--- ray/src/util/rcomb.c 2024/06/03 18:55:51 2.19 +++ ray/src/util/rcomb.c 2024/06/04 22:05:23 2.22 @@ -1,12 +1,12 @@ #ifndef lint -static const char RCSid[] = "$Id: rcomb.c,v 2.19 2024/06/03 18:55:51 greg Exp $"; +static const char RCSid[] = "$Id: rcomb.c,v 2.22 2024/06/04 22:05:23 greg Exp $"; #endif /* * General component matrix combiner, operating on a row at a time. * * Multi-processing mode under Unix creates children that each work * on one input row at a time, fed by the original process. Final conversion - * and output to stdout is sorted by first child while its siblings send it + * and output to stdout is sorted by last child while its siblings send it * their record calculations. */ @@ -62,9 +62,9 @@ SUBPROC *cproc = NULL; /* child process array */ int nchildren = 0; /* # of child processes */ int inchild = -1; /* our child ID (-1: parent) */ -static int checksymbolic(ROPMAT *rop); +extern int checksymbolic(ROPMAT *rop); -static int +int split_input(ROPMAT *rop) { if (rop->rmp == &rop->imx && !(rop->rmp = rmx_copy(&rop->imx))) { @@ -76,7 +76,7 @@ split_input(ROPMAT *rop) } /* Check/set transform based on a reference input file */ -static int +int checkreffile(ROPMAT *rop) { static const char *curRF = NULL; @@ -139,7 +139,7 @@ checkreffile(ROPMAT *rop) } /* Compute conversion row from spectrum to one channel of RGB */ -static void +void rgbrow(ROPMAT *rop, int r, int p) { const int nc = rop->imx.ncomp; @@ -156,7 +156,7 @@ rgbrow(ROPMAT *rop, int r, int p) } /* Compute conversion row from spectrum to one channel of XYZ */ -static void +void xyzrow(ROPMAT *rop, int r, int p) { const int nc = rop->imx.ncomp; @@ -173,7 +173,7 @@ xyzrow(ROPMAT *rop, int r, int p) } /* Use the spectral sensitivity function to compute matrix coefficients */ -static void +void sensrow(ROPMAT *rop, int r, double (*sf)(SCOLOR sc, int ncs, const float wlpt[4])) { const int nc = rop->imx.ncomp; @@ -188,7 +188,7 @@ sensrow(ROPMAT *rop, int r, double (*sf)(SCOLOR sc, in } /* Check/set symbolic transform */ -static int +int checksymbolic(ROPMAT *rop) { const int nc = rop->imx.ncomp; @@ -302,7 +302,7 @@ checksymbolic(ROPMAT *rop) return(1); } -static int +int get_component_xfm(ROPMAT *rop) { int i, j; @@ -385,7 +385,7 @@ get_component_xfm(ROPMAT *rop) return(1); } -static int +int apply_op(RMATRIX *dst, const RMATRIX *src, const RUNARYOP *ro) { if (ro->clen > 0) { @@ -404,7 +404,7 @@ apply_op(RMATRIX *dst, const RMATRIX *src, const RUNAR return(1); } -static int +int open_input(ROPMAT *rop) { int outtype; @@ -426,7 +426,7 @@ open_input(ROPMAT *rop) } /* Return nominal wavelength associated with input component (return nm) */ -static double +double l_wavelength(char *nam) { double comp = argument(1); @@ -450,7 +450,7 @@ l_wavelength(char *nam) } /* Return ith input with optional channel selector */ -static double +double l_chanin(char *nam) { double inp = argument(1); @@ -475,7 +475,7 @@ l_chanin(char *nam) return(mop[mi].rmp->mtx[cur_col*in_ncomp + chan]); } -static int +int initialize(RMATRIX *imp) { int i; @@ -522,7 +522,7 @@ initialize(RMATRIX *imp) return(1); } -static void +void output_headinfo(FILE *fp) { int i; @@ -545,25 +545,9 @@ output_headinfo(FILE *fp) } } -static void -reset_inputs(void) -{ - int i = nmats; - - fpurge(stdin); /* discard previous matrix input */ - while (i--) { - if (mop[i].infp != stdin) - fclose(mop[i].infp); /* ! pclose() */ - mop[i].infp = stdin; - mop[i].imx.dtype = DTdouble; - mop[i].imx.pflags &= ~RMF_SWAPIN; - } -} - -static int +int spawned_children(int np) { - size_t recsize = 0; int i, rv; #if defined(_WIN32) || defined(_WIN64) @@ -579,27 +563,28 @@ spawned_children(int np) mop[i].imx.nrows = 1; if (!rmx_prepare(&mop[i].imx)) goto memerror; - recsize += rmx_array_size(&mop[i].imx); if (mop[i].rmp != &mop[i].imx) { mop[i].rmp->nrows = 1; if (!rmx_prepare(mop[i].rmp)) goto memerror; } } - /* prep output row buffer */ + /* prep output row buffer(s) */ if (mcat || mop[nmats].preop.clen > 0) { if (!split_input(&mop[nmats])) /* need separate buffer */ return(0); if (mop[nmats].preop.clen > 0) mop[nmats].rmp->ncomp = mop[nmats].preop.clen / mop[nmats].imx.ncomp; - mop[nmats].rmp->nrows = 1; - if (!mcat | !mcat_last && !rmx_prepare(mop[nmats].rmp)) - goto memerror; } mop[nmats].imx.nrows = 1; if (!rmx_prepare(&mop[nmats].imx)) goto memerror; + if (mop[nmats].rmp != &mop[nmats].imx) { + mop[nmats].rmp->nrows = 1; + if (!rmx_prepare(mop[nmats].rmp)) + goto memerror; + } if (np <= 1) { /* single process return */ #ifdef getc_unlocked for (i = 0; i < nmats; i++) @@ -609,74 +594,81 @@ spawned_children(int np) return(0); } fflush(stdout); /* flush header & spawn children */ - nchildren = np+1; + nchildren = np + 1; /* extra child to sequence output */ cproc = (SUBPROC *)malloc(sizeof(SUBPROC)*nchildren); if (!cproc) goto memerror; - /* first child becomes stdout filter */ - cproc[0].flags = PF_FILT_OUT; - cproc[0].w = fileno(stdout); - cproc[0].r = 0; - cproc[0].pid = -1; - rv = open_process(&cproc[i], NULL); - if (rv < 0) { - perror("fork"); - exit(1); - } - if (rv == 0) { /* loop if first child */ - inchild = 0; - reset_inputs(); - output_loop(); - _exit(0); - } - /* start other children */ - for (i = 1; (i < nchildren) & (rv > 0); i++) { - cproc[i].flags = 0; - cproc[i].w = 1; - cproc[i].r = 0; - cproc[i].pid = -1; + for (i = nchildren; i--; ) cproc[i] = sp_inactive; + cproc[nchildren-1].flags |= PF_FILT_OUT; + /* start each child */ + for (i = 0; i < nchildren; i++) { rv = open_process(&cproc[i], NULL); + if (rv <= 0) break; } if (rv < 0) { perror("fork"); close_processes(cproc, i); exit(1); } - if (rv > 0) /* parent return? */ - return(1); + if (rv) { /* are we the parent? */ + i = nchildren-1; /* last child is sole reader */ + while (i-- > 0) { + close(cproc[i].r); + cproc[i].r = -1; + } + return(1); /* parent return value */ + } inchild = i; /* our child index */ - while (--i > 0) /* don't share siblings' pipes */ + while (i-- > 0) /* only parent writes siblings */ close(cproc[i].w); - reset_inputs(); + + if (inchild == nchildren-1) + return(-1); /* output process return value */ + + i = inchild; /* won't read from siblings */ + while (i-- > 0) + close(cproc[i].r); + i = nmats; /* redirect input matrix streams */ + while (i-- > 0) { + if (mop[i].infp != stdin) + fclose(mop[i].infp); /* ! pclose() */ + mop[i].infp = stdin; + mop[i].imx.dtype = DTrmx_native; + mop[i].imx.pflags &= ~RMF_SWAPIN; + } + fpurge(stdin); /* discard any previous matrix input */ #ifdef getc_unlocked flockfile(stdin); #endif - return(0); /* child return */ + mop[nmats].rmp->dtype = DTrmx_native; + return(0); /* worker child return value */ memerror: fputs("Out of memory in spawned_children()\n", stderr); exit(1); } -static int +int parent_loop(void) { int i; - rmx_reset(&mop[nmats].imx); /* not doing output side */ - if (mop[nmats].rmp != &mop[nmats].imx) - rmx_reset(mop[nmats].rmp); + rmx_reset(&mop[nmats].imx); /* not touching output side */ + if (mop[nmats].rmp != &mop[nmats].imx) { + rmx_free(mop[nmats].rmp); + mop[nmats].rmp = &mop[nmats].imx; + } #ifdef getc_unlocked - for (i = 0; i < nmats; i++) + for (i = 0; i < nmats; i++) /* we handle matrix inputs */ flockfile(mop[i].infp); #endif /* load & send rows to kids */ for (cur_row = 0; (in_nrows <= 0) | (cur_row < in_nrows); cur_row++) { - int wfd = cproc[1 + cur_row%(nchildren-1)].w; + int wfd = cproc[cur_row % (nchildren-1)].w; for (i = 0; i < nmats; i++) if (!rmx_load_row(mop[i].imx.mtx, &mop[i].imx, mop[i].infp)) { if (cur_row > in_nrows) /* unknown #input rows? */ break; - fprintf(stderr, "%s: read error at row %d\n", + fprintf(stderr, "%s: parent read error at row %d\n", mop[i].inspec, cur_row); return(0); } @@ -688,26 +680,26 @@ parent_loop(void) return(0); } i = close_processes(cproc, nchildren); - free(cproc); cproc = NULL; + free(cproc); cproc = NULL; nchildren = 0; if (i < 0) { - fputs("Warning: missing child in parent_loop()\n", stderr); + fputs("Warning: lost child in parent_loop()\n", stderr); return(1); } if (i > 0) { fprintf(stderr, "Child exited with status %d\n", i); return(0); } - return(1); + return(1); /* return success! */ memerror: fputs("Out of memory in parent_loop()\n", stderr); exit(1); } -static int +int combine_input(void) { - const int row0 = (inchild > 0)*(inchild-1); - const int rstep = nchildren + !nchildren; + const int row0 = (inchild >= 0)*inchild; + const int rstep = nchildren ? nchildren-1 : 1; ROPMAT *res = &mop[nmats]; int set_r, set_c; RMATRIX *tmp = NULL; @@ -783,17 +775,13 @@ combine_input(void) return(0); } rmx_free(mres); mres = NULL; - if (inchild > 0) { /* children share stdout */ - i = getc(stdin); /* signals it's our turn */ - if (i != EOF) ungetc(i, stdin); - } if (!rmx_write_data(res->rmp->mtx, res->rmp->ncomp, res->rmp->ncols, res->rmp->dtype, stdout)) return(0); - if (inchild > 0 && fflush(stdout) == EOF) + if (inchild >= 0 && fflush(stdout) == EOF) return(0); } - return(inchild > 0 || fflush(stdout) != EOF); + return(inchild >= 0 || fflush(stdout) != EOF); memerror: fputs("Out of buffer space in combine_input()\n", stderr); return(0); @@ -802,7 +790,48 @@ multerror: return(0); } -static int +int +output_loop(void) +{ + const size_t row_size = rmx_array_size(mop[nmats].rmp); + int i = nmats; + int cur_child = 0; + + if (mop[nmats].rmp != &mop[nmats].imx) /* output is split? */ + rmx_reset(&mop[nmats].imx); + while (i-- > 0) { /* close input matrices */ + fclose(mop[i].infp); /* ! pclose() */ + mop[i].infp = NULL; + rmx_reset(&mop[i].imx); + if (mop[i].rmp != &mop[i].imx) { + rmx_free(mop[i].rmp); + mop[i].rmp = &mop[i].imx; + } + } +#ifdef getc_unlocked + flockfile(stdout); /* we own this, now */ +#endif + for ( ; ; ) { /* loop until no more */ + ssize_t rv; + rv = readbuf(cproc[cur_child].r, mop[nmats].rmp->mtx, row_size); + if (!rv) /* out of rows? */ + break; + if (rv != row_size) { + fputs("Read error in output loop\n", stderr); + return(0); + } /* do final conversion */ + if (!rmx_write_data(mop[nmats].rmp->mtx, mop[nmats].rmp->ncomp, + mop[nmats].rmp->ncols, mop[nmats].rmp->dtype, stdout)) { + fputs("Conversion/write error in output loop\n", stderr); + return(0); + } + cur_child++; + cur_child *= (cur_child < inchild); + } + return(fflush(stdout) != EOF); +} + +int get_factors(double da[], int n, char *av[]) { int ac; @@ -812,7 +841,7 @@ get_factors(double da[], int n, char *av[]) return(ac); } -static void +void resize_inparr(int n2alloc) { int i; @@ -1015,9 +1044,12 @@ main(int argc, char *argv[]) return(1); } doptimize(1); /* optimize definitions */ - if (spawned_children(nproc)) /* running in parent process? */ + i = spawned_children(nproc); /* create multiple processes if requested */ + if (i > 0) /* running in parent process? */ return(parent_loop() ? 0 : 1); - /* process & write rows */ + if (i < 0) /* running in output process? */ + return(output_loop() ? 0 : 1); + /* else we are a worker process */ return(combine_input() ? 0 : 1); stdin_error: fprintf(stderr, "%s: %s used for more than one input\n",
