--- ray/src/util/rcomb.c 2024/02/23 03:47:57 2.7 +++ ray/src/util/rcomb.c 2024/06/07 03:55:59 2.23 @@ -1,18 +1,21 @@ #ifndef lint -static const char RCSid[] = "$Id: rcomb.c,v 2.7 2024/02/23 03:47:57 greg Exp $"; +static const char RCSid[] = "$Id: rcomb.c,v 2.23 2024/06/07 03:55:59 greg Exp $"; #endif /* * General component matrix combiner, operating on a row at a time. + * + * Multi-processing mode under Unix creates children that each work + * on one input row at a time, fed by the original process. Final conversion + * and output to stdout is sorted by last child while its siblings send it + * their record calculations. */ -#include #include #include "platform.h" +#include "rtprocess.h" #include "rtio.h" -#include "resolu.h" #include "rmatrix.h" #include "calcomp.h" -#include "paths.h" #ifndef M_PI #define M_PI 3.14159265358979323846 @@ -55,9 +58,13 @@ int cur_row; /* current input/output row */ int cur_col; /* current input/output column */ int cur_chan; /* if we're looping channels */ -static int checksymbolic(ROPMAT *rop); +SUBPROC *cproc = NULL; /* child process array */ +int nchildren = 0; /* # of child processes */ +int inchild = -1; /* our child ID (-1: parent) */ -static int +extern int checksymbolic(ROPMAT *rop); + +int split_input(ROPMAT *rop) { if (rop->rmp == &rop->imx && !(rop->rmp = rmx_copy(&rop->imx))) { @@ -69,7 +76,7 @@ split_input(ROPMAT *rop) } /* Check/set transform based on a reference input file */ -static int +int checkreffile(ROPMAT *rop) { static const char *curRF = NULL; @@ -132,7 +139,7 @@ checkreffile(ROPMAT *rop) } /* Compute conversion row from spectrum to one channel of RGB */ -static void +void rgbrow(ROPMAT *rop, int r, int p) { const int nc = rop->imx.ncomp; @@ -149,7 +156,7 @@ rgbrow(ROPMAT *rop, int r, int p) } /* Compute conversion row from spectrum to one channel of XYZ */ -static void +void xyzrow(ROPMAT *rop, int r, int p) { const int nc = rop->imx.ncomp; @@ -166,7 +173,7 @@ xyzrow(ROPMAT *rop, int r, int p) } /* Use the spectral sensitivity function to compute matrix coefficients */ -static void +void sensrow(ROPMAT *rop, int r, double (*sf)(SCOLOR sc, int ncs, const float wlpt[4])) { const int nc = rop->imx.ncomp; @@ -181,7 +188,7 @@ sensrow(ROPMAT *rop, int r, double (*sf)(SCOLOR sc, in } /* Check/set symbolic transform */ -static int +int checksymbolic(ROPMAT *rop) { const int nc = rop->imx.ncomp; @@ -295,7 +302,7 @@ checksymbolic(ROPMAT *rop) return(1); } -static int +int get_component_xfm(ROPMAT *rop) { int i, j; @@ -378,7 +385,7 @@ get_component_xfm(ROPMAT *rop) return(1); } -static int +int apply_op(RMATRIX *dst, const RMATRIX *src, const RUNARYOP *ro) { if (ro->clen > 0) { @@ -391,14 +398,13 @@ apply_op(RMATRIX *dst, const RMATRIX *src, const RUNAR return(0); rmx_free(res); } else if (dst != src) - memcpy(dst->mtx, src->mtx, - sizeof(double)*dst->ncomp*dst->ncols*dst->nrows); + memcpy(dst->mtx, src->mtx, rmx_array_size(dst)); if (ro->nsf == dst->ncomp) rmx_scale(dst, ro->sca); return(1); } -static int +int open_input(ROPMAT *rop) { int outtype; @@ -420,7 +426,7 @@ open_input(ROPMAT *rop) } /* Return nominal wavelength associated with input component (return nm) */ -static double +double l_wavelength(char *nam) { double comp = argument(1); @@ -444,7 +450,7 @@ l_wavelength(char *nam) } /* Return ith input with optional channel selector */ -static double +double l_chanin(char *nam) { double inp = argument(1); @@ -469,7 +475,7 @@ l_chanin(char *nam) return(mop[mi].rmp->mtx[cur_col*in_ncomp + chan]); } -static int +int initialize(RMATRIX *imp) { int i; @@ -516,7 +522,7 @@ initialize(RMATRIX *imp) return(1); } -static void +void output_headinfo(FILE *fp) { int i; @@ -539,16 +545,22 @@ output_headinfo(FILE *fp) } } -static int -combine_input(ROPMAT *res, FILE *fout) +int +spawned_children(int np) { - int set_r, set_c; - RMATRIX *tmp = NULL; - int co_set; - int i; - /* allocate input row buffers */ + int i, rv; + +#if defined(_WIN32) || defined(_WIN64) + if (np > 1) { + fputs("Warning: only one process under Windows\n", stderr); + np = 1; + } else +#endif + if ((in_nrows > 0) & (np*4 > in_nrows)) + np = in_nrows/4; + /* we'll be doing a row at a time */ for (i = 0; i < nmats; i++) { - mop[i].imx.nrows = 1; /* we'll be doing a row at a time */ + mop[i].imx.nrows = 1; if (!rmx_prepare(&mop[i].imx)) goto memerror; if (mop[i].rmp != &mop[i].imx) { @@ -557,22 +569,151 @@ combine_input(ROPMAT *res, FILE *fout) goto memerror; } } - /* prep output row buffers */ - if (mcat || res->preop.clen > 0) { - if (!split_input(res)) /* need separate buffer */ - return(0); - if (res->preop.clen > 0) - res->rmp->ncomp = res->preop.clen / res->imx.ncomp; - res->rmp->nrows = 1; - if (!mcat | !mcat_last && !rmx_prepare(res->rmp)) + /* prep output row buffer(s) */ + if (mop[nmats].preop.clen > 0) { + if (!split_input(&mop[nmats])) /* need separate buffer */ goto memerror; + mop[nmats].rmp->ncomp = mop[nmats].preop.clen / + mop[nmats].imx.ncomp; } - if (mcat && mcat_last && - !(tmp = rmx_alloc(1, res->imx.ncols, res->rmp->ncomp))) + mop[nmats].imx.nrows = 1; + if (!rmx_prepare(&mop[nmats].imx)) goto memerror; - res->imx.nrows = 1; - if (!rmx_prepare(&res->imx)) + if (mop[nmats].rmp != &mop[nmats].imx) { + mop[nmats].rmp->nrows = 1; + if (!rmx_prepare(mop[nmats].rmp)) + goto memerror; + } + if (np <= 1) { /* single process return */ +#ifdef getc_unlocked + for (i = 0; i < nmats; i++) + flockfile(mop[i].infp); + flockfile(stdout); +#endif + return(0); + } + fflush(stdout); /* flush header & spawn children */ + nchildren = np + 1; /* extra child to sequence output */ + cproc = (SUBPROC *)malloc(sizeof(SUBPROC)*nchildren); + if (!cproc) goto memerror; + for (i = nchildren; i--; ) cproc[i] = sp_inactive; + cproc[nchildren-1].flags |= PF_FILT_OUT; + /* start each child from parent */ + for (i = 0; i < nchildren; i++) + if ((rv = open_process(&cproc[i], NULL)) <= 0) + break; /* child breaks here */ + if (rv < 0) { + perror("fork"); /* WTH? */ + close_processes(cproc, i); + exit(1); + } + if (i != nchildren-1) { /* last child is sole reader */ + int j = i; + while (j-- > 0) { + close(cproc[j].r); + cproc[j].r = -1; + } + } + if (rv > 0) + return(1); /* parent return value */ + + inchild = i; /* else set our child index */ + while (i-- > 0) /* only parent writes siblings */ + close(cproc[i].w); + + i = nmats; /* close matrix streams (carefully) */ + while (i-- > 0) { + if (mop[i].infp != stdin) { + close(fileno(mop[i].infp)); /* avoid lseek() */ + fclose(mop[i].infp); /* ! pclose() */ + } + mop[i].infp = NULL; + } + fpurge(stdin); /* discard previously buffered input */ + + if (inchild == nchildren-1) + return(-1); /* output process return value */ + + i = nmats; /* get matrix rows from parent */ + while (i-- > 0) { + mop[i].infp = stdin; + mop[i].imx.dtype = DTrmx_native; + mop[i].imx.pflags &= ~RMF_SWAPIN; + } +#ifdef getc_unlocked + flockfile(stdin); +#endif + mop[nmats].rmp->dtype = DTrmx_native; + return(0); /* worker child return value */ +memerror: + fputs("Out of memory in spawned_children()\n", stderr); + exit(1); +} + +int +parent_loop(void) +{ + int i; + + rmx_reset(&mop[nmats].imx); /* not touching output side */ + if (mop[nmats].rmp != &mop[nmats].imx) { + rmx_free(mop[nmats].rmp); + mop[nmats].rmp = &mop[nmats].imx; + } +#ifdef getc_unlocked + for (i = 0; i < nmats; i++) /* we handle matrix inputs */ + flockfile(mop[i].infp); +#endif + /* load & send rows to kids */ + for (cur_row = 0; (in_nrows <= 0) | (cur_row < in_nrows); cur_row++) { + int wfd = cproc[cur_row % (nchildren-1)].w; + for (i = 0; i < nmats; i++) + if (!rmx_load_row(mop[i].imx.mtx, &mop[i].imx, mop[i].infp)) { + if (cur_row > in_nrows) /* unknown #input rows? */ + break; + fprintf(stderr, "%s: parent_loop() load error at row %d\n", + mop[i].inspec, cur_row); + return(0); + } + if (i < nmats) + break; + for (i = 0; i < nmats; i++) + if (writebuf(wfd, mop[i].imx.mtx, rmx_array_size(&mop[i].imx)) + != rmx_array_size(&mop[i].imx)) { + fprintf(stderr, "%s: parent_loop() write error at row %d\n", + mop[i].inspec, cur_row); + return(0); + } + } + i = close_processes(cproc, nchildren); /* collect family */ + free(cproc); cproc = NULL; nchildren = 0; + if (i < 0) { + fputs("Warning: lost child in parent_loop()\n", stderr); + return(1); + } + if (i > 0) { + fprintf(stderr, "Child exited with status %d\n", i); + return(0); + } + return(1); /* return success! */ +} + +int +combine_input(void) +{ + const int row0 = (inchild >= 0)*inchild; + const int rstep = nchildren ? nchildren-1 : 1; + ROPMAT *res = &mop[nmats]; + int set_r, set_c; + RMATRIX *tmp = NULL; + int co_set; + int i; + + if (mcat_last && !(tmp = rmx_alloc(1, res->imx.ncols, res->rmp->ncomp))) { + fputs("Out of buffer space in combine_input()\n", stderr); + return(0); + } /* figure out what the user set */ co_set = fundefined("co"); if (!co_set) @@ -588,19 +729,21 @@ combine_input(ROPMAT *res, FILE *fout) } else /* save a little time */ set_r = set_c = 0; /* read/process row-by-row */ - for (cur_row = 0; (in_nrows <= 0) | (cur_row < in_nrows); cur_row++) { + for (cur_row = row0; (in_nrows <= 0) | (cur_row < in_nrows); cur_row += rstep) { RMATRIX *mres = NULL; - for (i = 0; i < nmats; i++) { + for (i = 0; i < nmats; i++) if (!rmx_load_row(mop[i].imx.mtx, &mop[i].imx, mop[i].infp)) { if (cur_row > in_nrows) /* unknown #input rows? */ - goto loop_exit; - fprintf(stderr, "%s: read error at row %d\n", + break; + fprintf(stderr, "%s: combine_input() load error at row %d\n", mop[i].inspec, cur_row); return(0); } + if (i < nmats) + break; + for (i = 0; i < nmats; i++) if (!apply_op(mop[i].rmp, &mop[i].imx, &mop[i].preop)) return(0); - } if (set_r) varset("r", '=', cur_row); for (cur_col = 0; cur_col < in_ncols; cur_col++) { if (set_c) varset("c", '=', cur_col); @@ -638,34 +781,59 @@ combine_input(ROPMAT *res, FILE *fout) } rmx_free(mres); mres = NULL; if (!rmx_write_data(res->rmp->mtx, res->rmp->ncomp, - res->rmp->ncols, res->rmp->dtype, fout)) + res->rmp->ncols, res->rmp->dtype, stdout) || + (inchild >= 0 && fflush(stdout) == EOF)) { + fprintf(stderr, "Conversion/write error at row %d in combine_input()\n", + cur_row); return(0); + } } -loop_exit: -#if 0 /* we're about to exit, so who cares? */ - rmx_free(tmp); /* clean up */ - rmx_reset(res->rmp); - rmx_reset(&res->imx); - for (i = 0; i < nmats; i++) { - rmx_reset(mop[i].rmp); - rmx_reset(&mop[i].imx); - if (mop[i].inspec[0] == '!') - pclose(mop[i].infp); - else if (mop[i].inspec != stdin_name) - fclose(mop[i].infp); - mop[i].infp = NULL; - } -#endif - return(fflush(fout) != EOF); -memerror: - fputs("Out of buffer space in combine_input()\n", stderr); - return(0); + return(inchild >= 0 || fflush(stdout) != EOF); multerror: fputs("Unexpected matrix multiply error in combine_input()\n", stderr); return(0); } -static int +int +output_loop(void) +{ + const size_t row_size = rmx_array_size(mop[nmats].rmp); + int cur_child = 0; + int i = nmats; + + while (i-- > 0) { /* free input buffers */ + rmx_reset(&mop[i].imx); + if (mop[i].rmp != &mop[i].imx) { + rmx_free(mop[i].rmp); + mop[i].rmp = &mop[i].imx; + } + } + if (mop[nmats].rmp != &mop[nmats].imx) /* output is split? */ + rmx_reset(&mop[nmats].imx); +#ifdef getc_unlocked + flockfile(stdout); /* we own this, now */ +#endif + for ( ; ; ) { /* loop until no more */ + ssize_t rv; + rv = readbuf(cproc[cur_child].r, mop[nmats].rmp->mtx, row_size); + if (!rv) /* out of rows? */ + break; + if (rv != row_size) { + fputs("Read error in output_loop()\n", stderr); + return(0); + } /* do final conversion */ + if (!rmx_write_data(mop[nmats].rmp->mtx, mop[nmats].rmp->ncomp, + mop[nmats].rmp->ncols, mop[nmats].rmp->dtype, stdout)) { + fputs("Conversion/write error in output_loop()\n", stderr); + return(0); + } + cur_child++; + cur_child *= (cur_child < inchild); /* loop over workers */ + } + return(fflush(stdout) != EOF); +} + +int get_factors(double da[], int n, char *av[]) { int ac; @@ -675,7 +843,7 @@ get_factors(double da[], int n, char *av[]) return(ac); } -static void +void resize_inparr(int n2alloc) { int i; @@ -706,6 +874,7 @@ main(int argc, char *argv[]) const char *defCsym = NULL; int echoheader = 1; int stdin_used = 0; + int nproc = 1; const char *mcat_spec = NULL; int n2comp = 0; uby8 comp_ndx[128]; @@ -733,6 +902,11 @@ main(int argc, char *argv[]) case 'h': echoheader = !echoheader; break; + case 'n': + nproc = atoi(argv[++i]); + if (nproc <= 0) + goto userr; + break; case 'e': if (!n) goto userr; comp_ndx[n2comp++] = i++; @@ -771,13 +945,14 @@ main(int argc, char *argv[]) } break; case 'C': + mcat_last = 0; if (!n || isflt(argv[i+1])) goto userr; defCsym = mop[nmats].preop.csym = argv[++i]; mop[nmats].preop.clen = 0; - mcat_last = 0; break; case 'c': + mcat_last = 0; if (n && !isflt(argv[i+1])) { mop[nmats].preop.csym = argv[++i]; mop[nmats].preop.clen = 0; @@ -793,16 +968,15 @@ main(int argc, char *argv[]) goto userr; } mop[nmats].preop.csym = NULL; - mcat_last = 0; break; case 'm': + mcat_last = 1; if (!n) goto userr; if (argv[++i][0] == '-' && !argv[i][1]) { if (stdin_used++) goto stdin_error; mcat_spec = stdin_name; } else mcat_spec = argv[i]; - mcat_last = 1; break; default: fprintf(stderr, "%s: unknown option '%s'\n", @@ -871,15 +1045,20 @@ main(int argc, char *argv[]) return(1); } doptimize(1); /* optimize definitions */ - /* process & write rows */ - return(combine_input(&mop[nmats], stdout) ? 0 : 1); + i = spawned_children(nproc); /* create multiple processes if requested */ + if (i > 0) /* running in parent process? */ + return(parent_loop() ? 0 : 1); + if (i < 0) /* running in output process? */ + return(output_loop() ? 0 : 1); + /* else we are a worker process */ + return(combine_input() ? 0 : 1); stdin_error: fprintf(stderr, "%s: %s used for more than one input\n", argv[0], stdin_name); return(1); userr: fprintf(stderr, - "Usage: %s [-h][-f{adfc}][-e expr][-f file][-s sf .. | -c ce ..] m1 .. -m mcat > mres\n", + "Usage: %s [-h][-f{adfc}][-n nproc][-e expr][-f file][-s sf .. | -c ce ..] m1 .. -m mcat > mres\n", argv[0]); return(1); }
