stderr, "%s: need at least one input matrix\n", argv[0]);
| 813 |
goto userr;
| 814 |
| 815 |
resize_inparr(nmats+1); /* extra matrix at end for result */
| 816 |
mop[nmats].inspec = "trailing_ops";
| 817 |
/* load final concatenation matrix */
| 818 |
if (mcat_spec && !(mcat = rmx_load(mcat_spec, RMPnone))) {
| 819 |
fprintf(stderr, "%s: error loading concatenation matrix: %s\n",
| 820 |
argv[0], mcat_spec);
| 821 |
return(1);
| 822 |
| 823 |
/* get/check inputs, set constants */
| 824 |
if (!initialize(&mop[nmats].imx))
| 825 |
return(1);
| 826 |
| 827 |
for (i = 0; i < n2comp; i++) /* user .cal files and expressions */
| 828 |
if (argv[comp_ndx[i]][1] == 'f') {
| 829 |
char *fpath = getpath(argv[comp_ndx[i]+1],
| 830 |
getrlibpath(), 0);
| 831 |
if (fpath == NULL) {
| 832 |
fprintf(stderr, "%s: cannot find file '%s'\n",
| 833 |
argv[0], argv[comp_ndx[i]+1]);
| 834 |
return(1);
| 835 |
| 836 |
fcompile(fpath);
| 837 |
} else /* (argv[comp_ndx[i]][1] == 'e') */
| 838 |
scompile(argv[comp_ndx[i]+1], NULL, 0);
| 839 |
| 840 |
/* get trailing color transform */
| 841 |
if (!get_component_xfm(&mop[nmats]))
| 842 |
return(1);
| 843 |
/* adjust output dimensions and #components */
| 844 |
if (mcat) {
| 845 |
if (mop[nmats].imx.ncols != mcat->nrows) {
| 846 |
fprintf(stderr,
| 847 |
"%s: number of input columns does not match number of rows in '%s'\n",
| 848 |
| 849 |
return(1);
| 850 |
| 851 |
if (mcat->ncomp != (mcat_last ? mop[nmats].rmp->ncomp : mop[nmats].imx.ncomp)) {
| 852 |
fprintf(stderr,
| 853 |
"%s: number of components does not match those in '%s'\n",
| 854 |
| 855 |
return(1);
| 856 |
| 857 |
if (!split_input(&mop[nmats]))
| 858 |
return(1);
| 859 |
mop[nmats].rmp->ncols = mcat->ncols;
| 860 |
| 861 |
newheader("RADIANCE", stdout); /* write output header */
| 862 |
if (echoheader)
| 863 |
output_headinfo(stdout);
| 864 |
printargs(argc, argv, stdout);
| 865 |
fputnow(stdout);
| 866 |
mop[nmats].rmp->dtype = rmx_write_header(mop[nmats].rmp, outfmt, stdout);
| 867 |
if (!mop[nmats].rmp->dtype) {
| 868 |
fprintf(stderr, "%s: unsupported output format\n", argv[0]);
| 869 |
return(1);
| 870 |
| 871 |
/* process & write rows */
| 872 |
return(combine_input(&mop[nmats], stdout) ? 0 : 1);
| 873 |
stdin_error:
| 874 |
fprintf(stderr, "%s: %s used for more than one input\n",
| 875 |
argv[0], stdin_name);
| 876 |
return(1);
| 877 |
userr:
| 878 |
fprintf(stderr,
| 879 |
"Usage: %s [-h][-f{adfc}][-e expr][-f file][-s sf .. | -c ce ..] m1 .. -m mcat > mres\n",
| 880 |
argv[0]);
| 881 |
return(1);
| 882 |
