| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rcomb.c,v 2.15 2024/05/23 01:28:07 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* General component matrix combiner, operating on a row at a time.
| 6 |
| 7 |
| 8 |
#include <math.h>
| 9 |
#include "platform.h"
| 10 |
#include "rtprocess.h"
| 11 |
#include "rtio.h"
| 12 |
#include "rmatrix.h"
| 13 |
#include "calcomp.h"
| 14 |
| 15 |
#ifndef M_PI
| 16 |
#define M_PI 3.14159265358979323846
| 17 |
#endif
| 18 |
| 19 |
#define MAXCOMP MAXCSAMP /* #components we support */
| 20 |
| 21 |
/* Unary matrix operation(s) */
| 22 |
typedef struct {
| 23 |
double cmat[MAXCOMP*MAXCOMP]; /* component transformation */
| 24 |
double sca[MAXCOMP]; /* scalar coefficients */
| 25 |
const char *csym; /* symbolic coefficients */
| 26 |
short clen; /* number of coefficients */
| 27 |
short nsf; /* number of scalars */
| 28 |
} RUNARYOP;
| 29 |
| 30 |
/* Input matrix */
| 31 |
typedef struct {
| 32 |
const char *inspec; /* input specification */
| 33 |
RUNARYOP preop; /* transform operation */
| 34 |
RMATRIX imx; /* input matrix header info */
| 35 |
RMATRIX *rmp; /* active single-row matrix */
| 36 |
FILE *infp; /* open input stream */
| 37 |
} ROPMAT;
| 38 |
| 39 |
ROPMAT *mop = NULL; /* allocated input array */
| 40 |
int nall = 0; /* number allocated */
| 41 |
int nmats = 0; /* number of actual inputs */
| 42 |
| 43 |
RMATRIX *mcat = NULL; /* final concatenation */
| 44 |
int mcat_last = 0; /* goes after trailing ops? */
| 45 |
| 46 |
int in_nrows; /* number of input rows (or 0) */
| 47 |
#define in_ncols (mop[0].rmp->ncols) /* number of input columns */
| 48 |
#define in_ncomp (mop[0].rmp->ncomp) /* input #components */
| 49 |
| 50 |
extern int nowarn; /* turn off warnings? */
| 51 |
| 52 |
int cur_row; /* current input/output row */
| 53 |
int cur_col; /* current input/output column */
| 54 |
int cur_chan; /* if we're looping channels */
| 55 |
| 56 |
SUBPROC *cproc = NULL; /* child process array */
| 57 |
int nchildren = 0; /* # of child processes */
| 58 |
int inchild = -1; /* our child ID (-1: parent) */
| 59 |
| 60 |
static int checksymbolic(ROPMAT *rop);
| 61 |
| 62 |
static int
| 63 |
split_input(ROPMAT *rop)
| 64 |
| 65 |
if (rop->rmp == &rop->imx && !(rop->rmp = rmx_copy(&rop->imx))) {
| 66 |
fputs("Out of memory in split_input()\n", stderr);
| 67 |
return(0);
| 68 |
| 69 |
rmx_reset(rop->rmp);
| 70 |
return(1);
| 71 |
| 72 |
| 73 |
/* Check/set transform based on a reference input file */
| 74 |
static int
| 75 |
checkreffile(ROPMAT *rop)
| 76 |
| 77 |
static const char *curRF = NULL;
| 78 |
static RMATRIX refm;
| 79 |
const int nc = rop->imx.ncomp;
| 80 |
int i;
| 81 |
| 82 |
if (!curRF || strcmp(rop->preop.csym, curRF)) {
| 83 |
FILE *fp = fopen(rop->preop.csym, "rb");
| 84 |
if (!rmx_load_header(&refm, fp)) {
| 85 |
fprintf(stderr, "%s: cannot read info header\n",
| 86 |
rop->preop.csym);
| 87 |
curRF = NULL;
| 88 |
if (fp) fclose(fp);
| 89 |
return(0);
| 90 |
| 91 |
fclose(fp);
| 92 |
curRF = rop->preop.csym;
| 93 |
| 94 |
if (refm.ncomp == 3) {
| 95 |
rop->preop.csym = (refm.dtype == DTxyze) ? "XYZ" : "RGB";
| 96 |
return(checksymbolic(rop));
| 97 |
| 98 |
if (refm.ncomp == 2) {
| 99 |
fprintf(stderr, "%s: cannot convert to 2 components\n",
| 100 |
curRF);
| 101 |
return(0);
| 102 |
| 103 |
if (refm.ncomp == 1) {
| 104 |
rop->preop.csym = "Y"; /* XXX big assumption */
| 105 |
| 106 |
| 107 |
if (refm.ncomp == nc &&
| 108 |
!memcmp(refm.wlpart, rop->imx.wlpart, sizeof(refm.wlpart)))
| 109 |
return(1); /* nothing to do */
| 110 |
| 111 |
if ((nc <= 3) | (nc > MAXCSAMP) | (refm.ncomp > MAXCSAMP)) {
| 112 |
fprintf(stderr, "%s: cannot resample from %d to %d components\n",
| 113 |
curRF, nc, refm.ncomp);
| 114 |
return(0);
| 115 |
| 116 |
if (!split_input(rop)) /* get our own struct */
| 117 |
return(0);
| 118 |
rop->preop.clen = refm.ncomp * nc; /* compute spec to ref */
| 119 |
| 120 |
for (i = 0; i < nc; i++) {
| 121 |
SCOLOR scstim, scresp;
| 122 |
int j;
| 123 |
memset(scstim, 0, sizeof(COLORV)*nc);
| 124 |
scstim[i] = 1.f;
| 125 |
convertscolor(scresp, refm.ncomp, refm.wlpart[0], refm.wlpart[3],
| 126 |
scstim, nc, rop->imx.wlpart[0], rop->imx.wlpart[3]);
| 127 |
for (j = refm.ncomp; j-- > 0; )
| 128 |
rop->preop.cmat[j*nc + i] = scresp[j];
| 129 |
| 130 |
/* remember new spectral params */
| 131 |
memcpy(rop->rmp->wlpart, refm.wlpart, sizeof(rop->rmp->wlpart));
| 132 |
rop->rmp->ncomp = refm.ncomp;
| 133 |
return(1);
| 134 |
| 135 |
| 136 |
/* Compute conversion row from spectrum to one channel of RGB */
| 137 |
static void
| 138 |
rgbrow(ROPMAT *rop, int r, int p)
| 139 |
| 140 |
| 141 |
const float * wlp = rop->imx.wlpart;
| 142 |
int i;
| 143 |
| 144 |
for (i = nc; i--; ) {
| 145 |
int nmEnd = wlp[0] + (wlp[3] - wlp[0])*i/nc;
| 146 |
int nmStart = wlp[0] + (wlp[3] - wlp[0])*(i+1)/nc;
| 147 |
COLOR crgb;
| 148 |
spec_rgb(crgb, nmStart, nmEnd);
| 149 |
rop->preop.cmat[r*nc+i] = crgb[p];
| 150 |
| 151 |
| 152 |
| 153 |
/* Compute conversion row from spectrum to one channel of XYZ */
| 154 |
static void
| 155 |
xyzrow(ROPMAT *rop, int r, int p)
| 156 |
| 157 |
| 158 |
| 159 |
int i;
| 160 |
| 161 |
| 162 |
| 163 |
| 164 |
COLOR cxyz;
| 165 |
spec_cie(cxyz, nmStart, nmEnd);
| 166 |
rop->preop.cmat[r*nc+i] = cxyz[p];
| 167 |
| 168 |
| 169 |
| 170 |
/* Use the spectral sensitivity function to compute matrix coefficients */
| 171 |
static void
| 172 |
sensrow(ROPMAT *rop, int r, double (*sf)(SCOLOR sc, int ncs, const float wlpt[4]))
| 173 |
| 174 |
| 175 |
int i;
| 176 |
| 177 |
| 178 |
SCOLOR sclr;
| 179 |
memset(sclr, 0, sizeof(COLORV)*nc);
| 180 |
sclr[i] = 1.f;
| 181 |
rop->preop.cmat[r*nc+i] = (*sf)(sclr, nc, rop->imx.wlpart);
| 182 |
| 183 |
| 184 |
| 185 |
/* Check/set symbolic transform */
| 186 |
static int
| 187 |
| 188 |
| 189 |
| 190 |
const int dt = rop->imx.dtype;
| 191 |
double cf = 1;
| 192 |
int i, j;
| 193 |
/* check suffix => reference file */
| 194 |
if (strchr(rop->preop.csym, '.') > rop->preop.csym)
| 195 |
return(checkreffile(rop));
| 196 |
| 197 |
if (nc < 3) {
| 198 |
fprintf(stderr, "%s: -c '%s' requires at least 3 components\n",
| 199 |
rop->inspec, rop->preop.csym);
| 200 |
return(0);
| 201 |
| 202 |
rop->preop.clen = strlen(rop->preop.csym) * nc;
| 203 |
if (rop->preop.clen > MAXCOMP*MAXCOMP) {
| 204 |
fprintf(stderr, "%s: -c '%s' results in too many components\n",
| 205 |
| 206 |
return(0);
| 207 |
| 208 |
for (j = 0; rop->preop.csym[j]; j++) {
| 209 |
int comp = 0;
| 210 |
switch (rop->preop.csym[j]) {
| 211 |
case 'B':
| 212 |
case 'b':
| 213 |
++comp;
| 214 |
/* fall through */
| 215 |
case 'G':
| 216 |
case 'g':
| 217 |
++comp;
| 218 |
/* fall through */
| 219 |
case 'R':
| 220 |
case 'r':
| 221 |
if (rop->preop.csym[j] <= 'Z')
| 222 |
cf = 1./WHTEFFICACY;
| 223 |
if (dt == DTxyze) {
| 224 |
for (i = 3; i--; )
| 225 |
rop->preop.cmat[j*nc+i] = cf*xyz2rgbmat[comp][i];
| 226 |
} else if (nc == 3)
| 227 |
rop->preop.cmat[j*nc+comp] = 1.;
| 228 |
else
| 229 |
rgbrow(rop, j, comp);
| 230 |
break;
| 231 |
case 'Z':
| 232 |
case 'z':
| 233 |
++comp;
| 234 |
/* fall through */
| 235 |
case 'Y':
| 236 |
case 'y':
| 237 |
++comp;
| 238 |
/* fall through */
| 239 |
case 'X':
| 240 |
case 'x':
| 241 |
if ((rop->preop.csym[j] <= 'Z') & (dt != DTxyze))
| 242 |
cf = WHTEFFICACY;
| 243 |
if (dt == DTxyze) {
| 244 |
| 245 |
} else if (nc == 3) {
| 246 |
for (i = 3; i--; )
| 247 |
| 248 |
rgb2xyzmat[comp][i];
| 249 |
} else if (comp == CIEY)
| 250 |
sensrow(rop, j, scolor2photopic);
| 251 |
else
| 252 |
xyzrow(rop, j, comp);
| 253 |
| 254 |
for (i = nc*(cf != 1); i--; )
| 255 |
rop->preop.cmat[j*nc+i] *= cf;
| 256 |
break;
| 257 |
case 'S': /* scotopic (il)luminance */
| 258 |
cf = WHTSCOTOPIC;
| 259 |
/* fall through */
| 260 |
case 's':
| 261 |
sensrow(rop, j, scolor2scotopic);
| 262 |
| 263 |
| 264 |
break;
| 265 |
case 'M': /* melanopic (il)luminance */
| 266 |
cf = WHTMELANOPIC;
| 267 |
/* fall through */
| 268 |
case 'm':
| 269 |
sensrow(rop, j, scolor2melanopic);
| 270 |
| 271 |
| 272 |
break;
| 273 |
case 'A': /* average component */
| 274 |
case 'a':
| 275 |
for (i = nc; i--; )
| 276 |
rop->preop.cmat[j*nc+i] = 1./(double)nc;
| 277 |
break;
| 278 |
default:
| 279 |
fprintf(stderr, "%s: -c '%c' unsupported\n",
| 280 |
rop->inspec, rop->preop.csym[j]);
| 281 |
return(0);
| 282 |
| 283 |
| 284 |
| 285 |
return(0);
| 286 |
memcpy(rop->rmp->wlpart, WLPART, sizeof(rop->rmp->wlpart));
| 287 |
rop->rmp->ncomp = rop->preop.clen / nc;
| 288 |
/* decide on output type */
| 289 |
if (!strcasecmp(rop->preop.csym, "XYZ")) {
| 290 |
if (dt <= DTspec)
| 291 |
rop->rmp->dtype = DTxyze;
| 292 |
} else if (!strcasecmp(rop->preop.csym, "RGB")) {
| 293 |
if (dt <= DTspec)
| 294 |
rop->rmp->dtype = DTrgbe;
| 295 |
} else if (rop->rmp->dtype == DTspec)
| 296 |
rop->rmp->dtype = DTfloat;
| 297 |
return(1);
| 298 |
| 299 |
| 300 |
static int
| 301 |
get_component_xfm(ROPMAT *rop)
| 302 |
| 303 |
int i, j;
| 304 |
| 305 |
if (rop->rmp != &rop->imx) { /* reset destination matrix */
| 306 |
rmx_free(rop->rmp);
| 307 |
rop->rmp = &rop->imx;
| 308 |
| 309 |
if (rop->preop.csym && /* symbolic transform? */
| 310 |
!checksymbolic(rop))
| 311 |
return(0);
| 312 |
/* undo exposure? */
| 313 |
if (fabs(1. - bright(rop->rmp->cexp)) > .025) {
| 314 |
if (rop->rmp->ncomp == 1)
| 315 |
rop->rmp->cexp[RED] = rop->rmp->cexp[GRN] =
| 316 |
rop->rmp->cexp[BLU] = bright(rop->rmp->cexp);
| 317 |
if (rop->preop.nsf <= 0) {
| 318 |
rop->preop.nsf = i = rop->rmp->ncomp;
| 319 |
while (i--)
| 320 |
rop->preop.sca[i] = 1.;
| 321 |
| 322 |
if (rop->preop.nsf == 1) {
| 323 |
if (rop->rmp->ncomp == 3) {
| 324 |
rop->preop.sca[2] = rop->preop.sca[1] =
| 325 |
rop->preop.sca[0];
| 326 |
rop->preop.nsf = 3;
| 327 |
} else
| 328 |
rop->preop.sca[0] /= bright(rop->rmp->cexp);
| 329 |
| 330 |
if (rop->preop.nsf == 3) {
| 331 |
opcolor(rop->preop.sca, /=, rop->rmp->cexp);
| 332 |
} else if (rop->preop.nsf > 3) { /* punt */
| 333 |
double mult = 1./bright(rop->rmp->cexp);
| 334 |
for (i = rop->preop.nsf; i--; )
| 335 |
rop->preop.sca[i] *= mult;
| 336 |
| 337 |
setcolor(rop->rmp->cexp, 1., 1., 1.);
| 338 |
| 339 |
if (rop->preop.clen > 0) { /* use component transform? */
| 340 |
if (rop->preop.clen % rop->imx.ncomp) {
| 341 |
fprintf(stderr, "%s: -c must have N x %d coefficients\n",
| 342 |
rop->inspec, rop->imx.ncomp);
| 343 |
return(0);
| 344 |
| 345 |
if (rop->preop.nsf > 0) { /* scale transform, instead */
| 346 |
| 347 |
for (i = rop->preop.clen; i--; )
| 348 |
rop->preop.cmat[i] *= rop->preop.sca[0];
| 349 |
} else if (rop->preop.nsf*rop->imx.ncomp != rop->preop.clen) {
| 350 |
fprintf(stderr, "%s: -s must have one or %d factors\n",
| 351 |
rop->inspec,
| 352 |
rop->preop.clen/rop->imx.ncomp);
| 353 |
return(0);
| 354 |
} else {
| 355 |
| 356 |
for (j = rop->imx.ncomp; j--; )
| 357 |
rop->preop.cmat[i*rop->imx.ncomp+j]
| 358 |
*= rop->preop.sca[i];
| 359 |
| 360 |
| 361 |
rop->preop.nsf = 0; /* now folded in */
| 362 |
| 363 |
return(0);
| 364 |
rop->rmp->ncomp = rop->preop.clen / rop->imx.ncomp;
| 365 |
if ((rop->rmp->ncomp > 3) & (rop->rmp->dtype <= DTspec)) {
| 366 |
rop->rmp->dtype = DTfloat; /* probably not actual spectrum */
| 367 |
| 368 |
| 369 |
} else if (rop->preop.nsf > 0) { /* else use scalar(s)? */
| 370 |
| 371 |
for (i = rop->rmp->ncomp; --i; )
| 372 |
rop->preop.sca[i] = rop->preop.sca[0];
| 373 |
rop->preop.nsf = rop->rmp->ncomp;
| 374 |
} else if (rop->preop.nsf != rop->rmp->ncomp) {
| 375 |
| 376 |
rop->inspec, rop->rmp->ncomp);
| 377 |
return(0);
| 378 |
| 379 |
| 380 |
return(1);
| 381 |
| 382 |
| 383 |
static int
| 384 |
apply_op(RMATRIX *dst, const RMATRIX *src, const RUNARYOP *ro)
| 385 |
| 386 |
if (ro->clen > 0) {
| 387 |
RMATRIX *res = rmx_transform(src, dst->ncomp, ro->cmat);
| 388 |
if (!res) {
| 389 |
fputs("Error in call to rmx_transform()\n", stderr);
| 390 |
return(0);
| 391 |
| 392 |
if (!rmx_transfer_data(dst, res, 0))
| 393 |
return(0);
| 394 |
rmx_free(res);
| 395 |
} else if (dst != src)
| 396 |
memcpy(dst->mtx, src->mtx, rmx_array_size(dst));
| 397 |
if (ro->nsf == dst->ncomp)
| 398 |
rmx_scale(dst, ro->sca);
| 399 |
return(1);
| 400 |
| 401 |
| 402 |
static int
| 403 |
open_input(ROPMAT *rop)
| 404 |
| 405 |
int outtype;
| 406 |
| 407 |
if (!rop || !rop->inspec || !rop->inspec[0])
| 408 |
return(0);
| 409 |
if (rop->inspec == stdin_name)
| 410 |
rop->infp = stdin;
| 411 |
else if (rop->inspec[0] == '!')
| 412 |
rop->infp = popen(rop->inspec+1, "r");
| 413 |
else
| 414 |
rop->infp = fopen(rop->inspec, "rb");
| 415 |
| 416 |
if (!rmx_load_header(&rop->imx, rop->infp)) {
| 417 |
fprintf(stderr, "Bad header from: %s\n", rop->inspec);
| 418 |
return(0);
| 419 |
| 420 |
return(get_component_xfm(rop));
| 421 |
| 422 |
| 423 |
/* Return nominal wavelength associated with input component (return nm) */
| 424 |
static double
| 425 |
l_wavelength(char *nam)
| 426 |
| 427 |
double comp = argument(1);
| 428 |
| 429 |
if ((comp < -.5) | (comp >= in_ncomp+.5)) {
| 430 |
errno = EDOM;
| 431 |
return(.0);
| 432 |
| 433 |
if (comp < .5) /* asking for #components? */
| 434 |
return(in_ncomp);
| 435 |
| 436 |
if (in_ncomp == 3) { /* special case for RGB */
| 437 |
const int w0 = (int)(comp - .5);
| 438 |
return(mop[0].rmp->wlpart[w0] +
| 439 |
(comp-.5)*(mop[0].rmp->wlpart[w0+1] -
| 440 |
mop[0].rmp->wlpart[w0]));
| 441 |
| 442 |
return(mop[0].rmp->wlpart[0] + /* general case, even div. */
| 443 |
(comp-.5)/(double)in_ncomp *
| 444 |
(mop[0].rmp->wlpart[3] - mop[0].rmp->wlpart[0]));
| 445 |
| 446 |
| 447 |
/* Return ith input with optional channel selector */
| 448 |
static double
| 449 |
l_chanin(char *nam)
| 450 |
| 451 |
double inp = argument(1);
| 452 |
int mi, chan;
| 453 |
| 454 |
if ((mi = (int)(inp-.5)) < 0 || mi >= nmats) {
| 455 |
errno = EDOM;
| 456 |
return(.0);
| 457 |
| 458 |
if (inp < .5) /* asking for #inputs? */
| 459 |
return(nmats);
| 460 |
| 461 |
if (nargum() >= 2) {
| 462 |
double cval = argument(2);
| 463 |
if (cval < .5 || (chan = (int)(cval-.5)) >= in_ncomp) {
| 464 |
errno = EDOM;
| 465 |
return(.0);
| 466 |
| 467 |
} else
| 468 |
chan = cur_chan;
| 469 |
| 470 |
return(mop[mi].rmp->mtx[cur_col*in_ncomp + chan]);
| 471 |
| 472 |
| 473 |
static int
| 474 |
initialize(RMATRIX *imp)
| 475 |
| 476 |
int i;
| 477 |
/* XXX struct is zeroed coming in */
| 478 |
setcolor(imp->cexp, 1.f, 1.f, 1.f);
| 479 |
for (i = 0; i < nmats; i++) { /* open each input */
| 480 |
int restype;
| 481 |
if (!open_input(&mop[i]))
| 482 |
return(0);
| 483 |
restype = mop[i].rmp->dtype;
| 484 |
if (!imp->dtype || (restype = rmx_newtype(restype, imp->dtype)) > 0)
| 485 |
imp->dtype = restype;
| 486 |
else
| 487 |
fprintf(stderr, "%s: warning - data type mismatch\n",
| 488 |
mop[i].inspec);
| 489 |
if (!i) {
| 490 |
imp->ncols = mop[0].rmp->ncols;
| 491 |
imp->ncomp = mop[0].rmp->ncomp;
| 492 |
memcpy(imp->wlpart, mop[0].rmp->wlpart, sizeof(imp->wlpart));
| 493 |
} else if ((mop[i].rmp->ncols != imp->ncols) |
| 494 |
(mop[i].rmp->ncomp != imp->ncomp) |
| 495 |
((in_nrows > 0) & (mop[i].rmp->nrows > 0) &
| 496 |
(mop[i].rmp->nrows != in_nrows))) {
| 497 |
fprintf(stderr, "%s: mismatch in size or #components\n",
| 498 |
mop[i].inspec);
| 499 |
return(0);
| 500 |
} /* XXX should check wlpart? */
| 501 |
if (in_nrows <= 0)
| 502 |
in_nrows = imp->nrows = mop[i].rmp->nrows;
| 503 |
} /* set up .cal environment */
| 504 |
esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
| 505 |
esupport &= ~(E_OUTCHAN|E_INCHAN);
| 506 |
varset("PI", ':', M_PI);
| 507 |
varset("nfiles", ':', nmats);
| 508 |
varset("nrows", ':', in_nrows);
| 509 |
varset("ncols", ':', in_ncols);
| 510 |
varset("ncomp", ':', in_ncomp);
| 511 |
varset("R", ':', 1.);
| 512 |
varset("G", ':', 2.);
| 513 |
varset("B", ':', 3.);
| 514 |
funset("wl", 1, ':', l_wavelength);
| 515 |
funset("ci", 1, '=', l_chanin);
| 516 |
scompile("ri(i)=ci(i,R);gi(i)=ci(i,G);bi(i)=ci(i,B)", NULL, 0);
| 517 |
return(1);
| 518 |
| 519 |
| 520 |
static void
| 521 |
output_headinfo(FILE *fp)
| 522 |
| 523 |
int i;
| 524 |
| 525 |
| 526 |
const char *cp = mop[i].imx.info;
| 527 |
fputs(mop[i].inspec, fp);
| 528 |
fputs(":\n", fp);
| 529 |
if (!cp) continue;
| 530 |
while (*cp) {
| 531 |
if (*cp == '\n') {
| 532 |
cp++; /* avoid inadvertant terminus */
| 533 |
continue;
| 534 |
| 535 |
fputc('\t', fp); /* indent this input's info */
| 536 |
do
| 537 |
putc(*cp, fp);
| 538 |
while (*cp++ != '\n');
| 539 |
| 540 |
| 541 |
| 542 |
| 543 |
static int
| 544 |
spawned_children(int np)
| 545 |
| 546 |
long inpwidth = 0;
| 547 |
int i, rv;
| 548 |
| 549 |
#if defined(_WIN32) || defined(_WIN64)
| 550 |
if (np > 1) {
| 551 |
fputs("Warning: only one process under Windows\n", stderr);
| 552 |
np = 1;
| 553 |
} else
| 554 |
#endif
| 555 |
if ((in_nrows > 0) & (np > in_nrows))
| 556 |
np = in_nrows;
| 557 |
/* we'll be doing a row at a time */
| 558 |
| 559 |
mop[i].imx.nrows = 1;
| 560 |
if (!rmx_prepare(&mop[i].imx))
| 561 |
goto memerror;
| 562 |
inpwidth += rmx_array_size(&mop[i].imx);
| 563 |
if (mop[i].rmp != &mop[i].imx) {
| 564 |
mop[i].rmp->nrows = 1;
| 565 |
if (!rmx_prepare(mop[i].rmp))
| 566 |
goto memerror;
| 567 |
inpwidth += rmx_array_size(mop[i].rmp);
| 568 |
| 569 |
| 570 |
/* prep output row buffer */
| 571 |
if (mcat || mop[nmats].preop.clen > 0) {
| 572 |
if (!split_input(&mop[nmats])) /* need separate buffer */
| 573 |
return(0);
| 574 |
if (mop[nmats].preop.clen > 0)
| 575 |
mop[nmats].rmp->ncomp = mop[nmats].preop.clen /
| 576 |
mop[nmats].imx.ncomp;
| 577 |
mop[nmats].rmp->nrows = 1;
| 578 |
if (!mcat | !mcat_last && !rmx_prepare(mop[nmats].rmp))
| 579 |
goto memerror;
| 580 |
| 581 |
mop[nmats].imx.nrows = 1;
| 582 |
if (!rmx_prepare(&mop[nmats].imx))
| 583 |
goto memerror;
| 584 |
if (np <= 1) { /* single process return point */
| 585 |
#ifdef getc_unlocked
| 586 |
| 587 |
flockfile(mop[i].infp);
| 588 |
flockfile(stdout);
| 589 |
#endif
| 590 |
return(0);
| 591 |
| 592 |
fflush(stdout); /* flush header & spawn children */
| 593 |
cproc = (SUBPROC *)malloc(sizeof(SUBPROC)*np);
| 594 |
if (!cproc)
| 595 |
goto memerror;
| 596 |
nchildren = np;
| 597 |
for (i = 0; i < np; i++) {
| 598 |
cproc[i].flags = PF_FILT_OUT;
| 599 |
cproc[i].w = dup(1);
| 600 |
cproc[i].r = 0;
| 601 |
cproc[i].pid = -1;
| 602 |
rv = open_process(&cproc[i], NULL);
| 603 |
if (rv <= 0) break;
| 604 |
if (!i && 2*rv >= inpwidth) {
| 605 |
fputs("Problem too small for multi-processing\n",
| 606 |
stderr);
| 607 |
exit(1);
| 608 |
| 609 |
| 610 |
if (rv > 0)
| 611 |
return(1); /* parent return value */
| 612 |
if (rv < 0) {
| 613 |
perror("fork");
| 614 |
exit(1);
| 615 |
| 616 |
inchild = i; /* our child index */
| 617 |
while (i-- > 0) /* don't share siblings' pipes */
| 618 |
close(cproc[i].w);
| 619 |
fpurge(stdin); /* discard previous matrix input */
| 620 |
| 621 |
flockfile(stdin);
| 622 |
#endif
| 623 |
| 624 |
if (mop[i].infp != stdin)
| 625 |
fclose(mop[i].infp); /* ! pclose() */
| 626 |
mop[i].infp = stdin;
| 627 |
mop[i].imx.dtype = DTdouble;
| 628 |
| 629 |
return(0); /* child return */
| 630 |
memerror:
| 631 |
fputs("Out of memory in spawned_children()\n", stderr);
| 632 |
exit(1);
| 633 |
| 634 |
| 635 |
static int
| 636 |
parent_loop()
| 637 |
| 638 |
FILE **outfp = (FILE **)malloc(nchildren*sizeof(FILE *));
| 639 |
int i;
| 640 |
| 641 |
if (!outfp) goto memerror;
| 642 |
for (i = 0; i < nchildren; i++) {
| 643 |
outfp[i] = fdopen(cproc[i].w, "w");
| 644 |
if (!outfp[i]) goto memerror;
| 645 |
| 646 |
flockfile(outfp[i]);
| 647 |
#endif
| 648 |
| 649 |
| 650 |
| 651 |
| 652 |
#endif
| 653 |
for (cur_row = 0; (in_nrows <= 0) | (cur_row < in_nrows); cur_row++) {
| 654 |
FILE *ofp = outfp[cur_row % nchildren];
| 655 |
| 656 |
if (!rmx_load_row(mop[i].imx.mtx, &mop[i].imx, mop[i].infp)) {
| 657 |
if (cur_row > in_nrows) /* unknown #input rows? */
| 658 |
break;
| 659 |
fprintf(stderr, "%s: read error at row %d\n",
| 660 |
mop[i].inspec, cur_row);
| 661 |
return(0);
| 662 |
| 663 |
if (i < nmats)
| 664 |
break;
| 665 |
| 666 |
if (!rmx_write_data(mop[i].imx.mtx, mop[i].imx.ncomp,
| 667 |
mop[i].imx.ncols, DTdouble, ofp))
| 668 |
return(0);
| 669 |
if (fflush(ofp) == EOF)
| 670 |
return(0);
| 671 |
| 672 |
| 673 |
sleep(2); /* try to maintain order */
| 674 |
fclose(outfp[i]);
| 675 |
| 676 |
free(outfp);
| 677 |
i = close_processes(cproc, nchildren);
| 678 |
free(cproc); cproc = NULL;
| 679 |
if (i < 0) {
| 680 |
fputs("Warning: missing child in parent_loop()\n", stderr);
| 681 |
return(1);
| 682 |
| 683 |
if (i > 0) {
| 684 |
fprintf(stderr, "Child exited with status %d\n", i);
| 685 |
return(0);
| 686 |
| 687 |
return(1);
| 688 |
memerror:
| 689 |
fputs("Out of memory in parent_loop()\n", stderr);
| 690 |
exit(1);
| 691 |
| 692 |
| 693 |
static int
| 694 |
combine_input()
| 695 |
| 696 |
const int row0 = (inchild >= 0)*inchild;
| 697 |
const int rstep = nchildren + !nchildren;
| 698 |
ROPMAT *res = &mop[nmats];
| 699 |
int set_r, set_c;
| 700 |
RMATRIX *tmp = NULL;
| 701 |
int co_set;
| 702 |
int i;
| 703 |
| 704 |
if (mcat && mcat_last &&
| 705 |
!(tmp = rmx_alloc(1, res->imx.ncols, res->rmp->ncomp)))
| 706 |
goto memerror;
| 707 |
/* figure out what the user set */
| 708 |
co_set = fundefined("co");
| 709 |
if (!co_set)
| 710 |
co_set = -vardefined("co");
| 711 |
if (!co_set & (in_ncomp == 3) && vardefined("ro") &&
| 712 |
vardefined("go") && vardefined("bo")) {
| 713 |
scompile("co(p)=select(p,ro,go,bo)", NULL, 0);
| 714 |
co_set = 1;
| 715 |
| 716 |
if (co_set) { /* set if user wants, didn't set */
| 717 |
set_r = varlookup("r") != NULL && !vardefined("r");
| 718 |
set_c = varlookup("c") != NULL && !vardefined("c");
| 719 |
} else /* save a little time */
| 720 |
set_r = set_c = 0;
| 721 |
| 722 |
/* read/process row-by-row */
| 723 |
for (cur_row = row0; (in_nrows <= 0) | (cur_row < in_nrows); cur_row += rstep) {
| 724 |
RMATRIX *mres = NULL;
| 725 |
| 726 |
| 727 |
| 728 |
break;
| 729 |
| 730 |
| 731 |
return(0);
| 732 |
| 733 |
if (i < nmats)
| 734 |
break;
| 735 |
| 736 |
if (!apply_op(mop[i].rmp, &mop[i].imx, &mop[i].preop))
| 737 |
return(0);
| 738 |
if (set_r) varset("r", '=', cur_row);
| 739 |
for (cur_col = 0; cur_col < in_ncols; cur_col++) {
| 740 |
if (set_c) varset("c", '=', cur_col);
| 741 |
for (cur_chan = 0; cur_chan < in_ncomp; cur_chan++) {
| 742 |
const int ndx = cur_col*in_ncomp + cur_chan;
| 743 |
eclock++;
| 744 |
if (!co_set) { /* just summing elements? */
| 745 |
res->imx.mtx[ndx] = 0;
| 746 |
for (i = nmats; i--; )
| 747 |
res->imx.mtx[ndx] += mop[i].rmp->mtx[ndx];
| 748 |
} else if (co_set > 0) {
| 749 |
double dchan = cur_chan+1;
| 750 |
res->imx.mtx[ndx] = funvalue("co", 1, &dchan);
| 751 |
} else
| 752 |
res->imx.mtx[ndx] = varvalue("co");
| 753 |
| 754 |
} /* final conversions */
| 755 |
if (!mcat) {
| 756 |
if (!apply_op(res->rmp, &res->imx, &res->preop))
| 757 |
return(0);
| 758 |
} else if (mcat_last) {
| 759 |
if (!apply_op(tmp, &res->imx, &res->preop))
| 760 |
return(0);
| 761 |
mres = rmx_multiply(tmp, mcat);
| 762 |
if (!mres)
| 763 |
goto multerror;
| 764 |
if (!rmx_transfer_data(res->rmp, mres, 0))
| 765 |
return(0);
| 766 |
} else /* mcat && !mcat_last */ {
| 767 |
mres = rmx_multiply(&res->imx, mcat);
| 768 |
if (!mres)
| 769 |
goto multerror;
| 770 |
if (!apply_op(res->rmp, mres, &res->preop))
| 771 |
return(0);
| 772 |
| 773 |
rmx_free(mres); mres = NULL;
| 774 |
if (inchild >= 0) { /* children share stdout */
| 775 |
i = getc(stdin); /* signals it's our turn */
| 776 |
if (i != EOF) ungetc(i, stdin);
| 777 |
| 778 |
if (!rmx_write_data(res->rmp->mtx, res->rmp->ncomp,
| 779 |
res->rmp->ncols, res->rmp->dtype, stdout))
| 780 |
return(0);
| 781 |
if (inchild >= 0 && fflush(stdout) == EOF)
| 782 |
return(0);
| 783 |
| 784 |
return(inchild >= 0 || fflush(stdout) != EOF);
| 785 |
memerror:
| 786 |
fputs("Out of buffer space in combine_input()\n", stderr);
| 787 |
return(0);
| 788 |
multerror:
| 789 |
fputs("Unexpected matrix multiply error in combine_input()\n", stderr);
| 790 |
return(0);
| 791 |
| 792 |
| 793 |
static int
| 794 |
get_factors(double da[], int n, char *av[])
| 795 |
| 796 |
int ac;
| 797 |
| 798 |
for (ac = 0; ac < n && isflt(av[ac]); ac++)
| 799 |
da[ac] = atof(av[ac]);
| 800 |
return(ac);
| 801 |
| 802 |
| 803 |
static void
| 804 |
resize_inparr(int n2alloc)
| 805 |
| 806 |
int i;
| 807 |
| 808 |
if (n2alloc == nall)
| 809 |
return;
| 810 |
for (i = nall; i > n2alloc; i--) {
| 811 |
rmx_reset(&mop[i].imx);
| 812 |
| 813 |
rmx_free(mop[i].rmp);
| 814 |
| 815 |
mop = (ROPMAT *)realloc(mop, n2alloc*sizeof(ROPMAT));
| 816 |
if (mop == NULL) {
| 817 |
fputs("Out of memory in resize_inparr()\n", stderr);
| 818 |
exit(1);
| 819 |
| 820 |
if (n2alloc > nall)
| 821 |
memset(mop+nall, 0, (n2alloc-nall)*sizeof(ROPMAT));
| 822 |
nall = n2alloc;
| 823 |
| 824 |
| 825 |
/* Load one or more matrices and operate on them, sending results to stdout */
| 826 |
int
| 827 |
main(int argc, char *argv[])
| 828 |
| 829 |
| 830 |
int outfmt = DTfromHeader;
| 831 |
const char *defCsym = NULL;
| 832 |
int echoheader = 1;
| 833 |
int stdin_used = 0;
| 834 |
int nproc = 1;
| 835 |
const char *mcat_spec = NULL;
| 836 |
int n2comp = 0;
| 837 |
uby8 comp_ndx[128];
| 838 |
int i;
| 839 |
/* get starting input array */
| 840 |
mop = (ROPMAT *)calloc(nall=2, sizeof(ROPMAT));
| 841 |
/* get options and arguments */
| 842 |
for (i = 1; i < argc; i++)
| 843 |
if (argv[i][0] != '-' || !argv[i][1]) {
| 844 |
if (argv[i][0] == '-') {
| 845 |
if (stdin_used++) goto stdin_error;
| 846 |
mop[nmats].inspec = stdin_name;
| 847 |
} else
| 848 |
mop[nmats].inspec = argv[i];
| 849 |
if (!mop[nmats].preop.csym)
| 850 |
mop[nmats].preop.csym = defCsym;
| 851 |
if (++nmats >= nall)
| 852 |
resize_inparr(nmats + (nmats>>2) + 2);
| 853 |
} else {
| 854 |
int n = argc-1 - i;
| 855 |
switch (argv[i][1]) { /* get option */
| 856 |
case 'w':
| 857 |
nowarn = !nowarn;
| 858 |
break;
| 859 |
case 'h':
| 860 |
echoheader = !echoheader;
| 861 |
break;
| 862 |
case 'n':
| 863 |
nproc = atoi(argv[++i]);
| 864 |
if (nproc <= 0)
| 865 |
goto userr;
| 866 |
break;
| 867 |
case 'e':
| 868 |
if (!n) goto userr;
| 869 |
comp_ndx[n2comp++] = i++;
| 870 |
break;
| 871 |
case 'f':
| 872 |
switch (argv[i][2]) {
| 873 |
case '\0':
| 874 |
if (!n) goto userr;
| 875 |
| 876 |
break;
| 877 |
case 'd':
| 878 |
outfmt = DTdouble;
| 879 |
break;
| 880 |
case 'f':
| 881 |
outfmt = DTfloat;
| 882 |
break;
| 883 |
case 'a':
| 884 |
outfmt = DTascii;
| 885 |
break;
| 886 |
case 'c':
| 887 |
outfmt = DTrgbe;
| 888 |
break;
| 889 |
default:
| 890 |
goto userr;
| 891 |
| 892 |
break;
| 893 |
case 's':
| 894 |
if (n > MAXCOMP) n = MAXCOMP;
| 895 |
i += mop[nmats].preop.nsf =
| 896 |
get_factors(mop[nmats].preop.sca,
| 897 |
n, argv+i+1);
| 898 |
if (mop[nmats].preop.nsf <= 0) {
| 899 |
fprintf(stderr, "%s: -s missing arguments\n",
| 900 |
argv[0]);
| 901 |
goto userr;
| 902 |
| 903 |
break;
| 904 |
case 'C':
| 905 |
if (!n || isflt(argv[i+1]))
| 906 |
goto userr;
| 907 |
defCsym = mop[nmats].preop.csym = argv[++i];
| 908 |
mop[nmats].preop.clen = 0;
| 909 |
mcat_last = 0;
| 910 |
break;
| 911 |
case 'c':
| 912 |
if (n && !isflt(argv[i+1])) {
| 913 |
| 914 |
| 915 |
mcat_last = 0;
| 916 |
break;
| 917 |
| 918 |
if (n > MAXCOMP*MAXCOMP) n = MAXCOMP*MAXCOMP;
| 919 |
i += mop[nmats].preop.clen =
| 920 |
get_factors(mop[nmats].preop.cmat,
| 921 |
n, argv+i+1);
| 922 |
if (mop[nmats].preop.clen <= 0) {
| 923 |
fprintf(stderr, "%s: -c missing arguments\n",
| 924 |
argv[0]);
| 925 |
goto userr;
| 926 |
| 927 |
mop[nmats].preop.csym = NULL;
| 928 |
mcat_last = 0;
| 929 |
break;
| 930 |
case 'm':
| 931 |
if (!n) goto userr;
| 932 |
if (argv[++i][0] == '-' && !argv[i][1]) {
| 933 |
| 934 |
mcat_spec = stdin_name;
| 935 |
} else
| 936 |
mcat_spec = argv[i];
| 937 |
mcat_last = 1;
| 938 |
break;
| 939 |
default:
| 940 |
fprintf(stderr, "%s: unknown option '%s'\n",
| 941 |
argv[0], argv[i]);
| 942 |
goto userr;
| 943 |
| 944 |
| 945 |
if (!nmats) {
| 946 |
fprintf(stderr, "%s: need at least one input matrix\n", argv[0]);
| 947 |
goto userr;
| 948 |
| 949 |
resize_inparr(nmats+1); /* extra matrix at end for result */
| 950 |
mop[nmats].inspec = "trailing_ops";
| 951 |
/* load final concatenation matrix */
| 952 |
if (mcat_spec && !(mcat = rmx_load(mcat_spec, RMPnone))) {
| 953 |
fprintf(stderr, "%s: error loading concatenation matrix: %s\n",
| 954 |
argv[0], mcat_spec);
| 955 |
return(1);
| 956 |
| 957 |
/* get/check inputs, set constants */
| 958 |
if (!initialize(&mop[nmats].imx))
| 959 |
return(1);
| 960 |
| 961 |
for (i = 0; i < n2comp; i++) /* user .cal files and expressions */
| 962 |
if (argv[comp_ndx[i]][1] == 'f') {
| 963 |
char *fpath = getpath(argv[comp_ndx[i]+1],
| 964 |
getrlibpath(), 0);
| 965 |
if (fpath == NULL) {
| 966 |
fprintf(stderr, "%s: cannot find file '%s'\n",
| 967 |
argv[0], argv[comp_ndx[i]+1]);
| 968 |
return(1);
| 969 |
| 970 |
fcompile(fpath);
| 971 |
} else /* (argv[comp_ndx[i]][1] == 'e') */
| 972 |
scompile(argv[comp_ndx[i]+1], NULL, 0);
| 973 |
| 974 |
/* get trailing color transform */
| 975 |
if (!get_component_xfm(&mop[nmats]))
| 976 |
return(1);
| 977 |
/* adjust output dimensions and #components */
| 978 |
if (mcat) {
| 979 |
if (mop[nmats].imx.ncols != mcat->nrows) {
| 980 |
fprintf(stderr,
| 981 |
"%s: number of input columns does not match number of rows in '%s'\n",
| 982 |
| 983 |
return(1);
| 984 |
| 985 |
if (mcat->ncomp != (mcat_last ? mop[nmats].rmp->ncomp : mop[nmats].imx.ncomp)) {
| 986 |
fprintf(stderr,
| 987 |
"%s: number of components does not match those in '%s'\n",
| 988 |
| 989 |
return(1);
| 990 |
| 991 |
| 992 |
return(1);
| 993 |
mop[nmats].rmp->ncols = mcat->ncols;
| 994 |
| 995 |
newheader("RADIANCE", stdout); /* write output header */
| 996 |
if (echoheader)
| 997 |
output_headinfo(stdout);
| 998 |
printargs(argc, argv, stdout);
| 999 |
fputnow(stdout);
| 1000 |
mop[nmats].rmp->dtype = rmx_write_header(mop[nmats].rmp, outfmt, stdout);
| 1001 |
if (!mop[nmats].rmp->dtype) {
| 1002 |
fprintf(stderr, "%s: unsupported output format\n", argv[0]);
| 1003 |
return(1);
| 1004 |
| 1005 |
doptimize(1); /* optimize definitions */
| 1006 |
if (spawned_children(nproc)) /* running in parent process? */
| 1007 |
return(parent_loop() ? 0 : 1);
| 1008 |
/* process & write rows */
| 1009 |
return(combine_input() ? 0 : 1);
| 1010 |
stdin_error:
| 1011 |
fprintf(stderr, "%s: %s used for more than one input\n",
| 1012 |
argv[0], stdin_name);
| 1013 |
return(1);
| 1014 |
userr:
| 1015 |
fprintf(stderr,
| 1016 |
"Usage: %s [-h][-f{adfc}][-n nproc][-e expr][-f file][-s sf .. | -c ce ..] m1 .. -m mcat > mres\n",
| 1017 |
argv[0]);
| 1018 |
return(1);
| 1019 |
